diff --git a/module3/exo3/exercice.ipynb b/module3/exo3/exercice.ipynb
index 0bbbe371b01e359e381e43239412d77bf53fb1fb..6915dc093891f2519e5572c8468cb2ec4915c8e7 100644
--- a/module3/exo3/exercice.ipynb
+++ b/module3/exo3/exercice.ipynb
@@ -1,5 +1,2396 @@
- "cells": [],
+ "cells": [
+ "cell_type": "code",
+ "execution_count": 54,
+ "metadata": {},
+ "outputs": [],
+ "source": [
+ "import pandas as pd\n",
+ "import matplotlib.pyplot as plt\n",
+ "from scipy.optimize import curve_fit\n",
+ "import numpy as np\n",
+ "import isoweek # Pour gérer les semaines ISO"
+ "execution_count": 55,
+ "metadata": {},
+ "outputs": [],
+ "source": [
+ "data_url = \"https://scrippsco2.ucsd.edu/assets/data/atmospheric/stations/in_situ_co2/monthly/monthly_in_situ_co2_mlo.csv\"\n",
+ "data = \"monthly_in_situ_co2_mlo.csv\"\n",
+ "# Vérifier si le fichier local existe, et s'il n'existe pas, le télécharger depuis l'URL\n",
+ "import os\n",
+ "import urllib.request\n",
+ "\n",
+ "# Vérifier si le fichier local n'existe pas\n",
+ "if not os.path.exists(data):\n",
+ " # Télécharger les données depuis l'URL et les enregistrer dans le fichier local\n",
+ " urllib.request.urlretrieve(data_url, data)"
+ "execution_count": 56,
+ "metadata": {},
+ "outputs": [
+ "data": {
+ "text/html": [
\n",
+ "\n",
\n",
+ " \n",
+ " \n",
+ " | \n",
+ " Yr | \n",
+ " Mn | \n",
+ " Date | \n",
+ " Date | \n",
+ " CO2 | \n",
+ " seasonally | \n",
+ " fit | \n",
+ " CO2 | \n",
+ " Sta | \n",
\n",
+ " \n",
+ " \n",
+ " \n",
+ " | 0 | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " adjusted | \n",
+ " | \n",
+ " adjusted fit | \n",
+ " filled | \n",
+ " adjusted filled | \n",
+ " NaN | \n",
\n",
+ " \n",
+ " | 1 | \n",
+ " | \n",
+ " | \n",
+ " Excel | \n",
+ " | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " NaN | \n",
\n",
+ " \n",
+ " | 2 | \n",
+ " 1958 | \n",
+ " 01 | \n",
+ " 21200 | \n",
+ " 1958.0411 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 3 | \n",
+ " 1958 | \n",
+ " 02 | \n",
+ " 21231 | \n",
+ " 1958.1260 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 4 | \n",
+ " 1958 | \n",
+ " 03 | \n",
+ " 21259 | \n",
+ " 1958.2027 | \n",
+ " 315.71 | \n",
+ " 314.44 | \n",
+ " 316.19 | \n",
+ " 314.91 | \n",
+ " 315.71 | \n",
+ " 314.44 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 5 | \n",
+ " 1958 | \n",
+ " 04 | \n",
+ " 21290 | \n",
+ " 1958.2877 | \n",
+ " 317.45 | \n",
+ " 315.16 | \n",
+ " 317.30 | \n",
+ " 314.99 | \n",
+ " 317.45 | \n",
+ " 315.16 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 6 | \n",
+ " 1958 | \n",
+ " 05 | \n",
+ " 21320 | \n",
+ " 1958.3699 | \n",
+ " 317.51 | \n",
+ " 314.69 | \n",
+ " 317.89 | \n",
+ " 315.07 | \n",
+ " 317.51 | \n",
+ " 314.69 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 7 | \n",
+ " 1958 | \n",
+ " 06 | \n",
+ " 21351 | \n",
+ " 1958.4548 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " 317.27 | \n",
+ " 315.15 | \n",
+ " 317.27 | \n",
+ " 315.15 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 8 | \n",
+ " 1958 | \n",
+ " 07 | \n",
+ " 21381 | \n",
+ " 1958.5370 | \n",
+ " 315.87 | \n",
+ " 315.20 | \n",
+ " 315.86 | \n",
+ " 315.22 | \n",
+ " 315.87 | \n",
+ " 315.20 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 9 | \n",
+ " 1958 | \n",
+ " 08 | \n",
+ " 21412 | \n",
+ " 1958.6219 | \n",
+ " 314.93 | \n",
+ " 316.21 | \n",
+ " 313.97 | \n",
+ " 315.29 | \n",
+ " 314.93 | \n",
+ " 316.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 10 | \n",
+ " 1958 | \n",
+ " 09 | \n",
+ " 21443 | \n",
+ " 1958.7068 | \n",
+ " 313.21 | \n",
+ " 316.11 | \n",
+ " 312.44 | \n",
+ " 315.35 | \n",
+ " 313.21 | \n",
+ " 316.11 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 11 | \n",
+ " 1958 | \n",
+ " 10 | \n",
+ " 21473 | \n",
+ " 1958.7890 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " 312.42 | \n",
+ " 315.41 | \n",
+ " 312.42 | \n",
+ " 315.41 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 12 | \n",
+ " 1958 | \n",
+ " 11 | \n",
+ " 21504 | \n",
+ " 1958.8740 | \n",
+ " 313.33 | \n",
+ " 315.21 | \n",
+ " 313.61 | \n",
+ " 315.46 | \n",
+ " 313.33 | \n",
+ " 315.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 13 | \n",
+ " 1958 | \n",
+ " 12 | \n",
+ " 21534 | \n",
+ " 1958.9562 | \n",
+ " 314.67 | \n",
+ " 315.43 | \n",
+ " 314.77 | \n",
+ " 315.52 | \n",
+ " 314.67 | \n",
+ " 315.43 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 14 | \n",
+ " 1959 | \n",
+ " 01 | \n",
+ " 21565 | \n",
+ " 1959.0411 | \n",
+ " 315.58 | \n",
+ " 315.52 | \n",
+ " 315.64 | \n",
+ " 315.57 | \n",
+ " 315.58 | \n",
+ " 315.52 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 15 | \n",
+ " 1959 | \n",
+ " 02 | \n",
+ " 21596 | \n",
+ " 1959.1260 | \n",
+ " 316.49 | \n",
+ " 315.84 | \n",
+ " 316.29 | \n",
+ " 315.63 | \n",
+ " 316.49 | \n",
+ " 315.84 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 16 | \n",
+ " 1959 | \n",
+ " 03 | \n",
+ " 21624 | \n",
+ " 1959.2027 | \n",
+ " 316.65 | \n",
+ " 315.38 | \n",
+ " 316.98 | \n",
+ " 315.70 | \n",
+ " 316.65 | \n",
+ " 315.38 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 17 | \n",
+ " 1959 | \n",
+ " 04 | \n",
+ " 21655 | \n",
+ " 1959.2877 | \n",
+ " 317.72 | \n",
+ " 315.42 | \n",
+ " 318.09 | \n",
+ " 315.77 | \n",
+ " 317.72 | \n",
+ " 315.42 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 18 | \n",
+ " 1959 | \n",
+ " 05 | \n",
+ " 21685 | \n",
+ " 1959.3699 | \n",
+ " 318.29 | \n",
+ " 315.46 | \n",
+ " 318.68 | \n",
+ " 315.85 | \n",
+ " 318.29 | \n",
+ " 315.46 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 19 | \n",
+ " 1959 | \n",
+ " 06 | \n",
+ " 21716 | \n",
+ " 1959.4548 | \n",
+ " 318.15 | \n",
+ " 316.00 | \n",
+ " 318.07 | \n",
+ " 315.94 | \n",
+ " 318.15 | \n",
+ " 316.00 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 20 | \n",
+ " 1959 | \n",
+ " 07 | \n",
+ " 21746 | \n",
+ " 1959.5370 | \n",
+ " 316.54 | \n",
+ " 315.87 | \n",
+ " 316.67 | \n",
+ " 316.03 | \n",
+ " 316.54 | \n",
+ " 315.87 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 21 | \n",
+ " 1959 | \n",
+ " 08 | \n",
+ " 21777 | \n",
+ " 1959.6219 | \n",
+ " 314.80 | \n",
+ " 316.09 | \n",
+ " 314.80 | \n",
+ " 316.13 | \n",
+ " 314.80 | \n",
+ " 316.09 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 22 | \n",
+ " 1959 | \n",
+ " 09 | \n",
+ " 21808 | \n",
+ " 1959.7068 | \n",
+ " 313.84 | \n",
+ " 316.75 | \n",
+ " 313.30 | \n",
+ " 316.22 | \n",
+ " 313.84 | \n",
+ " 316.75 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 23 | \n",
+ " 1959 | \n",
+ " 10 | \n",
+ " 21838 | \n",
+ " 1959.7890 | \n",
+ " 313.33 | \n",
+ " 316.34 | \n",
+ " 313.31 | \n",
+ " 316.31 | \n",
+ " 313.33 | \n",
+ " 316.34 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 24 | \n",
+ " 1959 | \n",
+ " 11 | \n",
+ " 21869 | \n",
+ " 1959.8740 | \n",
+ " 314.81 | \n",
+ " 316.69 | \n",
+ " 314.53 | \n",
+ " 316.40 | \n",
+ " 314.81 | \n",
+ " 316.69 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 25 | \n",
+ " 1959 | \n",
+ " 12 | \n",
+ " 21899 | \n",
+ " 1959.9562 | \n",
+ " 315.58 | \n",
+ " 316.35 | \n",
+ " 315.72 | \n",
+ " 316.48 | \n",
+ " 315.58 | \n",
+ " 316.35 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 26 | \n",
+ " 1960 | \n",
+ " 01 | \n",
+ " 21930 | \n",
+ " 1960.0410 | \n",
+ " 316.43 | \n",
+ " 316.37 | \n",
+ " 316.63 | \n",
+ " 316.56 | \n",
+ " 316.43 | \n",
+ " 316.37 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 27 | \n",
+ " 1960 | \n",
+ " 02 | \n",
+ " 21961 | \n",
+ " 1960.1257 | \n",
+ " 316.98 | \n",
+ " 316.33 | \n",
+ " 317.29 | \n",
+ " 316.64 | \n",
+ " 316.98 | \n",
+ " 316.33 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 28 | \n",
+ " 1960 | \n",
+ " 03 | \n",
+ " 21990 | \n",
+ " 1960.2049 | \n",
+ " 317.58 | \n",
+ " 316.28 | \n",
+ " 318.03 | \n",
+ " 316.72 | \n",
+ " 317.58 | \n",
+ " 316.28 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 29 | \n",
+ " 1960 | \n",
+ " 04 | \n",
+ " 22021 | \n",
+ " 1960.2896 | \n",
+ " 319.03 | \n",
+ " 316.70 | \n",
+ " 319.14 | \n",
+ " 316.79 | \n",
+ " 319.03 | \n",
+ " 316.70 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
\n",
+ " \n",
+ " | 764 | \n",
+ " 2021 | \n",
+ " 07 | \n",
+ " 44392 | \n",
+ " 2021.5370 | \n",
+ " 416.65 | \n",
+ " 415.85 | \n",
+ " 416.95 | \n",
+ " 416.18 | \n",
+ " 416.65 | \n",
+ " 415.85 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 765 | \n",
+ " 2021 | \n",
+ " 08 | \n",
+ " 44423 | \n",
+ " 2021.6219 | \n",
+ " 414.34 | \n",
+ " 415.89 | \n",
+ " 414.78 | \n",
+ " 416.36 | \n",
+ " 414.34 | \n",
+ " 415.89 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 766 | \n",
+ " 2021 | \n",
+ " 09 | \n",
+ " 44454 | \n",
+ " 2021.7068 | \n",
+ " 412.90 | \n",
+ " 416.40 | \n",
+ " 413.04 | \n",
+ " 416.55 | \n",
+ " 412.90 | \n",
+ " 416.40 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 767 | \n",
+ " 2021 | \n",
+ " 10 | \n",
+ " 44484 | \n",
+ " 2021.7890 | \n",
+ " 413.55 | \n",
+ " 417.16 | \n",
+ " 413.14 | \n",
+ " 416.74 | \n",
+ " 413.55 | \n",
+ " 417.16 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 768 | \n",
+ " 2021 | \n",
+ " 11 | \n",
+ " 44515 | \n",
+ " 2021.8740 | \n",
+ " 414.82 | \n",
+ " 417.08 | \n",
+ " 414.69 | \n",
+ " 416.92 | \n",
+ " 414.82 | \n",
+ " 417.08 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 769 | \n",
+ " 2021 | \n",
+ " 12 | \n",
+ " 44545 | \n",
+ " 2021.9562 | \n",
+ " 416.43 | \n",
+ " 417.36 | \n",
+ " 416.19 | \n",
+ " 417.10 | \n",
+ " 416.43 | \n",
+ " 417.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 770 | \n",
+ " 2022 | \n",
+ " 01 | \n",
+ " 44576 | \n",
+ " 2022.0411 | \n",
+ " 418.01 | \n",
+ " 417.94 | \n",
+ " 417.34 | \n",
+ " 417.26 | \n",
+ " 418.01 | \n",
+ " 417.94 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 771 | \n",
+ " 2022 | \n",
+ " 02 | \n",
+ " 44607 | \n",
+ " 2022.1260 | \n",
+ " 418.99 | \n",
+ " 418.21 | \n",
+ " 418.21 | \n",
+ " 417.42 | \n",
+ " 418.99 | \n",
+ " 418.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 772 | \n",
+ " 2022 | \n",
+ " 03 | \n",
+ " 44635 | \n",
+ " 2022.2027 | \n",
+ " 418.45 | \n",
+ " 416.92 | \n",
+ " 419.11 | \n",
+ " 417.56 | \n",
+ " 418.45 | \n",
+ " 416.92 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 773 | \n",
+ " 2022 | \n",
+ " 04 | \n",
+ " 44666 | \n",
+ " 2022.2877 | \n",
+ " 420.02 | \n",
+ " 417.25 | \n",
+ " 420.50 | \n",
+ " 417.71 | \n",
+ " 420.02 | \n",
+ " 417.25 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 774 | \n",
+ " 2022 | \n",
+ " 05 | \n",
+ " 44696 | \n",
+ " 2022.3699 | \n",
+ " 420.77 | \n",
+ " 417.36 | \n",
+ " 421.27 | \n",
+ " 417.86 | \n",
+ " 420.77 | \n",
+ " 417.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 775 | \n",
+ " 2022 | \n",
+ " 06 | \n",
+ " 44727 | \n",
+ " 2022.4548 | \n",
+ " 420.68 | \n",
+ " 418.09 | \n",
+ " 420.60 | \n",
+ " 418.03 | \n",
+ " 420.68 | \n",
+ " 418.09 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 776 | \n",
+ " 2022 | \n",
+ " 07 | \n",
+ " 44757 | \n",
+ " 2022.5370 | \n",
+ " 418.68 | \n",
+ " 417.87 | \n",
+ " 418.98 | \n",
+ " 418.21 | \n",
+ " 418.68 | \n",
+ " 417.87 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 777 | \n",
+ " 2022 | \n",
+ " 08 | \n",
+ " 44788 | \n",
+ " 2022.6219 | \n",
+ " 416.76 | \n",
+ " 418.31 | \n",
+ " 416.80 | \n",
+ " 418.40 | \n",
+ " 416.76 | \n",
+ " 418.31 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 778 | \n",
+ " 2022 | \n",
+ " 09 | \n",
+ " 44819 | \n",
+ " 2022.7068 | \n",
+ " 415.41 | \n",
+ " 418.91 | \n",
+ " 415.07 | \n",
+ " 418.59 | \n",
+ " 415.41 | \n",
+ " 418.91 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 779 | \n",
+ " 2022 | \n",
+ " 10 | \n",
+ " 44849 | \n",
+ " 2022.7890 | \n",
+ " 415.31 | \n",
+ " 418.93 | \n",
+ " 415.18 | \n",
+ " 418.78 | \n",
+ " 415.31 | \n",
+ " 418.93 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 780 | \n",
+ " 2022 | \n",
+ " 11 | \n",
+ " 44880 | \n",
+ " 2022.8740 | \n",
+ " 417.04 | \n",
+ " 419.31 | \n",
+ " 416.74 | \n",
+ " 418.98 | \n",
+ " 417.04 | \n",
+ " 419.31 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 781 | \n",
+ " 2022 | \n",
+ " 12 | \n",
+ " 44910 | \n",
+ " 2022.9562 | \n",
+ " 418.57 | \n",
+ " 419.49 | \n",
+ " 418.27 | \n",
+ " 419.18 | \n",
+ " 418.57 | \n",
+ " 419.49 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 782 | \n",
+ " 2023 | \n",
+ " 01 | \n",
+ " 44941 | \n",
+ " 2023.0411 | \n",
+ " 419.24 | \n",
+ " 419.17 | \n",
+ " 419.46 | \n",
+ " 419.38 | \n",
+ " 419.24 | \n",
+ " 419.17 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 783 | \n",
+ " 2023 | \n",
+ " 02 | \n",
+ " 44972 | \n",
+ " 2023.1260 | \n",
+ " 420.33 | \n",
+ " 419.55 | \n",
+ " 420.38 | \n",
+ " 419.59 | \n",
+ " 420.33 | \n",
+ " 419.55 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 784 | \n",
+ " 2023 | \n",
+ " 03 | \n",
+ " 45000 | \n",
+ " 2023.2027 | \n",
+ " 420.51 | \n",
+ " 418.97 | \n",
+ " 421.34 | \n",
+ " 419.79 | \n",
+ " 420.51 | \n",
+ " 418.97 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 785 | \n",
+ " 2023 | \n",
+ " 04 | \n",
+ " 45031 | \n",
+ " 2023.2877 | \n",
+ " 422.73 | \n",
+ " 419.95 | \n",
+ " 422.81 | \n",
+ " 420.01 | \n",
+ " 422.73 | \n",
+ " 419.95 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 786 | \n",
+ " 2023 | \n",
+ " 05 | \n",
+ " 45061 | \n",
+ " 2023.3699 | \n",
+ " 423.78 | \n",
+ " 420.36 | \n",
+ " 423.65 | \n",
+ " 420.23 | \n",
+ " 423.78 | \n",
+ " 420.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 787 | \n",
+ " 2023 | \n",
+ " 06 | \n",
+ " 45092 | \n",
+ " 2023.4548 | \n",
+ " 423.39 | \n",
+ " 420.80 | \n",
+ " 423.03 | \n",
+ " 420.46 | \n",
+ " 423.39 | \n",
+ " 420.80 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 788 | \n",
+ " 2023 | \n",
+ " 07 | \n",
+ " 45122 | \n",
+ " 2023.5370 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 789 | \n",
