388ab714
388ab714
Benoit will take care of this (or not)
91dec995
2
2 changed files
49 additions
79 deletions
+49
-79
jupyter.html
module2/ressources/jupyter.html
+46
-66
jupyter.org
module2/ressources/jupyter.org
+3
-13
388ab714
@@ -4,54 +4,34 @@
<h2>
Table of Contents
</h2>
<div
id=
"text-table-of-contents"
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#orgaa631f0"
Interacting with gitlab
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#orgc0bede2"
Additional Jupyter resources or tricks
</a>
<li
style=
"margin-bottom:0;"
><a
href=
"#org975cdde"
</a>
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#org
a0a8c0a
Tips and tricks
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
cc5df2c
Running R and Python in the same notebook
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
50f9d65
Exporting a notebook
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
27d1582
Tips and tricks
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
4f5f0e8
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
6e2f783
</a></li>
</ul>
</li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
9ad15fe"
Installing jupyter or jupyter hub
on your own machine
</a>
<li
style=
"margin-bottom:0;"
><a
href=
"#org
75409e5"
Installing Jupyter
on your own machine
</a>
<ul
style=
"margin:0 0;"
<li
style=
"margin-bottom:0;"
><a
href=
"#org3c82116"
Installing jupyter
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org41613aa"
Using R
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#orgeebc12b"
Exporting your notebooks with latex
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#orgf4f33c6"
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#orgd30b2c8"
Interesting extensions to improve notebook readability
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org883d82c"
Installing jupyterhub
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org73474e0"
Installing jupyter
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org5dcb2d4"
Using R
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org919a045"
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org3bdebfb"
</a></li>
<li
style=
"margin-bottom:0;"
><a
href=
"#orgee218a0"
</a></li>
</ul>
</li>
<li
style=
"margin-bottom:0;"
><a
href=
"#org4ee7491"
Installing JupyterHub
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</span></span></a></li>
</ul>
</div>
</div>
<div
id=
"outline-container-orgaa631f0"
class=
"outline-2"
<h2
id=
"orgaa631f0"
</h2>
<div
class=
"outline-text-2"
id=
"text-orgaa631f0"
<blockquote>
<p>
This section needs some love.
</p>
</blockquote>
<p>
As you may have seen from the videos, we provide two buttons to sync
with gitlab. Indeed, even if you recover your files when you log back
into fun, the jupyter runs on a different machine than the gitlab
server and you need to commit your notebook every time you have made a
significant step. This is also the only way to really make it public
and to share your notebook with others.
</p>
</div>
</div>
<div
id=
"outline-container-orgc0bede2"
class=
"outline-2"
<h2
id=
"orgc0bede2"
</h2>
<div
class=
"outline-text-2"
id=
"text-orgc0bede2"
<div
id=
"outline-container-org975cdde"
class=
"outline-2"
<h2
id=
"org975cdde"
</h2>
<div
class=
"outline-text-2"
id=
"text-org975cdde"
</div>
<div
id=
a0a8c0a
class=
"outline-3"
<h3
id=
"org
a0a8c0a
Tips and tricks
</h3>
<div
class=
"outline-text-3"
id=
"text-org
a0a8c0a
<div
id=
27d1582
class=
"outline-3"
<h3
id=
"org
27d1582
Tips and tricks
</h3>
<div
class=
"outline-text-3"
id=
"text-org
27d1582
<p>
The following
<a
href=
"https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/"
webpage
</a>
lists several Jupyter tricks (in particular, it
illustrates many
<code>
Ipython magic
</code>
commands) that should improve your
@@ -61,9 +41,9 @@ now).
</p>
</div>
</div>
<div
id=
cc5df2c
class=
"outline-3"
<h3
id=
"org
cc5df2c
</h3>
<div
class=
"outline-text-3"
id=
"text-org
cc5df2c
<div
id=
4f5f0e8
class=
"outline-3"
<h3
id=
"org
4f5f0e8
</h3>
<div
class=
"outline-text-3"
id=
"text-org
4f5f0e8
<p>
The best solution to this is to install rpy2. On my machine, I have
installed the
<code>
python3-rpy2
</code>
debian package with
<code>
apt-get install
</code>
. An
@@ -105,9 +85,9 @@ plot((df)
</ol>
</div>
</div>
<div
id=
50f9d65
class=
"outline-3"
<h3
id=
"org
50f9d65
</h3>
<div
class=
"outline-text-3"
id=
"text-org
50f9d65
<div
id=
6e2f783
class=
"outline-3"
<h3
id=
"org
6e2f783
</h3>
<div
class=
"outline-text-3"
id=
"text-org
6e2f783
<p>
Obviously, you can convert to html or pdf using the using the
<code>
File
Download as
HTML
</code>
(or
<code>
PDF
</code>
) menu option. This can also be done from
@@ -134,13 +114,13 @@ taste.
