dc277b73
dc277b73
Marie-Gabrielle Dondon
Compléments Windows
c4f22946
20 additions
1 deletion
+20
-1
jupyter.org
module2/ressources/jupyter.org
+20
-1
dc277b73
@@ -43,6 +43,20 @@ Then you'll be able to use both languages in the same notebook by:
Note that this =%%R= notation allows you to use R for the whole cell but
an other possibility is to use =%R= to have a single line of R within a
python cell.
*** Windows
Download =rpy2= [[https://www.lfd.uci.edu/~gohlke/pythonlibs/#rpy2][binary file]] by choosing the right operating system.
Open a DOS console and type the following command:
python -m pip install rpy2‑2.9.4‑cp37‑cp37m‑win_amd64.whl # adapt filename
Install also =tzlocal=:
python -m pip install tzlocal
** Exporting a notebook
Obviously, you can convert to html or pdf using the using the =File > Download as > HTML= (or =PDF=) menu option. This can also be done from
the command line with the following command:
@@ -81,7 +95,7 @@ source activate mooc_rr
jupyter notebook
** Side note about Jupyter, JupyterLab, JupyterHub
** Side note about Jupyter, JupyterLab, JupyterHub...
Note that Jupyter notebooks are only a small part of the picture and
that Jupyter is now part of a bigger project: [[https://blog.jupyter.org/jupyterlab-is-ready-for-users-5a6f039b8906][JupyterLab]], which allows
you to mix various components (including notebooks) in your
@@ -96,6 +110,11 @@ the notebook export via latex works:
sudo apt-get install texlive-xetex wkhtmltopdf
*** Windows
Download and install MiKTeX from the [[https://miktex.org/download][MiKTeX webpage]]
by choosing the right operating system. You will be prompted to install some specific
packages when exporting to pdf.
** Jupyter extensions/plugins
*** Improving notebook readability
Here are a few extensions that can ease your life:
