Commit e5fb6ad1 authored by François Févotte's avatar François Févotte
MaJ 08/04
parent 6ca812f5
module2/exo4/daily.png
78.6 KB | W: | H:
82.8 KB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
...@@ -11,18 +11,39 @@ ...@@ -11,18 +11,39 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Identification du système
#+BEGIN_SRC shell :exports both
uname -a
#+END_SRC
: Linux aluminium 4.14.0-3-amd64 #1 SMP Debian 4.14.17-1 (2018-02-14) x86_64 GNU/Linux
#+BEGIN_SRC python :results value :session :exports both
import sys
sys.version
#+END_SRC
: 3.7.3rc1 (default, Mar 13 2019, 11:01:15)
: [GCC 8.3.0]
* Récupération des données * Récupération des données
On prend les données distribuées par [[https://ourworldindata.org][Our World In Data]], elles-mêmes issues de On prend les données distribuées par [[https://ourworldindata.org][Our World In Data]], elles-mêmes issues de
l'[[https://www.ecdc.europa.eu/][ECDC]] : l'[[https://www.ecdc.europa.eu/][ECDC]] :
#+BEGIN_SRC python :results none :session :exports none #+BEGIN_SRC python :results output :session :exports none
import numpy as np import numpy as np
import matplotlib.pyplot as plt import matplotlib.pyplot as plt
import pandas as pd import pandas as pd
plt.style.use('seaborn') plt.style.use('seaborn')
#+END_SRC #+END_SRC
#+BEGIN_SRC python :results value :session :exports both #+BEGIN_SRC python :results value :session :exports both
url = "https://covid.ourworldindata.org/data/ecdc/full_data.csv" url = "https://covid.ourworldindata.org/data/ecdc/full_data.csv"
data_raw = pd.read_csv(url, index_col='date') data_raw = pd.read_csv(url, index_col='date')
...@@ -32,9 +53,10 @@ l'[[https://www.ecdc.europa.eu/][ECDC]] : ...@@ -32,9 +53,10 @@ l'[[https://www.ecdc.europa.eu/][ECDC]] :
#+RESULTS: #+RESULTS:
: location new_cases new_deaths total_cases total_deaths : location new_cases new_deaths total_cases total_deaths
: date : date
: 2020-04-04 Zimbabwe 1 0 9 1
: 2020-04-05 Zimbabwe 0 0 9 1
: 2020-04-06 Zimbabwe 0 0 9 1 : 2020-04-06 Zimbabwe 0 0 9 1
: 2020-04-07 Zimbabwe 0 0 9 1
: 2020-04-08 Zimbabwe 1 0 10 1
* Evolution comparée de l'épidémie dans quelques pays * Evolution comparée de l'épidémie dans quelques pays
...@@ -43,6 +65,37 @@ comparable d'un pays à l'autre que, par exemple, le nombre de cas dépistés. A ...@@ -43,6 +65,37 @@ comparable d'un pays à l'autre que, par exemple, le nombre de cas dépistés. A
de recaler l'axe temporel, on positionne $t=0$ au moment où le nombre total de de recaler l'axe temporel, on positionne $t=0$ au moment où le nombre total de
morts dépasse 100. morts dépasse 100.
La logique est la suivante : on considère le nombre $n^c$ (de décès ou de cas)
dans un pays $c$. On suppose que l'évolution de $n^c$ en fonction du temps $t$
suit une loi de croissance exponentielle (au moins dans une phase initiale). On
s'attend ainsi à avoir une expression du type :
n^c(t) = n^c_0 \, e^{\lambda^c \left(t-t^c_0\right)}.
Dans cette expression, la valeur initiale $n^c_0 = n^c(t^c_0)$ est liée à la
taille de la population considérée. La constante de temps $\lambda^c$ en revanche,
n'a pas vraiment de raison de l'être : elle reflète simplement le rythme auquel
l'épidémie se propage.
Si l'on se donne un seuil $\tau$ unique, on peut fixer pour chaque pays
l'instant initial $t^c_0$ de sorte que
n^c(t^c_0) = \tau.
En effectuant un recalage de l'instant initial, c'est à dire en effectuant le
changement de variable temporelle $\tilde{t}^c=t-t^c_0$, on obtient
n^c(\tilde{t}^c) = \tau \, e^{\lambda^c\,\tilde{t}^c},
ce qui signifie que tous les pays deviennent comparables, indépendamment de leur
taille : on s'est ramené à comparer les constantes de temps $\lambda^c$ entre
elles.
En pratique, on prend
t^c_0 = \min \left\{t ; n^c(t) > \tau \right\}.
