Commit 836d8f54 authored by pmatrangolo's avatar pmatrangolo
doing exercice 2
parent 3bf897bf
"cells": [], "cells": [
"## Récupération des valeurs"
"execution_count": 1,
"[14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n"
"val_tab = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]\n",
"print(val_tab)"
"execution_count": 2,
"import numpy as np"
"## Calcul de la moyenne"
"execution_count": 3,
"14.113000000000001\n"
"print(np.mean(val_tab))"
"## Recherche du minimum"
"execution_count": 4,
"2.8\n"
"print(np.min(val_tab))"
"## Recherche du maximum"
"execution_count": 5,
"23.4\n"
"print(np.max(val_tab))"
"## Calcul de la médiane"
"execution_count": 6,
"14.5\n"
"print(np.median(val_tab))"
"## Calcul de l'écart-type"
"execution_count": 11,
"4.312369534258399\n"
"print(np.std(val_tab))"
"metadata": { "metadata": {
"interpreter": {
"hash": "68a78512f08647dba0d657fd7997aaa8ad8c9d9af1a9b906b8cea64366ea2030"
"display_name": "Python 3", "display_name": "Python 3.9.13 64-bit (windows store)",
"name": "python3" "name": "python3"
...@@ -16,10 +174,9 @@ ...@@ -16,10 +174,9 @@
"version": "3.6.3" "version": "3.9.13"
"nbformat": 4, "nbformat": 4,
