5785ce2009281db763af8064eb1752c5
5bd15e6a
5bd15e6a
Replace exo5_python_fr.org
c502c48e
219 additions
81 deletions
+219
-81
exo5_python_fr.org
module2/exo5/exo5_python_fr.org
+219
-81
5bd15e6a
#+TITLE: Analyse du risque de défaillance des joints toriques de la navette Challenger
:preambule:
#+PROPERTY: header-args :tangle yes
#+PROPERTY: header-args:jupyter-python :exports both
#+PROPERTY: header-args:jupyter-python+ :session /jpy:localhost#8889:jlab
#+PROPERTY: header-args:jupyter-R :exports both
#+PROPERTY: header-args:jupyter-R+ :session /jpy::ir
@@ -11,6 +20,38 @@
@@ -11,6 +20,38 @@
:end:
#+name: scrollImage
#+begin_src elisp :exports none
(defun org-image-resize (frame)
(setq org-export-allow-bind-keywords t)
(when (derived-mode-p 'org-mode)
(if (< (window-total-width) 80)
(setq org-image-actual-width (* 4 window-pixel-width))
(setq org-image-actual-width (* 70 (window-font-width))))
(org-redisplay-inline-images)))
(add-hook 'window-size-change-functions 'org-image-resize)
(visual-line-mode t)
(variable-pitch-mode t)
(add-hook 'org-babel-after-execute-hook 'org-redisplay-inline-images)
#+RESULTS: scrollImage
| org-redisplay-inline-images |
#+begin_src emacs-lisp
(setq org-image-actual-width '(200))
| 200 |
@@ -33,39 +74,39 @@ Challenger.
* Chargement des données
Nous commençons donc par charger ces données:
#+begin_src
python :results value :session *python* :exports both
#+begin_src
jupyter-python :results value :exports both :display text
module2_exo5_
shuttle.csv")
4/12/81 6 66 50 0
4/12/81 6 66 50 0
11/12/81 6 70 50 1
11/12/81 6 70 50 1
2
3/22/82 6 69 50 0
2
3/22/82 6 69 50 0
3
11/11/82 6 68 50 0
3
11/11/82 6 68 50 0
4
4/04/83 6 67 50 0
4
4/04/83 6 67 50 0
5
6/18/82 6 72 50 0
5
6/18/82 6 72 50 0
6
8/30/83 6 73 100 0
6
8/30/83 6 73 100 0
7
11/28/83 6 70 100 0
7
11/28/83 6 70 100 0
8
2/03/84 6 57 200 1
8
2/03/84 6 57 200 1
9
4/06/84 6 63 200 1
9
4/06/84 6 63 200 1
10
8/30/84 6 70 200 1
10
8/30/84 6 70 200 1
11
10/05/84 6 78 200 0
11
10/05/84 6 78 200 0
12
11/08/84 6 67 200 0
12
11/08/84 6 67 200 0
13
1/24/85 6 53 200 2
13
1/24/85 6 53 200 2
14
4/12/85 6 67 200 0
14
4/12/85 6 67 200 0
15
4/29/85 6 75 200 0
15
4/29/85 6 75 200 0
16
6/17/85 6 70 200 0
16
6/17/85 6 70 200 0
17
7/29/85 6 81 200 0
17
7/29/85 6 81 200 0
18
8/27/85 6 76 200 0
18
8/27/85 6 76 200 0
19
10/03/85 6 79 200 0
19
10/03/85 6 79 200 0
20
10/30/85 6 75 200 2
20
10/30/85 6 75 200 2
21
11/26/85 6 76 200 0
21
11/26/85 6 76 200 0
22
1/12/86 6 58 200 1
22
1/12/86 6 58 200 1
Le jeu de données nous indique la date de l'essai, le nombre de joints
@@ -79,40 +120,55 @@ sur l'influence de la température ou de la pression sur les
dysfonctionnements, nous nous concentrons sur les expériences où au
moins un joint a été défectueux.
#+begin_src
#+begin_src
Frequency
0.166667
0.166667
0.166667
0.166667
0.333333
0.333333
0.166667
Très bien, nous avons une variabilité de température importante mais
la pression est quasiment toujours égale à 200, ce qui devrait
simplifier l'analyse.
Comment la fréquence d'échecs varie-t-elle avec la température ?
#+begin_src jupyter-python :exports both :results raw drawer
cm = 1/2.54
plt.rcParams["figure.facecolor"] = "#A4B9C5"
#plt.rcParams['text.usetex'] = True
c_orange="#FF9A00"
c_darkblue="#5A7F96"
#+begin_src jupyter-python :results raw drawer :exports both
pd.options.mode.copy_on_write = True
#plt.clf()
data["Frequency"]=data["Malfunction"]/data["Count"]
[[./.ob-jupyter/3d4ddf0ba39f4d97099fa73e230ec4ef702db5f1.png]]
À première vue, ce n'est pas flagrant mais bon, essayons quand même
d'estimer l'impact de la température $t$ sur la probabilité de
@@ -128,38 +184,62 @@ température $t$ suit une loi binomiale de paramètre $n=6$ et
$p=p(t)$. Pour relier $p(t)$ à $t$, on va donc effectuer une
régression logistique.
