module 3 exo 3, début
parent dd93e4b7
"cells": [], "cells": [
"# Sujet 1: Concentration de CO2 dans l'atmosphère depuis 1952"
"execution_count": 39,
"%matplotlib inline\n",
"import pandas as pd\n",
"#import isomonth\n",
"import requests\n",
"import os\n",
"import urllib.request\n",
"data_file = \"weekly_in_situ_co2_mlo.csv\"\n",
"data_url = \"https://scrippsco2.ucsd.edu/assets/data/atmospheric/stations/in_situ_co2/weekly/weekly_in_situ_co2_mlo.csv\"\n",
"if not os.path.exists(data_file):\n",
" urllib.request.urlretrieve(data_url, data_file)"
"The raw data are rather a mess. The name are not good and are not several lines (with the unity). Hence, the data are stored in a dictionnary with proper keys. Moreover, the date with several format is in the raw data. Only the year and the month is stored. \n",
"Moreover, the data are string and then they are translated as float"
"execution_count": 65,
"text/html": [
"<div>\n",
"<style scoped>\n",
" vertical-align: middle;\n",
" }\n",
" vertical-align: top;\n",
" }\n",
" .dataframe thead th {\n",
" text-align: right;\n",
" }\n",
"</style>\n",
" <thead>\n",
" <th></th>\n",
" <th>CO2 seasonally</th>\n",
" <th>CO2 seasonally adjust</th>\n",
" <th>CO2 seasonally adjust filled</th>\n",
" <th>CO2 seasonally filled</th>\n",
" <th>Month</th>\n",
" <th>Year</th>\n",
" <th>seasonally adjusted fit</th>\n",
" <th>seasonally fit</th>\n",
" </tr>\n",
" </thead>\n",
" <tbody>\n",
" <tr>\n",
" <th>2</th>\n",
" <td>-99.99</td>\n",
" <td>1</td>\n",
" <td>1958</td>\n",
" </tr>\n",
" <tr>\n",
" <th>3</th>\n",
" <td>2</td>\n",
" <td>1958</td>\n",
" </tr>\n",
" <tr>\n",
" <th>4</th>\n",
" <td>315.70</td>\n",
" <td>314.43</td>\n",
" <td>3</td>\n",
" <td>1958</td>\n",
" <td>314.90</td>\n",
" <td>316.19</td>\n",
" </tr>\n",
" <tr>\n",
" <th>5</th>\n",
" <td>317.45</td>\n",
" <td>315.16</td>\n",
" <td>4</td>\n",
" <td>1958</td>\n",
" <td>314.98</td>\n",
" <td>317.30</td>\n",
" </tr>\n",
" <tr>\n",
" <th>6</th>\n",
" <td>317.51</td>\n",
" <td>314.71</td>\n",
" <td>5</td>\n",
" <td>1958</td>\n",
" <td>315.06</td>\n",
" <td>317.86</td>\n",
" </tr>\n",
" <tr>\n",
" <th>7</th>\n",
" <td>315.14</td>\n",
" <td>317.24</td>\n",
" <td>6</td>\n",
" <td>1958</td>\n",
" </tr>\n",
" <tr>\n",
" <th>8</th>\n",
" <td>315.86</td>\n",
" <td>315.19</td>\n",
" <td>7</td>\n",
" <td>1958</td>\n",
" <td>315.22</td>\n",
" </tr>\n",
" <tr>\n",
" <th>9</th>\n",
" <td>314.93</td>\n",
" <td>8</td>\n",
" <td>1958</td>\n",
" <td>315.29</td>\n",
" <td>313.99</td>\n",
" </tr>\n",
" <tr>\n",
" <th>10</th>\n",
" <td>313.21</td>\n",
" <td>316.09</td>\n",
" <td>9</td>\n",
" <td>1958</td>\n",
" <td>315.35</td>\n",
" <td>312.45</td>\n",
" </tr>\n",
" <tr>\n",
" <th>11</th>\n",
" <td>315.41</td>\n",
" <td>312.43</td>\n",
" <td>10</td>\n",
" <td>1958</td>\n",
" </tr>\n",
" <tr>\n",
" <th>12</th>\n",
" <td>313.33</td>\n",
" <td>315.20</td>\n",
" <td>11</td>\n",
" <td>1958</td>\n",
" <td>315.46</td>\n",
" <td>313.61</td>\n",
" </tr>\n",
" <tr>\n",
" <th>13</th>\n",
" <td>314.67</td>\n",
" <td>315.43</td>\n",
" <td>12</td>\n",
" <td>1958</td>\n",
" <td>315.51</td>\n",
" <td>314.77</td>\n",
" </tr>\n",
" <tr>\n",
" <th>14</th>\n",
" <td>315.58</td>\n",
" <td>315.54</td>\n",
" <td>1</td>\n",
" <td>1959</td>\n",
" <td>315.57</td>\n",
" <td>315.62</td>\n",
" </tr>\n",
" <tr>\n",
" <th>15</th>\n",
" <td>316.49</td>\n",
" <td>2</td>\n",
" <td>1959</td>\n",
" <td>315.63</td>\n",
" <td>316.27</td>\n",
" </tr>\n",
" <tr>\n",
" <th>16</th>\n",
" <td>316.65</td>\n",
" <td>315.38</td>\n",
" <td>3</td>\n",
" <td>1959</td>\n",
" <td>315.69</td>\n",
" <td>316.98</td>\n",
" </tr>\n",
" <tr>\n",
" <th>17</th>\n",
" <td>317.72</td>\n",
" <td>4</td>\n",
" <td>1959</td>\n",
" <td>315.77</td>\n",
" <td>318.09</td>\n",
" </tr>\n",
" <tr>\n",
" <th>18</th>\n",
" <td>318.29</td>\n",
" <td>315.48</td>\n",
" <td>5</td>\n",
" <td>1959</td>\n",
" <td>315.85</td>\n",
" <td>318.66</td>\n",
" </tr>\n",
" <tr>\n",
" <th>19</th>\n",
" <td>318.15</td>\n",
" <td>316.03</td>\n",
" <td>6</td>\n",
" <td>1959</td>\n",
" <td>315.94</td>\n",
" <td>318.04</td>\n",
" </tr>\n",
" <tr>\n",
" <th>20</th>\n",
" <td>316.54</td>\n",
" <td>315.87</td>\n",
" <td>7</td>\n",
" <td>1959</td>\n",
" <td>316.67</td>\n",
" </tr>\n",
" <tr>\n",
" <th>21</th>\n",
" <td>314.80</td>\n",
" <td>316.07</td>\n",
" <td>8</td>\n",
" <td>1959</td>\n",
" <td>316.12</td>\n",
" <td>314.82</td>\n",
" </tr>\n",
" <tr>\n",
" <th>22</th>\n",
" <td>313.84</td>\n",
" <td>316.73</td>\n",
" <td>9</td>\n",
" <td>1959</td>\n",
" <td>316.22</td>\n",
" <td>313.31</td>\n",
" </tr>\n",
" <tr>\n",
" <th>23</th>\n",
" <td>316.33</td>\n",
" <td>10</td>\n",
" <td>1959</td>\n",
" <td>316.31</td>\n",
" <td>313.32</td>\n",
" </tr>\n",
" <tr>\n",
" <th>24</th>\n",
" <td>314.81</td>\n",
" <td>316.68</td>\n",
" <td>11</td>\n",
" <td>1959</td>\n",
" <td>316.39</td>\n",
" <td>314.54</td>\n",
" </tr>\n",
" <tr>\n",
" <th>25</th>\n",
" <td>316.35</td>\n",
" <td>12</td>\n",
" <td>1959</td>\n",
" <td>316.47</td>\n",
" <td>315.73</td>\n",
" </tr>\n",
" <tr>\n",
" <th>26</th>\n",
" <td>316.43</td>\n",
" <td>1</td>\n",
" <td>1960</td>\n",
" <td>316.56</td>\n",
" <td>316.61</td>\n",
" </tr>\n",
" <tr>\n",
" <th>27</th>\n",
" <td>2</td>\n",
" <td>1960</td>\n",
" <td>316.64</td>\n",
" <td>317.27</td>\n",
" </tr>\n",
" <tr>\n",
" <th>28</th>\n",
" <td>317.58</td>\n",
" <td>316.28</td>\n",
" <td>3</td>\n",
" <td>1960</td>\n",
" <td>316.71</td>\n",
" <td>318.03</td>\n",
" </tr>\n",
" <tr>\n",
" <th>29</th>\n",
" <td>319.03</td>\n",
" <td>316.70</td>\n",
" <td>4</td>\n",
" <td>1960</td>\n",
" <td>316.79</td>\n",
" <td>319.15</td>\n",
" </tr>\n",
" <tr>\n",
" <th>30</th>\n",
" <td>320.04</td>\n",
" <td>317.21</td>\n",
" <td>5</td>\n",
" <td>1960</td>\n",
" <td>316.86</td>\n",
" <td>319.68</td>\n",
" </tr>\n",
" <tr>\n",
" <th>31</th>\n",
" <td>319.58</td>\n",
" <td>317.47</td>\n",
" <td>6</td>\n",
" <td>1960</td>\n",
" <td>316.93</td>\n",
" <td>319.02</td>\n",
" </tr>\n",
" <tr>\n",
" <th>...</th>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" <td>...</td>\n",
