Update toy_document_en.Rmd
parent e391755a
title: "Your title"
author: "Your name"
date: "Today's date"
title: "On the computation of pi"
author: "Lijuan Ren"
date: "20 Sept 2021"
output: html_document
## Asking the maths library
pi
## [1] 3.141593
```{r setup, include=FALSE}
## Some explanations
## Buffon’s needle
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
## Using a surface fraction argument
set.seed(42)
N = 1000
library(ggplot2)
4*mean(df$Accept)
```{r pressure, echo=FALSE}
plot(pressure)
