bef31968
bef31968
Let's rely on pyton rather than perl
1d0a618a
31 additions
30 deletions
+31
-30
article.org
module2/ressources/replicable_article/article.org
+31
-30
bef31968
@@ -97,37 +97,38 @@ echo 'file:measurements.txt'
* Extracting traces from data files :noexport:
#+begin_src perl :results output raw :exports both :var input="measurements.txt" output="data.csv"
#+begin_src python :results output raw :exports both :var input="measurements.txt" output="data.csv"
use strict;
import re,sys
open INPUT, $input;
open OUTPUT, "> $output";
INPUT = open(input, "r")
OUTPUT = open(output, "w")
my($line);
my($size);
OUTPUT.writelines("Size, Seq, Par, Libc\n")
my($seq,$par,$libc);
for line in INPUT.readlines():
print OUTPUT "Size, Seq, Par, Libc\n" ;
m = re.match('^Size: ([\d\.]*)$',line)
while($line=<INPUT>) {
if(m):
chomp $line;
size = m.group(1)
if($line =~/^Size: ([\d\.]*)$/) {
continue
$size = $1;
m = re.match('^Sequential quicksort.*: ([\d\.]*) sec.$',line)
next;
if(m):
seq = m.group(1)
if($line =~/^Sequential quicksort.*: ([\d\.]*) sec.$/) {
continue
$seq=$1; next;
m = re.match('^Parallel quicksort.*: ([\d\.]*) sec.$',line)
if(m):
if($line =~/^Parallel quicksort.*: ([\d\.]*) sec.$/) {
par = m.group(1)
$par=$1; next;
continue
m = re.match('^Built-in quicksort.*: ([\d\.]*) sec.$',line)
if($line =~/^Built-in quicksort.*: ([\d\.]*) sec.$/) {
if(m):
$libc=$1;
libc = m.group(1)
print OUTPUT "$size, $seq, $par, $libc\n";
OUTPUT.writelines(size+", "+seq+", "+par+", "+libc+"\n")
next;
print "[[file:"+output+"]]"
print "file:$output"
[[file:data.csv]]
* R functions :noexport:
Initialization and reading of the data.
@@ -248,7 +249,7 @@ our own experimental testbed with support of our university.
# Local Variables:
# Local Variables:
# eval: (add-to-list 'load-path ".")
# eval: (require 'org-install)
# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t)
(perl . t)
(python . t) ))
# eval: (org-babel-do-load-languages 'org-babel-load-languages '((shell . t) (R . t) (python . t) ))
# eval: (setq org-confirm-babel-evaluate nil)
# eval: (unless (boundp 'org-latex-classes) (setq org-latex-classes nil))
# eval: (add-to-list 'org-latex-classes '("IEEEtran"
