module 2 exercise 1
parent ded3bd3c
#+TITLE: Your title
#+AUTHOR: Your name
#+DATE: Today's date
#+TITLE: On the computation of pi
#+AUTHOR: Miguel Felipe Silva Vasconcelos
#+DATE: 25-02-2021
#+LANGUAGE: en
......@@ -11,84 +11,74 @@
* Some explanations
https://orgmode.org/guide/.
* Asking the math library
My computer tells me that \pi is approximatively
from math import *
pi
print("Hello world!")
: 3.141592653589793
* Buffon's needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon%27s_needle_problem][Buffon's]] needle, we get the approximation
np.random.seed(seed=42)
N = 10000
2/(sum((x+np.sin(theta))>1)/N)
: Hello world!
: 3.128911138923655
C-c~.
* Using a surface fraction argument
A method that is easier to understand and does not make use of the sin
function is based on the fact that if $X \sim U(0,1)$ and $Y \sim U(0,1)$,
then $P[X^2+Y^2 \le 1]=\pi/4$ (see
[[https://en.wikipedia.org/wiki/Monte_Carlo_method]["Monte Carlo
method" on Wikipedia]]). The following code uses this approach:
import numpy
x=numpy.linspace(-15,15)
print(x)
#+begin_src python :results output :session *python* :var matplot_lib_filename="figure.png" :exports code
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
N = 1000
accept = (x*x+y*y) <= 1
fig, ax = plt.subplots(1)
ax.set_aspect('equal')
[[file:./cosxsx.png]]
transparent and reproducible.
understandable on GitLab.
followed by ~Tab~.
: figure.png
[[./figure.png]]
It is then straightforward to obtain a (not really good) approximation
to \pi by counting how many times, on average, $X^2+Y^2$ is smaller than 1:
4*np.mean(accept)
: 3.112
