Avec corrections
parent cde2aa5c
...@@ -16,7 +16,7 @@ ...@@ -16,7 +16,7 @@
"execution_count": 42, "execution_count": 232,
"outputs": [ "outputs": [
...@@ -54,18 +54,19 @@ ...@@ -54,18 +54,19 @@
"27 QuizP 36 12 OrgMode\n", "27 QuizP 36 12 OrgMode\n",
"28 Exercices 195 1 Module 1\n", "28 Exercices 195 1 Module 1\n",
"29 Exercices 117 2 Module 2\n", "29 Exercices 117 2 Module 2\n",
"30 Exercices 85 3 Module 3\n" "30 Exercices 85 3 Module 3\n",
"31 ExoEvalPair 11 4 ExoEval\n"
"source": [ "source": [
"## Tableau\n", "## Tableau\n",
"\n", "\n",
"Type_init= list(donnees.columns[3:19])+list(donnees.columns[20:32])+list(donnees.columns[34:37])\n", "Type_init= list(donnees.columns[3:19])+list(donnees.columns[20:32])+list(donnees.columns[34:37])+[\"ExoEvalPair\"]\n",
"Type=[i.split()[0] for i in Type_init]\n", "Type=[i.split()[0] for i in Type_init]\n",
"Id=[int(i.split()[1]) for i in Type_init]\n", "Id=[int(i.split()[1]) for i in Type_init[:-1]]+[4]\n",
"Num=[(sum(donnees.loc[:,type]>0)) for type in Type_init]\n", "Num=[(sum(donnees.loc[:,type]>0)) for type in Type_init]\n",
"Label=[\"Module 1\",\"Module 1\",\"Module 1\",\"Module 1\",\"Module 1\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 3\",\"Module 3\",\"Module 4\",\"Module 4\",\"Module 4\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Module 1\",\"Module 2\",\"Module 3\"]\n", "Label=[\"Module 1\",\"Module 1\",\"Module 1\",\"Module 1\",\"Module 1\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 2\",\"Module 3\",\"Module 3\",\"Module 4\",\"Module 4\",\"Module 4\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Jupiter\",\"R\",\"OrgMode\",\"Module 1\",\"Module 2\",\"Module 3\",\"ExoEval\"]\n",
"tableau=pd.DataFrame({'Type':Type,\"Id\":Id,\"Num\":Num,\"Label\":Label})\n", "tableau=pd.DataFrame({'Type':Type,\"Id\":Id,\"Num\":Num,\"Label\":Label})\n",
"col=[\"Type\",\"Num\",\"Id\",\"Label\"]\n", "col=[\"Type\",\"Num\",\"Id\",\"Label\"]\n",
"tableau = tableau.loc[:, col]\n", "tableau = tableau.loc[:, col]\n",
...@@ -74,7 +75,7 @@ ...@@ -74,7 +75,7 @@
"execution_count": 215, "execution_count": 233,
...@@ -139,6 +140,36 @@ ...@@ -139,6 +140,36 @@
" \n", " \n",
"Graphique('inria_41016_self-paced_grade_report_2020-04-02-1234.csv','inria_41016_self-paced_grade_report_2020-03-27-0806.csv')" "Graphique('inria_41016_self-paced_grade_report_2020-04-02-1234.csv','inria_41016_self-paced_grade_report_2020-03-27-0806.csv')"
"execution_count": 245,
"Nombre d'élèves qui on commencé les exercices : 326\n",
"Nombre d'élèves qui on au dessus de la moyenne : 116\n",
"Nombre d'élèves qui on fait ExoEvalPair : 11\n",
"Moyenne ExoEvalPair : 0.8295454545454546\n"
"## Données supplémentaires\n",
"exos=sum(donnees.loc[:,\"grade\"]>0)\n",
"moyenne=sum(donnees.loc[:,\"grade\"]>0.5)\n",
"Pair=sum(donnees.loc[:,\"ExoEvalPair\"]>0)\n",
"moyenne_Pair=np.mean(donnees.loc[donnees.loc[:,\"ExoEvalPair\"]>0,\"ExoEvalPair\"])\n",
"print(f\"Nombre d'élèves qui on commencé les exercices : {exos}\")\n",
"print(f\"Nombre d'élèves qui on au dessus de la moyenne : {moyenne}\")\n",
"print(f\"Nombre d'élèves qui on fait ExoEvalPair : {Pair}\")\n",
"print(f\"Moyenne ExoEvalPair : {moyenne_Pair}\")"
"metadata": { "metadata": {
