50eb3e12b022657b764f06afc7ab4a85
b6c35ee7
b6c35ee7
test ligne 1
3c069a11
209 additions
+209
Module 4 exo1.ipynb
module2/exo5/Module 4 exo1.ipynb
+209
b6c35ee7
"cells": [
"Test code ligne 1"
"execution_count": 1,
"3.6.4 |Anaconda, Inc.| (default, Mar 13 2018, 01:15:57) \n",
"[GCC 7.2.0]\n",
"uname_result(system='Linux', node='4b8108b42aa8', release='4.4.0-164-generic', version='#192-Ubuntu SMP Fri Sep 13 12:02:50 UTC 2019', machine='x86_64', processor='x86_64')\n",
"IPython 7.12.0\n",
"IPython.core.release 7.12.0\n",
"PIL 7.0.0\n",
"PIL.Image 7.0.0\n",
"PIL._version 7.0.0\n",
"_csv 1.0\n",
"_ctypes 1.1.0\n",
"_curses b'2.2'\n",
"decimal 1.70\n",
"argparse 1.1\n",
"backcall 0.1.0\n",
"cffi 1.13.2\n",
"csv 1.0\n",
"ctypes 1.1.0\n",
"cycler 0.10.0\n",
"dateutil 2.8.1\n",
"decimal 1.70\n",
"decorator 4.4.1\n",
"distutils 3.6.4\n",
"ipaddress 1.0\n",
"ipykernel 5.1.4\n",
"ipykernel._version 5.1.4\n",
"ipython_genutils 0.2.0\n",
"ipython_genutils._version 0.2.0\n",
"ipywidgets 7.2.1\n",
"ipywidgets._version 7.2.1\n",
"jedi 0.16.0\n",
"json 2.0.9\n",
"jupyter_client 6.0.0\n",
"jupyter_client._version 6.0.0\n",
"jupyter_core 4.6.3\n",
"jupyter_core.version 4.6.3\n",
"kiwisolver 1.1.0\n",
"logging 0.5.1.2\n",
"matplotlib 2.2.3\n",
"matplotlib.backends.backend_agg 2.2.3\n",
"numpy 1.15.2\n",
"numpy.core 1.15.2\n",
"numpy.core.multiarray 3.1\n",
"numpy.lib 1.15.2\n",
"numpy.linalg._umath_linalg b'0.1.5'\n",
"numpy.matlib 1.15.2\n",
"optparse 1.5.3\n",
"pandas 0.22.0\n",
"_libjson 1.33\n",
"parso 0.6.0\n",
"patsy 0.5.1\n",
"patsy.version 0.5.1\n",
"pexpect 4.8.0\n",
"pickleshare 0.7.5\n",
"platform 1.0.8\n",
"prompt_toolkit 3.0.3\n",
"ptyprocess 0.6.0\n",
"pygments 2.5.2\n",
"pyparsing 2.4.6\n",
"pytz 2019.3\n",
"re 2.2.1\n",
"scipy 1.1.0\n",
"scipy._lib.decorator 4.0.5\n",
"scipy._lib.six 1.2.0\n",
"scipy.fftpack._fftpack b'$Revision: $'\n",
"scipy.fftpack.convolve b'$Revision: $'\n",
"scipy.integrate._dop b'$Revision: $'\n",
"scipy.integrate._ode $Id$\n",
"scipy.integrate._odepack 1.9 \n",
"scipy.integrate._quadpack 1.13 \n",
"scipy.integrate.lsoda b'$Revision: $'\n",
"scipy.integrate.vode b'$Revision: $'\n",
"scipy.interpolate._fitpack 1.7 \n",
"scipy.interpolate.dfitpack b'$Revision: $'\n",
"scipy.linalg 0.4.9\n",
"scipy.linalg._fblas b'$Revision: $'\n",
"scipy.linalg._flapack b'$Revision: $'\n",
"scipy.linalg._flinalg b'$Revision: $'\n",
"scipy.ndimage 2.0\n",
"scipy.optimize._cobyla b'$Revision: $'\n",
"scipy.optimize._lbfgsb b'$Revision: $'\n",
"scipy.optimize._minpack 1.10 \n",
"scipy.optimize._nnls b'$Revision: $'\n",
"scipy.optimize._slsqp b'$Revision: $'\n",
"scipy.optimize.minpack2 b'$Revision: $'\n",
"scipy.signal.spline 0.2\n",
"scipy.sparse.linalg.eigen.arpack._arpack b'$Revision: $'\n",
"scipy.sparse.linalg.isolve._iterative b'$Revision: $'\n",
"scipy.special.specfun b'$Revision: $'\n",
"scipy.stats.mvn b'$Revision: $'\n",
"scipy.stats.statlib b'$Revision: $'\n",
"seaborn 0.8.1\n",
"seaborn.external.husl 2.1.0\n",
"seaborn.external.six 1.10.0\n",
"six 1.14.0\n",
"statsmodels 0.9.0\n",
"statsmodels.__init__ 0.9.0\n",
"traitlets 4.3.3\n",
"traitlets._version 4.3.3\n",
"urllib.request 3.6\n",
"zlib 1.0\n",
"zmq 17.1.2\n",
"zmq.sugar 17.1.2\n",
"zmq.sugar.version 17.1.2\n"
"def print_imported_modules():\n",
" import sys\n",
" for name, val in sorted(sys.modules.items()):\n",
" if(hasattr(val, '__version__')): \n",
" print(val.__name__, val.__version__)\n",
"# else:\n",
"# print(val.__name__, \"(unknown version)\")\n",
"def print_sys_info():\n",
" import sys\n",
" import platform\n",
" print(sys.version)\n",
" print(platform.uname())\n",
"import numpy as np\n",
"import pandas as pd\n",
"import statsmodels.api as sm\n",
"import seaborn as sns\n",
"print_sys_info()\n",
"print_imported_modules()"
"execution_count": 2,
"ename": "ParserError",
"evalue": "Error tokenizing data. C error: Expected 1 fields in line 30, saw 21\n",
"output_type": "error",
"traceback": [