+ " 2023 | \n",
+ " 08 | \n",
+ " 45153 | \n",
+ " 2023.6219 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 790 | \n",
+ " 2023 | \n",
+ " 09 | \n",
+ " 45184 | \n",
+ " 2023.7068 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 791 | \n",
+ " 2023 | \n",
+ " 10 | \n",
+ " 45214 | \n",
+ " 2023.7890 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 792 | \n",
+ " 2023 | \n",
+ " 11 | \n",
+ " 45245 | \n",
+ " 2023.8740 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 793 | \n",
+ " 2023 | \n",
+ " 12 | \n",
+ " 45275 | \n",
+ " 2023.9562 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
\n",
794 rows × 11 columns
\n",
+ "text/plain": [
+ " Yr Mn Date Date CO2 seasonally fit \\\n",
+ "0 adjusted \n",
+ "1 Excel [ppm] [ppm] [ppm] \n",
+ "2 1958 01 21200 1958.0411 -99.99 -99.99 -99.99 \n",
+ "3 1958 02 21231 1958.1260 -99.99 -99.99 -99.99 \n",
+ "4 1958 03 21259 1958.2027 315.71 314.44 316.19 \n",
+ "5 1958 04 21290 1958.2877 317.45 315.16 317.30 \n",
+ "6 1958 05 21320 1958.3699 317.51 314.69 317.89 \n",
+ "7 1958 06 21351 1958.4548 -99.99 -99.99 317.27 \n",
+ "8 1958 07 21381 1958.5370 315.87 315.20 315.86 \n",
+ "9 1958 08 21412 1958.6219 314.93 316.21 313.97 \n",
+ "10 1958 09 21443 1958.7068 313.21 316.11 312.44 \n",
+ "11 1958 10 21473 1958.7890 -99.99 -99.99 312.42 \n",
+ "12 1958 11 21504 1958.8740 313.33 315.21 313.61 \n",
+ "13 1958 12 21534 1958.9562 314.67 315.43 314.77 \n",
+ "14 1959 01 21565 1959.0411 315.58 315.52 315.64 \n",
+ "15 1959 02 21596 1959.1260 316.49 315.84 316.29 \n",
+ "16 1959 03 21624 1959.2027 316.65 315.38 316.98 \n",
+ "17 1959 04 21655 1959.2877 317.72 315.42 318.09 \n",
+ "18 1959 05 21685 1959.3699 318.29 315.46 318.68 \n",
+ "19 1959 06 21716 1959.4548 318.15 316.00 318.07 \n",
+ "20 1959 07 21746 1959.5370 316.54 315.87 316.67 \n",
+ "21 1959 08 21777 1959.6219 314.80 316.09 314.80 \n",
+ "22 1959 09 21808 1959.7068 313.84 316.75 313.30 \n",
+ "23 1959 10 21838 1959.7890 313.33 316.34 313.31 \n",
+ "24 1959 11 21869 1959.8740 314.81 316.69 314.53 \n",
+ "25 1959 12 21899 1959.9562 315.58 316.35 315.72 \n",
+ "26 1960 01 21930 1960.0410 316.43 316.37 316.63 \n",
+ "27 1960 02 21961 1960.1257 316.98 316.33 317.29 \n",
+ "28 1960 03 21990 1960.2049 317.58 316.28 318.03 \n",
+ "29 1960 04 22021 1960.2896 319.03 316.70 319.14 \n",
+ ".. ... ... ... ... ... ... ... \n",
+ "764 2021 07 44392 2021.5370 416.65 415.85 416.95 \n",
+ "765 2021 08 44423 2021.6219 414.34 415.89 414.78 \n",
+ "766 2021 09 44454 2021.7068 412.90 416.40 413.04 \n",
+ "767 2021 10 44484 2021.7890 413.55 417.16 413.14 \n",
+ "768 2021 11 44515 2021.8740 414.82 417.08 414.69 \n",
+ "769 2021 12 44545 2021.9562 416.43 417.36 416.19 \n",
+ "770 2022 01 44576 2022.0411 418.01 417.94 417.34 \n",
+ "771 2022 02 44607 2022.1260 418.99 418.21 418.21 \n",
+ "772 2022 03 44635 2022.2027 418.45 416.92 419.11 \n",
+ "773 2022 04 44666 2022.2877 420.02 417.25 420.50 \n",
+ "774 2022 05 44696 2022.3699 420.77 417.36 421.27 \n",
+ "775 2022 06 44727 2022.4548 420.68 418.09 420.60 \n",
+ "776 2022 07 44757 2022.5370 418.68 417.87 418.98 \n",
+ "777 2022 08 44788 2022.6219 416.76 418.31 416.80 \n",
+ "778 2022 09 44819 2022.7068 415.41 418.91 415.07 \n",
+ "779 2022 10 44849 2022.7890 415.31 418.93 415.18 \n",
+ "780 2022 11 44880 2022.8740 417.04 419.31 416.74 \n",
+ "781 2022 12 44910 2022.9562 418.57 419.49 418.27 \n",
+ "782 2023 01 44941 2023.0411 419.24 419.17 419.46 \n",
+ "783 2023 02 44972 2023.1260 420.33 419.55 420.38 \n",
+ "784 2023 03 45000 2023.2027 420.51 418.97 421.34 \n",
+ "785 2023 04 45031 2023.2877 422.73 419.95 422.81 \n",
+ "786 2023 05 45061 2023.3699 423.78 420.36 423.65 \n",
+ "787 2023 06 45092 2023.4548 423.39 420.80 423.03 \n",
+ "788 2023 07 45122 2023.5370 -99.99 -99.99 -99.99 \n",
+ "789 2023 08 45153 2023.6219 -99.99 -99.99 -99.99 \n",
+ "790 2023 09 45184 2023.7068 -99.99 -99.99 -99.99 \n",
+ "791 2023 10 45214 2023.7890 -99.99 -99.99 -99.99 \n",
+ "792 2023 11 45245 2023.8740 -99.99 -99.99 -99.99 \n",
+ "793 2023 12 45275 2023.9562 -99.99 -99.99 -99.99 \n",
+ "\n",
+ " seasonally CO2 seasonally Sta \n",
+ "0 adjusted fit filled adjusted filled NaN \n",
+ "1 [ppm] [ppm] [ppm] NaN \n",
+ "2 -99.99 -99.99 -99.99 MLO \n",
+ "3 -99.99 -99.99 -99.99 MLO \n",
+ "4 314.91 315.71 314.44 MLO \n",
+ "5 314.99 317.45 315.16 MLO \n",
+ "6 315.07 317.51 314.69 MLO \n",
+ "7 315.15 317.27 315.15 MLO \n",
+ "8 315.22 315.87 315.20 MLO \n",
+ "9 315.29 314.93 316.21 MLO \n",
+ "10 315.35 313.21 316.11 MLO \n",
+ "11 315.41 312.42 315.41 MLO \n",
+ "12 315.46 313.33 315.21 MLO \n",
+ "13 315.52 314.67 315.43 MLO \n",
+ "14 315.57 315.58 315.52 MLO \n",
+ "15 315.63 316.49 315.84 MLO \n",
+ "16 315.70 316.65 315.38 MLO \n",
+ "17 315.77 317.72 315.42 MLO \n",
+ "18 315.85 318.29 315.46 MLO \n",
+ "19 315.94 318.15 316.00 MLO \n",
+ "20 316.03 316.54 315.87 MLO \n",
+ "21 316.13 314.80 316.09 MLO \n",
+ "22 316.22 313.84 316.75 MLO \n",
+ "23 316.31 313.33 316.34 MLO \n",
+ "24 316.40 314.81 316.69 MLO \n",
+ "25 316.48 315.58 316.35 MLO \n",
+ "26 316.56 316.43 316.37 MLO \n",
+ "27 316.64 316.98 316.33 MLO \n",
+ "28 316.72 317.58 316.28 MLO \n",
+ "29 316.79 319.03 316.70 MLO \n",
+ ".. ... ... ... ... \n",
+ "764 416.18 416.65 415.85 MLO \n",
+ "765 416.36 414.34 415.89 MLO \n",
+ "766 416.55 412.90 416.40 MLO \n",
+ "767 416.74 413.55 417.16 MLO \n",
+ "768 416.92 414.82 417.08 MLO \n",
+ "769 417.10 416.43 417.36 MLO \n",
+ "770 417.26 418.01 417.94 MLO \n",
+ "771 417.42 418.99 418.21 MLO \n",
+ "772 417.56 418.45 416.92 MLO \n",
+ "773 417.71 420.02 417.25 MLO \n",
+ "774 417.86 420.77 417.36 MLO \n",
+ "775 418.03 420.68 418.09 MLO \n",
+ "776 418.21 418.68 417.87 MLO \n",
+ "777 418.40 416.76 418.31 MLO \n",
+ "778 418.59 415.41 418.91 MLO \n",
+ "779 418.78 415.31 418.93 MLO \n",
+ "780 418.98 417.04 419.31 MLO \n",
+ "781 419.18 418.57 419.49 MKO \n",
+ "782 419.38 419.24 419.17 MKO \n",
+ "783 419.59 420.33 419.55 MKO \n",
+ "784 419.79 420.51 418.97 MLO \n",
+ "785 420.01 422.73 419.95 MLO \n",
+ "786 420.23 423.78 420.36 MLO \n",
+ "787 420.46 423.39 420.80 MLO \n",
+ "788 -99.99 -99.99 -99.99 MLO \n",
+ "789 -99.99 -99.99 -99.99 MLO \n",
+ "790 -99.99 -99.99 -99.99 MLO \n",
+ "791 -99.99 -99.99 -99.99 MLO \n",
+ "792 -99.99 -99.99 -99.99 MLO \n",
+ "793 -99.99 -99.99 -99.99 MLO \n",
+ "\n",
+ "[794 rows x 11 columns]"
+ "metadata": {},
+ "output_type": "execute_result"
+ "source": [
+ "# Lire les données depuis le fichier local CSV en sautant la première ligne (commentaire)\n",
+ "raw_data = pd.read_csv(data, skiprows=57)\n",
+ "\n",
+ "# Afficher les données brutes\n",
+ "raw_data"
+ "execution_count": 57,
+ "metadata": {},
+ "outputs": [
+ "data": {
+ "text/html": [
+ "\n",
+ "\n",
\n",
+ " \n",
+ " \n",
+ " | \n",
+ " Yr | \n",
+ " Mn | \n",
+ " Date | \n",
+ " Date | \n",
+ " CO2 | \n",
+ " fit | \n",
+ " CO2 | \n",
+ " Sta | \n",
\n",
+ " \n",
+ " \n",
+ " \n",
+ " | 0 | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " | \n",
+ " adjusted | \n",
+ " | \n",
+ " filled | \n",
+ " NaN | \n",
\n",
+ " \n",
+ " | 1 | \n",
+ " | \n",
+ " | \n",
+ " Excel | \n",
+ " | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " [ppm] | \n",
+ " NaN | \n",
\n",
+ " \n",
\n",
+ "text/plain": [
+ "0 adjusted \n",
+ "\n",
+ "1 [ppm] [ppm] [ppm] NaN "
+ "metadata": {},
+ "source": [
+ "# Sélectionner les lignes contenant au moins une valeur manquante (NaN)\n",
+ "raw_data[raw_data.isnull().any(axis=1)]"
+ "execution_count": 58,
+ "metadata": {},
+ "outputs": [
+ "data": {
+ "text/html": [
+ "\n",
+ "\n",
\n",
+ " \n",
+ " \n",
+ " | \n",
+ " Yr | \n",
+ " Mn | \n",
+ " Date | \n",
+ " Date | \n",
+ " CO2 | \n",
+ " fit | \n",
+ " CO2 | \n",
+ " Sta | \n",
\n",
+ " \n",
+ " \n",
+ " \n",
+ " | 2 | \n",
+ " 1958 | \n",
+ " 01 | \n",
+ " 21200 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 3 | \n",
+ " 1958 | \n",
+ " 02 | \n",
+ " 21231 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 4 | \n",
+ " 1958 | \n",
+ " 03 | \n",
+ " 21259 | \n",
+ " 315.71 | \n",
+ " 314.44 | \n",
+ " 316.19 | \n",
+ " 314.91 | \n",
+ " 315.71 | \n",
+ " 314.44 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 5 | \n",
+ " 1958 | \n",
+ " 04 | \n",
+ " 21290 | \n",
+ " 317.45 | \n",
+ " 315.16 | \n",
+ " 317.30 | \n",
+ " 314.99 | \n",
+ " 317.45 | \n",
+ " 315.16 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 6 | \n",
+ " 1958 | \n",
+ " 05 | \n",
+ " 21320 | \n",
+ " 317.51 | \n",
+ " 314.69 | \n",
+ " 317.89 | \n",
+ " 315.07 | \n",
+ " 317.51 | \n",
+ " 314.69 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 7 | \n",
+ " 1958 | \n",
+ " 06 | \n",
+ " 21351 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " 317.27 | \n",
+ " 315.15 | \n",
+ " 317.27 | \n",
+ " 315.15 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 8 | \n",
+ " 1958 | \n",
+ " 07 | \n",
+ " 21381 | \n",
+ " 315.87 | \n",
+ " 315.20 | \n",
+ " 315.86 | \n",
+ " 315.22 | \n",
+ " 315.87 | \n",
+ " 315.20 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 9 | \n",
+ " 1958 | \n",
+ " 08 | \n",
+ " 21412 | \n",
+ " 314.93 | \n",
+ " 316.21 | \n",
+ " 313.97 | \n",
+ " 315.29 | \n",
+ " 314.93 | \n",
+ " 316.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 10 | \n",
+ " 1958 | \n",
+ " 09 | \n",
+ " 21443 | \n",
+ " 313.21 | \n",
+ " 316.11 | \n",
+ " 312.44 | \n",
+ " 315.35 | \n",
+ " 313.21 | \n",
+ " 316.11 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 11 | \n",
+ " 1958 | \n",
+ " 10 | \n",
+ " 21473 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " 312.42 | \n",
+ " 315.41 | \n",
+ " 312.42 | \n",
+ " 315.41 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 12 | \n",
+ " 1958 | \n",
+ " 11 | \n",
+ " 21504 | \n",
+ " 313.33 | \n",
+ " 315.21 | \n",
+ " 313.61 | \n",
+ " 315.46 | \n",
+ " 313.33 | \n",
+ " 315.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 13 | \n",
+ " 1958 | \n",
+ " 12 | \n",
+ " 21534 | \n",
+ " 314.67 | \n",
+ " 315.43 | \n",
+ " 314.77 | \n",
+ " 315.52 | \n",
+ " 314.67 | \n",
+ " 315.43 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 14 | \n",
+ " 1959 | \n",
+ " 01 | \n",
+ " 21565 | \n",
+ " 315.58 | \n",
+ " 315.52 | \n",
+ " 315.64 | \n",
+ " 315.57 | \n",
+ " 315.58 | \n",
+ " 315.52 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 15 | \n",
+ " 1959 | \n",
+ " 02 | \n",
+ " 21596 | \n",
+ " 316.49 | \n",
+ " 315.84 | \n",
+ " 316.29 | \n",
+ " 315.63 | \n",
+ " 316.49 | \n",
+ " 315.84 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 16 | \n",
+ " 1959 | \n",
+ " 03 | \n",
+ " 21624 | \n",
+ " 316.65 | \n",
+ " 315.38 | \n",
+ " 316.98 | \n",
+ " 315.70 | \n",
+ " 316.65 | \n",
+ " 315.38 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 17 | \n",
+ " 1959 | \n",
+ " 04 | \n",
+ " 21655 | \n",
+ " 317.72 | \n",
+ " 315.42 | \n",
+ " 318.09 | \n",
+ " 315.77 | \n",
+ " 317.72 | \n",
+ " 315.42 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 18 | \n",
+ " 1959 | \n",
+ " 05 | \n",
+ " 21685 | \n",
+ " 318.29 | \n",
+ " 315.46 | \n",
+ " 318.68 | \n",
+ " 315.85 | \n",
+ " 318.29 | \n",
+ " 315.46 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 19 | \n",
+ " 1959 | \n",
+ " 06 | \n",
+ " 21716 | \n",
+ " 318.15 | \n",
+ " 316.00 | \n",
+ " 318.07 | \n",
+ " 315.94 | \n",
+ " 318.15 | \n",
+ " 316.00 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 20 | \n",
+ " 1959 | \n",
+ " 07 | \n",
+ " 21746 | \n",
+ " 316.54 | \n",
+ " 315.87 | \n",
+ " 316.67 | \n",
+ " 316.03 | \n",
+ " 316.54 | \n",
+ " 315.87 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 21 | \n",
+ " 1959 | \n",
+ " 08 | \n",
+ " 21777 | \n",
+ " 314.80 | \n",
+ " 316.09 | \n",
+ " 314.80 | \n",
+ " 316.13 | \n",
+ " 314.80 | \n",
+ " 316.09 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 22 | \n",
+ " 1959 | \n",
+ " 09 | \n",
+ " 21808 | \n",
+ " 313.84 | \n",
+ " 316.75 | \n",
+ " 313.30 | \n",
+ " 316.22 | \n",
+ " 313.84 | \n",
+ " 316.75 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 23 | \n",
+ " 1959 | \n",
+ " 10 | \n",
+ " 21838 | \n",
+ " 313.33 | \n",
+ " 316.34 | \n",
+ " 313.31 | \n",
+ " 316.31 | \n",
+ " 313.33 | \n",
+ " 316.34 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 24 | \n",
+ " 1959 | \n",
+ " 11 | \n",
+ " 21869 | \n",
+ " 314.81 | \n",
+ " 316.69 | \n",
+ " 314.53 | \n",
+ " 316.40 | \n",
+ " 314.81 | \n",
+ " 316.69 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 25 | \n",
+ " 1959 | \n",
+ " 12 | \n",
+ " 21899 | \n",
+ " 315.58 | \n",
+ " 316.35 | \n",
+ " 315.72 | \n",
+ " 316.48 | \n",
+ " 315.58 | \n",
+ " 316.35 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 26 | \n",
+ " 1960 | \n",
+ " 01 | \n",
+ " 21930 | \n",
+ " 316.43 | \n",
+ " 316.37 | \n",
+ " 316.63 | \n",
+ " 316.56 | \n",
+ " 316.43 | \n",
+ " 316.37 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 27 | \n",
+ " 1960 | \n",
+ " 02 | \n",
+ " 21961 | \n",
+ " 316.98 | \n",
+ " 316.33 | \n",
+ " 317.29 | \n",
+ " 316.64 | \n",
+ " 316.98 | \n",
+ " 316.33 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 28 | \n",
+ " 1960 | \n",
+ " 03 | \n",
+ " 21990 | \n",
+ " 317.58 | \n",
+ " 316.28 | \n",
+ " 318.03 | \n",
+ " 316.72 | \n",
+ " 317.58 | \n",
+ " 316.28 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 29 | \n",
+ " 1960 | \n",
+ " 04 | \n",
+ " 22021 | \n",
+ " 319.03 | \n",
+ " 316.70 | \n",
+ " 319.14 | \n",
+ " 316.79 | \n",
+ " 319.03 | \n",
+ " 316.70 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 30 | \n",
+ " 1960 | \n",
+ " 05 | \n",
+ " 22051 | \n",
+ " 1960.3716 | \n",
+ " 320.03 | \n",
+ " 317.20 | \n",
+ " 319.70 | \n",
+ " 316.87 | \n",
+ " 320.03 | \n",
+ " 317.20 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 31 | \n",
+ " 1960 | \n",
+ " 06 | \n",
+ " 22082 | \n",
+ " 1960.4563 | \n",
+ " 319.58 | \n",
+ " 317.45 | \n",
+ " 319.04 | \n",
+ " 316.93 | \n",
+ " 319.58 | \n",
