no commit message
parent 0fceb888
......@@ -2479,8 +2479,12 @@
"# Define the name of the local file\n",
"local_data_file = \"incidence-PAY-3.csv\""
"%matplotlib inline\n",
"import pandas as pd\n",
"import isoweek\n",
"import os\n",
"import requests\n"
......@@ -2488,13 +2492,45 @@
"execution_count": null,
"# Define the URL of the remote CSV file\n",
"remote_data_url = \"http://www.sentiweb.fr/datasets/incidence-PAY-3.csv\"\n",
"local_data_file = \"incidence-PAY-3.csv\"\n"
"execution_count": 16,
"ename": "NameError",
"evalue": "name 'local_data_file' is not defined",
"output_type": "error",
"traceback": [
"\u001b[0;31mNameError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m<ipython-input-16-f9172fedfd57>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m\u001b[0m\n\u001b[1;32m 1\u001b[0m \u001b[0;31m# Read the data from the local file into a Pandas DataFrame\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m----> 2\u001b[0;31m \u001b[0mraw_data\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mread_csv\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mlocal_data_file\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mskiprows\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m",
"\u001b[0;31mNameError\u001b[0m: name 'local_data_file' is not defined"
"# Check if the local file exists\n",
"if not os.path.isfile(local_data_file):\n",
" # If the local file does not exist, download the data from the remote URL\n",
" response = requests.get(remote_data_url)\n",
" with open(local_data_file, \"w\") as f:\n",
" f.write(response.text)"
" f.write(response.text)\n",
"# Read the data from the local file into a Pandas DataFrame\n",
"raw_data = pd.read_csv(local_data_file, skiprows=1)\n",
"# Remove rows with missing values\n",
"data = raw_data.dropna().copy()\n",
"\n"
......@@ -2503,8 +2539,50 @@
"raw_data = pd.read_csv(local_data_file, skiprows=1)"
"# Define a function to convert year and week integers to Pandas Period objects\n",
"def convert_week(year_and_week_int):\n",
" year_and_week_str = str(year_and_week_int)\n",
" year = int(year_and_week_str[:4])\n",
" week = int(year_and_week_str[4:])\n",
" w = isoweek.Week(year, week)\n",
" return pd.Period(w.day(0), 'W')\n",
"# Add a column to the DataFrame containing the Period objects\n",
"data['period'] = [convert_week(yw) for yw in data['week']]\n",
"# Sort the data by the period column\n",
"sorted_data = data.set_index('period').sort_index()\n",
"# Check for gaps in the data and print any that are found\n",
"periods = sorted_data.index\n",
"for p1, p2 in zip(periods[:-1], periods[1:]):\n",
" delta = p2.to_timestamp() - p1.end_time\n",
" if delta > pd.Timedelta('1s'):\n",
" print(p1, p2)\n",
"# Plot the incidence data over time\n",
"sorted_data['inc'].plot()\n",
"# Plot the last 200 data points\n",
"sorted_data['inc'][-200:].plot()\n",
"# Compute the total incidence for each year and plot the results\n",
"first_august_week = [pd.Period(pd.Timestamp(y, 8, 1), 'W')\n",
" for y in range(1985,\n",
" sorted_data.index[-1].year)]\n",
"year = []\n",
"yearly_incidence = []\n",
"for week1, week2 in zip(first_august_week[:-1],\n",
" first_august_week[1:]):\n",
" one_year = sorted_data['inc'][week1:week2-1]\n",
" assert abs(len(one_year)-52) < 2\n",
" yearly_incidence.append(one_year.sum())\n",
" year.append(week2.year)\n",
"yearly_incidence = pd.Series(data=yearly_incidence, index=year)\n",
"yearly_incidence.plot(style='*')\n",
"yearly_incidence.sort_values()\n",
"yearly_incidence.hist(xrot=20)\n"
