6ba812c8b193df42eeb5de9ab7cfb35d
2aa9afbd
2aa9afbd
migvasc
parcial text file - modl 2 ex3
92f06457
13 additions
79 deletions
+13
-79
exercice_python_en.org
module2/exo4/exercice_python_en.org
+13
-79
2aa9afbd
#+TITLE:
Your title
#+AUTHOR:
Your name
#+DATE:
Today's date
#+TITLE:
Analysis of custom data - Module 2 - Exercise 4
#+AUTHOR:
Miguel Felipe Silva Vasconcelos
#+DATE:
28/02/2021
#+LANGUAGE: en
@@ -11,84 +11,18 @@
Some explanations
Introduction
https://orgmode.org/guide/.
For the purpose of only solving this exercise, I'm using data that
was randomly generated. The file /data.csv/ contains two columns:
- The first column represents the day of the month
- The second column represents how many minutes were spent doing
determined task (in this case, studying for this MOOC)
The analysis will present the following metrics: median, average,
standard deviation, maximum,
and minimum value, regarding the time spent on each day.
print("Hello world!")
* Results of the experiments
: Hello world!
C-c~.
import numpy
x=numpy.linspace(-15,15)
print(x)
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
