diff --git a/DoE/DoE.Rmd b/DoE/DoE.Rmd deleted file mode 100644 index 09bdef2027caf6dfe38224d3ddd1f9ba25ee9898..0000000000000000000000000000000000000000 --- a/DoE/DoE.Rmd +++ /dev/null @@ -1,108 +0,0 @@ ---- -title: "Design of Experiments" -author: "El-hassane Nour" -date: "January 8, 2023" -output: - pdf_document: default - html_document: default ---- - -```{r setup, include=FALSE} -knitr::opts_chunk$set(echo = TRUE) -``` -# Note: - -Since I couldn't install DoE.wrapper, I run the experiments online using this website [DoE.wrapper](https://rdrr.io/cran/DoE.wrapper/) - -# Playing with the DoE Shiny Application -The model studied in this experiment is a black-blox, where x1, x2, ..., x11 are controlable factores, z1,...,z11 are uncontrolable factors and y is the output. -In order to approximate this unknown model, we need first to determine which variables are the most significant on the response y, using screening designs. - -Then, define and fit an analytical model of the response y as a function of the primary factors x using regression and lhs & optimal designs. - -## 1. First intuition -My first intuition was to run an lhs design using the 11 factors to have a general overview about the response behavior. -```{r} -library(DoE.wrapper) - set.seed(45); -design <- lhs.design(type= "maximin", nruns= 500 , nfactors= 11, digits=NULL, seed= 20523, factor.names=list(X1=c(0,1),X2=c(0,1),X3=c(0,1),X4=c(0,1),X5=c(0,1),X6=c(0,1),X7=c(0,1),X8=c(0,1),X9=c(0,1),X10=c(0,1),X11=c(0,1))) - -design.Dopt <- Dopt.design(30, data=design, nRepeat= 5, randomize= TRUE, seed=19573); design.Dopt -``` -Once data was generated, I tested it on the DoE shiny app and got a csv file containing the generated data with the corresponding response. -```{r} -df <- read.csv("exp.csv",header = TRUE, colClasses=c("NULL", NA, NA, NA, NA, NA, NA, NA,NA, NA, NA, NA, NA)); -df -``` -## 2. Designing experiments to run -### 2.1 Screening design using Plackett-Burman screening designs -Now, we're interested to see the factors effects in more in details. This will allow us to define the most efficient factor that influence the response. Since running a large number of such experiments is tedious, we gonna use the Plackett-Burman designs to see the different possible interactions. -```{r} -library(FrF2) -d<-pb(nruns= 12 ,n12.taguchi= FALSE ,nfactors= 12 -1, ncenter= 0 , replications= 1 ,repeat.only= FALSE ,randomize= TRUE ,seed= 26654 ,factor.names=list( X1=c(0,1),X2=c(0,1),X3=c(0,1),X4=c(0,1), -X5=c(0,1),X6=c(0,1),X7=c(0, 1),X8=c(0,1),X9=c(0,1),X10=c(0,1), -X11=c(0,1)));d -``` - -Here are the results (run on the website): - - X1 X2 X3 X4 X5 X6 X7 X8 X9 X10 X11 -1 1 0 1 1 0 1 1 1 0 0 0 -2 1 0 0 0 1 0 1 1 0 1 1 -3 0 0 1 0 1 1 0 1 1 1 0 -4 0 1 1 0 1 1 1 0 0 0 1 -5 0 1 0 1 1 0 1 1 1 0 0 -6 1 1 0 1 1 1 0 0 0 1 0 -7 1 1 1 0 0 0 1 0 1 1 0 -8 1 0 1 1 1 0 0 0 1 0 1 -9 0 0 0 0 0 0 0 0 0 0 0 -10 1 1 0 0 0 1 0 1 1 0 1 -11 0 0 0 1 0 1 1 0 1 1 1 -12 0 1 1 1 0 0 0 1 0 1 1 - -### 2.2. Regression and Analyse of Variance -In order to vizualise the correlation between factors and the response, we do a linear regression on the data generated by the application, and analyse the variance to see the effect. - -#### Experiment 1: X1, X3, X4, X6, X7, X8 taken into account -```{r} -y<-df$y -summary(lm(y~df$x1+df$x3+df$x4+df$x6+df$x7+df$x8,data=df)) -``` -Nothing interesting :/, even R^2 is too small wich is too bad. - -#### Experiment 2: X1, X5, X7, X8, X10, X11 taken into account -```{r} -y<-df$y -summary(lm(y~df$x1+df$x5+df$x7+df$x8+df$x10+df$x11,data=df)) -``` -Very small improvement in R^2, but still too bad. - -#### Experiment 3: X3, X5, X6, X8, X9, X10 taken into account -```{r} -y<-df$y -summary(lm(y~df$x3+df$x5+df$x6+df$x8+df$x9+df$x10,data=df)) -``` -It seems that X9 is a significant factor that influences the model, and the determination coefficient R^2 is 0.73 now, which is pretty good. - -#### Try the combination X3*X6: -```{r} -y<-df$y -summary(lm(y~df$x3+df$x9+df$x6+df$x3:df$x6,data=df)) -``` - -Not too much interesting. Let's try another experiment where X9 and X3 are set to 1. - -#### Experiment 8: X1, X3, X4, X5, X6, X9, X11 taken into account -```{r} -y<-df$y -summary(lm(y~df$x1+df$x3+df$x4+df$x5+df$x6+df$x9,data=df)) -``` - -Removing X11 doesn't have any effect. We decide to keep X9, X6, X4, combine X5 with X7, combine X1 with X3. - -```{r} -y<-df$y -summary(lm(y~df$x3:df$x1+df$x6+df$x5:df$x7+df$x4+df$x9,data=df)) -``` -We can say that our model is: -y= -2.72\*X9 + 0.72\*X4 + 0.42\*X6 + 0.99\*X1\*X3 -0.77\*X5\*X7 + 1.55 \ No newline at end of file
