35dce1f9
35dce1f9
Try to improve portability and run bibtex.
ecf65b27
6 additions
5 deletions
+6
-5
article.org
module2/ressources/replicable_article/article.org
+6
-5
35dce1f9
@@ -227,14 +227,15 @@ our own experimental testbed with support of our university.
# Local Variables:
# eval: (add-to-list 'load-path ".")
# eval: (require 'org-install)
# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (python . t) ))
# eval: (org-babel-do-load-languages 'org-babel-load-languages '((R . t) (python . t) ))
# eval: (setq org-babel-python-command (if (memq system-type '(windows-nt ms-dos)) "Python" "python3"))
# eval: (require 'ess-site)
# eval: (setq org-confirm-babel-evaluate nil)
# eval: (unless (boundp 'org-latex-classes) (setq org-latex-classes nil))
# eval: (add-to-list 'org-latex-classes '("IEEEtran"
# "\\documentclass[conference, 10pt
, compsocconf
]{IEEEtran}\n \[NO-DEFAULT-PACKAGES]\n \[EXTRA]\n \\usepackage{graphicx}\n \\usepackage{hyperref}" ("\\section{%s}" . "\\section*{%s}") ("\\subsection{%s}" . "\\subsection*{%s}") ("\\subsubsection{%s}" . "\\subsubsection*{%s}") ("\\paragraph{%s}" . "\\paragraph*{%s}") ("\\subparagraph{%s}" . "\\subparagraph*{%s}")))
# "\\documentclass[conference, 10pt]{IEEEtran}\n \[NO-DEFAULT-PACKAGES]\n \[EXTRA]\n \\usepackage{graphicx}\n \\usepackage{hyperref}" ("\\section{%s}" . "\\section*{%s}") ("\\subsection{%s}" . "\\subsection*{%s}") ("\\subsubsection{%s}" . "\\subsubsection*{%s}") ("\\paragraph{%s}" . "\\paragraph*{%s}") ("\\subparagraph{%s}" . "\\subparagraph*{%s}")))
# eval: (setq org-alphabetical-lists t)
# eval: (setq org-src-fontify-natively t)
# eval: (setq ess-ask-for-ess-directory nil)
# eval: (setq org-latex-pdf-process '("%latex -interaction nonstopmode -output-directory %o %f" "bibtex %b" "%latex -interaction nonstopmode -output-directory %o %f" "%latex -interaction nonstopmode -output-directory %o %f"))
# End:
