Solved exercise
parent 85a295af
"cells": [],
"cells": [
"execution_count": 18,
"import numpy as np"
"execution_count": 15,
"data = np.asarray([\n",
" 14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9,\n",
" 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7,\n",
" 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7,\n",
" 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4,\n",
" 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5,\n",
" 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2,\n",
" 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8,\n",
" 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4,\n",
" 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2,\n",
" 8.9, 21.0\n",
"], dtype=np.float64)"
"execution_count": 16,
"Moyenne : 14.113000000000001\n",
"Ecart-type : 4.334094455301447\n",
"Minimum : 2.8\n",
"Médiane : 14.5\n",
"Maximum : 23.4\n"
"print(f\"Moyenne : {data.mean()}\")\n",
"print(f\"Ecart-type : {data.std(ddof=1)}\")\n",
"print(f\"Minimum : {data.min()}\")\n",
"print(f\"Médiane : {np.median(data)}\")\n",
"print(f\"Maximum : {data.max()}\")"
"kernelspec": {
"display_name": "Python 3",
......@@ -16,10 +71,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