+ " 317.45 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
+ " ... | \n",
\n",
+ " \n",
+ " | 764 | \n",
+ " 2021 | \n",
+ " 07 | \n",
+ " 44392 | \n",
+ " 416.65 | \n",
+ " 415.85 | \n",
+ " 416.95 | \n",
+ " 416.18 | \n",
+ " 416.65 | \n",
+ " 415.85 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 765 | \n",
+ " 2021 | \n",
+ " 08 | \n",
+ " 44423 | \n",
+ " 414.34 | \n",
+ " 415.89 | \n",
+ " 414.78 | \n",
+ " 416.36 | \n",
+ " 414.34 | \n",
+ " 415.89 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 766 | \n",
+ " 2021 | \n",
+ " 09 | \n",
+ " 44454 | \n",
+ " 412.90 | \n",
+ " 416.40 | \n",
+ " 413.04 | \n",
+ " 416.55 | \n",
+ " 412.90 | \n",
+ " 416.40 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 767 | \n",
+ " 2021 | \n",
+ " 10 | \n",
+ " 44484 | \n",
+ " 413.55 | \n",
+ " 417.16 | \n",
+ " 413.14 | \n",
+ " 416.74 | \n",
+ " 413.55 | \n",
+ " 417.16 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 768 | \n",
+ " 2021 | \n",
+ " 11 | \n",
+ " 44515 | \n",
+ " 414.82 | \n",
+ " 417.08 | \n",
+ " 414.69 | \n",
+ " 416.92 | \n",
+ " 414.82 | \n",
+ " 417.08 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 769 | \n",
+ " 2021 | \n",
+ " 12 | \n",
+ " 44545 | \n",
+ " 416.43 | \n",
+ " 417.36 | \n",
+ " 416.19 | \n",
+ " 417.10 | \n",
+ " 416.43 | \n",
+ " 417.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 770 | \n",
+ " 2022 | \n",
+ " 01 | \n",
+ " 44576 | \n",
+ " 418.01 | \n",
+ " 417.94 | \n",
+ " 417.34 | \n",
+ " 417.26 | \n",
+ " 418.01 | \n",
+ " 417.94 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 771 | \n",
+ " 2022 | \n",
+ " 02 | \n",
+ " 44607 | \n",
+ " 418.99 | \n",
+ " 418.21 | \n",
+ " 418.21 | \n",
+ " 417.42 | \n",
+ " 418.99 | \n",
+ " 418.21 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 772 | \n",
+ " 2022 | \n",
+ " 03 | \n",
+ " 44635 | \n",
+ " 418.45 | \n",
+ " 416.92 | \n",
+ " 419.11 | \n",
+ " 417.56 | \n",
+ " 418.45 | \n",
+ " 416.92 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 773 | \n",
+ " 2022 | \n",
+ " 04 | \n",
+ " 44666 | \n",
+ " 420.02 | \n",
+ " 417.25 | \n",
+ " 420.50 | \n",
+ " 417.71 | \n",
+ " 420.02 | \n",
+ " 417.25 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 774 | \n",
+ " 2022 | \n",
+ " 05 | \n",
+ " 44696 | \n",
+ " 420.77 | \n",
+ " 417.36 | \n",
+ " 421.27 | \n",
+ " 417.86 | \n",
+ " 420.77 | \n",
+ " 417.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 775 | \n",
+ " 2022 | \n",
+ " 06 | \n",
+ " 44727 | \n",
+ " 420.68 | \n",
+ " 418.09 | \n",
+ " 420.60 | \n",
+ " 418.03 | \n",
+ " 420.68 | \n",
+ " 418.09 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 776 | \n",
+ " 2022 | \n",
+ " 07 | \n",
+ " 44757 | \n",
+ " 418.68 | \n",
+ " 417.87 | \n",
+ " 418.98 | \n",
+ " 418.21 | \n",
+ " 418.68 | \n",
+ " 417.87 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 777 | \n",
+ " 2022 | \n",
+ " 08 | \n",
+ " 44788 | \n",
+ " 416.76 | \n",
+ " 418.31 | \n",
+ " 416.80 | \n",
+ " 418.40 | \n",
+ " 416.76 | \n",
+ " 418.31 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 778 | \n",
+ " 2022 | \n",
+ " 09 | \n",
+ " 44819 | \n",
+ " 415.41 | \n",
+ " 418.91 | \n",
+ " 415.07 | \n",
+ " 418.59 | \n",
+ " 415.41 | \n",
+ " 418.91 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 779 | \n",
+ " 2022 | \n",
+ " 10 | \n",
+ " 44849 | \n",
+ " 415.31 | \n",
+ " 418.93 | \n",
+ " 415.18 | \n",
+ " 418.78 | \n",
+ " 415.31 | \n",
+ " 418.93 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 780 | \n",
+ " 2022 | \n",
+ " 11 | \n",
+ " 44880 | \n",
+ " 417.04 | \n",
+ " 419.31 | \n",
+ " 416.74 | \n",
+ " 418.98 | \n",
+ " 417.04 | \n",
+ " 419.31 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 781 | \n",
+ " 2022 | \n",
+ " 12 | \n",
+ " 44910 | \n",
+ " 418.57 | \n",
+ " 419.49 | \n",
+ " 418.27 | \n",
+ " 419.18 | \n",
+ " 418.57 | \n",
+ " 419.49 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 782 | \n",
+ " 2023 | \n",
+ " 01 | \n",
+ " 44941 | \n",
+ " 419.24 | \n",
+ " 419.17 | \n",
+ " 419.46 | \n",
+ " 419.38 | \n",
+ " 419.24 | \n",
+ " 419.17 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 783 | \n",
+ " 2023 | \n",
+ " 02 | \n",
+ " 44972 | \n",
+ " 420.33 | \n",
+ " 419.55 | \n",
+ " 420.38 | \n",
+ " 419.59 | \n",
+ " 420.33 | \n",
+ " 419.55 | \n",
+ " MKO | \n",
\n",
+ " \n",
+ " | 784 | \n",
+ " 2023 | \n",
+ " 03 | \n",
+ " 45000 | \n",
+ " 420.51 | \n",
+ " 418.97 | \n",
+ " 421.34 | \n",
+ " 419.79 | \n",
+ " 420.51 | \n",
+ " 418.97 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 785 | \n",
+ " 2023 | \n",
+ " 04 | \n",
+ " 45031 | \n",
+ " 422.73 | \n",
+ " 419.95 | \n",
+ " 422.81 | \n",
+ " 420.01 | \n",
+ " 422.73 | \n",
+ " 419.95 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 786 | \n",
+ " 2023 | \n",
+ " 05 | \n",
+ " 45061 | \n",
+ " 423.78 | \n",
+ " 420.36 | \n",
+ " 423.65 | \n",
+ " 420.23 | \n",
+ " 423.78 | \n",
+ " 420.36 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 787 | \n",
+ " 2023 | \n",
+ " 06 | \n",
+ " 45092 | \n",
+ " 423.39 | \n",
+ " 420.80 | \n",
+ " 423.03 | \n",
+ " 420.46 | \n",
+ " 423.39 | \n",
+ " 420.80 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 788 | \n",
+ " 2023 | \n",
+ " 07 | \n",
+ " 45122 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 789 | \n",
+ " 2023 | \n",
+ " 08 | \n",
+ " 45153 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 790 | \n",
+ " 2023 | \n",
+ " 09 | \n",
+ " 45184 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 791 | \n",
+ " 2023 | \n",
+ " 10 | \n",
+ " 45214 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 792 | \n",
+ " 2023 | \n",
+ " 11 | \n",
+ " 45245 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
+ " | 793 | \n",
+ " 2023 | \n",
+ " 12 | \n",
+ " 45275 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " -99.99 | \n",
+ " MLO | \n",
\n",
+ " \n",
\n",
792 rows × 11 columns
\n",
+ "text/plain": [
+ "30 1960 05 22051 1960.3716 320.03 317.20 319.70 \n",
+ "31 1960 06 22082 1960.4563 319.58 317.45 319.04 \n",
+ "\n",
+ "30 316.87 320.03 317.20 MLO \n",
+ "31 316.93 319.58 317.45 MLO \n",
+ "\n",
+ "[792 rows x 11 columns]"
+ "metadata": {},
+ "source": [
+ "# Supprimer les lignes contenant des valeurs manquantes (NaN) à partir des données brutes\n",
+ "data = raw_data.dropna().copy()\n",
+ "\n",
+ "# Afficher les données nettoyées (sans valeurs manquantes) et en créer une copie\n",
+ "data"
+ "execution_count": 59,
+ "metadata": {},
+ "outputs": [],
+ "source": [
+ "data = data.dropna(subset=[' CO2'])"
+ "execution_count": 60,
+ "metadata": {},
+ "outputs": [
+ "name": "stdout",
+ "output_type": "stream",
+ "text": [
+ "Index([' Yr', ' Mn', ' Date', ' Date', ' CO2', 'seasonally',\n",
+ " ' fit', ' seasonally', ' CO2', ' seasonally', ' Sta'],\n",
+ " dtype='object')\n"
+ "source": [
+ "print(data.columns)"
+ "execution_count": 61,
+ "metadata": {},
+ "outputs": [
+ "name": "stderr",
+ "text": [
+ "/opt/conda/lib/python3.6/site-packages/ipykernel_launcher.py:14: SettingWithCopyWarning: \n",
+ "A value is trying to be set on a copy of a slice from a DataFrame.\n",
+ "Try using .loc[row_indexer,col_indexer] = value instead\n",
+ "\n",
+ "See the caveats in the documentation: http://pandas.pydata.org/pandas-docs/stable/indexing.html#indexing-view-versus-copy\n",
+ " \n"
+ "data": {
+ "text/plain": [
+ "metadata": {},
+ "data": {
+ "image/png": "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\n",
+ "text/plain": [
+ "metadata": {
+ "needs_background": "light"
+ "output_type": "display_data"
+ "source": [
+ "#question1\n",
+ "# Grouper par année (Yr) et sommer les valeurs de CO2\n",
+ "annees = data[' Yr'].unique() # Obtenir la liste des années uniques\n",
+ "\n",
+ "# Initialiser les listes pour stocker les années et les émissions de CO2 annuelles\n",
+ "year = [] # Liste des années\n",
+ "yearly_CO2 = [] # Liste des émissions annuelles de CO2\n",
+ "\n",
+ "for annee in annees:\n",
+ " # Filtrer les données pour l'année spécifique\n",
+ " donnees_annee = data[data[' Yr'] == annee]\n",
+ " \n",
+ " # Somme des émissions de CO2 pour l'année spécifique\n",
+ " donnees_annee[' CO2'] = donnees_annee[' CO2'].astype(float)\n",
+ " somme_co2_annee = donnees_annee[' CO2'].sum()\n",
+ " \n",
+ " # Ajouter l'année et la somme des émissions à leurs listes respectives\n",
+ " year.append(annee)\n",
+ " yearly_CO2.append(somme_co2_annee)\n",
+ "\n",
+ "# Créer une série pandas avec les données annuelles et les années comme index\n",
+ "yearly_CO2 = pd.Series(data=yearly_CO2, index=year)\n",
+ "# Tracer un graphique de dispersion des données d'incidence annuelle avec un style en étoile\n",
+ "yearly_CO2.plot(style='*')"
+ "execution_count": 62,
+ "metadata": {},
+ "outputs": [
+ "ename": "ValueError",
+ "evalue": "to assemble mappings requires at least that [year, month, day] be specified: [month,year] is missing",
+ "output_type": "error",
+ "traceback": [
+ "\u001b[0;31m---------------------------------------------------------------------------\u001b[0m",
+ "\u001b[0;31mValueError\u001b[0m Traceback (most recent call last)",
+ "\u001b[0;32m\u001b[0m in \u001b[0;36m\u001b[0;34m\u001b[0m\n\u001b[1;32m 3\u001b[0m \u001b[0mdata\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mdata\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0massign\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mJr\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 4\u001b[0m \u001b[0;31m# Créez une colonne de date en combinant Year et Month\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m----> 5\u001b[0;31m \u001b[0mdata\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m'Date'\u001b[0m\u001b[0;34m]\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mpd\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mto_datetime\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mdata\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m[\u001b[0m\u001b[0;34m' Yr'\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m' Mn'\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m'Jr'\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m]\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0massign\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mday\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;36m1\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 6\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 7\u001b[0m \u001b[0;31m# Supprimez les colonnes Year et Month si nécessaire\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
+ "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/tools/datetimes.py\u001b[0m in \u001b[0;36mto_datetime\u001b[0;34m(arg, errors, dayfirst, yearfirst, utc, box, format, exact, unit, infer_datetime_format, origin)\u001b[0m\n\u001b[1;32m 374\u001b[0m \u001b[0mresult\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mSeries\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mvalues\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mindex\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mindex\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mname\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 375\u001b[0m \u001b[0;32melif\u001b[0m \u001b[0misinstance\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m(\u001b[0m\u001b[0mABCDataFrame\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mMutableMapping\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 376\u001b[0;31m \u001b[0mresult\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0m_assemble_from_unit_mappings\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0merrors\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0merrors\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 377\u001b[0m \u001b[0;32melif\u001b[0m \u001b[0misinstance\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mABCIndexClass\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 378\u001b[0m \u001b[0mresult\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0m_convert_listlike\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mbox\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mformat\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mname\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0marg\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mname\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
+ "\u001b[0;32m/opt/conda/lib/python3.6/site-packages/pandas/core/tools/datetimes.py\u001b[0m in \u001b[0;36m_assemble_from_unit_mappings\u001b[0;34m(arg, errors)\u001b[0m\n\u001b[1;32m 453\u001b[0m raise ValueError(\"to assemble mappings requires at least that \"\n\u001b[1;32m 454\u001b[0m \u001b[0;34m\"[year, month, day] be specified: [{required}] \"\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 455\u001b[0;31m \"is missing\".format(required=','.join(req)))\n\u001b[0m\u001b[1;32m 456\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 457\u001b[0m \u001b[0;31m# keys we don't recognize\u001b[0m\u001b[0;34m\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
+ "\u001b[0;31mValueError\u001b[0m: to assemble mappings requires at least that [year, month, day] be specified: [month,year] is missing"
+ "source": [
+ "#question2\n",
+ "from statsmodels.tsa.seasonal import seasonal_decompose\n",
+ "data = data.assign(Jr=1)\n",
+ "# Créez une colonne de date en combinant Year et Month\n",
+ "data['Date'] = pd.to_datetime(data[[' Yr', ' Mn', 'Jr']].assign(day=1))\n",
+ "\n",
+ "# Supprimez les colonnes Year et Month si nécessaire\n",
+ "data = data.drop([' Yr', ' Mn', 'Jr'], axis=1)\n",
+ "\n",
+ "# Assurez-vous que 'Date' est un objet DateTime pour définir la fréquence\n",
+ "data['Date'] = pd.to_datetime(data['Date'])\n",
+ "\n",
+ "# Décomposez les données en tendance, saisonnalité et résidus en spécifiant la fréquence\n",
+ "decomposition = seasonal_decompose(data[' CO2'], model='additive', freq=12) # Ici, 'freq=12' indique une fréquence mensuelle\n",
