d3769b49
d3769b49
Konrad Hinsen
Révision de la traduction anglaise
f214aeb4
44 additions
49 deletions
+44
-49
+44
-49
d3769b49
@@ -15,24 +15,24 @@
held a three-hour teleconference between the
Morton Thiokol (manufacturer of one of the engines) and NASA. The
Morton Thiokol (
the
0°C)
on
the success of the flight and in particular on the performance of the
O-rings used in
motor
s. Indeed, no test
0°C)
for
O-rings used in
the engine
s. Indeed, no test
The following study t
herefore takes up some of the analyses carried out in this study
night
and whose objective was to assess
the potential influence of
the temperature and pressure to which the
seal
s are subjected
O-rings on their probability of malfunction. To do this, we
have the results of the experiments carried out by the
engineers
of NASA during the 6
years preceding the launch of the shuttle
akes up some of the analyses carried out that
night
with the objective of assessing
O-ring
s are subjected
the results of the experiments carried out by NASA
engineers
during the six
Data loading
So w
e start by loading this data:
Loading the data
W
@@ -68,16 +68,15 @@ data
The data set shows us the date of
the test, the number of joint
s
each test, the number of O-ring
s
number of identified
dys
functions.
mal
functions.
* Graphical data inspection
Flights where no incidents are found that do not provide any information
on the influence of temperature or pressure on the
dysfunctions, we focus on experiences where in the
at least one seal was defective.
@@ -94,7 +93,7 @@ data
All right, w
e have a high temperature variability but
W
@@ -114,17 +113,16 @@ print(matplot_lib_filename)
At first sight, it's not obvious but good, let's try it anyway
to estimate the impact of temperature $t$ on the probability of
malfunctions of a seal.
Suppose that each of the
6 toroidal seal
s is damaged with the same
does not
depends only on the temperature. If
we note $p(t)$
this probability, the
number
of joints $D$ malfunctioning when the flight is performed
at
temperature $t$ follows a binomial law
of parameter
$n=6$ and
six O-ring
$p(t)$ is
number
$D$ of malfunctioning O-rings during a flight
at
with parameters
$n=6$ and
@@ -166,9 +164,9 @@ and the standard error of this estimator is 0.122, in other words we
* Estimation of the probability of
The expected temperature on take-off day is 31°F. Let's try to
estimate the probability of
at
O-ring malfunction
he t
O-ring malfunction
at
@@ -190,9 +188,7 @@ print(matplot_lib_filename)
where we had a failure of at least one joint. Let's get back to the subject
to the set of initial data to estimate the probability of
failure of a seal:
@@ -202,21 +198,20 @@ print(np.sum(data.Malfunction)/np.sum(data.Count))
This probability is th
erefore about $p=0.065$, k
nowing that there is
a primary
seal a secondary seal
on each of the three parts of the
launcher, the probability of failure of
the two
joints of a launcher
is $p^2 \approx 0.00425$. The probability of failure of one of the
so the thrower is $1-(1-p^2)^3 \approximately 1.2%$. I
t would really be
no luck.... Everything is under control, so the takeoff can have
us about $p=0.065$. K
a primary
and a secondary O-ring
both
any
one of the
launchers is $1-(1-p^2)^3 \approximately 1.2%$. Tha
t would really be
Only the next day, the Challenger shuttle will explode and take away
with her seven crew members. Public opinion is
affected and in the subsequent investigation, the reliability of the
O-rings will be directly implicated. Beyond the problems
of internal communication at NASA, which have a lot to do with this
fiasco, the previous analysis includes (at least) a small
problem.... Can you find it? You are free to modify this
analysis and to look at this dataset from all angles in order to
to explain what's wrong.
