Commits (4)
# Partie 1
## Sous-partie 1 : texte
Une phrase sans rien
*Une phrase en italique*
**Une phrase en gras**
Un lien vers [fun-mooc.fr](https://www.fun-mooc.fr/)
Une ligne de `code`
## Sous-partie 2 : listes
**Liste à puce**
- item
- sous-item
- sous-item
- item
- item
**Liste numérotée**
1. item
2. item
3. item
## Sous-partie 3 : code
# Extrait de code
\ No newline at end of file
#+TITLE: Your title #+TITLE: The London cholera epidemic of 1854
#+AUTHOR: Your name #+AUTHOR: LT
#+DATE: Today's date
#+LANGUAGE: en #+LANGUAGE: en
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/htmlize.css"/>
#+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/> #+HTML_HEAD: <link rel="stylesheet" type="text/css" href="http://www.pirilampo.org/styles/readtheorg/css/readtheorg.css"/>
...@@ -11,84 +9,353 @@ ...@@ -11,84 +9,353 @@
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/lib/js/jquery.stickytableheaders.js"></script>
#+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script> #+HTML_HEAD: <script type="text/javascript" src="http://www.pirilampo.org/styles/readtheorg/js/readtheorg.js"></script>
* Some explanations #+LATEX_HEADER: \usepackage{a4}
This is an org-mode document with code examples in R. Once opened in #+PROPERTY: header-args :session :exports both :eval never-export
https://orgmode.org/guide/.
When you type the shortcut =C-c C-e h o=, this document will be # FIXME! https://towardsdatascience.com/plotting-a-map-of-london-crime-data-using-r-8dcefef1c397
Like we showed in the video, Python code is included as follows (and * Data recovery and pre-processing
is exxecuted by typing ~C-c C-c~): Let's start by loading a number of libraries which we
will be useful later.
library(ggplot2)
library(stringr)
library(dplyr)
library(tidyr)
Package attachment : ‘dplyr’
The following objects are masked from ‘package:stats’:
filter, lag
The following objects are masked from ‘package:base’:
intersect, setdiff, setequal, union
Now download the data on the Cholera epidemic of 1854.
#+begin_src python :results output :exports both #+begin_src R :results output :session *R* :exports both
print("Hello world!") cholera_file = "./cholera.csv";
url = "https://fusiontables.google.com/exporttable?query=select+*+from+1HsIb_r4gYYmIz8y_UE1h-X8yUtAYW2INy99BR_c&o=csv"
if(!file.exists(cholera_file)) { download.file(url, cholera_file) }
cholera = read.csv(cholera_file, strip.white=T)
head(cholera)
str(cholera)
#+end_src #+end_src
#+RESULTS: #+RESULTS:
: Hello world! #+begin_example
essai de l'URL 'https://fusiontables.google.com/exporttable?query=select+*+from+1HsIb_r4gYYmIz8y_UE1h-X8yUtAYW2INy99BR_c&o=csv'
downloaded 16 KB
count geometry
1 3 <Point><coordinates>-0.13793,51.513418</coordinates></Point>
2 2 <Point><coordinates>-0.137883,51.513361</coordinates></Point>
3 1 <Point><coordinates>-0.137853,51.513317</coordinates></Point>
4 1 <Point><coordinates>-0.137812,51.513262</coordinates></Point>
5 4 <Point><coordinates>-0.137767,51.513204</coordinates></Point>
6 2 <Point><coordinates>-0.137537,51.513184</coordinates></Point>
'data.frame': 250 obs. of 2 variables:
$ count : int 3 2 1 1 4 2 2 2 3 2 ...
$ geometry: Factor w/ 250 levels "<Point><coordinates>-0.132933,51.513258</coordinates></Point>",..: 202 199 197 195 193 185 213 206 217 214 ...
C-c~.
