39781cc7cca0dc30af9d6060ede9947c
3e91a689
3e91a689
Précisions sur les IC (avec nouveau code séparé pour essai)
67b34b0d
2
2 changed files
123 additions
76 deletions
+123
-76
Essai_CI_band.ipynb
module3/exo3/Essai_CI_band.ipynb
+6
exercice.ipynb
module3/exo3/exercice.ipynb
+117
-76
3e91a689
"cells": [],
"nbformat": 4,
"nbformat_minor": 4
3e91a689
@@ -385,7 +385,7 @@
"execution_count": 5,
"hideCode":
fals
e,
"hideCode":
tru
e,
"hidePrompt": true
@@ -492,11 +492,11 @@
"Requirement already satisfied: lmfit in /opt/conda/lib/python3.6/site-packages (1.0.0)\n",
scipy>=1.2 in /opt/conda/lib/python3.6/site-packages (from lmfit) (1.4.1)
\n",
uncertainties>=3.0.1 in /opt/conda/lib/python3.6/site-packages (from lmfit) (3.1.2)
\n",
numpy>=1.16 in /opt/conda/lib/python3.6/site-packages (from lmfit) (1.18.2)
\n",
asteval>=0.9.16 in /opt/conda/lib/python3.6/site-packages (from lmfit) (0.9.18)
\n"
r\
n",
asteval>=0.9.16 in /opt/conda/lib/python3.6/site-packages (from lmfit) (0.9.18)\r
\n",
numpy>=1.16 in /opt/conda/lib/python3.6/site-packages (from lmfit) (1.18.2)\r
\n",
scipy>=1.2 in /opt/conda/lib/python3.6/site-packages (from lmfit) (1.4.1)\r
\n",
uncertainties>=3.0.1 in /opt/conda/lib/python3.6/site-packages (from lmfit) (3.1.2)\r
\n"
@@ -516,6 +516,7 @@
"# Import des librairies\n",
"from lmfit.models import QuadraticModel, Model\n",
"import lmfit\n",
"from sklearn.metrics import r2_score"
@@ -567,41 +568,58 @@
"execution_count": 11,
"execution_count": 37,
"hideCode": false,
"hideOutput": true,
"hidePrompt": true
"# Mise en dictionnaire des meilleures paramètres calculés\n",
"coeffs_long_trend = result_long_trend.params.valuesdict() "
"execution_count": 12,
"hideCode": true,
"hidePrompt": true
"OrderedDict([('a', 0.012977452801551667),\n",
" ('b', 0.7677869942992783),\n",
" ('c', 314.5704951470056)])"
"[[Variables]]\n",
" a: 0.01297745 +/- 1.4176e-04 (1.09%) (init = 0.01297745)\n",
" b: 0.76778699 +/- 0.00913468 (1.19%) (init = 0.767787)\n",
" c: 314.570495 +/- 0.12419930 (0.04%) (init = 314.5705)\n",
"[[Correlations]] (unreported correlations are < 0.100)\n",
" C(a, b) = -0.969\n",
" C(b, c) = -0.873\n",
" C(a, c) = 0.756\n"
"# Affichage des meilleures paramètres calculés\n",
"coeffs_long_trend = result_long_trend.params.valuesdict()\n",
"coeffs_long_trend "
"#Affichage des meilleures paramètres calculés avec les intervalles de confiances\n",
"print(lmfit.fit_report(result_long_trend.params))"
"hideCode": false,
"hidePrompt": true
"Ci-dessus, les différents paramètres de la courbe d'ajustement à long terme (fonction quadratique)."
2
3
"hideCode": false,
"hidePrompt": true
@@ -618,7 +636,7 @@
3
4
"hideCode": false,
"hidePrompt": true
@@ -631,7 +649,7 @@
4
5
"hideCode": false,
"hidePrompt": true
@@ -643,7 +661,7 @@
"0.9936252499490063"
4
5
@@ -666,9 +684,9 @@
5
6
"hideCode":
tru
e,
"hideCode":
fals
e,
"hidePrompt": true
@@ -714,6 +732,16 @@
"fig.tight_layout()"
"hidePrompt": true
"L'intervalle de confiance de la courbe ajustée n'est pas tracée sur les graphes précédents car il est très etroit. \n",
"Celui-ci dégraderait la lisibilité des graphiques."
