no commit message
parent da09b539
"cells": [],
"cells": [
"execution_count": 6,
"Mean: 14.11\n",
"Standard Deviation: 4.33\n",
"Minimum: 2.80\n",
"Median: 14.50\n",
"Maximum: 23.40\n"
"import numpy as np\n",
"data = np.array([\n",
" 14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0\n",
"])\n",
"mean = np.mean(data)\n",
"std_dev = np.std(data, ddof=1)\n",
"data_min = np.min(data)\n",
"median = np.median(data)\n",
"data_max = np.max(data)\n",
"print(f\"Mean: {mean:.2f}\")\n",
"print(f\"Standard Deviation: {std_dev:.2f}\")\n",
"print(f\"Minimum: {data_min:.2f}\")\n",
"print(f\"Median: {median:.2f}\")\n",
"print(f\"Maximum: {data_max:.2f}\")\n"
"execution_count": null,
"source": []
"kernelspec": {
"display_name": "Python 3",
......@@ -16,10 +62,9 @@
"name": "python",
"pygments_lexer": "ipython3",
"version": "3.6.3"
"version": "3.6.4"
"nbformat": 4,
"nbformat_minor": 2
