Module 2 Exercise 3 - plots
parent cc18009f
#+TITLE: Your title
#+AUTHOR: Your name
#+TITLE: Module 2 Exercise 3 - Data visualization
#+AUTHOR: Miguel Felipe Silva Vasconcelos
#+DATE: Today's date
#+LANGUAGE: en
......@@ -11,84 +11,71 @@
* Some explanations
https://orgmode.org/guide/.
* Reading input
Creating the data structure to store the following numbers:
#+begin_src
14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9,
18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1,
13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9,
12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0,
13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1,
13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1,
14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8,
8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4,
16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0
print("Hello world!")
array = np.array([14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9,
16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0])
: Hello world!
C-c~.
* Source for creating the graphs
[[https://matplotlib.org/2.0.2/users/pyplot_tutorial.html][matplot
tutorial's page]]
import numpy
x=numpy.linspace(-15,15)
print(x)
* Creating the histogram
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
#+begin_src python :results output file :session *python* :var matplot_lib_filename="histogram.png" :exports both
from matplotlib import pyplot as plt
plt.figure(1) # the first figure - we need this, otherwise the plots will overlap
plt.hist(array)
plt.title('Histogram')
plt.axis([0, 25, 0, 25])
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
[[file:histogram.png]]
* Creating the plot
#+begin_src python :results output file :session *python* :var matplot_lib_filename2="simple_plot.png" :exports both
plt.figure(2) # the second figure
plt.plot(array)
plt.title('Simple plot')
plt.axis([0, 100, 0, 25])
plt.savefig(matplot_lib_filename2)
print(matplot_lib_filename2)
[[file:simple_plot.png]]