+ "\n",
+ "# Extraire la tendance, la saisonnalité et les résidus\n",
+ "tendance = decomposition.trend\n",
+ "saisonnalite = decomposition.seasonal\n",
+ "residus = decomposition.resid\n",
+ "\n",
+ "\n",
+ "\n",
+ "# Tracer les composantes\n",
+ "plt.figure(figsize=(12, 6))\n",
+ "plt.subplot(411)\n",
+ "plt.plot(data[' Yr'], data[' CO2'], label='Données originales')\n",
+ "plt.legend()\n",
+ "plt.subplot(412)\n",
+ "plt.plot(data[' Yr'], tendance, label='Tendance')\n",
+ "plt.legend()\n",
+ "plt.subplot(413)\n",
+ "plt.plot(data[' Yr'], saisonnalite, label='Saisonnalité')\n",
+ "plt.legend()\n",
+ "plt.subplot(414)\n",
+ "plt.plot(data[' Yr'], residus, label='Résidus')\n",
+ "plt.legend()\n",
+ "plt.tight_layout()\n",
+ "plt.show()"
+ "execution_count": null,
+ "metadata": {},
+ "outputs": [],
+ "source": [
+ "#question3\n",
+ "from sklearn.linear_model import LinearRegression\n",
+ "\n",
+ "# Créer un modèle de régression linéaire\n",
+ "regression = LinearRegression()\n",
+ "\n",
+ "# Ajuster le modèle aux données de tendance\n",
+ "regression.fit(data['Date'].values.reshape(-1, 1), data['CO2'])\n",
+ "\n",
+ "# Obtenir les paramètres du modèle\n",
+ "pente = regression.coef_\n",
+ "intercept = regression.intercept_\n",
+ "\n",
+ "# Extrapoler les valeurs jusqu'en 2025\n",
+ "annee_2025 = 2025\n",
+ "co2_2025 = regression.predict([[annee_2025]])[0]\n",
+ "\n",
+ "# Afficher les résultats\n",
+ "print(f\"Équation de la régression linéaire : CO2 = {pente[0]} * Année + {intercept}\")\n",
+ "print(f\"Concentration de CO2 estimée pour 2025 : {co2_2025} ppm\")\n"
"metadata": {
"kernelspec": {
"display_name": "Python 3",
@@ -16,10 +2407,9 @@
"name": "python",
"nbconvert_exporter": "python",
"pygments_lexer": "ipython3",
- "version": "3.6.3"
+ "version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
diff --git a/module3/exo3/monthly_in_situ_co2_mlo.csv b/module3/exo3/monthly_in_situ_co2_mlo.csv
new file mode 100644
index 0000000000000000000000000000000000000000..d189d7725c8d88289be7315c3d510a2cc6d920e4
--- /dev/null
+++ b/module3/exo3/monthly_in_situ_co2_mlo.csv
@@ -0,0 +1,852 @@
+" Atmospheric CO2 concentrations (ppm) derived from in situ air measurements "
+" at Mauna Loa, Observatory, Hawaii: Latitude 19.5°N Longitude 155.6°W Elevation 3397m "
+" Since December 2022 sampling has temporarily been relocated to MaunuaKea, Hawaii "
+" Latitude 19.8°N Longitude 155.5°W Elevation 4145m "
+" Source: R. F. Keeling, S. J. Walker, S. C. Piper and A. F. Bollenbacher "
+" Scripps CO2 Program ( http://scrippsco2.ucsd.edu ) "
+" Scripps Institution of Oceanography (SIO) "
+" University of California "
+" La Jolla, California USA 92093-0244 "
+" Status of data and correspondence: "
+" These data are subject to revision based on recalibration of standard gases. Questions "
+" about the data should be directed to Dr. Ralph Keeling (rkeeling@ucsd.edu), Stephen Walker"
+" (sjwalker@ucsd.edu) and Stephen Piper (scpiper@ucsd.edu), Scripps CO2 Program. "
+" Baseline data in this file through 09-Jul-2023 from archive dated 10-Jul-2023 15:15:05 "
+" Please cite as: "
+" C. D. Keeling, S. C. Piper, R. B. Bacastow, M. Wahlen, T. P. Whorf, M. Heimann, and "
+" H. A. Meijer, Exchanges of atmospheric CO2 and 13CO2 with the terrestrial biosphere and "
+" oceans from 1978 to 2000. I. Global aspects, SIO Reference Series, No. 01-06, Scripps "
+" Institution of Oceanography, San Diego, 88 pages, 2001. "
+" If it is necessary to cite a peer-reviewed article, please cite as: "
+" H. A. Meijer, Atmospheric CO2 and 13CO2 exchange with the terrestrial biosphere and "
+" oceans from 1978 to 2000: observations and carbon cycle implications, pages 83-113, "
+" in "A History of Atmospheric CO2 and its effects on Plants, Animals, and Ecosystems", "
+" editors, Ehleringer, J.R., T. E. Cerling, M. D. Dearing, Springer Verlag, "
+" New York, 2005. "
+" The data file below contains 10 columns. Columns 1-4 give the dates in several redundant "
+" formats. Column 5 below gives monthly Mauna Loa CO2 concentrations in micro-mol CO2 per "
+" mole (ppm), reported on the 2012 SIO manometric mole fraction scale. This is the "
+" standard version of the data most often sought. The monthly values have been adjusted "
+" to 24:00 hours on the 15th of each month. Column 6 gives the same data after a seasonal "
+" adjustment to remove the quasi-regular seasonal cycle. The adjustment involves "
+" subtracting from the data a 4-harmonic fit with a linear gain factor. Column 7 is a "
+" smoothed version of the data generated from a stiff cubic spline function plus 4-harmonic "
+" functions with linear gain. Column 8 is the same smoothed version with the seasonal "
+" cycle removed. Column 9 is identical to Column 5 except that the missing values from "
+" Column 5 have been filled with values from Column 7. Column 10 is identical to Column 6 "
+" except missing values have been filled with values from Column 8. Missing values are "
+" denoted by -99.99 "
+" Column 11 is the 3-digit sampling station identifier"
+" CO2 concentrations are measured on the '12' calibration scale "
+ Yr, Mn, Date, Date, CO2,seasonally, fit, seasonally, CO2, seasonally, Sta
+ , , , , , adjusted, ,adjusted fit, filled,adjusted filled
+ , , Excel, , [ppm], [ppm] , [ppm], [ppm], [ppm], [ppm]
+1958, 01, 21200, 1958.0411, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+1958, 02, 21231, 1958.1260, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+1958, 03, 21259, 1958.2027, 315.71, 314.44, 316.19, 314.91, 315.71, 314.44, MLO
+1958, 04, 21290, 1958.2877, 317.45, 315.16, 317.30, 314.99, 317.45, 315.16, MLO
+1958, 05, 21320, 1958.3699, 317.51, 314.69, 317.89, 315.07, 317.51, 314.69, MLO
+1958, 06, 21351, 1958.4548, -99.99, -99.99, 317.27, 315.15, 317.27, 315.15, MLO
+1958, 07, 21381, 1958.5370, 315.87, 315.20, 315.86, 315.22, 315.87, 315.20, MLO
+1958, 08, 21412, 1958.6219, 314.93, 316.21, 313.97, 315.29, 314.93, 316.21, MLO
+1958, 09, 21443, 1958.7068, 313.21, 316.11, 312.44, 315.35, 313.21, 316.11, MLO
+1958, 10, 21473, 1958.7890, -99.99, -99.99, 312.42, 315.41, 312.42, 315.41, MLO
+1958, 11, 21504, 1958.8740, 313.33, 315.21, 313.61, 315.46, 313.33, 315.21, MLO
+1958, 12, 21534, 1958.9562, 314.67, 315.43, 314.77, 315.52, 314.67, 315.43, MLO
+1959, 01, 21565, 1959.0411, 315.58, 315.52, 315.64, 315.57, 315.58, 315.52, MLO
+1959, 02, 21596, 1959.1260, 316.49, 315.84, 316.29, 315.63, 316.49, 315.84, MLO
+1959, 03, 21624, 1959.2027, 316.65, 315.38, 316.98, 315.70, 316.65, 315.38, MLO
+1959, 04, 21655, 1959.2877, 317.72, 315.42, 318.09, 315.77, 317.72, 315.42, MLO
+1959, 05, 21685, 1959.3699, 318.29, 315.46, 318.68, 315.85, 318.29, 315.46, MLO
+1959, 06, 21716, 1959.4548, 318.15, 316.00, 318.07, 315.94, 318.15, 316.00, MLO
+1959, 07, 21746, 1959.5370, 316.54, 315.87, 316.67, 316.03, 316.54, 315.87, MLO
+1959, 08, 21777, 1959.6219, 314.80, 316.09, 314.80, 316.13, 314.80, 316.09, MLO
+1959, 09, 21808, 1959.7068, 313.84, 316.75, 313.30, 316.22, 313.84, 316.75, MLO
+1959, 10, 21838, 1959.7890, 313.33, 316.34, 313.31, 316.31, 313.33, 316.34, MLO
+1959, 11, 21869, 1959.8740, 314.81, 316.69, 314.53, 316.40, 314.81, 316.69, MLO
+1959, 12, 21899, 1959.9562, 315.58, 316.35, 315.72, 316.48, 315.58, 316.35, MLO
+1960, 01, 21930, 1960.0410, 316.43, 316.37, 316.63, 316.56, 316.43, 316.37, MLO
+1960, 02, 21961, 1960.1257, 316.98, 316.33, 317.29, 316.64, 316.98, 316.33, MLO
+1960, 03, 21990, 1960.2049, 317.58, 316.28, 318.03, 316.72, 317.58, 316.28, MLO
+1960, 04, 22021, 1960.2896, 319.03, 316.70, 319.14, 316.79, 319.03, 316.70, MLO
+1960, 05, 22051, 1960.3716, 320.03, 317.20, 319.70, 316.87, 320.03, 317.20, MLO
+1960, 06, 22082, 1960.4563, 319.58, 317.45, 319.04, 316.93, 319.58, 317.45, MLO
+1960, 07, 22112, 1960.5383, 318.18, 317.53, 317.59, 316.98, 318.18, 317.53, MLO
+1960, 08, 22143, 1960.6230, 315.90, 317.22, 315.67, 317.02, 315.90, 317.22, MLO
+1960, 09, 22174, 1960.7077, 314.17, 317.09, 314.11, 317.05, 314.17, 317.09, MLO
+1960, 10, 22204, 1960.7896, 313.83, 316.84, 314.08, 317.08, 313.83, 316.84, MLO
+1960, 11, 22235, 1960.8743, 315.00, 316.89, 315.25, 317.11, 315.00, 316.89, MLO
+1960, 12, 22265, 1960.9563, 316.19, 316.96, 316.40, 317.15, 316.19, 316.96, MLO
+1961, 01, 22296, 1961.0411, 316.89, 316.84, 317.27, 317.20, 316.89, 316.84, MLO
+1961, 02, 22327, 1961.1260, 317.70, 317.06, 317.93, 317.27, 317.70, 317.06, MLO
+1961, 03, 22355, 1961.2027, 318.54, 317.26, 318.63, 317.33, 318.54, 317.26, MLO
+1961, 04, 22386, 1961.2877, 319.48, 317.16, 319.75, 317.42, 319.48, 317.16, MLO
+1961, 05, 22416, 1961.3699, 320.58, 317.74, 320.35, 317.50, 320.58, 317.74, MLO
+1961, 06, 22447, 1961.4548, 319.77, 317.61, 319.73, 317.59, 319.77, 317.61, MLO
+1961, 07, 22477, 1961.5370, 318.56, 317.89, 318.32, 317.68, 318.56, 317.89, MLO
+1961, 08, 22508, 1961.6219, 316.79, 318.09, 316.44, 317.77, 316.79, 318.09, MLO
+1961, 09, 22539, 1961.7068, 314.99, 317.91, 314.91, 317.85, 314.99, 317.91, MLO
+1961, 10, 22569, 1961.7890, 315.31, 318.33, 314.91, 317.92, 315.31, 318.33, MLO
+1961, 11, 22600, 1961.8740, 316.10, 318.00, 316.12, 317.99, 316.10, 318.00, MLO
+1961, 12, 22630, 1961.9562, 317.01, 317.78, 317.30, 318.06, 317.01, 317.78, MLO
+1962, 01, 22661, 1962.0411, 317.94, 317.88, 318.20, 318.13, 317.94, 317.88, MLO
+1962, 02, 22692, 1962.1260, 318.55, 317.90, 318.86, 318.20, 318.55, 317.90, MLO
+1962, 03, 22720, 1962.2027, 319.68, 318.40, 319.56, 318.26, 319.68, 318.40, MLO
+1962, 04, 22751, 1962.2877, 320.57, 318.24, 320.66, 318.32, 320.57, 318.24, MLO
+1962, 05, 22781, 1962.3699, 321.02, 318.16, 321.24, 318.39, 321.02, 318.16, MLO
+1962, 06, 22812, 1962.4548, 320.62, 318.45, 320.60, 318.45, 320.62, 318.45, MLO
+1962, 07, 22842, 1962.5370, 319.61, 318.94, 319.15, 318.51, 319.61, 318.94, MLO
+1962, 08, 22873, 1962.6219, 317.40, 318.70, 317.22, 318.56, 317.40, 318.70, MLO
+1962, 09, 22904, 1962.7068, 316.24, 319.18, 315.65, 318.60, 316.24, 319.18, MLO
+1962, 10, 22934, 1962.7890, 315.42, 318.45, 315.62, 318.64, 315.42, 318.45, MLO
+1962, 11, 22965, 1962.8740, 316.69, 318.59, 316.80, 318.68, 316.69, 318.59, MLO
+1962, 12, 22995, 1962.9562, 317.70, 318.47, 317.96, 318.72, 317.70, 318.47, MLO
+1963, 01, 23026, 1963.0411, 318.74, 318.68, 318.83, 318.76, 318.74, 318.68, MLO
+1963, 02, 23057, 1963.1260, 319.07, 318.41, 319.47, 318.81, 319.07, 318.41, MLO
+1963, 03, 23085, 1963.2027, 319.86, 318.57, 320.16, 318.86, 319.86, 318.57, MLO
+1963, 04, 23116, 1963.2877, 321.38, 319.05, 321.26, 318.91, 321.38, 319.05, MLO
+1963, 05, 23146, 1963.3699, 322.25, 319.38, 321.83, 318.96, 322.25, 319.38, MLO
+1963, 06, 23177, 1963.4548, 321.49, 319.31, 321.17, 319.02, 321.49, 319.31, MLO
+1963, 07, 23207, 1963.5370, 319.74, 319.07, 319.71, 319.06, 319.74, 319.07, MLO
+1963, 08, 23238, 1963.6219, 317.77, 319.07, 317.76, 319.10, 317.77, 319.07, MLO
+1963, 09, 23269, 1963.7068, 316.21, 319.16, 316.19, 319.15, 316.21, 319.16, MLO
+1963, 10, 23299, 1963.7890, 315.99, 319.03, 316.16, 319.19, 315.99, 319.03, MLO
+1963, 11, 23330, 1963.8740, 317.07, 318.97, 317.35, 319.23, 317.07, 318.97, MLO
+1963, 12, 23360, 1963.9562, 318.35, 319.13, 318.52, 319.28, 318.35, 319.13, MLO
+1964, 01, 23391, 1964.0410, 319.57, 319.51, 319.39, 319.32, 319.57, 319.51, MLO
+1964, 02, 23422, 1964.1257, -99.99, -99.99, 320.03, 319.37, 320.03, 319.37, MLO
+1964, 03, 23451, 1964.2049, -99.99, -99.99, 320.74, 319.41, 320.74, 319.41, MLO
+1964, 04, 23482, 1964.2896, -99.99, -99.99, 321.83, 319.46, 321.83, 319.46, MLO
+1964, 05, 23512, 1964.3716, 322.25, 319.38, 322.37, 319.50, 322.25, 319.38, MLO
+1964, 06, 23543, 1964.4563, 321.89, 319.74, 321.67, 319.53, 321.89, 319.74, MLO
+1964, 07, 23573, 1964.5383, 320.44, 319.79, 320.18, 319.56, 320.44, 319.79, MLO
+1964, 08, 23604, 1964.6230, 318.69, 320.03, 318.22, 319.59, 318.69, 320.03, MLO
+1964, 09, 23635, 1964.7077, 316.71, 319.67, 316.63, 319.61, 316.71, 319.67, MLO
+1964, 10, 23665, 1964.7896, 316.87, 319.92, 316.59, 319.62, 316.87, 319.92, MLO
+1964, 11, 23696, 1964.8743, 317.68, 319.59, 317.75, 319.64, 317.68, 319.59, MLO
+1964, 12, 23726, 1964.9563, 318.71, 319.49, 318.90, 319.66, 318.71, 319.49, MLO
+1965, 01, 23757, 1965.0411, 319.44, 319.38, 319.76, 319.69, 319.44, 319.38, MLO
+1965, 02, 23788, 1965.1260, 320.45, 319.79, 320.39, 319.73, 320.45, 319.79, MLO
+1965, 03, 23816, 1965.2027, 320.89, 319.59, 321.08, 319.77, 320.89, 319.59, MLO
+1965, 04, 23847, 1965.2877, 322.14, 319.79, 322.20, 319.83, 322.14, 319.79, MLO
+1965, 05, 23877, 1965.3699, 322.17, 319.29, 322.79, 319.91, 322.17, 319.29, MLO
+1965, 06, 23908, 1965.4548, 321.87, 319.69, 322.17, 320.00, 321.87, 319.69, MLO
+1965, 07, 23938, 1965.5370, 321.21, 320.53, 320.75, 320.10, 321.21, 320.53, MLO
+1965, 08, 23969, 1965.6219, 318.87, 320.18, 318.86, 320.21, 318.87, 320.18, MLO
+1965, 09, 24000, 1965.7068, 317.82, 320.78, 317.35, 320.33, 317.82, 320.78, MLO
+1965, 10, 24030, 1965.7890, 317.30, 320.37, 317.38, 320.44, 317.30, 320.37, MLO
+1965, 11, 24061, 1965.8740, 318.87, 320.79, 318.65, 320.55, 318.87, 320.79, MLO
+1965, 12, 24091, 1965.9562, 319.42, 320.20, 319.90, 320.67, 319.42, 320.20, MLO
+1966, 01, 24122, 1966.0411, 320.62, 320.57, 320.86, 320.79, 320.62, 320.57, MLO
+1966, 02, 24153, 1966.1260, 321.60, 320.94, 321.57, 320.91, 321.60, 320.94, MLO
+1966, 03, 24181, 1966.2027, 322.39, 321.09, 322.33, 321.01, 322.39, 321.09, MLO
+1966, 04, 24212, 1966.2877, 323.70, 321.34, 323.49, 321.12, 323.70, 321.34, MLO
+1966, 05, 24242, 1966.3699, 324.08, 321.19, 324.12, 321.22, 324.08, 321.19, MLO
+1966, 06, 24273, 1966.4548, 323.75, 321.56, 323.50, 321.32, 323.75, 321.56, MLO
+1966, 07, 24303, 1966.5370, 322.37, 321.69, 322.06, 321.41, 322.37, 321.69, MLO
+1966, 08, 24334, 1966.6219, 320.36, 321.68, 320.13, 321.48, 320.36, 321.68, MLO
+1966, 09, 24365, 1966.7068, 318.64, 321.61, 318.57, 321.56, 318.64, 321.61, MLO
+1966, 10, 24395, 1966.7890, 318.10, 321.18, 318.56, 321.62, 318.10, 321.18, MLO
+1966, 11, 24426, 1966.8740, 319.78, 321.71, 319.78, 321.69, 319.78, 321.71, MLO
+1966, 12, 24456, 1966.9562, 321.02, 321.81, 320.98, 321.74, 321.02, 321.81, MLO
+1967, 01, 24487, 1967.0411, 322.33, 322.27, 321.87, 321.80, 322.33, 322.27, MLO
+1967, 02, 24518, 1967.1260, 322.50, 321.83, 322.53, 321.86, 322.50, 321.83, MLO
+1967, 03, 24546, 1967.2027, 323.03, 321.73, 323.23, 321.91, 323.03, 321.73, MLO
+1967, 04, 24577, 1967.2877, 324.41, 322.05, 324.34, 321.96, 324.41, 322.05, MLO
+1967, 05, 24607, 1967.3699, 325.00, 322.10, 324.92, 322.02, 325.00, 322.10, MLO
+1967, 06, 24638, 1967.4548, 324.09, 321.89, 324.26, 322.08, 324.09, 321.89, MLO
+1967, 07, 24668, 1967.5370, 322.54, 321.86, 322.79, 322.14, 322.54, 321.86, MLO
+1967, 08, 24699, 1967.6219, 320.92, 322.24, 320.85, 322.21, 320.92, 322.24, MLO
+1967, 09, 24730, 1967.7068, 319.25, 322.24, 319.28, 322.28, 319.25, 322.24, MLO
+1967, 10, 24760, 1967.7890, 319.39, 322.48, 319.28, 322.35, 319.39, 322.48, MLO
+1967, 11, 24791, 1967.8740, 320.73, 322.66, 320.51, 322.42, 320.73, 322.66, MLO
+1967, 12, 24821, 1967.9562, 321.95, 322.74, 321.73, 322.50, 321.95, 322.74, MLO
+1968, 01, 24852, 1968.0410, 322.57, 322.51, 322.64, 322.57, 322.57, 322.51, MLO
+1968, 02, 24883, 1968.1257, 323.15, 322.48, 323.33, 322.65, 323.15, 322.48, MLO
+1968, 03, 24912, 1968.2049, 323.89, 322.55, 324.08, 322.73, 323.89, 322.55, MLO
+1968, 04, 24943, 1968.2896, 325.02, 322.63, 325.24, 322.83, 325.02, 322.63, MLO
+1968, 05, 24973, 1968.3716, 325.57, 322.66, 325.84, 322.93, 325.57, 322.66, MLO
+1968, 06, 25004, 1968.4563, 325.36, 323.17, 325.20, 323.03, 325.36, 323.17, MLO
+1968, 07, 25034, 1968.5383, 324.14, 323.48, 323.77, 323.14, 324.14, 323.48, MLO
+1968, 08, 25065, 1968.6230, 322.11, 323.46, 321.87, 323.26, 322.11, 323.46, MLO
+1968, 09, 25096, 1968.7077, 320.33, 323.33, 320.36, 323.37, 320.33, 323.33, MLO
+1968, 10, 25126, 1968.7896, 320.25, 323.34, 320.41, 323.49, 320.25, 323.34, MLO
+1968, 11, 25157, 1968.8743, 321.32, 323.26, 321.71, 323.62, 321.32, 323.26, MLO
+1968, 12, 25187, 1968.9563, 322.89, 323.68, 322.98, 323.75, 322.89, 323.68, MLO
+1969, 01, 25218, 1969.0411, 324.00, 323.94, 323.96, 323.89, 324.00, 323.94, MLO
+1969, 02, 25249, 1969.1260, 324.41, 323.75, 324.71, 324.03, 324.41, 323.75, MLO
+1969, 03, 25277, 1969.2027, 325.63, 324.32, 325.49, 324.16, 325.63, 324.32, MLO
+1969, 04, 25308, 1969.2877, 326.66, 324.29, 326.70, 324.31, 326.66, 324.29, MLO
+1969, 05, 25338, 1969.3699, 327.38, 324.46, 327.36, 324.44, 327.38, 324.46, MLO
+1969, 06, 25369, 1969.4548, 326.71, 324.49, 326.77, 324.57, 326.71, 324.49, MLO
+1969, 07, 25399, 1969.5370, 325.88, 325.19, 325.35, 324.69, 325.88, 325.19, MLO
+1969, 08, 25430, 1969.6219, 323.66, 324.99, 323.44, 324.81, 323.66, 324.99, MLO
+1969, 09, 25461, 1969.7068, 322.38, 325.38, 321.89, 324.91, 322.38, 325.38, MLO
+1969, 10, 25491, 1969.7890, 321.78, 324.88, 321.90, 325.00, 321.78, 324.88, MLO
+1969, 11, 25522, 1969.8740, 322.85, 324.80, 323.16, 325.08, 322.85, 324.80, MLO
+1969, 12, 25552, 1969.9562, 324.11, 324.91, 324.38, 325.16, 324.11, 324.91, MLO
+1970, 01, 25583, 1970.0411, 325.06, 325.00, 325.31, 325.24, 325.06, 325.00, MLO
+1970, 02, 25614, 1970.1260, 325.99, 325.32, 326.00, 325.33, 325.99, 325.32, MLO
+1970, 03, 25642, 1970.2027, 326.93, 325.61, 326.73, 325.40, 326.93, 325.61, MLO
+1970, 04, 25673, 1970.2877, 328.13, 325.75, 327.88, 325.48, 328.13, 325.75, MLO
+1970, 05, 25703, 1970.3699, 328.08, 325.15, 328.48, 325.55, 328.08, 325.15, MLO
+1970, 06, 25734, 1970.4548, 327.67, 325.44, 327.84, 325.63, 327.67, 325.44, MLO
+1970, 07, 25764, 1970.5370, 326.34, 325.65, 326.37, 325.70, 326.34, 325.65, MLO
+1970, 08, 25795, 1970.6219, 324.68, 326.02, 324.40, 325.77, 324.68, 326.02, MLO
+1970, 09, 25826, 1970.7068, 323.10, 326.11, 322.81, 325.84, 323.10, 326.11, MLO
+1970, 10, 25856, 1970.7890, 323.07, 326.18, 322.79, 325.89, 323.07, 326.18, MLO
+1970, 11, 25887, 1970.8740, 324.01, 325.96, 324.00, 325.93, 324.01, 325.96, MLO
+1970, 12, 25917, 1970.9562, 325.13, 325.93, 325.19, 325.97, 325.13, 325.93, MLO
+1971, 01, 25948, 1971.0411, 326.17, 326.11, 326.08, 326.01, 326.17, 326.11, MLO
+1971, 02, 25979, 1971.1260, 326.69, 326.01, 326.73, 326.05, 326.69, 326.01, MLO
+1971, 03, 26007, 1971.2027, 327.18, 325.85, 327.43, 326.09, 327.18, 325.85, MLO
+1971, 04, 26038, 1971.2877, 327.78, 325.39, 328.55, 326.14, 327.78, 325.39, MLO
+1971, 05, 26068, 1971.3699, 328.93, 325.99, 329.14, 326.20, 328.93, 325.99, MLO
+1971, 06, 26099, 1971.4548, 328.57, 326.34, 328.48, 326.26, 328.57, 326.34, MLO
+1971, 07, 26129, 1971.5370, 327.36, 326.67, 327.00, 326.33, 327.36, 326.67, MLO
+1971, 08, 26160, 1971.6219, 325.43, 326.77, 325.03, 326.41, 325.43, 326.77, MLO
+1971, 09, 26191, 1971.7068, 323.36, 326.38, 323.44, 326.48, 323.36, 326.38, MLO
+1971, 10, 26221, 1971.7890, 323.56, 326.69, 323.44, 326.55, 323.56, 326.69, MLO
+1971, 11, 26252, 1971.8740, 324.80, 326.75, 324.69, 326.62, 324.80, 326.75, MLO
+1971, 12, 26282, 1971.9562, 326.01, 326.81, 325.92, 326.70, 326.01, 326.81, MLO
+1972, 01, 26313, 1972.0410, 326.77, 326.71, 326.86, 326.79, 326.77, 326.71, MLO
+1972, 02, 26344, 1972.1257, 327.63, 326.96, 327.56, 326.88, 327.63, 326.96, MLO
+1972, 03, 26373, 1972.2049, 327.75, 326.40, 328.35, 326.98, 327.75, 326.40, MLO
+1972, 04, 26404, 1972.2896, 329.72, 327.30, 329.54, 327.10, 329.72, 327.30, MLO
+1972, 05, 26434, 1972.3716, 330.07, 327.12, 330.18, 327.23, 330.07, 327.12, MLO
+1972, 06, 26465, 1972.4563, 329.09, 326.87, 329.58, 327.38, 329.09, 326.87, MLO
+1972, 07, 26495, 1972.5383, 328.04, 327.37, 328.18, 327.54, 328.04, 327.37, MLO
+1972, 08, 26526, 1972.6230, 326.32, 327.69, 326.32, 327.72, 326.32, 327.69, MLO
+1972, 09, 26557, 1972.7077, 324.84, 327.88, 324.86, 327.92, 324.84, 327.88, MLO
+1972, 10, 26587, 1972.7896, 325.20, 328.33, 324.99, 328.11, 325.20, 328.33, MLO
+1972, 11, 26618, 1972.8743, 326.50, 328.46, 326.38, 328.31, 326.50, 328.46, MLO
+1972, 12, 26648, 1972.9563, 327.55, 328.35, 327.73, 328.51, 327.55, 328.35, MLO
+1973, 01, 26679, 1973.0411, 328.55, 328.49, 328.79, 328.72, 328.55, 328.49, MLO
+1973, 02, 26710, 1973.1260, 329.56, 328.89, 329.61, 328.93, 329.56, 328.89, MLO
+1973, 03, 26738, 1973.2027, 330.30, 328.97, 330.46, 329.11, 330.30, 328.97, MLO
+1973, 04, 26769, 1973.2877, 331.50, 329.10, 331.73, 329.31, 331.50, 329.10, MLO
+1973, 05, 26799, 1973.3699, 332.48, 329.52, 332.44, 329.48, 332.48, 329.52, MLO
+1973, 06, 26830, 1973.4548, 332.07, 329.83, 331.87, 329.64, 332.07, 329.83, MLO
+1973, 07, 26860, 1973.5370, 330.87, 330.17, 330.44, 329.77, 330.87, 330.17, MLO
+1973, 08, 26891, 1973.6219, 329.31, 330.66, 328.50, 329.88, 329.31, 330.66, MLO
+1973, 09, 26922, 1973.7068, 327.52, 330.56, 326.91, 329.96, 327.52, 330.56, MLO
+1973, 10, 26952, 1973.7890, 327.19, 330.33, 326.89, 330.02, 327.19, 330.33, MLO
+1973, 11, 26983, 1973.8740, 328.17, 330.13, 328.10, 330.05, 328.17, 330.13, MLO
+1973, 12, 27013, 1973.9562, 328.65, 329.45, 329.29, 330.08, 328.65, 329.45, MLO
+1974, 01, 27044, 1974.0411, 329.36, 329.30, 330.17, 330.10, 329.36, 329.30, MLO
+1974, 02, 27075, 1974.1260, 330.71, 330.04, 330.81, 330.13, 330.71, 330.04, MLO
+1974, 03, 27103, 1974.2027, 331.49, 330.15, 331.50, 330.15, 331.49, 330.15, MLO
+1974, 04, 27134, 1974.2877, 332.65, 330.24, 332.62, 330.19, 332.65, 330.24, MLO
+1974, 05, 27164, 1974.3699, 333.10, 330.13, 333.19, 330.23, 333.10, 330.13, MLO
+1974, 06, 27195, 1974.4548, 332.26, 330.01, 332.51, 330.27, 332.26, 330.01, MLO
+1974, 07, 27225, 1974.5370, 331.18, 330.48, 330.99, 330.32, 331.18, 330.48, MLO
+1974, 08, 27256, 1974.6219, 329.40, 330.75, 328.98, 330.37, 329.40, 330.75, MLO
+1974, 09, 27287, 1974.7068, 327.44, 330.49, 327.36, 330.42, 327.44, 330.49, MLO
+1974, 10, 27317, 1974.7890, 327.38, 330.53, 327.33, 330.47, 327.38, 330.53, MLO
+1974, 11, 27348, 1974.8740, 328.46, 330.44, 328.58, 330.53, 328.46, 330.44, MLO
+1974, 12, 27378, 1974.9562, 329.58, 330.38, 329.81, 330.59, 329.58, 330.38, MLO
+1975, 01, 27409, 1975.0411, 330.41, 330.35, 330.74, 330.67, 330.41, 330.35, MLO
+1975, 02, 27440, 1975.1260, 331.41, 330.73, 331.44, 330.75, 331.41, 330.73, MLO
+1975, 03, 27468, 1975.2027, 332.04, 330.70, 332.18, 330.83, 332.04, 330.70, MLO
+1975, 04, 27499, 1975.2877, 333.32, 330.89, 333.36, 330.92, 333.32, 330.89, MLO
+1975, 05, 27529, 1975.3699, 333.98, 331.00, 333.99, 331.02, 333.98, 331.00, MLO
+1975, 06, 27560, 1975.4548, 333.62, 331.36, 333.36, 331.12, 333.62, 331.36, MLO
+1975, 07, 27590, 1975.5370, 331.91, 331.21, 331.88, 331.21, 331.91, 331.21, MLO
+1975, 08, 27621, 1975.6219, 330.06, 331.42, 329.92, 331.31, 330.06, 331.42, MLO
+1975, 09, 27652, 1975.7068, 328.57, 331.62, 328.32, 331.40, 328.57, 331.62, MLO
+1975, 10, 27682, 1975.7890, 328.35, 331.51, 328.33, 331.48, 328.35, 331.51, MLO
+1975, 11, 27713, 1975.8740, 329.50, 331.48, 329.61, 331.57, 329.50, 331.48, MLO
+1975, 12, 27743, 1975.9562, 330.77, 331.58, 330.86, 331.65, 330.77, 331.58, MLO
+1976, 01, 27774, 1976.0410, 331.76, 331.70, 331.80, 331.73, 331.76, 331.70, MLO
+1976, 02, 27805, 1976.1257, 332.58, 331.90, 332.50, 331.81, 332.58, 331.90, MLO
+1976, 03, 27834, 1976.2049, 333.50, 332.14, 333.27, 331.88, 333.50, 332.14, MLO
+1976, 04, 27865, 1976.2896, 334.59, 332.14, 334.43, 331.96, 334.59, 332.14, MLO
+1976, 05, 27895, 1976.3716, 334.89, 331.90, 335.02, 332.04, 334.89, 331.90, MLO
+1976, 06, 27926, 1976.4563, 334.34, 332.10, 334.35, 332.12, 334.34, 332.10, MLO
+1976, 07, 27956, 1976.5383, 333.06, 332.38, 332.85, 332.21, 333.06, 332.38, MLO
+1976, 08, 27987, 1976.6230, 330.95, 332.34, 330.88, 332.30, 330.95, 332.34, MLO
+1976, 09, 28018, 1976.7077, 329.31, 332.39, 329.31, 332.41, 329.31, 332.39, MLO
+1976, 10, 28048, 1976.7896, 328.95, 332.12, 329.36, 332.52, 328.95, 332.12, MLO
+1976, 11, 28079, 1976.8743, 330.32, 332.30, 330.69, 332.65, 330.32, 332.30, MLO
+1976, 12, 28109, 1976.9563, 331.69, 332.50, 331.99, 332.79, 331.69, 332.50, MLO
+1977, 01, 28140, 1977.0411, 332.94, 332.88, 333.02, 332.95, 332.94, 332.88, MLO
+1977, 02, 28171, 1977.1260, 333.43, 332.75, 333.81, 333.12, 333.43, 332.75, MLO
+1977, 03, 28199, 1977.2027, 334.71, 333.36, 334.65, 333.28, 334.71, 333.36, MLO
+1977, 04, 28230, 1977.2877, 336.08, 333.64, 335.92, 333.47, 336.08, 333.64, MLO
+1977, 05, 28260, 1977.3699, 336.76, 333.76, 336.64, 333.65, 336.76, 333.76, MLO
+1977, 06, 28291, 1977.4548, 336.28, 334.01, 336.08, 333.83, 336.28, 334.01, MLO
+1977, 07, 28321, 1977.5370, 334.93, 334.22, 334.67, 334.00, 334.93, 334.22, MLO
+1977, 08, 28352, 1977.6219, 332.76, 334.13, 332.77, 334.17, 332.76, 334.13, MLO
+1977, 09, 28383, 1977.7068, 331.60, 334.68, 331.23, 334.32, 331.60, 334.68, MLO
+1977, 10, 28413, 1977.7890, 331.17, 334.35, 331.30, 334.47, 331.17, 334.35, MLO
+1977, 11, 28444, 1977.8740, 332.41, 334.41, 332.64, 334.61, 332.41, 334.41, MLO
+1977, 12, 28474, 1977.9562, 333.86, 334.67, 333.95, 334.75, 333.86, 334.67, MLO
+1978, 01, 28505, 1978.0411, 334.98, 334.92, 334.96, 334.89, 334.98, 334.92, MLO
+1978, 02, 28536, 1978.1260, 335.40, 334.71, 335.72, 335.02, 335.40, 334.71, MLO
+1978, 03, 28564, 1978.2027, 336.65, 335.30, 336.51, 335.14, 336.65, 335.30, MLO
+1978, 04, 28595, 1978.2877, 337.76, 335.32, 337.73, 335.27, 337.76, 335.32, MLO
+1978, 05, 28625, 1978.3699, 338.02, 335.02, 338.39, 335.39, 338.02, 335.02, MLO
+1978, 06, 28656, 1978.4548, 337.91, 335.63, 337.76, 335.50, 337.91, 335.63, MLO
+1978, 07, 28686, 1978.5370, 336.55, 335.84, 336.29, 335.61, 336.55, 335.84, MLO
+1978, 08, 28717, 1978.6219, 334.69, 336.06, 334.31, 335.71, 334.69, 336.06, MLO
+1978, 09, 28748, 1978.7068, 332.77, 335.86, 332.71, 335.81, 332.77, 335.86, MLO
+1978, 10, 28778, 1978.7890, 332.56, 335.75, 332.72, 335.90, 332.56, 335.75, MLO
+1978, 11, 28809, 1978.8740, 333.93, 335.93, 334.02, 336.00, 333.93, 335.93, MLO
+1978, 12, 28839, 1978.9562, 334.96, 335.77, 335.30, 336.10, 334.96, 335.77, MLO
+1979, 01, 28870, 1979.0411, 336.24, 336.18, 336.28, 336.20, 336.24, 336.18, MLO
+1979, 02, 28901, 1979.1260, 336.77, 336.08, 337.02, 336.32, 336.77, 336.08, MLO
+1979, 03, 28929, 1979.2027, 337.97, 336.62, 337.80, 336.43, 337.97, 336.62, MLO
+1979, 04, 28960, 1979.2877, 338.89, 336.44, 339.02, 336.55, 338.89, 336.44, MLO
+1979, 05, 28990, 1979.3699, 339.48, 336.47, 339.69, 336.68, 339.48, 336.47, MLO
+1979, 06, 29021, 1979.4548, 339.30, 337.01, 339.08, 336.82, 339.30, 337.01, MLO
+1979, 07, 29051, 1979.5370, 337.74, 337.03, 337.63, 336.95, 337.74, 337.03, MLO
+1979, 08, 29082, 1979.6219, 336.10, 337.47, 335.68, 337.09, 336.10, 337.47, MLO
+1979, 09, 29113, 1979.7068, 333.93, 337.03, 334.12, 337.24, 333.93, 337.03, MLO
+1979, 10, 29143, 1979.7890, 333.87, 337.07, 334.19, 337.38, 333.87, 337.07, MLO
+1979, 11, 29174, 1979.8740, 335.30, 337.31, 335.56, 337.54, 335.30, 337.31, MLO
+1979, 12, 29204, 1979.9562, 336.74, 337.56, 336.90, 337.70, 336.74, 337.56, MLO
+1980, 01, 29235, 1980.0410, 338.03, 337.97, 337.94, 337.86, 338.03, 337.97, MLO
+1980, 02, 29266, 1980.1257, 338.37, 337.68, 338.73, 338.03, 338.37, 337.68, MLO
+1980, 03, 29295, 1980.2049, 340.09, 338.70, 339.59, 338.19, 340.09, 338.70, MLO
+1980, 04, 29326, 1980.2896, 340.78, 338.30, 340.85, 338.35, 340.78, 338.30, MLO
+1980, 05, 29356, 1980.3716, 341.48, 338.46, 341.52, 338.50, 341.48, 338.46, MLO
+1980, 06, 29387, 1980.4563, 341.19, 338.92, 340.90, 338.65, 341.19, 338.92, MLO
+1980, 07, 29417, 1980.5383, 339.57, 338.89, 339.44, 338.78, 339.57, 338.89, MLO
+1980, 08, 29448, 1980.6230, 337.61, 339.02, 337.48, 338.92, 337.61, 339.02, MLO
+1980, 09, 29479, 1980.7077, 335.90, 339.02, 335.91, 339.04, 335.90, 339.02, MLO
+1980, 10, 29509, 1980.7896, 336.03, 339.24, 335.96, 339.15, 336.03, 339.24, MLO
+1980, 11, 29540, 1980.8743, 337.12, 339.13, 337.27, 339.26, 337.12, 339.13, MLO
+1980, 12, 29570, 1980.9563, 338.23, 339.05, 338.56, 339.36, 338.23, 339.05, MLO
+1981, 01, 29601, 1981.0411, 339.25, 339.19, 339.54, 339.47, 339.25, 339.19, MLO
+1981, 02, 29632, 1981.1260, 340.50, 339.81, 340.27, 339.57, 340.50, 339.81, MLO
+1981, 03, 29660, 1981.2027, 341.40, 340.04, 341.03, 339.66, 341.40, 340.04, MLO
+1981, 04, 29691, 1981.2877, 342.52, 340.06, 342.23, 339.75, 342.52, 340.06, MLO
+1981, 05, 29721, 1981.3699, 342.93, 339.90, 342.86, 339.83, 342.93, 339.90, MLO
+1981, 06, 29752, 1981.4548, 342.27, 339.97, 342.20, 339.92, 342.27, 339.97, MLO
+1981, 07, 29782, 1981.5370, 340.50, 339.79, 340.68, 340.00, 340.50, 339.79, MLO
+1981, 08, 29813, 1981.6219, 338.45, 339.83, 338.67, 340.09, 338.45, 339.83, MLO
+1981, 09, 29844, 1981.7068, 336.71, 339.83, 337.05, 340.19, 336.71, 339.83, MLO
+1981, 10, 29874, 1981.7890, 336.88, 340.10, 337.08, 340.29, 336.88, 340.10, MLO
+1981, 11, 29905, 1981.8740, 338.38, 340.40, 338.40, 340.40, 338.38, 340.40, MLO
+1981, 12, 29935, 1981.9562, 339.63, 340.45, 339.70, 340.50, 339.63, 340.45, MLO
+1982, 01, 29966, 1982.0411, 340.77, 340.71, 340.69, 340.61, 340.77, 340.71, MLO
+1982, 02, 29997, 1982.1260, 341.63, 340.94, 341.42, 340.72, 341.63, 340.94, MLO
+1982, 03, 30025, 1982.2027, 342.72, 341.35, 342.19, 340.81, 342.72, 341.35, MLO
+1982, 04, 30056, 1982.2877, 343.59, 341.11, 343.39, 340.90, 343.59, 341.11, MLO
+1982, 05, 30086, 1982.3699, 344.16, 341.12, 344.02, 340.98, 344.16, 341.12, MLO
+1982, 06, 30117, 1982.4548, 343.37, 341.06, 343.35, 341.06, 343.37, 341.06, MLO
+1982, 07, 30147, 1982.5370, 342.07, 341.36, 341.83, 341.14, 342.07, 341.36, MLO
+1982, 08, 30178, 1982.6219, 339.83, 341.21, 339.80, 341.22, 339.83, 341.21, MLO
+1982, 09, 30209, 1982.7068, 338.00, 341.12, 338.16, 341.31, 338.00, 341.12, MLO
+1982, 10, 30239, 1982.7890, 337.88, 341.11, 338.18, 341.40, 337.88, 341.11, MLO
+1982, 11, 30270, 1982.8740, 339.28, 341.31, 339.51, 341.52, 339.28, 341.31, MLO
+1982, 12, 30300, 1982.9562, 340.51, 341.33, 340.84, 341.65, 340.51, 341.33, MLO
+1983, 01, 30331, 1983.0411, 341.40, 341.33, 341.87, 341.80, 341.40, 341.33, MLO
+1983, 02, 30362, 1983.1260, 342.54, 341.85, 342.68, 341.97, 342.54, 341.85, MLO
+1983, 03, 30390, 1983.2027, 343.12, 341.74, 343.52, 342.14, 343.12, 341.74, MLO
+1983, 04, 30421, 1983.2877, 344.96, 342.48, 344.83, 342.33, 344.96, 342.48, MLO
+1983, 05, 30451, 1983.3699, 345.78, 342.73, 345.57, 342.52, 345.78, 342.73, MLO
+1983, 06, 30482, 1983.4548, 345.34, 343.02, 345.01, 342.71, 345.34, 343.02, MLO
+1983, 07, 30512, 1983.5370, 344.00, 343.28, 343.58, 342.89, 344.00, 343.28, MLO
+1983, 08, 30543, 1983.6219, 342.40, 343.79, 341.64, 343.06, 342.40, 343.79, MLO
+1983, 09, 30574, 1983.7068, 339.89, 343.02, 340.08, 343.23, 339.89, 343.02, MLO
+1983, 10, 30604, 1983.7890, 340.00, 343.25, 340.15, 343.38, 340.00, 343.25, MLO
+1983, 11, 30635, 1983.8740, 341.16, 343.19, 341.52, 343.53, 341.16, 343.19, MLO
+1983, 12, 30665, 1983.9562, 342.99, 343.81, 342.86, 343.67, 342.99, 343.81, MLO
+1984, 01, 30696, 1984.0410, 343.82, 343.76, 343.89, 343.82, 343.82, 343.76, MLO
+1984, 02, 30727, 1984.1257, 344.62, 343.93, 344.66, 343.96, 344.62, 343.93, MLO
+1984, 03, 30756, 1984.2049, 345.38, 343.98, 345.50, 344.08, 345.38, 343.98, MLO
+1984, 04, 30787, 1984.2896, 347.14, 344.63, 346.74, 344.22, 347.14, 344.63, MLO
+1984, 05, 30817, 1984.3716, 347.52, 344.46, 347.39, 344.34, 347.52, 344.46, MLO
+1984, 06, 30848, 1984.4563, 346.88, 344.58, 346.74, 344.46, 346.88, 344.58, MLO
+1984, 07, 30878, 1984.5383, 345.47, 344.77, 345.23, 344.57, 345.47, 344.77, MLO
+1984, 08, 30909, 1984.6230, 343.34, 344.76, 343.23, 344.69, 343.34, 344.76, MLO
+1984, 09, 30940, 1984.7077, 341.13, 344.29, 341.63, 344.80, 341.13, 344.29, MLO
+1984, 10, 30970, 1984.7896, 341.40, 344.64, 341.68, 344.92, 341.40, 344.64, MLO
+1984, 11, 31001, 1984.8743, 343.02, 345.05, 343.03, 345.04, 343.02, 345.05, MLO
+1984, 12, 31031, 1984.9563, 344.25, 345.08, 344.35, 345.16, 344.25, 345.08, MLO
+1985, 01, 31062, 1985.0411, 344.99, 344.93, 345.36, 345.28, 344.99, 344.93, MLO
+1985, 02, 31093, 1985.1260, 346.01, 345.31, 346.12, 345.41, 346.01, 345.31, MLO
+1985, 03, 31121, 1985.2027, 347.43, 346.05, 346.91, 345.52, 347.43, 346.05, MLO
+1985, 04, 31152, 1985.2877, 348.34, 345.85, 348.14, 345.63, 348.34, 345.85, MLO
+1985, 05, 31182, 1985.3699, 348.92, 345.85, 348.80, 345.73, 348.92, 345.85, MLO
+1985, 06, 31213, 1985.4548, 348.24, 345.91, 348.14, 345.83, 348.24, 345.91, MLO
+1985, 07, 31243, 1985.5370, 346.53, 345.81, 346.61, 345.92, 346.53, 345.81, MLO
+1985, 08, 31274, 1985.6219, 344.64, 346.04, 344.57, 346.00, 344.64, 346.04, MLO
+1985, 09, 31305, 1985.7068, 343.06, 346.21, 342.92, 346.09, 343.06, 346.21, MLO
+1985, 10, 31335, 1985.7890, 342.77, 346.04, 342.92, 346.17, 342.77, 346.04, MLO
+1985, 11, 31366, 1985.8740, 344.21, 346.26, 344.24, 346.26, 344.21, 346.26, MLO
+1985, 12, 31396, 1985.9562, 345.53, 346.36, 345.54, 346.35, 345.53, 346.36, MLO
+1986, 01, 31427, 1986.0411, 346.28, 346.21, 346.53, 346.45, 346.28, 346.21, MLO
+1986, 02, 31458, 1986.1260, 346.93, 346.23, 347.27, 346.56, 346.93, 346.23, MLO
+1986, 03, 31486, 1986.2027, 347.83, 346.44, 348.07, 346.67, 347.83, 346.44, MLO
+1986, 04, 31517, 1986.2877, 349.53, 347.03, 349.32, 346.80, 349.53, 347.03, MLO
+1986, 05, 31547, 1986.3699, 350.19, 347.12, 350.00, 346.92, 350.19, 347.12, MLO
+1986, 06, 31578, 1986.4548, 349.54, 347.20, 349.36, 347.05, 349.54, 347.20, MLO
+1986, 07, 31608, 1986.5370, 347.92, 347.19, 347.87, 347.17, 347.92, 347.19, MLO
+1986, 08, 31639, 1986.6219, 345.88, 347.28, 345.86, 347.30, 345.88, 347.28, MLO
+1986, 09, 31670, 1986.7068, 344.83, 347.99, 344.25, 347.43, 344.83, 347.99, MLO
+1986, 10, 31700, 1986.7890, 344.15, 347.43, 344.30, 347.56, 344.15, 347.43, MLO
+1986, 11, 31731, 1986.8740, 345.64, 347.69, 345.66, 347.69, 345.64, 347.69, MLO
+1986, 12, 31761, 1986.9562, 346.88, 347.71, 347.00, 347.82, 346.88, 347.71, MLO
+1987, 01, 31792, 1987.0411, 348.00, 347.94, 348.04, 347.96, 348.00, 347.94, MLO
+1987, 02, 31823, 1987.1260, 348.47, 347.76, 348.83, 348.12, 348.47, 347.76, MLO
+1987, 03, 31851, 1987.2027, 349.40, 348.02, 349.67, 348.27, 349.40, 348.02, MLO
+1987, 04, 31882, 1987.2877, 350.97, 348.46, 350.97, 348.44, 350.97, 348.46, MLO
+1987, 05, 31912, 1987.3699, 351.84, 348.75, 351.70, 348.61, 351.84, 348.75, MLO
+1987, 06, 31943, 1987.4548, 351.25, 348.91, 351.12, 348.80, 351.25, 348.91, MLO
+1987, 07, 31973, 1987.5370, 349.50, 348.77, 349.68, 348.99, 349.50, 348.77, MLO
+1987, 08, 32004, 1987.6219, 348.08, 349.49, 347.74, 349.18, 348.08, 349.49, MLO
+1987, 09, 32035, 1987.7068, 346.44, 349.61, 346.19, 349.38, 346.44, 349.61, MLO
+1987, 10, 32065, 1987.7890, 346.09, 349.37, 346.30, 349.57, 346.09, 349.37, MLO
+1987, 11, 32096, 1987.8740, 347.54, 349.60, 347.74, 349.77, 347.54, 349.60, MLO
+1987, 12, 32126, 1987.9562, 348.69, 349.53, 349.15, 349.97, 348.69, 349.53, MLO
+1988, 01, 32157, 1988.0410, 350.16, 350.10, 350.25, 350.18, 350.16, 350.10, MLO
+1988, 02, 32188, 1988.1257, 351.47, 350.77, 351.10, 350.39, 351.47, 350.77, MLO
+1988, 03, 32217, 1988.2049, 351.96, 350.54, 352.01, 350.58, 351.96, 350.54, MLO
+1988, 04, 32248, 1988.2896, 353.33, 350.79, 353.34, 350.78, 353.33, 350.79, MLO
+1988, 05, 32278, 1988.3716, 353.97, 350.88, 354.06, 350.97, 353.97, 350.88, MLO
+1988, 06, 32309, 1988.4563, 353.55, 351.22, 353.46, 351.16, 353.55, 351.22, MLO
+1988, 07, 32339, 1988.5383, 352.14, 351.44, 352.00, 351.33, 352.14, 351.44, MLO
+1988, 08, 32370, 1988.6230, 350.19, 351.63, 350.02, 351.50, 350.19, 351.63, MLO
+1988, 09, 32401, 1988.7077, 348.50, 351.69, 348.45, 351.65, 348.50, 351.69, MLO
+1988, 10, 32431, 1988.7896, 348.66, 351.94, 348.53, 351.80, 348.66, 351.94, MLO
+1988, 11, 32462, 1988.8743, 349.85, 351.90, 349.90, 351.93, 349.85, 351.90, MLO
+1988, 12, 32492, 1988.9563, 351.12, 351.96, 351.23, 352.05, 351.12, 351.96, MLO
+1989, 01, 32523, 1989.0411, 352.55, 352.49, 352.25, 352.17, 352.55, 352.49, MLO
+1989, 02, 32554, 1989.1260, 352.86, 352.15, 353.00, 352.29, 352.86, 352.15, MLO
+1989, 03, 32582, 1989.2027, 353.48, 352.08, 353.80, 352.38, 353.48, 352.08, MLO
+1989, 04, 32613, 1989.2877, 355.21, 352.69, 355.03, 352.49, 355.21, 352.69, MLO
+1989, 05, 32643, 1989.3699, 355.47, 352.37, 355.69, 352.59, 355.47, 352.37, MLO
+1989, 06, 32674, 1989.4548, 354.92, 352.57, 355.03, 352.69, 354.92, 352.57, MLO
+1989, 07, 32704, 1989.5370, 353.70, 352.96, 353.49, 352.79, 353.70, 352.96, MLO
+1989, 08, 32735, 1989.6219, 351.47, 352.88, 351.44, 352.89, 351.47, 352.88, MLO
+1989, 09, 32766, 1989.7068, 349.61, 352.80, 349.78, 352.99, 349.61, 352.80, MLO
+1989, 10, 32796, 1989.7890, 349.79, 353.09, 349.80, 353.08, 349.79, 353.09, MLO
+1989, 11, 32827, 1989.8740, 351.10, 353.16, 351.14, 353.18, 351.10, 353.16, MLO
+1989, 12, 32857, 1989.9562, 352.32, 353.17, 352.46, 353.28, 352.32, 353.17, MLO
+1990, 01, 32888, 1990.0411, 353.46, 353.40, 353.46, 353.38, 353.46, 353.40, MLO
+1990, 02, 32919, 1990.1260, 354.50, 353.79, 354.21, 353.49, 354.50, 353.79, MLO
+1990, 03, 32947, 1990.2027, 355.19, 353.79, 355.00, 353.58, 355.19, 353.79, MLO
+1990, 04, 32978, 1990.2877, 356.00, 353.47, 356.24, 353.69, 356.00, 353.47, MLO
+1990, 05, 33008, 1990.3699, 356.96, 353.85, 356.90, 353.79, 356.96, 353.85, MLO
+1990, 06, 33039, 1990.4548, 356.04, 353.68, 356.25, 353.91, 356.04, 353.68, MLO
+1990, 07, 33069, 1990.5370, 354.62, 353.89, 354.73, 354.02, 354.62, 353.89, MLO
+1990, 08, 33100, 1990.6219, 352.71, 354.13, 352.70, 354.16, 352.71, 354.13, MLO
+1990, 09, 33131, 1990.7068, 350.77, 353.98, 351.08, 354.30, 350.77, 353.98, MLO
+1990, 10, 33161, 1990.7890, 350.99, 354.29, 351.14, 354.44, 350.99, 354.29, MLO
+1990, 11, 33192, 1990.8740, 352.64, 354.71, 352.54, 354.59, 352.64, 354.71, MLO
+1990, 12, 33222, 1990.9562, 354.02, 354.86, 353.91, 354.73, 354.02, 354.86, MLO
+1991, 01, 33253, 1991.0411, 354.53, 354.46, 354.96, 354.88, 354.53, 354.46, MLO
+1991, 02, 33284, 1991.1260, 355.55, 354.84, 355.74, 355.02, 355.55, 354.84, MLO
+1991, 03, 33312, 1991.2027, 356.96, 355.55, 356.56, 355.14, 356.96, 355.55, MLO
+1991, 04, 33343, 1991.2877, 358.40, 355.86, 357.81, 355.25, 358.40, 355.86, MLO
+1991, 05, 33373, 1991.3699, 359.14, 356.02, 358.47, 355.35, 359.14, 356.02, MLO
+1991, 06, 33404, 1991.4548, 358.04, 355.67, 357.78, 355.43, 358.04, 355.67, MLO
+1991, 07, 33434, 1991.5370, 355.98, 355.24, 356.20, 355.49, 355.98, 355.24, MLO
+1991, 08, 33465, 1991.6219, 353.81, 355.24, 354.09, 355.55, 353.81, 355.24, MLO
+1991, 09, 33496, 1991.7068, 351.95, 355.16, 352.38, 355.61, 351.95, 355.16, MLO
+1991, 10, 33526, 1991.7890, 352.02, 355.34, 352.36, 355.67, 352.02, 355.34, MLO
+1991, 11, 33557, 1991.8740, 353.55, 355.63, 353.67, 355.73, 353.55, 355.63, MLO
+1991, 12, 33587, 1991.9562, 354.79, 355.64, 354.97, 355.80, 354.79, 355.64, MLO
+1992, 01, 33618, 1992.0410, 355.79, 355.72, 355.94, 355.87, 355.79, 355.72, MLO
+1992, 02, 33649, 1992.1257, 356.52, 355.81, 356.66, 355.94, 356.52, 355.81, MLO
+1992, 03, 33678, 1992.2049, 357.61, 356.18, 357.45, 356.00, 357.61, 356.18, MLO
+1992, 04, 33709, 1992.2896, 358.95, 356.38, 358.65, 356.06, 358.95, 356.38, MLO
+1992, 05, 33739, 1992.3716, 359.46, 356.33, 359.25, 356.12, 359.46, 356.33, MLO
+1992, 06, 33770, 1992.4563, 359.06, 356.70, 358.50, 356.16, 359.06, 356.70, MLO
+1992, 07, 33800, 1992.5383, 356.82, 356.11, 356.88, 356.20, 356.82, 356.11, MLO
+1992, 08, 33831, 1992.6230, 354.80, 356.26, 354.74, 356.23, 354.80, 356.26, MLO
+1992, 09, 33862, 1992.7077, 352.81, 356.04, 353.02, 356.26, 352.81, 356.04, MLO
+1992, 10, 33892, 1992.7896, 353.11, 356.43, 352.98, 356.29, 353.11, 356.43, MLO
+1992, 11, 33923, 1992.8743, 353.96, 356.04, 354.27, 356.33, 353.96, 356.04, MLO
+1992, 12, 33953, 1992.9563, 355.20, 356.05, 355.54, 356.37, 355.20, 356.05, MLO
+1993, 01, 33984, 1993.0411, 356.50, 356.44, 356.50, 356.43, 356.50, 356.44, MLO
+1993, 02, 34015, 1993.1260, 356.97, 356.25, 357.22, 356.49, 356.97, 356.25, MLO
+1993, 03, 34043, 1993.2027, 358.18, 356.76, 357.98, 356.55, 358.18, 356.76, MLO
+1993, 04, 34074, 1993.2877, 359.26, 356.70, 359.20, 356.63, 359.26, 356.70, MLO
+1993, 05, 34104, 1993.3699, 360.08, 356.94, 359.85, 356.71, 360.08, 356.94, MLO
+1993, 06, 34135, 1993.4548, 359.40, 357.01, 359.16, 356.80, 359.40, 357.01, MLO
+1993, 07, 34165, 1993.5370, 357.38, 356.63, 357.61, 356.90, 357.38, 356.63, MLO
+1993, 08, 34196, 1993.6219, 355.33, 356.76, 355.55, 357.01, 355.33, 356.76, MLO
+1993, 09, 34227, 1993.7068, 353.50, 356.73, 353.90, 357.14, 353.50, 356.73, MLO
+1993, 10, 34257, 1993.7890, 353.80, 357.13, 353.95, 357.28, 353.80, 357.13, MLO
+1993, 11, 34288, 1993.8740, 355.15, 357.24, 355.37, 357.43, 355.15, 357.24, MLO
+1993, 12, 34318, 1993.9562, 356.62, 357.47, 356.76, 357.59, 356.62, 357.47, MLO
+1994, 01, 34349, 1994.0411, 358.19, 358.12, 357.84, 357.76, 358.19, 358.12, MLO
+1994, 02, 34380, 1994.1260, 358.73, 358.01, 358.66, 357.93, 358.73, 358.01, MLO
+1994, 03, 34408, 1994.2027, 359.79, 358.37, 359.52, 358.09, 359.79, 358.37, MLO
+1994, 04, 34439, 1994.2877, 361.09, 358.52, 360.84, 358.26, 361.09, 358.52, MLO
+1994, 05, 34469, 1994.3699, 361.52, 358.36, 361.57, 358.42, 361.52, 358.36, MLO
+1994, 06, 34500, 1994.4548, 360.78, 358.38, 360.96, 358.59, 360.78, 358.38, MLO
+1994, 07, 34530, 1994.5370, 359.38, 358.63, 359.47, 358.75, 359.38, 358.63, MLO
+1994, 08, 34561, 1994.6219, 357.31, 358.74, 357.46, 358.93, 357.31, 358.74, MLO
+1994, 09, 34592, 1994.7068, 355.68, 358.92, 355.85, 359.11, 355.68, 358.92, MLO
+1994, 10, 34622, 1994.7890, 355.83, 359.18, 355.95, 359.28, 355.83, 359.18, MLO
+1994, 11, 34653, 1994.8740, 357.42, 359.52, 357.40, 359.47, 357.42, 359.52, MLO
+1994, 12, 34683, 1994.9562, 358.87, 359.73, 358.81, 359.65, 358.87, 359.73, MLO
+1995, 01, 34714, 1995.0411, 359.81, 359.74, 359.91, 359.84, 359.81, 359.74, MLO
+1995, 02, 34745, 1995.1260, 360.84, 360.12, 360.75, 360.02, 360.84, 360.12, MLO
+1995, 03, 34773, 1995.2027, 361.48, 360.06, 361.62, 360.18, 361.48, 360.06, MLO
+1995, 04, 34804, 1995.2877, 363.30, 360.73, 362.94, 360.36, 363.30, 360.73, MLO
+1995, 05, 34834, 1995.3699, 363.64, 360.49, 363.68, 360.52, 363.64, 360.49, MLO
