Commit 48e56cd5 authored by amarell's avatar amarell
Added calculation of summary statistics to module2/exo2/exercice_en.Rmd
parent 87c91ec4
title: "Your title"
author: "Your name"
date: "Today's date"
title: "Exercice 02 (2nd part)"
author: "Anders Mårell"
date: "2023-06-09"
output: html_document
editor_options:
chunk_output_type: console
......@@ -10,24 +12,42 @@ output: html_document
## Some explanations
# Doing a simple calculation on your own
Compute the mean and the standard variation, the minimum, the median, and the maximum of the following data set:
x <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
We now calculate the mean:
mean(x)
We now calculate the standard deviation:
sd(x)
We now calculate the min:
```{r pressure, echo=FALSE}
plot(pressure)
min(x)
We now calculate the median:
median(x)
We now calculate the max:
max(x)
We can also use summary:
summary(x)