" </tr>\n",
" <tr>\n",
" <th>728</th>\n",
" <td>408.90</td>\n",
" <td>408.09</td>\n",
" <td>7</td>\n",
" <td>2018</td>\n",
" <td>408.65</td>\n",
" <td>409.42</td>\n",
" </tr>\n",
" <tr>\n",
" <th>729</th>\n",
" <td>407.10</td>\n",
" <td>408.63</td>\n",
" <td>8</td>\n",
" <td>2018</td>\n",
" <td>408.91</td>\n",
" <td>407.34</td>\n",
" </tr>\n",
" <tr>\n",
" <th>730</th>\n",
" <td>405.59</td>\n",
" <td>409.08</td>\n",
" <td>9</td>\n",
" <td>2018</td>\n",
" <td>409.18</td>\n",
" <td>405.67</td>\n",
" </tr>\n",
" <tr>\n",
" <th>731</th>\n",
" <td>405.99</td>\n",
" <td>409.61</td>\n",
" <td>10</td>\n",
" <td>2018</td>\n",
" <td>409.45</td>\n",
" <td>405.85</td>\n",
" </tr>\n",
" <tr>\n",
" <th>732</th>\n",
" <td>408.12</td>\n",
" <td>410.38</td>\n",
" <td>11</td>\n",
" <td>2018</td>\n",
" <td>409.72</td>\n",
" <td>407.49</td>\n",
" </tr>\n",
" <tr>\n",
" <th>733</th>\n",
" <td>409.23</td>\n",
" <td>410.15</td>\n",
" <td>12</td>\n",
" <td>2018</td>\n",
" <td>409.98</td>\n",
" </tr>\n",
" <tr>\n",
" <th>734</th>\n",
" <td>410.92</td>\n",
" <td>410.87</td>\n",
" <td>1</td>\n",
" <td>2019</td>\n",
" <td>410.24</td>\n",
" <td>410.31</td>\n",
" </tr>\n",
" <tr>\n",
" <th>735</th>\n",
" <td>411.66</td>\n",
" <td>410.90</td>\n",
" <td>2</td>\n",
" <td>2019</td>\n",
" <td>410.48</td>\n",
" <td>411.26</td>\n",
" </tr>\n",
" <tr>\n",
" <th>736</th>\n",
" <td>412.00</td>\n",
" <td>410.46</td>\n",
" <td>3</td>\n",
" <td>2019</td>\n",
" <td>410.70</td>\n",
" <td>412.25</td>\n",
" </tr>\n",
" <tr>\n",
" <th>737</th>\n",
" <td>413.52</td>\n",
" <td>410.73</td>\n",
" <td>4</td>\n",
" <td>2019</td>\n",
" <td>413.73</td>\n",
" </tr>\n",
" <tr>\n",
" <th>738</th>\n",
" <td>414.83</td>\n",
" <td>411.43</td>\n",
" <td>5</td>\n",
" <td>2019</td>\n",
" <td>411.14</td>\n",
" <td>414.54</td>\n",
" </tr>\n",
" <tr>\n",
" <th>739</th>\n",
" <td>413.96</td>\n",
" <td>411.39</td>\n",
" <td>6</td>\n",
" <td>2019</td>\n",
" <td>411.36</td>\n",
" <td>413.91</td>\n",
" </tr>\n",
" <tr>\n",
" <th>740</th>\n",
" <td>411.85</td>\n",
" <td>411.04</td>\n",
" <td>7</td>\n",
" <td>2019</td>\n",
" <td>411.57</td>\n",
" <td>412.34</td>\n",
" </tr>\n",
" <tr>\n",
" <th>741</th>\n",
" <td>410.08</td>\n",
" <td>411.62</td>\n",
" <td>8</td>\n",
" <td>2019</td>\n",
" <td>411.79</td>\n",
" <td>410.21</td>\n",
" </tr>\n",
" <tr>\n",
" <th>742</th>\n",
" <td>408.55</td>\n",
" <td>412.05</td>\n",
" <td>9</td>\n",
" <td>2019</td>\n",
" <td>412.01</td>\n",
" <td>408.49</td>\n",
" </tr>\n",
" <tr>\n",
" <th>743</th>\n",
" <td>408.43</td>\n",
" <td>412.06</td>\n",
" <td>10</td>\n",
" <td>2019</td>\n",
" <td>412.22</td>\n",
" <td>408.61</td>\n",
" </tr>\n",
" <tr>\n",
" <th>744</th>\n",
" <td>410.29</td>\n",
" <td>412.55</td>\n",
" <td>11</td>\n",
" <td>2019</td>\n",
" <td>412.44</td>\n",
" <td>410.20</td>\n",
" </tr>\n",
" <tr>\n",
" <th>745</th>\n",
" <td>412.78</td>\n",
" <td>12</td>\n",
" <td>2019</td>\n",
" <td>412.65</td>\n",
" <td>411.74</td>\n",
" </tr>\n",
" <tr>\n",
" <th>746</th>\n",
" <td>413.37</td>\n",
" <td>413.32</td>\n",
" <td>1</td>\n",
" <td>2020</td>\n",
" <td>412.86</td>\n",
" <td>412.92</td>\n",
" </tr>\n",
" <tr>\n",
" <th>747</th>\n",
" <td>414.09</td>\n",
" <td>413.33</td>\n",
" <td>2</td>\n",
" <td>2020</td>\n",
" <td>413.07</td>\n",
" <td>413.84</td>\n",
" </tr>\n",
" <tr>\n",
" <th>748</th>\n",
" <td>414.51</td>\n",
" <td>412.94</td>\n",
" <td>3</td>\n",
" <td>2020</td>\n",
" <td>413.26</td>\n",
" <td>414.85</td>\n",
" </tr>\n",
" <tr>\n",
" <th>749</th>\n",
" <td>416.18</td>\n",
" <td>413.35</td>\n",
" <td>4</td>\n",
" <td>2020</td>\n",
" <td>413.47</td>\n",
" <td>416.31</td>\n",
" </tr>\n",
" <tr>\n",
" <th>750</th>\n",
" <td>417.16</td>\n",
" <td>413.75</td>\n",
" <td>5</td>\n",
" <td>2020</td>\n",
" <td>413.67</td>\n",
" <td>417.08</td>\n",
" </tr>\n",
" <tr>\n",
" <th>751</th>\n",
" <td>416.30</td>\n",
" <td>6</td>\n",
" <td>2020</td>\n",
" <td>413.89</td>\n",
" <td>416.42</td>\n",
" </tr>\n",
" <tr>\n",
" <th>752</th>\n",
" <td>414.49</td>\n",
" <td>413.71</td>\n",
" <td>7</td>\n",
" <td>2020</td>\n",
" <td>414.10</td>\n",
" </tr>\n",
" <tr>\n",
" <th>753</th>\n",
" <td>412.59</td>\n",
" <td>414.16</td>\n",
" <td>8</td>\n",
" <td>2020</td>\n",
" <td>414.33</td>\n",
" <td>412.72</td>\n",
" </tr>\n",
" <tr>\n",
" <th>754</th>\n",
" <td>411.25</td>\n",
" <td>414.77</td>\n",
" <td>9</td>\n",
" <td>2020</td>\n",
" <td>414.57</td>\n",
" <td>411.03</td>\n",
" </tr>\n",
" <tr>\n",
" <th>755</th>\n",
" <td>411.22</td>\n",
" <td>10</td>\n",
" <td>2020</td>\n",
" <td>414.80</td>\n",
" <td>411.18</td>\n",
" </tr>\n",
" <tr>\n",
" <th>756</th>\n",
" <td>412.95</td>\n",
" <td>415.21</td>\n",
" <td>11</td>\n",
" <td>2020</td>\n",
" </tr>\n",
" <tr>\n",
" <th>757</th>\n",
" <td>12</td>\n",
" <td>2020</td>\n",
" </tr>\n",
" </tbody>\n",
"</table>\n",
"<p>756 rows × 8 columns</p>\n",
"</div>"
" CO2 seasonally CO2 seasonally adjust CO2 seasonally adjust filled \\\n",
"2 -99.99 -99.99 -99.99 \n",
"3 -99.99 -99.99 -99.99 \n",
"4 315.70 314.43 314.43 \n",
"5 317.45 315.16 315.16 \n",
"6 317.51 314.71 314.71 \n",
"7 -99.99 -99.99 315.14 \n",
"8 315.86 315.19 315.19 \n",
"9 314.93 316.19 316.19 \n",
"10 313.21 316.09 316.09 \n",
"11 -99.99 -99.99 315.41 \n",
"12 313.33 315.20 315.20 \n",
"13 314.67 315.43 315.43 \n",
"14 315.58 315.54 315.54 \n",
"15 316.49 315.86 315.86 \n",
"16 316.65 315.38 315.38 \n",
"17 317.72 315.41 315.41 \n",
"18 318.29 315.48 315.48 \n",
"19 318.15 316.03 316.03 \n",
"20 316.54 315.87 315.87 \n",
"21 314.80 316.07 316.07 \n",
"22 313.84 316.73 316.73 \n",
"23 313.33 316.33 316.33 \n",
"24 314.81 316.68 316.68 \n",
"25 315.58 316.35 316.35 \n",
"26 316.43 316.39 316.39 \n",
"27 316.98 316.35 316.35 \n",
"28 317.58 316.28 316.28 \n",
"29 319.03 316.70 316.70 \n",
"30 320.04 317.21 317.21 \n",
"31 319.58 317.47 317.47 \n",
".. ... ... ... \n",
"728 408.90 408.09 408.09 \n",
"729 407.10 408.63 408.63 \n",
"730 405.59 409.08 409.08 \n",
"731 405.99 409.61 409.61 \n",
"732 408.12 410.38 410.38 \n",
"733 409.23 410.15 410.15 \n",
"734 410.92 410.87 410.87 \n",