#+begin_src python :results output :session :exports both #+begin_src R :results output :session *R* :exports both
import numpy pump_file = "./water_pump.csv";
x=numpy.linspace(-15,15) url = "https://fusiontables.google.com/exporttable?query=select+*+from+1Al4BQYgV0BzoyEaWmTcCRgLMkOJkiBo8QUQT_tU&o=csv"
print(x) if(!file.exists(pump_file)) { download.file(url, pump_file) }
pump = read.csv(pump_file, strip.white=T)
head(pump)
str(pump)
#+end_src #+end_src
#+begin_example #+begin_example
[-15. -14.3877551 -13.7755102 -13.16326531 -12.55102041 essai de l'URL 'https://fusiontables.google.com/exporttable?query=select+*+from+1Al4BQYgV0BzoyEaWmTcCRgLMkOJkiBo8QUQT_tU&o=csv'
-11.93877551 -11.32653061 -10.71428571 -10.10204082 -9.48979592 Content type 'application/x-download; charset=UTF-8' length 520 bytes
-8.87755102 -8.26530612 -7.65306122 -7.04081633 -6.42857143 ==================================================
-5.81632653 -5.20408163 -4.59183673 -3.97959184 -3.36734694 downloaded 520 bytes
-2.75510204 -2.14285714 -1.53061224 -0.91836735 -0.30612245 geometry
0.30612245 0.91836735 1.53061224 2.14285714 2.75510204 1 <Point><coordinates>-0.136668,51.513341</coordinates></Point>
3.36734694 3.97959184 4.59183673 5.20408163 5.81632653 2 <Point><coordinates>-0.139586,51.513876</coordinates></Point>
6.42857143 7.04081633 7.65306122 8.26530612 8.87755102 3 <Point><coordinates>-0.139671,51.514906</coordinates></Point>
9.48979592 10.10204082 10.71428571 11.32653061 11.93877551 4 <Point><coordinates>-0.13163,51.512354</coordinates></Point>
12.55102041 13.16326531 13.7755102 14.3877551 15. ] 5 <Point><coordinates>-0.133594,51.512139</coordinates></Point>
6 <Point><coordinates>-0.135919,51.511542</coordinates></Point>
'data.frame': 8 obs. of 1 variable:
$ geometry: Factor w/ 8 levels "<Point><coordinates>-0.13163,51.512354</coordinates></Point>",..: 5 7 8 1 2 4 3 6
#+end_example #+end_example
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
print(matplot_lib_filename) These coordinates in the form of a character string are not very practical. Let's extract the latitudes and longitudes.
cholera$geometry %>%
str_replace_all("[</>A-Za-z]*","") %>%
str_split(",") %>% do.call("rbind",.) %>% as.numeric() -> cholera[,c("lon","lat")]
cholera %>% select(-geometry) -> cholera
# the do.call tricks was inspired by http://ggorjan.blogspot.com/2011/01/converting-strsplit-output-to-dataframe.html
head(cholera)
str(cholera)
#+end_src #+end_src
[[file:./cosxsx.png]] #+begin_example
count lon lat
1 3 -0.137930 51.51342
2 2 -0.137883 51.51336
3 1 -0.137853 51.51332
4 1 -0.137812 51.51326
5 4 -0.137767 51.51320
6 2 -0.137537 51.51318
'data.frame': 250 obs. of 3 variables:
$ count: int 3 2 1 1 4 2 2 2 3 2 ...
$ lon : num -0.138 -0.138 -0.138 -0.138 -0.138 ...
$ lat : num 51.5 51.5 51.5 51.5 51.5 ...
transparent and reproducible.
Watch out: the figure generated by the code block is /not/ stored in #+begin_src R :results output :session *R* :exports both
the org document. It's a plain file, here named ~cosxsx.png~. You have pump$geometry %>%
to commit it explicitly if you want your analysis to be legible and str_replace_all("[</>A-Za-z]*","") %>%
understandable on GitLab. str_split(",") %>% do.call("rbind",.) %>% as.numeric() -> pump[,c("lon","lat")]
pump %>% select(-geometry) -> pump
head(pump)
str(pump)
lon lat
1 -0.136668 51.51334
2 -0.139586 51.51388
3 -0.139671 51.51491
4 -0.131630 51.51235
5 -0.133594 51.51214
6 -0.135919 51.51154
'data.frame': 8 obs. of 2 variables:
$ lon: num -0.137 -0.14 -0.14 -0.132 -0.134 ...
