moy <- mean(valeurs)
print(moy)
## Écart-type
```{r pressure, echo=FALSE}
ecart <- sd(valeurs)
plot(pressure)
print(ecart)
## Min
mini <- min(valeurs)
print(mini)
## Médiane
median <- median(valeurs)
print(median)
## Max
maxi <- max(valeurs)
print(maxi)