"735 411.66 410.90 410.90 \n",
"736 412.00 410.46 410.46 \n",
"737 413.52 410.73 410.73 \n",
"738 414.83 411.43 411.43 \n",
"739 413.96 411.39 411.39 \n",
"740 411.85 411.04 411.04 \n",
"741 410.08 411.62 411.62 \n",
"742 408.55 412.05 412.05 \n",
"743 408.43 412.06 412.06 \n",
"744 410.29 412.55 412.55 \n",
"745 411.85 412.78 412.78 \n",
"746 413.37 413.32 413.32 \n",
"747 414.09 413.33 413.33 \n",
"748 414.51 412.94 412.94 \n",
"749 416.18 413.35 413.35 \n",
"750 417.16 413.75 413.75 \n",
"751 416.30 413.75 413.75 \n",
"752 414.49 413.71 413.71 \n",
"753 412.59 414.16 414.16 \n",
"754 411.25 414.77 414.77 \n",
"755 411.22 414.85 414.85 \n",
"756 412.95 415.21 415.21 \n",
"757 -99.99 -99.99 -99.99 \n",
" CO2 seasonally filled Month Year seasonally adjusted fit \\\n",
"2 -99.99 1 1958 -99.99 \n",
"3 -99.99 2 1958 -99.99 \n",
"4 315.70 3 1958 314.90 \n",
"5 317.45 4 1958 314.98 \n",
"6 317.51 5 1958 315.06 \n",
"7 317.24 6 1958 315.14 \n",
"8 315.86 7 1958 315.22 \n",
"9 314.93 8 1958 315.29 \n",
"10 313.21 9 1958 315.35 \n",
"11 312.43 10 1958 315.41 \n",
"12 313.33 11 1958 315.46 \n",
"13 314.67 12 1958 315.51 \n",
"14 315.58 1 1959 315.57 \n",
"15 316.49 2 1959 315.63 \n",
"16 316.65 3 1959 315.69 \n",
"17 317.72 4 1959 315.77 \n",
"18 318.29 5 1959 315.85 \n",
"19 318.15 6 1959 315.94 \n",
"20 316.54 7 1959 316.03 \n",
"21 314.80 8 1959 316.12 \n",
"22 313.84 9 1959 316.22 \n",
"23 313.33 10 1959 316.31 \n",
"24 314.81 11 1959 316.39 \n",
"25 315.58 12 1959 316.47 \n",
"26 316.43 1 1960 316.56 \n",
"27 316.98 2 1960 316.64 \n",
"28 317.58 3 1960 316.71 \n",
"29 319.03 4 1960 316.79 \n",
"30 320.04 5 1960 316.86 \n",
"31 319.58 6 1960 316.93 \n",
".. ... ... ... ... \n",
"728 408.90 7 2018 408.65 \n",
"729 407.10 8 2018 408.91 \n",
"730 405.59 9 2018 409.18 \n",
"731 405.99 10 2018 409.45 \n",
"732 408.12 11 2018 409.72 \n",
"733 409.23 12 2018 409.98 \n",
"734 410.92 1 2019 410.24 \n",
"735 411.66 2 2019 410.48 \n",
"736 412.00 3 2019 410.70 \n",
"737 413.52 4 2019 410.92 \n",
"738 414.83 5 2019 411.14 \n",
"739 413.96 6 2019 411.36 \n",
"740 411.85 7 2019 411.57 \n",
"741 410.08 8 2019 411.79 \n",
"742 408.55 9 2019 412.01 \n",
"743 408.43 10 2019 412.22 \n",
"744 410.29 11 2019 412.44 \n",
"745 411.85 12 2019 412.65 \n",
"746 413.37 1 2020 412.86 \n",
"747 414.09 2 2020 413.07 \n",
"748 414.51 3 2020 413.26 \n",
"749 416.18 4 2020 413.47 \n",
"750 417.16 5 2020 413.67 \n",
"751 416.30 6 2020 413.89 \n",
"752 414.49 7 2020 414.10 \n",
"753 412.59 8 2020 414.33 \n",
"754 411.25 9 2020 414.57 \n",
"755 411.22 10 2020 414.80 \n",
"756 412.95 11 2020 -99.99 \n",
"757 -99.99 12 2020 -99.99 \n",
" seasonally fit \n",
"2 -99.99 \n",
"3 -99.99 \n",
"4 316.19 \n",
"5 317.30 \n",
"6 317.86 \n",
"7 317.24 \n",
"8 315.86 \n",
"9 313.99 \n",
"10 312.45 \n",
"11 312.43 \n",
"12 313.61 \n",
"13 314.77 \n",
"14 315.62 \n",
"15 316.27 \n",
"16 316.98 \n",
"17 318.09 \n",
"18 318.66 \n",
"19 318.04 \n",
"20 316.67 \n",
"21 314.82 \n",
"22 313.31 \n",
"23 313.32 \n",
"24 314.54 \n",
"25 315.73 \n",
"26 316.61 \n",
"27 317.27 \n",
"28 318.03 \n",
"29 319.15 \n",
"30 319.68 \n",
"31 319.02 \n",
".. ... \n",
"728 409.42 \n",
"729 407.34 \n",
"730 405.67 \n",
"731 405.85 \n",
"732 407.49 \n",
"733 409.08 \n",
"734 410.31 \n",
"735 411.26 \n",
"736 412.25 \n",
"737 413.73 \n",
"738 414.54 \n",
"739 413.91 \n",
"740 412.34 \n",
"741 410.21 \n",
"742 408.49 \n",
"743 408.61 \n",
"744 410.20 \n",
"745 411.74 \n",
"746 412.92 \n",
"747 413.84 \n",
"748 414.85 \n",
"749 416.31 \n",
"750 417.08 \n",
"751 416.42 \n",
"752 414.85 \n",
"753 412.72 \n",
"754 411.03 \n",
"755 411.18 \n",
"756 -99.99 \n",
"757 -99.99 \n",
"[756 rows x 8 columns]"
"raw_data_prov = pd.read_csv('./monthly_in_situ_co2_mlo.csv',skiprows=54)\n",
"raw_data = pd.DataFrame({\"Year\":raw_data_prov[' Yr'][2:].astype(int), \"Month\":raw_data_prov[' Mn'][2:].astype(int), \n",
" \"CO2 seasonally\":raw_data_prov[' CO2'][2:].astype(float), \"CO2 seasonally adjust\":raw_data_prov['seasonally'][2:].astype(float),\n",
" \"seasonally fit\":raw_data_prov[' fit'][2:].astype(float),\"seasonally adjusted fit\":raw_data_prov[' seasonally'][2:].astype(float), \n",
" \"CO2 seasonally filled\":raw_data_prov[' CO2'][2:].astype(float), \"CO2 seasonally adjust filled\":raw_data_prov[' seasonally'][2:].astype(float)})\n",
"#raw_data = raw_data.drop([0,1])\n",
"raw_data\n"
"According to the authors:\n",
"\"CO2 seasonally\" gives monthly Mauna Loa CO2 concentrations in micro-mol CO2 per mole (ppm), reported on the 2008A SIO manometric mole fraction scale.The monthly values have been adjusted to 24:00 hours on the 15th of each month.\n",
"\"CO2 seasonally adjust\" gives the same data after a seasonal adjustment to remove the quasi-regular seasonal cycle. The adjustment involves subtracting from the data a 4-harmonic fit with a linear gain factor.\n",
"\"seasonally fit\" is a smoothed version of the data generated from a stiff cubic spline function plus 4-harmonic functions with linear gain.\n",
"\"seasonally adjusted fit\" is the same smoothed version with the seasonal cycle removed. \n",
"\"CO2 seasonally adjust filled\" and \"CO2 seasonally filled\" are identical to Columns \"CO2 seasonally\" and \"CO2 seasonally adjust\" except that the missing values from have been filled with values from Columns \"fit\" and \"seasonally adjusted fit\"\n",
"Moreover, it is said that the missing data are completed with the value -99.99\n",
"The month and year can be then converted to panda Period "
"execution_count": 69,
"raw_data['period'] = [pd.Period(str(y)+'-'+str(m)+'-15') for y,m in zip(raw_data['Year'],raw_data['Month'])]\n",
"sorted_data = raw_data.set_index('period').sort_index()"
"In order to highlight the seasonal and interannual variations, only the raw concentrations stored in 'CO2 seasonally\" and \"CO2 seasonally adjust\" are enough. The first one is the raw concentrations and contains both the seasonal and interannual variations. The second one is a adjustement made in order to get rid of the seasonal variations."