+1995, 06, 34865, 1995.4548, 363.11, 360.71, 363.06, 360.69, 363.11, 360.71, MLO
+1995, 07, 34895, 1995.5370, 361.74, 361.00, 361.56, 360.85, 361.74, 361.00, MLO
+1995, 08, 34926, 1995.6219, 359.31, 360.75, 359.53, 361.01, 359.31, 360.75, MLO
+1995, 09, 34957, 1995.7068, 357.91, 361.16, 357.91, 361.17, 357.91, 361.16, MLO
+1995, 10, 34987, 1995.7890, 357.62, 360.97, 357.99, 361.33, 357.62, 360.97, MLO
+1995, 11, 35018, 1995.8740, 359.42, 361.53, 359.41, 361.49, 359.42, 361.53, MLO
+1995, 12, 35048, 1995.9562, 360.56, 361.42, 360.81, 361.65, 360.56, 361.42, MLO
+1996, 01, 35079, 1996.0410, 361.91, 361.85, 361.88, 361.80, 361.91, 361.85, MLO
+1996, 02, 35110, 1996.1257, 363.11, 362.39, 362.68, 361.95, 363.11, 362.39, MLO
+1996, 03, 35139, 1996.2049, 363.88, 362.43, 363.55, 362.08, 363.88, 362.43, MLO
+1996, 04, 35170, 1996.2896, 364.58, 361.98, 364.83, 362.21, 364.58, 361.98, MLO
+1996, 05, 35200, 1996.3716, 365.29, 362.12, 365.49, 362.32, 365.29, 362.12, MLO
+1996, 06, 35231, 1996.4563, 364.84, 362.46, 364.79, 362.43, 364.84, 362.46, MLO
+1996, 07, 35261, 1996.5383, 363.52, 362.80, 363.22, 362.53, 363.52, 362.80, MLO
+1996, 08, 35292, 1996.6230, 361.35, 362.82, 361.11, 362.62, 361.35, 362.82, MLO
+1996, 09, 35323, 1996.7077, 359.32, 362.59, 359.42, 362.71, 359.32, 362.59, MLO
+1996, 10, 35353, 1996.7896, 359.48, 362.84, 359.44, 362.79, 359.48, 362.84, MLO
+1996, 11, 35384, 1996.8743, 360.64, 362.74, 360.79, 362.87, 360.64, 362.74, MLO
+1996, 12, 35414, 1996.9563, 362.21, 363.06, 362.11, 362.95, 362.21, 363.06, MLO
+1997, 01, 35445, 1997.0411, 363.06, 363.00, 363.11, 363.03, 363.06, 363.00, MLO
+1997, 02, 35476, 1997.1260, 363.87, 363.15, 363.86, 363.12, 363.87, 363.15, MLO
+1997, 03, 35504, 1997.2027, 364.44, 363.01, 364.65, 363.21, 364.44, 363.01, MLO
+1997, 04, 35535, 1997.2877, 366.23, 363.65, 365.92, 363.31, 366.23, 363.65, MLO
+1997, 05, 35565, 1997.3699, 366.68, 363.50, 366.61, 363.43, 366.68, 363.50, MLO
+1997, 06, 35596, 1997.4548, 365.52, 363.11, 365.96, 363.57, 365.52, 363.11, MLO
+1997, 07, 35626, 1997.5370, 364.36, 363.61, 364.43, 363.72, 364.36, 363.61, MLO
+1997, 08, 35657, 1997.6219, 362.39, 363.84, 362.41, 363.89, 362.39, 363.84, MLO
+1997, 09, 35688, 1997.7068, 360.08, 363.34, 360.81, 364.09, 360.08, 363.34, MLO
+1997, 10, 35718, 1997.7890, 360.67, 364.04, 360.95, 364.31, 360.67, 364.04, MLO
+1997, 11, 35749, 1997.8740, 362.32, 364.44, 362.46, 364.55, 362.32, 364.44, MLO
+1997, 12, 35779, 1997.9562, 364.17, 365.03, 363.96, 364.81, 364.17, 365.03, MLO
+1998, 01, 35810, 1998.0411, 365.22, 365.15, 365.15, 365.08, 365.22, 365.15, MLO
+1998, 02, 35841, 1998.1260, 366.04, 365.32, 366.09, 365.35, 366.04, 365.32, MLO
+1998, 03, 35869, 1998.2027, 367.20, 365.77, 367.05, 365.60, 367.20, 365.77, MLO
+1998, 04, 35900, 1998.2877, 368.50, 365.91, 368.49, 365.88, 368.50, 365.91, MLO
+1998, 05, 35930, 1998.3699, 369.19, 366.00, 369.33, 366.14, 369.19, 366.00, MLO
+1998, 06, 35961, 1998.4548, 368.77, 366.35, 368.80, 366.40, 368.77, 366.35, MLO
+1998, 07, 35991, 1998.5370, 367.53, 366.78, 367.37, 366.65, 367.53, 366.78, MLO
+1998, 08, 36022, 1998.6219, 365.67, 367.13, 365.39, 366.88, 365.67, 367.13, MLO
+1998, 09, 36053, 1998.7068, 363.80, 367.08, 363.81, 367.10, 363.80, 367.08, MLO
+1998, 10, 36083, 1998.7890, 364.13, 367.52, 363.92, 367.29, 364.13, 367.52, MLO
+1998, 11, 36114, 1998.8740, 365.36, 367.48, 365.37, 367.47, 365.36, 367.48, MLO
+1998, 12, 36144, 1998.9562, 366.87, 367.73, 366.77, 367.62, 366.87, 367.73, MLO
+1999, 01, 36175, 1999.0411, 368.05, 367.99, 367.83, 367.75, 368.05, 367.99, MLO
+1999, 02, 36206, 1999.1260, 368.77, 368.05, 368.61, 367.87, 368.77, 368.05, MLO
+1999, 03, 36234, 1999.2027, 369.49, 368.05, 369.41, 367.95, 369.49, 368.05, MLO
+1999, 04, 36265, 1999.2877, 371.04, 368.44, 370.66, 368.04, 371.04, 368.44, MLO
+1999, 05, 36295, 1999.3699, 370.90, 367.71, 371.30, 368.11, 370.90, 367.71, MLO
+1999, 06, 36326, 1999.4548, 370.25, 367.83, 370.58, 368.18, 370.25, 367.83, MLO
+1999, 07, 36356, 1999.5370, 369.17, 368.41, 368.97, 368.24, 369.17, 368.41, MLO
+1999, 08, 36387, 1999.6219, 366.83, 368.29, 366.82, 368.32, 366.83, 368.29, MLO
+1999, 09, 36418, 1999.7068, 364.54, 367.83, 365.09, 368.39, 364.54, 367.83, MLO
+1999, 10, 36448, 1999.7890, 365.04, 368.44, 365.09, 368.47, 365.04, 368.44, MLO
+1999, 11, 36479, 1999.8740, 366.58, 368.71, 366.45, 368.55, 366.58, 368.71, MLO
+1999, 12, 36509, 1999.9562, 367.92, 368.78, 367.79, 368.64, 367.92, 368.78, MLO
+2000, 01, 36540, 2000.0410, 369.05, 368.99, 368.81, 368.73, 369.05, 368.99, MLO
+2000, 02, 36571, 2000.1257, 369.37, 368.64, 369.57, 368.83, 369.37, 368.64, MLO
+2000, 03, 36600, 2000.2049, 370.42, 368.95, 370.41, 368.93, 370.42, 368.95, MLO
+2000, 04, 36631, 2000.2896, 371.57, 368.93, 371.69, 369.03, 371.57, 368.93, MLO
+2000, 05, 36661, 2000.3716, 371.74, 368.53, 372.35, 369.15, 371.74, 368.53, MLO
+2000, 06, 36692, 2000.4563, 371.60, 369.19, 371.67, 369.28, 371.60, 369.19, MLO
+2000, 07, 36722, 2000.5383, 370.02, 369.30, 370.11, 369.42, 370.02, 369.30, MLO
+2000, 08, 36753, 2000.6230, 368.03, 369.52, 368.03, 369.56, 368.03, 369.52, MLO
+2000, 09, 36784, 2000.7077, 366.53, 369.84, 366.38, 369.71, 366.53, 369.84, MLO
+2000, 10, 36814, 2000.7896, 366.64, 370.04, 366.46, 369.85, 366.64, 370.04, MLO
+2000, 11, 36845, 2000.8743, 368.20, 370.33, 367.88, 369.99, 368.20, 370.33, MLO
+2000, 12, 36875, 2000.9563, 369.44, 370.31, 369.27, 370.12, 369.44, 370.31, MLO
+2001, 01, 36906, 2001.0411, 370.20, 370.13, 370.32, 370.25, 370.20, 370.13, MLO
+2001, 02, 36937, 2001.1260, 371.42, 370.68, 371.11, 370.37, 371.42, 370.68, MLO
+2001, 03, 36965, 2001.2027, 372.04, 370.59, 371.94, 370.48, 372.04, 370.59, MLO
+2001, 04, 36996, 2001.2877, 372.78, 370.16, 373.23, 370.60, 372.78, 370.16, MLO
+2001, 05, 37026, 2001.3699, 373.94, 370.72, 373.93, 370.72, 373.94, 370.72, MLO
+2001, 06, 37057, 2001.4548, 373.23, 370.79, 373.27, 370.85, 373.23, 370.79, MLO
+2001, 07, 37087, 2001.5370, 371.54, 370.78, 371.71, 370.98, 371.54, 370.78, MLO
+2001, 08, 37118, 2001.6219, 369.47, 370.94, 369.62, 371.13, 369.47, 370.94, MLO
+2001, 09, 37149, 2001.7068, 367.88, 371.19, 367.96, 371.28, 367.88, 371.19, MLO
+2001, 10, 37179, 2001.7890, 368.01, 371.43, 368.03, 371.43, 368.01, 371.43, MLO
+2001, 11, 37210, 2001.8740, 369.60, 371.74, 369.48, 371.60, 369.60, 371.74, MLO
+2001, 12, 37240, 2001.9562, 371.16, 372.03, 370.91, 371.76, 371.16, 372.03, MLO
+2002, 01, 37271, 2002.0411, 372.36, 372.29, 372.01, 371.93, 372.36, 372.29, MLO
+2002, 02, 37302, 2002.1260, 373.00, 372.27, 372.85, 372.10, 373.00, 372.27, MLO
+2002, 03, 37330, 2002.2027, 373.44, 371.99, 373.73, 372.27, 373.44, 371.99, MLO
+2002, 04, 37361, 2002.2877, 374.77, 372.15, 375.09, 372.45, 374.77, 372.15, MLO
+2002, 05, 37391, 2002.3699, 375.48, 372.26, 375.87, 372.65, 375.48, 372.26, MLO
+2002, 06, 37422, 2002.4548, 375.33, 372.89, 375.28, 372.86, 375.33, 372.89, MLO
+2002, 07, 37452, 2002.5370, 373.95, 373.19, 373.80, 373.07, 373.95, 373.19, MLO
+2002, 08, 37483, 2002.6219, 371.41, 372.88, 371.79, 373.30, 371.41, 372.88, MLO
+2002, 09, 37514, 2002.7068, 370.63, 373.94, 370.20, 373.53, 370.63, 373.94, MLO
+2002, 10, 37544, 2002.7890, 370.18, 373.60, 370.35, 373.76, 370.18, 373.60, MLO
+2002, 11, 37575, 2002.8740, 372.01, 374.16, 371.87, 373.99, 372.01, 374.16, MLO
+2002, 12, 37605, 2002.9562, 373.71, 374.58, 373.36, 374.22, 373.71, 374.58, MLO
+2003, 01, 37636, 2003.0411, 374.61, 374.55, 374.52, 374.44, 374.61, 374.55, MLO
+2003, 02, 37667, 2003.1260, 375.55, 374.81, 375.41, 374.66, 375.55, 374.81, MLO
+2003, 03, 37695, 2003.2027, 376.04, 374.58, 376.33, 374.86, 376.04, 374.58, MLO
+2003, 04, 37726, 2003.2877, 377.58, 374.95, 377.72, 375.07, 377.58, 374.95, MLO
+2003, 05, 37756, 2003.3699, 378.28, 375.05, 378.50, 375.27, 378.28, 375.05, MLO
+2003, 06, 37787, 2003.4548, 378.07, 375.62, 377.91, 375.48, 378.07, 375.62, MLO
+2003, 07, 37817, 2003.5370, 376.54, 375.78, 376.40, 375.67, 376.54, 375.78, MLO
+2003, 08, 37848, 2003.6219, 374.42, 375.89, 374.35, 375.86, 374.42, 375.89, MLO
+2003, 09, 37879, 2003.7068, 372.92, 376.24, 372.70, 376.04, 372.92, 376.24, MLO
+2003, 10, 37909, 2003.7890, 372.94, 376.38, 372.78, 376.21, 372.94, 376.38, MLO
+2003, 11, 37940, 2003.8740, 374.29, 376.44, 374.24, 376.37, 374.29, 376.44, MLO
+2003, 12, 37970, 2003.9562, 375.63, 376.50, 375.65, 376.51, 375.63, 376.50, MLO
+2004, 01, 38001, 2004.0410, 376.73, 376.66, 376.73, 376.65, 376.73, 376.66, MLO
+2004, 02, 38032, 2004.1257, 377.31, 376.57, 377.53, 376.79, 377.31, 376.57, MLO
+2004, 03, 38061, 2004.2049, 378.33, 376.85, 378.41, 376.91, 378.33, 376.85, MLO
+2004, 04, 38092, 2004.2896, 380.44, 377.77, 379.71, 377.03, 380.44, 377.77, MLO
+2004, 05, 38122, 2004.3716, 380.56, 377.31, 380.38, 377.14, 380.56, 377.31, MLO
+2004, 06, 38153, 2004.4563, 379.49, 377.06, 379.67, 377.26, 379.49, 377.06, MLO
+2004, 07, 38183, 2004.5383, 377.70, 376.97, 378.08, 377.38, 377.70, 376.97, MLO
+2004, 08, 38214, 2004.6230, 375.77, 377.28, 375.97, 377.52, 375.77, 377.28, MLO
+2004, 09, 38245, 2004.7077, 373.99, 377.34, 374.31, 377.67, 373.99, 377.34, MLO
+2004, 10, 38275, 2004.7896, 374.17, 377.61, 374.41, 377.83, 374.17, 377.61, MLO
+2004, 11, 38306, 2004.8743, 375.79, 377.95, 375.88, 378.01, 375.79, 377.95, MLO
+2004, 12, 38336, 2004.9563, 377.39, 378.27, 377.34, 378.20, 377.39, 378.27, MLO
+2005, 01, 38367, 2005.0411, 378.29, 378.22, 378.49, 378.41, 378.29, 378.22, MLO
+2005, 02, 38398, 2005.1260, 379.56, 378.82, 379.37, 378.62, 379.56, 378.82, MLO
+2005, 03, 38426, 2005.2027, 380.07, 378.60, 380.30, 378.82, 380.07, 378.60, MLO
+2005, 04, 38457, 2005.2877, 382.01, 379.37, 381.71, 379.04, 382.01, 379.37, MLO
+2005, 05, 38487, 2005.3699, 382.21, 378.96, 382.51, 379.26, 382.21, 378.96, MLO
+2005, 06, 38518, 2005.4548, 382.05, 379.58, 381.93, 379.48, 382.05, 379.58, MLO
+2005, 07, 38548, 2005.5370, 380.63, 379.86, 380.43, 379.69, 380.63, 379.86, MLO
+2005, 08, 38579, 2005.6219, 378.64, 380.12, 378.39, 379.91, 378.64, 380.12, MLO
+2005, 09, 38610, 2005.7068, 376.38, 379.73, 376.76, 380.12, 376.38, 379.73, MLO
+2005, 10, 38640, 2005.7890, 376.77, 380.22, 376.87, 380.32, 376.77, 380.22, MLO
+2005, 11, 38671, 2005.8740, 378.27, 380.44, 378.37, 380.51, 378.27, 380.44, MLO
+2005, 12, 38701, 2005.9562, 379.93, 380.81, 379.84, 380.70, 379.93, 380.81, MLO
+2006, 01, 38732, 2006.0411, 381.33, 381.27, 380.96, 380.88, 381.33, 381.27, MLO
+2006, 02, 38763, 2006.1260, 381.98, 381.24, 381.81, 381.06, 381.98, 381.24, MLO
+2006, 03, 38791, 2006.2027, 382.53, 381.06, 382.69, 381.21, 382.53, 381.06, MLO
+2006, 04, 38822, 2006.2877, 384.33, 381.68, 384.03, 381.36, 384.33, 381.68, MLO
+2006, 05, 38852, 2006.3699, 384.89, 381.63, 384.77, 381.51, 384.89, 381.63, MLO
+2006, 06, 38883, 2006.4548, 384.00, 381.52, 384.11, 381.66, 384.00, 381.52, MLO
+2006, 07, 38913, 2006.5370, 382.25, 381.48, 382.53, 381.80, 382.25, 381.48, MLO
+2006, 08, 38944, 2006.6219, 380.44, 381.93, 380.42, 381.95, 380.44, 381.93, MLO
+2006, 09, 38975, 2006.7068, 378.77, 382.12, 378.72, 382.09, 378.77, 382.12, MLO
+2006, 10, 39005, 2006.7890, 379.03, 382.49, 378.79, 382.24, 379.03, 382.49, MLO
+2006, 11, 39036, 2006.8740, 380.11, 382.28, 380.24, 382.39, 380.11, 382.28, MLO
+2006, 12, 39066, 2006.9562, 381.63, 382.51, 381.67, 382.54, 381.63, 382.51, MLO
+2007, 01, 39097, 2007.0411, 382.55, 382.48, 382.77, 382.69, 382.55, 382.48, MLO
+2007, 02, 39128, 2007.1260, 383.68, 382.94, 383.60, 382.84, 383.68, 382.94, MLO
+2007, 03, 39156, 2007.2027, 384.31, 382.83, 384.48, 382.99, 384.31, 382.83, MLO
+2007, 04, 39187, 2007.2877, 386.19, 383.54, 385.83, 383.15, 386.19, 383.54, MLO
+2007, 05, 39217, 2007.3699, 386.38, 383.11, 386.57, 383.30, 386.38, 383.11, MLO
+2007, 06, 39248, 2007.4548, 385.85, 383.36, 385.92, 383.46, 385.85, 383.36, MLO
+2007, 07, 39278, 2007.5370, 384.42, 383.64, 384.36, 383.62, 384.42, 383.64, MLO
+2007, 08, 39309, 2007.6219, 381.81, 383.31, 382.26, 383.79, 381.81, 383.31, MLO
+2007, 09, 39340, 2007.7068, 380.83, 384.19, 380.57, 383.95, 380.83, 384.19, MLO
+2007, 10, 39370, 2007.7890, 380.83, 384.31, 380.65, 384.11, 380.83, 384.31, MLO
+2007, 11, 39401, 2007.8740, 382.32, 384.50, 382.11, 384.26, 382.32, 384.50, MLO
+2007, 12, 39431, 2007.9562, 383.58, 384.47, 383.54, 384.41, 383.58, 384.47, MLO
+2008, 01, 39462, 2008.0410, 385.04, 384.97, 384.64, 384.56, 385.04, 384.97, MLO
+2008, 02, 39493, 2008.1257, 385.81, 385.06, 385.46, 384.70, 385.81, 385.06, MLO
+2008, 03, 39522, 2008.2049, 385.80, 384.30, 386.36, 384.84, 385.80, 384.30, MLO
+2008, 04, 39553, 2008.2896, 386.74, 384.04, 387.71, 385.00, 386.74, 384.04, MLO
+2008, 05, 39583, 2008.3716, 388.48, 385.21, 388.43, 385.15, 388.48, 385.21, MLO
+2008, 06, 39614, 2008.4563, 388.02, 385.56, 387.76, 385.32, 388.02, 385.56, MLO
+2008, 07, 39644, 2008.5383, 386.22, 385.48, 386.20, 385.49, 386.22, 385.48, MLO
+2008, 08, 39675, 2008.6230, 384.05, 385.58, 384.09, 385.66, 384.05, 385.58, MLO
+2008, 09, 39706, 2008.7077, 383.05, 386.43, 382.42, 385.82, 383.05, 386.43, MLO
+2008, 10, 39736, 2008.7896, 382.75, 386.23, 382.51, 385.98, 382.75, 386.23, MLO
+2008, 11, 39767, 2008.8743, 383.98, 386.16, 383.98, 386.14, 383.98, 386.16, MLO
+2008, 12, 39797, 2008.9563, 385.08, 385.97, 385.42, 386.29, 385.08, 385.97, MLO
+2009, 01, 39828, 2009.0411, 386.63, 386.56, 386.52, 386.45, 386.63, 386.56, MLO
+2009, 02, 39859, 2009.1260, 387.10, 386.35, 387.37, 386.61, 387.10, 386.35, MLO
+2009, 03, 39887, 2009.2027, 388.50, 387.02, 388.25, 386.75, 388.50, 387.02, MLO
+2009, 04, 39918, 2009.2877, 389.54, 386.87, 389.61, 386.92, 389.54, 386.87, MLO
+2009, 05, 39948, 2009.3699, 390.15, 386.86, 390.38, 387.09, 390.15, 386.86, MLO
+2009, 06, 39979, 2009.4548, 389.60, 387.11, 389.75, 387.27, 389.60, 387.11, MLO
+2009, 07, 40009, 2009.5370, 388.05, 387.27, 388.20, 387.46, 388.05, 387.27, MLO
+2009, 08, 40040, 2009.6219, 386.06, 387.56, 386.12, 387.66, 386.06, 387.56, MLO
