006b4500d188491bec31dcfa180916c2
b918ae3d
b918ae3d
Samuel MEYNARD
Ajout etude stackoverflow
19885907
429 additions
17 deletions
+429
-17
exercice_python_fr.org
module3/exo3/exercice_python_fr.org
+429
-17
b918ae3d
@@ -36,7 +36,8 @@ _Votre mission si vous l'acceptez :_
5. Répétez les étapes précédentes avec le second jeu de données (stackoverflow)
6. Déposer dans FUN votre résultat
* Récupération du 1^er jeu de donnée
* Liglab2
** Récupération du 1^er jeu de donnée
** Téléchargement
#+BEGIN_SRC python :session :file step1.txt :results file
from urllib.request import urlretrieve
@@ -75,20 +76,19 @@ cleantable[:4]
| [1421761682.502054] | 262 | bytes | from | lig-publig.imag.fr | (129.88.11.7): | icmp_seq=1 | ttl=60 | time=21.2 | ms |
| [1421761682.729257] | 1107 | bytes | from | lig-publig.imag.fr | (129.88.11.7): | icmp_seq=1 | ttl=60 | time=23.3 | ms |
#+BEGIN_SRC python :session :results
output
replace
#+BEGIN_SRC python :session :results replace
from datetime import datetime
date = [datetime.utcfromtimestamp(float(row[0][1:-1])) for row in cleantable]
donnee
= [int(row[1]) for row in cleantable]
S
source = [str(row[4]) for row in cleantable]
ip = [str(row[5][1:-1]) for row in cleantable]
ltime = [float(row[8].split('=')[1]) for row in cleantable]
T = [float(row[8].split('=')[1]) for row in cleantable]
dataset = list(zip(date,donnee, ltime))
print(dataset[:4])
T[:10]
#+END_SRC
: [(datetime.datetime(2015, 1, 20, 13, 48, 2, 52172), 665, 22.5), (datetime.datetime(2015, 1, 20, 13, 48, 2, 277315), 1373, 21.2), (datetime.datetime(2015, 1, 20, 13, 48, 2, 502054), 262, 21.2), (datetime.datetime(2015, 1, 20, 13, 48, 2, 729257), 1107, 23.3)]
| 22.5 | 21.2 | 21.2 | 23.3 | 1.41 | 21.9 | 78.7 | 25.1 | 24.0 | 19.5 |
#+BEGIN_SRC python :session :results silent :file test.png
import matplotlib
@@ -98,20 +98,275 @@ fig, ax = plt.subplots(figsize=(12, 12))
# Add x-axis and y-axis
ax.scatter(date,
ltime
T
color='purple')
# Set title and labels for axes
ax.set(xlabel="Date",
ylabel="Latence",
title="Evolution de la latence dans le temps")
ylabel="Temps de transmission",
title="Evolution de la temps de transmission dans le temps")
plt.savefig('evol_temps_transmission_dans_le_temps.png')
#+END_SRC
: None
Il ne semble pas avoir d'impact au travers le temps
** Evolution du temps de transmission à travers le temps
#+BEGIN_SRC python :session :results silent :file test2.png
import matplotlib
# Create figure and plot space
ax.scatter(S,
T,
color='purple')
ax.set(xlabel="Taille des donnee",
title="Evolution du temps de transmission en fonction de la taille des données")
plt.savefig('evol_temps_transmission_en_fonction_de_la_taille.png')
#+END_SRC
Ici, on voit l'impact de la MTU ici certainement à 1500 sur le temps de transport
** Differenciation par rapport à la taille
*** Inférieur à la MTU
table_l1500 = [row for row in cleantable if int(row[1]) <= 1485]
date_l1500 = [datetime.utcfromtimestamp(float(row[0][1:-1])) for row in table_l1500]
S_l1500 = [int(row[1]) for row in table_l1500]
T_l1500 = [float(row[8].split('=')[1]) for row in table_l1500]
dataset_l1500 = list(zip(date_l1500,S_l1500, T_l1500))
dataset_l1500[:10]
#+END_SRC
| datetime.datetime | (2015 1 20 13 48 2 52172) | 665 | 22.5 |
| datetime.datetime | (2015 1 20 13 48 2 277315) | 1373 | 21.2 |
| datetime.datetime | (2015 1 20 13 48 2 502054) | 262 | 21.2 |
| datetime.datetime | (2015 1 20 13 48 2 729257) | 1107 | 23.3 |
