From f14369510120b5a5286c4cac5bc1c0bb246de66a Mon Sep 17 00:00:00 2001 From: Vivien Date: Mon, 20 Apr 2020 15:34:01 +0200 Subject: [PATCH] Update --- Exo_eval_pairs.Rmd | 103 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 103 insertions(+) create mode 100644 Exo_eval_pairs.Rmd diff --git a/Exo_eval_pairs.Rmd b/Exo_eval_pairs.Rmd new file mode 100644 index 0000000..45961ab --- /dev/null +++ b/Exo_eval_pairs.Rmd @@ -0,0 +1,103 @@ +--- +title: "Exercice_eval_pairs" +author: "Vivien Gaujoux" +date: "4/20/2020" +output: + pdf_document: default + html_document: default +--- + +```{r setup, include=FALSE} +knitr::opts_chunk$set(echo = TRUE) +``` + +```{r setup, include=FALSE} +knitr::opts_chunk$set(echo = TRUE) +``` +# Exercice évalué par les pairs +## Importation et tri des données +```{r} +library(tidyverse) +``` + +```{r} +liglab2 <- read_table("http://mescal.imag.fr/membres/arnaud.legrand/teaching/2014/RICM4_EP_ping/liglab2.log.gz", col_names = FALSE) +liglab2 +``` + +```{r} +names(liglab2)[names(liglab2) == "X1"] <- "date" +liglab2<-separate(liglab2, X2, sep = " ", extra = "merge", +into = c("taille", "a_virer")) +liglab2<-separate(liglab2, a_virer, sep = "time=", extra = "merge", +into = c("a_virer", "time")) +liglab2$a_virer <- NULL +liglab2 +``` +```{r} + +liglab2$time = substr(liglab2$time,1,nchar(liglab2$time)-3) +liglab2$date = substr(liglab2$date,2,nchar(liglab2$date)-1) +liglab2$time <- as.numeric(as.character(liglab2$time)) +liglab2$taille <- as.numeric(as.character(liglab2$taille)) +lignes_na = apply(liglab2, 1, function(x) any(is.na(x))) +liglab2[lignes_na,] +``` + + + +```{r} +lignes_na = apply(liglab2, 1, function(x) any(is.na(x))) +liglab2[lignes_na,] +liglab2 <- liglab2 %>% drop_na("time") +``` + +## 1) Représentation graphique : +```{r} +ggplot(liglab2) + +geom_point(aes(x = date, y = time, color = taille)) + +scale_color_gradient(low = 'gray', high = 'gray0') +``` +Il semble que la taille des messages ne soit pas la seule en cause dans le temps de transmission. + +## 2) Représentation graphique : temps de transmission en fonction de la taille des messages + +```{r} +with(liglab2, plot(taille, time, type = "p")) + +``` +On peut voir la rupture à partir de 1500 octets environ. + +```{r} +donnees_low <- subset(liglab2, taille <= 1500) +donnees_high <-subset(liglab2, taille > 1500) +donnees_high +``` + +## 3) Régression linéaire : +```{r} +high_time.lm <- lm(time~taille, data = donnees_high) +summary(high_time.lm) +``` +```{r} +plot(high_time.lm) +``` +```{r} +low_time.lm <- lm(time~taille, data = donnees_low) +summary(low_time.lm) + +``` +```{r} +plot(low_time.lm) +``` +```{r} +tinytex::install_tinytex() +``` + + +La valeur $\alpha$\ et donc la latence des données de taille élevée est de 4.920748 et la valeur $\beta$\ est de 0.002779. +La valeur $\alpha$\ et donc la latence des données de taille basse est de 3.124 et la valeur $\beta$\ est de 0.0006248. + +Ces valeurs indiquent une capacité respectivement de 1/0.002779 et 1/0.0006248, soit 359.84 pour les données de taille élevée et 1600.051 pour les données de taille basse. + + -- 2.18.1
