NourElh
f943a2fe
f943a2fe
NourElh
Update exo5_en.Rmd
020c82b5
26 additions
+26
exo5_en.Rmd
module2/exo5/exo5_en.Rmd
+26
f943a2fe
@@ -30,14 +30,27 @@ data = read.csv("shuttle.csv",header=T)
### Comment:
There is no datapoint for low temperatures as the one used during launching => Lack of data.
# Graphical inspection
### New analysis:
However, I'd like to visualize the data of successful flights.
d = data[data$Malfunction==0,]
d
We can see that for high temperatures, there are failures, so excluding this data may prevent the detection of the origin of the failures.
### Continue
@@ -78,6 +91,14 @@ and the standard error of this estimator is 0.049, in other words we
### New analysis
library(ggplot2)
ggplot(d,aes(x=Temperature, y=Malfunction/Count))+geom_point(alpha=.3,size=3)+theme_bw()+geom_smooth(method = "glm",method.args=list(family="binomial"))+xlim(0,200)
From the graph, we see that there is a big uncertainty of this estimate, so the possibility that temperature has an effect cannot be ruled out.
# Estimation of the probability of O-ring malfunction
@@ -85,6 +106,8 @@ this temperature from the model we just built:
# shuttle=shuttle[shuttle$r!=0,]
logistic_reg = glm(data=data, Malfunction/Count ~ Temperature, weights=Count,
family=binomial(link='logit'))
tempv = seq(from=30, to=90, by = .5)
rmv <- predict(logistic_reg,list(Temperature=tempv),type="response")
plot(tempv,rmv,type="l",ylim=c(0,1))
@@ -117,3 +140,6 @@ of NASA, which have a lot to do with this fiasco, the previous analysis
### Comment:
Lack of low temperatures data + aggregating data + not considering the uncertainty of the estimate have led to this mistake.