| datetime.datetime | (2015 1 20 13 48 2 934648) | 1128 | 1.41 |
| datetime.datetime | (2015 1 20 13 48 3 160397) | 489 | 21.9 |
| datetime.datetime | (2015 1 20 13 48 3 672157) | 1146 | 25.1 |
| datetime.datetime | (2015 1 20 13 48 3 899933) | 884 | 24.0 |
| datetime.datetime | (2015 1 20 13 48 4 122687) | 1422 | 19.5 |
| datetime.datetime | (2015 1 20 13 48 4 344135) | 1180 | 18.0 |
import matplotlib
ax.scatter(S_l1500,
T_l1500,
color='purple')
plt.savefig('l1500_evol_T-f(S).png')
#+END_SRC
*** Supérieur à la MTU
Calcul d'un tableau avec les donnée supérieure à la MTU
table_g1500 = [row for row in cleantable if int(row[1]) >= 1485]
date_g1500 = [datetime.utcfromtimestamp(float(row[0][1:-1])) for row in table_g1500]
S_g1500 = [int(row[1]) for row in table_g1500]
T_g1500 = [float(row[8].split('=')[1]) for row in table_g1500]
dataset_g1500 = list(zip(date_g1500,S_g1500, T_g1500))
dataset_g1500[:10]
#+END_SRC
| datetime.datetime | (2015 1 20 13 48 3 443055) | 1759 | 78.7 |
| datetime.datetime | (2015 1 20 13 48 5 620117) | 1843 | 2.31 |
| datetime.datetime | (2015 1 20 13 48 6 234464) | 1511 | 2.18 |
| datetime.datetime | (2015 1 20 13 48 7 463275) | 1510 | 2.17 |
| datetime.datetime | (2015 1 20 13 48 7 874230) | 1966 | 2.2 |
| datetime.datetime | (2015 1 20 13 48 8 694652) | 1518 | 2.19 |
| datetime.datetime | (2015 1 20 13 48 10 335289) | 1732 | 2.29 |
| datetime.datetime | (2015 1 20 13 48 10 950126) | 1500 | 2.14 |
| datetime.datetime | (2015 1 20 13 48 11 359824) | 1520 | 2.1 |
| datetime.datetime | (2015 1 20 13 48 11 974735) | 1509 | 2.23 |
import matplotlib
ax.scatter(S_g1500,
T_g1500,
color='purple')
plt.savefig('g1500_evol_T-f(S).png')
#+END_SRC
** Régression linéaire
** Cas inférieur à la MTU
from matplotlib import dates
from scipy import stats
import seaborn as sns
from sklearn import linear_model
@plt.FuncFormatter
def fake_dates(x, pos):
""" Custom formater to turn floats into e.g., 2016-05-08"""
return dates.num2date(x).strftime('%Y-%m-%d')
sns.set(color_codes=True)
df = pd.DataFrame({
'date': pd.to_datetime(date_l1500),
'datenum': dates.date2num(date_l1500),
'T': T_l1500,
'S': S_l1500})
fig, ax = plt.subplots()
sns.regplot(x="datenum", y="T", color='purple', data=df, ax=ax)
# here's the magic:
ax.xaxis.set_major_formatter(fake_dates)
# legible labels
ax.tick_params(labelrotation=30)
fig.savefig('l1500_reglineaireT-f(S).png')
#+END_SRC
: None
np.array(S_l1500).reshape(1, -1)[:9]
#+END_SRC
| 1759 | 1843 | 1511 | ... | 1503 | 1515 | 1875 |
from sklearn.linear_model import LinearRegression
from sklearn.metrics import mean_squared_error
S_tt = [[value] for value in S_l1500]
my_s = np.array(S_tt)
my_t = np.array(T_l1500)
#my_s = np.array([[1], [2], [3]])
lmodel = LinearRegression()
lmodel.fit(my_s, my_t)
f"Les coeff sont L = {lmodel.intercept_} et C = { 1 / lmodel.coef_}"
#+END_SRC
: Les coeff sont L = 3.257592785874401 et C = [2761.3155395]
** Cas supérieur à la MTU
S_tt = [[value] for value in S_g1500]
my_t = np.array(T_g1500)
plt.savefig('test.png')
#+END_SRC
: Les coeff sont L = 5.867233082184833 et C = [441.71908009]
* Stackoverflow
** Récupération du jeu de donnée
*** Téléchargement
#+BEGIN_SRC python :session :file step1.txt :results replace
from os import path
stacko_file = "stackoverflow.log"
stacko_filegz = stacko_file + ".gz"
url = "http://mescal.imag.fr/membres/arnaud.legrand/teaching/2014/RICM4_EP_ping/stackoverflow.log.gz"
if not path.exists(stacko_file):
urlretrieve(url, stacko_filegz)