"execution_count": null,
"nb_year = 10\n",
"sorted_data=sorted_data[~(sorted_data[\"CO2 seasonally\"] < 0)]\n",
"sorted_data[\"CO2 seasonally\"][-12*nb_year:].plot(label='raw data')\n",
"sorted_data[\"CO2 seasonally adjust\"][-12*nb_year:].plot(label='interannual variation')\n",
"sorted_data=sorted_data[~(sorted_data[\"seasonally fit\"] < 0)]\n",
"sorted_data[\"seasonally fit\"][-12*nb_year:].plot(label='smoothed data')\n",
"plt.plot([sorted_data[\"period\"][-12*nb_year],sorted_data[\"period\"][-1]],[sorted_data[\"CO2 seasonally adjust\"][-12*nb_year],sorted_data[\"CO2 seasonally adjust\"][-1]])\n",
"plt.legend()\n",
"#sorted_data = data.set_index('period').sort_index()"
"We store the difference between the monthly CO2 concentration and the interannual variations of this concentration (obtained by the adjustement). Hence, it represent the seasonnal variations of the concentration "
"sorted_data[\"CO2 seasonal variations\"] = sorted_data[\"CO2 seasonally\"] - sorted_data[\"CO2 seasonally adjust\"]\n",
"sorted_data[\"CO2 seasonal variations\"][-12*nb_year:].plot()"
"This seasonal variations are rather close to a cosinus function with a one year period. In the other hand, the interannual variations are nearly linear. A FAIRE : une régression linéaire pour montrer la proximité et la pente "
"metadata": { "metadata": {
...@@ -16,10 +1052,9 @@ ...@@ -16,10 +1052,9 @@
"nbformat": 4, "nbformat": 4,
" Atmospheric CO2 concentrations (ppm) derived from in situ air measurements "
" at Mauna Loa, Observatory, Hawaii: Latitude 19.5°N Longitude 155.6°W Elevation 3397m "
" Source: R. F. Keeling, S. J. Walker, S. C. Piper and A. F. Bollenbacher "
" Scripps CO2 Program ( http://scrippsco2.ucsd.edu ) "
" Scripps Institution of Oceanography (SIO) "
" University of California "
" La Jolla, California USA 92093-0244 "
" Status of data and correspondence: "
" These data are subject to revision based on recalibration of standard gases. Questions "
" about the data should be directed to Dr. Ralph Keeling (rkeeling@ucsd.edu), Stephen Walker"
" (sjwalker@ucsd.edu) and Stephen Piper (scpiper@ucsd.edu), Scripps CO2 Program. "
" Baseline data in this file through 06-Dec-2020 from archive dated 07-Dec-2020 07:28:39 "
" Please cite as: "
" C. D. Keeling, S. C. Piper, R. B. Bacastow, M. Wahlen, T. P. Whorf, M. Heimann, and "
" H. A. Meijer, Exchanges of atmospheric CO2 and 13CO2 with the terrestrial biosphere and "
" oceans from 1978 to 2000. I. Global aspects, SIO Reference Series, No. 01-06, Scripps "
" Institution of Oceanography, San Diego, 88 pages, 2001. "
" If it is necessary to cite a peer-reviewed article, please cite as: "
" H. A. Meijer, Atmospheric CO2 and 13CO2 exchange with the terrestrial biosphere and "
" oceans from 1978 to 2000: observations and carbon cycle implications, pages 83-113, "
" in "A History of Atmospheric CO2 and its effects on Plants, Animals, and Ecosystems", "
" editors, Ehleringer, J.R., T. E. Cerling, M. D. Dearing, Springer Verlag, "
" New York, 2005. "
" The data file below contains 10 columns. Columns 1-4 give the dates in several redundant "
" formats. Column 5 below gives monthly Mauna Loa CO2 concentrations in micro-mol CO2 per "
" mole (ppm), reported on the 2008A SIO manometric mole fraction scale. This is the "
" standard version of the data most often sought. The monthly values have been adjusted "
" to 24:00 hours on the 15th of each month. Column 6 gives the same data after a seasonal "
" adjustment to remove the quasi-regular seasonal cycle. The adjustment involves "
" subtracting from the data a 4-harmonic fit with a linear gain factor. Column 7 is a "
" smoothed version of the data generated from a stiff cubic spline function plus 4-harmonic "
" functions with linear gain. Column 8 is the same smoothed version with the seasonal "
" cycle removed. Column 9 is identical to Column 5 except that the missing values from "
" Column 5 have been filled with values from Column 7. Column 10 is identical to Column 6 "
" except missing values have been filled with values from Column 8. Missing values are "
" denoted by -99.99 "
" CO2 concentrations are measured on the '08A' calibration scale "
Yr, Mn, Date, Date, CO2,seasonally, fit, seasonally, CO2, seasonally
, , , , , adjusted, ,adjusted fit, filled,adjusted filled
, , Excel, , [ppm], [ppm] , [ppm], [ppm], [ppm], [ppm]
1958, 01, 21200, 1958.0411, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
1958, 02, 21231, 1958.1260, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
1958, 03, 21259, 1958.2027, 315.70, 314.43, 316.19, 314.90, 315.70, 314.43
1958, 04, 21290, 1958.2877, 317.45, 315.16, 317.30, 314.98, 317.45, 315.16
1958, 05, 21320, 1958.3699, 317.51, 314.71, 317.86, 315.06, 317.51, 314.71
1958, 06, 21351, 1958.4548, -99.99, -99.99, 317.24, 315.14, 317.24, 315.14
1958, 07, 21381, 1958.5370, 315.86, 315.19, 315.86, 315.22, 315.86, 315.19
1958, 08, 21412, 1958.6219, 314.93, 316.19, 313.99, 315.29, 314.93, 316.19
1958, 09, 21443, 1958.7068, 313.21, 316.09, 312.45, 315.35, 313.21, 316.09
1958, 10, 21473, 1958.7890, -99.99, -99.99, 312.43, 315.41, 312.43, 315.41
1958, 11, 21504, 1958.8740, 313.33, 315.20, 313.61, 315.46, 313.33, 315.20
1958, 12, 21534, 1958.9562, 314.67, 315.43, 314.77, 315.51, 314.67, 315.43
1959, 01, 21565, 1959.0411, 315.58, 315.54, 315.62, 315.57, 315.58, 315.54
1959, 02, 21596, 1959.1260, 316.49, 315.86, 316.27, 315.63, 316.49, 315.86
1959, 03, 21624, 1959.2027, 316.65, 315.38, 316.98, 315.69, 316.65, 315.38
1959, 04, 21655, 1959.2877, 317.72, 315.41, 318.09, 315.77, 317.72, 315.41
1959, 05, 21685, 1959.3699, 318.29, 315.48, 318.66, 315.85, 318.29, 315.48
1959, 06, 21716, 1959.4548, 318.15, 316.03, 318.04, 315.94, 318.15, 316.03
1959, 07, 21746, 1959.5370, 316.54, 315.87, 316.67, 316.03, 316.54, 315.87
1959, 08, 21777, 1959.6219, 314.80, 316.07, 314.82, 316.12, 314.80, 316.07
1959, 09, 21808, 1959.7068, 313.84, 316.73, 313.31, 316.22, 313.84, 316.73
1959, 10, 21838, 1959.7890, 313.33, 316.33, 313.32, 316.31, 313.33, 316.33
1959, 11, 21869, 1959.8740, 314.81, 316.68, 314.54, 316.39, 314.81, 316.68
1959, 12, 21899, 1959.9562, 315.58, 316.35, 315.73, 316.47, 315.58, 316.35
1960, 01, 21930, 1960.0410, 316.43, 316.39, 316.61, 316.56, 316.43, 316.39
1960, 02, 21961, 1960.1257, 316.98, 316.35, 317.27, 316.64, 316.98, 316.35