+2009, 09, 40071, 2009.7068, 384.64, 388.02, 384.48, 387.88, 384.64, 388.02, MLO
+2009, 10, 40101, 2009.7890, 384.32, 387.82, 384.61, 388.09, 384.32, 387.82, MLO
+2009, 11, 40132, 2009.8740, 386.05, 388.24, 386.15, 388.31, 386.05, 388.24, MLO
+2009, 12, 40162, 2009.9562, 387.48, 388.38, 387.66, 388.54, 387.48, 388.38, MLO
+2010, 01, 40193, 2010.0411, 388.55, 388.49, 388.85, 388.77, 388.55, 388.49, MLO
+2010, 02, 40224, 2010.1260, 390.08, 389.33, 389.76, 388.99, 390.08, 389.33, MLO
+2010, 03, 40252, 2010.2027, 391.02, 389.54, 390.69, 389.19, 391.02, 389.54, MLO
+2010, 04, 40283, 2010.2877, 392.39, 389.70, 392.10, 389.40, 392.39, 389.70, MLO
+2010, 05, 40313, 2010.3699, 393.24, 389.94, 392.89, 389.60, 393.24, 389.94, MLO
+2010, 06, 40344, 2010.4548, 392.26, 389.75, 392.26, 389.78, 392.26, 389.75, MLO
+2010, 07, 40374, 2010.5370, 390.35, 389.57, 390.70, 389.96, 390.35, 389.57, MLO
+2010, 08, 40405, 2010.6219, 388.53, 390.03, 388.59, 390.13, 388.53, 390.03, MLO
+2010, 09, 40436, 2010.7068, 386.85, 390.24, 386.89, 390.30, 386.85, 390.24, MLO
+2010, 10, 40466, 2010.7890, 387.18, 390.69, 386.96, 390.45, 387.18, 390.69, MLO
+2010, 11, 40497, 2010.8740, 388.69, 390.89, 388.43, 390.61, 388.69, 390.89, MLO
+2010, 12, 40527, 2010.9562, 389.83, 390.73, 389.87, 390.74, 389.83, 390.73, MLO
+2011, 01, 40558, 2011.0411, 391.33, 391.26, 390.96, 390.88, 391.33, 391.26, MLO
+2011, 02, 40589, 2011.1260, 391.96, 391.21, 391.78, 391.01, 391.96, 391.21, MLO
+2011, 03, 40617, 2011.2027, 392.49, 391.00, 392.64, 391.13, 392.49, 391.00, MLO
+2011, 04, 40648, 2011.2877, 393.40, 390.71, 393.98, 391.27, 393.40, 390.71, MLO
+2011, 05, 40678, 2011.3699, 394.33, 391.02, 394.72, 391.42, 394.33, 391.02, MLO
+2011, 06, 40709, 2011.4548, 393.75, 391.24, 394.07, 391.58, 393.75, 391.24, MLO
+2011, 07, 40739, 2011.5370, 392.64, 391.86, 392.49, 391.74, 392.64, 391.86, MLO
+2011, 08, 40770, 2011.6219, 390.25, 391.75, 390.38, 391.92, 390.25, 391.75, MLO
+2011, 09, 40801, 2011.7068, 389.05, 392.45, 388.69, 392.10, 389.05, 392.45, MLO
+2011, 10, 40831, 2011.7890, 388.98, 392.50, 388.78, 392.28, 388.98, 392.50, MLO
+2011, 11, 40862, 2011.8740, 390.30, 392.50, 390.29, 392.47, 390.30, 392.50, MLO
+2011, 12, 40892, 2011.9562, 391.86, 392.76, 391.77, 392.65, 391.86, 392.76, MLO
+2012, 01, 40923, 2012.0410, 393.13, 393.07, 392.92, 392.84, 393.13, 393.07, MLO
+2012, 02, 40954, 2012.1257, 393.42, 392.66, 393.80, 393.03, 393.42, 392.66, MLO
+2012, 03, 40983, 2012.2049, 394.43, 392.91, 394.75, 393.22, 394.43, 392.91, MLO
+2012, 04, 41014, 2012.2896, 396.51, 393.78, 396.16, 393.42, 396.51, 393.78, MLO
+2012, 05, 41044, 2012.3716, 396.96, 393.64, 396.94, 393.62, 396.96, 393.64, MLO
+2012, 06, 41075, 2012.4563, 395.97, 393.48, 396.31, 393.84, 395.97, 393.48, MLO
+2012, 07, 41105, 2012.5383, 394.60, 393.85, 394.78, 394.06, 394.60, 393.85, MLO
+2012, 08, 41136, 2012.6230, 392.61, 394.15, 392.72, 394.30, 392.61, 394.15, MLO
+2012, 09, 41167, 2012.7077, 391.20, 394.62, 391.10, 394.54, 391.20, 394.62, MLO
+2012, 10, 41197, 2012.7896, 391.09, 394.61, 391.27, 394.78, 391.09, 394.61, MLO
+2012, 11, 41228, 2012.8743, 393.03, 395.23, 392.84, 395.02, 393.03, 395.23, MLO
+2012, 12, 41258, 2012.9563, 394.42, 395.31, 394.37, 395.25, 394.42, 395.31, MLO
+2013, 01, 41289, 2013.0411, 395.69, 395.63, 395.57, 395.49, 395.69, 395.63, MLO
+2013, 02, 41320, 2013.1260, 396.94, 396.18, 396.49, 395.72, 396.94, 396.18, MLO
+2013, 03, 41348, 2013.2027, 397.35, 395.86, 397.43, 395.92, 397.35, 395.86, MLO
+2013, 04, 41379, 2013.2877, 398.44, 395.74, 398.85, 396.13, 398.44, 395.74, MLO
+2013, 05, 41409, 2013.3699, 400.06, 396.74, 399.66, 396.33, 400.06, 396.74, MLO
+2013, 06, 41440, 2013.4548, 398.96, 396.43, 399.03, 396.53, 398.96, 396.43, MLO
+2013, 07, 41470, 2013.5370, 397.45, 396.67, 397.48, 396.72, 397.45, 396.67, MLO
+2013, 08, 41501, 2013.6219, 395.49, 397.00, 395.36, 396.92, 395.49, 397.00, MLO
+2013, 09, 41532, 2013.7068, 393.47, 396.89, 393.67, 397.11, 393.47, 396.89, MLO
+2013, 10, 41562, 2013.7890, 393.77, 397.31, 393.77, 397.28, 393.77, 397.31, MLO
+2013, 11, 41593, 2013.8740, 395.27, 397.49, 395.28, 397.47, 395.27, 397.49, MLO
+2013, 12, 41623, 2013.9562, 396.90, 397.80, 396.75, 397.64, 396.90, 397.80, MLO
+2014, 01, 41654, 2014.0411, 398.01, 397.94, 397.89, 397.81, 398.01, 397.94, MLO
+2014, 02, 41685, 2014.1260, 398.18, 397.42, 398.76, 397.98, 398.18, 397.42, MLO
+2014, 03, 41713, 2014.2027, 399.56, 398.06, 399.65, 398.14, 399.56, 398.06, MLO
+2014, 04, 41744, 2014.2877, 401.43, 398.72, 401.04, 398.31, 401.43, 398.72, MLO
+2014, 05, 41774, 2014.3699, 401.98, 398.65, 401.80, 398.46, 401.98, 398.65, MLO
+2014, 06, 41805, 2014.4548, 401.41, 398.88, 401.13, 398.62, 401.41, 398.88, MLO
+2014, 07, 41835, 2014.5370, 399.17, 398.38, 399.53, 398.78, 399.17, 398.38, MLO
+2014, 08, 41866, 2014.6219, 397.30, 398.82, 397.38, 398.94, 397.30, 398.82, MLO
+2014, 09, 41897, 2014.7068, 395.49, 398.91, 395.65, 399.10, 395.49, 398.91, MLO
+2014, 10, 41927, 2014.7890, 395.74, 399.28, 395.73, 399.26, 395.74, 399.28, MLO
+2014, 11, 41958, 2014.8740, 397.32, 399.54, 397.23, 399.43, 397.32, 399.54, MLO
+2014, 12, 41988, 2014.9562, 398.88, 399.79, 398.71, 399.59, 398.88, 399.79, MLO
+2015, 01, 42019, 2015.0411, 399.95, 399.88, 399.85, 399.77, 399.95, 399.88, MLO
+2015, 02, 42050, 2015.1260, 400.40, 399.63, 400.72, 399.94, 400.40, 399.63, MLO
+2015, 03, 42078, 2015.2027, 401.60, 400.09, 401.63, 400.11, 401.60, 400.09, MLO
+2015, 04, 42109, 2015.2877, 403.52, 400.81, 403.04, 400.31, 403.52, 400.81, MLO
+2015, 05, 42139, 2015.3699, 404.04, 400.69, 403.85, 400.50, 404.04, 400.69, MLO
+2015, 06, 42170, 2015.4548, 402.81, 400.27, 403.24, 400.72, 402.81, 400.27, MLO
+2015, 07, 42200, 2015.5370, 401.54, 400.75, 401.71, 400.95, 401.54, 400.75, MLO
+2015, 08, 42231, 2015.6219, 398.93, 400.45, 399.65, 401.22, 398.93, 400.45, MLO
+2015, 09, 42262, 2015.7068, 397.43, 400.87, 398.05, 401.50, 397.43, 400.87, MLO
+2015, 10, 42292, 2015.7890, 398.22, 401.77, 398.26, 401.80, 398.22, 401.77, MLO
+2015, 11, 42323, 2015.8740, 400.17, 402.40, 399.91, 402.11, 400.17, 402.40, MLO
+2015, 12, 42353, 2015.9562, 401.82, 402.73, 401.53, 402.42, 401.82, 402.73, MLO
+2016, 01, 42384, 2016.0410, 402.58, 402.51, 402.82, 402.74, 402.58, 402.51, MLO
+2016, 02, 42415, 2016.1257, 404.09, 403.33, 403.82, 403.05, 404.09, 403.33, MLO
+2016, 03, 42444, 2016.2049, 404.79, 403.25, 404.88, 403.32, 404.79, 403.25, MLO
+2016, 04, 42475, 2016.2896, 407.50, 404.74, 406.38, 403.60, 407.50, 404.74, MLO
+2016, 05, 42505, 2016.3716, 407.59, 404.24, 407.20, 403.85, 407.59, 404.24, MLO
+2016, 06, 42536, 2016.4563, 406.94, 404.42, 406.59, 404.09, 406.94, 404.42, MLO
+2016, 07, 42566, 2016.5383, 404.43, 403.67, 405.04, 404.32, 404.43, 403.67, MLO
+2016, 08, 42597, 2016.6230, 402.17, 403.72, 402.94, 404.54, 402.17, 403.72, MLO
+2016, 09, 42628, 2016.7077, 400.95, 404.40, 401.28, 404.76, 400.95, 404.40, MLO
+2016, 10, 42658, 2016.7896, 401.43, 404.99, 401.43, 404.97, 401.43, 404.99, MLO
+2016, 11, 42689, 2016.8743, 403.57, 405.80, 402.98, 405.18, 403.57, 405.80, MLO
+2016, 12, 42719, 2016.9563, 404.48, 405.39, 404.49, 405.37, 404.48, 405.39, MLO
+2017, 01, 42750, 2017.0411, 406.00, 405.94, 405.65, 405.57, 406.00, 405.94, MLO
+2017, 02, 42781, 2017.1260, 406.57, 405.81, 406.53, 405.75, 406.57, 405.81, MLO
+2017, 03, 42809, 2017.2027, 406.99, 405.47, 407.44, 405.91, 406.99, 405.47, MLO
+2017, 04, 42840, 2017.2877, 408.88, 406.14, 408.83, 406.08, 408.88, 406.14, MLO
+2017, 05, 42870, 2017.3699, 409.84, 406.48, 409.60, 406.24, 409.84, 406.48, MLO
+2017, 06, 42901, 2017.4548, 409.05, 406.50, 408.93, 406.40, 409.05, 406.50, MLO
+2017, 07, 42931, 2017.5370, 407.13, 406.34, 407.31, 406.55, 407.13, 406.34, MLO
+2017, 08, 42962, 2017.6219, 405.17, 406.70, 405.13, 406.71, 405.17, 406.70, MLO
+2017, 09, 42993, 2017.7068, 403.20, 406.66, 403.39, 406.86, 403.20, 406.66, MLO
+2017, 10, 43023, 2017.7890, 403.57, 407.14, 403.46, 407.01, 403.57, 407.14, MLO
+2017, 11, 43054, 2017.8740, 405.10, 407.34, 404.96, 407.17, 405.10, 407.34, MLO
+2017, 12, 43084, 2017.9562, 406.68, 407.59, 406.43, 407.32, 406.68, 407.59, MLO
+2018, 01, 43115, 2018.0411, 407.98, 407.91, 407.56, 407.48, 407.98, 407.91, MLO
+2018, 02, 43146, 2018.1260, 408.36, 407.59, 408.41, 407.63, 408.36, 407.59, MLO
+2018, 03, 43174, 2018.2027, 409.21, 407.69, 409.32, 407.78, 409.21, 407.69, MLO
+2018, 04, 43205, 2018.2877, 410.23, 407.49, 410.73, 407.96, 410.23, 407.49, MLO
+2018, 05, 43235, 2018.3699, 411.23, 407.86, 411.53, 408.16, 411.23, 407.86, MLO
+2018, 06, 43266, 2018.4548, 410.82, 408.26, 410.91, 408.37, 410.82, 408.26, MLO
+2018, 07, 43296, 2018.5370, 408.83, 408.03, 409.36, 408.60, 408.83, 408.03, MLO
+2018, 08, 43327, 2018.6219, 407.02, 408.56, 407.28, 408.86, 407.02, 408.56, MLO
+2018, 09, 43358, 2018.7068, 405.53, 408.99, 405.64, 409.13, 405.53, 408.99, MLO
+2018, 10, 43388, 2018.7890, 405.93, 409.51, 405.82, 409.39, 405.93, 409.51, MLO
+2018, 11, 43419, 2018.8740, 408.04, 410.29, 407.44, 409.66, 408.04, 410.29, MLO
+2018, 12, 43449, 2018.9562, 409.17, 410.08, 409.03, 409.92, 409.17, 410.08, MLO
+2019, 01, 43480, 2019.0411, 410.85, 410.78, 410.26, 410.18, 410.85, 410.78, MLO
+2019, 02, 43511, 2019.1260, 411.59, 410.82, 411.21, 410.43, 411.59, 410.82, MLO
+2019, 03, 43539, 2019.2027, 411.91, 410.39, 412.18, 410.64, 411.91, 410.39, MLO
+2019, 04, 43570, 2019.2877, 413.46, 410.71, 413.63, 410.87, 413.46, 410.71, MLO
+2019, 05, 43600, 2019.3699, 414.76, 411.38, 414.46, 411.08, 414.76, 411.38, MLO
+2019, 06, 43631, 2019.4548, 413.89, 411.32, 413.85, 411.30, 413.89, 411.32, MLO
+2019, 07, 43661, 2019.5370, 411.78, 410.98, 412.28, 411.52, 411.78, 410.98, MLO
+2019, 08, 43692, 2019.6219, 410.01, 411.55, 410.16, 411.74, 410.01, 411.55, MLO
+2019, 09, 43723, 2019.7068, 408.48, 411.95, 408.47, 411.96, 408.48, 411.95, MLO
+2019, 10, 43753, 2019.7890, 408.40, 411.99, 408.60, 412.18, 408.40, 411.99, MLO
+2019, 11, 43784, 2019.8740, 410.16, 412.41, 410.18, 412.40, 410.16, 412.41, MLO
+2019, 12, 43814, 2019.9562, 411.81, 412.73, 411.72, 412.61, 411.81, 412.73, MLO
+2020, 01, 43845, 2020.0410, 413.30, 413.24, 412.91, 412.83, 413.30, 413.24, MLO
+2020, 02, 43876, 2020.1257, 414.05, 413.28, 413.82, 413.04, 414.05, 413.28, MLO
+2020, 03, 43905, 2020.2049, 414.45, 412.90, 414.80, 413.23, 414.45, 412.90, MLO
+2020, 04, 43936, 2020.2896, 416.11, 413.32, 416.24, 413.44, 416.11, 413.32, MLO
+2020, 05, 43966, 2020.3716, 417.15, 413.76, 417.02, 413.63, 417.15, 413.76, MLO
+2020, 06, 43997, 2020.4563, 416.29, 413.74, 416.36, 413.84, 416.29, 413.74, MLO
+2020, 07, 44027, 2020.5383, 414.42, 413.65, 414.76, 414.03, 414.42, 413.65, MLO
+2020, 08, 44058, 2020.6230, 412.52, 414.09, 412.62, 414.23, 412.52, 414.09, MLO
+2020, 09, 44089, 2020.7077, 411.18, 414.68, 410.92, 414.43, 411.18, 414.68, MLO
+2020, 10, 44119, 2020.7896, 411.12, 414.72, 411.04, 414.62, 411.12, 414.72, MLO
+2020, 11, 44150, 2020.8743, 412.88, 415.14, 412.58, 414.81, 412.88, 415.14, MLO
+2020, 12, 44180, 2020.9563, 413.89, 414.80, 414.09, 414.98, 413.89, 414.80, MLO
+2021, 01, 44211, 2021.0411, 415.15, 415.08, 415.24, 415.16, 415.15, 415.08, MLO
+2021, 02, 44242, 2021.1260, 416.48, 415.70, 416.12, 415.34, 416.48, 415.70, MLO
+2021, 03, 44270, 2021.2027, 417.16, 415.63, 417.04, 415.49, 417.16, 415.63, MLO
+2021, 04, 44301, 2021.2877, 418.24, 415.47, 418.44, 415.66, 418.24, 415.47, MLO
+2021, 05, 44331, 2021.3699, 418.95, 415.55, 419.23, 415.83, 418.95, 415.55, MLO
+2021, 06, 44362, 2021.4548, 418.70, 416.12, 418.56, 416.00, 418.70, 416.12, MLO
+2021, 07, 44392, 2021.5370, 416.65, 415.85, 416.95, 416.18, 416.65, 415.85, MLO
+2021, 08, 44423, 2021.6219, 414.34, 415.89, 414.78, 416.36, 414.34, 415.89, MLO
+2021, 09, 44454, 2021.7068, 412.90, 416.40, 413.04, 416.55, 412.90, 416.40, MLO
+2021, 10, 44484, 2021.7890, 413.55, 417.16, 413.14, 416.74, 413.55, 417.16, MLO
+2021, 11, 44515, 2021.8740, 414.82, 417.08, 414.69, 416.92, 414.82, 417.08, MLO
+2021, 12, 44545, 2021.9562, 416.43, 417.36, 416.19, 417.10, 416.43, 417.36, MLO
+2022, 01, 44576, 2022.0411, 418.01, 417.94, 417.34, 417.26, 418.01, 417.94, MLO
+2022, 02, 44607, 2022.1260, 418.99, 418.21, 418.21, 417.42, 418.99, 418.21, MLO
+2022, 03, 44635, 2022.2027, 418.45, 416.92, 419.11, 417.56, 418.45, 416.92, MLO
+2022, 04, 44666, 2022.2877, 420.02, 417.25, 420.50, 417.71, 420.02, 417.25, MLO
+2022, 05, 44696, 2022.3699, 420.77, 417.36, 421.27, 417.86, 420.77, 417.36, MLO
+2022, 06, 44727, 2022.4548, 420.68, 418.09, 420.60, 418.03, 420.68, 418.09, MLO
+2022, 07, 44757, 2022.5370, 418.68, 417.87, 418.98, 418.21, 418.68, 417.87, MLO
+2022, 08, 44788, 2022.6219, 416.76, 418.31, 416.80, 418.40, 416.76, 418.31, MLO
+2022, 09, 44819, 2022.7068, 415.41, 418.91, 415.07, 418.59, 415.41, 418.91, MLO
+2022, 10, 44849, 2022.7890, 415.31, 418.93, 415.18, 418.78, 415.31, 418.93, MLO
+2022, 11, 44880, 2022.8740, 417.04, 419.31, 416.74, 418.98, 417.04, 419.31, MLO
+2022, 12, 44910, 2022.9562, 418.57, 419.49, 418.27, 419.18, 418.57, 419.49, MKO
+2023, 01, 44941, 2023.0411, 419.24, 419.17, 419.46, 419.38, 419.24, 419.17, MKO
+2023, 02, 44972, 2023.1260, 420.33, 419.55, 420.38, 419.59, 420.33, 419.55, MKO
+2023, 03, 45000, 2023.2027, 420.51, 418.97, 421.34, 419.79, 420.51, 418.97, MLO
+2023, 04, 45031, 2023.2877, 422.73, 419.95, 422.81, 420.01, 422.73, 419.95, MLO
+2023, 05, 45061, 2023.3699, 423.78, 420.36, 423.65, 420.23, 423.78, 420.36, MLO
+2023, 06, 45092, 2023.4548, 423.39, 420.80, 423.03, 420.46, 423.39, 420.80, MLO
+2023, 07, 45122, 2023.5370, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+2023, 08, 45153, 2023.6219, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+2023, 09, 45184, 2023.7068, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+2023, 10, 45214, 2023.7890, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+2023, 11, 45245, 2023.8740, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
+2023, 12, 45275, 2023.9562, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99, MLO
