n
parent 76754db1
......@@ -2,7 +2,7 @@
"cells": [
"execution_count": 3,
"execution_count": 15,
......@@ -11,6 +11,7 @@
"Mean: 14.113000000000001\n",
"Standard_variation: 4.312369534258399\n",
"4.31\n",
"Min: 2.8\n",
"Median: 14.5\n",
"Max: 23.4\n"
......@@ -21,23 +22,88 @@
"import numpy as np\n",
"import pandas as pd\n",
"#input dataset\n",
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,\n",
" 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2,\n",
" 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0,\n",
" 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6,\n",
" 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3,\n",
" 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2,\n",
" 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"#convert to array\n",
"data_1 = np.array(data)\n",
"#mean\n",
"print(\"Mean:\", np.mean(data))\n",
"print(\"Mean:\", np.mean(data_1))\n",
"#standard_variation\n",
"print(\"Standard_variation:\", np.std(data))\n",
"print(\"Standard_variation:\", np.std(data_1))\n",
"a = round(np.std(data_1),2)\n",
"print(a)\n",
"#minimum\n",
"print(\"Min:\", np.min(data))\n",
"print(\"Min:\", np.min(data_1))\n",
"#median\n",
"print(\"Median:\", np.median(data))\n",
"print(\"Median:\", np.median(data_1))\n",
"#maximum\n",
"print(\"Max:\", np.max(data))"
"print(\"Max:\", np.max(data_1))"
"execution_count": 8,
"Standard Deviation: 4.312369534258399\n",
"Minimum: 2.8\n",
"Median: 14.5\n",
"Maximum: 23.4\n"
"# Input the dataset\n",
"# Convert to a numpy array\n",
"np_data = np.array(data)\n",
"# Compute the mean\n",
"mean_value = np.mean(np_data)\n",
"print(f\"Mean: {mean_value}\")\n",
"# Compute the standard deviation\n",
"std_deviation = np.std(np_data)\n",
"print(f\"Standard Deviation: {std_deviation}\")\n",
"# Compute the minimum\n",
"min_value = np.min(np_data)\n",
"print(f\"Minimum: {min_value}\")\n",
"# Compute the median\n",
"median_value = np.median(np_data)\n",
"print(f\"Median: {median_value}\")\n",
"# Compute the maximum\n",
"max_value = np.max(np_data)\n",
"print(f\"Maximum: {max_value}\")\n"