1960, 03, 21990, 1960.2049, 317.58, 316.28, 318.03, 316.71, 317.58, 316.28
1960, 04, 22021, 1960.2896, 319.03, 316.70, 319.15, 316.79, 319.03, 316.70
1960, 05, 22051, 1960.3716, 320.04, 317.21, 319.68, 316.86, 320.04, 317.21
1960, 06, 22082, 1960.4563, 319.58, 317.47, 319.02, 316.93, 319.58, 317.47
1960, 07, 22112, 1960.5383, 318.18, 317.53, 317.59, 316.98, 318.18, 317.53
1960, 08, 22143, 1960.6230, 315.90, 317.20, 315.68, 317.01, 315.90, 317.20
1960, 09, 22174, 1960.7077, 314.17, 317.08, 314.12, 317.05, 314.17, 317.08
1960, 10, 22204, 1960.7896, 313.83, 316.83, 314.09, 317.07, 313.83, 316.83
1960, 11, 22235, 1960.8743, 315.00, 316.88, 315.25, 317.11, 315.00, 316.88
1960, 12, 22265, 1960.9563, 316.19, 316.96, 316.40, 317.15, 316.19, 316.96
1961, 01, 22296, 1961.0411, 316.90, 316.85, 317.25, 317.20, 316.90, 316.85
1961, 02, 22327, 1961.1260, 317.70, 317.07, 317.90, 317.26, 317.70, 317.07
1961, 03, 22355, 1961.2027, 318.54, 317.26, 318.63, 317.33, 318.54, 317.26
1961, 04, 22386, 1961.2877, 319.48, 317.15, 319.75, 317.41, 319.48, 317.15
1961, 05, 22416, 1961.3699, 320.58, 317.75, 320.33, 317.50, 320.58, 317.75
1961, 06, 22447, 1961.4548, 319.77, 317.63, 319.71, 317.59, 319.77, 317.63
1961, 07, 22477, 1961.5370, 318.56, 317.89, 318.32, 317.68, 318.56, 317.89
1961, 08, 22508, 1961.6219, 316.79, 318.07, 316.45, 317.76, 316.79, 318.07
1961, 09, 22539, 1961.7068, 314.99, 317.90, 314.92, 317.85, 314.99, 317.90
1961, 10, 22569, 1961.7890, 315.31, 318.32, 314.92, 317.92, 315.31, 318.32
1961, 11, 22600, 1961.8740, 316.10, 317.99, 316.13, 317.99, 316.10, 317.99
1961, 12, 22630, 1961.9562, 317.01, 317.78, 317.30, 318.06, 317.01, 317.78
1962, 01, 22661, 1962.0411, 317.94, 317.90, 318.18, 318.13, 317.94, 317.90
1962, 02, 22692, 1962.1260, 318.55, 317.92, 318.84, 318.19, 318.55, 317.92
1962, 03, 22720, 1962.2027, 319.68, 318.39, 319.56, 318.26, 319.68, 318.39
1962, 04, 22751, 1962.2877, 320.57, 318.24, 320.67, 318.32, 320.57, 318.24
1962, 05, 22781, 1962.3699, 321.02, 318.18, 321.23, 318.39, 321.02, 318.18
1962, 06, 22812, 1962.4548, 320.62, 318.47, 320.58, 318.45, 320.62, 318.47
1962, 07, 22842, 1962.5370, 319.61, 318.94, 319.15, 318.51, 319.61, 318.94
1962, 08, 22873, 1962.6219, 317.40, 318.69, 317.24, 318.56, 317.40, 318.69
1962, 09, 22904, 1962.7068, 316.25, 319.17, 315.67, 318.60, 316.25, 319.17
1962, 10, 22934, 1962.7890, 315.42, 318.45, 315.63, 318.64, 315.42, 318.45
1962, 11, 22965, 1962.8740, 316.69, 318.58, 316.81, 318.68, 316.69, 318.58
1962, 12, 22995, 1962.9562, 317.70, 318.47, 317.96, 318.72, 317.70, 318.47
1963, 01, 23026, 1963.0411, 318.74, 318.70, 318.82, 318.76, 318.74, 318.70
1963, 02, 23057, 1963.1260, 319.07, 318.43, 319.45, 318.81, 319.07, 318.43
1963, 03, 23085, 1963.2027, 319.86, 318.57, 320.16, 318.86, 319.86, 318.57
1963, 04, 23116, 1963.2877, 321.38, 319.04, 321.26, 318.91, 321.38, 319.04
1963, 05, 23146, 1963.3699, 322.25, 319.40, 321.81, 318.96, 322.25, 319.40
1963, 06, 23177, 1963.4548, 321.48, 319.33, 321.15, 319.01, 321.48, 319.33
1963, 07, 23207, 1963.5370, 319.74, 319.06, 319.71, 319.06, 319.74, 319.06
1963, 08, 23238, 1963.6219, 317.77, 319.05, 317.78, 319.10, 317.77, 319.05
1963, 09, 23269, 1963.7068, 316.21, 319.14, 316.20, 319.14, 316.21, 319.14
1963, 10, 23299, 1963.7890, 315.99, 319.02, 316.16, 319.18, 315.99, 319.02
1963, 11, 23330, 1963.8740, 317.07, 318.97, 317.35, 319.23, 317.07, 318.97
1963, 12, 23360, 1963.9562, 318.35, 319.13, 318.51, 319.27, 318.35, 319.13
1964, 01, 23391, 1964.0410, 319.57, 319.53, 319.37, 319.32, 319.57, 319.53
1964, 02, 23422, 1964.1257, -99.99, -99.99, 320.01, 319.37, 320.01, 319.37
1964, 03, 23451, 1964.2049, -99.99, -99.99, 320.74, 319.41, 320.74, 319.41
1964, 04, 23482, 1964.2896, -99.99, -99.99, 321.84, 319.45, 321.84, 319.45
1964, 05, 23512, 1964.3716, 322.26, 319.40, 322.35, 319.49, 322.26, 319.40
1964, 06, 23543, 1964.4563, 321.89, 319.75, 321.65, 319.53, 321.89, 319.75
1964, 07, 23573, 1964.5383, 320.44, 319.78, 320.18, 319.56, 320.44, 319.78
1964, 08, 23604, 1964.6230, 318.69, 320.01, 318.23, 319.58, 318.69, 320.01
1964, 09, 23635, 1964.7077, 316.71, 319.66, 316.64, 319.60, 316.71, 319.66
1964, 10, 23665, 1964.7896, 316.87, 319.91, 316.59, 319.62, 316.87, 319.91
1964, 11, 23696, 1964.8743, 317.68, 319.58, 317.76, 319.64, 317.68, 319.58
1964, 12, 23726, 1964.9563, 318.71, 319.48, 318.90, 319.66, 318.71, 319.48
1965, 01, 23757, 1965.0411, 319.44, 319.40, 319.74, 319.68, 319.44, 319.40
1965, 02, 23788, 1965.1260, 320.44, 319.80, 320.37, 319.72, 320.44, 319.80
1965, 03, 23816, 1965.2027, 320.89, 319.59, 321.08, 319.77, 320.89, 319.59
1965, 04, 23847, 1965.2877, 322.14, 319.78, 322.20, 319.83, 322.14, 319.78
1965, 05, 23877, 1965.3699, 322.17, 319.30, 322.78, 319.91, 322.17, 319.30
1965, 06, 23908, 1965.4548, 321.87, 319.70, 322.15, 320.00, 321.87, 319.70
1965, 07, 23938, 1965.5370, 321.21, 320.52, 320.76, 320.10, 321.21, 320.52
1965, 08, 23969, 1965.6219, 318.87, 320.16, 318.88, 320.21, 318.87, 320.16
1965, 09, 24000, 1965.7068, 317.82, 320.77, 317.36, 320.32, 317.82, 320.77
1965, 10, 24030, 1965.7890, 317.30, 320.36, 317.39, 320.43, 317.30, 320.36
1965, 11, 24061, 1965.8740, 318.87, 320.78, 318.66, 320.55, 318.87, 320.78
1965, 12, 24091, 1965.9562, 319.42, 320.20, 319.90, 320.66, 319.42, 320.20
1966, 01, 24122, 1966.0411, 320.62, 320.58, 320.84, 320.78, 320.62, 320.58
1966, 02, 24153, 1966.1260, 321.60, 320.95, 321.56, 320.90, 321.60, 320.95
1966, 03, 24181, 1966.2027, 322.39, 321.08, 322.33, 321.01, 322.39, 321.08
1966, 04, 24212, 1966.2877, 323.70, 321.34, 323.50, 321.12, 323.70, 321.34
1966, 05, 24242, 1966.3699, 324.08, 321.20, 324.10, 321.22, 324.08, 321.20
1966, 06, 24273, 1966.4548, 323.75, 321.57, 323.48, 321.32, 323.75, 321.57
1966, 07, 24303, 1966.5370, 322.38, 321.69, 322.06, 321.40, 322.38, 321.69
1966, 08, 24334, 1966.6219, 320.36, 321.66, 320.15, 321.48, 320.36, 321.66
1966, 09, 24365, 1966.7068, 318.64, 321.60, 318.58, 321.55, 318.64, 321.60
1966, 10, 24395, 1966.7890, 318.10, 321.17, 318.56, 321.62, 318.10, 321.17
1966, 11, 24426, 1966.8740, 319.78, 321.70, 319.78, 321.68, 319.78, 321.70
1966, 12, 24456, 1966.9562, 321.03, 321.81, 320.97, 321.74, 321.03, 321.81
1967, 01, 24487, 1967.0411, 322.33, 322.28, 321.85, 321.80, 322.33, 322.28
1967, 02, 24518, 1967.1260, 322.50, 321.85, 322.51, 321.86, 322.50, 321.85
1967, 03, 24546, 1967.2027, 323.04, 321.73, 323.23, 321.90, 323.04, 321.73