</div>
</div>
</div>
<div
id=
9ad15fe
class=
"outline-2"
<h2
id=
"org
9ad15fe"
on your own machine
</h2>
<div
class=
"outline-text-2"
id=
"text-org
9ad15fe
<div
id=
75409e5
class=
"outline-2"
<h2
id=
"org
75409e5"
Installing Jupyter
on your own machine
</h2>
<div
class=
"outline-text-2"
id=
"text-org
75409e5
</div>
<div
id=
3c82116
class=
"outline-3"
<h3
id=
"org
3c82116
Installing jupyter
</h3>
<div
class=
"outline-text-3"
id=
"text-org
3c82116
<div
id=
73474e0
class=
"outline-3"
<h3
id=
"org
73474e0
Installing jupyter
</h3>
<div
class=
"outline-text-3"
id=
"text-org
73474e0
<p>
Here is what you should install:
</p>
@@ -171,16 +151,16 @@ The ipython notebook can then be run with the following command:
</div>
</div>
</div>
<div
id=
41613aa
class=
"outline-3"
<h3
id=
"org
41613aa
Using R
</h3>
<div
class=
"outline-text-3"
id=
"text-org
41613aa
<div
id=
5dcb2d4
class=
"outline-3"
<h3
id=
"org
5dcb2d4
Using R
</h3>
<div
class=
"outline-text-3"
id=
"text-org
5dcb2d4
<p>
If you also want to have the R kernel in jupyter, follow
<a
href=
"https://github.com/IRkernel/IRkernel#installation"
these
instructions
</a>
</p>
<p>
Alternatively, you can install
<code>
rpy2
</code>
(see the
<a
href=
"#org
cc5df2c
<code>
rpy2
</code>
(see the
<a
href=
"#org
4f5f0e8
the same notebook
</a>
section).
</p>
<div
class=
"org-src-container"
@@ -189,9 +169,9 @@ the same notebook</a> section).
</div>
</div>
</div>
<div
id=
eebc12b
class=
"outline-3"
<h3
id=
"org
eebc12b
</h3>
<div
class=
"outline-text-3"
id=
"text-org
eebc12b
<div
id=
919a045
class=
"outline-3"
<h3
id=
"org
919a045
</h3>
<div
class=
"outline-text-3"
id=
"text-org
919a045
<p>
Here is what I had to install to make sure the notebook export via
latex works:
@@ -203,9 +183,9 @@ sudo apt-get install texlive-xetex
</div>
</div>
</div>
<div
id=
f4f33c6
class=
"outline-3"
<h3
id=
"org
f4f33c6
</h3>
<div
class=
"outline-text-3"
id=
"text-org
f4f33c6
<div
id=
3bdebfb
class=
"outline-3"
<h3
id=
"org
3bdebfb
</h3>
<div
class=
"outline-text-3"
id=
"text-org
3bdebfb
<p>
Here is our
<a
href=
"https://github.com/brospars/nb-git"
jupyter extension that allows to git push/pull from the
notebooks
</a>
@@ -217,9 +197,9 @@ jupyter nbextension enable nb-git
</div>
</div>
</div>
<div
id=
d30b2c8
class=
"outline-3"
<h3
id=
"org
d30b2c8
</h3>
<div
class=
"outline-text-3"
id=
"text-org
d30b2c8
<div
id=
ee218a0
class=
"outline-3"
<h3
id=
"org
ee218a0
</h3>
<div
class=
"outline-text-3"
id=
"text-org
ee218a0
<p>
Here are two interesting extensions that can improve readability:
</p>
@@ -245,9 +225,10 @@ jupyter-serverextension enable --py hide_code
</ul>
</div>
</div>
<div
id=
"outline-container-org883d82c"
class=
"outline-3"
<h3
id=
"org883d82c"
</h3>
<div
class=
"outline-text-3"
id=
"text-org883d82c"
</div>
<div
id=
"outline-container-org4ee7491"
class=
"outline-2"
<h2
id=
"org4ee7491"
<span
class=
"tag"
><span
class=
"Benoit"
Benoit
</span></span></h2>
<div
class=
"outline-text-2"
id=
"text-org4ee7491"
<blockquote>
<p>
Benoit may give a few hints on this.
@@ -256,4 +237,3 @@ Benoit may give a few hints on this.
</div>
</div>
</div>
</div>
388ab714
@@ -4,18 +4,8 @@
#+DATE: June, 2018
#+STARTUP: overview indent
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
* Interacting with gitlab
#+BEGIN_QUOTE
#+END_QUOTE
* Additional Jupyter resources or tricks
** Tips and tricks
The following [[https://www.dataquest.io/blog/jupyter-notebook-tips-tricks-shortcuts/][webpage]] lists several Jupyter tricks (in particular, it
@@ -64,7 +54,7 @@ Instead of going directly through LaTeX and playing too much with the
nbconvert exporter, an other option consists in exporting to Markdown
and playing with [[https://pandoc.org/][pandoc]]. Both approaches work, it's rather a matter of
taste.
* Installing
on your own machine
* Installing
Jupyter
on your own machine
** Installing jupyter
@@ -120,7 +110,7 @@ Here are two interesting extensions that can improve readability:
jupyter-nbextension enable --py hide_code
* Installing jupyterhub
Installing JupyterHub :Benoit:
#+BEGIN_QUOTE
#+END_QUOTE
