Commit b4d52d43 authored by amarell's avatar amarell
Correction module2/exo1/toy_document_en.Rmd
parent 8bea253a
...@@ -5,20 +5,19 @@ date: "25 juin 2018" ...@@ -5,20 +5,19 @@ date: "25 juin 2018"
# Asking the maths library ## Asking the maths library
My computer tells me that $\pi$ is approximatively My computer tells me that $\pi$ is *approximatively*
```{r} ```{r}
pi pi
# Buffon’s needle ## Buffon's needle
Applying the method of [Buffon’s needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the **approximation** Applying the method of [Buffon's needle](https://en.wikipedia.org/wiki/Buffon%27s_needle_problem), we get the __approximation__
```{r} ```{r}
set.seed(42) set.seed(42)
...@@ -28,8 +27,8 @@ theta = pi/2*runif(N) ...@@ -28,8 +27,8 @@ theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1)) 2/(mean(x+sin(theta)>1))
# Using a surface fraction argument ## Using a surface fraction argument
A method that is easier to understand and does not make use of the $sin$ function is based on the fact that if $X∼U(0,1)$ and $Y∼U(0,1)$, then $P[X2+Y2≤1]=\pi/4$ (see [“Monte Carlo method” on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach: A method that is easier to understand and does not make use of the $sin$ function is based on the fact that if $X\sim U(0,1)$ and $Y\sim U(0,1)$, then $P[X2+Y2\leq 1]= \pi/4$ (see ["Monte Carlo method" on Wikipedia](https://en.wikipedia.org/wiki/Monte_Carlo_method)). The following code uses this approach:
```{r} ```{r}
...@@ -40,8 +39,9 @@ library(ggplot2) ...@@ -40,8 +39,9 @@ library(ggplot2)
ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw() ggplot(df, aes(x=X,y=Y,color=Accept)) + geom_point(alpha=.2) + coord_fixed() + theme_bw()
It is therefore straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2+Y^2$ is smaller than 1 : It is then straightforward to obtain a (not really good) approximation to $\pi$ by counting how many times, on average, $X^2 + Y^2$ is smaller than 1 :
```{r} ```{r}
4*mean(df$Accept) 4*mean(df$Accept)