@@ -736,7 +764,7 @@
6
7
"hideCode": false,
"hidePrompt": true
@@ -749,7 +777,7 @@
7
8
"hideCode": true,
"hidePrompt": true
@@ -758,10 +786,10 @@
"<matplotlib.axes._subplots.AxesSubplot at 0x7f
4bee2fec88
a3f4fdc5c0
7
8
@@ -810,7 +838,7 @@
8
9
"hidePrompt": true
@@ -823,7 +851,7 @@
"execution_count":
19
"execution_count":
20
"hidePrompt": true
@@ -838,28 +866,38 @@
"execution_count": 20,
"execution_count": 38,
"hideOutput": true,
"hidePrompt": true
"coeffs_seasonal_oscillation = result_seasonal_oscillation.params.valuesdict()"
"execution_count": 22,
"hidePrompt": true
"OrderedDict([('amp', 2.5022539354204705),\n",
" ('freq', 1.0044805631567757),\n",
" ('shift', 316.19947719002874)])"
"[[Variables]]\n",
" amp: 2.50225394 +/- 0.03484620 (1.39%) (init = 7)\n",
" freq: 1.00448056 +/- 6.1469e-05 (0.01%) (init = 1)\n",
" shift: 316.199477 +/- 0.02463756 (0.01%) (init = 0)\n"
"coeffs_seasonal_oscillation = result_seasonal_oscillation.params.valuesdict()\n",
"coeffs_seasonal_oscillation"
"print(lmfit.fit_report(result_seasonal_oscillation.params))"
@@ -871,12 +909,14 @@
"Avec ces résulats nous pouvons caractériser l'oscillation saisonnière comme suit :\n",
"- +/- 2.5 *ppm* sur une année.\n",
"- Une féquence de 1 année pour chaque oscillation. Ce qui conforme aux observations.\n",
"- Un décalage de 316.20 *ppm* qui correspond à la première mesure de la base de données."
"- Un décalage de 316.20 *ppm* qui correspond à la première mesure de la base de données. \n",
"Les intervalles de confiance sont là aussi très restreints. Nous faisons le choix de ne pas les représenter sur les graphiques à venir."
3
"hidePrompt": true
@@ -891,7 +931,7 @@
2
4
"hidePrompt": true
@@ -903,7 +943,7 @@
3
5
"hideCode": true,
"hidePrompt": true
@@ -912,10 +952,10 @@
4bea999f9
8>"
a3db00027
8>"
3
5
@@ -977,7 +1017,7 @@
4
6
"hidePrompt": true
@@ -991,7 +1031,7 @@
5
7
"hideCode": true,
"hidePrompt": true
@@ -1000,10 +1040,10 @@
4c13b6dac8
a4041c7550
5
7
@@ -1039,7 +1079,7 @@
6
8
"hidePrompt": true
@@ -1050,7 +1090,7 @@
"0.997596462036615"
6
8
@@ -1090,7 +1130,7 @@
7
9
"hideOutput": true,
"hidePrompt": true
@@ -1102,7 +1142,7 @@
"(52,)"
7
9
@@ -1116,7 +1156,7 @@
"execution_count":
28
"execution_count":
30
"hidePrompt": true
@@ -1128,7 +1168,7 @@
"execution_count":
29
"execution_count":
31
"hidePrompt": true
@@ -1146,7 +1186,7 @@
2
"hidePrompt": true
@@ -1157,7 +1197,7 @@
"425.0"
2
@@ -1170,7 +1210,7 @@
3
"hidePrompt": true
@@ -1181,7 +1221,7 @@
"425.0"
3
@@ -1203,7 +1243,7 @@
2
4
"hideCode": true,
"hidePrompt": true
@@ -1212,10 +1252,10 @@
4c13bd0710
a40643fdd8
2
4
@@ -1266,7 +1306,7 @@
3
5
"hidePrompt": true
@@ -1281,7 +1321,7 @@
4
6
"hideCode": true,
"hidePrompt": true
@@ -1290,10 +1330,10 @@
4c1373e470
a4043843c8
4
6
@@ -1335,7 +1375,8 @@
"hidePrompt": true
"Ci-dessus la prédiction pour l'année 2025 complète (courbe verte) et sa tendance à long terme (courbe orange)."
"Ci-dessus la prédiction pour l'année 2025 complète (courbe verte) et sa tendance à long terme (courbe orange). \n",
"Pour assurer une bonne lisibilité du graphique, les intervalles de confiance (très étroits) ne sont pas représentés."