$ lat: num 51.5 51.5 51.5 51.5 51.5 ...
On the other hand, later, some algorithms (density estimation, / clustering /) that I will use do not manage well the fact that an entry includes several deaths. So I'm going to prepare a "flattened" version of ~ cholera ~. For this, I am inspired by the following entry on
[[https://stackoverflow.com/questions/46841463/expand-a-data-frame-to-have-as-many-rows-as-range-of-two-columns-in-original-row[[stackoverflow ]].
cholera %>%
rowwise() %>%
do(data.frame(lon= .$lon, lat= .$lat, value = 1:.$count)) %>%
as.data.frame() -> cholera_flat
head(cholera_flat )
: lon lat value
: 1 -0.137930 51.51342 1
: 2 -0.137930 51.51342 2
: 3 -0.137930 51.51342 3
: 4 -0.137883 51.51336 1
: 5 -0.137883 51.51336 2
: 6 -0.137853 51.51332 1
* Visualisations
From there, it's easy to represent the previous data:
#+begin_src R :results output graphics :file "map1.png" :exports both :width 600 :height 600 :session *R*
ggplot(cholera,aes(x=lon,y=lat)) +
geom_point(aes(size=count),color="red3") +
geom_point(data=pump, color="blue", size=4) +
theme_bw() + coord_fixed()
[[file:map1.png]]
** With a map of London (current)
But to have a real map, it is better to use the right tool: [[https://journal.r-project.org/archive/2013-1/kahle-wickham.pdf[[ggmap]]. So I read this documentation well to improve things. I will center my map on the median of the previous coordinates.
library(ggmap)
mapImageData <- get_map(location = c(lon = median(cholera$lon), lat = median(cholera$lat)),
color = "color",
source = "google",
maptype = "toner",
zoom = 16)
LondonMap = ggmap(mapImageData,
extent = "device",
ylab = "Latitude",
xlab = "Longitude")
Google Maps API Terms of Service: http://developers.google.com/maps/terms.
Please cite ggmap if you use it: see citation('ggmap') for details.
maptype = "toner" is only available with source = "stamen".
resetting to source = "stamen"...
Map from URL : http://maps.googleapis.com/maps/api/staticmap?center=51.513379,-0.136288&zoom=16&size=640x640&scale=2&maptype=terrain&sensor=false
Map from URL : http://tile.stamen.com/toner/16/32741/21789.png
Map from URL : http://tile.stamen.com/toner/16/32742/21789.png
Map from URL : http://tile.stamen.com/toner/16/32743/21789.png
Map from URL : http://tile.stamen.com/toner/16/32744/21789.png
Map from URL : http://tile.stamen.com/toner/16/32741/21790.png
Map from URL : http://tile.stamen.com/toner/16/32742/21790.png
Map from URL : http://tile.stamen.com/toner/16/32743/21790.png
Map from URL : http://tile.stamen.com/toner/16/32744/21790.png
Map from URL : http://tile.stamen.com/toner/16/32741/21791.png
Map from URL : http://tile.stamen.com/toner/16/32742/21791.png
Map from URL : http://tile.stamen.com/toner/16/32743/21791.png
Map from URL : http://tile.stamen.com/toner/16/32744/21791.png
Warning message:
`panel.margin` is deprecated. Please use `panel.spacing` property instead
Let’s go. As before, in red the cases of Cholera and in blue the
sources of water.