1967, 04, 24577, 1967.2877, 324.42, 322.04, 324.35, 321.96, 324.42, 322.04
1967, 05, 24607, 1967.3699, 325.00, 322.11, 324.90, 322.01, 325.00, 322.11
1967, 06, 24638, 1967.4548, 324.09, 321.91, 324.24, 322.07, 324.09, 321.91
1967, 07, 24668, 1967.5370, 322.54, 321.85, 322.80, 322.14, 322.54, 321.85
1967, 08, 24699, 1967.6219, 320.92, 322.22, 320.87, 322.20, 320.92, 322.22
1967, 09, 24730, 1967.7068, 319.25, 322.23, 319.29, 322.27, 319.25, 322.23
1967, 10, 24760, 1967.7890, 319.39, 322.47, 319.28, 322.35, 319.39, 322.47
1967, 11, 24791, 1967.8740, 320.73, 322.65, 320.51, 322.42, 320.73, 322.65
1967, 12, 24821, 1967.9562, 321.96, 322.74, 321.72, 322.49, 321.96, 322.74
1968, 01, 24852, 1968.0410, 322.57, 322.53, 322.62, 322.57, 322.57, 322.53
1968, 02, 24883, 1968.1257, 323.15, 322.50, 323.31, 322.65, 323.15, 322.50
1968, 03, 24912, 1968.2049, 323.89, 322.55, 324.08, 322.73, 323.89, 322.55
1968, 04, 24943, 1968.2896, 325.02, 322.62, 325.24, 322.83, 325.02, 322.62
1968, 05, 24973, 1968.3716, 325.57, 322.67, 325.82, 322.92, 325.57, 322.67
1968, 06, 25004, 1968.4563, 325.36, 323.19, 325.18, 323.03, 325.36, 323.19
1968, 07, 25034, 1968.5383, 324.14, 323.47, 323.77, 323.14, 324.14, 323.47
1968, 08, 25065, 1968.6230, 322.11, 323.44, 321.88, 323.25, 322.11, 323.44
1968, 09, 25096, 1968.7077, 320.33, 323.32, 320.36, 323.37, 320.33, 323.32
1968, 10, 25126, 1968.7896, 320.25, 323.33, 320.42, 323.49, 320.25, 323.33
1968, 11, 25157, 1968.8743, 321.32, 323.25, 321.71, 323.61, 321.32, 323.25
1968, 12, 25187, 1968.9563, 322.89, 323.68, 322.97, 323.75, 322.89, 323.68
1969, 01, 25218, 1969.0411, 324.00, 323.96, 323.94, 323.89, 324.00, 323.96
1969, 02, 25249, 1969.1260, 324.41, 323.76, 324.69, 324.03, 324.41, 323.76
1969, 03, 25277, 1969.2027, 325.63, 324.31, 325.49, 324.16, 325.63, 324.31
1969, 04, 25308, 1969.2877, 326.66, 324.27, 326.71, 324.30, 326.66, 324.27
1969, 05, 25338, 1969.3699, 327.38, 324.47, 327.35, 324.44, 327.38, 324.47
1969, 06, 25369, 1969.4548, 326.71, 324.51, 326.75, 324.57, 326.71, 324.51
1969, 07, 25399, 1969.5370, 325.88, 325.19, 325.35, 324.69, 325.88, 325.19
1969, 08, 25430, 1969.6219, 323.66, 324.98, 323.46, 324.80, 323.66, 324.98
1969, 09, 25461, 1969.7068, 322.38, 325.37, 321.90, 324.90, 322.38, 325.37
1969, 10, 25491, 1969.7890, 321.78, 324.88, 321.90, 324.99, 321.78, 324.88
1969, 11, 25522, 1969.8740, 322.85, 324.79, 323.16, 325.08, 322.85, 324.79
1969, 12, 25552, 1969.9562, 324.12, 324.91, 324.38, 325.16, 324.12, 324.91
1970, 01, 25583, 1970.0411, 325.06, 325.02, 325.30, 325.24, 325.06, 325.02
1970, 02, 25614, 1970.1260, 325.98, 325.33, 325.98, 325.32, 325.98, 325.33
1970, 03, 25642, 1970.2027, 326.93, 325.61, 326.73, 325.40, 326.93, 325.61
1970, 04, 25673, 1970.2877, 328.13, 325.74, 327.89, 325.48, 328.13, 325.74
1970, 05, 25703, 1970.3699, 328.08, 325.16, 328.47, 325.55, 328.08, 325.16
1970, 06, 25734, 1970.4548, 327.67, 325.46, 327.82, 325.63, 327.67, 325.46
1970, 07, 25764, 1970.5370, 326.34, 325.65, 326.37, 325.70, 326.34, 325.65
1970, 08, 25795, 1970.6219, 324.69, 326.00, 324.42, 325.77, 324.69, 326.00
1970, 09, 25826, 1970.7068, 323.10, 326.10, 322.81, 325.83, 323.10, 326.10
1970, 10, 25856, 1970.7890, 323.06, 326.18, 322.79, 325.88, 323.06, 326.18
1970, 11, 25887, 1970.8740, 324.01, 325.95, 324.00, 325.93, 324.01, 325.95
1970, 12, 25917, 1970.9562, 325.13, 325.93, 325.19, 325.97, 325.13, 325.93
1971, 01, 25948, 1971.0411, 326.17, 326.13, 326.06, 326.01, 326.17, 326.13
1971, 02, 25979, 1971.1260, 326.68, 326.03, 326.71, 326.05, 326.68, 326.03
1971, 03, 26007, 1971.2027, 327.17, 325.85, 327.43, 326.09, 327.17, 325.85
1971, 04, 26038, 1971.2877, 327.79, 325.38, 328.56, 326.14, 327.79, 325.38
1971, 05, 26068, 1971.3699, 328.93, 326.00, 329.12, 326.19, 328.93, 326.00
1971, 06, 26099, 1971.4548, 328.57, 326.36, 328.46, 326.26, 328.57, 326.36
1971, 07, 26129, 1971.5370, 327.36, 326.66, 327.00, 326.33, 327.36, 326.66
1971, 08, 26160, 1971.6219, 325.43, 326.75, 325.05, 326.40, 325.43, 326.75
1971, 09, 26191, 1971.7068, 323.36, 326.37, 323.45, 326.47, 323.36, 326.37
1971, 10, 26221, 1971.7890, 323.56, 326.68, 323.44, 326.54, 323.56, 326.68
1971, 11, 26252, 1971.8740, 324.80, 326.75, 324.69, 326.62, 324.80, 326.75
1971, 12, 26282, 1971.9562, 326.01, 326.81, 325.92, 326.70, 326.01, 326.81
1972, 01, 26313, 1972.0410, 326.77, 326.73, 326.84, 326.78, 326.77, 326.73
1972, 02, 26344, 1972.1257, 327.63, 326.98, 327.54, 326.88, 327.63, 326.98
1972, 03, 26373, 1972.2049, 327.75, 326.39, 328.35, 326.98, 327.75, 326.39
1972, 04, 26404, 1972.2896, 329.72, 327.29, 329.55, 327.10, 329.72, 327.29
1972, 05, 26434, 1972.3716, 330.07, 327.13, 330.16, 327.23, 330.07, 327.13
1972, 06, 26465, 1972.4563, 329.09, 326.89, 329.56, 327.38, 329.09, 326.89
1972, 07, 26495, 1972.5383, 328.04, 327.37, 328.18, 327.54, 328.04, 327.37
1972, 08, 26526, 1972.6230, 326.32, 327.67, 326.33, 327.72, 326.32, 327.67
1972, 09, 26557, 1972.7077, 324.84, 327.87, 324.86, 327.91, 324.84, 327.87
1972, 10, 26587, 1972.7896, 325.20, 328.33, 324.99, 328.10, 325.20, 328.33
1972, 11, 26618, 1972.8743, 326.50, 328.45, 326.37, 328.31, 326.50, 328.45
1972, 12, 26648, 1972.9563, 327.55, 328.35, 327.73, 328.51, 327.55, 328.35
1973, 01, 26679, 1973.0411, 328.55, 328.50, 328.77, 328.72, 328.55, 328.50
1973, 02, 26710, 1973.1260, 329.56, 328.90, 329.59, 328.92, 329.56, 328.90
1973, 03, 26738, 1973.2027, 330.30, 328.96, 330.46, 329.11, 330.30, 328.96
1973, 04, 26769, 1973.2877, 331.50, 329.08, 331.74, 329.30, 331.50, 329.08
1973, 05, 26799, 1973.3699, 332.48, 329.53, 332.42, 329.48, 332.48, 329.53
1973, 06, 26830, 1973.4548, 332.07, 329.84, 331.85, 329.64, 332.07, 329.84
1973, 07, 26860, 1973.5370, 330.87, 330.17, 330.44, 329.77, 330.87, 330.17
1973, 08, 26891, 1973.6219, 329.31, 330.64, 328.51, 329.88, 329.31, 330.64
1973, 09, 26922, 1973.7068, 327.51, 330.55, 326.91, 329.96, 327.51, 330.55
1973, 10, 26952, 1973.7890, 327.18, 330.32, 326.88, 330.01, 327.18, 330.32
1973, 11, 26983, 1973.8740, 328.16, 330.13, 328.10, 330.04, 328.16, 330.13
1973, 12, 27013, 1973.9562, 328.64, 329.44, 329.28, 330.07, 328.64, 329.44
1974, 01, 27044, 1974.0411, 329.35, 329.31, 330.15, 330.09, 329.35, 329.31
1974, 02, 27075, 1974.1260, 330.71, 330.05, 330.79, 330.12, 330.71, 330.05
1974, 03, 27103, 1974.2027, 331.48, 330.14, 331.50, 330.14, 331.48, 330.14
