68d6b36d6dfa73b2f7f25db9fb7770c1
6a979781
6a979781
Replace exercice_python_fr.org
aa2b8587
31 additions
74 deletions
+31
-74
module2/exo2/exercice_python_fr.org
+31
-74
6a979781
+TITLE: Votre titre
+AUTHOR: Votre nom
DATE: La date du jour
LANGUAGE: f
r
#+PROPERTY: header-args :eval never-export
-*- mode: org -*-
-*- coding: utf8 -*-
TITLE: Exercice 2
AUTHOR: Victo
r
+LANGUAGE: French
#+PROPERTY: header-args :session :exports both
* Quelques explications
from numpy import mean, median, std
data = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
document.
data_mean = mean(data)
print(f"Mean: {round(data_mean, 2)}")
p
ython de la façon suivante (et on l'exécute en faisant ~C-c C-c~):
data_min = min(data)
p
rint(f"Min: {round(data_min, 2)}")
print("Hello world!")
data_max = max(data)
print(f"Max: {round(data_max, 2)}")
: Hello world!
data_median = median(data)
print(f"Median: {round(data_median, 2)}")
data_stddev = std(data, ddof=1)
print(f"Standard deviation: {round(data_stddev, 2)}")
~C-c C-c~).
import numpy
x=numpy.linspace(-15,15)
print(x)
: Mean: 14.11
: Min: 2.8
: Max: 23.4
: Median: 14.5
: Standard deviation: 4.33
#+begin_src python :results file :session :var matplot_lib_filename=(org-babel-temp-file "figure" ".png") :exports both
plt.figure(figsize=(10,5)
plt.plot(x,numpy.cos(x)/x
plt.tight_layout(
fig, ax = plt.subplots(2
ax[0].plot(data
ax[1].hist(data
[[file:./cosxsx.png]]
compréhensible sur GitLab.
[[file:/tmp/babel-Cll6iL/figureWKO5RN.png]]