#+BEGIN_SRC python :results value :exports both :session #+BEGIN_SRC python :results value :exports both :session
# Parameters # Parameters
column = "total_deaths" column = "total_deaths"
...@@ -53,21 +106,44 @@ morts dépasse 100. ...@@ -53,21 +106,44 @@ morts dépasse 100.
for country in countries: for country in countries:
total[country] = data_raw.query(f"location == '{country}' & {column} > {threshold}") total[country] = data_raw.query(f"location == '{country}' & {column} > {threshold}")
daily[countries[0]].head(3) total[countries[0]]
#+END_SRC #+END_SRC
: location new_cases new_deaths total_cases total_deaths #+begin_example
: date location new_cases new_deaths total_cases total_deaths
: 2020-03-14 France 785 18 3661 79 date
: 2020-03-16 France 924 36 5423 127 2020-03-16 France 924 36 5423 127
: 2020-03-17 France 1210 21 6633 148 2020-03-17 France 1210 21 6633 148
2020-03-18 France 1097 27 7730 175
2020-03-19 France 1404 69 9134 244
2020-03-20 France 1861 128 10995 372
2020-03-21 France 1617 78 12612 450
2020-03-22 France 1847 112 14459 562
2020-03-23 France 1559 112 16018 674
2020-03-24 France 3838 186 19856 860
2020-03-25 France 2446 240 22302 1100
2020-03-26 France 2931 231 25233 1331
2020-03-27 France 3922 365 29155 1696
2020-03-28 France 3809 299 32964 1995
2020-03-29 France 4611 319 37575 2314
2020-03-30 France 2599 292 40174 2606
2020-03-31 France 4376 418 44550 3024
2020-04-01 France 7578 499 52128 3523
2020-04-02 France 4861 509 56989 4032
2020-04-03 France 2116 471 59105 4503
2020-04-04 France 5233 2004 64338 6507
2020-04-05 France 4267 1053 68605 7560
2020-04-06 France 1873 518 70478 8078
2020-04-07 France 3912 833 74390 8911
2020-04-08 France 3777 1417 78167 10328
#+BEGIN_SRC python :session :results output file :exports results :var pltfile="total.png" #+BEGIN_SRC python :session :results output file :exports results :var pltfile="total.png"
plt.figure(figsize=(10,5)) plt.figure(figsize=(10,5))
for country in total.keys(): for country in total.keys():
x = total[country]['total_deaths'] x = total[country]['total_deaths']
plt.plot(numpy.arange(len(x)), x, label=country, linewidth=3) plt.plot(np.arange(len(x)), x, label=country, linewidth=3)
plt.xlabel(f"Number of days since {column} > {threshold}") plt.xlabel(f"Number of days since {column} > {threshold}")
plt.yscale("log") plt.yscale("log")
plt.legend(fontsize='x-large') plt.legend(fontsize='x-large')
...@@ -95,21 +171,23 @@ de morts dépasse 15. ...@@ -95,21 +171,23 @@ de morts dépasse 15.
daily[country] = data_raw.query(f"location == '{country}' & new_deaths > {threshold}") daily[country] = data_raw.query(f"location == '{country}' & new_deaths > {threshold}")
daily[countries[0]].head(3) daily[countries[0]].tail(3)
#+END_SRC #+END_SRC
: date : date
: 2020-03-14 France 785 18 3661 79 : 2020-04-04 France 5233 2004 64338 6507
: 2020-03-16 France 924 36 5423 127 : 2020-04-05 France 4267 1053 68605 7560
: 2020-03-17 France 1210 21 6633 148 : 2020-04-06 France 1873 518 70478 8078
: 2020-04-07 France 3912 833 74390 8911
: 2020-04-08 France 3777 1417 78167 10328
#+BEGIN_SRC python :session :results output file :exports results :var pltfile="daily.png" #+BEGIN_SRC python :session :results output file :exports results :var pltfile="daily.png"
for country in daily.keys(): for country in daily.keys():
x = daily[country]['new_deaths'] x = daily[country]['new_deaths']
plt.xlabel(f"Number of days since daily deaths > {threshold}") plt.xlabel(f"Number of days since daily deaths > {threshold}")
...@@ -121,3 +199,8 @@ de morts dépasse 15. ...@@ -121,3 +199,8 @@ de morts dépasse 15.
[[file:daily.png]] [[file:daily.png]]
# Local Variables:
# org-babel-python-command: "python3"
# org-confirm-babel-evaluate: nil
# End:
module2/exo4/total.png
58.9 KB | W: | H:
60.6 KB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
