43800f9eebbeb989c35b6b37774edfea
65d8c41c
65d8c41c
Anton Y.
task try 1
85815026
53 additions
69 deletions
+53
-69
toy_document_orgmode_python_en.org
module2/exo1/toy_document_orgmode_python_en.org
+53
-69
65d8c41c
#+TITLE:
Your title
#+AUTHOR:
Your name
+DATE: Today's date
#+TITLE:
On the computation of pi
#+AUTHOR:
Anton Y.
#+DATE: 2025-07-07
#+LANGUAGE: en
Some explanations
Asking the math library
https://orgmode.org/guide/.
My computer tells me that π is approximatively
print("Hello world!")
from math import *
pi
: Hello world!
C-c~.
* * Buffon's needle
Applying the method of Buffon's needle, we get the approximation
import numpy
x=numpy.linspace(-15,15)
print(x)
np.random.seed(seed=42)
N = 10000
2/(sum((x+np.sin(theta))>1)/N)
* Using a surface fraction argument
A method that is easier to understand and does not make use of the sin
function is based on the fact that if X∼U(0,1) and Y∼U(0,1), then
P[X2+Y2≤1]=π/4 (see "Monte Carlo method" on Wikipedia). The following
code uses this approach:
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
N = 1000
accept = (x*x+y*y) <= 1
fig, ax = plt.subplots(1)
ax.set_aspect('equal')
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
[[file:None]]
It is then straightforward to obtain a (not really good) approximation to π
by counting how many times, on average, X2+Y2
is smaller than 1:
4*np.mean(accept)
