2763f6885913bcde7101695b876ccdbe
8663c42c
8663c42c
Jamal KHAN
Fix formatting
d94f86b8
12 additions
12 deletions
+12
-12
toy_document_orgmode_R_en.org
module2/exo1/toy_document_orgmode_R_en.org
+12
-12
8663c42c
@@ -12,7 +12,7 @@
* Asking the maths library
My computer tells me that
\pi is approximattively
$\pi$ is /approximatively/
pi
@@ -20,9 +20,9 @@ pi
: [1] 3.141593
* Buffon
s needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon
's_needle_problem][Buffon's needle]], we get the **approximation*
both
* Buffon
s needle
%2527s_needle_problem][Buffon's needle]] we get the *approximation
results
set.seed(42)
N = 100000
x = runif(N)
@@ -31,15 +31,15 @@ theta = pi/2*runif(N)
: [1] 3.14327
* Using a surface fraction argument
A method that is easier to understand and does not make use of the sin
function is based on the fact that if $X\simU(0,1)$ and $Y\simU(0,1)$, then
$P[X^2+Y^2 \le1]=\pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The
following code uses this approach:
#+begin_src R :results output graphics :file (org-babel-temp-file "figure" ".png") :exports both :width 600 :height 400 :session *R*
$\sin$ function is based on the fact that if $X\simU(0,1)$ and
$Y\simU(0,1)$, then $P[X^2+Y^2 \le1]=\pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on
Wikipedia]]). The following code uses this approach:
#+begin_src R :results output graphics :file figure_pi_mc1.png :exports both :width 600 :height 400 :session *R*
set.seed(42)
N = 1000
@@ -49,10 +49,10 @@ ggplot(df, aes(x=X, y=Y, color=Accept)) + geom_point(alpha=.2) + coord_fixed() +
[[file:
/tmp/babel-9oTMJE/figure0FnJcH
.png]]
[[file:
figure_pi_mc1
.png]]
It is then straightforward to obtain a (not really good) approximation
to \pi by counting how many times, on average, $X^2
+Y^2$
is smaller than 1:
+ Y^2$
is smaller than 1:
4*mean(df$Accept)
