From 80ce5f28a3e597c83d9979918523e3f03c55bffb Mon Sep 17 00:00:00 2001 From: Renaud Marti Date: Tue, 23 Feb 2021 09:53:19 +0100 Subject: [PATCH] Modif Windows Renaud --- .ipynb_checkpoints/readme-checkpoint.md | 11 + .../.ipynb_checkpoints/README-checkpoint.md | 1 + ...se-syndrome-grippal-Copy1-checkpoint.ipynb | 1038 +++++++++ .../analyse-syndrome-grippal-checkpoint.ipynb | 372 ++++ .../exo1/analyse-syndrome-grippal-Copy1.ipynb | 1038 +++++++++ module3/exo1/analyse-syndrome-grippal.ipynb | 2 +- module3/exo1/incidence.csv | 1896 +++++++++++++++++ .../exercice_en-checkpoint.ipynb | 25 + .../exercice_fr-checkpoint.ipynb | 25 + .../exercice_fr-checkpoint.ipynb | 930 ++++++++ module3/exo3/exercice_fr.ipynb | 913 +++++++- module3/exo3/incidence_varicelles.csv | 1578 ++++++++++++++ 12 files changed, 7824 insertions(+), 5 deletions(-) create mode 100644 .ipynb_checkpoints/readme-checkpoint.md create mode 100644 module3/.ipynb_checkpoints/README-checkpoint.md create mode 100644 module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-Copy1-checkpoint.ipynb create mode 100644 module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-checkpoint.ipynb create mode 100644 module3/exo1/analyse-syndrome-grippal-Copy1.ipynb create mode 100644 module3/exo1/incidence.csv create mode 100644 module3/exo2/.ipynb_checkpoints/exercice_en-checkpoint.ipynb create mode 100644 module3/exo2/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb create mode 100644 module3/exo3/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb create mode 100644 module3/exo3/incidence_varicelles.csv diff --git a/.ipynb_checkpoints/readme-checkpoint.md b/.ipynb_checkpoints/readme-checkpoint.md new file mode 100644 index 0000000..9259ffa --- /dev/null +++ b/.ipynb_checkpoints/readme-checkpoint.md @@ -0,0 +1,11 @@ +# MOOC Recherche Reproductible / Reproducibleesearch Mooc + +FR + +Ce dépôt contient les fichiers utiles au MOOC Recherche Reproductible. + +EN + +This repository contains useful files for the Reproducible Research MOOC. + +Ceci est un test. Un deuxième test depuis Windows ! Un de plus en mode graphique. Un troisième essai. diff --git a/module3/.ipynb_checkpoints/README-checkpoint.md b/module3/.ipynb_checkpoints/README-checkpoint.md new file mode 100644 index 0000000..7d100eb --- /dev/null +++ b/module3/.ipynb_checkpoints/README-checkpoint.md @@ -0,0 +1 @@ +Module 3 diff --git a/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-Copy1-checkpoint.ipynb b/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-Copy1-checkpoint.ipynb new file mode 100644 index 0000000..4cad743 --- /dev/null +++ b/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-Copy1-checkpoint.ipynb @@ -0,0 +1,1038 @@ +{ + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Incidence du syndrome grippal" + ] + }, + { + "cell_type": "code", + "execution_count": 38, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek\n", + "import requests\n", + "import csv\n", + "from pathlib import Path" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Les données de l'incidence du syndrome grippal sont disponibles du site Web du [Réseau Sentinelles](http://www.sentiweb.fr/). Nous les récupérons sous forme d'un fichier en format CSV dont chaque ligne correspond à une semaine de la période demandée. Nous téléchargeons toujours le jeu de données complet, qui commence en 1984 et se termine avec une semaine récente." + ] + }, + { + "cell_type": "code", + "execution_count": 39, + "metadata": {}, + "outputs": [], + "source": [ + "r = requests.get(\"https://www.sentiweb.fr/datasets/incidence-PAY-3.csv\") # on envoie ne requête http à l'aide de la bibliothèque \"requests\" et on récupère le contenu dans l'objet 'r'" + ] + }, + { + "cell_type": "code", + "execution_count": 46, + "metadata": {}, + "outputs": [], + "source": [ + "file = r\"C:\\Users\\renau\\mooc-rr\\module3\\exo1\\incidence.csv\" # on teste si le fichier des données existent\n", + "if (Path(file).is_file() == False):\n", + " file_data = open(r\"C:\\Users\\renau\\mooc-rr\\module3\\exo1\\incidence.csv\",\"w\",encoding = \"ANSI\") # création d'un fichier vide accesible en écriture\n", + " file_data.write(r.text) # écriture dans le fichier du contenu de la requête au format texte\n", + " print(\"Ce fichier a été téléchargé depuis l'url du site du réseau **Sentinelles**\")\n", + " file_data.close()" + ] + }, + { + "cell_type": "code", + "execution_count": 47, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "'C:\\\\Users\\\\renau\\\\mooc-rr\\\\module3\\\\exo1\\\\incidence.csv'" + ] + }, + "execution_count": 47, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "file" + ] + }, + { + "cell_type": "code", + "execution_count": 48, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
weekindicatorincinc_lowinc_upinc100inc100_lowinc100_upgeo_inseegeo_name
020210632381618867.028765.03629.043.0FRFrance
120210532249118436.026546.03428.040.0FRFrance
220210432580421491.030117.03932.046.0FRFrance
320210332181017894.025726.03327.039.0FRFrance
420210231732013906.020734.02621.031.0FRFrance
188919844837862060634.096606.0143110.0176.0FRFrance
189019844737202954274.089784.013199.0163.0FRFrance
189119844638733067686.0106974.0159123.0195.0FRFrance
18921984453135223101414.0169032.0246184.0308.0FRFrance
189319844436842220056.0116788.012537.0213.0FRFrance
\n", + "
1894 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 3 23816 18867.0 28765.0 36 29.0 \n", + "1 202105 3 22491 18436.0 26546.0 34 28.0 \n", + "2 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "3 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "4 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "... ... ... ... ... ... ... ... \n", + "1889 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1890 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1891 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1892 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1893 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 43.0 FR France \n", + "1 40.0 FR France \n", + "2 46.0 FR France \n", + "3 39.0 FR France \n", + "4 31.0 FR France \n", + "... ... ... ... \n", + "1889 176.0 FR France \n", + "1890 163.0 FR France \n", + "1891 195.0 FR France \n", + "1892 308.0 FR France \n", + "1893 213.0 FR France \n", + "\n", + "[1894 rows x 10 columns]" + ] + }, + "execution_count": 48, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data = pd.read_csv(file, sep=',', encoding = 'ansi', skiprows=1) # on lit le fichier csv, en tant que panda data frame\n", + "raw_data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici l'explication des colonnes données [sur le site d'origine](https://ns.sentiweb.fr/incidence/csv-schema-v1.json):\n", + "\n", + "| Nom de colonne | Libellé de colonne |\n", + "|----------------|-----------------------------------------------------------------------------------------------------------------------------------|\n", + "| week | Semaine calendaire (ISO 8601) |\n", + "| indicator | Code de l'indicateur de surveillance |\n", + "| inc | Estimation de l'incidence de consultations en nombre de cas |\n", + "| inc_low | Estimation de la borne inférieure de l'IC95% du nombre de cas de consultation |\n", + "| inc_up | Estimation de la borne supérieure de l'IC95% du nombre de cas de consultation |\n", + "| inc100 | Estimation du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_low | Estimation de la borne inférieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_up | Estimation de la borne supérieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| geo_insee | Code de la zone géographique concernée (Code INSEE) http://www.insee.fr/fr/methodes/nomenclatures/cog/ |\n", + "| geo_name | Libellé de la zone géographique (ce libellé peut être modifié sans préavis) |\n", + "\n", + "La première ligne du fichier CSV est un commentaire, que nous ignorons en précisant `skiprows=1`." + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Y a-t-il des points manquants dans ce jeux de données ? Oui, la semaine 19 de l'année 1989 n'a pas de valeurs associées." + ] + }, + { + "cell_type": "code", + "execution_count": 49, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
165719891930NaNNaN0NaNNaNFRFrance
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low inc100_up \\\n", + "1657 198919 3 0 NaN NaN 0 NaN NaN \n", + "\n", + " geo_insee geo_name \n", + "1657 FR France " + ] + }, + "execution_count": 49, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous éliminons ce point, ce qui n'a pas d'impact fort sur notre analyse qui est assez simple." + ] + }, + { + "cell_type": "code", + "execution_count": 50, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "
1893 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 3 23816 18867.0 28765.0 36 29.0 \n", + "1 202105 3 22491 18436.0 26546.0 34 28.0 \n", + "2 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "3 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "4 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "... ... ... ... ... ... ... ... \n", + "1889 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1890 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1891 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1892 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1893 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 43.0 FR France \n", + "1 40.0 FR France \n", + "2 46.0 FR France \n", + "3 39.0 FR France \n", + "4 31.0 FR France \n", + "... ... ... ... \n", + "1889 176.0 FR France \n", + "1890 163.0 FR France \n", + "1891 195.0 FR France \n", + "1892 308.0 FR France \n", + "1893 213.0 FR France \n", + "\n", + "[1893 rows x 10 columns]" + ] + }, + "execution_count": 50, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nos données utilisent une convention inhabituelle: le numéro de\n", + "semaine est collé à l'année, donnant l'impression qu'il s'agit\n", + "de nombre entier. C'est comme ça que Pandas les interprète.\n", + " \n", + "Un deuxième problème est que Pandas ne comprend pas les numéros de\n", + "semaine. Il faut lui fournir les dates de début et de fin de\n", + "semaine. Nous utilisons pour cela la bibliothèque `isoweek`.\n", + "\n", + "Comme la conversion des semaines est devenu assez complexe, nous\n", + "écrivons une petite fonction Python pour cela. Ensuite, nous\n", + "l'appliquons à tous les points de nos donnés. Les résultats vont\n", + "dans une nouvelle colonne 'period'." + ] + }, + { + "cell_type": "code", + "execution_count": 51, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Il restent deux petites modifications à faire.\n", + "\n", + "Premièrement, nous définissons les périodes d'observation\n", + "comme nouvel index de notre jeux de données. Ceci en fait\n", + "une suite chronologique, ce qui sera pratique par la suite.\n", + "\n", + "Deuxièmement, nous trions les points par période, dans\n", + "le sens chronologique." + ] + }, + { + "cell_type": "code", + "execution_count": 52, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous vérifions la cohérence des données. Entre la fin d'une période et\n", + "le début de la période qui suit, la différence temporelle doit être\n", + "zéro, ou au moins très faible. Nous laissons une \"marge d'erreur\"\n", + "d'une seconde.\n", + "\n", + "Ceci s'avère tout à fait juste sauf pour deux périodes consécutives\n", + "entre lesquelles il manque une semaine.\n", + "\n", + "Nous reconnaissons ces dates: c'est la semaine sans observations\n", + "que nous avions supprimées !" + ] + }, + { + "cell_type": "code", + "execution_count": 53, + "metadata": {}, + "outputs": [ + { + "name": "stdout", + "output_type": "stream", + "text": [ + "1989-05-01/1989-05-07 1989-05-15/1989-05-21\n" + ] + } + ], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un premier regard sur les données !" + ] + }, + { + "cell_type": "code", + "execution_count": 54, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 54, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "iVBORw0KGgoAAAANSUhEUgAAAXYAAAERCAYAAABvr4yHAAAAOXRFWHRTb2Z0d2FyZQBNYXRwbG90bGliIHZlcnNpb24zLjMuMiwgaHR0cHM6Ly9tYXRwbG90bGliLm9yZy8vihELAAAACXBIWXMAAAsTAAALEwEAmpwYAABaCElEQVR4nO19d5wcxZn2807cpLyrgAISQQSTERhMNrYJn+/D2djYOJ0xd+Dzd3c+G9t35zvjgH2+s302mOMIDtjgBDaYjAkGYYQkhIQkhFDWKq+kzWF2Zur7o7u6q3u6qqt3emd6V/X8fvvbCTVVb1dXP/XWU29VEWMMBgYGBgbjB6l6G2BgYGBgEC8MsRsYGBiMMxhiNzAwMBhnMMRuYGBgMM5giN3AwMBgnMEQu4GBgcE4Q12JnYjuJKK9RLRaM/0HiGgtEa0hol+Otn0GBgYGYxFUzzh2IjofQC+AnzHGTghJezSAXwN4K2PsIBFNZ4ztrYWdBgYGBmMJdfXYGWN/BnBA/IyIjiSiR4loORE9R0TH2l99GsDNjLGD9m8NqRsYGBgEIIka+20APssYOx3A5wHcYn++EMBCIlpMRC8S0aV1s9DAwMAgwcjU2wARRNQC4C0AfkNE/OO8/T8D4GgAFwKYA+A5IjqBMdZZYzMNDAwMEo1EETusEUQnY+yUgO/aAbzIGBsGsJmIXodF9EtraJ+BgYFB4pEoKYYx1g2LtN8PAGThZPvr3wO4yP68FZY0s6kedhoYGBgkGfUOd7wHwF8AHENE7UT0KQBXAfgUEa0EsAbAFXbyxwDsJ6K1AJ4G8E+Msf31sNvAwMAgyahruKOBgYGBQfxIlBRjYGBgYFA96jZ52trayubPn1+v4g0MDAzGJJYvX97BGGtTpakbsc+fPx/Lli2rV/EGBgYGYxJEtDUsjZFiDAwMDMYZDLEbGBgYjDMYYjcwMDAYZzDEbmBgYDDOYIjdwMDAYJwhlNjDDsOwl/3/NxFtIKJVRHRa/GYaGBgYGOhCx2P/CQDVFrmXwdqM62gA1wD4cfVmGRgYGBiMFKHEHnQYhg9XwDoBiTHGXgQwmYhmxWVgLbGrawB/em1Pvc0wMDAwqApxaOyzAWwX3rfbn405/NUPn8enfmoWTRkYGIxtxEHsFPBZ4M5iRHQNES0jomX79u2Loeh40dFbqLcJBgYGBlUjDmJvBzBXeD8HwM6ghIyx2xhjixhji9ralFsdGBgYGBiMEHEQ+wMArrajY84C0MUY2xVDvgYGBgYGI0DoJmD2YRgXAmglonYAXwWQBQDG2K0AHgZwOYANAPoBfGK0jK0VGGMQzlw1MDAwGFMIJXbG2IdCvmcArovNogSgzIC04XUDA4MxCrPyNABlc6qUgYHBGIYh9gAYXjcwMBjLMMQeAOOxGxgYjGUYYg+A4XUDA4OxDEPsATAeu4GBwViGIfYAGGI3MDAYyzDEHgBD6wYGBmMZhtgDwMr1tsDAwMBg5DDEHgAjxRgYGIxlGGIPgCF2AwODsQxD7AEwtG5gYDCWYYg9AMZjNzAwGMswxB4Aw+sGBgZjGYbYA2A8dgMDg7EMQ+wBGGu8ftMj6zD/hofqbYaBgUFCYIg9AGPNY7/12Y31NsHAwCBBMMQegDHG6wYGBgYeGGIPwFjz2A0MDAxEGGIPgOF1AwODsQxD7AEoGWY3MDAYwzDEbmBgYDDOYIg9AMZhNzAwGMswxB4Iw+wGBgZjF4bYDQwMDMYZDLEHwEgxBgYGYxmG2AMwVnmdmR7JwMAAhtgDMVb5cazabWBgEC8MsY8jGF43MDAADLEHgo1RijRSjIGBAWCIPRAqfjzQV8DCrzyCpVsO1M4gTRhaNzAwAAyxR8bSLQdQKJVx25831duUChiH3cDAANAkdiK6lIheJ6INRHRDwPeTiOhBIlpJRGuI6BPxm1o7qAiSyx0pqpExETBWJSQDA4N4EUrsRJQGcDOAywAcD+BDRHS8L9l1ANYyxk4GcCGA/ySiXMy21gwqgizbX6UoecxuPHYDAwNAz2M/E8AGxtgmxlgBwL0ArvClYQAmEBEBaAFwAEAxVksTgrLjsSeP2A0MDAwAPWKfDWC78L7d/kzEjwAcB2AngFcBfI4xVvZnRETXENEyIlq2b9++EZo8+lB5vtxjRwJ53XjsBgYGgB6xB1GYn0IuAfAKgMMAnALgR0Q0seJHjN3GGFvEGFvU1tYW0dRkgCXYYzcau4GBAaBH7O0A5grv58DyzEV8AsB9zMIGAJsBHBuPickCczT2+toRBOOxGxgYAHrEvhTA0US0wJ4QvRLAA7402wBcDABENAPAMQCSFw+oCbUUY32ZQF43/rqBgQEAIBOWgDFWJKLrATwGIA3gTsbYGiK61v7+VgA3AvgJEb0Ki/O+yBjrGEW7RxVjNyrGULuBgYEGsQMAY+xhAA/7PrtVeL0TwDviNS2ZcDz2JBJ7vQ0wMDBIBMzK0wCM2QVKFXFIBgYGhyIMsQdA5fmyJEsxxmc3MDCAIfZAqLRqR2NPYM0Zid3AwAAwxB4ZZZbcFUpx8Pr3n1yPuxZvjiEnAwODekFr8vRQw1h1fOOIivn+k28AAD5xzoKq8zIwMKgPjMcegLEqaYxRsw0MDGKGIfaIcOdMk0ejY7VDMjAwiBeG2AMhZ0hKoLbOYaJiDAwMAEPsgVB5vtxjT6R3nESbDAwMag5D7BHB/fUkEnsCTTIwMKgDDLEHYKwSZBI7GwMDg9rDEHsAtKSYBNJ/Em0yMDCoPQyxRwSfPE2id5xEmwwMDGoPQ+wB0Fnok0QOTaJNBgYGtYch9gAoCTLBUTFmP3YDAwPAEHtkOFExCfSPDa8bGBgAhtgDoZ48dWZPDQwMDBIJQ+wBUHnjyV13ajx2AwMDC4bYg6BBkEnk0CTKQwYGBrWHIfYRIokTlQk0ycDAoA4wxB4AHX5MIocm0SYDA4PawxB7AJSHWdfOjMhI4ijCwMCg9jDEHhGcPJPIoQk0ycDAoA4wxB4AnUnIJJJoEjsbAwOD2sMQewB0pJhkyh61sWmgUMKBvkJNyjIwMIiOuhJ7oVjG/zy7EYViuZ5mjAiJpPUaGfXuWxbjtBufqE1hBgYGkVFXYv/pC1vwrUfW4ScvbK6nGRVQ8mMSGd1GrUxbt7unRiUZGBiMBHUl9v5CCQDQM1ispxkV0JJZEkjwiVSHDAwMao66EnvKXp9fHkOMxCdWk7jKM4k2GRgY1B71JXab2csJ4yOVOUnug5Jsm4GBQe2gRexEdCkRvU5EG4joBkmaC4noFSJaQ0TPahVOnNgTxkg6SkzCTAaSaZOBgUHtkQlLQERpADcDeDuAdgBLiegBxthaIc1kALcAuJQxto2IpusU7kgxSXPZFXDDHetqRiCMFGNgYADoeexnAtjAGNvEGCsAuBfAFb40HwZwH2NsGwAwxvZqFU5JlWJ0FiglzGgks7MxMDCoPXSIfTaA7cL7dvszEQsBTCGiZ4hoORFdrVV4KplSjHKBEgtPY2BgYFBPhEoxCD5bwk9rGQCnA7gYQCOAvxDRi4yx9Z6MiK4BcA0AzJs3L7FSjHrlabJsFZG0DtLAwKA+0PHY2wHMFd7PAbAzIM2jjLE+xlgHgD8DONmfEWPsNsbYIsbYora2NqQTGhWjgySabHjdwMAA0CP2pQCOJqIFRJQDcCWAB3xp/gDgPCLKEFETgDcDeC0sY35+aClhjKQT7pgwkwEks7MxMDCoPUKlGMZYkYiuB/AYgDSAOxlja4joWvv7WxljrxHRowBWASgDuJ0xtjos77RN7EnbUEvPnmTZDCSvHg0MDOoDHY0djLGHATzs++xW3/v/APAfUQrnGntpDGkxyQ53NDAwMKj3ytPEhjvGk6bWSGJnc6jjl0u2Yf4ND6FvKFn7IRmMb9SV2G1eTxwhKe1JmrEeJNm2QxO3PrsRANDRO1RnSwwOJSTEYx87hJTkgzYSaNK4RH+hiKdf11qD58DcG4Naoq7Enk7oAiUdzzdpFgPJtGk84iv3r8Yn7lqKDXt7Q9NS0CoQA4NRRiKkmKRNnuqsPE0SkippjVds2mcRes/gcJ0tGRmWbNpvjjYc50iExz4WCSmJNidRHooDr7Z34d8eWJOc6+NhujpJ7f8JsRzlMsMHb3sRV9+5pN6mGIwiEnGYdeI8dtV3jIWmqReqtSkqcdaKaK+6/UX85IUt6E7ISVspZ4QUfv2UsLUag0Xr1LL1e8JlJIOxi7oSO2/rSdPY1XvF8DTJshmofhQR9fe1qoKGbBoAMDhcqk2BIXC88OQ1gVAMDlsHx+fTifDpYseSTfsx/4aHsHZnd71NqSvqS+z2/4Q57GMO7nC/uoqM+uu4blvfUBH7euThgJzYBwrJIHYezVWM0HCT0sQH7M4xnx2fxP7UOita6Zn10aKWxhvq7LFbzT1xHrviMUyYqV5U7bHXR4p55w+fxxnfeFL6fSMn9qR47HZPWiiWw9OOsi1RwUc9uXHqsTfnrcX0h/qCsETc3cQR+1g9Gq/K30cdOcU10trc0af8nnuXSZFi+HUnbW5IB8MlqzNKp5PW5cQDl9iT0VbqhYRo7PW0ohLKyVPnf3KMdifoqssn6jXVqg549FQU6WM0wUcqUYg9KY5AUuwYLWTstjIWO904UVdi5556Eiciw5BEk6vW2BM6eZpNWc1UR/oIw76eIazYdrCqPCJtNx0hgqYWSPK203HALAizkAiPPWm9q+ohdMIdk2UygGTaFAcytmxQKFVP7Ff86Hm8+5YXqspjJCd/xdHEH1+zG/ur3HMmSSPN0cShcp0yJCQq5tC+CdUirkUwUe9Dre5bxp7oG47BY9/ZNVh1HiM5IKbauuoeHMY1P1+OT/5kaVX5jHuPvd4GJAQJiYpRp3t2/T48tGpXDSzSRxI9gmqH+0mVYrhuOlxKRp1HOUeAE021xM5HB1v291eVT1LxyZ8sxX8+/nq9zRg3SIbHHvKAfOzOl3DdL18efYNs6OwVk0SPp+qVpzUuTxcusVfvsXNUc4A6IfrmdeUqTedl1rrzrhWeWrcXP3xqQ2z5JfU6a4X6hjsmdeXpGN3dsVqjkivFxKexcwxXwbT2XC50zKG4tqbmk7DV5eK07aRM5sYOM3sKoO4eux02NobamEP6CbLZ2d1xnEbFxOWtiqhmwt45R6CGUoyDmLaNUGWzcV9vYtYMjBQJejzrgkRExSTNe9CSYhLYdKquxqRqMTbiDJ6qRq8f2eTpiIsDEN/mc846DElGB/sKuPg/n8W/PbCmypLqA+OvW0iExp68cMd40tQa43WBEn9a45R+ilXIOpw8oi1QqnLyNCYnKOz3m+xVwGt31WcTraQ5eWMVifDYE8brSjDf/yTAkSqqzKdeWwpolxdjgdVJMdZ/nY6GnLQjLg7AKHjskpz4BHVDJl1lSSNDXLf4UO8fEqGxJ62X1rEmaTYDo+/NxV2eLlydOr48h6uJiiH9ZetxbU3teuxVZRMa1VVvKSNpgRRjFXXeUoD/T9bNVK88tf/XyJYoGIsSe5TDKuJsJ9V4/6kReOFxyWTVy196v6/XHFK199gNikniE1o71Dnc0ar8sSTFcCSsLwIQnzeniziINtoin6qLE6SRajLTj4rhSEr8eZhjUu9mXes2PF6RiMnTOLXTOKCyJpHyUUxeSuRriqEKonm9MXrsVWQVpXOIa07G3TCvunzComLiKmekqDaQIlHPZR2RkMnThN0MjXDHJCKuh3600gch2gRknMRefV5RcohNG68uG8GO4JzqLTXGNRdxqCMRe8XoxgPXqjceqytP43voRyd9tXnE+dBW05ZG8tNqNetyTIwbdt31dlyqvcf1HnEkBQmRYvTSJynePUkNJ67DlaOSTxxer5bHbv+P4/7Ho9frk4fuRnfh+fCSq5QqfPn5Ue8zEuKai0jS81kPjCkppla8rvXAJtBnr94rjFpe9RDvveyhdk+ISpoUU/vJ09GWdOoti1bbedfb/qQgGR67NrHXSopRfMc9sPj2o6oacS+CGa30QRBtDoutjrNjr+b+jUyKqQ6OJ11lPmGdUf019up+b3jdghaxE9GlRPQ6EW0gohsU6c4gohIRvU8n36jD1CT0xgkwoQL12tI1Ho1d8NhliZI6eao1svO/GGFZTpnxZCTLp97PWPVbLyTwAa0DQomdiNIAbgZwGYDjAXyIiI6XpPs2gMeiGqEb7pgsKWb8oR7ELt5T6UPJKtNWi2psH8lPq4/2iMtj9/6vLKfKAqpE9ZOn1v8kSqW1hI7HfiaADYyxTYyxAoB7AVwRkO6zAH4HYK9u4VE19lpNnqoaBf/mtV3deP6NjprYo4taT57G8fB4NXZZOfz7GCZPY1jFOhI7RnsrgLjsqHdUSZQdM4NgPHYLOsQ+G8B24X27/ZkDIpoN4N0AblVlRETXENEyIlq2b98+5ybo8nXSFh985I4l9TbBg7G4H7s4WpM9lPzzODv2eKQY/aFd1Z52TG3fXWAnK4enqw/iWqyYJKroHhzG955YX9OoPh1iD9oXyG/h9wF8kTGm3J2fMXYbY2wRY2xRW1tb5MnTmnnsimKS1GA4nIM2YtJxdRFPuGN4GndkV3VxkcqVYSQ/rXr+o6pfi3bw/8E5sriGBiNEtcUmbRU7AHzzodfwgz+9gcfW7K5ZmRmNNO0A5grv5wDY6UuzCMC99jC3FcDlRFRkjP1elbHzwCZNY69NMbGj6ocialRMdcVVlBnmscc5YotjgVKUuZi4Ft5Ui+Rr7NVKMTEZEiN6BosAarsOR4fYlwI4mogWANgB4EoAHxYTMMYW8NdE9BMAfwwjdcAdFqquVyT9JEgxcU7KrGrvRIoIJ8yeFEt+1Q/3Rzd9ELQ09ohzMSrEGTpZy25QNzzzYF8BuUwKzfngRzvsGYprkjYKRJvi0tjrzxQuivbNS6dqtylyqBTDGCsCuB5WtMtrAH7NGFtDRNcS0bXVFK7zwJZivOnaUJQTpwn/90eL8c4fPl91Pu7K07hiJkYrfUAOQhZhHnu8UkwVHvtIflOjie1Tb3wCF333GUU+/hde1GPyUSwyrjMFEuADOuCHdaVqeNC2jscOxtjDAB72fRY4UcoY+3hUI5TE7plci5rzyJCgNhEJtfbY47gfHo89JM2YjGOPK0wxQgZ7e4YUGXn+VVVOXPDKcdXlFXXerhbgtiTKYx9N8EY/XGLSnrooEnsCBLT6W6BA1TpuxOJiIfbw/LjHE+f9ryqOPcKP4yKauHgqzPOvR7ij1loG7bzidwKqBXdOM4cOsbuvB4eDRcSSRjhc3EhQm9CCs5dK1RtERVWNq68onb1i4tpIS1buSBFtr5jqyopt8tSZ+JXJXvb3NXRhxLKq3yvG+z8J4PcudcgQu/C6Z2g4ME2tpBimQTD2l6NnRJUY7cUrfsSxX453clySJkYvLK59dYBo9VVtcbETu/T72nvsXo29uryS7LGna6ixJ8ZjHygEh8AXBfYYzXAhT+NSpRs1C6pHrckjHo89vPzR8MKqW3k6kt9UO5qKBzyfsAikWkIn5FUXYSOSeqAeptTZY3evuCh5akWvMAk3KwEmSFFrjz32cMeQNImJY+erNyOVN+Li7N/H5bEnXWOvLi/n8J4EaTHcUa9ZVB/qTezCdcpuhMdjH8WKEXNWKjEJ9NmdcMcE2haGKAuUYo2KqUJGcn6rYY8rfSRl8pT/V4+OaglPHPs41Ngd+S9hWwqMGsQbOlzSmDwdxT3QtbaPhfHYRcSypYB4T2UaO4+KiaHu+RbH1TgJIyHp6rVjjTQaiVypQlZO7Ru4NzKqWmKPf3QXF2pZt4mZPJX11PWIilGh/hbIUXONPWYpRsZLjscea7hj9Rq7Tg46q6t1oHNvhrU8H3U+ccXdRwHTaAP6ecWTT5xwnIlDx2N3X8s09loRu1eKkZeTgL6lEjEdehr113FUhVdjD87RfVhjcdntvEaexUh+WotDUIqlKNJQMJxwxxo2dLGo8RjHHmckli6SM3kqaZSeBUoxVEypzLBPtTIvBEnWsau1LOrDrPvw3LV4M376whZJHmL56nKSExUTfYKxFvdGJmcG2pEoKUaUW+Mh9iRNnnIcOlKMx2MP19jjuFnfeWwdzvjGk9jf6yV37TpPXntxULXGrlWG4GFrlvfvD67FVx9YE5qfrOGXYvTC4tgELMqEqGNyDe7NcASPfaTfjwbijYrx/k8SDh0pRnito7HHMTx86jXrgKeO3oLPFj3CGo1bU+11xbUJmM4iLe/H1deG9/4GpymPwsNaXbhjdMQlMaggc45EuKGawflFCXd8zy2LcdMj68IThtkUYxy7GxWTHGaP49SuqEiQx6721oB4huKZdMouT/4QKI/GG4WbE1dHXv1wP/i1CJ1tdqNAR4pxtxSIr+7HmhSj00YiaezSuta36eVtnbj12Y36P5DZJLyufoGSXlsplRnOuekp/OGVHVWVFwWHDrFraOy6UsyurgFs2tcbWibfiMdfnm6dj8a9iWuIFqcUI8vK+xBWVx7gDzNVe5GxHo1XTRy7I8WEIy5pQMehKETQ2GW51V1jj23yVJ2ur1DEjs4BfOX+1SMu67fL23HdL14OTcdH1Bq3JzZobds7ahAqvyR50kQCVjXus7/1FABgy03/R1lkJm0Tu+LO11qKift0nBH/XiMDr1dfvd06+mopxjh2t6zaSjG1WKCk57Gr09RjEzBPG6iS/BwpJqSx8O+racOf/81KAMDNIencqJhDxmN3Id1SQKiMOFaeuh67SoqRo14e++NrdmNwOHg/HWd3xxh1XPnuf6KHXT1KGmW60kf1JcZyPuwIpJjq9xkPz0AnKsbJT+P+juT3QdjROYAn1u7RyiuuvWLC8ikUrbqq5fjkkFx5Kt9SIJrGHtbg+Gb3/o5EW4oZhaYQ1gi3H+jHNT9frnw44oDHG4+YfqQYiwdtjOiX1Xa6GpytI8WEXbfu/EEUjnrXzYvx6Z8tU5Q5snyD89KTYnTqKm4cMnvFiJUvC9USJRqdHi/M+0053q08zUi/GynCHtp+e+dL2Q6YHNVr7KL3HF6GjtcWds90InF09/945NVduOF3q0Jt0slL/Vub/LTCHXna6qDz+yHJmQYiwo5p050/EJ+zzv6CIiWcdSM6o4S4NPawtsn5phZcG+c5u7pITFSMTGMXO1admx7WK8r0Lg+p1ThYPcxmHsEj8zIceSFGHTdsIhPQ80De2Kue0Pbu3ilJo+mx/80vXsa9S7eH2qSTlwrOTzWy4DKZjv6tgo69Q0V1xw+4z5ns0Ad3sjdMi3e/X7OzO7Rcq2yZ1Bac70ig6wRw2SqOZ11Xljp0pBiNbXs9HrtGvYR57LJNoHRC/UYLYTZzUgjTUKuPvAjPS/xYNQHNccn3/6z8XmuvmHJ8Ugy//3HsFaODfMZ6xIaK1Q39dezVKYPfM9lhPu5oRA1PB69JWDrzaHHtqaOrscswVCzhtj9v1Oosw54D3rkfOguUPB57uMauUzG6lTfS3nN04tjDPHbr+7DGWP1wX19aAIBSlV4ooLdXjBvpUHVxFXmOBBEcdmTTnNjDCUJZpkZhYe0DcJ8PmRTj3N+Q8kayIlyWLs7dHfnPw2zio99sKpgC71q8Bd98eB1+pTECDBuNuVLMIULsIuQae7gGK0sfBN6eKyZPQ3OOli4KQondboQyjz2mPcA0Fyi5r+OYDNIJdUvc5GmEKB3eWcnO9AUsJ+O3y9uVkVo63KnlsZfUxM7LCbu34r3SGbmJZfsR537szsraMCmmqJakth3o17ZHZ8UvcAgRO2MM2TQfpmjsFaNRMbqNzO+x6555Wo9wR8djD/EMqtULtRqexihrpGWG7e6oW/c6o7E49oqJklblsd+/Ygc+/5uV+N/nNsvz0bi3UYILwqSY0JWbHjLWIzYZAYolVS3FOGse9Dz2jKQiugaCz2AOQqjHzk9QqmEgTt3j2DMpvsQ/HikmrHE7etcIGXpUwh1Dbjivg7g09lXtnTj9xidwsM+/X474WkKyGvMiURBtd8fqtFxAjGOvwmPX9AoB12aVxz5ok/62A32KfPTLUsHR2CWEpit7ic+ibjuQSzEs8PVIoNtW+LOUltQDHz3peexhaQ7BvWKclaCSXq8ckdhH2sg8pKbIYlQ8dl0pRjLUjrpA6ZanN2J/XwEvbtrv/SKqFBOD6C3eX1mZ/F7pPhhaDkCNJk91PPYJDVkAQPdgUZFPPKMQJyomRGPXjXe38tSrkGEZscd4rrHuhnGFopVA5rGXHGcqRinmkJk8BXMml+Ly2MOjYixUhDuKpKb4/WjcmjCbh0OiYqJq7G54pBfekM9geB9ovfJUiDR5qnl9Og9aWF6Prt6NlzYfkPzW9tg1bOFpVPp3zn4GZB03oHdvo0iVMimG5xDWJsWydEM5ZZPt4n2vtk05h1lrSjGykQu/fh3nRVuKqaHHXte9YhizSCmTIj2NPQ5i55OnFZuA6VX6aNwbnZ3oALnGznz/wyBbVq/jOYmfxuKxs+DXnjKjSjEaRBOW17V3LwcQvPeQU98R5JEhyXYQgEuyqqarc+1xBBe4oaX6+eiHO0o0dk8bqO4B478OlWKKao2dd4A6CkBYGm7KobNACZaMkE6R1tF4Oj2ebq+o9NiVWcR/d8LDHe0FSmHhjlWaxiSvRYi2xqOxi1KMzGOPSOwadlVVVxF+6xC74t6lNPbr1upEIjg+0jUDjpQR1gG4r7WjYjQ09rj2OwrzOcI09uEIGnuYgzMaZ/aGoe5RMUS2x17ltr26aWRbaOpIAkB9omLCpBgnn4jG+a9T63Qk4fM4omJ0DjKOGseukmIcKa4K290Rkn4HItvADXDvm6o+9VZdhyYJna9wtkiOEBWjqzFL59E0Rm260O2YwoidO1E6nVaYDu/IOofS5CkBao894iRNuBQjWXkamrOdLsK96R0q4ldLt0XyfoLAPQIZsUfd/ZAgmTgLyFOVJg5i916S5MEflclTrawkv+X1HZ6Wp1GNtnSuT68sfdkgNAIpTGMXGq22xi6bRxMaQXwHbajT8RFUWrJAiddTHJxTjwO2tYidiC4loteJaAMR3RDw/VVEtMr+e4GITtbJlzFL782kU1pH48XqsftIUvdkoCjhjl/47Up88Xevhu6lEdaTh3ns/NdRidZfrE6kw0iWkqugtaVABCIF1B0lz6JWUTG8HJVXp+Oxa8WxR9DYpefLamrsUYMaAGBYcmPEPZCqbVO6Iw5+P2QaO/9ep9MKG0knUoohojSsveQvA3A8gA8R0fG+ZJsBXMAYOwnAjQBu0ymcgSEVorGLFRvnlgIV94sFvqxAlId69Q6L0Pl+IVJbwhYolfgmYBIvmksVurbJomI0hsRimjg0do8UI+1M+H/dexvu+cYRx66V1k6qevh1wjn14tjFciXPk02uoR572LyP0BarjWP3HqYj//1Lmw9g/g0PYUuHIt6/zPNR2/SrpdsAyKUYPiLRCRAIjSByvH95GsYYfvzMRhzoU++UqQsdj/1MABsYY5sYYwUA9wK4wmfUC4yxg/bbFwHM0Sm8zKyJI2VUjOghRhhqyuDs7uhL53mrIoZQC1y4O8ipEdYInQVKkuF81KGeJNLNp3VKOhHhdRTvShI2raWv6nphOnZxUq6mTxqZx67aLoB7dPJ8ojo1YSNgWZtzSUiPrKzXehq7rA6GNaWY+1e0AwCe39AhTaN7f7fs71d+zzubODR2ndWwL2/rxLcfXYcv/HZlaHk60CH22QDEnXDa7c9k+BSAR4K+IKJriGgZES3bt28fyvbkaTpFijNPhWFaDGFskO3uKFCW6l6OxNELG87pbikgJQfu0VbpQevMZ0RdMMbR1pIPLlPIIywcTluK0fB845BioiwaUkox9mWrRxrhZTENJ4i3RdmtKzker7qsoue+Vdfheold/nu+5kXdSfL/ejbJ0g07HruOM6kpxWjc31p67EG+VqCFRHQRLGL/YtD3jLHbGGOLGGOL2trawASPXbVAiS/g0PLYtfdtkHvsygcsgs+uu6ub7spT2X7sUT1aDj9ZiKQdZXm6Co3ZtFWW5Hud8MmSxoPhSa/y2DUn11SIdniGhseu4SVHnRCWVVVsUTEj6OBl91eUGFX32FnMqHjGnfuraZOsvCgeu2q7CEBvDkV2sttIoUPs7QDmCu/nANjpT0REJwG4HcAVjLH9/u+DUGYMqZDJ03KZIZMmEMW7VLxiSwENrddKqJW9B2E3S3evGFlkBc9dl9dJEjct1knYTotWeg39MWTi06PZS8Ph4iN2nXA47zYHlemiNAHXY1do7BpRTVFCGf2vRThRMSF56K6tEPMMg+z+ihKj6tnjxK461s712NW2uJsPBn+vExXD8+gvyLeCAKC16IsTu84WBjrQIfalAI4mogVElANwJYAHxARENA/AfQA+yhhbr1u4qLHLhjPFMkM6xXX4eLxIIIjY9fIYSbWHSy1qggw7aIPbrus5yWL5dRaDlTXrybVNTVoejz3g+hhj7uSwZhy7zpBXVVdi9EZQuijSELdFFe6oE+cclxQT1om4GnxIRzMCj13mCOhKMbJ5GhE6TkChWBaOxpN57OFx7PmMNRrtDzmy0hlxKvJyVrrGtAVk6JYCjLEiEV0P4DEAaQB3MsbWENG19ve3AvhXANMA3GJ7g0XG2KKwvEWNXTXZk04RUiRP49V9w1ZnBt948a3OUD4KokxEBWHYiWOPx6N1y/XWlUgGYUN1QG+46xCF5PuwjkIn0kNWpqo8lemiZzlcYrCfXyEPfk06ZGvbpNT9eWcjzyeyFCPJqxSqsYttAEhLyNSjsWt6mTKSHBAWb1Ufxx6eT++Q62GHReqo+KQhm0bvUBGd/eotfnkWqjbARy3x+Ouae8Uwxh4G8LDvs1uF138N4K+jFs4YC9XYS2WGTIrU5O+RB9Rl8iz85eluHRql4p3zLkM6m9CVa5px7NpRMZLDRrxSTHBeuiMbJ5+QB82rsVden/hZtVExTPMee4i9XEYjvMwepQ1EiXhRdZTitVsrtisZVyeCjN8z2fWv2H7QeV1mDGlJDFWppL5vgWVL2rno8dZigZI4epJq7I4HLc+oKWe1i/V7epQ26The7sKxeKi9ritPy2U4cewqjz0s1j1K6JXsIRLfKaWYEdR7WLt/edtB5ff6UTHR7PI32rIGMUTZrlUngkZME9TBidekO68kX1zlvlY9QKIUExRiGkWK4WlU5KcjxXgntiVpNO4Nfz5kRe3pHgrNAxhZVIwsXX+hiJQ9cq9+P3brv+r+ivdCZjpPo7o2Xj/iCECVTtVxhy1yior6Ejvje8WkpD1jUfDYw1bLWa/Dy/T/RvwcqD5s0I8wj+a2P29Sfs9vukynjRoVw30wlceuQ46hk8Ie/Tw8v6AyxbrTlmJ0ZCRFVuGLb/Tbh+hBVrPJmWiGdI2BRsclXk9Yfaq+9rQV7S0FgtvvQKGMplwGaaLQ5zcMsudbRDEkCocx5q48Vcp61nd9YcTuPJ/yNI7mr8xJH3UmdgjeuIS0ygzptHry1Os96MWUVsSxhxCMkw7A4dOaAOF/GGSNRxfutr1xSTHBxxGWPA998G+jdIA6G0V59xypTOPXfHUgawLiNanqSvSegjpTxyvUsYUFvxbBi1NKMRr3RmfyO0p9qhyFkUTFyCTHoWIJDdkUUim9NqwXxy7/Pbc3J4nG01UAeLq+kMlTHd2ft/2YlJh6bwLGkEpZpyip4tjTpD95GtYwnIkMvxSjKTEwZtlz8tzJmD+tWVkWR5C3GmVQ4O4Vo/b4ojaKkXns+kNwnjSXTmG4xAI7M3E726D8+GdEEcIdq/XYPfJQcKSO9T/clrA5BDGNzgSr/7WIKOGOgHodg6qcyrLUzpRs7QjHULGMfCaNFJFW56Yidp2zi/l9yGVSgeXpTgxre+w6UkzMKkHdpRh3SwFJY2Xh4Y5RZuhliwVYQJogMEC614q0zAC7o2iJvCGWykwZfhd1AyV/XelMvumObMTv+V45QemHimXnoInADtD+TTYd/BD60/lfy2xXarAldWcTpZb5Wg3LruA07oMvz0fHY/fKVuH5+C/NPyKURdZYZdlebyYVvo2H7zd+WMSesqQYxX1xttJVPONFxfU5aUqu7UFpdDc449/1axK7MsSWR8WMi8lTxrftlWvspRJDJpVCSkHsuhEtgPvQ+9Np71po20yoTvONRuxyD1I30iMsX8BLiFpx55oaey4jP/5wqFhGc94Kzgra/U8cNqsu79uPrnNeV9tOxJFRkBTj5h9e38Uyc64/TB7RCdO0So3HY/fXgb9tqUhW7LS1V55KPO2h4RJyGesZV8d6q1dg+8sIi3jJpVOB1xjWsXPw697ZNajellkjUsfZnE2eJBLqRuyd/QV78jTcG09xj11jQkiXbFQLlNQau2WzzmIJVX5ROFhsaJXE7r6OujLT/6CJb2XPjneyM2Q+w/6ae+xBQ+ihYgktNrEHTcJxW7NptTf3yyXb3N/IRhuibRoPmcxm7oSEVXe5bC2ucrbECJHSVPNDOjKSZydUaSciJ60T/+1xAMDR01sqyqwoyyH2tMbGe+rl8kPFMvLZtBUdp+pwi7zd6nrs6jrIZVKBDoyuxy5+9eqOLkW6YGdSxLBmm9JF3Yh9+8EBrNzeaYU5pUm6V3OZWVExKVW4ozjLrSkPqOLY1Rq7fHdEGYI19ggeu2/BjMceMU/NiAKZHKW1CZjuyAYBHntAPQwVy2i044GDdMaiQ+wpZZ0NaSxL1/XYwxwF3bjtknP9ac/7inSOdhzuHQIKwtLQl8V+SvQyxfQN9v4+Sr3bziiaxy4j9hLy6ZQ9jyb/vbtQT+Wxi1ygTpOT2K67JXGZMZw0ZxIA4KBi8y5nkzeVFOPsBBsPs9dViukeLFpRMYpJE76lgCqNN/pCXTHOAg2Fx65ekm5NBhH0e9egB5rfZCJ3o6wwmwG1FKO9gEcSyqUjxUTS2H3EHtR5Dw1bE2eyrZv5Zxaxy8sqaAyfRc1YVVWejrRYWd+63hWvn5yzL4m6/eps7QsoVpV6PE1ZGveLoaIbzSF2Kg3ZlF2m1BzXY8+mQmOweVuSdYiWx55COhUW6219p5RiPDHqck4BrJFUUHHi9YRFxRw2qREA0D0oX32qtUBpvHjsHGV7clQ1dEynCBk7skKWxn0dQux8qbAvmVi8eq8YBgIFrvyTIXjy1PqfS6fC94oRvvdreR7tVbNVyPal8AxBpcSu34nqeewla+JMsnUzN1E2bFaVq/pcJ/QMqBxFRJmgdog9w4lSYhefhCuUsK9nKDCNZ/JU4tXpSAhimqFhsTN0X3OPXU9jT4dGkfGvZYRsde7hk6fO/i1VSjHixG9oVEyIxz6hwZIRVSGPzuS4SooJWTgWFXUn9sHhsh3mFPz94g37USiWkUvLY9292rC6ZngFVq481ZMYuMfu/40KwRo7fzDkoYCOzeJknt9j17RbhGxVnY7M4tXYQ4jd0djT0vQFOyIiK+m4i47HTlWvPGUaaQAvmfs99qIGwTplaEweW7a4r/d0DwbbpLFRlihJqlZyc3tE+Uqse36/dDatyodExYh2yCYYrc49HTp5yusgTIpxDtORZMU7iFxGPXkatvFgqczQYhP7gGKHR51FU3z+IC7Un9iLJWkFrtttHS336o4u+8EPvqFR9hNxN/fxk5r4Wt1Lp4i0pBhV/K7jsdsPke7DoZ48VdvDIQsb09FxR6SxKw5I4BNnmbRMirHyCNPYg36j+ly9MlE+eSq+DzuFpyRouYCe9t89EDykF4k3zBMFgEIp2IMslpizx4koxYjXzKUYVXXz+mvIqjX2ohaxW517itRbCvB921VzEcVy2WlvYatv85ngNsXzb8ympaMDPhLhE/99Q3KPXWfb3qLG/EEU1J/YCyUrlDGggrsH3F4wm05JezWRD8KWN8smTz0SQ8gkVjoVLSomeNdCt3GFlekhmqLf7so8w+B4PoqVp2H7sROFSzHOcD2rDnfMZ1LIpCh08pQxPblJZwGP6gESicNvk3ifXtp8QGkHb9N8H3GdDkem1eqE8Xn0c8nhD6UyQ3POIqOCZHGYjhTjyhnqqBg9j51r7KRcdl/U9NhzinUTPA1ga+wBWfH881m5zMQ/zqRSaMimPDtU+qGzbS9vc3t7hjyhuyNF3Yl9YLiEdErm1bqfZTMpqUYnElQY2fCbVhnHHlyuHyUGpOwVJ7p6WNAN9RO7LCrIstltrCopRpfYC9JRi+DRhkyeZlPh0RA8rdpjt2KYrf2CKr/ndcfz0BmVyA9PECcO9Sbg/FKM6j5V2uG1XbW6mkNGEB4vVSYxlF0ZQnZ9xbLosQePTNKSg1hE8LmvrOK8YsDbEco1dluKoTDy4xKiJIKuzFAsM1dKktaTK8UEXSP/vjEnl5n4vU2ngOZcRrn6VGvbXqFufvzMRmk6XdSd2AeHy8hISEKsh1yapD21zjacHPKTUVhFmiCUywxpAgikrbEHeuzCpCAgP6ia28ojZ/x1EEXz5hjWkWJCZIN8JoWO3uCJPic/nta2PXDylE+cScJZHY89E042/nIrPtf02EU7+31Eq7v3uFhe2ORpQVh9K/O0dTT2gUIJU5pyVj7F4A6iVC5LpBg30wVt1lYZ6uX91m6MqvOKAS+Zh0kxql1eAWFrDcnInXeKE23dO9Rjl2jsvJyGTFraafF7mUoRGnNpDCgmT7UWKJXKjgR28bHT5Qk1UXdi54doBDUisTGrNPaw/UaC8pR57OmQCRwuxYAieOwBCSukGOVkXllK7N6Vp3r2FCSej84GUfzzo2a0YPuBfvURcz6NPcjTKpSscMdsWhYV45UzZOR4RFszTpk72Uqj4RmrdFqxjjt98ckVWx1ryBCqLRUAqw4mNGQBAIMSj10n2qOvUMKUJisftcduEV9QVMwPrjwFC1otYlfH1ZeRSZE9N6JXl0HEzhjzaOw6Xq3M8++zJzCnNFudm6wuxZFUkLzHy2nMyWUmx2Mnsjx2xeSplhRTZmjJZ3HcrImRIu5kqDux5zJW/Kr/hn7twbW4+s6XPOmkPf5w8CRQEGQTh46uJunFOUrC5GkY+P1RrV7ki3NUS5KHhsvO7Ls/nWip7nbDzpBW4bGHbaTV2pJHmaklDUdGcVaeBnnsVrij7Nxb/mBlUuoJvaHhMlpbchXXIULbYxfSHej3ErtfilFLOt7rlxJ7sYSJjRllfqK9srvcXyhiqk1qKo2de+wiQQ4LujPviAYlXj8grC8JkeQ8xB5Q5/wzvvK0Gimm357A5HUgs5/fl8aAegDc56JBMXnKn4+07bHLjscTj3YM2ysmlybk0qSM09dF3Yn9W+85MXBV6Z2LNzuvb7nqNGk4HBDcQIPQO1R0Hhw/cenMhAO2FMM1dmkqC7yIINLmBME9cZXH3jtUxFR7iF3hsQtvtSdPeefmK9NzNJ7MHvtjJ35XoS3yOuVEElSv3YNFd/JUpbGHSDFDxZLjiUqjRkL2gHHTueFu/uvzX4PMKxTLaMyqpYFCsYwJebWnvXFvr/Nadm/6hnSkGIamfIDHXnKJimvUss6B55NJqU8/A7ztNejaeB3xzl21yyH/vUyK4eQ6zSZ2mTzCO4amgElk0eYG1eSp/XmKCE0KYteJNLNsYsikU7YDq94GWAd1J/ZL3jQTmZCe+qQ5k5BNyydPr//lCue1qrfbJoSn+cvjZNeQTYdMngpRMSE8ym9qUIMuOqSXsd8H280Ys4jdbqwFH7F44ti1pRgrod/z0dn+mH8+wSYH1ekxRV/n5fd2l289CAD43cvt0q2bxagYQE6OQ8NlNOe5XKX22Buy8rYk/n5SY7YijM3f+ai8WofYc+pNwAola1uFTIoCO4o93YPY2eXGt8uap8djl3QQVlRMpcbO7002nXKimGSdA8A9dr6wTF6XBYGEgzrTIYHYG7MpZTw4J2rZBHZ/hRQjkaN8DkclsdvtJCNfPOhOnhKachk5sWsuiiuUysimSalMREFdif1Nh00EgNAVZ43ZtHTy9ICggTZkgyMrOD7106XOaz+JuL20emhZLnMpJlyM4WUEeuzOEDQ42oVjqFhGqcycxqpcMKMbFWM/sH4CLDFrIRAQvkDpsMnWUur2gwPSckStEqj0dvkqy+GSRRJBxC5uKSCW78dgsYSJjVkQuQ+4H2JHo5ZirO8mNWXxxt4e33d+j11BanYseWPI3ivWArwUGrLpQELuGfReT+CcTZmhv1BSEjtjzKuxi3NT9r3JpAkNtseuujZr19Vwj53XZYrUxJ7LpJQECQjELtXYvR67rNPlv+fE7n8O3KiYNMos+L5xvkqluMce3ObEvFW8MlAooTGXds4uqBZ1Jfa7P/Vmy4gUgUkqELC8aCuOXU3sbRPyyqW9u2yv502HTayo5IJAQsrVZkyUYtQ3YNC2Jcjz4WU0KiJGAPehntpsDdX9kzRFzYYjgjecinDHMgudpOQd55wp1ulRqsgYUd4Sf8vBO7UfffhUZCWen99jD+q8DvYVMFyywtxa8pkKIuTg19uUyyhX+nG7T5kzGev39GJvj+stcxtPmzcZgFqKGXI89oznWvwoFMvIZSxtOyg//tmMiXkAwQNFHhEyye7chgLy4cXzkY2X2Ln8FMVjV59XzK/NKjMT6LxwO/OZNJoU0SWMMSdCSSrFDPFnhc8zBOfFr3uCZN5KjIoBgkda3JFPE6E5L5dixPup8rv6C0U0ZTNj32NfOGOC44Xyh1bmtTbnM8hmgnsyroHe8bFF2H5gAA+t2hXYODZ39AEALj9xJuZMaQxYUWjlPaUpp5QXSmVLV6OQqBixIQbdKFfnS3ve+8Ft4R6yqLVadru/042KcSdP/d5/WZA8gn/L7xF/eLolJGrl752k8uun/D61TchbUowiKoZvpBV0jf/8h9UAgBc2dGBiQ1a+yEeQYlQeOy/z3KNbAXg9Zt5OzlgwFYCa2P0dm8xxGbKJXeaxc9K4YGGblU9Aw+MdfnM+g3wmeMEMb2N8AZInjt3pQMmZPFVNDJfKZWTShGxavaUAd7SmNucCOwpRilFp1XzkKl6HH/1CWYB8TQAPL+Udrn+Vrjh6B4IdJm5DOmXNocgO2xDbh0qVcDz2THpsT57yxgO4cadBntZXLj8OgDVbXyiVKzw2Tuz8sAYAgRspXfTdZwAA0yc0BOr1/GbOmNiAA30F5aRJOoXQiZ7hElNq7P6HviDxQnrtOpk+oQGzJzdWEKmH2DWYnS/iAILkKCbs7BecF7ebPzw9il3tHClG4rFzYm+0R2RBDZqX58TCBzzUfBl+yd6USeaxi9KQzmENPASxX9DZefl8jkEpxRR9BKHQ2FUeu0jaQPCohc8FNOfTmNacx/6AbWR5e8ykLPIO2lIgk065k6chET86Hjt/Pqc15zBQUGjsWS7FBN873lmnUyT1aPlvpzVbIxvZveEhtjwM13+dvC4acvLAhqGi20k259PoHy4F3hduQ9i+M/2FEppsKWZMe+wi+APESYJXUCZF+NS5CwDIN1LiDZgTDQDs88kDIvld8qaZgZXHSeakOZNQZsDK9s5AW7kUk5NIQxxiAw302PlwL8Rj55tCTZ+QR0u+suHrxDeL8Gxv6/OQh4olTLTvxUChhPk3PIT/evx1n93uMDZFXtLzI0xj5x5VYy6NxmxaKUNwIg0atYkxxdsP9OOJtXsC8+JbVExrzisfnu0HB5BJkSNZ9Ay5nZcrjdnkoZAr+L3i7VslxeTTKeQlHjtvm3xfkqBsdthzHU25DFon5AOdG153PERPHNny7zIpcjoimZTBbWrI2B2yoi45sbe25AMnRkUpRhU26N67nLQendFBizqOnZ/YxJ3LUCkmoM0N+uxmLHiEwNM12Wlk6Hc89pSyQ9VFQojdarDr91gTVXvtRslPTxLTHPTFFfMG3NaSx4PXnwsA2C8Q+4G+Ao7+yiPO+4ZsqmKx07b9/fjaH9cCAM4/2hrubtjjlTwA4IWNHdh2oB8pIuQy8pWwjDGc8rUnnPeBHrs/3FGise/ssh7YWZMbAhs+t0F2aIAfYvievzMpFMuY1pJDNk3Y0WmV+99PbZCWl88Ek7Gbv3dU4o9m4L9tzKbRnA9e5MHTTGy0yDGoM+XXnSJyHu7vPbm+It0LGzsAWNKP7N6t3tGF+1fsQLHMMGeyNY+wVYim2m3P08yfZn2nIr/P3fsKADiLhpSTpyqP3b5nk+w6CCLSj9yxBIC1vH3zvl4890aHdITUlMtYkpWw4VhRjIrR8Ni7BoYxuSmLZnv0I6vP25/bDACYOakh0KvlHWVDNo2mrLUgKOj6uMc+rUV+78TRAQClrJPLpNxtOioCErySVZDTxT3xfDbldNy9ASNFLqVOa8krn5X+QhFNuTTyAeGOG/b24uanN4Su0RGRCGLnD+21d7+MoWIJV91uNVLurQPA4dOs1XCvbOv0/PbuJVsBWI2+dYJ1Qzt6XfK/9ufLPekbc2lkM+Tx/N536wvOax4H3OPTzBhj+PD/LkGhaO+RoQi/9I8Yghoqb4ST7YdelteKbZ3IpVNobc4HTtLwDmFSY1a5+o1jy35rriEbEF5YsE+Ln9KUw8Z9VsfmXwTHQyWz9uZHao/V9jQlS7w50TRk5RNnnFz4Ah5/Pa3e0YUl9mZcHzxjLu742CLHPhGMMfzCPj5v9uRGlFmwZMfrB4DTnjr7XQLc0z2IXCaFuVMtYu+S7sbo2jnZWYNQSezLtx7E3p4hZNNWfQZ67MPuXIT4PgiTm7KOXLery7sFMCeZloYMJjdlHQcKcEdezXlrFTCRPA4cADoHhjGpMeuMxmQk+rrtrM2Y2ADGKjuL1Tu7QAQcM3OC47wF1Sn/bFpzTrrN9fo9PZg3tQkNWUvSkM21bNjbi8MmNUgXzjkeu0Jj5zJWQybtSMlB8018o7h5U5vQNTAsjVyzpBh78tTXxv/1D6vxH4+9jmV2eLAOEkHsot7+ansXNtgThG87bobz+ZsXTEWKgNU7u53PXtjQgU37rAcxlSJHWxM9dv9ZhA2ZNHLptMfzO2O+NRHW2pJ3Gqp/2CjuNNlg63MyKYbbxCFGVXDstzufWfYJLEEPdLnM8MjqXbj0hJnWnhTZynAwTiCTA2Kug/DeH/8FAHDynMkV6bknM7U554yemnynO/HyshlCQzYt1TFf29WNz/9mJQDXg/I/QP3DJWTtCbimXDrQ/sHhEojki0keWLnTeX3JCTNx8XEz0JyrHEmI9XvOUdak6OqdledUiveZa7Bimbu6BjFrUgOm2xEqe7qDo4JEb5h33kEeG3cq+OZVQSMAXi9tLXn7vbwDnzetyfHs/ZOVDrHn0zhmxgTPs8FJ0AoZJSxobcaagPrhcDx2Wx4K0sbFjqHJea68Nm3a14e5U5rQks84neX2g5XbIfP6nGbLLEFyzPYDAzjKPq91YqN8ruVAXwFzpza599c3eTpQKFmTq4rFg65TknIc06CO5P4VOwBYHVexzAI75XW7u60jIrNckix7OhP+LKqO3/MjEcTO96YA3J0TAfcmApZXN2dKkxPdAgAftj17jlwmhYkNGc/Ekb8iG3NpZ5tN3ns259OYPiGPF7/0VnunQaogUC5NWOkz9m6Twb2vn9i37O/3NPy93YP46gNrAMBpiB0+73FwuITLfvAcBofLTgSG5dV6Gyvv3ac05dBXKMo37yoz/PzFrc77MxZMxcH+gic9n8Sb1pJzCItHDjhpiu6QvUGiiwPA5+5d4bzm0U9+Uu4dLDrE0JTLYGC45LHn+Tc6sGV/v9WRSna3FAcUGbvttDRkKiKbxIecH9YcJLeJUl8mnUKKhP2FygwPrNyJvd1DyGfSmNqcw27JwRhLtxxwXjcFeLWMMQwOlxzd9awjpko99v5CEUSudhzUAZ44exIuWNiGiQ1ZfP+DpwAAen3puMMzpSmHeVOb0DNYxFCxhK6BYXz9odcAAC32/T5t3hQ8/fq+wGtjjKFrYBgTG7OB18Zx5W2WE/HZtx7lpvO1l86BYad98HmyIAJbYY/U59nkHyTH7OoawKxJDQCseY2gve17BoexqaMPTbm0G43nq/O+gtUuM4pFcXwUN7kp58xLBXUkR01vQWtLHvNtxSFoNPKeW6zOnTHxRCY3L+5sqKL1/EgEsU9oyOKT5yxAPpPCToFAW20PhWNBazM22RKBGI3x3fef7PnNrq4BPPLqrsBhT0MmjclNWRTLzKmoroFhTGnKOTeyOV9JDLu6XLuyGWvytGdwOJDYuI081hkANu51yf76e1zSm9acQy6d8gyLAWDxhg5nGHu43Zh3dw9iy/5+T6Pmut4Rbc1gDBX5cKza0YV/+b0VFtiSz6CtJY9SmaFTaGiDhRIas2nHOwbc2GmOg/0FtOQzyKZTmNSY9cgUIrhOC1gTn/lMCgf6XNt+sWQr/rJpv+OF8olKsSP+yB1L8ODKnc7CDaBSYxeJmD+oHb0F3Lt0u/PAPrZmN874xpMAgCvPmIspzTm0tuQqFh8B7rqIX3/mbADwDI35YqyFMycAAOZMacSjq3dXaJ9f/cNqXHv3ywCAf3z7QjRlK73a3y5vx7H/8qjz/opTZqMxmw4kh/5CCU3ZNGZOtEhLbIscPYPDjqfOO0u/5sulmcMmN2KmTYCv7erBg8KohztWz663SP2xNbsryhocLqNQLGNyY85pK0GT6CvbLY8/ReQ4CH7HpLO/gMm23ZMknm+hWMY9L23DcbMmOmk8B4+UGV7Z3omD/cMCsQd77NyhWtXeFXiSFGCNiJpzGUdJCPKy+XMzpSnrSjEBpN3RO4RjZ05w7A4idt4xnLFgqnPv+Khs8YYOp/3t6BzA/Bseqvh9EBJB7ADwzpNnYahY9mwPwCedOBa0NmNzRx8YY9jSYQ3Xvnz5sXjf6XOcNK0teTy2Zg/+5hcv45n1lR5HQy7lSDbcs+4eKDoaLgDMmtTgGRkA8HQ4x86cgNmTGzFULHseTgD40n2rcPvzm3Hi7Em472/PwS8/bS3CEglIfOCICG0T8hVyjegJnjxnMgBXr9si2HbPS5ZufKrdiQSRFQBsFbTjJ//hArRO8MpWz7y+Fzu7BtGSz6BLIOut+707OO7vLTgjqdlTGvH8ho4Kj+eXS7Y5w/y5UxtBRJgxsQF/WrcXG/b2orO/gK/cvxob9vY6ujEnCO6piHl2DQw7Dd7/sIoL1PjCMb4Z2Npd3bjv5XZ8Rphn+eAZcwFYHu5fNu335LWnexB3PL8Z86c14Ux7lCRGffB79I9vXwjAIvYDfQXPwQilMsNP/+KOjK676Cg02Z2W6Czcbev9gOuYHDW9BTs6BzxOy3W/eBl3PL8ZTfmM7R1mPJO5APDrpduxZX+/04ZbnO0evCSyq8uK9mltyePUeVMAWG2JSwl8JTivHwCOLMoxXCrjyv99EYBFxK7H7r0vf3O3W+fvPW2OI+lxz75UZrjke3/GqvYuZ42GQ34+Z+Fbj7yGoWIZ86c1Oe3l9d1uO3/2jX14182LAbjSpkXs3nweX7Mb971sSSMTG7MOv/hHCJv29WFyU9aZGwrylDv7C0iRRcqTeD79/p1Ay1ixrROtLTmnrAO93jR8NfDlJ87EeUe3OaMWPv8jrpb//pNvVNghQ2KI/YTDJkFQYXDvNWdVbF955PQW9BdKuHvJNmy2ieqChd69i2dPaXReczL+/DsWOp/l0ilcfNx05DIp/HrZdgAWcfBeE7CGWc+90YH5NzyE9Xt6wBjDzq5BZNOEJV++GO86ZTbm2VERIgYKJdzzkpXnm21imG43xB/8yb0pfMLxpvecaKWZmK9YePSGLRM88/kLnYbzgytPscqxPYjNHX3OcPktR7Yil05VeFibO/qw6OtPOhEaS758MWZOanDsum/FDjDG8PG7rAa0ZX8fvv7uE5BOES46pg29Q0WPjvzwq7ucgxjeeoxV96fd+IRD/hv39eLL978KADhu1kQ894W3OvWwaV8f3vZfz+L5DR1OfvxB5Tp0R4/V8MWHqVRmOGyy5Yk9vnY3bnnGjRAIitf+w3VWdNTiDR34h1+v9HzHt/Z9y5Gt2H5gABf+x9N4fXcPHli5E2/+5p8AeMMJ80L4GZ+k5RPs/CSi/31us0MifmkmZU+0z5zYgG0HXELuETy3vzp5FgDg2JkWsXIyLZcZHnp1FwDgMNsTnd/a7Jng3ds9iC/8bhUA1/NrkXSCL2zcj+Z8BukUYdakBhBZo8tvP2J1TDd/+DQn7S1XWa/9HuZT6/Zi5fZOAF5iF+/Xi5v245HVbjucN63JcSR4W9pxcMAZke6zO0zewfzbg2vxzh8+Z6XrHMBdi7cAAC48pg1vO24GiNwIJ8ArqfHnsrUl7xm9FoplXCN08De950RMabIiwHYL7fu3y9uxbOtBnHtUq9tB+urxO4+uww+f2oAys+5vW0seDdmUZy8qAFhjzwcePWMC5tty88aOSpm2o3cI59nReMfao8G/bLScDu7URYUWsRPRpUT0OhFtIKIbAr4nIvpv+/tVRHRaUD4q5DIpvPwvb3feHzNjQkUaTpb/8vvV+DtbzjjcR7Bcy+LpAGDetGacbD/QRITJTTmcOHsSfrFkG0746mNYu6vbIRgAOH9hq/P6Hd/7M+54fjN+tXQ7pk9owIyJDSAivOP4Gc5vlm45gGVbDjiRJADwD3Znwu1ZvvUg7nu5HeUyw+6uQXz8LfNx5ZnzrGuY2oSV7V2eicAXNnbgzPlTnQYBWJEFAHDX4i14ZXsnnly7BwBw9hHTMHdqE847uhUvbjqAXV0DGCqWUCyVsXJ7p7Ps//qLjnLy4PMaP35mo4ccLz52OhbOmICN37wcf33eEQCAZVstQjv/O0+jWGbYZDfO95w2G4D1UG8/YHWiSza52jIfogKuTAJ4N2275E0zAQBHtlm69xt7e+wIpBchgks2v17Wju88+jo+/bNlACyP/fBpTXjuCxc5aWdOasBR01scOUEEdxZm2ES5ZX8/vvC7VU57AoC/Ps+NxmrKZfDo6l1Ysmm/M+o5eoZl6zts2wHgr374PL503yqPh/uZ849wXi9obcZ9L+9wRkgH+guYP60JH3/LfEe24hr6gystGVFcS/E3Fx4JwNKYt+7vx+INHSiXGVa1uxOcHz37cACu58tHndv29+Pel7ZhxbZOh6ib8xkcPrUJ//3UBmf+qFV4BhqyaZw2bzL+8MoOFEtlLN9qtStO6oDlFc+f1oxsmhwiAixi53jpyxc7dgPAtgP9KJUZ7l3qjljed7o1isqmU84GZat3dIMxhnNuespJ94FFc9Gcz+CwSY14bVe349l/42FrfuD0w6c4RHj41Ca0HxxwRltff2itk8+tHzkdR7S1IJUiTJ/QgL12ZzxcKjsT/m85apoj63zTzh+wRm23+E444qNu8TnqGhjGJ35iOUvvPnU2Zk1qQEs+gw173JFG71DRWTjJHY7DpzXj2JkT8Oz6fbhr8WYs2XwA5x7Vig+dadXR7687BzrIhCUgojSAmwG8HUA7gKVE9ABjbK2Q7DIAR9t/bwbwY/t/JExuyuHM+VPx0pYDzjBIxFFtLZjWnPNUYIMvauOa84/A3p5B/GLJNsfzOmP+FLz12OmeCcqPnnU4lm896HgaU4QFTt9494no7B/G4zZx8omlOcJogIjwh+vOwVtuegrvv9WaJPrMBdaD/NDfnetIC5l0Ct9530n4wm9X4R9+vRL//uBa9BdKOLLNJewvXnYsHl69G393zwoPwfzTJcd4ro3POdy/Yocz2w4A91xzFgDgxDmT8Kd1e3H2t56CH//6zuPxIbsjAaxO4uJjp+NP6/bim/b13fGxRbjYF4k0pSmLz96zAo+8utvxOO+1yyMiXLCwDc+u34fz/+NpnDh7kifS4u/f7o6UpgoT4YDlVf7pHy+o6Gg+d+8rzugCsBaMTZ/QUDF6e/r1fXjPLYuxdX8/rnrzPCeigqNQLHvOJD1zwVR87Yo3Oe9n2yMAAB6y+v4HT8EVpxzmvD/98Cm4f8UOfPA2q6M5duYEp829/fgZuPCYNjzz+j5s2d+PLfv7nRHb0q+8zeMs8Emx07/+pPPZ9Rcd5XSegEvIdy7ejD3dg84oBgDeeqx1Xw6f1oQ/rtrlhARzPP735zsyxKSmLA6b1IBbntmIW5/d6BmB/NcH3PmoC4+Zjp+8sAWANffQkvc+c5eeMBPffHgdjhLWgXCcNm8yTj98CprzGVx4zHTc/vxm3LF4s2cRzpkLpmK6fX+5FHHjH9fixj+61LHsn9/mmUtb0NaM1TssT3fBlx52Pv/ZJ8902sBwqYzH1uzBY2se94zyf/c3b3Fe85H7wn9+BN//4Cn4mS2PvfSVizF9gnvvG3Np3LdiB+4TnicAOPuIVjTm0piQz2Dd7h786Kk3sLNr0DMfwVfFA9aJavev2IGV7Z24/qKj8L0n1+NAn9V5c6npqOkt+OlftuKMBVORTafwsD0aA6wtVjjOPaoVtz+/GS/YneUFC9vw6fOPwNeuOMHjIKmgk+pMABsYY5sYYwUA9wK4wpfmCgA/YxZeBDCZiGZpWeDDPdechZX/+o7AC0ilCC/aHgAAfO+DJ1ekacyl8Y13n+h46Hd+fBFmTWpESz7j8X7fdeps/K3tBTXn0vjsW49yvsumU7jt6kV4+vMX4uwjpjmf/6Mg6QDu/i0c//PsJrTkM06kC8cHFs3FDz90KgB3aHvcLFfPnDWpEV+89NiKaxGJGACObGv2TMgCwIff7KZ572lzEIRMivDJcxc4oZwcX7j0WOTSKdy3YgdaW/JYdPhU7+/SKbzv9DlgDI4k8J33nYSzhDq59SOnO94YJ/XWljw2f+tyT7pPn3cEPnrW4c77950+xyF1wOqgRY0XsO7LA9efi9vt2PTXvnYp3nPqbOf7l+1ICa6Hi7j+oqM87//1ncc7UgdgRX2I9xYALjqmDe86dbanExHXUgDWJLWIuz5+Bi5900xnYhOw7pNI6gDw/kVzK2w8y1f+vKlNjrTx0Ku78Isl29CcS2PTNy93JvrecfzMinwAYO4Ub8f2t/b1i6T+mfOPwHuENvLVvzoe/3TJMfjgorm46b0nVeT56fOOcEZlIn581Wm472/PceY9vmA7ICKpf+7io/HzT53pvCcinDnfe5/ec+rsigAJfxsELFnofHufHAC4+my3HZWZtdbiib8/3/Obi4Tj5f7fr14BAFx30ZEeUgeAv3/bQk8HCgBrv3aJ86zc+K4TAADffXw9frlkG3oGi2jIpvDHz57rGdlxYt60rw//8OuV2H5gAB87+3D87JOuf8vnAq//5Qp85ufL8YdXduLCY9qw+t8vceaHAOC9wpzhZSfMdJ5xXVIHAArb6pWI3gfgUsbYX9vvPwrgzYyx64U0fwRwE2Psefv9nwB8kTG2zJfXNQCuAYB58+advnXrVowEm/b1Ys3Oblx+4ixPhYjgQ7BcprpphHKZ4fG1e3DBwrYKYgSsYe4jq3ehIZvG/St24J//z3FYNL+ycQJWXPGdz2/BW46c5nQ8IoqlsuckIdm1FUtlrNnZjRNmTwpMs2LbQTy6ZjcKxTI+sGgujmxrkdZDV/8w7l6yFe88aZazCEwEYwzrdvfg0dW7kU0TPnPBkRUN7GBfAft6h7Bk034QEa568zzp8V57uwfxyvZOXHzcjArbi6UyGKxQz637+3GCPYEXhHte2oa7X9yKG991Ak6dOzmwvL6hIm5+egMmNWbxmQuODMxncLiEFzftR/vBAbzzpFnOYiIRHb1D2NM9iJe3deKS42c4XmgQXtneiYUzWjyRRWJZ7QctOePEOZM8Xpq/vI/cvgRb9/fj99edg2NmetPt7x3Clv39+N4T69EzVMSXLju2opMAgFXtnXhh435ceEwbOvuHcdq8KSN6Hl5t78LsKY24/blNWDR/ijN6ENEzOIxdXYN4bPVufOCMuZ5Om6N7cBg7OwecvYH8jhFgTcI+90YHWlty2NzRjyPamnGaPdErolRm2LSvF4dNbsTu7kFHyvNjT/cg1u3uwQsbO/CpcxZI79263d1Ys6Mb5y1s9ZD/ULGE25/bjJ7BIuZNbbLm59IpzwgfsEYR//n4ehwzswWTm3JIE+G8o1s97ZLPmWw7YIU/z5zUiPeeNjuwrQwVS0gRBZI5ES1njC0KvBCeRoPY3w/gEh+xn8kY+6yQ5iEA3/IR+xcYY8uD8gSARYsWsWXLlsm+NjAwMDAIgA6x63Tf7QDEceQcADtHkMbAwMDAoAbQIfalAI4mogVElANwJYAHfGkeAHC1HR1zFoAuxtguf0YGBgYGBqOP0KgYxliRiK4H8BiANIA7GWNriOha+/tbATwM4HIAGwD0A/jE6JlsYGBgYKBCKLEDAGPsYVjkLX52q/CaAbguXtMMDAwMDEaCxKw8NTAwMDCIB4bYDQwMDMYZDLEbGBgYjDMYYjcwMDAYZwhdoDRqBRP1AHgdQCuAjpDkkwDIj3OJN41uulraHWdecdkdp03G7rFpd61t0q2n8c4pMxljwcuWORhjdfkDsEz8H5L2tlqliZBXzeyOuQ5isbvW98XYnTy762CTbj2Na07RSTdWpJgHa5gmSro48onTplrarZvO2B1fPkmzO87yxrPdUdLFkk89pZhljLFF/H9djKgCxu7awthdW4xVu4Gxa7uu3Trp6umx3+b7P9Zg7K4tjN21xVi1Gxi7tuvaHZqubh67gYGBgcHoYKxo7AYGBgYGmjDEbmBgYDDOEDuxE9GdRLSXiFYLn51MRH8holeJ6EEimmh/niWin9qfv0ZEXxJ+84x9gPYr9t/0oPLqZHeOiO6yP19JRBcKvznd/nyDfcB38FFCybO71vU9l4ietu/7GiL6nP35VCJ6gojesP9PEX7zJbteXyeiS4TPa1bnMdtdszqPajcRTbPT9xLRj3x51bqNx2l7kuv87US03K7b5UT0ViGvaHWuE4MZ5Q/A+QBOA7Ba+GwpgAvs158EcKP9+sMA7rVfNwHYAmC+/f4ZAIviti8mu68DcJf9ejqA5QBS9vuXAJwNgAA8AuCyMWJ3ret7FoDT7NcTAKwHcDyA7wC4wf78BgDftl8fD2AlgDyABQA2AkjXus5jtrtmdT4Cu5sBnAvgWgA/8uVV6zYep+1JrvNTARxmvz4BwI6R1nnsHjtj7M8ADvg+PgbAn+3XTwB4L08OoJmIMgAaARQAdMdtkw4i2n08gD/Zv9sLoBPAIrIO8J7IGPsLs+7GzwC8K+l2j6Z9MjDGdjHGXrZf9wB4DcBsWAej/9RO9lO49XcFLCdgiDG2Gdbe/2fWus7jsnu07JMhqt2MsT5mHXU5KOZTpzYei+21xgjsXsEY4yfPrQHQQET5kdR5rTT21QD+r/36/XCP0fstgD4AuwBsA/BdxphIUnfZw6V/Ge3hngQyu1cCuIKIMkS0AMDp9nezYR0TyNFuf1ZrRLWboy71TUTzYXkrSwDMYPbpW/Z/PlSeDWC78DNet3Wr8yrt5qh5nWvaLUNd23iVtnOMhTp/L4AVjLEhjKDOa0XsnwRwHREthzUkKdifnwmgBOAwWMPUfySiI+zvrmKMnQjgPPvvozWyVYTM7jthVe4yAN8H8AKAIqxhkh/1iCeNajdQp/omohYAvwPw/xhjqtGarG7rUucx2A3Uoc4j2C3NIuCzmrTxGGwHxkCdE9GbAHwbwGf4RwHJlHVeE2JnjK1jjL2DMXY6gHtg6YyApbE/yhgbtqWBxbClAcbYDvt/D4Bfoj7D10C7GWNFxtjfM8ZOYYxdAWAygDdgkeYcIYu6HOo9ArvrUt9ElIXV4H/BGLvP/niPPfTkw/699ueyA9NrXucx2V3zOo9otwx1aeMx2Z74OieiOQDuB3A1Y4zzZOQ6rwmx85lnIkoB+GcA/Fi9bQDeShaaAZwFYJ0tFbTav8kCeCcseaGmkNlNRE22vSCitwMoMsbW2sOqHiI6yx7iXQ3gD0m3ux71bdfPHQBeY4z9l/DVAwA+Zr/+GNz6ewDAlbbmuADA0QBeqnWdx2V3ret8BHYHoh5tPC7bk17nRDQZwEMAvsQYW8wTj6jOVTOrI/mD5SHuAjAMq6f5FIDPwZoRXg/gJrgrXlsA/AbWRMFaAP/E3Fnt5QBW2d/9AHYkwWj9RbR7Pqwth18D8CSAw4V8FsFqLBsB/Ij/Jsl216m+z4U1nFwF4BX773IA02BN8L5h/58q/OYrdr2+DiEqoJZ1Hpfdta7zEdq9BdbEfK/dto6vUxuPxfak1zksJ6xPSPsKgOkjqXOzpYCBgYHBOINZeWpgYGAwzmCI3cDAwGCcwRC7gYGBwTiDIXYDAwODcQZD7AYGBgbjDIbYDQwkIKJriejqCOnnk7DLpoFBvZCptwEGBkkEEWUYY7eGpzQwSB4MsRuMW9gbLz0Ka+OlU2Et2LoawHEA/gvWArkOAB9njO0iomdg7Z9zDoAHiGgCgF7G2HeJ6BRYK3ibYC0S+SRj7CARnQ5rD55+AM/X7uoMDOQwUozBeMcxAG5jjJ0Ea0vo6wD8EMD7mLWXzp0AviGkn8wYu4Ax9p++fH4G4It2Pq8C+Kr9+V0A/o4xdvZoXoSBQRQYj91gvGM7c/fduBvAl2EdYvCEvWNrGtaWDBy/8mdARJNgEf6z9kc/BfCbgM9/DuCy+C/BwCAaDLEbjHf498zoAbBG4WH3RcibAvI3MKg7jBRjMN4xj4g4iX8IwIsA2vhnZJ27+yZVBoyxLgAHieg8+6OPAniWMdYJoIuIzrU/vyp26w0MRgDjsRuMd7wG4GNE9D+wdtP7IYDHAPy3LaVkYB06siYkn48BuJWImgBsAvAJ+/NPALiTiPrtfA0M6g6zu6PBuIUdFfNHxtgJ9bbFwKCWMFKMgYGBwTiD8dgNDAwMxhmMx25gYGAwzmCI3cDAwGCcwRC7gYGBwTiDIXYDAwODcQZD7AYGBgbjDP8fteQw2SMdDvIAAAAASUVORK5CYII=\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un zoom sur les dernières années montre mieux la situation des pics en hiver. Le creux des incidences se trouve en été." + ] + }, + { + "cell_type": "code", + "execution_count": 55, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 55, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Etude de l'incidence annuelle" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Etant donné que le pic de l'épidémie se situe en hiver, à cheval\n", + "entre deux années civiles, nous définissons la période de référence\n", + "entre deux minima de l'incidence, du 1er août de l'année $N$ au\n", + "1er août de l'année $N+1$.\n", + "\n", + "Notre tâche est un peu compliquée par le fait que l'année ne comporte\n", + "pas un nombre entier de semaines. Nous modifions donc un peu nos périodes\n", + "de référence: à la place du 1er août de chaque année, nous utilisons le\n", + "premier jour de la semaine qui contient le 1er août.\n", + "\n", + "Comme l'incidence de syndrome grippal est très faible en été, cette\n", + "modification ne risque pas de fausser nos conclusions.\n", + "\n", + "Encore un petit détail: les données commencent an octobre 1984, ce qui\n", + "rend la première année incomplète. Nous commençons donc l'analyse en 1985." + ] + }, + { + "cell_type": "code", + "execution_count": 56, + "metadata": {}, + "outputs": [], + "source": [ + "first_august_week = [pd.Period(pd.Timestamp(y, 8, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "En partant de cette liste des semaines qui contiennent un 1er août, nous obtenons nos intervalles d'environ un an comme les périodes entre deux semaines adjacentes dans cette liste. Nous calculons les sommes des incidences hebdomadaires pour toutes ces périodes.\n", + "\n", + "Nous vérifions également que ces périodes contiennent entre 51 et 52 semaines, pour nous protéger contre des éventuelles erreurs dans notre code." + ] + }, + { + "cell_type": "code", + "execution_count": 57, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_august_week[:-1],\n", + " first_august_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici les incidences annuelles." + ] + }, + { + "cell_type": "code", + "execution_count": 58, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 58, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Une liste triée permet de plus facilement répérer les valeurs les plus élevées (à la fin)." + ] + }, + { + "cell_type": "code", + "execution_count": 59, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "2014 1600941\n", + "1991 1659249\n", + "1995 1840410\n", + "2020 2042389\n", + "2012 2175217\n", + "2003 2234584\n", + "2019 2254386\n", + "2006 2307352\n", + "2017 2321583\n", + "2001 2529279\n", + "1992 2574578\n", + "1993 2703886\n", + "2018 2705325\n", + "1988 2765617\n", + "2007 2780164\n", + "1987 2855570\n", + "2016 2856393\n", + "2011 2857040\n", + "2008 2973918\n", + "1998 3034904\n", + "2002 3125418\n", + "2009 3444020\n", + "1994 3514763\n", + "1996 3539413\n", + "2004 3567744\n", + "1997 3620066\n", + "2015 3654892\n", + "2000 3826372\n", + "2005 3835025\n", + "1999 3908112\n", + "2010 4111392\n", + "2013 4182691\n", + "1986 5115251\n", + "1990 5235827\n", + "1989 5466192\n", + "dtype: int64" + ] + }, + "execution_count": 59, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Enfin, un histogramme montre bien que les épidémies fortes, qui touchent environ 10% de la population\n", + " française, sont assez rares: il y en eu trois au cours des 35 dernières années." + ] + }, + { + "cell_type": "code", + "execution_count": 60, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 60, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.7.9" + } + }, + "nbformat": 4, + "nbformat_minor": 4 +} diff --git a/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-checkpoint.ipynb b/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-checkpoint.ipynb new file mode 100644 index 0000000..fbcf11a --- /dev/null +++ b/module3/exo1/.ipynb_checkpoints/analyse-syndrome-grippal-checkpoint.ipynb @@ -0,0 +1,372 @@ +{ + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Incidence du syndrome grippal" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Les données de l'incidence du syndrome grippal sont disponibles du site Web du [Réseau Sentinelles](http://www.sentiweb.fr/). Nous les récupérons sous forme d'un fichier en format CSV dont chaque ligne correspond à une semaine de la période demandée. Nous téléchargeons toujours le jeu de données complet, qui commence en 1984 et se termine avec une semaine récente." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": { + "collapsed": true + }, + "outputs": [], + "source": [ + "data_url = \"http://www.sentiweb.fr/datasets/incidence-PAY-3.csv\"" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici l'explication des colonnes données [sur le site d'origine](https://ns.sentiweb.fr/incidence/csv-schema-v1.json):\n", + "\n", + "| Nom de colonne | Libellé de colonne |\n", + "|----------------|-----------------------------------------------------------------------------------------------------------------------------------|\n", + "| week | Semaine calendaire (ISO 8601) |\n", + "| indicator | Code de l'indicateur de surveillance |\n", + "| inc | Estimation de l'incidence de consultations en nombre de cas |\n", + "| inc_low | Estimation de la borne inférieure de l'IC95% du nombre de cas de consultation |\n", + "| inc_up | Estimation de la borne supérieure de l'IC95% du nombre de cas de consultation |\n", + "| inc100 | Estimation du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_low | Estimation de la borne inférieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_up | Estimation de la borne supérieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| geo_insee | Code de la zone géographique concernée (Code INSEE) http://www.insee.fr/fr/methodes/nomenclatures/cog/ |\n", + "| geo_name | Libellé de la zone géographique (ce libellé peut être modifié sans préavis) |\n", + "\n", + "La première ligne du fichier CSV est un commentaire, que nous ignorons en précisant `skiprows=1`." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "raw_data = pd.read_csv(data_url, skiprows=1)\n", + "raw_data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Y a-t-il des points manquants dans ce jeux de données ? Oui, la semaine 19 de l'année 1989 n'a pas de valeurs associées." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous éliminons ce point, ce qui n'a pas d'impact fort sur notre analyse qui est assez simple." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nos données utilisent une convention inhabituelle: le numéro de\n", + "semaine est collé à l'année, donnant l'impression qu'il s'agit\n", + "de nombre entier. C'est comme ça que Pandas les interprète.\n", + " \n", + "Un deuxième problème est que Pandas ne comprend pas les numéros de\n", + "semaine. Il faut lui fournir les dates de début et de fin de\n", + "semaine. Nous utilisons pour cela la bibliothèque `isoweek`.\n", + "\n", + "Comme la conversion des semaines est devenu assez complexe, nous\n", + "écrivons une petite fonction Python pour cela. Ensuite, nous\n", + "l'appliquons à tous les points de nos donnés. Les résultats vont\n", + "dans une nouvelle colonne 'period'." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Il restent deux petites modifications à faire.\n", + "\n", + "Premièrement, nous définissons les périodes d'observation\n", + "comme nouvel index de notre jeux de données. Ceci en fait\n", + "une suite chronologique, ce qui sera pratique par la suite.\n", + "\n", + "Deuxièmement, nous trions les points par période, dans\n", + "le sens chronologique." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": { + "collapsed": true + }, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous vérifions la cohérence des données. Entre la fin d'une période et\n", + "le début de la période qui suit, la différence temporelle doit être\n", + "zéro, ou au moins très faible. Nous laissons une \"marge d'erreur\"\n", + "d'une seconde.\n", + "\n", + "Ceci s'avère tout à fait juste sauf pour deux périodes consécutives\n", + "entre lesquelles il manque une semaine.\n", + "\n", + "Nous reconnaissons ces dates: c'est la semaine sans observations\n", + "que nous avions supprimées !" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un premier regard sur les données !" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un zoom sur les dernières années montre mieux la situation des pics en hiver. Le creux des incidences se trouve en été." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Etude de l'incidence annuelle" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Etant donné que le pic de l'épidémie se situe en hiver, à cheval\n", + "entre deux années civiles, nous définissons la période de référence\n", + "entre deux minima de l'incidence, du 1er août de l'année $N$ au\n", + "1er août de l'année $N+1$.\n", + "\n", + "Notre tâche est un peu compliquée par le fait que l'année ne comporte\n", + "pas un nombre entier de semaines. Nous modifions donc un peu nos périodes\n", + "de référence: à la place du 1er août de chaque année, nous utilisons le\n", + "premier jour de la semaine qui contient le 1er août.\n", + "\n", + "Comme l'incidence de syndrome grippal est très faible en été, cette\n", + "modification ne risque pas de fausser nos conclusions.\n", + "\n", + "Encore un petit détail: les données commencent an octobre 1984, ce qui\n", + "rend la première année incomplète. Nous commençons donc l'analyse en 1985." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": { + "collapsed": true + }, + "outputs": [], + "source": [ + "first_august_week = [pd.Period(pd.Timestamp(y, 8, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "En partant de cette liste des semaines qui contiennent un 1er août, nous obtenons nos intervalles d'environ un an comme les périodes entre deux semaines adjacentes dans cette liste. Nous calculons les sommes des incidences hebdomadaires pour toutes ces périodes.\n", + "\n", + "Nous vérifions également que ces périodes contiennent entre 51 et 52 semaines, pour nous protéger contre des éventuelles erreurs dans notre code." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_august_week[:-1],\n", + " first_august_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici les incidences annuelles." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Une liste triée permet de plus facilement répérer les valeurs les plus élevées (à la fin)." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Enfin, un histogramme montre bien que les épidémies fortes, qui touchent environ 10% de la population\n", + " française, sont assez rares: il y en eu trois au cours des 35 dernières années." + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": {}, + "outputs": [], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + }, + { + "cell_type": "code", + "execution_count": null, + "metadata": { + "collapsed": true + }, + "outputs": [], + "source": [] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.7.9" + } + }, + "nbformat": 4, + "nbformat_minor": 1 +} diff --git a/module3/exo1/analyse-syndrome-grippal-Copy1.ipynb b/module3/exo1/analyse-syndrome-grippal-Copy1.ipynb new file mode 100644 index 0000000..8991855 --- /dev/null +++ b/module3/exo1/analyse-syndrome-grippal-Copy1.ipynb @@ -0,0 +1,1038 @@ +{ + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Incidence du syndrome grippal" + ] + }, + { + "cell_type": "code", + "execution_count": 38, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek\n", + "import requests\n", + "import csv\n", + "from pathlib import Path" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Les données de l'incidence du syndrome grippal sont disponibles du site Web du [Réseau Sentinelles](http://www.sentiweb.fr/). Nous les récupérons sous forme d'un fichier en format CSV dont chaque ligne correspond à une semaine de la période demandée. Nous téléchargeons toujours le jeu de données complet, qui commence en 1984 et se termine avec une semaine récente." + ] + }, + { + "cell_type": "code", + "execution_count": 39, + "metadata": {}, + "outputs": [], + "source": [ + "r = requests.get(\"https://www.sentiweb.fr/datasets/incidence-PAY-3.csv\") # on envoie ne requête http à l'aide de la bibliothèque \"requests\" et on récupère le contenu dans l'objet 'r'" + ] + }, + { + "cell_type": "code", + "execution_count": 46, + "metadata": {}, + "outputs": [], + "source": [ + "file = r\"C:\\Users\\renau\\mooc-rr\\module3\\exo1\\incidence.csv\" \n", + "if (Path(file).is_file() == False): # on teste si le fichier des données existent\n", + " file_data = open(r\"C:\\Users\\renau\\mooc-rr\\module3\\exo1\\incidence.csv\",\"w\",encoding = \"ANSI\") # création d'un fichier vide accesible en écriture\n", + " file_data.write(r.text) # écriture dans le fichier du contenu de la requête au format texte\n", + " print(\"Ce fichier a été téléchargé depuis l'url du site du réseau **Sentinelles**\")\n", + " file_data.close()" + ] + }, + { + "cell_type": "code", + "execution_count": 47, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "'C:\\\\Users\\\\renau\\\\mooc-rr\\\\module3\\\\exo1\\\\incidence.csv'" + ] + }, + "execution_count": 47, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "file" + ] + }, + { + "cell_type": "code", + "execution_count": 48, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
weekindicatorincinc_lowinc_upinc100inc100_lowinc100_upgeo_inseegeo_name
020210632381618867.028765.03629.043.0FRFrance
120210532249118436.026546.03428.040.0FRFrance
220210432580421491.030117.03932.046.0FRFrance
320210332181017894.025726.03327.039.0FRFrance
420210231732013906.020734.02621.031.0FRFrance
188919844837862060634.096606.0143110.0176.0FRFrance
189019844737202954274.089784.013199.0163.0FRFrance
189119844638733067686.0106974.0159123.0195.0FRFrance
18921984453135223101414.0169032.0246184.0308.0FRFrance
189319844436842220056.0116788.012537.0213.0FRFrance
\n", + "
1894 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 3 23816 18867.0 28765.0 36 29.0 \n", + "1 202105 3 22491 18436.0 26546.0 34 28.0 \n", + "2 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "3 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "4 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "... ... ... ... ... ... ... ... \n", + "1889 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1890 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1891 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1892 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1893 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 43.0 FR France \n", + "1 40.0 FR France \n", + "2 46.0 FR France \n", + "3 39.0 FR France \n", + "4 31.0 FR France \n", + "... ... ... ... \n", + "1889 176.0 FR France \n", + "1890 163.0 FR France \n", + "1891 195.0 FR France \n", + "1892 308.0 FR France \n", + "1893 213.0 FR France \n", + "\n", + "[1894 rows x 10 columns]" + ] + }, + "execution_count": 48, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data = pd.read_csv(file, sep=',', encoding = 'ansi', skiprows=1) # on lit le fichier csv, en tant que panda data frame\n", + "raw_data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici l'explication des colonnes données [sur le site d'origine](https://ns.sentiweb.fr/incidence/csv-schema-v1.json):\n", + "\n", + "| Nom de colonne | Libellé de colonne |\n", + "|----------------|-----------------------------------------------------------------------------------------------------------------------------------|\n", + "| week | Semaine calendaire (ISO 8601) |\n", + "| indicator | Code de l'indicateur de surveillance |\n", + "| inc | Estimation de l'incidence de consultations en nombre de cas |\n", + "| inc_low | Estimation de la borne inférieure de l'IC95% du nombre de cas de consultation |\n", + "| inc_up | Estimation de la borne supérieure de l'IC95% du nombre de cas de consultation |\n", + "| inc100 | Estimation du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_low | Estimation de la borne inférieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| inc100_up | Estimation de la borne supérieure de l'IC95% du taux d'incidence du nombre de cas de consultation (en cas pour 100,000 habitants) |\n", + "| geo_insee | Code de la zone géographique concernée (Code INSEE) http://www.insee.fr/fr/methodes/nomenclatures/cog/ |\n", + "| geo_name | Libellé de la zone géographique (ce libellé peut être modifié sans préavis) |\n", + "\n", + "La première ligne du fichier CSV est un commentaire, que nous ignorons en précisant `skiprows=1`." + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Y a-t-il des points manquants dans ce jeux de données ? Oui, la semaine 19 de l'année 1989 n'a pas de valeurs associées." + ] + }, + { + "cell_type": "code", + "execution_count": 49, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
165719891930NaNNaN0NaNNaNFRFrance
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low inc100_up \\\n", + "1657 198919 3 0 NaN NaN 0 NaN NaN \n", + "\n", + " geo_insee geo_name \n", + "1657 FR France " + ] + }, + "execution_count": 49, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "raw_data[raw_data.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous éliminons ce point, ce qui n'a pas d'impact fort sur notre analyse qui est assez simple." + ] + }, + { + "cell_type": "code", + "execution_count": 50, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "
1893 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 3 23816 18867.0 28765.0 36 29.0 \n", + "1 202105 3 22491 18436.0 26546.0 34 28.0 \n", + "2 202104 3 25804 21491.0 30117.0 39 32.0 \n", + "3 202103 3 21810 17894.0 25726.0 33 27.0 \n", + "4 202102 3 17320 13906.0 20734.0 26 21.0 \n", + "... ... ... ... ... ... ... ... \n", + "1889 198448 3 78620 60634.0 96606.0 143 110.0 \n", + "1890 198447 3 72029 54274.0 89784.0 131 99.0 \n", + "1891 198446 3 87330 67686.0 106974.0 159 123.0 \n", + "1892 198445 3 135223 101414.0 169032.0 246 184.0 \n", + "1893 198444 3 68422 20056.0 116788.0 125 37.0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 43.0 FR France \n", + "1 40.0 FR France \n", + "2 46.0 FR France \n", + "3 39.0 FR France \n", + "4 31.0 FR France \n", + "... ... ... ... \n", + "1889 176.0 FR France \n", + "1890 163.0 FR France \n", + "1891 195.0 FR France \n", + "1892 308.0 FR France \n", + "1893 213.0 FR France \n", + "\n", + "[1893 rows x 10 columns]" + ] + }, + "execution_count": 50, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data = raw_data.dropna().copy()\n", + "data" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nos données utilisent une convention inhabituelle: le numéro de\n", + "semaine est collé à l'année, donnant l'impression qu'il s'agit\n", + "de nombre entier. C'est comme ça que Pandas les interprète.\n", + " \n", + "Un deuxième problème est que Pandas ne comprend pas les numéros de\n", + "semaine. Il faut lui fournir les dates de début et de fin de\n", + "semaine. Nous utilisons pour cela la bibliothèque `isoweek`.\n", + "\n", + "Comme la conversion des semaines est devenu assez complexe, nous\n", + "écrivons une petite fonction Python pour cela. Ensuite, nous\n", + "l'appliquons à tous les points de nos donnés. Les résultats vont\n", + "dans une nouvelle colonne 'period'." + ] + }, + { + "cell_type": "code", + "execution_count": 51, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period(w.day(0), 'W')\n", + "\n", + "data['period'] = [convert_week(yw) for yw in data['week']]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Il restent deux petites modifications à faire.\n", + "\n", + "Premièrement, nous définissons les périodes d'observation\n", + "comme nouvel index de notre jeux de données. Ceci en fait\n", + "une suite chronologique, ce qui sera pratique par la suite.\n", + "\n", + "Deuxièmement, nous trions les points par période, dans\n", + "le sens chronologique." + ] + }, + { + "cell_type": "code", + "execution_count": 52, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Nous vérifions la cohérence des données. Entre la fin d'une période et\n", + "le début de la période qui suit, la différence temporelle doit être\n", + "zéro, ou au moins très faible. Nous laissons une \"marge d'erreur\"\n", + "d'une seconde.\n", + "\n", + "Ceci s'avère tout à fait juste sauf pour deux périodes consécutives\n", + "entre lesquelles il manque une semaine.\n", + "\n", + "Nous reconnaissons ces dates: c'est la semaine sans observations\n", + "que nous avions supprimées !" + ] + }, + { + "cell_type": "code", + "execution_count": 53, + "metadata": {}, + "outputs": [ + { + "name": "stdout", + "output_type": "stream", + "text": [ + "1989-05-01/1989-05-07 1989-05-15/1989-05-21\n" + ] + } + ], + "source": [ + "periods = sorted_data.index\n", + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un premier regard sur les données !" + ] + }, + { + "cell_type": "code", + "execution_count": 54, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 54, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Un zoom sur les dernières années montre mieux la situation des pics en hiver. Le creux des incidences se trouve en été." + ] + }, + { + "cell_type": "code", + "execution_count": 55, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 55, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Etude de l'incidence annuelle" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Etant donné que le pic de l'épidémie se situe en hiver, à cheval\n", + "entre deux années civiles, nous définissons la période de référence\n", + "entre deux minima de l'incidence, du 1er août de l'année $N$ au\n", + "1er août de l'année $N+1$.\n", + "\n", + "Notre tâche est un peu compliquée par le fait que l'année ne comporte\n", + "pas un nombre entier de semaines. Nous modifions donc un peu nos périodes\n", + "de référence: à la place du 1er août de chaque année, nous utilisons le\n", + "premier jour de la semaine qui contient le 1er août.\n", + "\n", + "Comme l'incidence de syndrome grippal est très faible en été, cette\n", + "modification ne risque pas de fausser nos conclusions.\n", + "\n", + "Encore un petit détail: les données commencent an octobre 1984, ce qui\n", + "rend la première année incomplète. Nous commençons donc l'analyse en 1985." + ] + }, + { + "cell_type": "code", + "execution_count": 56, + "metadata": {}, + "outputs": [], + "source": [ + "first_august_week = [pd.Period(pd.Timestamp(y, 8, 1), 'W')\n", + " for y in range(1985,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "En partant de cette liste des semaines qui contiennent un 1er août, nous obtenons nos intervalles d'environ un an comme les périodes entre deux semaines adjacentes dans cette liste. Nous calculons les sommes des incidences hebdomadaires pour toutes ces périodes.\n", + "\n", + "Nous vérifions également que ces périodes contiennent entre 51 et 52 semaines, pour nous protéger contre des éventuelles erreurs dans notre code." + ] + }, + { + "cell_type": "code", + "execution_count": 57, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_august_week[:-1],\n", + " first_august_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Voici les incidences annuelles." + ] + }, + { + "cell_type": "code", + "execution_count": 58, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 58, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Une liste triée permet de plus facilement répérer les valeurs les plus élevées (à la fin)." + ] + }, + { + "cell_type": "code", + "execution_count": 59, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "2014 1600941\n", + "1991 1659249\n", + "1995 1840410\n", + "2020 2042389\n", + "2012 2175217\n", + "2003 2234584\n", + "2019 2254386\n", + "2006 2307352\n", + "2017 2321583\n", + "2001 2529279\n", + "1992 2574578\n", + "1993 2703886\n", + "2018 2705325\n", + "1988 2765617\n", + "2007 2780164\n", + "1987 2855570\n", + "2016 2856393\n", + "2011 2857040\n", + "2008 2973918\n", + "1998 3034904\n", + "2002 3125418\n", + "2009 3444020\n", + "1994 3514763\n", + "1996 3539413\n", + "2004 3567744\n", + "1997 3620066\n", + "2015 3654892\n", + "2000 3826372\n", + "2005 3835025\n", + "1999 3908112\n", + "2010 4111392\n", + "2013 4182691\n", + "1986 5115251\n", + "1990 5235827\n", + "1989 5466192\n", + "dtype: int64" + ] + }, + "execution_count": 59, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Enfin, un histogramme montre bien que les épidémies fortes, qui touchent environ 10% de la population\n", + " française, sont assez rares: il y en eu trois au cours des 35 dernières années." + ] + }, + { + "cell_type": "code", + "execution_count": 60, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 60, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.7.9" + } + }, + "nbformat": 4, + "nbformat_minor": 4 +} diff --git a/module3/exo1/analyse-syndrome-grippal.ipynb b/module3/exo1/analyse-syndrome-grippal.ipynb index 59d72b5..fbcf11a 100644 --- a/module3/exo1/analyse-syndrome-grippal.ipynb +++ b/module3/exo1/analyse-syndrome-grippal.ipynb @@ -364,7 +364,7 @@ "name": "python", "nbconvert_exporter": "python", "pygments_lexer": "ipython3", - "version": "3.6.1" + "version": "3.7.9" } }, "nbformat": 4, diff --git a/module3/exo1/incidence.csv b/module3/exo1/incidence.csv new file mode 100644 index 0000000..19a2bb3 --- /dev/null +++ b/module3/exo1/incidence.csv @@ -0,0 +1,1896 @@ +# @source="réseau Sentinelles, INSERM, Sorbonne Université, http://www.sentiweb.fr", @meta={"period":[198444,202106],"geo":["PAY","1"],"geo_ref":"insee","indicator":"3","type":"all","conf_int":true,"compact":false}, @date=2021-02-21T18:53:33+01:00 +week,indicator,inc,inc_low,inc_up,inc100,inc100_low,inc100_up,geo_insee,geo_name +202106,3,23816,18867,28765,36,29,43,FR,France +202105,3,22491,18436,26546,34,28,40,FR,France +202104,3,25804,21491,30117,39,32,46,FR,France +202103,3,21810,17894,25726,33,27,39,FR,France +202102,3,17320,13906,20734,26,21,31,FR,France +202101,3,21799,17778,25820,33,27,39,FR,France +202053,3,21220,16498,25942,32,25,39,FR,France +202052,3,16428,12285,20571,25,19,31,FR,France +202051,3,21619,17370,25868,33,27,39,FR,France +202050,3,16845,13220,20470,26,20,32,FR,France +202049,3,12939,9923,15955,20,15,25,FR,France +202048,3,13804,10641,16967,21,16,26,FR,France +202047,3,19085,15285,22885,29,23,35,FR,France +202046,3,24801,20503,29099,38,31,45,FR,France +202045,3,42516,36857,48175,65,56,74,FR,France +202044,3,44567,38521,50613,68,59,77,FR,France +202043,3,43737,37523,49951,66,57,75,FR,France +202042,3,35145,29812,40478,53,45,61,FR,France +202041,3,27877,23206,32548,42,35,49,FR,France +202040,3,20443,16381,24505,31,25,37,FR,France +202039,3,19810,15900,23720,30,24,36,FR,France +202038,3,25562,21142,29982,39,32,46,FR,France +202037,3,18485,14649,22321,28,22,34,FR,France +202036,3,10390,7646,13134,16,12,20,FR,France +202035,3,9918,6842,12994,15,10,20,FR,France +202034,3,6084,3090,9078,9,4,14,FR,France +202033,3,6106,3411,8801,9,5,13,FR,France +202032,3,5918,3330,8506,9,5,13,FR,France +202031,3,4351,2269,6433,7,4,10,FR,France +202030,3,8179,5442,10916,12,8,16,FR,France +202029,3,8687,5860,11514,13,9,17,FR,France +202028,3,8340,5701,10979,13,9,17,FR,France +202027,3,4066,2406,5726,6,3,9,FR,France +202026,3,4039,2389,5689,6,3,9,FR,France +202025,3,2853,1488,4218,4,2,6,FR,France +202024,3,3058,1690,4426,5,3,7,FR,France +202023,3,4168,2468,5868,6,3,9,FR,France +202022,3,3580,1947,5213,5,3,7,FR,France +202021,3,6114,4026,8202,9,6,12,FR,France +202020,3,9315,6775,11855,14,10,18,FR,France +202019,3,11679,8722,14636,18,14,22,FR,France +202018,3,16398,12851,19945,25,20,30,FR,France +202017,3,18082,14454,21710,27,21,33,FR,France +202016,3,24165,19893,28437,37,31,43,FR,France +202015,3,41049,35377,46721,62,53,71,FR,France +202014,3,71666,64531,78801,109,98,120,FR,France +202013,3,107742,99187,116297,164,151,177,FR,France +202012,3,107283,98610,115956,163,150,176,FR,France +202011,3,101704,93652,109756,154,142,166,FR,France +202010,3,104977,96650,113304,159,146,172,FR,France +202009,3,110696,102066,119326,168,155,181,FR,France +202008,3,143753,133984,153522,218,203,233,FR,France +202007,3,183610,172812,194408,279,263,295,FR,France +202006,3,206669,195481,217857,314,297,331,FR,France +202005,3,187957,177445,198469,285,269,301,FR,France +202004,3,122331,113492,131170,186,173,199,FR,France +202003,3,78413,71330,85496,119,108,130,FR,France +202002,3,53614,47654,59574,81,72,90,FR,France +202001,3,36850,31608,42092,56,48,64,FR,France +201952,3,28135,23220,33050,43,36,50,FR,France +201951,3,29786,25042,34530,45,38,52,FR,France +201950,3,34223,29156,39290,52,44,60,FR,France +201949,3,25662,21414,29910,39,33,45,FR,France +201948,3,22367,18055,26679,34,27,41,FR,France +201947,3,18669,14759,22579,28,22,34,FR,France +201946,3,16030,12567,19493,24,19,29,FR,France +201945,3,10138,7160,13116,15,10,20,FR,France +201944,3,7822,5010,10634,12,8,16,FR,France +201943,3,9487,6448,12526,14,9,19,FR,France +201942,3,7747,5243,10251,12,8,16,FR,France +201941,3,7122,4720,9524,11,7,15,FR,France +201940,3,8505,5784,11226,13,9,17,FR,France +201939,3,7091,4462,9720,11,7,15,FR,France +201938,3,4897,2891,6903,7,4,10,FR,France +201937,3,3172,1367,4977,5,2,8,FR,France +201936,3,2295,728,3862,3,1,5,FR,France +201935,3,1010,2,2018,2,0,4,FR,France +201934,3,1672,279,3065,3,1,5,FR,France +201933,3,1593,68,3118,2,0,4,FR,France +201932,3,1592,71,3113,2,0,4,FR,France +201931,3,2337,695,3979,4,2,6,FR,France +201930,3,1944,415,3473,3,1,5,FR,France +201929,3,2096,420,3772,3,0,6,FR,France +201928,3,1195,125,2265,2,0,4,FR,France +201927,3,2466,848,4084,4,2,6,FR,France +201926,3,1798,402,3194,3,1,5,FR,France +201925,3,1544,389,2699,2,0,4,FR,France +201924,3,876,17,1735,1,0,2,FR,France +201923,3,2004,748,3260,3,1,5,FR,France +201922,3,2181,602,3760,3,1,5,FR,France +201921,3,2585,1102,4068,4,2,6,FR,France +201920,3,2891,1202,4580,4,1,7,FR,France +201919,3,3221,1509,4933,5,2,8,FR,France +201918,3,1385,278,2492,2,0,4,FR,France +201917,3,3166,1348,4984,5,2,8,FR,France +201916,3,3842,1973,5711,6,3,9,FR,France +201915,3,5932,3669,8195,9,6,12,FR,France +201914,3,12675,9167,16183,19,14,24,FR,France +201913,3,16513,12530,20496,25,19,31,FR,France +201912,3,22184,17786,26582,34,27,41,FR,France +201911,3,31553,26556,36550,48,40,56,FR,France +201910,3,49742,43268,56216,76,66,86,FR,France +201909,3,88354,79564,97144,134,121,147,FR,France +201908,3,172604,160024,185184,262,243,281,FR,France +201907,3,307338,291220,323456,467,443,491,FR,France +201906,3,394286,376782,411790,599,572,626,FR,France +201905,3,355785,339295,372275,540,515,565,FR,France +201904,3,241090,227261,254919,366,345,387,FR,France +201903,3,147063,135890,158236,223,206,240,FR,France +201902,3,75548,67632,83464,115,103,127,FR,France +201901,3,50295,43525,57065,76,66,86,FR,France +201852,3,37903,31375,44431,58,48,68,FR,France +201851,3,39259,32977,45541,60,50,70,FR,France +201850,3,27781,22638,32924,42,34,50,FR,France +201849,3,19738,15481,23995,30,24,36,FR,France +201848,3,19501,15275,23727,30,24,36,FR,France +201847,3,15949,12105,19793,24,18,30,FR,France +201846,3,11278,7957,14599,17,12,22,FR,France +201845,3,11065,7791,14339,17,12,22,FR,France +201844,3,6586,3875,9297,10,6,14,FR,France +201843,3,6550,3988,9112,10,6,14,FR,France +201842,3,7787,5129,10445,12,8,16,FR,France +201841,3,8048,5098,10998,12,8,16,FR,France +201840,3,7409,4717,10101,11,7,15,FR,France +201839,3,7174,4235,10113,11,7,15,FR,France +201838,3,7349,4399,10299,11,7,15,FR,France +201837,3,4915,2386,7444,7,3,11,FR,France +201836,3,3215,1349,5081,5,2,8,FR,France +201835,3,1506,239,2773,2,0,4,FR,France +201834,3,1368,116,2620,2,0,4,FR,France +201833,3,1962,5,3919,3,0,6,FR,France +201832,3,1839,183,3495,3,0,6,FR,France +201831,3,2048,242,3854,3,0,6,FR,France +201830,3,1951,202,3700,3,0,6,FR,France +201829,3,1951,252,3650,3,0,6,FR,France +201828,3,1654,52,3256,3,1,5,FR,France +201827,3,3266,1145,5387,5,2,8,FR,France +201826,3,3758,1493,6023,6,3,9,FR,France +201825,3,4580,2220,6940,7,3,11,FR,France +201824,3,3223,1351,5095,5,2,8,FR,France +201823,3,1207,136,2278,2,0,4,FR,France +201822,3,3202,1330,5074,5,2,8,FR,France +201821,3,2537,763,4311,4,1,7,FR,France +201820,3,2694,967,4421,4,1,7,FR,France +201819,3,1025,0,2098,2,0,4,FR,France +201818,3,3541,1416,5666,5,2,8,FR,France +201817,3,2573,1003,4143,4,2,6,FR,France +201816,3,4818,2724,6912,7,4,10,FR,France +201815,3,16311,12168,20454,25,19,31,FR,France +201814,3,22666,18092,27240,35,28,42,FR,France +201813,3,32680,25536,39824,50,39,61,FR,France +201812,3,52040,44590,59490,79,68,90,FR,France +201811,3,65159,56506,73812,99,86,112,FR,France +201810,3,93512,83989,103035,142,128,156,FR,France +201809,3,108545,98645,118445,165,150,180,FR,France +201808,3,131870,120950,142790,201,184,218,FR,France +201807,3,141138,130177,152099,215,198,232,FR,France +201806,3,138810,128164,149456,211,195,227,FR,France +201805,3,157839,146646,169032,240,223,257,FR,France +201804,3,175483,163835,187131,267,249,285,FR,France +201803,3,178329,166640,190018,271,253,289,FR,France +201802,3,198079,185663,210495,302,283,321,FR,France +201801,3,235493,220941,250045,358,336,380,FR,France +201752,3,299114,279359,318869,459,429,489,FR,France +201751,3,229448,214366,244530,352,329,375,FR,France +201750,3,129535,118787,140283,199,183,215,FR,France +201749,3,63789,56120,71458,98,86,110,FR,France +201748,3,37568,31541,43595,58,49,67,FR,France +201747,3,24972,19923,30021,38,30,46,FR,France +201746,3,13398,9948,16848,21,16,26,FR,France +201745,3,14035,8091,19979,22,13,31,FR,France +201744,3,8544,5318,11770,13,8,18,FR,France +201743,3,7300,4402,10198,11,7,15,FR,France +201742,3,9966,6503,13429,15,10,20,FR,France +201741,3,12434,8718,16150,19,13,25,FR,France +201740,3,12725,8690,16760,20,14,26,FR,France +201739,3,14949,10534,19364,23,16,30,FR,France +201738,3,11463,7438,15488,18,12,24,FR,France +201737,3,9716,6364,13068,15,10,20,FR,France +201736,3,2815,917,4713,4,1,7,FR,France +201735,3,2794,850,4738,4,1,7,FR,France +201734,3,2497,879,4115,4,2,6,FR,France +201733,3,2406,766,4046,4,1,7,FR,France +201732,3,2667,879,4455,4,1,7,FR,France +201731,3,3256,1158,5354,5,2,8,FR,France +201730,3,3759,1299,6219,6,2,10,FR,France +201729,3,5014,1989,8039,8,3,13,FR,France +201728,3,5271,2576,7966,8,4,12,FR,France +201727,3,3924,1432,6416,6,2,10,FR,France +201726,3,3171,1166,5176,5,2,8,FR,France +201725,3,837,0,1721,1,0,2,FR,France +201724,3,1566,248,2884,2,0,4,FR,France +201723,3,1664,203,3125,3,1,5,FR,France +201722,3,1305,92,2518,2,0,4,FR,France +201721,3,971,0,2046,1,0,3,FR,France +201720,3,2686,793,4579,4,1,7,FR,France +201719,3,3461,1490,5432,5,2,8,FR,France +201718,3,2102,515,3689,3,1,5,FR,France +201717,3,2071,428,3714,3,0,6,FR,France +201716,3,1380,222,2538,2,0,4,FR,France +201715,3,479,0,1242,1,0,2,FR,France +201714,3,1110,0,2549,2,0,4,FR,France +201713,3,7594,3808,11380,12,6,18,FR,France +201712,3,8780,4834,12726,13,7,19,FR,France +201711,3,7814,4329,11299,12,7,17,FR,France +201710,3,11802,7964,15640,18,12,24,FR,France +201709,3,13111,9099,17123,20,14,26,FR,France +201708,3,29545,23136,35954,45,35,55,FR,France +201707,3,59590,49764,69416,91,76,106,FR,France +201706,3,93628,82560,104696,144,127,161,FR,France +201705,3,193677,179255,208099,297,275,319,FR,France +201704,3,256428,240618,272238,394,370,418,FR,France +201703,3,267276,251345,283207,410,386,434,FR,France +201702,3,260588,245070,276106,400,376,424,FR,France +201701,3,255535,239743,271327,392,368,416,FR,France +201652,3,224489,207799,241179,345,319,371,FR,France +201651,3,187704,172655,202753,288,265,311,FR,France +201650,3,126570,115081,138059,194,176,212,FR,France +201649,3,76390,67374,85406,117,103,131,FR,France +201648,3,40502,33949,47055,62,52,72,FR,France +201647,3,22270,17612,26928,34,27,41,FR,France +201646,3,20816,16125,25507,32,25,39,FR,France +201645,3,15957,11448,20466,24,17,31,FR,France +201644,3,15145,10357,19933,23,16,30,FR,France +201643,3,9378,5830,12926,14,9,19,FR,France +201642,3,12920,9044,16796,20,14,26,FR,France +201641,3,13909,9709,18109,21,15,27,FR,France +201640,3,13379,8969,17789,21,14,28,FR,France +201639,3,10598,6814,14382,16,10,22,FR,France +201638,3,5969,3073,8865,9,5,13,FR,France +201637,3,4065,1538,6592,6,2,10,FR,France +201636,3,2372,473,4271,4,1,7,FR,France +201635,3,3420,1350,5490,5,2,8,FR,France +201634,3,2233,0,4643,3,0,7,FR,France +201633,3,1567,0,3938,2,0,6,FR,France +201632,3,2100,93,4107,3,0,6,FR,France +201631,3,3691,0,9120,6,0,14,FR,France +201630,3,3209,644,5774,5,1,9,FR,France +201629,3,1469,0,3073,2,0,4,FR,France +201628,3,2725,357,5093,4,0,8,FR,France +201627,3,5905,2343,9467,9,4,14,FR,France +201626,3,4186,1636,6736,6,2,10,FR,France +201625,3,4611,1560,7662,7,2,12,FR,France +201624,3,4977,2404,7550,8,4,12,FR,France +201623,3,4893,2416,7370,8,4,12,FR,France +201622,3,5667,3015,8319,9,5,13,FR,France +201621,3,5603,2475,8731,9,4,14,FR,France +201620,3,3908,1679,6137,6,3,9,FR,France +201619,3,4738,2308,7168,7,3,11,FR,France +201618,3,8204,4394,12014,13,7,19,FR,France +201617,3,13385,8822,17948,21,14,28,FR,France +201616,3,25670,19632,31708,39,30,48,FR,France +201615,3,48441,39824,57058,74,61,87,FR,France +201614,3,92603,81261,103945,142,125,159,FR,France +201613,3,170654,156387,184921,262,240,284,FR,France +201612,3,272174,254338,290010,418,391,445,FR,France +201611,3,304543,286453,322633,467,439,495,FR,France +201610,3,261822,245799,277845,402,377,427,FR,France +201609,3,229943,214533,245353,353,329,377,FR,France +201608,3,195067,180874,209260,299,277,321,FR,France +201607,3,207359,193223,221495,318,296,340,FR,France +201606,3,196143,182672,209614,301,280,322,FR,France +201605,3,178963,166296,191630,275,256,294,FR,France +201604,3,148473,136591,160355,228,210,246,FR,France +201603,3,75277,66630,83924,116,103,129,FR,France +201602,3,44617,37821,51413,68,58,78,FR,France +201601,3,42263,35556,48970,65,55,75,FR,France +201553,3,24835,19106,30564,38,29,47,FR,France +201552,3,19495,14319,24671,30,22,38,FR,France +201551,3,29080,23014,35146,45,36,54,FR,France +201550,3,25043,19812,30274,39,31,47,FR,France +201549,3,21479,16686,26272,33,26,40,FR,France +201548,3,16428,12273,20583,25,19,31,FR,France +201547,3,14959,10856,19062,23,17,29,FR,France +201546,3,12599,8237,16961,20,13,27,FR,France +201545,3,13577,9192,17962,21,14,28,FR,France +201544,3,14596,10025,19167,23,16,30,FR,France +201543,3,16749,11745,21753,26,18,34,FR,France +201542,3,18675,13613,23737,29,21,37,FR,France +201541,3,13585,9830,17340,21,15,27,FR,France +201540,3,13100,9349,16851,20,14,26,FR,France +201539,3,8595,5671,11519,13,8,18,FR,France +201538,3,8402,4929,11875,13,8,18,FR,France +201537,3,8817,4089,13545,14,7,21,FR,France +201536,3,1922,440,3404,3,1,5,FR,France +201535,3,229,0,644,0,0,1,FR,France +201534,3,760,0,1618,1,0,2,FR,France +201533,3,1537,208,2866,2,0,4,FR,France +201532,3,1594,66,3122,2,0,4,FR,France +201531,3,2845,475,5215,4,0,8,FR,France +201530,3,2447,353,4541,4,1,7,FR,France +201529,3,2389,332,4446,4,1,7,FR,France +201528,3,2089,105,4073,3,0,6,FR,France +201527,3,2257,393,4121,3,0,6,FR,France +201526,3,2536,774,4298,4,1,7,FR,France +201525,3,2607,680,4534,4,1,7,FR,France +201524,3,2849,1000,4698,4,1,7,FR,France +201523,3,2702,857,4547,4,1,7,FR,France +201522,3,4262,1989,6535,7,3,11,FR,France +201521,3,5547,2875,8219,9,5,13,FR,France +201520,3,4594,2040,7148,7,3,11,FR,France +201519,3,6307,3256,9358,10,5,15,FR,France +201518,3,3664,1544,5784,6,3,9,FR,France +201517,3,6382,3523,9241,10,6,14,FR,France +201516,3,12098,7913,16283,19,13,25,FR,France +201515,3,19458,14192,24724,30,22,38,FR,France +201514,3,30940,24617,37263,48,38,58,FR,France +201513,3,49563,41986,57140,77,65,89,FR,France +201512,3,70024,61079,78969,109,95,123,FR,France +201511,3,99295,88838,109752,154,138,170,FR,France +201510,3,143931,131682,156180,223,204,242,FR,France +201509,3,238947,222902,254992,370,345,395,FR,France +201508,3,409972,388670,431274,635,602,668,FR,France +201507,3,517750,494301,541199,802,766,838,FR,France +201506,3,533317,510627,556007,827,792,862,FR,France +201505,3,457911,436964,478858,710,678,742,FR,France +201504,3,292161,275491,308831,453,427,479,FR,France +201503,3,153931,141290,166572,239,219,259,FR,France +201502,3,104096,93358,114834,161,144,178,FR,France +201501,3,70962,60505,81419,110,94,126,FR,France +201452,3,63168,52705,73631,98,82,114,FR,France +201451,3,45346,38002,52690,71,60,82,FR,France +201450,3,42182,35049,49315,66,55,77,FR,France +201449,3,33537,27281,39793,52,42,62,FR,France +201448,3,28156,21896,34416,44,34,54,FR,France +201447,3,18158,13186,23130,28,20,36,FR,France +201446,3,14764,10174,19354,23,16,30,FR,France +201445,3,16172,11449,20895,25,18,32,FR,France +201444,3,15500,10464,20536,24,16,32,FR,France +201443,3,16011,10653,21369,25,17,33,FR,France +201442,3,21651,15828,27474,34,25,43,FR,France +201441,3,22486,16295,28677,35,25,45,FR,France +201440,3,16526,11583,21469,26,18,34,FR,France +201439,3,8583,5054,12112,13,8,18,FR,France +201438,3,10567,6496,14638,16,10,22,FR,France +201437,3,7714,3780,11648,12,6,18,FR,France +201436,3,5018,1949,8087,8,3,13,FR,France +201435,3,2268,355,4181,4,1,7,FR,France +201434,3,2367,250,4484,4,1,7,FR,France +201433,3,2358,0,4875,4,0,8,FR,France +201432,3,3229,447,6011,5,1,9,FR,France +201431,3,4143,349,7937,6,0,12,FR,France +201430,3,4631,902,8360,7,1,13,FR,France +201429,3,5122,1258,8986,8,2,14,FR,France +201428,3,4145,1200,7090,6,1,11,FR,France +201427,3,4823,1997,7649,8,4,12,FR,France +201426,3,3858,1235,6481,6,2,10,FR,France +201425,3,4564,1276,7852,7,2,12,FR,France +201424,3,2007,249,3765,3,0,6,FR,France +201423,3,5164,1853,8475,8,3,13,FR,France +201422,3,6907,1856,11958,11,3,19,FR,France +201421,3,4523,1039,8007,7,2,12,FR,France +201420,3,5881,2432,9330,9,4,14,FR,France +201419,3,3588,1277,5899,6,2,10,FR,France +201418,3,4708,1654,7762,7,2,12,FR,France +201417,3,2989,625,5353,5,1,9,FR,France +201416,3,7057,3381,10733,11,5,17,FR,France +201415,3,10800,6762,14838,17,11,23,FR,France +201414,3,19217,13490,24944,30,21,39,FR,France +201413,3,21577,15435,27719,34,24,44,FR,France +201412,3,23524,17260,29788,37,27,47,FR,France +201411,3,44513,35939,53087,69,56,82,FR,France +201410,3,86105,73497,98713,134,114,154,FR,France +201409,3,147035,131889,162181,229,205,253,FR,France +201408,3,188419,171950,204888,293,267,319,FR,France +201407,3,208726,191283,226169,325,298,352,FR,France +201406,3,160403,145280,175526,250,226,274,FR,France +201405,3,120261,107176,133346,187,167,207,FR,France +201404,3,85280,74414,96146,133,116,150,FR,France +201403,3,64159,54089,74229,100,84,116,FR,France +201402,3,46850,38202,55498,73,60,86,FR,France +201401,3,35624,27451,43797,55,42,68,FR,France +201352,3,30142,22721,37563,47,35,59,FR,France +201351,3,29787,23215,36359,47,37,57,FR,France +201350,3,24055,18214,29896,38,29,47,FR,France +201349,3,18071,13058,23084,28,20,36,FR,France +201348,3,17606,12195,23017,28,20,36,FR,France +201347,3,22636,16343,28929,35,25,45,FR,France +201346,3,13340,8367,18313,21,13,29,FR,France +201345,3,10596,6057,15135,17,10,24,FR,France +201344,3,10193,5622,14764,16,9,23,FR,France +201343,3,15780,9497,22063,25,15,35,FR,France +201342,3,14830,9545,20115,23,15,31,FR,France +201341,3,12391,7265,17517,19,11,27,FR,France +201340,3,9794,5140,14448,15,8,22,FR,France +201339,3,5371,1704,9038,8,2,14,FR,France +201338,3,9324,4198,14450,15,7,23,FR,France +201337,3,5027,1752,8302,8,3,13,FR,France +201336,3,4639,1425,7853,7,2,12,FR,France +201335,3,1291,0,3112,2,0,5,FR,France +201334,3,1889,0,4912,3,0,8,FR,France +201333,3,4740,348,9132,7,0,14,FR,France +201332,3,4709,549,8869,7,0,14,FR,France +201331,3,2270,0,5811,4,0,10,FR,France +201330,3,2169,0,4630,3,0,7,FR,France +201329,3,1696,0,3558,3,0,6,FR,France +201328,3,983,0,2168,2,0,4,FR,France +201327,3,4278,1327,7229,7,2,12,FR,France +201326,3,3488,839,6137,5,1,9,FR,France +201325,3,2735,0,5826,4,0,9,FR,France +201324,3,7245,2997,11493,11,4,18,FR,France +201323,3,16094,8918,23270,25,14,36,FR,France +201322,3,7245,2923,11567,11,4,18,FR,France +201321,3,5974,2401,9547,9,3,15,FR,France +201320,3,3831,1245,6417,6,2,10,FR,France +201319,3,1166,0,2680,2,0,4,FR,France +201318,3,3415,757,6073,5,1,9,FR,France +201317,3,7941,2950,12932,12,4,20,FR,France +201316,3,9520,4758,14282,15,8,22,FR,France +201315,3,19357,13311,25403,30,21,39,FR,France +201314,3,36855,27737,45973,58,44,72,FR,France +201313,3,43236,34048,52424,68,54,82,FR,France +201312,3,60822,50414,71230,95,79,111,FR,France +201311,3,84308,72456,96160,132,113,151,FR,France +201310,3,165558,148471,182645,259,232,286,FR,France +201309,3,259984,239067,280901,407,374,440,FR,France +201308,3,351626,327537,375715,550,512,588,FR,France +201307,3,470076,443682,496470,736,695,777,FR,France +201306,3,471647,445112,498182,738,696,780,FR,France +201305,3,492026,464729,519323,770,727,813,FR,France +201304,3,391525,367182,415868,613,575,651,FR,France +201303,3,224661,207134,242188,352,325,379,FR,France +201302,3,184159,168343,199975,288,263,313,FR,France +201301,3,163491,147340,179642,256,231,281,FR,France +201252,3,159290,141978,176602,251,224,278,FR,France +201251,3,113901,99835,127967,179,157,201,FR,France +201250,3,79918,68086,91750,126,107,145,FR,France +201249,3,47537,38711,56363,75,61,89,FR,France +201248,3,43006,32863,53149,68,52,84,FR,France +201247,3,39223,29140,49306,62,46,78,FR,France +201246,3,26436,18286,34586,42,29,55,FR,France +201245,3,18893,12799,24987,30,20,40,FR,France +201244,3,13106,8784,17428,21,14,28,FR,France +201243,3,17791,11284,24298,28,18,38,FR,France +201242,3,13096,8369,17823,21,14,28,FR,France +201241,3,18675,12010,25340,29,19,39,FR,France +201240,3,17873,11545,24201,28,18,38,FR,France +201239,3,20257,14180,26334,32,22,42,FR,France +201238,3,14715,9178,20252,23,14,32,FR,France +201237,3,7775,3509,12041,12,5,19,FR,France +201236,3,6384,2420,10348,10,4,16,FR,France +201235,3,8277,2206,14348,13,3,23,FR,France +201234,3,3858,0,8641,6,0,14,FR,France +201233,3,6492,840,12144,10,1,19,FR,France +201232,3,6381,0,14034,10,0,22,FR,France +201231,3,2696,0,5763,4,0,9,FR,France +201230,3,1834,0,4194,3,0,7,FR,France +201229,3,6329,1424,11234,10,2,18,FR,France +201228,3,4628,1091,8165,7,1,13,FR,France +201227,3,4162,1487,6837,7,3,11,FR,France +201226,3,4819,1097,8541,8,2,14,FR,France +201225,3,2669,530,4808,4,1,7,FR,France +201224,3,5977,2335,9619,9,3,15,FR,France +201223,3,2361,576,4146,4,1,7,FR,France +201222,3,5772,2435,9109,9,4,14,FR,France +201221,3,3722,821,6623,6,1,11,FR,France +201220,3,2731,897,4565,4,1,7,FR,France +201219,3,3267,1317,5217,5,2,8,FR,France +201218,3,2328,569,4087,4,1,7,FR,France +201217,3,6982,2701,11263,11,4,18,FR,France +201216,3,11455,6874,16036,18,11,25,FR,France +201215,3,20437,13435,27439,32,21,43,FR,France +201214,3,36740,27799,45681,58,44,72,FR,France +201213,3,62917,50171,75663,99,79,119,FR,France +201212,3,84738,71566,97910,133,112,154,FR,France +201211,3,128945,113778,144112,203,179,227,FR,France +201210,3,174704,157337,192071,275,248,302,FR,France +201209,3,225648,206810,244486,355,325,385,FR,France +201208,3,287293,264901,309685,452,417,487,FR,France +201207,3,263557,242711,284403,415,382,448,FR,France +201206,3,175123,158942,191304,276,251,301,FR,France +201205,3,106110,92524,119696,167,146,188,FR,France +201204,3,67778,56784,78772,107,90,124,FR,France +201203,3,49440,40981,57899,78,65,91,FR,France +201202,3,40507,32652,48362,64,52,76,FR,France +201201,3,45104,35640,54568,71,56,86,FR,France +201152,3,36532,28367,44697,58,45,71,FR,France +201151,3,25835,19002,32668,41,30,52,FR,France +201150,3,24155,18145,30165,38,28,48,FR,France +201149,3,27209,20376,34042,43,32,54,FR,France +201148,3,32358,24451,40265,51,38,64,FR,France +201147,3,17627,11780,23474,28,19,37,FR,France +201146,3,22368,15730,29006,35,24,46,FR,France +201145,3,18104,11995,24213,29,19,39,FR,France +201144,3,14050,8471,19629,22,13,31,FR,France +201143,3,21522,14251,28793,34,22,46,FR,France +201142,3,16932,11363,22501,27,18,36,FR,France +201141,3,7486,4024,10948,12,7,17,FR,France +201140,3,14053,8659,19447,22,13,31,FR,France +201139,3,17021,11062,22980,27,18,36,FR,France +201138,3,14007,8465,19549,22,13,31,FR,France +201137,3,8365,4174,12556,13,6,20,FR,France +201136,3,4606,1714,7498,7,2,12,FR,France +201135,3,4178,1634,6722,7,3,11,FR,France +201134,3,3312,683,5941,5,1,9,FR,France +201133,3,2421,0,5277,4,0,9,FR,France +201132,3,2590,119,5061,4,0,8,FR,France +201131,3,2409,320,4498,4,1,7,FR,France +201130,3,3972,1395,6549,6,2,10,FR,France +201129,3,2265,717,3813,4,2,6,FR,France +201128,3,1977,255,3699,3,0,6,FR,France +201127,3,3524,551,6497,6,1,11,FR,France +201126,3,1155,0,2685,2,0,4,FR,France +201125,3,3791,1006,6576,6,2,10,FR,France +201124,3,3507,1149,5865,6,2,10,FR,France +201123,3,3406,1170,5642,5,1,9,FR,France +201122,3,3122,1125,5119,5,2,8,FR,France +201121,3,2694,769,4619,4,1,7,FR,France +201120,3,3951,1443,6459,6,2,10,FR,France +201119,3,5416,1995,8837,9,4,14,FR,France +201118,3,5306,1815,8797,8,2,14,FR,France +201117,3,2659,310,5008,4,0,8,FR,France +201116,3,5061,1988,8134,8,3,13,FR,France +201115,3,6557,3038,10076,10,4,16,FR,France +201114,3,7352,3784,10920,12,6,18,FR,France +201113,3,8749,5213,12285,14,8,20,FR,France +201112,3,12491,7845,17137,20,13,27,FR,France +201111,3,14619,10009,19229,23,16,30,FR,France +201110,3,33628,26073,41183,53,41,65,FR,France +201109,3,54522,46057,62987,86,73,99,FR,France +201108,3,78392,67885,88899,124,107,141,FR,France +201107,3,149219,134798,163640,236,213,259,FR,France +201106,3,216579,200236,232922,343,317,369,FR,France +201105,3,278192,260235,296149,440,412,468,FR,France +201104,3,278218,259626,296810,440,411,469,FR,France +201103,3,275882,257313,294451,437,408,466,FR,France +201102,3,308949,288320,329578,489,456,522,FR,France +201101,3,309933,288190,331676,490,456,524,FR,France +201052,3,228105,208046,248164,363,331,395,FR,France +201051,3,158957,142576,175338,253,227,279,FR,France +201050,3,104874,91639,118109,167,146,188,FR,France +201049,3,54971,46418,63524,88,74,102,FR,France +201048,3,36982,29304,44660,59,47,71,FR,France +201047,3,26598,20123,33073,42,32,52,FR,France +201046,3,15465,10915,20015,25,18,32,FR,France +201045,3,9040,5772,12308,14,9,19,FR,France +201044,3,15833,10255,21411,25,16,34,FR,France +201043,3,16002,11001,21003,25,17,33,FR,France +201042,3,18709,13376,24042,30,22,38,FR,France +201041,3,17352,12182,22522,28,20,36,FR,France +201040,3,18331,12824,23838,29,20,38,FR,France +201039,3,11978,7913,16043,19,13,25,FR,France +201038,3,8936,4906,12966,14,8,20,FR,France +201037,3,5318,2551,8085,8,4,12,FR,France +201036,3,4954,2058,7850,8,3,13,FR,France +201035,3,4279,1604,6954,7,3,11,FR,France +201034,3,4926,566,9286,8,1,15,FR,France +201033,3,2950,0,6507,5,0,11,FR,France +201032,3,671,0,1522,1,0,2,FR,France +201031,3,2732,509,4955,4,0,8,FR,France +201030,3,3989,1068,6910,6,1,11,FR,France +201029,3,4123,1531,6715,7,3,11,FR,France +201028,3,1209,0,2640,2,0,4,FR,France +201027,3,2494,433,4555,4,1,7,FR,France +201026,3,5808,2454,9162,9,4,14,FR,France +201025,3,8019,4395,11643,13,7,19,FR,France +201024,3,3584,1657,5511,6,3,9,FR,France +201023,3,4016,1905,6127,6,3,9,FR,France +201022,3,6251,3664,8838,10,6,14,FR,France +201021,3,3860,1636,6084,6,2,10,FR,France +201020,3,2470,442,4498,4,1,7,FR,France +201019,3,2273,636,3910,4,1,7,FR,France +201018,3,4095,1639,6551,7,3,11,FR,France +201017,3,2216,817,3615,4,2,6,FR,France +201016,3,3471,1085,5857,6,2,10,FR,France +201015,3,3990,1376,6604,6,2,10,FR,France +201014,3,6188,3191,9185,10,5,15,FR,France +201013,3,6705,3665,9745,11,6,16,FR,France +201012,3,6727,3582,9872,11,6,16,FR,France +201011,3,8692,5002,12382,14,8,20,FR,France +201010,3,8844,5465,12223,14,9,19,FR,France +201009,3,12081,7334,16828,19,11,27,FR,France +201008,3,15433,10422,20444,25,17,33,FR,France +201007,3,19690,11728,27652,31,18,44,FR,France +201006,3,27858,18883,36833,44,30,58,FR,France +201005,3,22197,17019,27375,35,27,43,FR,France +201004,3,33817,26151,41483,54,42,66,FR,France +201003,3,36236,27936,44536,58,45,71,FR,France +201002,3,40691,32891,48491,65,53,77,FR,France +201001,3,66574,56164,76984,106,89,123,FR,France +200953,3,96141,81818,110464,153,130,176,FR,France +200952,3,172872,153238,192506,275,244,306,FR,France +200951,3,247809,229140,266478,395,365,425,FR,France +200950,3,379424,355974,402874,604,567,641,FR,France +200949,3,473718,447756,499680,754,713,795,FR,France +200948,3,467551,441506,493596,744,703,785,FR,France +200947,3,378924,355752,402096,603,566,640,FR,France +200946,3,223847,203918,243776,356,324,388,FR,France +200945,3,147046,131155,162937,234,209,259,FR,France +200944,3,170231,151298,189164,271,241,301,FR,France +200943,3,131408,114883,147933,209,183,235,FR,France +200942,3,99387,84491,114283,158,134,182,FR,France +200941,3,100802,86381,115223,160,137,183,FR,France +200940,3,111587,97628,125546,178,156,200,FR,France +200939,3,121267,106153,136381,193,169,217,FR,France +200938,3,137924,121242,154606,220,193,247,FR,France +200937,3,101332,87522,115142,161,139,183,FR,France +200936,3,46024,36435,55613,73,58,88,FR,France +200935,3,31660,23669,39651,50,37,63,FR,France +200934,3,24985,17699,32271,40,28,52,FR,France +200933,3,24435,16308,32562,39,26,52,FR,France +200932,3,23151,14624,31678,37,23,51,FR,France +200931,3,30255,9818,50692,48,15,81,FR,France +200930,3,13868,7861,19875,22,12,32,FR,France +200929,3,10704,5314,16094,17,8,26,FR,France +200928,3,15516,273,30759,25,1,49,FR,France +200927,3,10354,2760,17948,16,4,28,FR,France +200926,3,9932,5257,14607,16,9,23,FR,France +200925,3,7619,4026,11212,12,6,18,FR,France +200924,3,7794,3409,12179,12,5,19,FR,France +200923,3,4342,1975,6709,7,3,11,FR,France +200922,3,6390,3020,9760,10,5,15,FR,France +200921,3,7118,3704,10532,11,6,16,FR,France +200920,3,9482,5804,13160,15,9,21,FR,France +200919,3,7538,4299,10777,12,7,17,FR,France +200918,3,9627,5121,14133,15,8,22,FR,France +200917,3,9537,5267,13807,15,8,22,FR,France +200916,3,14666,9218,20114,23,14,32,FR,France +200915,3,17533,12137,22929,28,19,37,FR,France +200914,3,26324,19150,33498,42,31,53,FR,France +200913,3,27737,20781,34693,44,33,55,FR,France +200912,3,38811,29935,47687,62,48,76,FR,France +200911,3,40410,30705,50115,64,49,79,FR,France +200910,3,53395,41943,64847,85,67,103,FR,France +200909,3,70558,57400,83716,112,91,133,FR,France +200908,3,109100,94840,123360,174,151,197,FR,France +200907,3,141531,125101,157961,225,199,251,FR,France +200906,3,276274,252759,299789,440,403,477,FR,France +200905,3,401868,375032,428704,640,597,683,FR,France +200904,3,545313,512892,577734,868,816,920,FR,France +200903,3,520957,487271,554643,829,775,883,FR,France +200902,3,287145,262869,311421,457,418,496,FR,France +200901,3,200349,180878,219820,319,288,350,FR,France +200852,3,198418,115769,281067,323,188,458,FR,France +200851,3,112588,96656,128520,184,158,210,FR,France +200850,3,51746,43319,60173,84,70,98,FR,France +200849,3,34950,27527,42373,57,45,69,FR,France +200848,3,25604,18563,32645,42,31,53,FR,France +200847,3,18706,10838,26574,30,17,43,FR,France +200846,3,10899,5461,16337,18,9,27,FR,France +200845,3,12472,7082,17862,20,11,29,FR,France +200844,3,9772,5661,13883,16,9,23,FR,France +200843,3,9345,5541,13149,15,9,21,FR,France +200842,3,9087,5572,12602,15,9,21,FR,France +200841,3,9925,5637,14213,16,9,23,FR,France +200840,3,7869,4535,11203,13,8,18,FR,France +200839,3,2195,506,3884,4,1,7,FR,France +200838,3,3679,1481,5877,6,2,10,FR,France +200837,3,2429,561,4297,4,1,7,FR,France +200836,3,2512,492,4532,4,1,7,FR,France +200835,3,1901,0,4869,3,0,8,FR,France +200834,3,2552,0,6509,4,0,10,FR,France +200833,3,7229,0,16106,12,0,26,FR,France +200832,3,4378,107,8649,7,0,14,FR,France +200831,3,3972,621,7323,6,1,11,FR,France +200830,3,3821,643,6999,6,1,11,FR,France +200829,3,2055,0,4225,3,0,7,FR,France +200828,3,3257,208,6306,5,0,10,FR,France +200827,3,2862,474,5250,5,1,9,FR,France +200826,3,897,0,2062,1,0,3,FR,France +200825,3,2006,360,3652,3,0,6,FR,France +200824,3,3217,823,5611,5,1,9,FR,France +200823,3,2906,1006,4806,5,2,8,FR,France +200822,3,1792,451,3133,3,1,5,FR,France +200821,3,3642,925,6359,6,2,10,FR,France +200820,3,6452,2790,10114,11,5,17,FR,France +200819,3,5173,1485,8861,8,2,14,FR,France +200818,3,5315,1770,8860,9,3,15,FR,France +200817,3,10150,5835,14465,17,10,24,FR,France +200816,3,11876,7054,16698,19,11,27,FR,France +200815,3,22871,16253,29489,37,26,48,FR,France +200814,3,45610,27907,63313,74,45,103,FR,France +200813,3,38600,29300,47900,63,48,78,FR,France +200812,3,53169,43299,63039,87,71,103,FR,France +200811,3,62014,50430,73598,101,82,120,FR,France +200810,3,90342,75729,104955,147,123,171,FR,France +200809,3,119696,104205,135187,195,170,220,FR,France +200808,3,198688,180749,216627,324,295,353,FR,France +200807,3,286498,264535,308461,467,431,503,FR,France +200806,3,377097,350714,403480,615,572,658,FR,France +200805,3,344050,320436,367664,561,523,599,FR,France +200804,3,290196,268193,312199,473,437,509,FR,France +200803,3,260268,233385,287151,424,380,468,FR,France +200802,3,160872,145311,176433,262,237,287,FR,France +200801,3,102562,88547,116577,167,144,190,FR,France +200752,3,86742,72295,101189,141,117,165,FR,France +200751,3,61954,51764,72144,101,84,118,FR,France +200750,3,45366,36923,53809,74,60,88,FR,France +200749,3,38351,26177,50525,63,43,83,FR,France +200748,3,48174,35418,60930,79,58,100,FR,France +200747,3,30716,23351,38081,50,38,62,FR,France +200746,3,18204,12267,24141,30,20,40,FR,France +200745,3,15521,10195,20847,25,16,34,FR,France +200744,3,13904,9072,18736,23,15,31,FR,France +200743,3,16212,10778,21646,26,17,35,FR,France +200742,3,20197,13955,26439,33,23,43,FR,France +200741,3,12987,8464,17510,21,14,28,FR,France +200740,3,13517,2983,24051,22,5,39,FR,France +200739,3,15985,7519,24451,26,12,40,FR,France +200738,3,4769,837,8701,8,2,14,FR,France +200737,3,1449,300,2598,2,0,4,FR,France +200736,3,1100,0,2424,2,0,4,FR,France +200735,3,1177,0,2872,2,0,5,FR,France +200734,3,3353,654,6052,5,1,9,FR,France +200733,3,4189,360,8018,7,1,13,FR,France +200732,3,132,0,688,0,0,1,FR,France +200731,3,1965,0,4461,3,0,7,FR,France +200730,3,2158,0,4583,4,0,8,FR,France +200729,3,3406,240,6572,6,1,11,FR,France +200728,3,1459,0,3467,2,0,5,FR,France +200727,3,1453,0,3382,2,0,5,FR,France +200726,3,157,0,513,0,0,1,FR,France +200725,3,3699,0,7778,6,0,13,FR,France +200724,3,2854,481,5227,5,1,9,FR,France +200723,3,5343,2164,8522,9,4,14,FR,France +200722,3,7689,4224,11154,13,7,19,FR,France +200721,3,4319,1659,6979,7,3,11,FR,France +200720,3,6400,2685,10115,10,4,16,FR,France +200719,3,3012,703,5321,5,1,9,FR,France +200718,3,2232,348,4116,4,1,7,FR,France +200717,3,4705,1736,7674,8,3,13,FR,France +200716,3,3817,1438,6196,6,2,10,FR,France +200715,3,4757,717,8797,8,1,15,FR,France +200714,3,11377,6957,15797,19,12,26,FR,France +200713,3,21271,13093,29449,35,22,48,FR,France +200712,3,25433,17717,33149,41,28,54,FR,France +200711,3,30764,23356,38172,50,38,62,FR,France +200710,3,49469,40368,58570,81,66,96,FR,France +200709,3,138901,117018,160784,226,190,262,FR,France +200708,3,316747,284988,348506,516,464,568,FR,France +200707,3,417698,386505,448891,681,630,732,FR,France +200706,3,500016,466668,533364,815,761,869,FR,France +200705,3,375457,346822,404092,612,565,659,FR,France +200704,3,209878,189332,230424,342,309,375,FR,France +200703,3,126161,110596,141726,206,181,231,FR,France +200702,3,82849,69493,96205,135,113,157,FR,France +200701,3,70842,58613,83071,115,95,135,FR,France +200652,3,78190,64191,92189,128,105,151,FR,France +200651,3,62734,50210,75258,103,82,124,FR,France +200650,3,35668,27280,44056,58,44,72,FR,France +200649,3,18773,13164,24382,31,22,40,FR,France +200648,3,16439,11225,21653,27,18,36,FR,France +200647,3,16104,9343,22865,26,15,37,FR,France +200646,3,14032,5590,22474,23,9,37,FR,France +200645,3,12285,7745,16825,20,13,27,FR,France +200644,3,8031,4172,11890,13,7,19,FR,France +200643,3,21157,12483,29831,35,21,49,FR,France +200642,3,16673,8249,25097,27,13,41,FR,France +200641,3,13920,9081,18759,23,15,31,FR,France +200640,3,11950,7132,16768,20,12,28,FR,France +200639,3,8945,4333,13557,15,7,23,FR,France +200638,3,2532,138,4926,4,0,8,FR,France +200637,3,1786,233,3339,3,0,6,FR,France +200636,3,1107,0,2346,2,0,4,FR,France +200635,3,2170,0,4760,4,0,8,FR,France +200634,3,1572,0,3756,3,0,7,FR,France +200633,3,0,0,0,0,0,0,FR,France +200632,3,0,0,0,0,0,0,FR,France +200631,3,1773,0,3892,3,0,6,FR,France +200630,3,665,0,1614,1,0,3,FR,France +200629,3,1339,0,3260,2,0,5,FR,France +200628,3,843,0,2245,1,0,3,FR,France +200627,3,1351,0,3031,2,0,5,FR,France +200626,3,4564,1506,7622,7,2,12,FR,France +200625,3,6259,2072,10446,10,3,17,FR,France +200624,3,4279,964,7594,7,2,12,FR,France +200623,3,4532,1489,7575,7,2,12,FR,France +200622,3,5807,2667,8947,10,5,15,FR,France +200621,3,4661,1761,7561,8,3,13,FR,France +200620,3,8859,4754,12964,15,8,22,FR,France +200619,3,5083,2011,8155,8,3,13,FR,France +200618,3,4454,1632,7276,7,2,12,FR,France +200617,3,17762,11802,23722,29,19,39,FR,France +200616,3,22096,15420,28772,36,25,47,FR,France +200615,3,26969,19631,34307,44,32,56,FR,France +200614,3,40321,31022,49620,66,51,81,FR,France +200613,3,77053,63531,90575,126,104,148,FR,France +200612,3,108004,93005,123003,177,152,202,FR,France +200611,3,122437,106388,138486,201,175,227,FR,France +200610,3,124749,109104,140394,204,178,230,FR,France +200609,3,164150,146099,182201,269,239,299,FR,France +200608,3,199088,178830,219346,326,293,359,FR,France +200607,3,243908,221071,266745,400,363,437,FR,France +200606,3,256758,235190,278326,421,386,456,FR,France +200605,3,184928,166901,202955,303,273,333,FR,France +200604,3,104620,90909,118331,171,149,193,FR,France +200603,3,66255,55727,76783,109,92,126,FR,France +200602,3,39211,31418,47004,64,51,77,FR,France +200601,3,34603,26269,42937,57,43,71,FR,France +200552,3,32132,24389,39875,53,40,66,FR,France +200551,3,40344,28397,52291,67,47,87,FR,France +200550,3,36880,28635,45125,61,47,75,FR,France +200549,3,27589,20576,34602,46,34,58,FR,France +200548,3,24860,17839,31881,41,29,53,FR,France +200547,3,26884,19810,33958,44,32,56,FR,France +200546,3,23967,17155,30779,40,29,51,FR,France +200545,3,14609,8709,20509,24,14,34,FR,France +200544,3,20481,13625,27337,34,23,45,FR,France +200543,3,18045,11916,24174,30,20,40,FR,France +200542,3,23653,15209,32097,39,25,53,FR,France +200541,3,26466,18270,34662,44,30,58,FR,France +200540,3,26647,18088,35206,44,30,58,FR,France +200539,3,23994,15381,32607,40,26,54,FR,France +200538,3,21881,13979,29783,36,23,49,FR,France +200537,3,10347,5384,15310,17,9,25,FR,France +200536,3,7082,2806,11358,12,5,19,FR,France +200535,3,2448,0,4987,4,0,8,FR,France +200534,3,5281,539,10023,9,1,17,FR,France +200533,3,2815,0,6252,5,0,11,FR,France +200532,3,1572,0,3690,3,0,6,FR,France +200531,3,3767,0,10955,6,0,18,FR,France +200530,3,2203,0,5072,4,0,9,FR,France +200529,3,3965,739,7191,7,2,12,FR,France +200528,3,1988,96,3880,3,0,6,FR,France +200527,3,2305,0,4713,4,0,8,FR,France +200526,3,4720,1385,8055,8,2,14,FR,France +200525,3,2354,0,4747,4,0,8,FR,France +200524,3,5892,2029,9755,10,4,16,FR,France +200523,3,5246,1722,8770,9,3,15,FR,France +200522,3,3935,1031,6839,6,1,11,FR,France +200521,3,4284,474,8094,7,1,13,FR,France +200520,3,7841,3611,12071,13,6,20,FR,France +200519,3,7638,3346,11930,13,6,20,FR,France +200518,3,2755,388,5122,5,1,9,FR,France +200517,3,7166,3530,10802,12,6,18,FR,France +200516,3,9741,5344,14138,16,9,23,FR,France +200515,3,14881,9018,20744,25,15,35,FR,France +200514,3,21988,14834,29142,36,24,48,FR,France +200513,3,42971,33053,52889,71,55,87,FR,France +200512,3,90040,75374,104706,149,125,173,FR,France +200511,3,183032,161407,204657,302,266,338,FR,France +200510,3,222526,199990,245062,367,330,404,FR,France +200509,3,251784,229464,274104,416,379,453,FR,France +200508,3,277423,254825,300021,458,421,495,FR,France +200507,3,459444,430026,488862,759,710,808,FR,France +200506,3,568610,536207,601013,939,885,993,FR,France +200505,3,568285,534912,601658,938,883,993,FR,France +200504,3,316856,292011,341701,523,482,564,FR,France +200503,3,154208,137061,171355,255,227,283,FR,France +200502,3,88853,75576,102130,147,125,169,FR,France +200501,3,55801,45339,66263,92,75,109,FR,France +200453,3,40695,31926,49464,68,53,83,FR,France +200452,3,32687,24316,41058,54,40,68,FR,France +200451,3,46209,36017,56401,77,60,94,FR,France +200450,3,42358,31865,52851,70,53,87,FR,France +200449,3,27092,17910,36274,45,30,60,FR,France +200448,3,30522,21236,39808,51,36,66,FR,France +200447,3,21148,13386,28910,35,22,48,FR,France +200446,3,13934,8335,19533,23,14,32,FR,France +200445,3,15658,9703,21613,26,16,36,FR,France +200444,3,23166,14852,31480,38,24,52,FR,France +200443,3,16780,10545,23015,28,18,38,FR,France +200442,3,20480,13909,27051,34,23,45,FR,France +200441,3,15852,9789,21915,26,16,36,FR,France +200440,3,25639,17291,33987,43,29,57,FR,France +200439,3,22680,13222,32138,38,22,54,FR,France +200438,3,17483,9417,25549,29,16,42,FR,France +200437,3,9103,4768,13438,15,8,22,FR,France +200436,3,7753,3596,11910,13,6,20,FR,France +200435,3,4408,775,8041,7,1,13,FR,France +200434,3,4501,610,8392,7,1,13,FR,France +200433,3,1697,0,4046,3,0,7,FR,France +200432,3,3496,0,8181,6,0,14,FR,France +200431,3,2949,20,5878,5,0,10,FR,France +200430,3,3557,642,6472,6,1,11,FR,France +200429,3,5164,1162,9166,9,2,16,FR,France +200428,3,6358,2224,10492,11,4,18,FR,France +200427,3,7486,3040,11932,12,5,19,FR,France +200426,3,7113,0,14709,12,0,25,FR,France +200425,3,3275,508,6042,5,0,10,FR,France +200424,3,6737,2394,11080,11,4,18,FR,France +200423,3,9792,807,18777,16,1,31,FR,France +200422,3,8077,3482,12672,13,5,21,FR,France +200421,3,8073,3588,12558,13,6,20,FR,France +200420,3,7885,3454,12316,13,6,20,FR,France +200419,3,7235,3101,11369,12,5,19,FR,France +200418,3,5108,1830,8386,8,3,13,FR,France +200417,3,3647,523,6771,6,1,11,FR,France +200416,3,5265,1359,9171,9,3,15,FR,France +200415,3,8272,3655,12889,14,6,22,FR,France +200414,3,15657,8888,22426,26,15,37,FR,France +200413,3,8316,4067,12565,14,7,21,FR,France +200412,3,12482,6899,18065,21,12,30,FR,France +200411,3,13964,7879,20049,23,13,33,FR,France +200410,3,22531,14164,30898,37,23,51,FR,France +200409,3,12618,7283,17953,21,12,30,FR,France +200408,3,17738,11055,24421,29,18,40,FR,France +200407,3,25484,17228,33740,42,28,56,FR,France +200406,3,27452,19505,35399,46,33,59,FR,France +200405,3,35110,25869,44351,58,43,73,FR,France +200404,3,44571,35266,53876,74,59,89,FR,France +200403,3,60482,50389,70575,100,83,117,FR,France +200402,3,95234,81407,109061,158,135,181,FR,France +200401,3,109116,84565,133667,181,140,222,FR,France +200352,3,72239,5520,138958,121,10,232,FR,France +200351,3,445464,389214,501714,744,650,838,FR,France +200350,3,522427,491781,553073,873,822,924,FR,France +200349,3,555492,524706,586278,928,877,979,FR,France +200348,3,514668,485364,543972,860,811,909,FR,France +200347,3,332927,305972,359882,556,511,601,FR,France +200346,3,146101,126840,165362,244,212,276,FR,France +200345,3,95565,80900,110230,160,135,185,FR,France +200344,3,54703,43193,66213,91,72,110,FR,France +200343,3,45834,36611,55057,77,62,92,FR,France +200342,3,39010,28885,49135,65,48,82,FR,France +200341,3,29579,21478,37680,49,35,63,FR,France +200340,3,30862,19484,42240,52,33,71,FR,France +200339,3,26592,18927,34257,44,31,57,FR,France +200338,3,14811,8777,20845,25,15,35,FR,France +200337,3,14735,7495,21975,25,13,37,FR,France +200336,3,10951,3732,18170,18,6,30,FR,France +200335,3,1504,0,3349,3,0,6,FR,France +200334,3,2194,0,4889,4,0,9,FR,France +200333,3,1504,0,3921,3,0,7,FR,France +200332,3,1619,0,4072,3,0,7,FR,France +200331,3,5164,0,10601,9,0,18,FR,France +200330,3,3183,28,6338,5,0,10,FR,France +200329,3,6801,450,13152,11,0,22,FR,France +200328,3,3975,609,7341,7,1,13,FR,France +200327,3,2293,0,4605,4,0,8,FR,France +200326,3,5333,2138,8528,9,4,14,FR,France +200325,3,2602,0,5228,4,0,8,FR,France +200324,3,8429,0,19483,14,0,32,FR,France +200323,3,4821,1479,8163,8,2,14,FR,France +200322,3,2573,158,4988,4,0,8,FR,France +200321,3,5563,2465,8661,9,4,14,FR,France +200320,3,7554,3748,11360,13,7,19,FR,France +200319,3,8325,3777,12873,14,6,22,FR,France +200318,3,12268,6392,18144,20,10,30,FR,France +200317,3,46253,36234,56272,77,60,94,FR,France +200316,3,50759,39835,61683,85,67,103,FR,France +200315,3,69269,55778,82760,116,93,139,FR,France +200314,3,70084,55374,84794,117,92,142,FR,France +200313,3,70335,56370,84300,118,95,141,FR,France +200312,3,88582,73568,103596,148,123,173,FR,France +200311,3,99729,83353,116105,167,140,194,FR,France +200310,3,121516,104361,138671,203,174,232,FR,France +200309,3,177255,151800,202710,296,253,339,FR,France +200308,3,222638,194269,251007,372,325,419,FR,France +200307,3,237104,207851,266357,396,347,445,FR,France +200306,3,206955,177973,235937,346,298,394,FR,France +200305,3,151864,125877,177851,254,211,297,FR,France +200304,3,95356,76211,114501,159,127,191,FR,France +200303,3,50983,38264,63702,85,64,106,FR,France +200302,3,31447,21706,41188,53,37,69,FR,France +200301,3,31228,19202,43254,52,32,72,FR,France +200252,3,47016,33692,60340,79,57,101,FR,France +200251,3,47629,36912,58346,80,62,98,FR,France +200250,3,35221,26217,44225,59,44,74,FR,France +200249,3,24656,16900,32412,41,28,54,FR,France +200248,3,19799,12868,26730,33,21,45,FR,France +200247,3,16449,9214,23684,28,16,40,FR,France +200246,3,12753,5779,19727,21,9,33,FR,France +200245,3,19304,8475,30133,32,14,50,FR,France +200244,3,18082,10671,25493,30,18,42,FR,France +200243,3,14326,7548,21104,24,13,35,FR,France +200242,3,13774,7800,19748,23,13,33,FR,France +200241,3,11036,5650,16422,19,10,28,FR,France +200240,3,8137,3375,12899,14,6,22,FR,France +200239,3,15989,9892,22086,27,17,37,FR,France +200238,3,7067,3299,10835,12,6,18,FR,France +200237,3,12409,4981,19837,21,9,33,FR,France +200236,3,1679,0,4072,3,0,7,FR,France +200235,3,2126,0,6301,4,0,11,FR,France +200234,3,2843,0,7483,5,0,13,FR,France +200233,3,2670,0,5462,4,0,9,FR,France +200232,3,1087,0,3003,2,0,5,FR,France +200231,3,5455,399,10511,9,1,17,FR,France +200230,3,3601,0,7836,6,0,13,FR,France +200229,3,5576,379,10773,9,0,18,FR,France +200228,3,6602,0,14289,11,0,24,FR,France +200227,3,1882,0,6151,3,0,10,FR,France +200226,3,4523,0,12320,8,0,21,FR,France +200225,3,4765,1076,8454,8,2,14,FR,France +200224,3,12063,7174,16952,20,12,28,FR,France +200223,3,15468,9806,21130,26,16,36,FR,France +200222,3,4854,1696,8012,8,3,13,FR,France +200221,3,5901,2212,9590,10,4,16,FR,France +200220,3,3803,1215,6391,6,2,10,FR,France +200219,3,6139,2598,9680,10,4,16,FR,France +200218,3,6083,2646,9520,10,4,16,FR,France +200217,3,7223,2678,11768,12,4,20,FR,France +200216,3,17762,9887,25637,30,17,43,FR,France +200215,3,21654,13662,29646,36,23,49,FR,France +200214,3,23877,15709,32045,40,26,54,FR,France +200213,3,27497,16289,38705,46,27,65,FR,France +200212,3,33510,20938,46082,56,35,77,FR,France +200211,3,40426,29171,51681,68,49,87,FR,France +200210,3,42915,24537,61293,72,41,103,FR,France +200209,3,63735,48368,79102,107,81,133,FR,France +200208,3,117204,95548,138860,197,161,233,FR,France +200207,3,170251,137065,203437,286,230,342,FR,France +200206,3,325084,296111,354057,546,497,595,FR,France +200205,3,456186,422559,489813,767,710,824,FR,France +200204,3,504715,470859,538571,848,791,905,FR,France +200203,3,383720,353019,414421,645,593,697,FR,France +200202,3,244028,217752,270304,410,366,454,FR,France +200201,3,115422,95696,135148,194,161,227,FR,France +200152,3,57999,43225,72773,98,73,123,FR,France +200151,3,45961,36017,55905,78,61,95,FR,France +200150,3,31309,22878,39740,53,39,67,FR,France +200149,3,34792,23268,46316,59,40,78,FR,France +200148,3,43283,20164,66402,73,34,112,FR,France +200147,3,27455,20021,34889,46,33,59,FR,France +200146,3,21127,14294,27960,36,24,48,FR,France +200145,3,20766,13979,27553,35,24,46,FR,France +200144,3,11410,6593,16227,19,11,27,FR,France +200143,3,23311,15652,30970,39,26,52,FR,France +200142,3,18963,11652,26274,32,20,44,FR,France +200141,3,20241,14032,26450,34,24,44,FR,France +200140,3,18113,9971,26255,31,17,45,FR,France +200139,3,25407,7785,43029,43,13,73,FR,France +200138,3,9736,4985,14487,16,8,24,FR,France +200137,3,8025,3527,12523,14,6,22,FR,France +200136,3,4663,654,8672,8,1,15,FR,France +200135,3,4399,0,9810,7,0,16,FR,France +200134,3,2990,0,6419,5,0,11,FR,France +200133,3,0,0,0,0,0,0,FR,France +200132,3,0,0,0,0,0,0,FR,France +200131,3,18999,4286,33712,32,7,57,FR,France +200130,3,2144,0,5670,4,0,10,FR,France +200129,3,2408,0,5215,4,0,9,FR,France +200128,3,3555,553,6557,6,1,11,FR,France +200127,3,4739,1122,8356,8,2,14,FR,France +200126,3,3335,466,6204,6,1,11,FR,France +200125,3,2643,527,4759,4,0,8,FR,France +200124,3,4784,2158,7410,8,4,12,FR,France +200123,3,6299,3161,9437,11,6,16,FR,France +200122,3,4544,2006,7082,8,4,12,FR,France +200121,3,8925,4094,13756,15,7,23,FR,France +200120,3,15269,8883,21655,26,15,37,FR,France +200119,3,17369,10575,24163,29,18,40,FR,France +200118,3,21043,14262,27824,36,25,47,FR,France +200117,3,25787,19109,32465,44,33,55,FR,France +200116,3,24025,16833,31217,41,29,53,FR,France +200115,3,24188,17340,31036,41,29,53,FR,France +200114,3,40429,31774,49084,68,53,83,FR,France +200113,3,48644,39517,57771,82,67,97,FR,France +200112,3,45411,35780,55042,77,61,93,FR,France +200111,3,49809,40534,59084,84,68,100,FR,France +200110,3,46649,37240,56058,79,63,95,FR,France +200109,3,58623,47346,69900,99,80,118,FR,France +200108,3,77423,63237,91609,131,107,155,FR,France +200107,3,126970,107898,146042,215,183,247,FR,France +200106,3,225969,198142,253796,382,335,429,FR,France +200105,3,278674,249486,307862,471,422,520,FR,France +200104,3,209193,189129,229257,354,320,388,FR,France +200103,3,139823,124243,155403,236,210,262,FR,France +200102,3,105356,92392,118320,178,156,200,FR,France +200101,3,98930,84599,113261,167,143,191,FR,France +200052,3,143525,124203,162847,244,211,277,FR,France +200051,3,125224,108719,141729,213,185,241,FR,France +200050,3,99177,84857,113497,169,145,193,FR,France +200049,3,74170,54196,94144,126,92,160,FR,France +200048,3,43642,34064,53220,74,58,90,FR,France +200047,3,64848,11322,118374,110,19,201,FR,France +200046,3,20598,14053,27143,35,24,46,FR,France +200045,3,25375,17229,33521,43,29,57,FR,France +200044,3,16330,9762,22898,28,17,39,FR,France +200043,3,36951,27693,46209,63,47,79,FR,France +200042,3,41200,30772,51628,70,52,88,FR,France +200041,3,40022,30939,49105,68,53,83,FR,France +200040,3,27237,19986,34488,46,34,58,FR,France +200039,3,19338,12649,26027,33,22,44,FR,France +200038,3,7417,3193,11641,13,6,20,FR,France +200037,3,2243,0,4722,4,0,8,FR,France +200036,3,2990,0,6416,5,0,11,FR,France +200035,3,5590,0,12003,10,0,21,FR,France +200034,3,5188,0,12418,9,0,21,FR,France +200033,3,1690,0,3859,3,0,7,FR,France +200032,3,1405,0,4239,2,0,7,FR,France +200031,3,2159,0,4744,4,0,8,FR,France +200030,3,218,0,783,0,0,1,FR,France +200029,3,1532,0,3751,3,0,7,FR,France +200028,3,1071,0,2881,2,0,5,FR,France +200027,3,2427,150,4704,4,0,8,FR,France +200026,3,1997,0,4996,3,0,8,FR,France +200025,3,4239,221,8257,7,0,14,FR,France +200024,3,5411,1122,9700,9,2,16,FR,France +200023,3,8757,4101,13413,15,7,23,FR,France +200022,3,4966,1694,8238,8,2,14,FR,France +200021,3,4271,1389,7153,7,2,12,FR,France +200020,3,4520,1478,7562,8,3,13,FR,France +200019,3,13867,8548,19186,24,15,33,FR,France +200018,3,5386,2261,8511,9,4,14,FR,France +200017,3,7018,1581,12455,12,3,21,FR,France +200016,3,5328,1433,9223,9,2,16,FR,France +200015,3,12020,6436,17604,20,11,29,FR,France +200014,3,10942,5691,16193,19,10,28,FR,France +200013,3,8572,3443,13701,15,6,24,FR,France +200012,3,7081,3097,11065,12,5,19,FR,France +200011,3,12172,7447,16897,21,13,29,FR,France +200010,3,9091,5450,12732,15,9,21,FR,France +200009,3,14631,9200,20062,25,16,34,FR,France +200008,3,23647,17172,30122,40,29,51,FR,France +200007,3,59173,48440,69906,101,83,119,FR,France +200006,3,146517,129961,163073,249,221,277,FR,France +200005,3,261687,239983,283391,445,408,482,FR,France +200004,3,374822,349785,399859,637,594,680,FR,France +200003,3,484233,456706,511760,824,777,871,FR,France +200002,3,521069,492185,549953,886,837,935,FR,France +200001,3,541945,511326,572564,922,870,974,FR,France +199952,3,387655,360652,414658,663,617,709,FR,France +199951,3,272075,250906,293244,465,429,501,FR,France +199950,3,181113,164571,197655,310,282,338,FR,France +199949,3,112328,99058,125598,192,169,215,FR,France +199948,3,58710,48651,68769,100,83,117,FR,France +199947,3,35912,23462,48362,61,40,82,FR,France +199946,3,8601,1503,15699,15,3,27,FR,France +199945,3,17781,10817,24745,30,18,42,FR,France +199944,3,18238,12870,23606,31,22,40,FR,France +199943,3,18135,12601,23669,31,22,40,FR,France +199942,3,19183,13258,25108,33,23,43,FR,France +199941,3,25171,18689,31653,43,32,54,FR,France +199940,3,24185,16184,32186,41,27,55,FR,France +199939,3,28553,20776,36330,49,36,62,FR,France +199938,3,12430,7759,17101,21,13,29,FR,France +199937,3,7543,4283,10803,13,7,19,FR,France +199936,3,8191,2827,13555,14,5,23,FR,France +199935,3,3334,1188,5480,6,2,10,FR,France +199934,3,7600,0,27730,13,0,47,FR,France +199933,3,9757,354,19160,17,1,33,FR,France +199932,3,7149,0,15077,12,0,26,FR,France +199931,3,2640,0,5463,5,0,10,FR,France +199930,3,1478,0,3153,3,0,6,FR,France +199929,3,3983,498,7468,7,1,13,FR,France +199928,3,3731,712,6750,6,1,11,FR,France +199927,3,5004,1597,8411,9,3,15,FR,France +199926,3,3459,699,6219,6,1,11,FR,France +199925,3,5302,2057,8547,9,3,15,FR,France +199924,3,4327,1646,7008,7,2,12,FR,France +199923,3,5370,2374,8366,9,4,14,FR,France +199922,3,4404,1643,7165,8,3,13,FR,France +199921,3,4180,1485,6875,7,2,12,FR,France +199920,3,6073,2775,9371,10,4,16,FR,France +199919,3,6241,3220,9262,11,6,16,FR,France +199918,3,3057,678,5436,5,1,9,FR,France +199917,3,2904,701,5107,5,1,9,FR,France +199916,3,7539,3360,11718,13,6,20,FR,France +199915,3,11535,6814,16256,20,12,28,FR,France +199914,3,18730,13131,24329,32,22,42,FR,France +199913,3,38453,29560,47346,66,51,81,FR,France +199912,3,58090,48072,68108,99,82,116,FR,France +199911,3,91329,78686,103972,156,134,178,FR,France +199910,3,147976,131058,164894,253,224,282,FR,France +199909,3,207450,188710,226190,355,323,387,FR,France +199908,3,313293,292280,334306,536,500,572,FR,France +199907,3,524136,496702,551570,896,849,943,FR,France +199906,3,493908,466605,521211,844,797,891,FR,France +199905,3,476884,449696,504072,815,769,861,FR,France +199904,3,368514,345131,391897,630,590,670,FR,France +199903,3,242388,224208,260568,414,383,445,FR,France +199902,3,160657,145209,176105,275,249,301,FR,France +199901,3,130133,115125,145141,222,196,248,FR,France +199853,3,107611,92301,122921,185,159,211,FR,France +199852,3,72373,61032,83714,124,105,143,FR,France +199851,3,78179,67156,89202,134,115,153,FR,France +199850,3,54775,45478,64072,94,78,110,FR,France +199849,3,33385,26332,40438,57,45,69,FR,France +199848,3,22636,16668,28604,39,29,49,FR,France +199847,3,14505,9746,19264,25,17,33,FR,France +199846,3,13804,9049,18559,24,16,32,FR,France +199845,3,13021,8113,17929,22,14,30,FR,France +199844,3,12631,7410,17852,22,13,31,FR,France +199843,3,12180,7125,17235,21,12,30,FR,France +199842,3,18885,12726,25044,32,21,43,FR,France +199841,3,24196,17506,30886,42,31,53,FR,France +199840,3,20235,14114,26356,35,25,45,FR,France +199839,3,17075,11538,22612,29,20,38,FR,France +199838,3,10837,6336,15338,19,11,27,FR,France +199837,3,6968,3227,10709,12,6,18,FR,France +199836,3,3033,580,5486,5,1,9,FR,France +199835,3,2491,0,5022,4,0,8,FR,France +199834,3,3853,589,7117,7,1,13,FR,France +199833,3,2934,0,6598,5,0,11,FR,France +199832,3,1308,0,2894,2,0,5,FR,France +199831,3,12147,0,29237,21,0,50,FR,France +199830,3,5309,1628,8990,9,3,15,FR,France +199829,3,6486,2465,10507,11,4,18,FR,France +199828,3,9577,4464,14690,16,7,25,FR,France +199827,3,12358,7158,17558,21,12,30,FR,France +199826,3,10415,6547,14283,18,11,25,FR,France +199825,3,18246,13050,23442,31,22,40,FR,France +199824,3,16263,11126,21400,28,19,37,FR,France +199823,3,8553,4911,12195,15,9,21,FR,France +199822,3,5181,2669,7693,9,5,13,FR,France +199821,3,4751,2416,7086,8,4,12,FR,France +199820,3,12129,8099,16159,21,14,28,FR,France +199819,3,24118,17906,30330,41,30,52,FR,France +199818,3,31612,24512,38712,54,42,66,FR,France +199817,3,61148,51894,70402,105,89,121,FR,France +199816,3,123195,109878,136512,211,188,234,FR,France +199815,3,171603,156715,186491,294,268,320,FR,France +199814,3,319092,298398,339786,547,512,582,FR,France +199813,3,298212,278513,317911,512,478,546,FR,France +199812,3,263585,246356,280814,452,422,482,FR,France +199811,3,220578,204894,236262,378,351,405,FR,France +199810,3,202354,186304,218404,347,319,375,FR,France +199809,3,227553,209970,245136,390,360,420,FR,France +199808,3,271362,252005,290719,465,432,498,FR,France +199807,3,190187,173694,206680,326,298,354,FR,France +199806,3,88217,76829,99605,151,131,171,FR,France +199805,3,45180,36970,53390,77,63,91,FR,France +199804,3,30005,23272,36738,51,39,63,FR,France +199803,3,23900,18221,29579,41,31,51,FR,France +199802,3,31143,23994,38292,53,41,65,FR,France +199801,3,24809,17786,31832,43,31,55,FR,France +199752,3,29039,21984,36094,50,38,62,FR,France +199751,3,34924,27737,42111,60,48,72,FR,France +199750,3,33527,26388,40666,58,46,70,FR,France +199749,3,15978,11147,20809,27,19,35,FR,France +199748,3,11507,7744,15270,20,14,26,FR,France +199747,3,11059,7151,14967,19,12,26,FR,France +199746,3,8073,4613,11533,14,8,20,FR,France +199745,3,18202,13113,23291,31,22,40,FR,France +199744,3,19770,14405,25135,34,25,43,FR,France +199743,3,16707,11945,21469,29,21,37,FR,France +199742,3,15340,10351,20329,26,17,35,FR,France +199741,3,16933,11941,21925,29,20,38,FR,France +199740,3,13292,8709,17875,23,15,31,FR,France +199739,3,10189,6279,14099,18,11,25,FR,France +199738,3,3231,1061,5401,6,2,10,FR,France +199737,3,4542,1949,7135,8,4,12,FR,France +199736,3,5131,2205,8057,9,4,14,FR,France +199735,3,1842,0,3740,3,0,6,FR,France +199734,3,3226,0,6717,6,0,12,FR,France +199733,3,1799,0,4368,3,0,7,FR,France +199732,3,2086,0,4411,4,0,8,FR,France +199731,3,1386,0,3332,2,0,5,FR,France +199730,3,2116,0,4919,4,0,9,FR,France +199729,3,1973,0,4347,3,0,7,FR,France +199728,3,1560,216,2904,3,1,5,FR,France +199727,3,2540,754,4326,4,1,7,FR,France +199726,3,5582,2699,8465,10,5,15,FR,France +199725,3,4012,1090,6934,7,2,12,FR,France +199724,3,4696,1824,7568,8,3,13,FR,France +199723,3,4709,2136,7282,8,4,12,FR,France +199722,3,2283,665,3901,4,1,7,FR,France +199721,3,2108,664,3552,4,2,6,FR,France +199720,3,3257,1519,4995,6,3,9,FR,France +199719,3,4646,2436,6856,8,4,12,FR,France +199718,3,5246,2764,7728,9,5,13,FR,France +199717,3,14236,9906,18566,24,17,31,FR,France +199716,3,12169,8111,16227,21,14,28,FR,France +199715,3,9516,6192,12840,16,10,22,FR,France +199714,3,13602,9659,17545,23,16,30,FR,France +199713,3,18032,13345,22719,31,23,39,FR,France +199712,3,17199,12707,21691,30,22,38,FR,France +199711,3,19988,15419,24557,34,26,42,FR,France +199710,3,21903,17338,26468,38,30,46,FR,France +199709,3,29860,24261,35459,51,41,61,FR,France +199708,3,55445,47857,63033,95,82,108,FR,France +199707,3,70876,62518,79234,122,108,136,FR,France +199706,3,76906,68152,85660,132,117,147,FR,France +199705,3,95900,86095,105705,165,148,182,FR,France +199704,3,96896,87079,106713,167,150,184,FR,France +199703,3,143844,131917,155771,248,227,269,FR,France +199702,3,211578,197395,225761,364,340,388,FR,France +199701,3,280440,263783,297097,483,454,512,FR,France +199652,3,388201,369211,407191,670,637,703,FR,France +199651,3,640627,617388,663866,1106,1066,1146,FR,France +199650,3,535205,514568,555842,924,888,960,FR,France +199649,3,411498,393335,429661,710,679,741,FR,France +199648,3,195568,182563,208573,338,316,360,FR,France +199647,3,71980,63619,80341,124,110,138,FR,France +199646,3,32138,26358,37918,55,45,65,FR,France +199645,3,25551,20136,30966,44,35,53,FR,France +199644,3,10753,7230,14276,19,13,25,FR,France +199643,3,12971,9311,16631,22,16,28,FR,France +199642,3,11929,8472,15386,21,15,27,FR,France +199641,3,9918,6674,13162,17,11,23,FR,France +199640,3,10765,7067,14463,19,13,25,FR,France +199639,3,8377,5183,11571,14,8,20,FR,France +199638,3,9470,5965,12975,16,10,22,FR,France +199637,3,2925,829,5021,5,1,9,FR,France +199636,3,1122,23,2221,2,0,4,FR,France +199635,3,1674,93,3255,3,0,6,FR,France +199634,3,1273,122,2424,2,0,4,FR,France +199633,3,540,0,1246,1,0,2,FR,France +199632,3,1453,176,2730,3,1,5,FR,France +199631,3,3010,752,5268,5,1,9,FR,France +199630,3,2992,706,5278,5,1,9,FR,France +199629,3,1559,144,2974,3,1,5,FR,France +199628,3,3109,541,5677,5,1,9,FR,France +199627,3,4456,1595,7317,8,3,13,FR,France +199626,3,2871,1138,4604,5,2,8,FR,France +199625,3,2308,856,3760,4,1,7,FR,France +199624,3,2490,1067,3913,4,2,6,FR,France +199623,3,2819,1262,4376,5,2,8,FR,France +199622,3,4005,1984,6026,7,4,10,FR,France +199621,3,7042,4291,9793,12,7,17,FR,France +199620,3,10619,7365,13873,18,12,24,FR,France +199619,3,11898,8065,15731,21,14,28,FR,France +199618,3,18338,13352,23324,32,23,41,FR,France +199617,3,24954,19100,30808,43,33,53,FR,France +199616,3,29313,23868,34758,51,42,60,FR,France +199615,3,51703,43644,59762,89,75,103,FR,France +199614,3,44414,36774,52054,77,64,90,FR,France +199613,3,30622,25062,36182,53,43,63,FR,France +199612,3,31818,25852,37784,55,45,65,FR,France +199611,3,24427,19499,29355,42,33,51,FR,France +199610,3,20910,16198,25622,36,28,44,FR,France +199609,3,19594,15228,23960,34,26,42,FR,France +199608,3,19046,14850,23242,33,26,40,FR,France +199607,3,23041,18338,27744,40,32,48,FR,France +199606,3,21810,17153,26467,38,30,46,FR,France +199605,3,25275,20410,30140,44,36,52,FR,France +199604,3,43359,36948,49770,75,64,86,FR,France +199603,3,54691,48016,61366,94,82,106,FR,France +199602,3,105606,96106,115106,182,166,198,FR,France +199601,3,223830,209274,238386,386,361,411,FR,France +199552,3,397122,378252,415992,688,655,721,FR,France +199551,3,749988,725434,774542,1299,1256,1342,FR,France +199550,3,604926,583100,626752,1047,1009,1085,FR,France +199549,3,375500,358200,392800,650,620,680,FR,France +199548,3,206446,193457,219435,357,335,379,FR,France +199547,3,120472,110526,130418,209,192,226,FR,France +199546,3,62380,55042,69718,108,95,121,FR,France +199545,3,29791,24523,35059,52,43,61,FR,France +199544,3,13168,9820,16516,23,17,29,FR,France +199543,3,16188,12389,19987,28,21,35,FR,France +199542,3,15178,11387,18969,26,19,33,FR,France +199541,3,14980,10851,19109,26,19,33,FR,France +199540,3,16245,11610,20880,28,20,36,FR,France +199539,3,18499,13844,23154,32,24,40,FR,France +199538,3,13123,9410,16836,23,17,29,FR,France +199537,3,4895,2666,7124,8,4,12,FR,France +199536,3,3659,1574,5744,6,2,10,FR,France +199535,3,2496,644,4348,4,1,7,FR,France +199534,3,1887,214,3560,3,0,6,FR,France +199533,3,905,0,2007,2,0,4,FR,France +199532,3,700,0,1699,1,0,3,FR,France +199531,3,1946,92,3800,3,0,6,FR,France +199530,3,1898,46,3750,3,0,6,FR,France +199529,3,2148,687,3609,4,1,7,FR,France +199528,3,3312,1430,5194,6,3,9,FR,France +199527,3,4853,2683,7023,8,4,12,FR,France +199526,3,4986,2911,7061,9,5,13,FR,France +199525,3,4571,2520,6622,8,4,12,FR,France +199524,3,8058,5054,11062,14,9,19,FR,France +199523,3,13820,9801,17839,24,17,31,FR,France +199522,3,14124,9999,18249,24,17,31,FR,France +199521,3,11931,8655,15207,21,15,27,FR,France +199520,3,18846,14311,23381,33,25,41,FR,France +199519,3,26261,21488,31034,45,37,53,FR,France +199518,3,39231,33258,45204,68,58,78,FR,France +199517,3,88640,79343,97937,153,137,169,FR,France +199516,3,140488,129439,151537,243,224,262,FR,France +199515,3,181007,169110,192904,313,292,334,FR,France +199514,3,248704,235144,262264,431,408,454,FR,France +199513,3,209839,197191,222487,363,341,385,FR,France +199512,3,122434,112497,132371,212,195,229,FR,France +199511,3,81730,73346,90114,142,127,157,FR,France +199510,3,49387,42703,56071,86,74,98,FR,France +199509,3,39696,33259,46133,69,58,80,FR,France +199508,3,38008,32225,43791,66,56,76,FR,France +199507,3,30550,25479,35621,53,44,62,FR,France +199506,3,37351,32007,42695,65,56,74,FR,France +199505,3,27876,23218,32534,48,40,56,FR,France +199504,3,27643,22818,32468,48,40,56,FR,France +199503,3,24844,20391,29297,43,35,51,FR,France +199502,3,23480,19249,27711,41,34,48,FR,France +199501,3,26556,21916,31196,46,38,54,FR,France +199452,3,22036,17495,26577,38,30,46,FR,France +199451,3,26912,21750,32074,47,38,56,FR,France +199450,3,28831,23470,34192,50,41,59,FR,France +199449,3,21161,16559,25763,37,29,45,FR,France +199448,3,18487,14456,22518,32,25,39,FR,France +199447,3,15206,11578,18834,26,20,32,FR,France +199446,3,14252,10525,17979,25,19,31,FR,France +199445,3,12152,8448,15856,21,15,27,FR,France +199444,3,11307,7688,14926,20,14,26,FR,France +199443,3,11254,8002,14506,20,14,26,FR,France +199442,3,14406,10653,18159,25,18,32,FR,France +199441,3,14073,10341,17805,24,18,30,FR,France +199440,3,15962,11850,20074,28,21,35,FR,France +199439,3,15878,11643,20113,28,21,35,FR,France +199438,3,15366,11100,19632,27,20,34,FR,France +199437,3,5949,3561,8337,10,6,14,FR,France +199436,3,2806,1133,4479,5,2,8,FR,France +199435,3,4556,2358,6754,8,4,12,FR,France +199434,3,3459,1444,5474,6,2,10,FR,France +199433,3,4272,977,7567,7,1,13,FR,France +199432,3,4786,1613,7959,8,2,14,FR,France +199431,3,5027,1580,8474,9,3,15,FR,France +199430,3,2100,520,3680,4,1,7,FR,France +199429,3,1188,0,2384,2,0,4,FR,France +199428,3,1581,316,2846,3,1,5,FR,France +199427,3,713,0,1459,1,0,2,FR,France +199426,3,990,80,1900,2,0,4,FR,France +199425,3,5431,3222,7640,9,5,13,FR,France +199424,3,6288,3723,8853,11,7,15,FR,France +199423,3,6440,1052,11828,11,2,20,FR,France +199422,3,845,0,2449,1,0,4,FR,France +199421,3,2197,395,3999,4,1,7,FR,France +199420,3,2217,852,3582,4,2,6,FR,France +199419,3,1483,406,2560,3,1,5,FR,France +199418,3,3705,1940,5470,6,3,9,FR,France +199417,3,2288,1064,3512,4,2,6,FR,France +199416,3,5156,3176,7136,9,6,12,FR,France +199415,3,6952,4678,9226,12,8,16,FR,France +199414,3,4671,2784,6558,8,5,11,FR,France +199413,3,3343,1641,5045,6,3,9,FR,France +199412,3,4305,2412,6198,7,4,10,FR,France +199411,3,5399,3327,7471,9,5,13,FR,France +199410,3,4548,2529,6567,8,4,12,FR,France +199409,3,5635,3251,8019,10,6,14,FR,France +199408,3,9539,6652,12426,17,12,22,FR,France +199407,3,14639,11188,18090,25,19,31,FR,France +199406,3,17308,13395,21221,30,23,37,FR,France +199405,3,18489,14290,22688,32,25,39,FR,France +199404,3,23712,19048,28376,41,33,49,FR,France +199403,3,29882,24817,34947,52,43,61,FR,France +199402,3,47402,41415,53389,82,72,92,FR,France +199401,3,118119,108182,128056,205,188,222,FR,France +199352,3,233137,218608,247666,406,381,431,FR,France +199351,3,377472,359792,395152,658,627,689,FR,France +199350,3,627639,607097,648181,1094,1058,1130,FR,France +199349,3,898045,873419,922671,1565,1522,1608,FR,France +199348,3,527582,507752,547412,920,885,955,FR,France +199347,3,241371,226769,255973,421,396,446,FR,France +199346,3,76034,68003,84065,133,119,147,FR,France +199345,3,32289,27022,37556,56,47,65,FR,France +199344,3,17832,14015,21649,31,24,38,FR,France +199343,3,15098,11333,18863,26,19,33,FR,France +199342,3,19187,14893,23481,33,26,40,FR,France +199341,3,18285,14384,22186,32,25,39,FR,France +199340,3,13805,10348,17262,24,18,30,FR,France +199339,3,14783,11173,18393,26,20,32,FR,France +199338,3,10492,7329,13655,18,12,24,FR,France +199337,3,7023,4503,9543,12,8,16,FR,France +199336,3,4361,2445,6277,8,5,11,FR,France +199335,3,5589,3066,8112,10,6,14,FR,France +199334,3,2984,1209,4759,5,2,8,FR,France +199333,3,3217,758,5676,6,2,10,FR,France +199332,3,3755,1051,6459,7,2,12,FR,France +199331,3,4163,1768,6558,7,3,11,FR,France +199330,3,4055,1907,6203,7,3,11,FR,France +199329,3,3714,1668,5760,6,2,10,FR,France +199328,3,1774,484,3064,3,1,5,FR,France +199327,3,2574,918,4230,4,1,7,FR,France +199326,3,3048,1450,4646,5,2,8,FR,France +199325,3,8348,5260,11436,15,10,20,FR,France +199324,3,6624,3747,9501,12,7,17,FR,France +199323,3,7424,4302,10546,13,8,18,FR,France +199322,3,3432,1849,5015,6,3,9,FR,France +199321,3,5942,3670,8214,10,6,14,FR,France +199320,3,5137,3157,7117,9,6,12,FR,France +199319,3,4593,2725,6461,8,5,11,FR,France +199318,3,5027,3075,6979,9,6,12,FR,France +199317,3,8111,5138,11084,14,9,19,FR,France +199316,3,24932,19468,30396,43,33,53,FR,France +199315,3,22181,17147,27215,39,30,48,FR,France +199314,3,38266,30865,45667,67,54,80,FR,France +199313,3,62987,54506,71468,110,95,125,FR,France +199312,3,63493,55956,71030,111,98,124,FR,France +199311,3,80548,72628,88468,140,126,154,FR,France +199310,3,127910,117688,138132,223,205,241,FR,France +199309,3,184150,171378,196922,321,299,343,FR,France +199308,3,222932,209051,236813,389,365,413,FR,France +199307,3,248494,234936,262052,433,409,457,FR,France +199306,3,286939,271830,302048,500,474,526,FR,France +199305,3,255890,241516,270264,446,421,471,FR,France +199304,3,193107,181261,204953,337,316,358,FR,France +199303,3,147854,137256,158452,258,240,276,FR,France +199302,3,90269,82164,98374,157,143,171,FR,France +199301,3,75288,67244,83332,131,117,145,FR,France +199253,3,56622,49107,64137,99,86,112,FR,France +199252,3,49588,42568,56608,87,75,99,FR,France +199251,3,41156,35024,47288,72,61,83,FR,France +199250,3,40100,34699,45501,70,61,79,FR,France +199249,3,39146,33847,44445,69,60,78,FR,France +199248,3,32392,27499,37285,57,48,66,FR,France +199247,3,26276,21797,30755,46,38,54,FR,France +199246,3,22758,18462,27054,40,32,48,FR,France +199245,3,22023,17804,26242,39,32,46,FR,France +199244,3,27619,22945,32293,48,40,56,FR,France +199243,3,24969,20704,29234,44,37,51,FR,France +199242,3,29980,25261,34699,52,44,60,FR,France +199241,3,24091,19953,28229,42,35,49,FR,France +199240,3,17593,13885,21301,31,25,37,FR,France +199239,3,13535,10301,16769,24,18,30,FR,France +199238,3,9837,7106,12568,17,12,22,FR,France +199237,3,7480,5130,9830,13,9,17,FR,France +199236,3,5155,2958,7352,9,5,13,FR,France +199235,3,6383,3687,9079,11,6,16,FR,France +199234,3,2953,922,4984,5,1,9,FR,France +199233,3,4046,1549,6543,7,3,11,FR,France +199232,3,4963,2215,7711,9,4,14,FR,France +199231,3,4233,1733,6733,7,3,11,FR,France +199230,3,3091,1145,5037,5,2,8,FR,France +199229,3,3586,1583,5589,6,2,10,FR,France +199228,3,4179,2133,6225,7,3,11,FR,France +199227,3,5568,3134,8002,10,6,14,FR,France +199226,3,5886,3229,8543,10,5,15,FR,France +199225,3,5304,2805,7803,9,5,13,FR,France +199224,3,5928,3482,8374,10,6,14,FR,France +199223,3,3914,1855,5973,7,3,11,FR,France +199222,3,4899,2641,7157,9,5,13,FR,France +199221,3,5059,2889,7229,9,5,13,FR,France +199220,3,4308,2226,6390,8,4,12,FR,France +199219,3,2982,1181,4783,5,2,8,FR,France +199218,3,3887,1777,5997,7,3,11,FR,France +199217,3,3614,1216,6012,6,2,10,FR,France +199216,3,5460,2934,7986,10,6,14,FR,France +199215,3,8642,5029,12255,15,9,21,FR,France +199214,3,11346,7536,15156,20,13,27,FR,France +199213,3,11693,8096,15290,20,14,26,FR,France +199212,3,11752,7834,15670,21,14,28,FR,France +199211,3,11689,7575,15803,20,13,27,FR,France +199210,3,19224,12971,25477,34,23,45,FR,France +199209,3,26629,20275,32983,47,36,58,FR,France +199208,3,37667,30887,44447,66,54,78,FR,France +199207,3,57312,48777,65847,100,85,115,FR,France +199206,3,112450,99989,124911,197,175,219,FR,France +199205,3,165474,151342,179606,290,265,315,FR,France +199204,3,147959,133595,162323,259,234,284,FR,France +199203,3,137893,122944,152842,241,215,267,FR,France +199202,3,185852,166558,205146,325,291,359,FR,France +199201,3,247688,222574,272802,434,390,478,FR,France +199152,3,349815,325499,374131,615,572,658,FR,France +199151,3,378413,355928,400898,666,626,706,FR,France +199150,3,198721,182878,214564,350,322,378,FR,France +199149,3,93903,82992,104814,165,146,184,FR,France +199148,3,45173,37384,52962,79,65,93,FR,France +199147,3,35691,28224,43158,63,50,76,FR,France +199146,3,23685,17531,29839,42,31,53,FR,France +199145,3,19565,13551,25579,34,23,45,FR,France +199144,3,21571,15477,27665,38,27,49,FR,France +199143,3,28842,21958,35726,51,39,63,FR,France +199142,3,27483,20385,34581,48,36,60,FR,France +199141,3,28185,20655,35715,50,37,63,FR,France +199140,3,26740,16049,37431,47,28,66,FR,France +199139,3,14373,8734,20012,25,15,35,FR,France +199138,3,7460,3700,11220,13,6,20,FR,France +199137,3,2429,434,4424,4,0,8,FR,France +199136,3,2380,0,4882,4,0,8,FR,France +199135,3,2372,0,5025,4,0,9,FR,France +199134,3,2099,0,5104,4,0,9,FR,France +199133,3,1654,0,4102,3,0,7,FR,France +199132,3,625,0,2190,1,0,4,FR,France +199131,3,2464,0,5830,4,0,10,FR,France +199130,3,2382,0,6857,4,0,12,FR,France +199129,3,3837,40,7634,7,0,14,FR,France +199128,3,3297,152,6442,6,0,12,FR,France +199127,3,3164,934,5394,6,2,10,FR,France +199126,3,6376,3324,9428,11,6,16,FR,France +199125,3,8218,4776,11660,14,8,20,FR,France +199124,3,8223,4660,11786,14,8,20,FR,France +199123,3,6801,3596,10006,12,6,18,FR,France +199122,3,6050,2682,9418,11,5,17,FR,France +199121,3,6391,3385,9397,11,6,16,FR,France +199120,3,8633,4683,12583,15,8,22,FR,France +199119,3,7785,3986,11584,14,7,21,FR,France +199118,3,10856,6457,15255,19,11,27,FR,France +199117,3,15603,10950,20256,27,19,35,FR,France +199116,3,15665,11184,20146,28,20,36,FR,France +199115,3,15062,10715,19409,26,18,34,FR,France +199114,3,27862,21583,34141,49,38,60,FR,France +199113,3,32179,25829,38529,57,46,68,FR,France +199112,3,27873,22312,33434,49,39,59,FR,France +199111,3,46186,38876,53496,81,68,94,FR,France +199110,3,88750,77784,99716,156,137,175,FR,France +199109,3,139093,124326,153860,245,219,271,FR,France +199108,3,216369,198630,234108,381,350,412,FR,France +199107,3,208836,191789,225883,367,337,397,FR,France +199106,3,134737,121280,148194,237,213,261,FR,France +199105,3,73564,62716,84412,129,110,148,FR,France +199104,3,48253,39031,57475,85,69,101,FR,France +199103,3,29382,22258,36506,52,39,65,FR,France +199102,3,29759,22044,37474,52,38,66,FR,France +199101,3,42927,33706,52148,76,60,92,FR,France +199052,3,41262,31607,50917,73,56,90,FR,France +199051,3,46924,37544,56304,83,66,100,FR,France +199050,3,44125,36137,52113,78,64,92,FR,France +199049,3,38379,30603,46155,68,54,82,FR,France +199048,3,29571,22315,36827,52,39,65,FR,France +199047,3,23358,15890,30826,41,28,54,FR,France +199046,3,20246,7930,32562,36,14,58,FR,France +199045,3,17571,11591,23551,31,20,42,FR,France +199044,3,16182,10305,22059,29,19,39,FR,France +199043,3,17579,11588,23570,31,20,42,FR,France +199042,3,13011,7875,18147,23,14,32,FR,France +199041,3,19723,13330,26116,35,24,46,FR,France +199040,3,20433,14614,26252,36,26,46,FR,France +199039,3,15618,10315,20921,28,19,37,FR,France +199038,3,11146,6197,16095,20,11,29,FR,France +199037,3,4051,1022,7080,7,2,12,FR,France +199036,3,2542,124,4960,4,0,8,FR,France +199035,3,934,0,2681,2,0,5,FR,France +199034,3,201,0,595,0,0,1,FR,France +199033,3,0,0,0,0,0,0,FR,France +199032,3,1399,0,3849,2,0,6,FR,France +199031,3,881,0,2206,2,0,4,FR,France +199030,3,425,0,1262,1,0,2,FR,France +199029,3,1077,0,2643,2,0,5,FR,France +199028,3,959,0,2252,2,0,4,FR,France +199027,3,2948,793,5103,5,1,9,FR,France +199026,3,7236,2651,11821,13,5,21,FR,France +199025,3,7879,3136,12622,14,6,22,FR,France +199024,3,5727,2460,8994,10,4,16,FR,France +199023,3,3655,1043,6267,6,1,11,FR,France +199022,3,4196,1292,7100,7,2,12,FR,France +199021,3,1004,0,2367,2,0,4,FR,France +199020,3,4506,1771,7241,8,3,13,FR,France +199019,3,5897,2440,9354,10,4,16,FR,France +199018,3,1738,141,3335,3,0,6,FR,France +199017,3,5278,2197,8359,9,4,14,FR,France +199016,3,8129,3754,12504,14,6,22,FR,France +199015,3,11707,5831,17583,21,11,31,FR,France +199014,3,12862,8177,17547,23,15,31,FR,France +199013,3,21879,15088,28670,39,27,51,FR,France +199012,3,17035,11135,22935,30,20,40,FR,France +199011,3,20018,14311,25725,35,25,45,FR,France +199010,3,16294,11045,21543,29,20,38,FR,France +199009,3,21793,15460,28126,39,28,50,FR,France +199008,3,26110,19342,32878,46,34,58,FR,France +199007,3,61742,49720,73764,109,88,130,FR,France +199006,3,399984,353345,446623,707,625,789,FR,France +199005,3,161765,146354,177176,286,259,313,FR,France +199004,3,287771,267698,307844,509,474,544,FR,France +199003,3,315466,296550,334382,558,525,591,FR,France +199002,3,345060,326087,364033,610,576,644,FR,France +199001,3,483600,460913,506287,855,815,895,FR,France +198952,3,581149,556023,606275,1035,990,1080,FR,France +198951,3,821540,793846,849234,1463,1414,1512,FR,France +198950,3,749283,723633,774933,1334,1288,1380,FR,France +198949,3,358043,340053,376033,638,606,670,FR,France +198948,3,119087,108253,129921,212,193,231,FR,France +198947,3,40963,33897,48029,73,60,86,FR,France +198946,3,23547,17952,29142,42,32,52,FR,France +198945,3,22711,16999,28423,40,30,50,FR,France +198944,3,23405,17475,29335,42,31,53,FR,France +198943,3,29549,23287,35811,53,42,64,FR,France +198942,3,39410,32172,46648,70,57,83,FR,France +198941,3,43763,35245,52281,78,63,93,FR,France +198940,3,31453,24288,38618,56,43,69,FR,France +198939,3,24622,18425,30819,44,33,55,FR,France +198938,3,18296,13483,23109,33,24,42,FR,France +198937,3,12022,8082,15962,21,14,28,FR,France +198936,3,4769,2299,7239,8,4,12,FR,France +198935,3,4661,1696,7626,8,3,13,FR,France +198934,3,6039,2185,9893,11,4,18,FR,France +198933,3,7940,3858,12022,14,7,21,FR,France +198932,3,7114,2361,11867,13,5,21,FR,France +198931,3,2721,0,5478,5,0,10,FR,France +198930,3,3168,561,5775,6,1,11,FR,France +198929,3,3909,1504,6314,7,3,11,FR,France +198928,3,1284,105,2463,2,0,4,FR,France +198927,3,3641,1350,5932,6,2,10,FR,France +198926,3,5753,2885,8621,10,5,15,FR,France +198925,3,6299,3454,9144,11,6,16,FR,France +198924,3,6337,3537,9137,11,6,16,FR,France +198923,3,11779,7984,15574,21,14,28,FR,France +198922,3,9104,4764,13444,16,8,24,FR,France +198921,3,9554,4316,14792,17,8,26,FR,France +198920,3,6093,1023,11163,11,2,20,FR,France +198919,3,0,,,0,,,FR,France +198918,3,13452,1365,25539,24,2,46,FR,France +198917,3,10949,7147,14751,19,12,26,FR,France +198916,3,10908,7494,14322,19,13,25,FR,France +198915,3,9667,6209,13125,17,11,23,FR,France +198914,3,15230,10469,19991,27,19,35,FR,France +198913,3,10564,6767,14361,19,12,26,FR,France +198912,3,13419,9542,17296,24,17,31,FR,France +198911,3,16633,12140,21126,30,22,38,FR,France +198910,3,12387,8750,16024,22,16,28,FR,France +198909,3,12895,9183,16607,23,16,30,FR,France +198908,3,19746,15258,24234,35,27,43,FR,France +198907,3,27277,21760,32794,49,39,59,FR,France +198906,3,47844,40320,55368,85,72,98,FR,France +198905,3,52840,45665,60015,94,81,107,FR,France +198904,3,54942,47750,62134,98,85,111,FR,France +198903,3,66010,58065,73955,118,104,132,FR,France +198902,3,112284,102003,122565,200,182,218,FR,France +198901,3,202266,188305,216227,360,335,385,FR,France +198852,3,467971,447033,488909,837,800,874,FR,France +198851,3,872748,846468,899028,1562,1515,1609,FR,France +198850,3,1001824,974799,1028849,1793,1745,1841,FR,France +198849,3,966523,940068,992978,1729,1682,1776,FR,France +198848,3,637811,614785,660837,1141,1100,1182,FR,France +198847,3,246062,231234,260890,440,413,467,FR,France +198846,3,92484,83160,101808,165,148,182,FR,France +198845,3,53940,46148,61732,97,83,111,FR,France +198844,3,42106,35336,48876,75,63,87,FR,France +198843,3,38252,31909,44595,68,57,79,FR,France +198842,3,45495,38467,52523,81,68,94,FR,France +198841,3,46336,39344,53328,83,70,96,FR,France +198840,3,39882,33507,46257,71,60,82,FR,France +198839,3,43730,36755,50705,78,66,90,FR,France +198838,3,35243,29367,41119,63,52,74,FR,France +198837,3,15537,11911,19163,28,22,34,FR,France +198836,3,7539,4840,10238,13,8,18,FR,France +198835,3,7797,4762,10832,14,9,19,FR,France +198834,3,4950,2005,7895,9,4,14,FR,France +198833,3,7937,3861,12013,14,7,21,FR,France +198832,3,7033,2595,11471,13,5,21,FR,France +198831,3,8758,3591,13925,16,7,25,FR,France +198830,3,4205,1224,7186,8,3,13,FR,France +198829,3,6103,1013,11193,11,2,20,FR,France +198828,3,8562,3483,13641,15,6,24,FR,France +198827,3,4690,2196,7184,8,4,12,FR,France +198826,3,7065,3905,10225,13,7,19,FR,France +198825,3,7657,4664,10650,14,9,19,FR,France +198824,3,6676,3978,9374,12,7,17,FR,France +198823,3,8695,5755,11635,16,11,21,FR,France +198822,3,11566,8282,14850,21,15,27,FR,France +198821,3,11107,7742,14472,20,14,26,FR,France +198820,3,14118,10223,18013,25,18,32,FR,France +198819,3,18260,13847,22673,33,25,41,FR,France +198818,3,20415,16281,24549,37,30,44,FR,France +198817,3,21750,17436,26064,39,31,47,FR,France +198816,3,33730,27496,39964,60,49,71,FR,France +198815,3,70616,61754,79478,126,110,142,FR,France +198814,3,123868,113211,134525,222,203,241,FR,France +198813,3,193710,181519,205901,347,325,369,FR,France +198812,3,283445,268834,298056,507,481,533,FR,France +198811,3,316175,300858,331492,566,539,593,FR,France +198810,3,235142,222004,248280,421,397,445,FR,France +198809,3,135564,125263,145865,243,225,261,FR,France +198808,3,87753,78449,97057,157,140,174,FR,France +198807,3,77099,68423,85775,138,122,154,FR,France +198806,3,69349,61502,77196,124,110,138,FR,France +198805,3,72705,64952,80458,130,116,144,FR,France +198804,3,72818,64944,80692,130,116,144,FR,France +198803,3,68869,60922,76816,123,109,137,FR,France +198802,3,59743,51907,67579,107,93,121,FR,France +198801,3,60929,52573,69285,109,94,124,FR,France +198753,3,47257,38170,56344,85,69,101,FR,France +198752,3,11935,2353,21517,21,4,38,FR,France +198751,3,47744,34266,61222,86,62,110,FR,France +198750,3,57767,50181,65353,104,90,118,FR,France +198749,3,49380,42461,56299,89,77,101,FR,France +198748,3,41871,35115,48627,75,63,87,FR,France +198747,3,29688,23465,35911,53,42,64,FR,France +198746,3,37216,30199,44233,67,54,80,FR,France +198745,3,35456,29024,41888,64,52,76,FR,France +198744,3,41024,33829,48219,74,61,87,FR,France +198743,3,46356,38370,54342,83,69,97,FR,France +198742,3,38021,30236,45806,68,54,82,FR,France +198741,3,42021,32016,52026,76,58,94,FR,France +198740,3,24641,15930,33352,44,28,60,FR,France +198739,3,32328,23548,41108,58,42,74,FR,France +198738,3,16782,11870,21694,30,21,39,FR,France +198737,3,11208,6542,15874,20,12,28,FR,France +198736,3,7906,4014,11798,14,7,21,FR,France +198735,3,6149,2970,9328,11,5,17,FR,France +198734,3,6631,2734,10528,12,5,19,FR,France +198733,3,6404,1834,10974,12,4,20,FR,France +198732,3,7215,2353,12077,13,4,22,FR,France +198731,3,8233,3655,12811,15,7,23,FR,France +198730,3,4642,1301,7983,8,2,14,FR,France +198729,3,4389,913,7865,8,2,14,FR,France +198728,3,2702,138,5266,5,0,10,FR,France +198727,3,10171,5904,14438,18,10,26,FR,France +198726,3,12341,7824,16858,22,14,30,FR,France +198725,3,23413,15490,31336,42,28,56,FR,France +198724,3,11289,7282,15296,20,13,27,FR,France +198723,3,15857,10943,20771,29,20,38,FR,France +198722,3,14887,9743,20031,27,18,36,FR,France +198721,3,17619,12649,22589,32,23,41,FR,France +198720,3,10344,6454,14234,19,12,26,FR,France +198719,3,12539,7943,17135,23,15,31,FR,France +198718,3,16095,10330,21860,29,19,39,FR,France +198717,3,21256,14850,27662,38,26,50,FR,France +198716,3,32416,25100,39732,58,45,71,FR,France +198715,3,44292,36456,52128,80,66,94,FR,France +198714,3,50642,41866,59418,91,75,107,FR,France +198713,3,62246,52749,71743,112,95,129,FR,France +198712,3,59625,50653,68597,107,91,123,FR,France +198711,3,53561,45035,62087,96,81,111,FR,France +198710,3,93067,80519,105615,167,144,190,FR,France +198709,3,147006,133519,160493,264,240,288,FR,France +198708,3,217779,202179,233379,391,363,419,FR,France +198707,3,288180,270718,305642,518,487,549,FR,France +198706,3,296702,279051,314353,533,501,565,FR,France +198705,3,236046,219483,252609,424,394,454,FR,France +198704,3,158333,143625,173041,285,259,311,FR,France +198703,3,103841,91699,115983,187,165,209,FR,France +198702,3,74213,64014,84412,133,115,151,FR,France +198701,3,69745,59207,80283,125,106,144,FR,France +198652,3,76263,64958,87568,138,118,158,FR,France +198651,3,72920,63047,82793,132,114,150,FR,France +198650,3,73413,64019,82807,133,116,150,FR,France +198649,3,56296,48229,64363,102,87,117,FR,France +198648,3,46031,38578,53484,83,70,96,FR,France +198647,3,36740,29710,43770,66,53,79,FR,France +198646,3,32134,25327,38941,58,46,70,FR,France +198645,3,38964,31382,46546,70,56,84,FR,France +198644,3,28646,22048,35244,52,40,64,FR,France +198643,3,27532,20842,34222,50,38,62,FR,France +198642,3,31815,25124,38506,57,45,69,FR,France +198641,3,32864,25939,39789,59,47,71,FR,France +198640,3,33516,26776,40256,60,48,72,FR,France +198639,3,28665,22477,34853,52,41,63,FR,France +198638,3,26615,20479,32751,48,37,59,FR,France +198637,3,15998,10802,21194,29,20,38,FR,France +198636,3,9182,4982,13382,17,9,25,FR,France +198635,3,10587,4470,16704,19,8,30,FR,France +198634,3,5762,858,10666,10,1,19,FR,France +198633,3,3115,554,5676,6,1,11,FR,France +198632,3,1027,0,2311,2,0,4,FR,France +198631,3,2247,0,4574,4,0,8,FR,France +198630,3,2346,141,4551,4,0,8,FR,France +198629,3,3654,931,6377,7,2,12,FR,France +198628,3,2327,0,5318,4,0,9,FR,France +198627,3,7529,3353,11705,14,6,22,FR,France +198626,3,8778,5106,12450,16,9,23,FR,France +198625,3,11075,6804,15346,20,12,28,FR,France +198624,3,11160,7252,15068,20,13,27,FR,France +198623,3,14372,9896,18848,26,18,34,FR,France +198622,3,9717,5594,13840,18,11,25,FR,France +198621,3,14460,9575,19345,26,17,35,FR,France +198620,3,17133,12106,22160,31,22,40,FR,France +198619,3,22177,16008,28346,40,29,51,FR,France +198618,3,31736,24115,39357,57,43,71,FR,France +198617,3,34874,27440,42308,63,50,76,FR,France +198616,3,41196,32894,49498,74,59,89,FR,France +198615,3,42659,33537,51781,77,61,93,FR,France +198614,3,49792,39728,59856,90,72,108,FR,France +198613,3,87249,63562,110936,157,114,200,FR,France +198612,3,124777,97237,152317,225,175,275,FR,France +198611,3,168146,151035,185257,303,272,334,FR,France +198610,3,257305,231225,283385,464,417,511,FR,France +198609,3,321140,296644,345636,580,536,624,FR,France +198608,3,448786,419219,478353,810,757,863,FR,France +198607,3,490723,460150,521296,886,831,941,FR,France +198606,3,439300,411764,466836,793,743,843,FR,France +198605,3,364727,339868,389586,658,613,703,FR,France +198604,3,348509,322464,374554,629,582,676,FR,France +198603,3,271539,248654,294424,490,449,531,FR,France +198602,3,178138,159344,196932,322,288,356,FR,France +198601,3,112614,96539,128689,203,174,232,FR,France +198552,3,86452,72250,100654,157,131,183,FR,France +198551,3,114666,99538,129794,208,181,235,FR,France +198550,3,86031,73604,98458,156,133,179,FR,France +198549,3,65931,55326,76536,120,101,139,FR,France +198548,3,68291,57581,79001,124,105,143,FR,France +198547,3,66177,55221,77133,120,100,140,FR,France +198546,3,70534,58788,82280,128,107,149,FR,France +198545,3,57514,47167,67861,104,85,123,FR,France +198544,3,67356,55744,78968,122,101,143,FR,France +198543,3,87402,74208,100596,158,134,182,FR,France +198542,3,76218,64604,87832,138,117,159,FR,France +198541,3,45712,36755,54669,83,67,99,FR,France +198540,3,49739,40335,59143,90,73,107,FR,France +198539,3,39819,31234,48404,72,56,88,FR,France +198538,3,27605,20614,34596,50,37,63,FR,France +198537,3,22219,15626,28812,40,28,52,FR,France +198536,3,27986,18992,36980,51,35,67,FR,France +198535,3,30215,18546,41884,55,34,76,FR,France +198534,3,40389,24786,55992,73,45,101,FR,France +198533,3,22611,8819,36403,41,16,66,FR,France +198532,3,7488,1851,13125,14,4,24,FR,France +198531,3,16958,8479,25437,31,16,46,FR,France +198530,3,11598,5507,17689,21,10,32,FR,France +198529,3,13054,6474,19634,24,12,36,FR,France +198528,3,14588,7659,21517,26,13,39,FR,France +198527,3,19670,11761,27579,36,22,50,FR,France +198526,3,18609,12637,24581,34,23,45,FR,France +198525,3,19362,12454,26270,35,22,48,FR,France +198524,3,19855,13577,26133,36,25,47,FR,France +198523,3,19373,10010,28736,35,18,52,FR,France +198522,3,24099,17190,31008,44,31,57,FR,France +198521,3,26096,19621,32571,47,35,59,FR,France +198520,3,27896,20885,34907,51,38,64,FR,France +198519,3,43154,32821,53487,78,59,97,FR,France +198518,3,40555,29935,51175,74,55,93,FR,France +198517,3,34053,24366,43740,62,44,80,FR,France +198516,3,50362,36451,64273,91,66,116,FR,France +198515,3,63881,45538,82224,116,83,149,FR,France +198514,3,134545,114400,154690,244,207,281,FR,France +198513,3,197206,176080,218332,357,319,395,FR,France +198512,3,245240,223304,267176,445,405,485,FR,France +198511,3,276205,252399,300011,501,458,544,FR,France +198510,3,353231,326279,380183,640,591,689,FR,France +198509,3,369895,341109,398681,670,618,722,FR,France +198508,3,389886,359529,420243,707,652,762,FR,France +198507,3,471852,432599,511105,855,784,926,FR,France +198506,3,565825,518011,613639,1026,939,1113,FR,France +198505,3,637302,592795,681809,1155,1074,1236,FR,France +198504,3,424937,390794,459080,770,708,832,FR,France +198503,3,213901,174689,253113,388,317,459,FR,France +198502,3,97586,80949,114223,177,147,207,FR,France +198501,3,85489,65918,105060,155,120,190,FR,France +198452,3,84830,60602,109058,154,110,198,FR,France +198451,3,101726,80242,123210,185,146,224,FR,France +198450,3,123680,101401,145959,225,184,266,FR,France +198449,3,101073,81684,120462,184,149,219,FR,France +198448,3,78620,60634,96606,143,110,176,FR,France +198447,3,72029,54274,89784,131,99,163,FR,France +198446,3,87330,67686,106974,159,123,195,FR,France +198445,3,135223,101414,169032,246,184,308,FR,France +198444,3,68422,20056,116788,125,37,213,FR,France diff --git a/module3/exo2/.ipynb_checkpoints/exercice_en-checkpoint.ipynb b/module3/exo2/.ipynb_checkpoints/exercice_en-checkpoint.ipynb new file mode 100644 index 0000000..0bbbe37 --- /dev/null +++ b/module3/exo2/.ipynb_checkpoints/exercice_en-checkpoint.ipynb @@ -0,0 +1,25 @@ +{ + "cells": [], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.6.3" + } + }, + "nbformat": 4, + "nbformat_minor": 2 +} + diff --git a/module3/exo2/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb b/module3/exo2/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb new file mode 100644 index 0000000..0bbbe37 --- /dev/null +++ b/module3/exo2/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb @@ -0,0 +1,25 @@ +{ + "cells": [], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.6.3" + } + }, + "nbformat": 4, + "nbformat_minor": 2 +} + diff --git a/module3/exo3/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb b/module3/exo3/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb new file mode 100644 index 0000000..cfbb200 --- /dev/null +++ b/module3/exo3/.ipynb_checkpoints/exercice_fr-checkpoint.ipynb @@ -0,0 +1,930 @@ +{ + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Analyse d'incidence de la varicelle" + ] + }, + { + "cell_type": "code", + "execution_count": 2, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek\n", + "import requests\n", + "import csv\n", + "from pathlib import Path" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Lecture des données" + ] + }, + { + "cell_type": "code", + "execution_count": 6, + "metadata": {}, + "outputs": [], + "source": [ + "URL = \"https://www.sentiweb.fr/datasets/incidence-PAY-7.csv\"" + ] + }, + { + "cell_type": "code", + "execution_count": 7, + "metadata": {}, + "outputs": [], + "source": [ + "r = requests.get(URL)" + ] + }, + { + "cell_type": "code", + "execution_count": 13, + "metadata": {}, + "outputs": [], + "source": [ + "file_data = r\"C:\\Users\\renau\\mooc-rr\\module3\\exo3\\incidence_varicelles.csv\" \n", + "if (Path(file_data).is_file() == False): \n", + " file_data = open(file_data,\"w\",encoding = \"ANSI\")\n", + " file_data.write(r.text)\n", + " file_data.close()" + ] + }, + { + "cell_type": "code", + "execution_count": 17, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
