4273f2ba61d873c01ff7dbef7231bb4c
49802b18
49802b18
deux cellules
608c32e2
112 additions
+112
Premier_Test.ipynb
module2/exo1/Premier_Test.ipynb
+112
49802b18
"cells": [
"# Fichier test de calculs en python"
"## boucle for"
"execution_count": 3,
"0\n",
"1\n",
"2\n",
"3\n",
"4\n"
"for i in range(5): # ici un commentaire du code\n",
" print(i)"
"texte simple comme un commentaire des résultats"
"## test if / else"
"execution_count": 19,
"0\n",
"nombre pair\n"
"var1 = 10\n",
"print(var1 % 2)\n",
"if (var1 % 2) == 0:\n",
" print (\"nombre pair\"), var1\n",
"else:\n",
" print (\"nombre impair\"), var1"
"execution_count": null,
"source": []
"source": []
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