1974, 04, 27134, 1974.2877, 332.65, 330.22, 332.62, 330.18, 332.65, 330.22
1974, 05, 27164, 1974.3699, 333.09, 330.13, 333.18, 330.22, 333.09, 330.13
1974, 06, 27195, 1974.4548, 332.25, 330.01, 332.48, 330.26, 332.25, 330.01
1974, 07, 27225, 1974.5370, 331.18, 330.47, 330.99, 330.31, 331.18, 330.47
1974, 08, 27256, 1974.6219, 329.39, 330.73, 328.99, 330.36, 329.39, 330.73
1974, 09, 27287, 1974.7068, 327.43, 330.47, 327.35, 330.41, 327.43, 330.47
1974, 10, 27317, 1974.7890, 327.37, 330.52, 327.32, 330.46, 327.37, 330.52
1974, 11, 27348, 1974.8740, 328.46, 330.43, 328.57, 330.52, 328.46, 330.43
1974, 12, 27378, 1974.9562, 329.57, 330.38, 329.79, 330.58, 329.57, 330.38
1975, 01, 27409, 1975.0411, 330.40, 330.36, 330.71, 330.65, 330.40, 330.36
1975, 02, 27440, 1975.1260, 331.40, 330.74, 331.41, 330.74, 331.40, 330.74
1975, 03, 27468, 1975.2027, 332.04, 330.69, 332.17, 330.82, 332.04, 330.69
1975, 04, 27499, 1975.2877, 333.31, 330.87, 333.36, 330.91, 333.31, 330.87
1975, 05, 27529, 1975.3699, 333.97, 331.00, 333.97, 331.00, 333.97, 331.00
1975, 06, 27560, 1975.4548, 333.60, 331.36, 333.33, 331.10, 333.60, 331.36
1975, 07, 27590, 1975.5370, 331.90, 331.20, 331.88, 331.20, 331.90, 331.20
1975, 08, 27621, 1975.6219, 330.06, 331.40, 329.92, 331.29, 330.06, 331.40
1975, 09, 27652, 1975.7068, 328.56, 331.61, 328.32, 331.39, 328.56, 331.61
1975, 10, 27682, 1975.7890, 328.34, 331.50, 328.32, 331.47, 328.34, 331.50
1975, 11, 27713, 1975.8740, 329.49, 331.47, 329.60, 331.56, 329.49, 331.47
1975, 12, 27743, 1975.9562, 330.76, 331.57, 330.85, 331.64, 330.76, 331.57
1976, 01, 27774, 1976.0410, 331.75, 331.70, 331.77, 331.72, 331.75, 331.70
1976, 02, 27805, 1976.1257, 332.57, 331.90, 332.47, 331.80, 332.57, 331.90
1976, 03, 27834, 1976.2049, 333.50, 332.12, 333.26, 331.87, 333.50, 332.12
1976, 04, 27865, 1976.2896, 334.58, 332.12, 334.43, 331.95, 334.58, 332.12
1976, 05, 27895, 1976.3716, 334.88, 331.90, 335.00, 332.03, 334.88, 331.90
1976, 06, 27926, 1976.4563, 334.33, 332.10, 334.32, 332.11, 334.33, 332.10
1976, 07, 27956, 1976.5383, 333.05, 332.37, 332.85, 332.19, 333.05, 332.37
1976, 08, 27987, 1976.6230, 330.94, 332.31, 330.88, 332.29, 330.94, 332.31
1976, 09, 28018, 1976.7077, 329.30, 332.38, 329.30, 332.39, 329.30, 332.38
1976, 10, 28048, 1976.7896, 328.94, 332.11, 329.35, 332.50, 328.94, 332.11
1976, 11, 28079, 1976.8743, 330.31, 332.29, 330.67, 332.63, 330.31, 332.29
1976, 12, 28109, 1976.9563, 331.68, 332.49, 331.98, 332.77, 331.68, 332.49
1977, 01, 28140, 1977.0411, 332.93, 332.88, 332.99, 332.93, 332.93, 332.88
1977, 02, 28171, 1977.1260, 333.42, 332.75, 333.78, 333.11, 333.42, 332.75
1977, 03, 28199, 1977.2027, 334.70, 333.35, 334.64, 333.27, 334.70, 333.35
1977, 04, 28230, 1977.2877, 336.07, 333.62, 335.92, 333.46, 336.07, 333.62
1977, 05, 28260, 1977.3699, 336.75, 333.76, 336.62, 333.63, 336.75, 333.76
1977, 06, 28291, 1977.4548, 336.27, 334.01, 336.05, 333.82, 336.27, 334.01
1977, 07, 28321, 1977.5370, 334.92, 334.21, 334.67, 333.98, 334.92, 334.21
1977, 08, 28352, 1977.6219, 332.75, 334.10, 332.77, 334.15, 332.75, 334.10
1977, 09, 28383, 1977.7068, 331.59, 334.66, 331.22, 334.31, 331.59, 334.66
1977, 10, 28413, 1977.7890, 331.16, 334.35, 331.28, 334.46, 331.16, 334.35
1977, 11, 28444, 1977.8740, 332.40, 334.40, 332.63, 334.60, 332.40, 334.40
1977, 12, 28474, 1977.9562, 333.85, 334.66, 333.94, 334.74, 333.85, 334.66
1978, 01, 28505, 1978.0411, 334.97, 334.93, 334.93, 334.87, 334.97, 334.93
1978, 02, 28536, 1978.1260, 335.39, 334.72, 335.69, 335.01, 335.39, 334.72
1978, 03, 28564, 1978.2027, 336.64, 335.28, 336.50, 335.13, 336.64, 335.28
1978, 04, 28595, 1978.2877, 337.76, 335.30, 337.73, 335.25, 337.76, 335.30
1978, 05, 28625, 1978.3699, 338.01, 335.01, 338.37, 335.37, 338.01, 335.01
1978, 06, 28656, 1978.4548, 337.90, 335.63, 337.73, 335.49, 337.90, 335.63
1978, 07, 28686, 1978.5370, 336.54, 335.82, 336.28, 335.60, 336.54, 335.82
1978, 08, 28717, 1978.6219, 334.68, 336.04, 334.31, 335.70, 334.68, 336.04
1978, 09, 28748, 1978.7068, 332.76, 335.84, 332.70, 335.80, 332.76, 335.84
1978, 10, 28778, 1978.7890, 332.55, 335.74, 332.71, 335.89, 332.55, 335.74
1978, 11, 28809, 1978.8740, 333.92, 335.92, 334.01, 335.99, 333.92, 335.92
1978, 12, 28839, 1978.9562, 334.95, 335.76, 335.29, 336.08, 334.95, 335.76
1979, 01, 28870, 1979.0411, 336.23, 336.18, 336.25, 336.19, 336.23, 336.18
1979, 02, 28901, 1979.1260, 336.76, 336.09, 336.99, 336.30, 336.76, 336.09
1979, 03, 28929, 1979.2027, 337.96, 336.60, 337.79, 336.41, 337.96, 336.60
1979, 04, 28960, 1979.2877, 338.88, 336.41, 339.02, 336.54, 338.88, 336.41
1979, 05, 28990, 1979.3699, 339.47, 336.46, 339.67, 336.67, 339.47, 336.46
1979, 06, 29021, 1979.4548, 339.29, 337.01, 339.06, 336.80, 339.29, 337.01
1979, 07, 29051, 1979.5370, 337.73, 337.01, 337.62, 336.94, 337.73, 337.01
1979, 08, 29082, 1979.6219, 336.09, 337.44, 335.68, 337.08, 336.09, 337.44
1979, 09, 29113, 1979.7068, 333.92, 337.01, 334.11, 337.22, 333.92, 337.01
1979, 10, 29143, 1979.7890, 333.86, 337.07, 334.17, 337.37, 333.86, 337.07
1979, 11, 29174, 1979.8740, 335.29, 337.30, 335.54, 337.52, 335.29, 337.30
1979, 12, 29204, 1979.9562, 336.73, 337.55, 336.88, 337.68, 336.73, 337.55
1980, 01, 29235, 1980.0410, 338.01, 337.97, 337.90, 337.85, 338.01, 337.97
1980, 02, 29266, 1980.1257, 338.36, 337.69, 338.70, 338.02, 338.36, 337.69
1980, 03, 29295, 1980.2049, 340.07, 338.68, 339.58, 338.17, 340.07, 338.68
1980, 04, 29326, 1980.2896, 340.76, 338.26, 340.85, 338.33, 340.76, 338.26
1980, 05, 29356, 1980.3716, 341.47, 338.45, 341.50, 338.48, 341.47, 338.45
1980, 06, 29387, 1980.4563, 341.17, 338.92, 340.87, 338.63, 341.17, 338.92
1980, 07, 29417, 1980.5383, 339.56, 338.87, 339.43, 338.76, 339.56, 338.87
1980, 08, 29448, 1980.6230, 337.60, 338.99, 337.47, 338.90, 337.60, 338.99
1980, 09, 29479, 1980.7077, 335.88, 338.99, 335.89, 339.02, 335.88, 338.99
1980, 10, 29509, 1980.7896, 336.02, 339.23, 335.93, 339.13, 336.02, 339.23
1980, 11, 29540, 1980.8743, 337.10, 339.11, 337.25, 339.24, 337.10, 339.11
1980, 12, 29570, 1980.9563, 338.21, 339.03, 338.54, 339.34, 338.21, 339.03
1981, 01, 29601, 1981.0411, 339.24, 339.19, 339.50, 339.44, 339.24, 339.19
1981, 02, 29632, 1981.1260, 340.48, 339.80, 340.23, 339.55, 340.48, 339.80
1981, 03, 29660, 1981.2027, 341.38, 340.01, 341.02, 339.63, 341.38, 340.01
1981, 04, 29691, 1981.2877, 342.50, 340.02, 342.23, 339.72, 342.50, 340.02
