732afbed1f51733fba4ec4ed0e9bd727
9c8fe393
9c8fe393
Update exercice_python_fr.org
fa9d44ea
29 additions
66 deletions
+29
-66
module2/exo2/exercice_python_fr.org
+29
-66
9c8fe393
@@ -11,83 +11,46 @@
@@ -11,83 +11,46 @@
* Quelques explications
donnees = [14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9, 12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0]
moyenne = np.mean(donnees)
document.
print("Hello world!")
Hello world!
14.113000000000001
~C-c C-c~).
ecart_type = np.std(donnees, ddof=1)
import numpy
x=numpy.linspace(-15,15)
print(x)
: 4.334094455301447
plt.figure(figsize=(10,5))
plt.plot(x,numpy.cos(x)/x)
plt.tight_layout()
minimum = np.min(donnees)
[[file:./cosxsx.png]]
: 2.8
mediane = np.median(donnees)
: 14.
compréhensible sur GitLab.
maximum = np.max(donnees)
: 23.4
