Restored previous version
parent fd7b540d
# On the computation of $\pi$
## Asking the maths library
My computer tells me that $\pi$ is _approximatively_
```python
from math import *
print(pi)
3.141592653589793
## Buffon’s needle
Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__
```python
np.random.seed(seed=42)
N = 10000
2/(sum((x+np.sin(theta))>1)/N)
3.128911138923655
## Using a surface fraction argument
A method that is easier to understand and does not make use of the sin function is based on the
fact that if $X\sim U(0, 1)$ and $Y\sim U(0, 1)$, then $P[X^2 + Y^2\le 1] = \pi/4$ (see ["Monte Carlo method"
on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
```python
%matplotlib inline
N = 1000
accept = (x*x+y*y) <= 1
fig, ax = plt.subplots(1)
ax.set_aspect('equal')
![png](output_6_0.png)
It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how
many times, on average, $X^2 + Y^2$ is smaller than 1:
```python
4*np.mean(accept)
3.112
"cells": [],
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"nbformat": 4,
"nbformat_minor": 2
\ No newline at end of file