#+END_SRC
: None
*** Lecture du fichier
#+BEGIN_SRC python :session :results output
import gzip
f = gzip.open(stacko_filegz)
data = f.read().decode('latin-1').strip().splitlines()
f.close()
#+END_SRC
table = [row.split(' ') for row in data]
cleantable = []
for row in table:
if len(row) == 10:
cleantable.append(row)
cleantable[:4]
#+END_SRC
| [1421771203.082701] | 1257 | bytes | from | stackoverflow.com | (198.252.206.140): | icmp_seq=1 | ttl=50 | time=120 | ms |
| [1421771203.408254] | 454 | bytes | from | stackoverflow.com | (198.252.206.140): | icmp_seq=1 | ttl=50 | time=120 | ms |
| [1421771203.739730] | 775 | bytes | from | stackoverflow.com | (198.252.206.140): | icmp_seq=1 | ttl=50 | time=126 | ms |
| [1421771204.056630] | 1334 | bytes | from | stackoverflow.com | (198.252.206.140): | icmp_seq=1 | ttl=50 | time=112 | ms |
S = [int(row[1]) for row in cleantable]
T[:10]
#+END_SRC
| 120.0 | 120.0 | 126.0 | 112.0 | 111.0 | 111.0 | 112.0 | 111.0 | 111.0 | 111.0 |
import matplotlib
ax.scatter(date,
T,
color='purple')
plt.savefig('stacko_evol_temps_transmission_dans_le_temps.png')
#+END_SRC
: None
import matplotlib
@@ -119,16 +374,173 @@ import matplotlib.pyplot as plt
ax.scatter(
donnee
ltime
ax.scatter(
S
T
color='purple')
ylabel="
Latence
title="Evolution d
s")
ylabel="
title="Evolution d
s")
plt.savefig('
test2
.png')
plt.savefig('
stacko_evol_temps_transmission_en_fonction_de_la_taille
.png')
#+END_SRC
*** Differenciation par rapport à la taille
**** Inférieur à la MTU
dataset_l1500[:10]
#+END_SRC
| datetime.datetime | (2015 1 20 16 26 43 82701) | 1257 | 120.0 |
| datetime.datetime | (2015 1 20 16 26 43 408254) | 454 | 120.0 |
| datetime.datetime | (2015 1 20 16 26 43 739730) | 775 | 126.0 |
| datetime.datetime | (2015 1 20 16 26 44 56630) | 1334 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 44 372224) | 83 | 111.0 |
| datetime.datetime | (2015 1 20 16 26 44 688367) | 694 | 111.0 |
| datetime.datetime | (2015 1 20 16 26 45 321112) | 632 | 111.0 |
| datetime.datetime | (2015 1 20 16 26 45 637464) | 405 | 111.0 |
| datetime.datetime | (2015 1 20 16 26 45 953472) | 1419 | 111.0 |
| datetime.datetime | (2015 1 20 16 26 46 269163) | 329 | 111.0 |
import matplotlib
ax.scatter(S_l1500,
T_l1500,
color='purple')
plt.savefig('stacko_l1500_evol_T-f(S).png')
#+END_SRC
**** Supérieur à la MTU
dataset_g1500[:10]
#+END_SRC
| datetime.datetime | (2015 1 20 16 26 45 5514) | 1577 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 46 901972) | 1714 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 47 851148) | 1598 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 52 272504) | 1619 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 55 749652) | 1655 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 56 66885) | 1556 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 57 648057) | 1839 | 112.0 |
| datetime.datetime | (2015 1 20 16 26 58 280820) | 1572 | 112.0 |
| datetime.datetime | (2015 1 20 16 27 1 133246) | 1491 | 120.0 |
| datetime.datetime | (2015 1 20 16 27 1 765499) | 1978 | 112.0 |
import matplotlib
ax.scatter(S_g1500,
T_g1500,
color='purple')
plt.savefig('stacko_g1500_evol_T-f(S).png')
#+END_SRC
*** Cas inférieur à la MTU
@plt.FuncFormatter
df = pd.DataFrame({
'T': T_l1500,
'S': S_l1500})
# here's the magic:
# legible labels
fig.savefig('stacko_l1500_reglineaireT-f(S).png')
#+END_SRC
: None
#+END_SRC
#+END_SRC
*** Cas supérieur à la MTU
#+END_SRC
