2f72555a2613970ebb90637b2e23f177
c20f962a
c20f962a
Upload exercice 4_1 done with RStudio
306ef997
120 additions
+120
exercices_module4_1.Rmd
module4/exercices_module4_1.Rmd
+120
c20f962a
title: "exercices_module4_1"
author: "Jerome Riera"
date: "2024-08-31"
output:
pdf_document: default
html_document: default
```{r setup, include=FALSE}
## R version
library(ggplot2)
sessionInfo()
## Installed libraries
library(usethis)
library(devtools)
devtools :: session_info()
## Loading data
data_full<-read.csv("/Users/jeromeriera/Library/Mobile Documents/com~apple~CloudDocs/Thèse/MOOC RR/mooc rr/module2/exo5/shuttle.csv", header = TRUE)
### Data inspection
plot(data=data_full, Malfunction/Count ~Temperature, ylim=c(0,1))
### Logistic regression
logistic_reg=glm(data=data_full, Malfunction/Count ~ Temperature, weights=Count, family = binomial(link = "logit"))
summary(logistic_reg)
**Results of Dalal *et al.* have successfully been replicated here.**
### Predicitng failure probability
# shuttle=shuttle[shuttle$r!=0,]
tempv=seq(from=30, to=90, by=.5)
rmv <- predict(logistic_reg, list(Temperature=tempv), type='response')
plot(tempv, rmv, type = 'l', ylim=c(0,1))
points(data=data_full, Malfunction/Count ~Temperature)
**Figure 4 od Dalal *et al* have successfully been replicated.**
### Confidence of the prediction
ggplot(data_full, aes(y=Malfunction/Count, x=Temperature)) + geom_point(alpha=.2, size = 2, color='blue') + geom_smooth(method='glm', method.args = list(family='binomial'), fullrange=T) + xlim(30,90) + ylim(0,1) + theme_bw()
Same warning as in the example. Let's provide the raw data to ggplot2
data_flat=data.frame()
for(i in 1:nrow(data_full)) {
temperature=data_full[i, 'Temperature'];
malfunction=data_full[i,'Malfunction'];
d = data.frame(Temperature=temperature, Malfunction=rep(0, times=data_full[i,'Count']))
if(malfunction>0) {
d[1:malfunction, 'Malfunction']=1;
data_flat=rbind(data_flat,d)
dim(data_flat)
str(data_flat)
computation of the regression
logistic_reg_flat=glm(data = data_flat, Malfunction~Temperature, family=binomial(link = 'logit'))
summary(logistic_reg_flat)
Residual deviance is different now. Let's plot it again
ggplot(data = data_flat, aes(y=Malfunction, x=Temperature))+
geom_smooth(method = 'glm', method.args=list(family='binomial'), fullrange = T)+
geom_point(data=data_full, aes(y=Malfunction/Count, x=Temperature), alpha =.2, size=2, color='blue')+
geom_point(alpha=.5, size=.5)+
xlim(30,90)+ylim(0,1)+theme_bw()
Comparison with the direct prediction
pred=predict(logistic_reg_flat, list(Temperature=30), type = 'response', se.fit = T)
pred
pred_link=predict(logistic_reg_flat, list(Temperature=30), type = 'link', se.fit = T)
pred_link
logistic_reg$family$linkinv(pred_link$fit)
critval=1.96
logistic_reg$family$linkinv(c(pred_link$fit-critval*pred_link$se.fit,
pred_link$fit+critval*pred_link$se.fit))
This confident interval correspond to what we can observe with ggplot2.
**Very interesting exercise for me. It overwhelmed my statistical and R knowledge a bit, but I managed to learn a lot while trying to understand what has been done here **
\ No newline at end of file
