modif1
parent 8d58e71b
...@@ -6,7 +6,7 @@ ...@@ -6,7 +6,7 @@
"source": [ "source": [
"# A propos du calcul de $\\pi$\n", "# A propos du calcul de $\\pi$\n",
"\n", "\n",
"## En demandant la lib maths\n", "## En demandant à la lib maths\n",
"\n", "\n",
"Mon ordinateur m'indique que $\\pi$ vaut *approximativement*" "Mon ordinateur m'indique que $\\pi$ vaut *approximativement*"
...@@ -40,7 +40,7 @@ ...@@ -40,7 +40,7 @@
"execution_count": 4, "execution_count": 7,
"outputs": [ "outputs": [
...@@ -49,7 +49,7 @@ ...@@ -49,7 +49,7 @@
"3.128911138923655" "3.128911138923655"
"output_type": "execute_result" "output_type": "execute_result"
...@@ -57,9 +57,9 @@ ...@@ -57,9 +57,9 @@
"import numpy as np\n", "import numpy as np\n",
"np.random.seed(seed=42)\n", "np.random.seed(seed=42)\n",
"N=10000\n", "N = 10000\n",
"x=np.random.uniform(size=N, low=0, high=1)\n", "x = np.random.uniform(size=N, low=0, high=1)\n",
"theta=np.random.uniform(size=N, low=0, high=pi/2)\n", "theta = np.random.uniform(size=N, low=0, high=pi/2)\n",
"2/(sum((x+np.sin(theta))>1)/N)" "2/(sum((x+np.sin(theta))>1)/N)"