weekindicatorincinc_lowinc_upinc100inc100_lowinc100_upgeo_inseegeo_name
02021067147191046218976221628FRFrance
1202105712379910715651191424FRFrance
2202104712026882615226181323FRFrance
32021037891363751145113917FRFrance
42021027779554301016012816FRFrance
15711991017155651027120859271836FRFrance
15721990527193751329525455342345FRFrance
15731990517190801380724353342543FRFrance
1574199050711079666015498201228FRFrance
15751990497114302610205FRFrance
\n", + "
1576 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 7 14719 10462 18976 22 16 \n", + "1 202105 7 12379 9107 15651 19 14 \n", + "2 202104 7 12026 8826 15226 18 13 \n", + "3 202103 7 8913 6375 11451 13 9 \n", + "4 202102 7 7795 5430 10160 12 8 \n", + "... ... ... ... ... ... ... ... \n", + "1571 199101 7 15565 10271 20859 27 18 \n", + "1572 199052 7 19375 13295 25455 34 23 \n", + "1573 199051 7 19080 13807 24353 34 25 \n", + "1574 199050 7 11079 6660 15498 20 12 \n", + "1575 199049 7 1143 0 2610 2 0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 28 FR France \n", + "1 24 FR France \n", + "2 23 FR France \n", + "3 17 FR France \n", + "4 16 FR France \n", + "... ... ... ... \n", + "1571 36 FR France \n", + "1572 45 FR France \n", + "1573 43 FR France \n", + "1574 28 FR France \n", + "1575 5 FR France \n", + "\n", + "[1576 rows x 10 columns]" + ] + }, + "execution_count": 17, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data_raw = pd.read_csv(file_data, sep =',', encoding = 'ANSI', skiprows = 1)\n", + "data_raw" + ] + }, + { + "cell_type": "code", + "execution_count": 18, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "
" + ], + "text/plain": [ + "Empty DataFrame\n", + "Columns: [week, indicator, inc, inc_low, inc_up, inc100, inc100_low, inc100_up, geo_insee, geo_name]\n", + "Index: []" + ] + }, + "execution_count": 18, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data_raw[data_raw.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Je ne constate pas la présence de données nulles. " + ] + }, + { + "cell_type": "code", + "execution_count": 22, + "metadata": {}, + "outputs": [], + "source": [ + "data = data_raw" + ] + }, + { + "cell_type": "code", + "execution_count": 23, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period (w.day(0), 'W')" + ] + }, + { + "cell_type": "code", + "execution_count": 24, + "metadata": {}, + "outputs": [], + "source": [ + "data['period'] = [convert_week(yw) for yw in data_raw['week']]" + ] + }, + { + "cell_type": "code", + "execution_count": 25, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "code", + "execution_count": 26, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
period
1990-12-03/1990-12-091990497114302610205FRFrance
1990-12-10/1990-12-16199050711079666015498201228FRFrance
1990-12-17/1990-12-231990517190801380724353342543FRFrance
1990-12-24/1990-12-301990527193751329525455342345FRFrance
1990-12-31/1991-01-061991017155651027120859271836FRFrance
2021-01-11/2021-01-172021027779554301016012816FRFrance
2021-01-18/2021-01-242021037891363751145113917FRFrance
2021-01-25/2021-01-31202104712026882615226181323FRFrance
2021-02-01/2021-02-07202105712379910715651191424FRFrance
2021-02-08/2021-02-142021067147191046218976221628FRFrance
\n", + "
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 \\\n", + "period \n", + "1990-12-03/1990-12-09 199049 7 1143 0 2610 2 \n", + "1990-12-10/1990-12-16 199050 7 11079 6660 15498 20 \n", + "1990-12-17/1990-12-23 199051 7 19080 13807 24353 34 \n", + "1990-12-24/1990-12-30 199052 7 19375 13295 25455 34 \n", + "1990-12-31/1991-01-06 199101 7 15565 10271 20859 27 \n", + "... ... ... ... ... ... ... \n", + "2021-01-11/2021-01-17 202102 7 7795 5430 10160 12 \n", + "2021-01-18/2021-01-24 202103 7 8913 6375 11451 13 \n", + "2021-01-25/2021-01-31 202104 7 12026 8826 15226 18 \n", + "2021-02-01/2021-02-07 202105 7 12379 9107 15651 19 \n", + "2021-02-08/2021-02-14 202106 7 14719 10462 18976 22 \n", + "\n", + " inc100_low inc100_up geo_insee geo_name \n", + "period \n", + "1990-12-03/1990-12-09 0 5 FR France \n", + "1990-12-10/1990-12-16 12 28 FR France \n", + "1990-12-17/1990-12-23 25 43 FR France \n", + "1990-12-24/1990-12-30 23 45 FR France \n", + "1990-12-31/1991-01-06 18 36 FR France \n", + "... ... ... ... ... \n", + "2021-01-11/2021-01-17 8 16 FR France \n", + "2021-01-18/2021-01-24 9 17 FR France \n", + "2021-01-25/2021-01-31 13 23 FR France \n", + "2021-02-01/2021-02-07 14 24 FR France \n", + "2021-02-08/2021-02-14 16 28 FR France \n", + "\n", + "[1576 rows x 10 columns]" + ] + }, + "execution_count": 26, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "sorted_data" + ] + }, + { + "cell_type": "code", + "execution_count": 27, + "metadata": {}, + "outputs": [], + "source": [ + "periods = sorted_data.index" + ] + }, + { + "cell_type": "code", + "execution_count": 28, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "PeriodIndex(['1990-12-03/1990-12-09', '1990-12-10/1990-12-16',\n", + " '1990-12-17/1990-12-23', '1990-12-24/1990-12-30',\n", + " '1990-12-31/1991-01-06', '1991-01-07/1991-01-13',\n", + " '1991-01-14/1991-01-20', '1991-01-21/1991-01-27',\n", + " '1991-01-28/1991-02-03', '1991-02-04/1991-02-10',\n", + " ...\n", + " '2020-12-07/2020-12-13', '2020-12-14/2020-12-20',\n", + " '2020-12-21/2020-12-27', '2020-12-28/2021-01-03',\n", + " '2021-01-04/2021-01-10', '2021-01-11/2021-01-17',\n", + " '2021-01-18/2021-01-24', '2021-01-25/2021-01-31',\n", + " '2021-02-01/2021-02-07', '2021-02-08/2021-02-14'],\n", + " dtype='period[W-SUN]', name='period', length=1576, freq='W-SUN')" + ] + }, + "execution_count": 28, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "periods" + ] + }, + { + "cell_type": "code", + "execution_count": 29, + "metadata": {}, + "outputs": [], + "source": [ + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "code", + "execution_count": 30, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 30, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": 31, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 31, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Etude de l'incidence annuelle" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Etant donné que le gros de l'épidémie va de janvier à juillet, la période de référence entre deux minima de l'incidence, est fixée du 1er septembre de l'année $N$ au 1er septembre de l'année $N+1$. On comence en 1991." + ] + }, + { + "cell_type": "code", + "execution_count": 33, + "metadata": {}, + "outputs": [], + "source": [ + "first_september_week = [pd.Period(pd.Timestamp(y, 9, 1), 'W')\n", + " for y in range(1991,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "code", + "execution_count": 35, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_september_week[:-1],\n", + " first_september_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "code", + "execution_count": 36, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 36, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "code", + "execution_count": 37, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "2020 221186\n", + "2002 516689\n", + "2018 542312\n", + "2017 551041\n", + "1996 564901\n", + "2019 584066\n", + "2015 604382\n", + "2000 617597\n", + "2001 619041\n", + "2012 624573\n", + "2005 628464\n", + "2006 632833\n", + "2011 642368\n", + "1993 643387\n", + "1995 652478\n", + "1994 661409\n", + "1998 677775\n", + "1997 683434\n", + "2014 685769\n", + "2013 698332\n", + "2007 717352\n", + "2008 749478\n", + "1999 756456\n", + "2003 758363\n", + "2004 777388\n", + "2016 782114\n", + "2010 829911\n", + "1992 832939\n", + "2009 842373\n", + "dtype: int64" + ] + }, + "execution_count": 37, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "code", + "execution_count": 38, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 38, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + } + ], + "metadata": { + "kernelspec": { + "display_name": "Python 3", + "language": "python", + "name": "python3" + }, + "language_info": { + "codemirror_mode": { + "name": "ipython", + "version": 3 + }, + "file_extension": ".py", + "mimetype": "text/x-python", + "name": "python", + "nbconvert_exporter": "python", + "pygments_lexer": "ipython3", + "version": "3.7.9" + } + }, + "nbformat": 4, + "nbformat_minor": 4 +} diff --git a/module3/exo3/exercice_fr.ipynb b/module3/exo3/exercice_fr.ipynb index 0bbbe37..cfbb200 100644 --- a/module3/exo3/exercice_fr.ipynb +++ b/module3/exo3/exercice_fr.ipynb @@ -1,5 +1,911 @@ { - "cells": [], + "cells": [ + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "# Analyse d'incidence de la varicelle" + ] + }, + { + "cell_type": "code", + "execution_count": 2, + "metadata": {}, + "outputs": [], + "source": [ + "%matplotlib inline\n", + "import matplotlib.pyplot as plt\n", + "import pandas as pd\n", + "import isoweek\n", + "import requests\n", + "import csv\n", + "from pathlib import Path" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Lecture des données" + ] + }, + { + "cell_type": "code", + "execution_count": 6, + "metadata": {}, + "outputs": [], + "source": [ + "URL = \"https://www.sentiweb.fr/datasets/incidence-PAY-7.csv\"" + ] + }, + { + "cell_type": "code", + "execution_count": 7, + "metadata": {}, + "outputs": [], + "source": [ + "r = requests.get(URL)" + ] + }, + { + "cell_type": "code", + "execution_count": 13, + "metadata": {}, + "outputs": [], + "source": [ + "file_data = r\"C:\\Users\\renau\\mooc-rr\\module3\\exo3\\incidence_varicelles.csv\" \n", + "if (Path(file_data).is_file() == False): \n", + " file_data = open(file_data,\"w\",encoding = \"ANSI\")\n", + " file_data.write(r.text)\n", + " file_data.close()" + ] + }, + { + "cell_type": "code", + "execution_count": 17, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
weekindicatorincinc_lowinc_upinc100inc100_lowinc100_upgeo_inseegeo_name
02021067147191046218976221628FRFrance
1202105712379910715651191424FRFrance
2202104712026882615226181323FRFrance
32021037891363751145113917FRFrance
42021027779554301016012816FRFrance
15711991017155651027120859271836FRFrance
15721990527193751329525455342345FRFrance
15731990517190801380724353342543FRFrance
1574199050711079666015498201228FRFrance
15751990497114302610205FRFrance
\n", + "
1576 rows × 10 columns
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 inc100_low \\\n", + "0 202106 7 14719 10462 18976 22 16 \n", + "1 202105 7 12379 9107 15651 19 14 \n", + "2 202104 7 12026 8826 15226 18 13 \n", + "3 202103 7 8913 6375 11451 13 9 \n", + "4 202102 7 7795 5430 10160 12 8 \n", + "... ... ... ... ... ... ... ... \n", + "1571 199101 7 15565 10271 20859 27 18 \n", + "1572 199052 7 19375 13295 25455 34 23 \n", + "1573 199051 7 19080 13807 24353 34 25 \n", + "1574 199050 7 11079 6660 15498 20 12 \n", + "1575 199049 7 1143 0 2610 2 0 \n", + "\n", + " inc100_up geo_insee geo_name \n", + "0 28 FR France \n", + "1 24 FR France \n", + "2 23 FR France \n", + "3 17 FR France \n", + "4 16 FR France \n", + "... ... ... ... \n", + "1571 36 FR France \n", + "1572 45 FR France \n", + "1573 43 FR France \n", + "1574 28 FR France \n", + "1575 5 FR France \n", + "\n", + "[1576 rows x 10 columns]" + ] + }, + "execution_count": 17, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data_raw = pd.read_csv(file_data, sep =',', encoding = 'ANSI', skiprows = 1)\n", + "data_raw" + ] + }, + { + "cell_type": "code", + "execution_count": 18, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "
" + ], + "text/plain": [ + "Empty DataFrame\n", + "Columns: [week, indicator, inc, inc_low, inc_up, inc100, inc100_low, inc100_up, geo_insee, geo_name]\n", + "Index: []" + ] + }, + "execution_count": 18, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "data_raw[data_raw.isnull().any(axis=1)]" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Je ne constate pas la présence de données nulles. " + ] + }, + { + "cell_type": "code", + "execution_count": 22, + "metadata": {}, + "outputs": [], + "source": [ + "data = data_raw" + ] + }, + { + "cell_type": "code", + "execution_count": 23, + "metadata": {}, + "outputs": [], + "source": [ + "def convert_week(year_and_week_int):\n", + " year_and_week_str = str(year_and_week_int)\n", + " year = int(year_and_week_str[:4])\n", + " week = int(year_and_week_str[4:])\n", + " w = isoweek.Week(year, week)\n", + " return pd.Period (w.day(0), 'W')" + ] + }, + { + "cell_type": "code", + "execution_count": 24, + "metadata": {}, + "outputs": [], + "source": [ + "data['period'] = [convert_week(yw) for yw in data_raw['week']]" + ] + }, + { + "cell_type": "code", + "execution_count": 25, + "metadata": {}, + "outputs": [], + "source": [ + "sorted_data = data.set_index('period').sort_index()" + ] + }, + { + "cell_type": "code", + "execution_count": 26, + "metadata": {}, + "outputs": [ + { + "data": { + "text/html": [ + "
\n", + "\n", + "\n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + " \n", + "
period
1990-12-03/1990-12-091990497114302610205FRFrance
1990-12-10/1990-12-16199050711079666015498201228FRFrance
1990-12-17/1990-12-231990517190801380724353342543FRFrance
1990-12-24/1990-12-301990527193751329525455342345FRFrance
1990-12-31/1991-01-061991017155651027120859271836FRFrance
2021-01-11/2021-01-172021027779554301016012816FRFrance
2021-01-18/2021-01-242021037891363751145113917FRFrance
2021-01-25/2021-01-31202104712026882615226181323FRFrance
2021-02-01/2021-02-07202105712379910715651191424FRFrance
2021-02-08/2021-02-142021067147191046218976221628FRFrance
\n", + "
\n", + "
" + ], + "text/plain": [ + " week indicator inc inc_low inc_up inc100 \\\n", + "period \n", + "1990-12-03/1990-12-09 199049 7 1143 0 2610 2 \n", + "1990-12-10/1990-12-16 199050 7 11079 6660 15498 20 \n", + "1990-12-17/1990-12-23 199051 7 19080 13807 24353 34 \n", + "1990-12-24/1990-12-30 199052 7 19375 13295 25455 34 \n", + "1990-12-31/1991-01-06 199101 7 15565 10271 20859 27 \n", + "... ... ... ... ... ... ... \n", + "2021-01-11/2021-01-17 202102 7 7795 5430 10160 12 \n", + "2021-01-18/2021-01-24 202103 7 8913 6375 11451 13 \n", + "2021-01-25/2021-01-31 202104 7 12026 8826 15226 18 \n", + "2021-02-01/2021-02-07 202105 7 12379 9107 15651 19 \n", + "2021-02-08/2021-02-14 202106 7 14719 10462 18976 22 \n", + "\n", + " inc100_low inc100_up geo_insee geo_name \n", + "period \n", + "1990-12-03/1990-12-09 0 5 FR France \n", + "1990-12-10/1990-12-16 12 28 FR France \n", + "1990-12-17/1990-12-23 25 43 FR France \n", + "1990-12-24/1990-12-30 23 45 FR France \n", + "1990-12-31/1991-01-06 18 36 FR France \n", + "... ... ... ... ... \n", + "2021-01-11/2021-01-17 8 16 FR France \n", + "2021-01-18/2021-01-24 9 17 FR France \n", + "2021-01-25/2021-01-31 13 23 FR France \n", + "2021-02-01/2021-02-07 14 24 FR France \n", + "2021-02-08/2021-02-14 16 28 FR France \n", + "\n", + "[1576 rows x 10 columns]" + ] + }, + "execution_count": 26, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "sorted_data" + ] + }, + { + "cell_type": "code", + "execution_count": 27, + "metadata": {}, + "outputs": [], + "source": [ + "periods = sorted_data.index" + ] + }, + { + "cell_type": "code", + "execution_count": 28, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "PeriodIndex(['1990-12-03/1990-12-09', '1990-12-10/1990-12-16',\n", + " '1990-12-17/1990-12-23', '1990-12-24/1990-12-30',\n", + " '1990-12-31/1991-01-06', '1991-01-07/1991-01-13',\n", + " '1991-01-14/1991-01-20', '1991-01-21/1991-01-27',\n", + " '1991-01-28/1991-02-03', '1991-02-04/1991-02-10',\n", + " ...\n", + " '2020-12-07/2020-12-13', '2020-12-14/2020-12-20',\n", + " '2020-12-21/2020-12-27', '2020-12-28/2021-01-03',\n", + " '2021-01-04/2021-01-10', '2021-01-11/2021-01-17',\n", + " '2021-01-18/2021-01-24', '2021-01-25/2021-01-31',\n", + " '2021-02-01/2021-02-07', '2021-02-08/2021-02-14'],\n", + " dtype='period[W-SUN]', name='period', length=1576, freq='W-SUN')" + ] + }, + "execution_count": 28, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "periods" + ] + }, + { + "cell_type": "code", + "execution_count": 29, + "metadata": {}, + "outputs": [], + "source": [ + "for p1, p2 in zip(periods[:-1], periods[1:]):\n", + " delta = p2.to_timestamp() - p1.end_time\n", + " if delta > pd.Timedelta('1s'):\n", + " print(p1, p2)" + ] + }, + { + "cell_type": "code", + "execution_count": 30, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 30, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'].plot()" + ] + }, + { + "cell_type": "code", + "execution_count": 31, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 31, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "sorted_data['inc'][-200:].plot()" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "## Etude de l'incidence annuelle" + ] + }, + { + "cell_type": "markdown", + "metadata": {}, + "source": [ + "Etant donné que le gros de l'épidémie va de janvier à juillet, la période de référence entre deux minima de l'incidence, est fixée du 1er septembre de l'année $N$ au 1er septembre de l'année $N+1$. On comence en 1991." + ] + }, + { + "cell_type": "code", + "execution_count": 33, + "metadata": {}, + "outputs": [], + "source": [ + "first_september_week = [pd.Period(pd.Timestamp(y, 9, 1), 'W')\n", + " for y in range(1991,\n", + " sorted_data.index[-1].year)]" + ] + }, + { + "cell_type": "code", + "execution_count": 35, + "metadata": {}, + "outputs": [], + "source": [ + "year = []\n", + "yearly_incidence = []\n", + "for week1, week2 in zip(first_september_week[:-1],\n", + " first_september_week[1:]):\n", + " one_year = sorted_data['inc'][week1:week2-1]\n", + " assert abs(len(one_year)-52) < 2\n", + " yearly_incidence.append(one_year.sum())\n", + " year.append(week2.year)\n", + "yearly_incidence = pd.Series(data=yearly_incidence, index=year)" + ] + }, + { + "cell_type": "code", + "execution_count": 36, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 36, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.plot(style='*')" + ] + }, + { + "cell_type": "code", + "execution_count": 37, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "2020 221186\n", + "2002 516689\n", + "2018 542312\n", + "2017 551041\n", + "1996 564901\n", + "2019 584066\n", + "2015 604382\n", + "2000 617597\n", + "2001 619041\n", + "2012 624573\n", + "2005 628464\n", + "2006 632833\n", + "2011 642368\n", + "1993 643387\n", + "1995 652478\n", + "1994 661409\n", + "1998 677775\n", + "1997 683434\n", + "2014 685769\n", + "2013 698332\n", + "2007 717352\n", + "2008 749478\n", + "1999 756456\n", + "2003 758363\n", + "2004 777388\n", + "2016 782114\n", + "2010 829911\n", + "1992 832939\n", + "2009 842373\n", + "dtype: int64" + ] + }, + "execution_count": 37, + "metadata": {}, + "output_type": "execute_result" + } + ], + "source": [ + "yearly_incidence.sort_values()" + ] + }, + { + "cell_type": "code", + "execution_count": 38, + "metadata": {}, + "outputs": [ + { + "data": { + "text/plain": [ + "" + ] + }, + "execution_count": 38, + "metadata": {}, + "output_type": "execute_result" + }, + { + "data": { + "image/png": "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\n", + "text/plain": [ + "
" + ] + }, + "metadata": { + "needs_background": "light" + }, + "output_type": "display_data" + } + ], + "source": [ + "yearly_incidence.hist(xrot=20)" + ] + } + ], "metadata": { "kernelspec": { "display_name": "Python 3", @@ -16,10 +922,9 @@ "name": "python", "nbconvert_exporter": "python", "pygments_lexer": "ipython3", - "version": "3.6.3" + "version": "3.7.9" } }, "nbformat": 4, - "nbformat_minor": 2 + "nbformat_minor": 4 } - diff --git a/module3/exo3/incidence_varicelles.csv b/module3/exo3/incidence_varicelles.csv new file mode 100644 index 0000000..7e8247a --- /dev/null +++ b/module3/exo3/incidence_varicelles.csv @@ -0,0 +1,1578 @@ +# @source="réseau Sentinelles, INSERM, Sorbonne Université, http://www.sentiweb.fr", @meta={"period":[199049,202106],"geo":["PAY","1"],"geo_ref":"insee","indicator":"7","type":"all","conf_int":true,"compact":false}, @date=2021-02-21T19:07:07+01:00 +week,indicator,inc,inc_low,inc_up,inc100,inc100_low,inc100_up,geo_insee,geo_name +202106,7,14719,10462,18976,22,16,28,FR,France +202105,7,12379,9107,15651,19,14,24,FR,France +202104,7,12026,8826,15226,18,13,23,FR,France +202103,7,8913,6375,11451,13,9,17,FR,France +202102,7,7795,5430,10160,12,8,16,FR,France +202101,7,10525,7750,13300,16,12,20,FR,France +202053,7,11978,8406,15550,18,13,23,FR,France +202052,7,12012,8285,15739,18,12,24,FR,France +202051,7,10564,7574,13554,16,11,21,FR,France +202050,7,7063,4744,9382,11,7,15,FR,France +202049,7,5026,3145,6907,8,5,11,FR,France +202048,7,6683,4312,9054,10,6,14,FR,France +202047,7,4999,2963,7035,8,5,11,FR,France +202046,7,3752,1963,5541,6,3,9,FR,France +202045,7,3696,2016,5376,6,3,9,FR,France +202044,7,4391,2375,6407,7,4,10,FR,France +202043,7,4376,2505,6247,7,4,10,FR,France +202042,7,4000,1979,6021,6,3,9,FR,France +202041,7,3961,2099,5823,6,3,9,FR,France +202040,7,2078,675,3481,3,1,5,FR,France +202039,7,1049,237,1861,2,1,3,FR,France +202038,7,2253,782,3724,3,1,5,FR,France +202037,7,1584,405,2763,2,0,4,FR,France +202036,7,919,100,1738,1,0,2,FR,France +202035,7,828,0,1694,1,0,2,FR,France +202034,7,2272,371,4173,3,0,6,FR,France +202033,7,1284,177,2391,2,0,4,FR,France +202032,7,2650,689,4611,4,1,7,FR,France +202031,7,1303,100,2506,2,0,4,FR,France +202030,7,1385,75,2695,2,0,4,FR,France +202029,7,841,10,1672,1,0,2,FR,France +202028,7,728,0,1515,1,0,2,FR,France +202027,7,986,149,1823,1,0,2,FR,France +202026,7,694,0,1454,1,0,2,FR,France +202025,7,228,0,597,0,0,1,FR,France +202024,7,388,0,959,1,0,2,FR,France +202023,7,558,1,1115,1,0,2,FR,France +202022,7,277,0,633,0,0,1,FR,France +202021,7,602,36,1168,1,0,2,FR,France +202020,7,824,20,1628,1,0,2,FR,France +202019,7,310,0,753,0,0,1,FR,France +202018,7,849,98,1600,1,0,2,FR,France +202017,7,272,0,658,0,0,1,FR,France +202016,7,758,78,1438,1,0,2,FR,France +202015,7,1918,675,3161,3,1,5,FR,France +202014,7,3879,2227,5531,6,3,9,FR,France +202013,7,7326,5236,9416,11,8,14,FR,France +202012,7,8123,5790,10456,12,8,16,FR,France +202011,7,10198,7568,12828,15,11,19,FR,France +202010,7,9011,6691,11331,14,10,18,FR,France +202009,7,13631,10544,16718,21,16,26,FR,France +202008,7,10424,7708,13140,16,12,20,FR,France +202007,7,8959,6574,11344,14,10,18,FR,France +202006,7,9264,6925,11603,14,10,18,FR,France +202005,7,8505,6314,10696,13,10,16,FR,France +202004,7,7991,5831,10151,12,9,15,FR,France +202003,7,5968,4100,7836,9,6,12,FR,France +202002,7,6534,4530,8538,10,7,13,FR,France +202001,7,9835,7019,12651,15,11,19,FR,France +201952,7,7941,5246,10636,12,8,16,FR,France +201951,7,5823,3675,7971,9,6,12,FR,France +201950,7,6424,4276,8572,10,7,13,FR,France +201949,7,6621,4540,8702,10,7,13,FR,France +201948,7,5542,3383,7701,8,5,11,FR,France +201947,7,7536,5058,10014,11,7,15,FR,France +201946,7,2638,1316,3960,4,2,6,FR,France +201945,7,4492,2615,6369,7,4,10,FR,France +201944,7,5728,3627,7829,9,6,12,FR,France +201943,7,4834,2751,6917,7,4,10,FR,France +201942,7,6279,3989,8569,10,7,13,FR,France +201941,7,4130,2030,6230,6,3,9,FR,France +201940,7,4211,2218,6204,6,3,9,FR,France +201939,7,3137,1310,4964,5,2,8,FR,France +201938,7,3078,1416,4740,5,2,8,FR,France +201937,7,970,162,1778,1,0,2,FR,France +201936,7,1277,263,2291,2,0,4,FR,France +201935,7,922,0,1857,1,0,2,FR,France +201934,7,1997,605,3389,3,1,5,FR,France +201933,7,3279,1103,5455,5,2,8,FR,France +201932,7,3627,1576,5678,6,3,9,FR,France +201931,7,7611,4605,10617,12,7,17,FR,France +201930,7,8875,5629,12121,13,8,18,FR,France +201929,7,10658,7151,14165,16,11,21,FR,France +201928,7,11251,7604,14898,17,11,23,FR,France +201927,7,16602,12349,20855,25,19,31,FR,France +201926,7,18851,14491,23211,29,22,36,FR,France +201925,7,18309,13972,22646,28,21,35,FR,France +201924,7,13382,9659,17105,20,14,26,FR,France +201923,7,19264,15027,23501,29,23,35,FR,France +201922,7,16861,12783,20939,26,20,32,FR,France +201921,7,17572,13140,22004,27,20,34,FR,France +201920,7,16180,12310,20050,25,19,31,FR,France +201919,7,16646,12721,20571,25,19,31,FR,France +201918,7,13803,10159,17447,21,15,27,FR,France +201917,7,15868,11815,19921,24,18,30,FR,France +201916,7,17127,12815,21439,26,19,33,FR,France +201915,7,21449,16525,26373,33,26,40,FR,France +201914,7,16131,12254,20008,25,19,31,FR,France +201913,7,17264,13409,21119,26,20,32,FR,France +201912,7,14133,10499,17767,21,15,27,FR,France +201911,7,12655,9528,15782,19,14,24,FR,France +201910,7,14062,10547,17577,21,16,26,FR,France +201909,7,13725,10221,17229,21,16,26,FR,France +201908,7,17186,13156,21216,26,20,32,FR,France +201907,7,10206,7388,13024,16,12,20,FR,France +201906,7,13504,10402,16606,21,16,26,FR,France +201905,7,12799,9843,15755,19,15,23,FR,France +201904,7,11842,9041,14643,18,14,22,FR,France +201903,7,8616,6114,11118,13,9,17,FR,France +201902,7,12005,9035,14975,18,13,23,FR,France +201901,7,15951,12224,19678,24,18,30,FR,France +201852,7,16234,11915,20553,25,18,32,FR,France +201851,7,16859,12787,20931,26,20,32,FR,France +201850,7,11554,8405,14703,18,13,23,FR,France +201849,7,12632,9322,15942,19,14,24,FR,France +201848,7,8093,5509,10677,12,8,16,FR,France +201847,7,8670,5920,11420,13,9,17,FR,France +201846,7,7039,4453,9625,11,7,15,FR,France +201845,7,7479,4820,10138,11,7,15,FR,France +201844,7,7749,4931,10567,12,8,16,FR,France +201843,7,8705,5414,11996,13,8,18,FR,France +201842,7,4640,2523,6757,7,4,10,FR,France +201841,7,2956,1207,4705,4,1,7,FR,France +201840,7,3858,1827,5889,6,3,9,FR,France +201839,7,2584,870,4298,4,1,7,FR,France +201838,7,2401,761,4041,4,2,6,FR,France +201837,7,1891,501,3281,3,1,5,FR,France +201836,7,559,0,1335,1,0,2,FR,France +201835,7,872,0,1916,1,0,3,FR,France +201834,7,3736,1415,6057,6,2,10,FR,France +201833,7,3803,1130,6476,6,2,10,FR,France +201832,7,3225,1155,5295,5,2,8,FR,France +201831,7,6610,3565,9655,10,5,15,FR,France +201830,7,9338,5780,12896,14,9,19,FR,France +201829,7,8513,5059,11967,13,8,18,FR,France +201828,7,12115,7907,16323,18,12,24,FR,France +201827,7,13975,9739,18211,21,15,27,FR,France +201826,7,15317,11019,19615,23,16,30,FR,France +201825,7,11282,7840,14724,17,12,22,FR,France +201824,7,16554,12219,20889,25,18,32,FR,France +201823,7,9511,6385,12637,14,9,19,FR,France +201822,7,15972,11793,20151,24,18,30,FR,France +201821,7,10909,7627,14191,17,12,22,FR,France +201820,7,13417,9692,17142,20,14,26,FR,France +201819,7,16718,12351,21085,25,18,32,FR,France +201818,7,16120,11128,21112,25,17,33,FR,France +201817,7,16154,11960,20348,25,19,31,FR,France +201816,7,18341,13836,22846,28,21,35,FR,France +201815,7,17946,13622,22270,27,20,34,FR,France +201814,7,15036,10780,19292,23,17,29,FR,France +201813,7,16373,12472,20274,25,19,31,FR,France +201812,7,18819,14373,23265,29,22,36,FR,France +201811,7,15478,11427,19529,24,18,30,FR,France +201810,7,15753,11901,19605,24,18,30,FR,France +201809,7,13217,9653,16781,20,15,25,FR,France +201808,7,13390,9832,16948,20,15,25,FR,France +201807,7,13453,10096,16810,20,15,25,FR,France +201806,7,15491,11679,19303,24,18,30,FR,France +201805,7,15078,11374,18782,23,17,29,FR,France +201804,7,14562,10973,18151,22,17,27,FR,France +201803,7,7972,5473,10471,12,8,16,FR,France +201802,7,10976,7974,13978,17,12,22,FR,France +201801,7,11471,8430,14512,17,12,22,FR,France +201752,7,11120,7732,14508,17,12,22,FR,France +201751,7,8055,5279,10831,12,8,16,FR,France +201750,7,10095,7184,13006,15,11,19,FR,France +201749,7,11214,8103,14325,17,12,22,FR,France +201748,7,8686,5706,11666,13,8,18,FR,France +201747,7,8741,5969,11513,13,9,17,FR,France +201746,7,5708,3483,7933,9,6,12,FR,France +201745,7,4902,2777,7027,8,5,11,FR,France +201744,7,5645,3125,8165,9,5,13,FR,France +201743,7,6892,3966,9818,11,7,15,FR,France +201742,7,4490,2218,6762,7,4,10,FR,France +201741,7,2516,1110,3922,4,2,6,FR,France +201740,7,4902,2504,7300,8,4,12,FR,France +201739,7,2901,917,4885,4,1,7,FR,France +201738,7,2138,736,3540,3,1,5,FR,France +201737,7,2360,700,4020,4,1,7,FR,France +201736,7,1903,450,3356,3,1,5,FR,France +201735,7,3419,1409,5429,5,2,8,FR,France +201734,7,3886,1559,6213,6,2,10,FR,France +201733,7,3133,829,5437,5,1,9,FR,France +201732,7,4194,1599,6789,6,2,10,FR,France +201731,7,7130,3572,10688,11,6,16,FR,France +201730,7,7368,3708,11028,11,5,17,FR,France +201729,7,15320,10560,20080,24,17,31,FR,France +201728,7,14764,9589,19939,23,15,31,FR,France +201727,7,12000,7980,16020,18,12,24,FR,France +201726,7,11914,8364,15464,18,13,23,FR,France +201725,7,16264,12303,20225,25,19,31,FR,France +201724,7,16473,12221,20725,25,18,32,FR,France +201723,7,15607,11196,20018,24,17,31,FR,France +201722,7,19102,14187,24017,29,21,37,FR,France +201721,7,21160,15647,26673,32,24,40,FR,France +201720,7,19412,14439,24385,30,22,38,FR,France +201719,7,20724,15468,25980,32,24,40,FR,France +201718,7,14497,10154,18840,22,15,29,FR,France +201717,7,17548,12284,22812,27,19,35,FR,France +201716,7,14963,10491,19435,23,16,30,FR,France +201715,7,16400,11762,21038,25,18,32,FR,France +201714,7,18892,13332,24452,29,20,38,FR,France +201713,7,21702,16488,26916,33,25,41,FR,France +201712,7,18534,14161,22907,28,21,35,FR,France +201711,7,18361,12709,24013,28,19,37,FR,France +201710,7,10218,6896,13540,16,11,21,FR,France +201709,7,12248,8571,15925,19,13,25,FR,France +201708,7,14721,10712,18730,23,17,29,FR,France +201707,7,10991,7538,14444,17,12,22,FR,France +201706,7,9627,6502,12752,15,10,20,FR,France +201705,7,8885,6064,11706,14,10,18,FR,France +201704,7,9227,6249,12205,14,9,19,FR,France +201703,7,8791,6072,11510,13,9,17,FR,France +201702,7,9034,6097,11971,14,9,19,FR,France +201701,7,7803,5142,10464,12,8,16,FR,France +201652,7,7665,4768,10562,12,8,16,FR,France +201651,7,9916,5966,13866,15,9,21,FR,France +201650,7,8866,5849,11883,14,9,19,FR,France +201649,7,7919,5039,10799,12,8,16,FR,France +201648,7,6906,4242,9570,11,7,15,FR,France +201647,7,6877,4083,9671,11,7,15,FR,France +201646,7,4683,2458,6908,7,4,10,FR,France +201645,7,3807,1499,6115,6,2,10,FR,France +201644,7,4879,2029,7729,7,3,11,FR,France +201643,7,9264,4949,13579,14,7,21,FR,France +201642,7,7301,3877,10725,11,6,16,FR,France +201641,7,5849,2950,8748,9,5,13,FR,France +201640,7,5023,2267,7779,8,4,12,FR,France +201639,7,2437,595,4279,4,1,7,FR,France +201638,7,2550,0,5121,4,0,8,FR,France +201637,7,3031,501,5561,5,1,9,FR,France +201636,7,1621,33,3209,2,0,4,FR,France +201635,7,1554,38,3070,2,0,4,FR,France +201634,7,3089,711,5467,5,1,9,FR,France +201633,7,3373,671,6075,5,1,9,FR,France +201632,7,4670,936,8404,7,1,13,FR,France +201631,7,13619,5986,21252,21,9,33,FR,France +201630,7,14149,8423,19875,22,13,31,FR,France +201629,7,15769,9829,21709,24,15,33,FR,France +201628,7,19968,12709,27227,31,20,42,FR,France +201627,7,23790,16940,30640,37,26,48,FR,France +201626,7,26083,19873,32293,40,30,50,FR,France +201625,7,19250,13742,24758,30,22,38,FR,France +201624,7,16465,11779,21151,25,18,32,FR,France +201623,7,21642,16030,27254,33,24,42,FR,France +201622,7,21913,16307,27519,34,25,43,FR,France +201621,7,22707,16878,28536,35,26,44,FR,France +201620,7,20389,14741,26037,31,22,40,FR,France +201619,7,19685,14453,24917,30,22,38,FR,France +201618,7,19785,14138,25432,30,21,39,FR,France +201617,7,20489,14781,26197,31,22,40,FR,France +201616,7,23848,18353,29343,37,29,45,FR,France +201615,7,30982,24510,37454,48,38,58,FR,France +201614,7,30996,24507,37485,48,38,58,FR,France +201613,7,20260,15476,25044,31,24,38,FR,France +201612,7,19129,14501,23757,29,22,36,FR,France +201611,7,16660,12252,21068,26,19,33,FR,France +201610,7,16812,12677,20947,26,20,32,FR,France +201609,7,18118,13735,22501,28,21,35,FR,France +201608,7,17557,13397,21717,27,21,33,FR,France +201607,7,22222,17422,27022,34,27,41,FR,France +201606,7,24486,19563,29409,38,30,46,FR,France +201605,7,20906,16470,25342,32,25,39,FR,France +201604,7,17717,13394,22040,27,20,34,FR,France +201603,7,17146,13088,21204,26,20,32,FR,France +201602,7,9960,6845,13075,15,10,20,FR,France +201601,7,16221,12114,20328,25,19,31,FR,France +201553,7,14386,10110,18662,22,15,29,FR,France +201552,7,12550,8407,16693,19,13,25,FR,France +201551,7,16168,11913,20423,25,18,32,FR,France +201550,7,14600,10277,18923,23,16,30,FR,France +201549,7,10580,7148,14012,16,11,21,FR,France +201548,7,6694,3816,9572,10,6,14,FR,France +201547,7,7224,4543,9905,11,7,15,FR,France +201546,7,6377,3768,8986,10,6,14,FR,France +201545,7,7838,4650,11026,12,7,17,FR,France +201544,7,10638,7012,14264,16,10,22,FR,France +201543,7,8228,4766,11690,13,8,18,FR,France +201542,7,6730,3669,9791,10,5,15,FR,France +201541,7,8455,5347,11563,13,8,18,FR,France +201540,7,6242,3556,8928,10,6,14,FR,France +201539,7,5142,2663,7621,8,4,12,FR,France +201538,7,4845,2170,7520,8,4,12,FR,France +201537,7,1710,315,3105,3,1,5,FR,France +201536,7,3852,1413,6291,6,2,10,FR,France +201535,7,3158,1104,5212,5,2,8,FR,France +201534,7,6626,2734,10518,10,4,16,FR,France +201533,7,3005,815,5195,5,2,8,FR,France +201532,7,4592,1514,7670,7,2,12,FR,France +201531,7,5901,2320,9482,9,3,15,FR,France +201530,7,11437,6572,16302,18,10,26,FR,France +201529,7,16251,10104,22398,25,15,35,FR,France +201528,7,19181,12819,25543,30,20,40,FR,France +201527,7,20526,14918,26134,32,23,41,FR,France +201526,7,20491,15043,25939,32,24,40,FR,France +201525,7,18253,13349,23157,28,20,36,FR,France +201524,7,20522,15347,25697,32,24,40,FR,France +201523,7,22298,16988,27608,35,27,43,FR,France +201522,7,16681,11603,21759,26,18,34,FR,France +201521,7,19208,13976,24440,30,22,38,FR,France +201520,7,15791,10998,20584,24,17,31,FR,France +201519,7,17661,12845,22477,27,20,34,FR,France +201518,7,18126,13142,23110,28,20,36,FR,France +201517,7,22059,16386,27732,34,25,43,FR,France +201516,7,22837,17103,28571,35,26,44,FR,France +201515,7,20116,14743,25489,31,23,39,FR,France +201514,7,19969,14683,25255,31,23,39,FR,France +201513,7,14076,10028,18124,22,16,28,FR,France +201512,7,13120,9230,17010,20,14,26,FR,France +201511,7,12073,8302,15844,19,13,25,FR,France +201510,7,11340,7811,14869,18,13,23,FR,France +201509,7,9509,6202,12816,15,10,20,FR,France +201508,7,10045,6921,13169,16,11,21,FR,France +201507,7,13810,9930,17690,21,15,27,FR,France +201506,7,14586,10675,18497,23,17,29,FR,France +201505,7,8379,5519,11239,13,9,17,FR,France +201504,7,12373,8955,15791,19,14,24,FR,France +201503,7,8408,5545,11271,13,9,17,FR,France +201502,7,9656,6569,12743,15,10,20,FR,France +201501,7,15419,10638,20200,24,17,31,FR,France +201452,7,12109,7254,16964,19,11,27,FR,France +201451,7,13237,9282,17192,21,15,27,FR,France +201450,7,12272,8434,16110,19,13,25,FR,France +201449,7,6652,4023,9281,10,6,14,FR,France +201448,7,3785,1414,6156,6,2,10,FR,France +201447,7,4213,2058,6368,7,4,10,FR,France +201446,7,2638,808,4468,4,1,7,FR,France +201445,7,5138,2609,7667,8,4,12,FR,France +201444,7,7639,4394,10884,12,7,17,FR,France +201443,7,9721,6051,13391,15,9,21,FR,France +201442,7,7702,4827,10577,12,8,16,FR,France +201441,7,7853,4576,11130,12,7,17,FR,France +201440,7,5643,2875,8411,9,5,13,FR,France +201439,7,3067,959,5175,5,2,8,FR,France +201438,7,1431,130,2732,2,0,4,FR,France +201437,7,1034,0,2338,2,0,4,FR,France +201436,7,2765,707,4823,4,1,7,FR,France +201435,7,3052,734,5370,5,1,9,FR,France +201434,7,6443,1010,11876,10,2,18,FR,France +201433,7,5893,1698,10088,9,2,16,FR,France +201432,7,5574,1636,9512,9,3,15,FR,France +201431,7,11224,5825,16623,17,9,25,FR,France +201430,7,13856,7742,19970,22,12,32,FR,France +201429,7,13818,8249,19387,22,13,31,FR,France +201428,7,14452,8576,20328,23,14,32,FR,France +201427,7,10934,6552,15316,17,10,24,FR,France +201426,7,13972,9090,18854,22,14,30,FR,France +201425,7,15684,10131,21237,24,15,33,FR,France +201424,7,21981,15632,28330,34,24,44,FR,France +201423,7,24015,16956,31074,37,26,48,FR,France +201422,7,19748,13406,26090,31,21,41,FR,France +201421,7,18296,12087,24505,28,18,38,FR,France +201420,7,17693,11979,23407,28,19,37,FR,France +201419,7,18515,12667,24363,29,20,38,FR,France +201418,7,22172,15443,28901,35,25,45,FR,France +201417,7,22727,16224,29230,35,25,45,FR,France +201416,7,17010,11590,22430,26,18,34,FR,France +201415,7,20239,14242,26236,32,23,41,FR,France +201414,7,17565,12341,22789,27,19,35,FR,France +201413,7,17723,12128,23318,28,19,37,FR,France +201412,7,14097,9068,19126,22,14,30,FR,France +201411,7,15073,10122,20024,23,15,31,FR,France +201410,7,16941,11407,22475,26,17,35,FR,France +201409,7,15621,10397,20845,24,16,32,FR,France +201408,7,19870,14111,25629,31,22,40,FR,France +201407,7,15327,10359,20295,24,16,32,FR,France +201406,7,16534,11424,21644,26,18,34,FR,France +201405,7,12071,7897,16245,19,12,26,FR,France +201404,7,15767,10826,20708,25,17,33,FR,France +201403,7,12852,8190,17514,20,13,27,FR,France +201402,7,12465,7896,17034,19,12,26,FR,France +201401,7,22504,15572,29436,35,24,46,FR,France +201352,7,13843,8314,19372,22,13,31,FR,France +201351,7,12787,7843,17731,20,12,28,FR,France +201350,7,11421,7184,15658,18,11,25,FR,France +201349,7,10146,6171,14121,16,10,22,FR,France +201348,7,6708,3361,10055,11,6,16,FR,France +201347,7,9940,5667,14213,16,9,23,FR,France +201346,7,5110,2148,8072,8,3,13,FR,France +201345,7,7669,3726,11612,12,6,18,FR,France +201344,7,10655,5983,15327,17,10,24,FR,France +201343,7,8192,3927,12457,13,6,20,FR,France +201342,7,12324,7315,17333,19,11,27,FR,France +201341,7,9487,5101,13873,15,8,22,FR,France +201340,7,4114,1452,6776,6,2,10,FR,France +201339,7,5037,1810,8264,8,3,13,FR,France +201338,7,4449,1499,7399,7,2,12,FR,France +201337,7,5212,1954,8470,8,3,13,FR,France +201336,7,3481,606,6356,5,0,10,FR,France +201335,7,3486,281,6691,5,0,10,FR,France +201334,7,3994,670,7318,6,1,11,FR,France +201333,7,3758,372,7144,6,1,11,FR,France +201332,7,2986,635,5337,5,1,9,FR,France +201331,7,9137,3957,14317,14,6,22,FR,France +201330,7,13810,6870,20750,22,11,33,FR,France +201329,7,12278,6878,17678,19,11,27,FR,France +201328,7,17146,10622,23670,27,17,37,FR,France +201327,7,13859,8697,19021,22,14,30,FR,France +201326,7,17956,11585,24327,28,18,38,FR,France +201325,7,24609,17743,31475,39,28,50,FR,France +201324,7,23981,17469,30493,38,28,48,FR,France +201323,7,15848,10235,21461,25,16,34,FR,France +201322,7,12528,7759,17297,20,13,27,FR,France +201321,7,10637,6458,14816,17,10,24,FR,France +201320,7,12435,7726,17144,19,12,26,FR,France +201319,7,14230,8491,19969,22,13,31,FR,France +201318,7,17735,11898,23572,28,19,37,FR,France +201317,7,25213,18328,32098,39,28,50,FR,France +201316,7,23918,16084,31752,37,25,49,FR,France +201315,7,15307,10483,20131,24,16,32,FR,France +201314,7,19302,13484,25120,30,21,39,FR,France +201313,7,18224,11953,24495,29,19,39,FR,France +201312,7,17413,11819,23007,27,18,36,FR,France +201311,7,16229,10756,21702,25,16,34,FR,France +201310,7,16515,10966,22064,26,17,35,FR,France +201309,7,16338,11305,21371,26,18,34,FR,France +201308,7,17915,12458,23372,28,19,37,FR,France +201307,7,12245,7795,16695,19,12,26,FR,France +201306,7,13305,8249,18361,21,13,29,FR,France +201305,7,11184,6677,15691,18,11,25,FR,France +201304,7,16505,11326,21684,26,18,34,FR,France +201303,7,10434,6735,14133,16,10,22,FR,France +201302,7,14746,9924,19568,23,15,31,FR,France +201301,7,22537,16290,28784,35,25,45,FR,France +201252,7,14682,9011,20353,23,14,32,FR,France +201251,7,15811,10483,21139,25,17,33,FR,France +201250,7,19840,13797,25883,31,21,41,FR,France +201249,7,11967,7591,16343,19,12,26,FR,France +201248,7,12897,8376,17418,20,13,27,FR,France +201247,7,11934,7042,16826,19,11,27,FR,France +201246,7,10741,6201,15281,17,10,24,FR,France +201245,7,20339,12476,28202,32,20,44,FR,France +201244,7,8472,4834,12110,13,7,19,FR,France +201243,7,11375,7120,15630,18,11,25,FR,France +201242,7,11450,6987,15913,18,11,25,FR,France +201241,7,8700,4885,12515,14,8,20,FR,France +201240,7,9175,5327,13023,14,8,20,FR,France +201239,7,4058,1438,6678,6,2,10,FR,France +201238,7,2684,621,4747,4,1,7,FR,France +201237,7,2505,0,5339,4,0,8,FR,France +201236,7,3930,291,7569,6,0,12,FR,France +201235,7,3515,884,6146,6,2,10,FR,France +201234,7,5663,2195,9131,9,4,14,FR,France +201233,7,7969,3171,12767,13,5,21,FR,France +201232,7,9206,2073,16339,14,3,25,FR,France +201231,7,7579,3540,11618,12,6,18,FR,France +201230,7,11253,5812,16694,18,9,27,FR,France +201229,7,20711,13977,27445,33,22,44,FR,France +201228,7,16966,9789,24143,27,16,38,FR,France +201227,7,17733,11174,24292,28,18,38,FR,France +201226,7,20974,13153,28795,33,21,45,FR,France +201225,7,25480,17130,33830,40,27,53,FR,France +201224,7,17872,11690,24054,28,18,38,FR,France +201223,7,22034,15327,28741,35,24,46,FR,France +201222,7,18774,11901,25647,30,19,41,FR,France +201221,7,18515,9501,27529,29,15,43,FR,France +201220,7,17026,9608,24444,27,15,39,FR,France +201219,7,13599,8726,18472,21,13,29,FR,France +201218,7,16482,10836,22128,26,17,35,FR,France +201217,7,18041,12040,24042,28,19,37,FR,France +201216,7,16251,10239,22263,26,17,35,FR,France +201215,7,10203,5281,15125,16,8,24,FR,France +201214,7,7426,3526,11326,12,6,18,FR,France +201213,7,12507,5913,19101,20,10,30,FR,France +201212,7,12006,6344,17668,19,10,28,FR,France +201211,7,11997,7398,16596,19,12,26,FR,France +201210,7,15569,9700,21438,25,16,34,FR,France +201209,7,18085,12427,23743,28,19,37,FR,France +201208,7,13515,8822,18208,21,14,28,FR,France +201207,7,12594,7774,17414,20,12,28,FR,France +201206,7,15273,9953,20593,24,16,32,FR,France +201205,7,12192,7305,17079,19,11,27,FR,France +201204,7,10248,4996,15500,16,8,24,FR,France +201203,7,11474,6843,16105,18,11,25,FR,France +201202,7,13651,8191,19111,21,12,30,FR,France +201201,7,14028,9063,18993,22,14,30,FR,France +201152,7,21306,14321,28291,34,23,45,FR,France +201151,7,14945,8910,20980,24,14,34,FR,France +201150,7,10051,5417,14685,16,9,23,FR,France +201149,7,10075,5049,15101,16,8,24,FR,France +201148,7,9018,5083,12953,14,8,20,FR,France +201147,7,10055,4853,15257,16,8,24,FR,France +201146,7,7721,3993,11449,12,6,18,FR,France +201145,7,5764,1962,9566,9,3,15,FR,France +201144,7,6178,2704,9652,10,5,15,FR,France +201143,7,6168,2653,9683,10,4,16,FR,France +201142,7,6713,3036,10390,11,5,17,FR,France +201141,7,4184,1543,6825,7,3,11,FR,France +201140,7,3114,618,5610,5,1,9,FR,France +201139,7,2504,414,4594,4,1,7,FR,France +201138,7,3386,585,6187,5,1,9,FR,France +201137,7,1183,9,2357,2,0,4,FR,France +201136,7,3367,478,6256,5,0,10,FR,France +201135,7,5945,2380,9510,9,3,15,FR,France +201134,7,3180,891,5469,5,1,9,FR,France +201133,7,4960,1053,8867,8,2,14,FR,France +201132,7,7230,1500,12960,11,2,20,FR,France +201131,7,10789,4593,16985,17,7,27,FR,France +201130,7,23137,9828,36446,37,16,58,FR,France +201129,7,10056,4896,15216,16,8,24,FR,France +201128,7,13428,7761,19095,21,12,30,FR,France +201127,7,20770,13604,27936,33,22,44,FR,France +201126,7,16862,10623,23101,27,17,37,FR,France +201125,7,19411,12763,26059,31,20,42,FR,France +201124,7,18584,12337,24831,29,19,39,FR,France +201123,7,20707,14800,26614,33,24,42,FR,France +201122,7,16995,11552,22438,27,18,36,FR,France +201121,7,19179,12997,25361,30,20,40,FR,France +201120,7,21512,15082,27942,34,24,44,FR,France +201119,7,18038,12286,23790,29,20,38,FR,France +201118,7,18512,13142,23882,29,21,37,FR,France +201117,7,20715,14602,26828,33,23,43,FR,France +201116,7,18128,12859,23397,29,21,37,FR,France +201115,7,22169,16454,27884,35,26,44,FR,France +201114,7,17431,12573,22289,28,20,36,FR,France +201113,7,15637,10796,20478,25,17,33,FR,France +201112,7,14856,9810,19902,24,16,32,FR,France +201111,7,12156,7712,16600,19,12,26,FR,France +201110,7,12987,8644,17330,21,14,28,FR,France +201109,7,11971,7656,16286,19,12,26,FR,France +201108,7,17295,11843,22747,27,18,36,FR,France +201107,7,12488,7431,17545,20,12,28,FR,France +201106,7,9801,6179,13423,16,10,22,FR,France +201105,7,10857,7046,14668,17,11,23,FR,France +201104,7,13749,9496,18002,22,15,29,FR,France +201103,7,12936,8875,16997,20,14,26,FR,France +201102,7,9451,6208,12694,15,10,20,FR,France +201101,7,14380,10066,18694,23,16,30,FR,France +201052,7,13112,8997,17227,21,14,28,FR,France +201051,7,12055,8046,16064,19,13,25,FR,France +201050,7,8281,5242,11320,13,8,18,FR,France +201049,7,12525,8601,16449,20,14,26,FR,France +201048,7,9048,5627,12469,14,9,19,FR,France +201047,7,7329,4256,10402,12,7,17,FR,France +201046,7,8955,5377,12533,14,8,20,FR,France +201045,7,4800,2269,7331,8,4,12,FR,France +201044,7,11274,7155,15393,18,11,25,FR,France +201043,7,8144,4621,11667,13,7,19,FR,France +201042,7,9178,5507,12849,15,9,21,FR,France +201041,7,7110,3983,10237,11,6,16,FR,France +201040,7,5196,2450,7942,8,4,12,FR,France +201039,7,3415,964,5866,5,1,9,FR,France +201038,7,3057,681,5433,5,1,9,FR,France +201037,7,1056,0,2338,2,0,4,FR,France +201036,7,1629,241,3017,3,1,5,FR,France +201035,7,5847,1895,9799,9,3,15,FR,France +201034,7,4649,1665,7633,7,2,12,FR,France +201033,7,3972,1372,6572,6,2,10,FR,France +201032,7,4307,1345,7269,7,2,12,FR,France +201031,7,7403,3912,10894,12,6,18,FR,France +201030,7,8502,4404,12600,14,7,21,FR,France +201029,7,14481,8874,20088,23,14,32,FR,France +201028,7,28483,18947,38019,45,30,60,FR,France +201027,7,25965,18206,33724,41,29,53,FR,France +201026,7,22628,16253,29003,36,26,46,FR,France +201025,7,21027,15245,26809,33,24,42,FR,France +201024,7,26164,19503,32825,42,31,53,FR,France +201023,7,19858,14032,25684,32,23,41,FR,France +201022,7,22275,16460,28090,35,26,44,FR,France +201021,7,24815,18263,31367,40,30,50,FR,France +201020,7,22370,16020,28720,36,26,46,FR,France +201019,7,25552,18564,32540,41,30,52,FR,France +201018,7,18894,13264,24524,30,21,39,FR,France +201017,7,17512,12221,22803,28,20,36,FR,France +201016,7,21439,15519,27359,34,25,43,FR,France +201015,7,26362,19735,32989,42,31,53,FR,France +201014,7,20168,14274,26062,32,23,41,FR,France +201013,7,18917,13394,24440,30,21,39,FR,France +201012,7,18171,12995,23347,29,21,37,FR,France +201011,7,13401,9041,17761,21,14,28,FR,France +201010,7,18123,12614,23632,29,20,38,FR,France +201009,7,21145,14746,27544,34,24,44,FR,France +201008,7,30549,21013,40085,49,34,64,FR,France +201007,7,25017,17142,32892,40,27,53,FR,France +201006,7,22358,13688,31028,36,22,50,FR,France +201005,7,26817,18132,35502,43,29,57,FR,France +201004,7,14384,8912,19856,23,14,32,FR,France +201003,7,11821,7294,16348,19,12,26,FR,France +201002,7,12756,7177,18335,20,11,29,FR,France +201001,7,14182,9107,19257,23,15,31,FR,France +200953,7,28213,17662,38764,45,28,62,FR,France +200952,7,15203,9597,20809,24,15,33,FR,France +200951,7,17611,11223,23999,28,18,38,FR,France +200950,7,17430,9879,24981,28,16,40,FR,France +200949,7,7199,3960,10438,11,6,16,FR,France +200948,7,14656,9570,19742,23,15,31,FR,France +200947,7,7051,3901,10201,11,6,16,FR,France +200946,7,4662,2107,7217,7,3,11,FR,France +200945,7,15603,9790,21416,25,16,34,FR,France +200944,7,13165,6629,19701,21,11,31,FR,France +200943,7,9872,5298,14446,16,9,23,FR,France +200942,7,13992,7999,19985,22,12,32,FR,France +200941,7,7811,4267,11355,12,6,18,FR,France +200940,7,12414,7441,17387,20,12,28,FR,France +200939,7,4090,921,7259,7,2,12,FR,France +200938,7,2802,999,4605,4,1,7,FR,France +200937,7,1989,362,3616,3,0,6,FR,France +200936,7,1681,212,3150,3,1,5,FR,France +200935,7,3605,1131,6079,6,2,10,FR,France +200934,7,8863,3112,14614,14,5,23,FR,France +200933,7,6592,965,12219,10,1,19,FR,France +200932,7,9370,4069,14671,15,7,23,FR,France +200931,7,18728,0,38349,30,0,61,FR,France +200930,7,10418,5698,15138,17,9,25,FR,France +200929,7,14716,8450,20982,23,13,33,FR,France +200928,7,21297,14200,28394,34,23,45,FR,France +200927,7,22300,14361,30239,36,23,49,FR,France +200926,7,24817,17154,32480,40,28,52,FR,France +200925,7,22427,15617,29237,36,25,47,FR,France +200924,7,14666,9828,19504,23,15,31,FR,France +200923,7,18094,10701,25487,29,17,41,FR,France +200922,7,20358,14457,26259,32,23,41,FR,France +200921,7,23147,16066,30228,37,26,48,FR,France +200920,7,27753,19893,35613,44,31,57,FR,France +200919,7,29529,19088,39970,47,30,64,FR,France +200918,7,17676,11359,23993,28,18,38,FR,France +200917,7,21880,15613,28147,35,25,45,FR,France +200916,7,23899,16714,31084,38,27,49,FR,France +200915,7,21717,14784,28650,35,24,46,FR,France +200914,7,22143,14930,29356,35,24,46,FR,France +200913,7,23445,16436,30454,37,26,48,FR,France +200912,7,17997,11343,24651,29,18,40,FR,France +200911,7,22428,14154,30702,36,23,49,FR,France +200910,7,21362,13994,28730,34,22,46,FR,France +200909,7,26922,18447,35397,43,30,56,FR,France +200908,7,20424,13766,27082,33,22,44,FR,France +200907,7,23181,15024,31338,37,24,50,FR,France +200906,7,29147,20804,37490,46,33,59,FR,France +200905,7,14176,8933,19419,23,15,31,FR,France +200904,7,14887,10004,19770,24,16,32,FR,France +200903,7,12650,7578,17722,20,12,28,FR,France +200902,7,22806,13997,31615,36,22,50,FR,France +200901,7,27073,17648,36498,43,28,58,FR,France +200852,7,13485,8749,18221,22,14,30,FR,France +200851,7,10984,7406,14562,18,12,24,FR,France +200850,7,12868,7126,18610,21,12,30,FR,France +200849,7,11365,4402,18328,19,8,30,FR,France +200848,7,14199,5494,22904,23,9,37,FR,France +200847,7,15819,7899,23739,26,13,39,FR,France +200846,7,8147,4546,11748,13,7,19,FR,France +200845,7,10538,5244,15832,17,8,26,FR,France +200844,7,10753,6665,14841,18,11,25,FR,France +200843,7,9420,5654,13186,15,9,21,FR,France +200842,7,10865,5017,16713,18,8,28,FR,France +200841,7,8583,3541,13625,14,6,22,FR,France +200840,7,8164,3051,13277,13,5,21,FR,France +200839,7,5477,2331,8623,9,4,14,FR,France +200838,7,3780,1129,6431,6,2,10,FR,France +200837,7,4612,1860,7364,8,4,12,FR,France +200836,7,2821,365,5277,5,1,9,FR,France +200835,7,2304,0,4896,4,0,8,FR,France +200834,7,4452,915,7989,7,1,13,FR,France +200833,7,5347,1116,9578,9,2,16,FR,France +200832,7,5294,1512,9076,9,3,15,FR,France +200831,7,10207,5298,15116,17,9,25,FR,France +200830,7,10220,5331,15109,17,9,25,FR,France +200829,7,10071,5148,14994,16,8,24,FR,France +200828,7,9826,4460,15192,16,7,25,FR,France +200827,7,11768,6077,17459,19,10,28,FR,France +200826,7,15584,10821,20347,25,17,33,FR,France +200825,7,21617,15364,27870,35,25,45,FR,France +200824,7,18253,12292,24214,30,20,40,FR,France +200823,7,14388,8610,20166,23,14,32,FR,France +200822,7,13560,7829,19291,22,13,31,FR,France +200821,7,19074,4085,34063,31,7,55,FR,France +200820,7,18272,12040,24504,30,20,40,FR,France +200819,7,16110,10352,21868,26,17,35,FR,France +200818,7,17377,11105,23649,28,18,38,FR,France +200817,7,27000,19317,34683,44,31,57,FR,France +200816,7,23002,15304,30700,37,24,50,FR,France +200815,7,25454,15856,35052,41,25,57,FR,France +200814,7,22236,15623,28849,36,25,47,FR,France +200813,7,20308,13107,27509,33,21,45,FR,France +200812,7,22462,15587,29337,37,26,48,FR,France +200811,7,20505,13958,27052,33,22,44,FR,France +200810,7,18078,11784,24372,29,19,39,FR,France +200809,7,20474,14073,26875,33,23,43,FR,France +200808,7,21441,15042,27840,35,25,45,FR,France +200807,7,17894,12348,23440,29,20,38,FR,France +200806,7,16310,11091,21529,27,18,36,FR,France +200805,7,16684,11106,22262,27,18,36,FR,France +200804,7,20997,14662,27332,34,24,44,FR,France +200803,7,19263,11093,27433,31,18,44,FR,France +200802,7,20501,13032,27970,33,21,45,FR,France +200801,7,20780,14093,27467,34,23,45,FR,France +200752,7,18010,11329,24691,29,18,40,FR,France +200751,7,20052,12509,27595,33,21,45,FR,France +200750,7,19059,12513,25605,31,20,42,FR,France +200749,7,18394,12805,23983,30,21,39,FR,France +200748,7,10765,5871,15659,18,10,26,FR,France +200747,7,10703,1791,19615,17,2,32,FR,France +200746,7,12318,4207,20429,20,7,33,FR,France +200745,7,12352,0,29660,20,0,48,FR,France +200744,7,7897,3419,12375,13,6,20,FR,France +200743,7,5788,2306,9270,9,3,15,FR,France +200742,7,5993,2329,9657,10,4,16,FR,France +200741,7,7130,0,17274,12,0,29,FR,France +200740,7,8146,940,15352,13,1,25,FR,France +200739,7,3916,500,7332,6,0,12,FR,France +200738,7,2691,462,4920,4,0,8,FR,France +200737,7,4100,1263,6937,7,2,12,FR,France +200736,7,1580,0,3223,3,0,6,FR,France +200735,7,3471,0,7162,6,0,12,FR,France +200734,7,3333,0,6764,5,0,11,FR,France +200733,7,3241,451,6031,5,0,10,FR,France +200732,7,7321,2112,12530,12,4,20,FR,France +200731,7,9932,3688,16176,16,6,26,FR,France +200730,7,9879,3616,16142,16,6,26,FR,France +200729,7,17227,7803,26651,28,13,43,FR,France +200728,7,14874,7763,21985,24,12,36,FR,France +200727,7,13500,7382,19618,22,12,32,FR,France +200726,7,15454,9522,21386,25,15,35,FR,France +200725,7,20567,13847,27287,34,23,45,FR,France +200724,7,26470,18336,34604,43,30,56,FR,France +200723,7,23443,15824,31062,38,26,50,FR,France +200722,7,18811,11559,26063,31,19,43,FR,France +200721,7,15325,9347,21303,25,15,35,FR,France +200720,7,17507,11589,23425,29,19,39,FR,France +200719,7,22692,15113,30271,37,25,49,FR,France +200718,7,20630,13394,27866,34,22,46,FR,France +200717,7,23755,14388,33122,39,24,54,FR,France +200716,7,23388,16188,30588,38,26,50,FR,France +200715,7,25695,17711,33679,42,29,55,FR,France +200714,7,16974,9959,23989,28,17,39,FR,France +200713,7,24625,16598,32652,40,27,53,FR,France +200712,7,20303,11331,29275,33,18,48,FR,France +200711,7,33056,21724,44388,54,36,72,FR,France +200710,7,20775,12182,29368,34,20,48,FR,France +200709,7,18750,12252,25248,31,20,42,FR,France +200708,7,19458,12998,25918,32,21,43,FR,France +200707,7,20978,14822,27134,34,24,44,FR,France +200706,7,14466,9375,19557,24,16,32,FR,France +200705,7,15339,9771,20907,25,16,34,FR,France +200704,7,19661,13333,25989,32,22,42,FR,France +200703,7,16211,10323,22099,26,16,36,FR,France +200702,7,15631,10037,21225,25,16,34,FR,France +200701,7,16483,10582,22384,27,17,37,FR,France +200652,7,20472,13371,27573,34,22,46,FR,France +200651,7,20557,12905,28209,34,21,47,FR,France +200650,7,11364,6541,16187,19,11,27,FR,France +200649,7,12518,6273,18763,21,11,31,FR,France +200648,7,8028,2783,13273,13,4,22,FR,France +200647,7,6240,2268,10212,10,3,17,FR,France +200646,7,4953,1841,8065,8,3,13,FR,France +200645,7,4064,1178,6950,7,2,12,FR,France +200644,7,5300,1084,9516,9,2,16,FR,France +200643,7,3518,1027,6009,6,2,10,FR,France +200642,7,2885,539,5231,5,1,9,FR,France +200641,7,4405,123,8687,7,0,14,FR,France +200640,7,2513,0,5505,4,0,9,FR,France +200639,7,992,0,2812,2,0,5,FR,France +200638,7,1363,0,3045,2,0,5,FR,France +200637,7,992,0,2711,2,0,5,FR,France +200636,7,820,0,2313,1,0,3,FR,France +200635,7,614,0,1628,1,0,3,FR,France +200634,7,1149,0,2623,2,0,4,FR,France +200633,7,161,0,630,0,0,1,FR,France +200632,7,476,0,1785,1,0,3,FR,France +200631,7,6255,754,11756,10,1,19,FR,France +200630,7,7140,2123,12157,12,4,20,FR,France +200629,7,6227,2488,9966,10,4,16,FR,France +200628,7,13044,6388,19700,21,10,32,FR,France +200627,7,18263,9407,27119,30,15,45,FR,France +200626,7,12465,6504,18426,20,10,30,FR,France +200625,7,14114,8492,19736,23,14,32,FR,France +200624,7,14773,9362,20184,24,15,33,FR,France +200623,7,12338,7512,17164,20,12,28,FR,France +200622,7,12669,7540,17798,21,13,29,FR,France +200621,7,15426,9709,21143,25,16,34,FR,France +200620,7,10366,6001,14731,17,10,24,FR,France +200619,7,13862,8779,18945,23,15,31,FR,France +200618,7,11495,6482,16508,19,11,27,FR,France +200617,7,16230,9656,22804,27,16,38,FR,France +200616,7,17624,10886,24362,29,18,40,FR,France +200615,7,18171,11485,24857,30,19,41,FR,France +200614,7,19218,13041,25395,31,21,41,FR,France +200613,7,16805,11064,22546,28,19,37,FR,France +200612,7,17604,12029,23179,29,20,38,FR,France +200611,7,15789,10289,21289,26,17,35,FR,France +200610,7,16775,11238,22312,27,18,36,FR,France +200609,7,16734,11153,22315,27,18,36,FR,France +200608,7,16964,11317,22611,28,19,37,FR,France +200607,7,11878,7047,16709,19,11,27,FR,France +200606,7,18915,13000,24830,31,21,41,FR,France +200605,7,16029,10665,21393,26,17,35,FR,France +200604,7,11400,7136,15664,19,12,26,FR,France +200603,7,15577,10494,20660,26,18,34,FR,France +200602,7,10313,6274,14352,17,10,24,FR,France +200601,7,20058,13481,26635,33,22,44,FR,France +200552,7,16588,9246,23930,27,15,39,FR,France +200551,7,27150,14219,40081,45,24,66,FR,France +200550,7,14340,8527,20153,24,14,34,FR,France +200549,7,12056,6953,17159,20,12,28,FR,France +200548,7,15056,8846,21266,25,15,35,FR,France +200547,7,14805,7691,21919,24,12,36,FR,France +200546,7,8390,2583,14197,14,4,24,FR,France +200545,7,11513,3776,19250,19,6,32,FR,France +200544,7,10086,2788,17384,17,5,29,FR,France +200543,7,9316,2080,16552,15,3,27,FR,France +200542,7,8373,3760,12986,14,6,22,FR,France +200541,7,11587,6045,17129,19,10,28,FR,France +200540,7,12374,6622,18126,20,11,29,FR,France +200539,7,4450,1509,7391,7,2,12,FR,France +200538,7,2272,67,4477,4,0,8,FR,France +200537,7,1677,0,3664,3,0,6,FR,France +200536,7,3369,510,6228,6,1,11,FR,France +200535,7,3124,482,5766,5,1,9,FR,France +200534,7,6673,1394,11952,11,2,20,FR,France +200533,7,8588,1696,15480,14,3,25,FR,France +200532,7,7859,2362,13356,13,4,22,FR,France +200531,7,9570,3334,15806,16,6,26,FR,France +200530,7,6172,0,13912,10,0,23,FR,France +200529,7,12452,5092,19812,21,9,33,FR,France +200528,7,18277,5762,30792,30,9,51,FR,France +200527,7,17547,9967,25127,29,16,42,FR,France +200526,7,27248,18071,36425,45,30,60,FR,France +200525,7,14089,8408,19770,23,14,32,FR,France +200524,7,15632,9553,21711,26,16,36,FR,France +200523,7,20069,12360,27778,33,20,46,FR,France +200522,7,20392,9119,31665,34,15,53,FR,France +200521,7,13623,8254,18992,22,13,31,FR,France +200520,7,17482,10870,24094,29,18,40,FR,France +200519,7,12622,7407,17837,21,12,30,FR,France +200518,7,10630,5706,15554,18,10,26,FR,France +200517,7,14979,8429,21529,25,14,36,FR,France +200516,7,11520,6566,16474,19,11,27,FR,France +200515,7,9114,4530,13698,15,7,23,FR,France +200514,7,16876,10333,23419,28,17,39,FR,France +200513,7,12513,7324,17702,21,12,30,FR,France +200512,7,15395,9108,21682,25,15,35,FR,France +200511,7,12702,7588,17816,21,13,29,FR,France +200510,7,11279,6465,16093,19,11,27,FR,France +200509,7,13085,7767,18403,22,13,31,FR,France +200508,7,10359,6162,14556,17,10,24,FR,France +200507,7,18640,12932,24348,31,22,40,FR,France +200506,7,11814,7295,16333,20,13,27,FR,France +200505,7,15387,10293,20481,25,17,33,FR,France +200504,7,12525,7897,17153,21,13,29,FR,France +200503,7,15946,10225,21667,26,17,35,FR,France +200502,7,12669,7600,17738,21,13,29,FR,France +200501,7,14192,8841,19543,23,14,32,FR,France +200453,7,17869,11244,24494,30,19,41,FR,France +200452,7,16974,10864,23084,28,18,38,FR,France +200451,7,14890,9250,20530,25,16,34,FR,France +200450,7,17657,10659,24655,29,17,41,FR,France +200449,7,16219,8194,24244,27,14,40,FR,France +200448,7,7162,2532,11792,12,4,20,FR,France +200447,7,8816,4136,13496,15,7,23,FR,France +200446,7,6806,2939,10673,11,5,17,FR,France +200445,7,9065,2889,15241,15,5,25,FR,France +200444,7,9795,4169,15421,16,7,25,FR,France +200443,7,5673,2412,8934,9,4,14,FR,France +200442,7,3038,802,5274,5,1,9,FR,France +200441,7,5061,1296,8826,8,2,14,FR,France +200440,7,3409,690,6128,6,1,11,FR,France +200439,7,5226,1044,9408,9,2,16,FR,France +200438,7,3412,0,7137,6,0,12,FR,France +200437,7,4351,537,8165,7,1,13,FR,France +200436,7,5121,1260,8982,9,3,15,FR,France +200435,7,7279,2610,11948,12,4,20,FR,France +200434,7,6425,1962,10888,11,4,18,FR,France +200433,7,11183,5394,16972,19,9,29,FR,France +200432,7,15854,7918,23790,26,13,39,FR,France +200431,7,17793,5261,30325,30,9,51,FR,France +200430,7,23244,14352,32136,39,24,54,FR,France +200429,7,34645,23193,46097,58,39,77,FR,France +200428,7,19481,11767,27195,32,19,45,FR,France +200427,7,21322,8377,34267,35,13,57,FR,France +200426,7,17171,7899,26443,29,14,44,FR,France +200425,7,26606,17976,35236,44,30,58,FR,France +200424,7,26142,17142,35142,43,28,58,FR,France +200423,7,23643,15715,31571,39,26,52,FR,France +200422,7,16119,9794,22444,27,16,38,FR,France +200421,7,20283,12915,27651,34,22,46,FR,France +200420,7,15730,9735,21725,26,16,36,FR,France +200419,7,22791,15145,30437,38,25,51,FR,France +200418,7,17807,11014,24600,30,19,41,FR,France +200417,7,19913,12212,27614,33,20,46,FR,France +200416,7,19289,11424,27154,32,19,45,FR,France +200415,7,20587,13594,27580,34,22,46,FR,France +200414,7,24610,16629,32591,41,28,54,FR,France +200413,7,22910,15782,30038,38,26,50,FR,France +200412,7,23468,15220,31716,39,25,53,FR,France +200411,7,23977,16337,31617,40,27,53,FR,France +200410,7,25519,15764,35274,42,26,58,FR,France +200409,7,26592,17202,35982,44,28,60,FR,France +200408,7,22820,15102,30538,38,25,51,FR,France +200407,7,23871,16628,31114,40,28,52,FR,France +200406,7,24567,15700,33434,41,26,56,FR,France +200405,7,12869,7824,17914,21,13,29,FR,France +200404,7,13172,8314,18030,22,14,30,FR,France +200403,7,6442,3015,9869,11,5,17,FR,France +200402,7,11126,6305,15947,18,10,26,FR,France +200401,7,24971,13819,36123,41,22,60,FR,France +200352,7,4920,0,22288,8,0,37,FR,France +200351,7,10235,2435,18035,17,4,30,FR,France +200350,7,9805,5520,14090,16,9,23,FR,France +200349,7,11685,7721,15649,20,13,27,FR,France +200348,7,6201,3319,9083,10,5,15,FR,France +200347,7,4897,1842,7952,8,3,13,FR,France +200346,7,4596,1236,7956,8,2,14,FR,France +200345,7,3501,1090,5912,6,2,10,FR,France +200344,7,3469,894,6044,6,2,10,FR,France +200343,7,4671,1766,7576,8,3,13,FR,France +200342,7,3855,955,6755,6,1,11,FR,France +200341,7,3179,427,5931,5,0,10,FR,France +200340,7,6983,2852,11114,12,5,19,FR,France +200339,7,952,0,2308,2,0,4,FR,France +200338,7,1628,0,3406,3,0,6,FR,France +200337,7,2995,0,6029,5,0,10,FR,France +200336,7,3595,0,7784,6,0,13,FR,France +200335,7,1340,0,4253,2,0,7,FR,France +200334,7,3842,0,10414,6,0,17,FR,France +200333,7,7269,0,18830,12,0,31,FR,France +200332,7,2908,0,6463,5,0,11,FR,France +200331,7,2053,0,4640,3,0,7,FR,France +200330,7,5106,259,9953,9,1,17,FR,France +200329,7,8195,0,21289,14,0,36,FR,France +200328,7,9002,3511,14493,15,6,24,FR,France +200327,7,4902,1397,8407,8,2,14,FR,France +200326,7,17746,7867,27625,30,13,47,FR,France +200325,7,8190,3460,12920,14,6,22,FR,France +200324,7,33803,13366,54240,56,22,90,FR,France +200323,7,14278,6733,21823,24,11,37,FR,France +200322,7,13397,7140,19654,22,12,32,FR,France +200321,7,12113,3506,20720,20,6,34,FR,France +200320,7,10454,5534,15374,17,9,25,FR,France +200319,7,12833,6772,18894,21,11,31,FR,France +200318,7,25572,16325,34819,43,28,58,FR,France +200317,7,21556,11493,31619,36,19,53,FR,France +200316,7,20007,12091,27923,33,20,46,FR,France +200315,7,26837,18106,35568,45,30,60,FR,France +200314,7,19148,10594,27702,32,18,46,FR,France +200313,7,27087,16490,37684,45,27,63,FR,France +200312,7,24322,15256,33388,41,26,56,FR,France +200311,7,21652,12929,30375,36,21,51,FR,France +200310,7,29033,19506,38560,49,33,65,FR,France +200309,7,28198,17625,38771,47,29,65,FR,France +200308,7,36298,22548,50048,61,38,84,FR,France +200307,7,27050,14994,39106,45,25,65,FR,France +200306,7,25101,14828,35374,42,25,59,FR,France +200305,7,15588,7493,23683,26,12,40,FR,France +200304,7,17141,9713,24569,29,17,41,FR,France +200303,7,18329,11799,24859,31,20,42,FR,France +200302,7,18829,10035,27623,31,16,46,FR,France +200301,7,22582,11488,33676,38,19,57,FR,France +200252,7,20417,12258,28576,34,20,48,FR,France +200251,7,22444,14164,30724,38,24,52,FR,France +200250,7,10873,6406,15340,18,10,26,FR,France +200249,7,16468,2559,30377,28,5,51,FR,France +200248,7,10264,4123,16405,17,7,27,FR,France +200247,7,12129,4283,19975,20,7,33,FR,France +200246,7,5507,1186,9828,9,2,16,FR,France +200245,7,9335,4813,13857,16,8,24,FR,France +200244,7,9388,2462,16314,16,4,28,FR,France +200243,7,10756,4601,16911,18,8,28,FR,France +200242,7,8703,3946,13460,15,7,23,FR,France +200241,7,7695,3062,12328,13,5,21,FR,France +200240,7,7097,2512,11682,12,4,20,FR,France +200239,7,6215,2540,9890,10,4,16,FR,France +200238,7,4237,1165,7309,7,2,12,FR,France +200237,7,1210,0,2674,2,0,4,FR,France +200236,7,2671,314,5028,4,0,8,FR,France +200235,7,1193,0,3093,2,0,5,FR,France +200234,7,5394,1014,9774,9,2,16,FR,France +200233,7,5395,510,10280,9,1,17,FR,France +200232,7,11308,1117,21499,19,2,36,FR,France +200231,7,7163,1350,12976,12,2,22,FR,France +200230,7,10184,3615,16753,17,6,28,FR,France +200229,7,11146,5228,17064,19,9,29,FR,France +200228,7,15908,8318,23498,27,14,40,FR,France +200227,7,12124,441,23807,20,0,40,FR,France +200226,7,18706,4188,33224,31,7,55,FR,France +200225,7,18807,9408,28206,32,16,48,FR,France +200224,7,15035,9084,20986,25,15,35,FR,France +200223,7,12617,6916,18318,21,11,31,FR,France +200222,7,18851,10747,26955,32,18,46,FR,France +200221,7,14282,7527,21037,24,13,35,FR,France +200220,7,12558,6860,18256,21,11,31,FR,France +200219,7,18605,11518,25692,31,19,43,FR,France +200218,7,10857,5495,16219,18,9,27,FR,France +200217,7,16252,9537,22967,27,16,38,FR,France +200216,7,10284,5016,15552,17,8,26,FR,France +200215,7,19217,9502,28932,32,16,48,FR,France +200214,7,15585,6215,24955,26,10,42,FR,France +200213,7,29411,13274,45548,49,22,76,FR,France +200212,7,12354,7208,17500,21,12,30,FR,France +200211,7,11781,7053,16509,20,12,28,FR,France +200210,7,9450,5283,13617,16,9,23,FR,France +200209,7,11735,5297,18173,20,9,31,FR,France +200208,7,8153,3653,12653,14,6,22,FR,France +200207,7,6992,3354,10630,12,6,18,FR,France +200206,7,7857,3052,12662,13,5,21,FR,France +200205,7,7405,2868,11942,12,4,20,FR,France +200204,7,13562,7935,19189,23,14,32,FR,France +200203,7,8152,4543,11761,14,8,20,FR,France +200202,7,9486,4411,14561,16,7,25,FR,France +200201,7,6329,1565,11093,11,3,19,FR,France +200152,7,5566,2267,8865,9,3,15,FR,France +200151,7,6045,2630,9460,10,4,16,FR,France +200150,7,11601,4100,19102,20,7,33,FR,France +200149,7,5828,851,10805,10,2,18,FR,France +200148,7,9965,5007,14923,17,9,25,FR,France +200147,7,6292,2021,10563,11,4,18,FR,France +200146,7,5424,2218,8630,9,4,14,FR,France +200145,7,9468,5023,13913,16,8,24,FR,France +200144,7,4941,1881,8001,8,3,13,FR,France +200143,7,6978,3201,10755,12,6,18,FR,France +200142,7,6726,3147,10305,11,5,17,FR,France +200141,7,5410,1849,8971,9,3,15,FR,France +200140,7,3320,637,6003,6,1,11,FR,France +200139,7,1152,0,2569,2,0,4,FR,France +200138,7,864,0,2411,1,0,4,FR,France +200137,7,1234,0,3393,2,0,6,FR,France +200136,7,391,0,1256,1,0,2,FR,France +200135,7,2539,0,6274,4,0,10,FR,France +200134,7,1946,0,4439,3,0,7,FR,France +200133,7,655,0,2046,1,0,3,FR,France +200132,7,4619,0,10912,8,0,19,FR,France +200131,7,7622,1190,14054,13,2,24,FR,France +200130,7,13686,4678,22694,23,8,38,FR,France +200129,7,12966,4727,21205,22,8,36,FR,France +200128,7,20908,11957,29859,35,20,50,FR,France +200127,7,26634,17739,35529,45,30,60,FR,France +200126,7,13863,7666,20060,23,13,33,FR,France +200125,7,17329,9452,25206,29,16,42,FR,France +200124,7,10961,6673,15249,19,12,26,FR,France +200123,7,7892,3888,11896,13,6,20,FR,France +200122,7,10912,4621,17203,18,7,29,FR,France +200121,7,10194,5217,15171,17,9,25,FR,France +200120,7,10390,5710,15070,18,10,26,FR,France +200119,7,10976,5927,16025,19,10,28,FR,France +200118,7,11933,6833,17033,20,11,29,FR,France +200117,7,16250,9256,23244,27,15,39,FR,France +200116,7,14131,8691,19571,24,15,33,FR,France +200115,7,11033,6411,15655,19,11,27,FR,France +200114,7,18381,12349,24413,31,21,41,FR,France +200113,7,15253,9582,20924,26,16,36,FR,France +200112,7,12761,8155,17367,22,14,30,FR,France +200111,7,11592,6790,16394,20,12,28,FR,France +200110,7,11220,6697,15743,19,11,27,FR,France +200109,7,10984,6431,15537,19,11,27,FR,France +200108,7,18335,10145,26525,31,17,45,FR,France +200107,7,17404,10389,24419,29,17,41,FR,France +200106,7,18382,10498,26266,31,18,44,FR,France +200105,7,13455,7904,19006,23,14,32,FR,France +200104,7,16438,10780,22096,28,18,38,FR,France +200103,7,18174,12049,24299,31,21,41,FR,France +200102,7,22905,16080,29730,39,27,51,FR,France +200101,7,29487,21117,37857,50,36,64,FR,France +200052,7,17041,10342,23740,29,18,40,FR,France +200051,7,11749,7358,16140,20,13,27,FR,France +200050,7,14215,8706,19724,24,15,33,FR,France +200049,7,10172,5845,14499,17,10,24,FR,France +200048,7,13683,8322,19044,23,14,32,FR,France +200047,7,9924,5066,14782,17,9,25,FR,France +200046,7,11103,5449,16757,19,9,29,FR,France +200045,7,7870,3542,12198,13,6,20,FR,France +200044,7,11328,6118,16538,19,10,28,FR,France +200043,7,5292,1687,8897,9,3,15,FR,France +200042,7,4410,1293,7527,8,3,13,FR,France +200041,7,5242,1813,8671,9,3,15,FR,France +200040,7,4066,1351,6781,7,2,12,FR,France +200039,7,4574,885,8263,8,2,14,FR,France +200038,7,8241,3875,12607,14,7,21,FR,France +200037,7,3124,423,5825,5,0,10,FR,France +200036,7,731,0,2044,1,0,3,FR,France +200035,7,6605,959,12251,11,1,21,FR,France +200034,7,6924,931,12917,12,2,22,FR,France +200033,7,10713,3957,17469,18,7,29,FR,France +200032,7,15736,5003,26469,27,9,45,FR,France +200031,7,13088,5542,20634,22,9,35,FR,France +200030,7,16422,9062,23782,28,15,41,FR,France +200029,7,16543,8116,24970,28,14,42,FR,France +200028,7,12868,5178,20558,22,9,35,FR,France +200027,7,18228,10887,25569,31,19,43,FR,France +200026,7,17377,10789,23965,30,19,41,FR,France +200025,7,22600,15119,30081,38,25,51,FR,France +200024,7,16046,10504,21588,27,18,36,FR,France +200023,7,11887,6681,17093,20,11,29,FR,France +200022,7,26275,18762,33788,45,32,58,FR,France +200021,7,15921,9967,21875,27,17,37,FR,France +200020,7,19178,12565,25791,33,22,44,FR,France +200019,7,17152,10424,23880,29,18,40,FR,France +200018,7,17571,10754,24388,30,18,42,FR,France +200017,7,9999,5672,14326,17,10,24,FR,France +200016,7,17506,11461,23551,30,20,40,FR,France +200015,7,23333,14747,31919,40,25,55,FR,France +200014,7,15027,9838,20216,26,17,35,FR,France +200013,7,17924,12383,23465,30,21,39,FR,France +200012,7,15415,9917,20913,26,17,35,FR,France +200011,7,12359,7372,17346,21,13,29,FR,France +200010,7,13858,9167,18549,24,16,32,FR,France +200009,7,9096,5451,12741,15,9,21,FR,France +200008,7,10596,6574,14618,18,11,25,FR,France +200007,7,13593,8816,18370,23,15,31,FR,France +200006,7,9017,5391,12643,15,9,21,FR,France +200005,7,12681,7750,17612,22,14,30,FR,France +200004,7,11889,7253,16525,20,12,28,FR,France +200003,7,9171,5628,12714,16,10,22,FR,France +200002,7,10268,5957,14579,17,10,24,FR,France +200001,7,10986,6521,15451,19,11,27,FR,France +199952,7,10358,5667,15049,18,10,26,FR,France +199951,7,10099,6132,14066,17,10,24,FR,France +199950,7,10439,6481,14397,18,11,25,FR,France +199949,7,7736,4269,11203,13,7,19,FR,France +199948,7,11414,6754,16074,20,12,28,FR,France +199947,7,7639,2705,12573,13,5,21,FR,France +199946,7,6544,0,15074,11,0,26,FR,France +199945,7,11273,3165,19381,19,5,33,FR,France +199944,7,8049,3828,12270,14,7,21,FR,France +199943,7,7788,4226,11350,13,7,19,FR,France +199942,7,6779,3659,9899,12,7,17,FR,France +199941,7,5213,2646,7780,9,5,13,FR,France +199940,7,5018,2256,7780,9,4,14,FR,France +199939,7,3108,1141,5075,5,2,8,FR,France +199938,7,2095,143,4047,4,1,7,FR,France +199937,7,3611,1095,6127,6,2,10,FR,France +199936,7,2085,116,4054,4,1,7,FR,France +199935,7,1102,0,2231,2,0,4,FR,France +199934,7,2813,468,5158,5,1,9,FR,France +199933,7,7210,2996,11424,12,5,19,FR,France +199932,7,6981,2822,11140,12,5,19,FR,France +199931,7,6389,2284,10494,11,4,18,FR,France +199930,7,10567,4364,16770,18,7,29,FR,France +199929,7,18284,11145,25423,31,19,43,FR,France +199928,7,21079,13832,28326,36,24,48,FR,France +199927,7,18824,12647,25001,32,21,43,FR,France +199926,7,18098,12190,24006,31,21,41,FR,France +199925,7,23863,16911,30815,41,29,53,FR,France +199924,7,18038,12162,23914,31,21,41,FR,France +199923,7,19660,13601,25719,34,24,44,FR,France +199922,7,18093,12570,23616,31,22,40,FR,France +199921,7,15850,10129,21571,27,17,37,FR,France +199920,7,12241,7408,17074,21,13,29,FR,France +199919,7,10738,6273,15203,18,10,26,FR,France +199918,7,20739,14823,26655,35,25,45,FR,France +199917,7,13993,9229,18757,24,16,32,FR,France +199916,7,16199,10966,21432,28,19,37,FR,France +199915,7,19936,13939,25933,34,24,44,FR,France +199914,7,22907,15999,29815,39,27,51,FR,France +199913,7,18404,11277,25531,31,19,43,FR,France +199912,7,19242,13136,25348,33,23,43,FR,France +199911,7,14923,9872,19974,26,17,35,FR,France +199910,7,16058,10370,21746,27,17,37,FR,France +199909,7,11125,6841,15409,19,12,26,FR,France +199908,7,10840,7075,14605,19,13,25,FR,France +199907,7,13655,9263,18047,23,15,31,FR,France +199906,7,17654,12681,22627,30,21,39,FR,France +199905,7,16838,11942,21734,29,21,37,FR,France +199904,7,17056,12124,21988,29,21,37,FR,France +199903,7,18805,13967,23643,32,24,40,FR,France +199902,7,14863,10135,19591,25,17,33,FR,France +199901,7,13707,9075,18339,23,15,31,FR,France +199853,7,24797,17975,31619,43,31,55,FR,France +199852,7,23616,16902,30330,41,29,53,FR,France +199851,7,13919,9478,18360,24,16,32,FR,France +199850,7,20556,15164,25948,35,26,44,FR,France +199849,7,16232,11327,21137,28,20,36,FR,France +199848,7,11998,7691,16305,21,14,28,FR,France +199847,7,13617,8934,18300,23,15,31,FR,France +199846,7,7646,4419,10873,13,7,19,FR,France +199845,7,15930,10713,21147,27,18,36,FR,France +199844,7,14145,9390,18900,24,16,32,FR,France +199843,7,16707,11447,21967,29,20,38,FR,France +199842,7,12475,7806,17144,21,13,29,FR,France +199841,7,13018,8151,17885,22,14,30,FR,France +199840,7,7396,3653,11139,13,7,19,FR,France +199839,7,4467,1896,7038,8,4,12,FR,France +199838,7,3421,1176,5666,6,2,10,FR,France +199837,7,4489,2136,6842,8,4,12,FR,France +199836,7,6355,2914,9796,11,5,17,FR,France +199835,7,7689,3867,11511,13,6,20,FR,France +199834,7,7235,3191,11279,12,5,19,FR,France +199833,7,11431,6018,16844,20,11,29,FR,France +199832,7,20493,9237,31749,35,16,54,FR,France +199831,7,15619,9125,22113,27,16,38,FR,France +199830,7,19360,12617,26103,33,21,45,FR,France +199829,7,17816,11414,24218,31,20,42,FR,France +199828,7,20757,14385,27129,36,25,47,FR,France +199827,7,20714,14671,26757,36,26,46,FR,France +199826,7,24479,17611,31347,42,30,54,FR,France +199825,7,24462,17924,31000,42,31,53,FR,France +199824,7,18928,13945,23911,32,23,41,FR,France +199823,7,13478,8876,18080,23,15,31,FR,France +199822,7,13213,8997,17429,23,16,30,FR,France +199821,7,10741,6627,14855,18,11,25,FR,France +199820,7,23223,17217,29229,40,30,50,FR,France +199819,7,16130,10667,21593,28,19,37,FR,France +199818,7,15802,10374,21230,27,18,36,FR,France +199817,7,14119,8452,19786,24,14,34,FR,France +199816,7,11744,7632,15856,20,13,27,FR,France +199815,7,17422,12372,22472,30,21,39,FR,France +199814,7,20962,15699,26225,36,27,45,FR,France +199813,7,17029,12181,21877,29,21,37,FR,France +199812,7,14960,10393,19527,26,18,34,FR,France +199811,7,13687,9540,17834,23,16,30,FR,France +199810,7,14294,9623,18965,25,17,33,FR,France +199809,7,12550,8183,16917,22,15,29,FR,France +199808,7,15378,10656,20100,26,18,34,FR,France +199807,7,14618,10083,19153,25,17,33,FR,France +199806,7,15316,10683,19949,26,18,34,FR,France +199805,7,11805,7653,15957,20,13,27,FR,France +199804,7,15746,10733,20759,27,18,36,FR,France +199803,7,13085,8916,17254,22,15,29,FR,France +199802,7,10764,6882,14646,18,11,25,FR,France +199801,7,19222,13376,25068,33,23,43,FR,France +199752,7,18582,12576,24588,32,22,42,FR,France +199751,7,10933,6829,15037,19,12,26,FR,France +199750,7,9622,6005,13239,17,11,23,FR,France +199749,7,12183,8157,16209,21,14,28,FR,France +199748,7,7368,4022,10714,13,7,19,FR,France +199747,7,10482,6595,14369,18,11,25,FR,France +199746,7,8391,4342,12440,14,7,21,FR,France +199745,7,7499,3716,11282,13,6,20,FR,France +199744,7,5492,2442,8542,9,4,14,FR,France +199743,7,4829,2314,7344,8,4,12,FR,France +199742,7,4781,2027,7535,8,3,13,FR,France +199741,7,6622,3367,9877,11,5,17,FR,France +199740,7,2851,764,4938,5,1,9,FR,France +199739,7,3242,851,5633,6,2,10,FR,France +199738,7,2916,579,5253,5,1,9,FR,France +199737,7,4944,2248,7640,9,4,14,FR,France +199736,7,2767,679,4855,5,1,9,FR,France +199735,7,1245,12,2478,2,0,4,FR,France +199734,7,6971,2145,11797,12,4,20,FR,France +199733,7,11167,5245,17089,19,9,29,FR,France +199732,7,12349,6916,17782,21,12,30,FR,France +199731,7,13276,8068,18484,23,14,32,FR,France +199730,7,16463,10419,22507,28,18,38,FR,France +199729,7,12458,6536,18380,21,11,31,FR,France +199728,7,14155,8553,19757,24,14,34,FR,France +199727,7,16611,11473,21749,29,20,38,FR,France +199726,7,14303,10203,18403,25,18,32,FR,France +199725,7,11562,7487,15637,20,13,27,FR,France +199724,7,20722,15143,26301,36,26,46,FR,France +199723,7,11958,8064,15852,21,14,28,FR,France +199722,7,19175,14023,24327,33,24,42,FR,France +199721,7,15933,11074,20792,27,19,35,FR,France +199720,7,16512,11798,21226,28,20,36,FR,France +199719,7,14490,10231,18749,25,18,32,FR,France +199718,7,14033,9863,18203,24,17,31,FR,France +199717,7,17029,12579,21479,29,21,37,FR,France +199716,7,14686,10709,18663,25,18,32,FR,France +199715,7,19100,14311,23889,33,25,41,FR,France +199714,7,17746,13153,22339,31,23,39,FR,France +199713,7,17384,12873,21895,30,22,38,FR,France +199712,7,13589,9321,17857,23,16,30,FR,France +199711,7,16033,11789,20277,28,21,35,FR,France +199710,7,12351,8688,16014,21,15,27,FR,France +199709,7,16809,12329,21289,29,21,37,FR,France +199708,7,9660,6429,12891,17,11,23,FR,France +199707,7,16751,12377,21125,29,21,37,FR,France +199706,7,17151,13029,21273,30,23,37,FR,France +199705,7,12543,9128,15958,22,16,28,FR,France +199704,7,14475,10891,18059,25,19,31,FR,France +199703,7,12135,8727,15543,21,15,27,FR,France +199702,7,15541,11574,19508,27,20,34,FR,France +199701,7,14432,10701,18163,25,19,31,FR,France +199652,7,15556,11735,19377,27,20,34,FR,France +199651,7,14038,10500,17576,24,18,30,FR,France +199650,7,14236,10857,17615,25,19,31,FR,France +199649,7,10776,7924,13628,19,14,24,FR,France +199648,7,7489,4949,10029,13,9,17,FR,France +199647,7,11826,8573,15079,20,14,26,FR,France +199646,7,10269,7201,13337,18,13,23,FR,France +199645,7,17313,12967,21659,30,22,38,FR,France +199644,7,12095,8643,15547,21,15,27,FR,France +199643,7,14958,10739,19177,26,19,33,FR,France +199642,7,14106,10196,18016,24,17,31,FR,France +199641,7,10302,6968,13636,18,12,24,FR,France +199640,7,9514,5990,13038,16,10,22,FR,France +199639,7,6376,3651,9101,11,6,16,FR,France +199638,7,3835,1587,6083,7,3,11,FR,France +199637,7,2746,1100,4392,5,2,8,FR,France +199636,7,4577,2320,6834,8,4,12,FR,France +199635,7,2624,902,4346,5,2,8,FR,France +199634,7,6280,3139,9421,11,6,16,FR,France +199633,7,10194,5347,15041,18,10,26,FR,France +199632,7,10116,5942,14290,17,10,24,FR,France +199631,7,14292,9640,18944,25,17,33,FR,France +199630,7,20862,14786,26938,36,26,46,FR,France +199629,7,17243,12463,22023,30,22,38,FR,France +199628,7,16021,11796,20246,28,21,35,FR,France +199627,7,19880,14406,25354,34,25,43,FR,France +199626,7,12565,8783,16347,22,15,29,FR,France +199625,7,19360,14570,24150,33,25,41,FR,France +199624,7,20778,15610,25946,36,27,45,FR,France +199623,7,17991,13162,22820,31,23,39,FR,France +199622,7,18294,13971,22617,32,25,39,FR,France +199621,7,14000,10136,17864,24,17,31,FR,France +199620,7,16598,12361,20835,29,22,36,FR,France +199619,7,11710,8148,15272,20,14,26,FR,France +199618,7,12140,8325,15955,21,14,28,FR,France +199617,7,17984,13059,22909,31,22,40,FR,France +199616,7,10796,7250,14342,19,13,25,FR,France +199615,7,12766,9101,16431,22,16,28,FR,France +199614,7,14952,10656,19248,26,19,33,FR,France +199613,7,12861,9266,16456,22,16,28,FR,France +199612,7,11592,8202,14982,20,14,26,FR,France +199611,7,15991,12026,19956,28,21,35,FR,France +199610,7,13551,9873,17229,23,17,29,FR,France +199609,7,9737,6799,12675,17,12,22,FR,France +199608,7,11835,8569,15101,20,14,26,FR,France +199607,7,9296,6455,12137,16,11,21,FR,France +199606,7,11330,8078,14582,20,14,26,FR,France +199605,7,10249,7092,13406,18,13,23,FR,France +199604,7,9004,6336,11672,16,11,21,FR,France +199603,7,5904,3709,8099,10,6,14,FR,France +199602,7,6166,4027,8305,11,7,15,FR,France +199601,7,7238,4902,9574,12,8,16,FR,France +199552,7,7808,5225,10391,14,10,18,FR,France +199551,7,10505,7602,13408,18,13,23,FR,France +199550,7,9513,7014,12012,16,12,20,FR,France +199549,7,10263,7482,13044,18,13,23,FR,France +199548,7,9491,6551,12431,16,11,21,FR,France +199547,7,11221,8016,14426,19,13,25,FR,France +199546,7,5104,2852,7356,9,5,13,FR,France +199545,7,5017,2797,7237,9,5,13,FR,France +199544,7,8374,5440,11308,14,9,19,FR,France +199543,7,6365,3429,9301,11,6,16,FR,France +199542,7,5827,3427,8227,10,6,14,FR,France +199541,7,5884,3274,8494,10,5,15,FR,France +199540,7,4653,2571,6735,8,4,12,FR,France +199539,7,4334,2014,6654,8,4,12,FR,France +199538,7,3821,1909,5733,7,4,10,FR,France +199537,7,2297,884,3710,4,2,6,FR,France +199536,7,2317,870,3764,4,1,7,FR,France +199535,7,2531,1035,4027,4,1,7,FR,France +199534,7,5067,2070,8064,9,4,14,FR,France +199533,7,4709,1793,7625,8,3,13,FR,France +199532,7,8030,3945,12115,14,7,21,FR,France +199531,7,12034,7228,16840,21,13,29,FR,France +199530,7,16283,11419,21147,28,20,36,FR,France +199529,7,15520,11209,19831,27,20,34,FR,France +199528,7,21385,16186,26584,37,28,46,FR,France +199527,7,31707,25490,37924,55,44,66,FR,France +199526,7,23680,18921,28439,41,33,49,FR,France +199525,7,27941,22665,33217,48,39,57,FR,France +199524,7,24813,19263,30363,43,33,53,FR,France +199523,7,19371,14610,24132,34,26,42,FR,France +199522,7,16158,12114,20202,28,21,35,FR,France +199521,7,14986,10952,19020,26,19,33,FR,France +199520,7,12831,9059,16603,22,15,29,FR,France +199519,7,15806,11585,20027,27,20,34,FR,France +199518,7,15333,10987,19679,27,19,35,FR,France +199517,7,15551,11471,19631,27,20,34,FR,France +199516,7,15939,12349,19529,28,22,34,FR,France +199515,7,16126,12689,19563,28,22,34,FR,France +199514,7,15247,11965,18529,26,20,32,FR,France +199513,7,16864,13368,20360,29,23,35,FR,France +199512,7,15875,12429,19321,27,21,33,FR,France +199511,7,12844,9644,16044,22,16,28,FR,France +199510,7,15346,11782,18910,27,21,33,FR,France +199509,7,14754,11260,18248,26,20,32,FR,France +199508,7,14521,11077,17965,25,19,31,FR,France +199507,7,14315,10809,17821,25,19,31,FR,France +199506,7,18089,14383,21795,31,25,37,FR,France +199505,7,13414,10176,16652,23,17,29,FR,France +199504,7,15743,12316,19170,27,21,33,FR,France +199503,7,13763,10614,16912,24,19,29,FR,France +199502,7,11495,8490,14500,20,15,25,FR,France +199501,7,13733,10266,17200,24,18,30,FR,France +199452,7,12696,9453,15939,22,16,28,FR,France +199451,7,10390,7458,13322,18,13,23,FR,France +199450,7,8048,5524,10572,14,10,18,FR,France +199449,7,8212,5651,10773,14,10,18,FR,France +199448,7,6481,4250,8712,11,7,15,FR,France +199447,7,7140,4666,9614,12,8,16,FR,France +199446,7,5021,2972,7070,9,5,13,FR,France +199445,7,6759,4267,9251,12,8,16,FR,France +199444,7,9276,5996,12556,16,10,22,FR,France +199443,7,5622,3091,8153,10,6,14,FR,France +199442,7,5848,3383,8313,10,6,14,FR,France +199441,7,4921,2796,7046,9,5,13,FR,France +199440,7,5936,3694,8178,10,6,14,FR,France +199439,7,4090,2080,6100,7,4,10,FR,France +199438,7,2734,1164,4304,5,2,8,FR,France +199437,7,4364,1957,6771,8,4,12,FR,France +199436,7,1991,509,3473,3,0,6,FR,France +199435,7,3676,1494,5858,6,2,10,FR,France +199434,7,6830,3728,9932,12,7,17,FR,France +199433,7,6933,3534,10332,12,6,18,FR,France +199432,7,4851,2299,7403,8,4,12,FR,France +199431,7,7346,3935,10757,13,7,19,FR,France +199430,7,17674,12807,22541,31,23,39,FR,France +199429,7,17175,12461,21889,30,22,38,FR,France +199428,7,16743,12021,21465,29,21,37,FR,France +199427,7,22335,17343,27327,39,30,48,FR,France +199426,7,23679,18832,28526,41,33,49,FR,France +199425,7,24951,20263,29639,43,35,51,FR,France +199424,7,29139,22549,35729,51,40,62,FR,France +199423,7,13583,3641,23525,24,7,41,FR,France +199422,7,16336,4640,28032,28,8,48,FR,France +199421,7,16477,11025,21929,29,20,38,FR,France +199420,7,12872,9458,16286,22,16,28,FR,France +199419,7,13769,10440,17098,24,18,30,FR,France +199418,7,13066,9917,16215,23,18,28,FR,France +199417,7,18648,14838,22458,32,25,39,FR,France +199416,7,17629,13660,21598,31,24,38,FR,France +199415,7,23128,18550,27706,40,32,48,FR,France +199414,7,20128,15971,24285,35,28,42,FR,France +199413,7,16259,12721,19797,28,22,34,FR,France +199412,7,15215,11581,18849,26,20,32,FR,France +199411,7,16439,12812,20066,29,23,35,FR,France +199410,7,20681,16433,24929,36,29,43,FR,France +199409,7,22652,17519,27785,39,30,48,FR,France +199408,7,22067,17044,27090,38,29,47,FR,France +199407,7,15332,11563,19101,27,20,34,FR,France +199406,7,15321,11710,18932,27,21,33,FR,France +199405,7,15264,11523,19005,27,21,33,FR,France +199404,7,10871,7697,14045,19,13,25,FR,France +199403,7,10882,7808,13956,19,14,24,FR,France +199402,7,11834,8348,15320,21,15,27,FR,France +199401,7,11104,8142,14066,19,14,24,FR,France +199352,7,9874,6746,13002,17,12,22,FR,France +199351,7,9565,6818,12312,17,12,22,FR,France +199350,7,6195,4181,8209,11,7,15,FR,France +199349,7,10095,7443,12747,18,13,23,FR,France +199348,7,6413,4261,8565,11,7,15,FR,France +199347,7,7543,4934,10152,13,8,18,FR,France +199346,7,7862,5175,10549,14,9,19,FR,France +199345,7,5648,3511,7785,10,6,14,FR,France +199344,7,6964,4509,9419,12,8,16,FR,France +199343,7,5976,3632,8320,10,6,14,FR,France +199342,7,7669,4853,10485,13,8,18,FR,France +199341,7,9657,6648,12666,17,12,22,FR,France +199340,7,5725,3082,8368,10,5,15,FR,France +199339,7,5520,3207,7833,10,6,14,FR,France +199338,7,2179,888,3470,4,2,6,FR,France +199337,7,1762,557,2967,3,1,5,FR,France +199336,7,3214,1526,4902,6,3,9,FR,France +199335,7,2335,910,3760,4,2,6,FR,France +199334,7,3770,1712,5828,7,3,11,FR,France +199333,7,5925,3250,8600,10,5,15,FR,France +199332,7,12711,8079,17343,22,14,30,FR,France +199331,7,12481,7874,17088,22,14,30,FR,France +199330,7,12584,8619,16549,22,15,29,FR,France +199329,7,13179,8991,17367,23,16,30,FR,France +199328,7,15293,11335,19251,27,20,34,FR,France +199327,7,14134,9791,18477,25,17,33,FR,France +199326,7,17937,13577,22297,31,23,39,FR,France +199325,7,19581,14916,24246,34,26,42,FR,France +199324,7,18285,13450,23120,32,24,40,FR,France +199323,7,16003,11927,20079,28,21,35,FR,France +199322,7,12652,8597,16707,22,15,29,FR,France +199321,7,15218,10970,19466,27,20,34,FR,France +199320,7,11343,7655,15031,20,14,26,FR,France +199319,7,12086,8856,15316,21,15,27,FR,France +199318,7,18898,14305,23491,33,25,41,FR,France +199317,7,14969,10565,19373,26,18,34,FR,France +199316,7,15102,11226,18978,26,19,33,FR,France +199315,7,15058,11183,18933,26,19,33,FR,France +199314,7,12425,9045,15805,22,16,28,FR,France +199313,7,12266,8927,15605,21,15,27,FR,France +199312,7,10821,7884,13758,19,14,24,FR,France +199311,7,11021,8006,14036,19,14,24,FR,France +199310,7,15847,12158,19536,28,22,34,FR,France +199309,7,15084,11059,19109,26,19,33,FR,France +199308,7,16967,12936,20998,30,23,37,FR,France +199307,7,16057,12350,19764,28,22,34,FR,France +199306,7,15887,12275,19499,28,22,34,FR,France +199305,7,15954,12443,19465,28,22,34,FR,France +199304,7,12374,9426,15322,22,17,27,FR,France +199303,7,15283,11831,18735,27,21,33,FR,France +199302,7,13366,10262,16470,23,18,28,FR,France +199301,7,18678,14977,22379,33,27,39,FR,France +199253,7,17829,13827,21831,31,24,38,FR,France +199252,7,14330,10582,18078,25,18,32,FR,France +199251,7,14635,11262,18008,26,20,32,FR,France +199250,7,15252,11566,18938,27,21,33,FR,France +199249,7,14411,11187,17635,25,19,31,FR,France +199248,7,10048,7396,12700,18,13,23,FR,France +199247,7,13069,9752,16386,23,17,29,FR,France +199246,7,6900,4727,9073,12,8,16,FR,France +199245,7,10791,7794,13788,19,14,24,FR,France +199244,7,10205,7482,12928,18,13,23,FR,France +199243,7,7196,4908,9484,13,9,17,FR,France +199242,7,5748,3738,7758,10,6,14,FR,France +199241,7,3587,2045,5129,6,3,9,FR,France +199240,7,5654,3442,7866,10,6,14,FR,France +199239,7,4747,2751,6743,8,5,11,FR,France +199238,7,2842,1306,4378,5,2,8,FR,France +199237,7,4103,2203,6003,7,4,10,FR,France +199236,7,2801,1200,4402,5,2,8,FR,France +199235,7,6428,3717,9139,11,6,16,FR,France +199234,7,7517,4190,10844,13,7,19,FR,France +199233,7,9951,5955,13947,17,10,24,FR,France +199232,7,16090,11337,20843,28,20,36,FR,France +199231,7,17156,12441,21871,30,22,38,FR,France +199230,7,21780,16301,27259,38,28,48,FR,France +199229,7,18926,13397,24455,33,23,43,FR,France +199228,7,28144,20384,35904,49,35,63,FR,France +199227,7,29388,22331,36445,51,39,63,FR,France +199226,7,27933,21686,34180,49,38,60,FR,France +199225,7,26446,21153,31739,46,37,55,FR,France +199224,7,19614,14769,24459,34,26,42,FR,France +199223,7,23628,17852,29404,41,31,51,FR,France +199222,7,20438,14868,26008,36,26,46,FR,France +199221,7,22595,17395,27795,40,31,49,FR,France +199220,7,21092,15963,26221,37,28,46,FR,France +199219,7,19210,13934,24486,34,25,43,FR,France +199218,7,30273,22605,37941,53,40,66,FR,France +199217,7,19162,14251,24073,34,25,43,FR,France +199216,7,15583,11158,20008,27,19,35,FR,France +199215,7,15473,10723,20223,27,19,35,FR,France +199214,7,14455,10040,18870,25,17,33,FR,France +199213,7,17146,12105,22187,30,21,39,FR,France +199212,7,15838,10923,20753,28,19,37,FR,France +199211,7,20003,13824,26182,35,24,46,FR,France +199210,7,22906,16060,29752,40,28,52,FR,France +199209,7,21824,15687,27961,38,27,49,FR,France +199208,7,15243,10265,20221,27,18,36,FR,France +199207,7,22633,16160,29106,40,29,51,FR,France +199206,7,17009,12219,21799,30,22,38,FR,France +199205,7,15997,11590,20404,28,20,36,FR,France +199204,7,20690,15075,26305,36,26,46,FR,France +199203,7,18586,12684,24488,33,23,43,FR,France +199202,7,16588,10590,22586,29,18,40,FR,France +199201,7,23607,16552,30662,41,29,53,FR,France +199152,7,15184,10392,19976,27,19,35,FR,France +199151,7,15043,10624,19462,26,18,34,FR,France +199150,7,14115,9737,18493,25,17,33,FR,France +199149,7,13304,8548,18060,23,15,31,FR,France +199148,7,15370,10164,20576,27,18,36,FR,France +199147,7,12813,8139,17487,23,15,31,FR,France +199146,7,6453,3123,9783,11,5,17,FR,France +199145,7,8048,4083,12013,14,7,21,FR,France +199144,7,9882,5623,14141,17,10,24,FR,France +199143,7,14307,8645,19969,25,15,35,FR,France +199142,7,6419,3334,9504,11,6,16,FR,France +199141,7,6168,3113,9223,11,6,16,FR,France +199140,7,3615,1159,6071,6,2,10,FR,France +199139,7,3105,472,5738,5,0,10,FR,France +199138,7,4446,1435,7457,8,3,13,FR,France +199137,7,1457,0,3262,3,0,6,FR,France +199136,7,3053,29,6077,5,0,10,FR,France +199135,7,805,0,2556,1,0,4,FR,France +199134,7,5512,856,10168,10,2,18,FR,France +199133,7,7347,2903,11791,13,5,21,FR,France +199132,7,16099,7334,24864,28,13,43,FR,France +199131,7,16803,8145,25461,30,15,45,FR,France +199130,7,15915,6368,25462,28,11,45,FR,France +199129,7,23744,14703,32785,42,26,58,FR,France +199128,7,24222,15617,32827,43,28,58,FR,France +199127,7,20309,12868,27750,36,23,49,FR,France +199126,7,17608,11304,23912,31,20,42,FR,France +199125,7,16169,10700,21638,28,18,38,FR,France +199124,7,16171,10071,22271,28,17,39,FR,France +199123,7,11947,7671,16223,21,13,29,FR,France +199122,7,15452,9953,20951,27,17,37,FR,France +199121,7,14903,8975,20831,26,16,36,FR,France +199120,7,19053,12742,25364,34,23,45,FR,France +199119,7,16739,11246,22232,29,19,39,FR,France +199118,7,21385,13882,28888,38,25,51,FR,France +199117,7,13462,8877,18047,24,16,32,FR,France +199116,7,14857,10068,19646,26,18,34,FR,France +199115,7,13975,9781,18169,25,18,32,FR,France +199114,7,12265,7684,16846,22,14,30,FR,France +199113,7,9567,6041,13093,17,11,23,FR,France +199112,7,10864,7331,14397,19,13,25,FR,France +199111,7,15574,11184,19964,27,19,35,FR,France +199110,7,16643,11372,21914,29,20,38,FR,France +199109,7,13741,8780,18702,24,15,33,FR,France +199108,7,13289,8813,17765,23,15,31,FR,France +199107,7,12337,8077,16597,22,15,29,FR,France +199106,7,10877,7013,14741,19,12,26,FR,France +199105,7,10442,6544,14340,18,11,25,FR,France +199104,7,7913,4563,11263,14,8,20,FR,France +199103,7,15387,10484,20290,27,18,36,FR,France +199102,7,16277,11046,21508,29,20,38,FR,France +199101,7,15565,10271,20859,27,18,36,FR,France +199052,7,19375,13295,25455,34,23,45,FR,France +199051,7,19080,13807,24353,34,25,43,FR,France +199050,7,11079,6660,15498,20,12,28,FR,France +199049,7,1143,0,2610,2,0,5,FR,France -- 2.18.1