#+begin_src R :results output graphics :file :file "map2.png" :exports both :width 800 :height 800 :session *R*
LondonMap +
geom_point(data=cholera,aes(x=lon,y=lat, size=count),color="red3") +
geom_point(data=pump, color="blue",size=4) + theme_bw()
[[file:map2.png]]
** Clustering
L'histoire, dit qu'une des dames qui a contracté le Choléra faisait un
peu office d'/outlier/ car elle n'habitait pas à proximité de la pompe
infectée. Peut-être est-ce le petit point le plus en haut à droite ?
Peut-être qu'un algorithme de clustering aurait été capable d'aider à
le repérer ? Essayons de faire ça bien avec une bibliothèque faisant
de l'estimation par maximum de vraisemblance de mixtures de
gaussiennes. Pour ça, je m'inspire des [[https://www.statmethods.net/advstats/cluster.html][commandes données ici]].
library(mclust)
fit <- Mclust(as.matrix(cholera_flat[,c("lon","lat")]),verbose=F)
: __ ___________ __ _____________
: / |/ / ____/ / / / / / ___/_ __/
: / /|_/ / / / / / / / /\__ \ / /
: / / / / /___/ /___/ /_/ /___/ // /
: /_/ /_/\____/_____/\____//____//_/ version 5.4.1
: Type 'citation("mclust")' for citing this R package in publications.
#+begin_src R :results output graphics :file "clustering_BIC.png" :exports both :width 600 :height 400 :session *R*
plot(fit,what = c("BIC"))
[[file:clustering_BIC.png]]
Ouh là, je ne trouve pas que ça soit bon signe, un BIC qui monte comme
ça sans maximum bien clair.
summary(fit)
Gaussian finite mixture model fitted by EM algorithm
Mclust VEV (ellipsoidal, equal shape) model with 7 components:
log.likelihood n df BIC ICL
5523.087 489 35 10829.44 10693.22
Clustering table:
1 2 3 4 5 6 7
121 119 26 73 83 23 44
Let's take a look at what the most likely classification looks like.
#+begin_src R :results output graphics :file "clustering.png" :exports both :width 600 :height 400 :session *R*
plot(fit,what = c("classification"))
[[file:clustering.png]]
Bof, it's a little anything but hey, let's try anyway
to use this information on the previous card:
#+begin_src R :results output graphics :file "map3.png" :exports both :width 800 :height 800 :session *R*
cholera_flat$cluster = as.factor(fit$classification)
cluster = as.data.frame(t(fit$parameters$mean))
cluster$id = 1:nrow(cluster)
cholera_clustered = cholera_flat %>% group_by(lon,lat,cluster) %>% summarize(count=n())
outlier = cholera[cholera$lat == max(cholera$lat),]
LondonMap +
geom_point(data=cholera_clustered,
aes(x=lon, y=lat, size=count, color=cluster)) +
stat_ellipse(data=cholera_flat,aes(x=lon, y=lat, fill=cluster, group=cluster),
type = "norm",geom = "polygon", alpha = .3) +
geom_label(data = cluster, aes(x=lon, y=lat, label=id)) +
geom_label(data = outlier, aes(x=lon, y=lat+0.00012), fill="red", label="outlier",alpha=.3) +
scale_colour_brewer(palette="Set1") +
scale_fill_brewer(palette="Set1") + theme_bw()
[[file:map3.png]]
** Estimation the density
#+begin_src R :results output graphics :file "map4.png" :exports both :width 800 :height 800 :session *R*
LondonMap +
stat_density2d(data=cholera_flat,
aes(x = lon, y = lat, fill = ..level.., alpha = ..level..),
size = 2, bins = 4,
geom = "polygon",
fill="red"
theme_bw()
[[file:map4.png]]
#+begin_src R :results output graphics :file "map5.png" :exports both :width 800 :height 800 :session *R*
LondonMap +
stat_density2d(data=cholera,
size = 2, bins = 4,
geom = "polygon",
fill="red"
stat_ellipse(data=cholera,aes(x=lon, y=lat),
theme_bw()
[[file:map5.png]]
followed by ~Tab~.
