"A method that is easier to understand and does not make use of the sin function is based on the\n",
"fact that if X ∼ U(0, 1) and Y ∼ U(0, 1), then P[X² + Y² ≤ 1] = π/4 (see \"Monte Carlo method\" on Wikipedia). \n",
"The following code uses this approach:"
"A method that is easier to understand and does not make use of the $\\sin$ function is based on the fact that if $X\\sim U(0,1)$ and $Y\\sim U(0,1)$, then $P[X^2+Y^2\\leq 1] = \\pi/4$ (see [\"Monte Carlo method\" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:"