"\u001b[0;31mParserError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m<ipython-input-2-dd5c5ce9e9a8>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"https://app-learninglab.inria.fr/moocrr/gitlab/moocrr-session3/moocrr-reproducibility-study/blob/master/data/shuttle.csv\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 2\u001b[0m \u001b[0mdata\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mparser_f\u001b[0;34m(filepath_or_buffer, sep, delimiter, header, names, index_col, usecols, squeeze, prefix, mangle_dupe_cols, dtype, engine, converters, true_values, false_values, skipinitialspace, skiprows, nrows, na_values, keep_default_na, na_filter, verbose, skip_blank_lines, parse_dates, infer_datetime_format, keep_date_col, date_parser, dayfirst, iterator, chunksize, compression, thousands, decimal, lineterminator, quotechar, quoting, escapechar, comment, encoding, dialect, tupleize_cols, error_bad_lines, warn_bad_lines, skipfooter, skip_footer, doublequote, delim_whitespace, as_recarray, compact_ints, use_unsigned, low_memory, buffer_lines, memory_map, float_precision)\u001b[0m\n\u001b[1;32m 707\u001b[0m skip_blank_lines=skip_blank_lines)\n\u001b[1;32m 708\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 709\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0m_read\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfilepath_or_buffer\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mkwds\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 710\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 711\u001b[0m \u001b[0mparser_f\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m__name__\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36m_read\u001b[0;34m(filepath_or_buffer, kwds)\u001b[0m\n\u001b[1;32m 453\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 454\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;32mfinally\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0mparser\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1067\u001b[0m \u001b[0;32mraise\u001b[0m \u001b[0mValueError\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'skipfooter not supported for iteration'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1068\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1069\u001b[0;31m \u001b[0mret\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_engine\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1070\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1071\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0moptions\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mget\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m'as_recarray'\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/io/parsers.py\u001b[0m in \u001b[0;36mread\u001b[0;34m(self, nrows)\u001b[0m\n\u001b[1;32m 1837\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mself\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mnrows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;32mNone\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1838\u001b[0m \u001b[0;32mtry\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1839\u001b[0;31m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_reader\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mnrows\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1840\u001b[0m \u001b[0;32mexcept\u001b[0m \u001b[0mStopIteration\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1841\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mself\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0m_first_chunk\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader.read\u001b[0;34m()\u001b[0m\n",
"\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_low_memory\u001b[0;34m()\u001b[0m\n",
"\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._read_rows\u001b[0;34m()\u001b[0m\n",
"\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.TextReader._tokenize_rows\u001b[0;34m()\u001b[0m\n",
"\u001b[0;32mpandas/_libs/parsers.pyx\u001b[0m in \u001b[0;36mpandas._libs.parsers.raise_parser_error\u001b[0;34m()\u001b[0m\n",
"\u001b[0;31mParserError\u001b[0m: Error tokenizing data. C error: Expected 1 fields in line 30, saw 21\n"
" data = pd.read_csv(\"https://app-learninglab.inria.fr/moocrr/gitlab/moocrr-session3/moocrr-reproducibility-study/blob/master/data/shuttle.csv\")\n",
"data"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
"language": "python",
"name": "python3"
"language_info": {
"codemirror_mode": {
"name": "ipython",
"version": 3
"file_extension": ".py",
"mimetype": "text/x-python",
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 4
