Commit ef2cd9b9 authored by Jamal KHAN's avatar Jamal KHAN
Update format fix
parent 3899f757
...@@ -10,7 +10,7 @@ ...@@ -10,7 +10,7 @@
#+PROPERTY: header-args :session :exports both #+PROPERTY: header-args :session :exports both
* Asking the maths library * Asking the math library
My computer tells me that $\pi$ is /approximatively/ My computer tells me that $\pi$ is /approximatively/
#+begin_src python :results value :session *python* :exports both #+begin_src python :results value :session *python* :exports both
...@@ -18,28 +18,22 @@ from math import * ...@@ -18,28 +18,22 @@ from math import *
pi pi
#+end_src #+end_src
: 3.141592653589793
* Buffon's needle * Buffon's needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]], we get the *approximation* Applying the method of [[https://en.wikipedia.org/wiki/Buffon%2527s_needle_problem][Buffon's needle]], we get the *approximation*
import numpy as np import numpy as np
np.random.seed(seed=42) np.random.seed(seed=42)
N = 1000 N = 10000
x = np.random.uniform(size=N, low=0, high=1) x = np.random.uniform(size=N, low=0, high=1)
theta = np.random.uniform(size=N, low=0, high=pi/2) theta = np.random.uniform(size=N, low=0, high=pi/2)
2/(sum((x+np.sin(theta))>1)/N) 2/(sum((x+np.sin(theta))>1)/N)
#+end_src #+end_src
: 3.144654088050314
* Using a surface fraction argument * Using a surface fraction argument
A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\simU(0,1)$ and $Y\simU(0,1)$, then $P[X^2+Y^2 \le1]=\pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach: A method that is easier to understand and does not make use of the $\sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X^2+Y^2\le 1]=\pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo method" on Wikipedia]]). The following code uses this approach:
#+begin_src python :results output :session *python* :var matplot_lib_filename="figure_pi_mc2.png" :exports both #+begin_src python :results output file :var matplot_lib_filename="figure_pi_mc2.png" :exports both :session *python*
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
...@@ -59,14 +53,8 @@ plt.savefig(matplot_lib_filename) ...@@ -59,14 +53,8 @@ plt.savefig(matplot_lib_filename)
print(matplot_lib_filename) print(matplot_lib_filename)
#+end_src #+end_src
: figure_pi_mc2.png
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1: It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1:
#+begin_src python :results value :session *python* :exports both #+begin_src python :results output :session *python* :exports both
4*np.mean(accept) 4*np.mean(accept)
#+end_src #+end_src
: 3.112
