57d0e5ff
57d0e5ff
Konrad Hinsen
Debut d'un tutoriel pour snakemake
5b4af3a7
8
8 changed files
172 additions
2 deletions
+172
-2
.gitignore
.gitignore
+3
-1
Makefile
Makefile
+1
-1
Snakefile
...ressources/incidence_syndrome_grippal_snakemake/Snakefile
+39
annual-incidence-histogram.R
...me_grippal_snakemake/scripts/annual-incidence-histogram.R
+11
annual-incidence.R
...nce_syndrome_grippal_snakemake/scripts/annual-incidence.R
+23
incidence-plots.R
...ence_syndrome_grippal_snakemake/scripts/incidence-plots.R
+14
preprocess.py
...ncidence_syndrome_grippal_snakemake/scripts/preprocess.py
+68
snakemake_tutorial_fr.org
module6/ressources/snakemake_tutorial_fr.org
+13
.gitignore
57d0e5ff
@@ -10,3 +10,5 @@
@@ -10,3 +10,5 @@
_minted*
_minted*
svg-inkscape*
svg-inkscape*
*-svg.pdf
*-svg.pdf
.Rhistory
.snakemake
Makefile
57d0e5ff
ressources-md
ressources-md
for
i
in
module1/ressources module2/ressources module2/slides module3/ressources
for
i
in
module4/ressources module5/ressources
do
module6/ressources
do
make
-C
i ressources-md
make
-C
i ressources-md
done
done
module6/ressources/incidence_syndrome_grippal_snakemake/Snakefile
57d0e5ff
rule download:
output:
"data/weekly-incidence.csv"
shell:
"wget -O {output} http://www.sentiweb.fr/datasets/incidence-PAY-3.csv"
rule preprocess:
input:
output:
data="data/preprocessed-weekly-incidence.csv",
errorlog="data/errors-from-preprocessing.csv"
script:
"scripts/preprocess.py"
rule plot:
input:
output:
"data/weekly-incidence-plot.png",
"data/weekly-incidence-plot-last-years.png"
script:
"scripts/incidence-plots.R"
rule annual_incidence:
input:
output:
"data/annual-incidence.csv"
script:
"scripts/annual-incidence.R"
rule histogram:
input:
output:
"data/annual-incidence-histogram.png"
script:
"scripts/annual-incidence-histogram.R"
module6/ressources/incidence_syndrome_grippal_snakemake/scripts/annual-incidence-histogram.R
57d0e5ff
# Read in the data and convert the dates
read.csv
snakemake
input
# Plot the histogram
png
filename
snakemake
output
hist
incidence
breaks
10
xlab
"Annual incidence"
ylab
"Number of observations"
main
dev.off
module6/ressources/incidence_syndrome_grippal_snakemake/scripts/annual-incidence.R
57d0e5ff
read.csv
snakemake
input
names
c
"date"
"incidence"
date
as.Date
date
# A function that extracts the peak for year N
yearly_peak
function
year
start
paste0
year
-1
"-08-01"
paste0
year
"-08-01"
records
date
start
date
sum
incidence
records
# The years for which we have the full peak
years
1986
2018
# Make a new data frame for the annual incidences
annual_data
data.frame
year
years
incidence
sapply
years
yearly_peak
# write output file
write.csv
annual_data
file
snakemake
output
row.names
FALSE
module6/ressources/incidence_syndrome_grippal_snakemake/scripts/incidence-plots.R
57d0e5ff
read.csv
snakemake
input
names
c
"date"
"incidence"
date
as.Date
date
# Plot the complete incidence dataset
png
filename
snakemake
output
plot
type
"l"
xlab
"Date"
ylab
"Weekly incidence"
dev.off
# Zoom on the last four years
png
filename
snakemake
output
2
plot
tail
4
52
type
"l"
xlab
"Date"
ylab
"Weekly incidence"
dev.off
module6/ressources/incidence_syndrome_grippal_snakemake/scripts/preprocess.py
57d0e5ff
# Libraries used by this script:
import
datetime
# for date conversion
import
csv
# for writing output to a CSV file
# Read the CSV file into memory
open
snakemake
input
'rb'
read
# Decode the Latin-1 character set,
# remove white space at both ends,
# and split into lines.
lines
decode
'latin-1'
strip
split
\n
# Discard the first line, which contains a comment
data_lines
lines
# Split each line into columns
table
line
split
for
line
in
data_lines
# Remove records with missing data and write
# the removed records to a separate file for inspection.
open
snakemake
output
errorlog
"w"
as
errorlog
valid_table
for
row
in
table
missing
any
column
for
column
in
row
if
missing
errorlog
write
"Missing data in record
\n
errorlog
write
str
row
errorlog
write
\n
else
valid_table
append
row
# Extract the two relevant columns, "week" and "inc"
week
row
for
row
in
valid_table
assert
week
'week'
del
week
inc
row
2
for
row
in
valid_table
assert
inc
'inc'
del
inc
list
zip
week
inc
# Check for obviously out-of-range values
open
snakemake
output
errorlog
"a"
as
errorlog
for
week
inc
in
if
len
week
6
not
week
isdigit
errorlog
write
"Suspect value in column 'week': {week}
\n
if
not
inc
isdigit
errorlog
write
"Suspect value in column 'inc': {inc}
\n
# Convert year/week by date of the corresponding Monday,
# then sort by increasing date
converted_data
datetime
datetime
strptime
year_and_week
":1"
G
V:
u'
date
inc
for
year_and_week
inc
in
converted_data
sort
key
lambda
record
record
# Check that consecutive dates are seven days apart
open
snakemake
output
errorlog
"a"
as
errorlog
dates
date
for
date
_
in
converted_data
for
date1
date2
in
zip
dates
dates
if
date2
date1
datetime
timedelta
weeks
errorlog
write
f
"{date2-date1} between {date1} and {date2}
\n
# Write data to a CSV file with two columns:
# 1. the date of the Monday of each week, in ISO format
# 2. the incidence estimate for that week
open
snakemake
output
"w"
as
csvfile
csv_writer
csv
writer
csvfile
for
row
in
converted_data
csv_writer
writerow
row
57d0e5ff
# -*- mode: org -*-
#+TITLE: Gérer un workflow avec snakemake
#+DATE: August, 2019
#+STARTUP: overview indent
#+OPTIONS: num:nil toc:t
#+PROPERTY: header-args :eval never-export
* Installer snakemake
TODO
* L'analyse de l'incidence du syndrome grippal revisitée
Nous allons reprendre l'exemple du module 3, l'analyse de l'incidence du syndrome grippal.
** 1ère étape: le téléchargement des données
