Van-Duong LE
parent 8a0fa69d
......@@ -182,27 +182,9 @@
"execution_count": 29,
"# Predicted Probabilities from Logistic Regression\n",
"data['Predicted_Death_Prob'] = model.predict(data[['Age', 'Smoker_Code']])"
"execution_count": 30,
"execution_count": 32,
"name": "stderr",
"/opt/conda/lib/python3.6/site-packages/scipy/stats/stats.py:1713: FutureWarning: Using a non-tuple sequence for multidimensional indexing is deprecated; use `arr[tuple(seq)]` instead of `arr[seq]`. In the future this will be interpreted as an array index, `arr[np.array(seq)]`, which will result either in an error or a different result.\n",
" return np.add.reduce(sorted[indexer] * weights, axis=axis) / sumval\n"
"image/png": "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\n",
......@@ -217,7 +199,8 @@
"# Visualization using lmplot\n",
"data['Predicted_Death_Prob'] = model.predict(data[['Age', 'Smoker_Code']])\n",
"sns.lmplot(x='Age', y='Predicted_Death_Prob', hue='Smoker', data=data, logistic=True, aspect=1.5)\n",
"plt.title('Predicted Probability of Death by Age and Smoking Status')\n",
"plt.ylabel('Predicted Probability of Death')\n",
......@@ -225,6 +208,13 @@
"plt.show()"
"execution_count": null,
"source": []
