043bd0c9dc66175ab3bf17bb7d5c8a9f
4d51d1e6
4d51d1e6
Lucie Leonarski
commit exo3
112a19fc
2
2 changed files
18 additions
62 deletions
+18
-62
module2/exo1/cosxsx.png
+0
exercice_python_fr.org
module2/exo3/exercice_python_fr.org
+18
-62
View replaced file @
112a19fc
4d51d1e6
21.9 KB
W:
H:
42.5 KB
W:
H:
2-up
Swipe
Onion skin
4d51d1e6
#+TITLE:
Votre titre
#+TITLE:
Plot
#+AUTHOR: Votre nom
#+DATE: La date du jour
@@ -11,59 +11,34 @@
* Quelques explications
document.
data=[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
#+begin_src python :results output file :session :var matplot_lib_filename="/home/lucie/Documents/WORK/MOOC_RR/mooc-rr/module2/exo3/figure1.png" :exports results
print("Hello world!")
x=np.linspace(1,len(data),len(data))
: Hello world!
plt.figure(figsize=(10,5))
plt.plot(x,data,color="blue")
plt.tight_layout()
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
[[file:figure1.png]]
#+begin_src python :results output file :session :var matplot_lib_filename="/home/lucie/Documents/WORK/MOOC_RR/mooc-rr/module2/exo3/figure2.png" :exports results
plt.
plot(x,numpy.cos(x)/x
plt.
hist(data,color="blue",edgecolor='black'
plt.tight_layout()
@@ -71,23 +46,4 @@ print(matplot_lib_filename)
[[file:./cosxsx.png]]
compréhensible sur GitLab.
[[file:figure2.png]]