#+begin_src jupyter-python :results value :exports both
logit_model=sm.Logit(data["Frequency"],data[["Intercept","Temperature"]]).fit()
logit_model.summary()
:RESULTS:
: Optimization terminated successfully.
: Current function value: 0.393555
: Iterations 5
: /home/vincent/.pyenv/versions/3.10.1/envs/default/lib/python3.10/site-packages/statsmodels/discrete/discrete_model.py:4469: RuntimeWarning: divide by zero encountered in scalar divide
: return 1 - self.llf/self.llnull
#+begin_export html
Logit Regression Results
Model: Logit Df Residuals: 5
Method: MLE Df Model: 1
Date: Sat, 13 Apr 2024 Pseudo R-squ.: inf
Time: 20:21:52 Log-Likelihood: -2.7549
converged: True LL-Null: 0.0000
Covariance Type: nonrobust LLR p-value: 1.000
#+end_export
:END:
| Dep. Variable: | Frequency | No. Observations: 7 | |
| Model: | Logit | Df Residuals: | 5 |
| Method: | MLE | Df Model: | 1 |
| Date: | Sat, 13 Apr 2024 | Pseudo R-squ.: | inf |
| Time: | 16:44:31 | Log-Likelihood: | -2.7549 |
| converged: | True | LL-Null: | 0.0000 |
| Covariance Type: | nonrobust | LLR p-value: | 1.000 |
| | coef | std err | z | P>z | [0.025 | 0.975] |
| Intercept | -1.3895 | 7.828 | -0.178 | 0.859 | -16.732 | 13.953 |
| Temperature | 0.0014 | 0.122 | 0.012 | 0.991 | -0.238 | 0.240 |
L'estimateur le plus probable du paramètre de température est 0.0014
et l'erreur standard de cet estimateur est de 0.122, autrement dit on
@@ -171,11 +251,11 @@ La température prévue le jour du décollage est de 31°F. Essayons
d'estimer la probabilité de dysfonctionnement des joints toriques à
cette température à partir du modèle que nous venons de construire:
#+begin_src
python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both :session *python*
#+begin_src
jupyter-python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both
data_pred['Frequency'] = logmodel.predict(data_pred[['Intercept','Temperature']])
it_
@@ -185,38 +265,96 @@ print(matplot_lib_filename)
:RESULTS:
: proba_estimate_python.png
[[./.ob-jupyter/32327fd28a2604a503ea9a032641035fd0b02e56.png]]
:END:
Comme on pouvait s'attendre au vu des données initiales, la
température n'a pas d'impact notable sur la probabilité d'échec des
joints toriques. Elle sera d'environ 0
2, comme dans les essais
précédents où nous il y a eu défaillance d'au moins un joint. Revenons
à l'ensemble des données initiales pour estimer la probabilité de
défaillance d'un joint:
#+begin_src
python :results output :session *python*
:exports both
#+begin_src
:exports both
module2_exo5_
shuttle.csv")
Cette probabilité est donc d'environ $p=0
065$, sachant qu'il existe
un joint primaire un joint secondaire sur chacune des trois parties du
lançeur, la probabilité de défaillance des deux joints d'un lançeur
est de $p^2 \approx 0.00425$. La probabilité de défaillance d'un des
lançeur est donc de $1-(1-p^2)^3 \approx 1.2%$. Ça serait vraiment
pas de chance... Tout est sous contrôle, le décollage peut donc avoir
lieu demain comme prévu.
Seulement, le lendemain, la navette Challenger explosera et emportera
avec elle ses sept membres d'équipages. L'opinion publique est
fortement touchée et lors de l'enquête qui suivra, la fiabilité des
joints toriques sera directement mise en cause. Au
delà des problèmes
delà des problèmes
de communication interne à la NASA qui sont pour beaucoup dans ce
fiasco, l'analyse précédente comporte (au moins) un petit
problème... Saurez-vous le trouver ? Vous êtes libre de modifier cette
analyse et de regarder ce jeu de données sous tous les angles afin
analyse et de regarder ce jeu de données sous tous les angles afin d'expliquer ce qui ne va pas.
* Autre analyse
Visualisation de l'ensemble du nuage avec intervalle de confiance (par
bootstrap).
from __future__ import print_function
from sklearn.linear_model import LogisticRegression
from sklearn.linear_model import LinearRegression
from scipy import stats
import seaborn as sns
sns.set(style='darkgrid', font_scale=1.2)
%matplotlib inline
#+begin_src jupyter-python :kernel python3 :exports :results raw drawer :display text
data = pd.read_csv("module2_exo5_shuttle.csv")
fig, ax = plt.subplots(figsize=(10,6))
plot=sns.regplot(x='Temperature',
y='Frequency',
data=data,
logistic=True,
n_boot=500,
y_jitter=0,
ax=ax)
plt.show()
[[./.ob-jupyter/dd04d70ba0976bf2224db67c19eefcbcf2398b08.png]]