1981, 05, 29721, 1981.3699, 342.91, 339.88, 342.84, 339.81, 342.91, 339.88
1981, 06, 29752, 1981.4548, 342.25, 339.96, 342.16, 339.89, 342.25, 339.96
1981, 07, 29782, 1981.5370, 340.49, 339.76, 340.67, 339.98, 340.49, 339.76
1981, 08, 29813, 1981.6219, 338.43, 339.80, 338.66, 340.07, 338.43, 339.80
1981, 09, 29844, 1981.7068, 336.69, 339.81, 337.03, 340.16, 336.69, 339.81
1981, 10, 29874, 1981.7890, 336.86, 340.08, 337.05, 340.26, 336.86, 340.08
1981, 11, 29905, 1981.8740, 338.36, 340.38, 338.38, 340.37, 338.36, 340.38
1981, 12, 29935, 1981.9562, 339.61, 340.44, 339.67, 340.48, 339.61, 340.44
1982, 01, 29966, 1982.0411, 340.75, 340.71, 340.65, 340.59, 340.75, 340.71
1982, 02, 29997, 1982.1260, 341.61, 340.94, 341.38, 340.70, 341.61, 340.94
1982, 03, 30025, 1982.2027, 342.70, 341.32, 342.18, 340.79, 342.70, 341.32
1982, 04, 30056, 1982.2877, 343.57, 341.07, 343.39, 340.88, 343.57, 341.07
1982, 05, 30086, 1982.3699, 344.14, 341.10, 344.00, 340.96, 344.14, 341.10
1982, 06, 30117, 1982.4548, 343.35, 341.05, 343.31, 341.04, 343.35, 341.05
1982, 07, 30147, 1982.5370, 342.06, 341.33, 341.81, 341.12, 342.06, 341.33
1982, 08, 30178, 1982.6219, 339.81, 341.18, 339.79, 341.20, 339.81, 341.18
1982, 09, 30209, 1982.7068, 337.98, 341.10, 338.14, 341.28, 337.98, 341.10
1982, 10, 30239, 1982.7890, 337.86, 341.10, 338.15, 341.38, 337.86, 341.10
1982, 11, 30270, 1982.8740, 339.26, 341.29, 339.49, 341.49, 339.26, 341.29
1982, 12, 30300, 1982.9562, 340.49, 341.31, 340.81, 341.62, 340.49, 341.31
1983, 01, 30331, 1983.0411, 341.38, 341.33, 341.83, 341.78, 341.38, 341.33
1983, 02, 30362, 1983.1260, 342.52, 341.84, 342.64, 341.95, 342.52, 341.84
1983, 03, 30390, 1983.2027, 343.10, 341.72, 343.51, 342.11, 343.10, 341.72
1983, 04, 30421, 1983.2877, 344.94, 342.44, 344.82, 342.31, 344.94, 342.44
1983, 05, 30451, 1983.3699, 345.76, 342.71, 345.54, 342.49, 345.76, 342.71
1983, 06, 30482, 1983.4548, 345.32, 343.01, 344.97, 342.68, 345.32, 343.01
1983, 07, 30512, 1983.5370, 343.98, 343.25, 343.56, 342.86, 343.98, 343.25
1983, 08, 30543, 1983.6219, 342.38, 343.76, 341.62, 343.03, 342.38, 343.76
1983, 09, 30574, 1983.7068, 339.87, 343.00, 340.04, 343.19, 339.87, 343.00
1983, 10, 30604, 1983.7890, 339.99, 343.24, 340.10, 343.34, 339.99, 343.24
1983, 11, 30635, 1983.8740, 341.15, 343.19, 341.47, 343.48, 341.15, 343.19
1983, 12, 30665, 1983.9562, 342.99, 343.82, 342.81, 343.62, 342.99, 343.82
1984, 01, 30696, 1984.0410, 343.70, 343.65, 343.81, 343.76, 343.70, 343.65
1984, 02, 30727, 1984.1257, 344.50, 343.82, 344.58, 343.89, 344.50, 343.82
1984, 03, 30756, 1984.2049, 345.28, 343.87, 345.44, 344.01, 345.28, 343.87
1984, 04, 30787, 1984.2896, 347.05, 344.52, 346.69, 344.14, 347.05, 344.52
1984, 05, 30817, 1984.3716, 347.43, 344.38, 347.32, 344.26, 347.43, 344.38
1984, 06, 30848, 1984.4563, 346.80, 344.51, 346.65, 344.39, 346.80, 344.51
1984, 07, 30878, 1984.5383, 345.39, 344.69, 345.17, 344.50, 345.39, 344.69
1984, 08, 30909, 1984.6230, 343.28, 344.69, 343.18, 344.62, 343.28, 344.69
1984, 09, 30940, 1984.7077, 341.07, 344.23, 341.57, 344.74, 341.07, 344.23
1984, 10, 30970, 1984.7896, 341.35, 344.60, 341.62, 344.86, 341.35, 344.60
1984, 11, 31001, 1984.8743, 342.98, 345.01, 342.98, 344.99, 342.98, 345.01
1984, 12, 31031, 1984.9563, 344.22, 345.05, 344.31, 345.12, 344.22, 345.05
1985, 01, 31062, 1985.0411, 344.97, 344.92, 345.31, 345.25, 344.97, 344.92
1985, 02, 31093, 1985.1260, 345.99, 345.31, 346.08, 345.38, 345.99, 345.31
1985, 03, 31121, 1985.2027, 347.42, 346.03, 346.91, 345.50, 347.42, 346.03
1985, 04, 31152, 1985.2877, 348.35, 345.83, 348.16, 345.62, 348.35, 345.83
1985, 05, 31182, 1985.3699, 348.93, 345.86, 348.80, 345.73, 348.93, 345.86
1985, 06, 31213, 1985.4548, 348.25, 345.94, 348.13, 345.83, 348.25, 345.94
1985, 07, 31243, 1985.5370, 346.56, 345.83, 346.63, 345.92, 346.56, 345.83
1985, 08, 31274, 1985.6219, 344.67, 346.06, 344.60, 346.02, 344.67, 346.06
1985, 09, 31305, 1985.7068, 343.09, 346.24, 342.93, 346.10, 343.09, 346.24
1985, 10, 31335, 1985.7890, 342.80, 346.07, 342.93, 346.19, 342.80, 346.07
1985, 11, 31366, 1985.8740, 344.24, 346.28, 344.26, 346.28, 344.24, 346.28
1985, 12, 31396, 1985.9562, 345.56, 346.39, 345.55, 346.37, 345.56, 346.39
1986, 01, 31427, 1986.0411, 346.30, 346.25, 346.53, 346.47, 346.30, 346.25
1986, 02, 31458, 1986.1260, 346.95, 346.26, 347.28, 346.58, 346.95, 346.26
1986, 03, 31486, 1986.2027, 347.85, 346.46, 348.10, 346.69, 347.85, 346.46
1986, 04, 31517, 1986.2877, 349.55, 347.03, 349.35, 346.81, 349.55, 347.03
1986, 05, 31547, 1986.3699, 350.22, 347.14, 350.01, 346.93, 350.22, 347.14
1986, 06, 31578, 1986.4548, 349.55, 347.23, 349.37, 347.06, 349.55, 347.23
1986, 07, 31608, 1986.5370, 347.94, 347.20, 347.89, 347.18, 347.94, 347.20
1986, 08, 31639, 1986.6219, 345.90, 347.29, 345.89, 347.31, 345.90, 347.29
1986, 09, 31670, 1986.7068, 344.85, 348.02, 344.26, 347.44, 344.85, 348.02
1986, 10, 31700, 1986.7890, 344.17, 347.45, 344.30, 347.56, 344.17, 347.45
1986, 11, 31731, 1986.8740, 345.66, 347.71, 345.67, 347.69, 345.66, 347.71
1986, 12, 31761, 1986.9562, 346.90, 347.74, 347.01, 347.83, 346.90, 347.74
1987, 01, 31792, 1987.0411, 348.02, 347.98, 348.03, 347.97, 348.02, 347.98
1987, 02, 31823, 1987.1260, 348.48, 347.79, 348.83, 348.13, 348.48, 347.79
1987, 03, 31851, 1987.2027, 349.42, 348.02, 349.70, 348.29, 349.42, 348.02
1987, 04, 31882, 1987.2877, 350.98, 348.45, 351.02, 348.47, 350.98, 348.45
1987, 05, 31912, 1987.3699, 351.85, 348.76, 351.74, 348.66, 351.85, 348.76
1987, 06, 31943, 1987.4548, 351.26, 348.92, 351.17, 348.86, 351.26, 348.92
1987, 07, 31973, 1987.5370, 349.51, 348.77, 349.77, 349.06, 349.51, 348.77
1987, 08, 32004, 1987.6219, 348.10, 349.49, 347.85, 349.28, 348.10, 349.49
1987, 09, 32035, 1987.7068, 346.45, 349.62, 346.31, 349.50, 346.45, 349.62
1987, 10, 32065, 1987.7890, 346.36, 349.65, 346.44, 349.72, 346.36, 349.65
1987, 11, 32096, 1987.8740, 347.81, 349.87, 347.91, 349.94, 347.81, 349.87
1987, 12, 32126, 1987.9562, 348.96, 349.80, 349.34, 350.16, 348.96, 349.80
1988, 01, 32157, 1988.0410, 350.43, 350.39, 350.45, 350.39, 350.43, 350.39
1988, 02, 32188, 1988.1257, 351.73, 351.04, 351.31, 350.61, 351.73, 351.04
1988, 03, 32217, 1988.2049, 352.22, 350.79, 352.26, 350.81, 352.22, 350.79
1988, 04, 32248, 1988.2896, 353.59, 351.02, 353.60, 351.02, 353.59, 351.02
1988, 05, 32278, 1988.3716, 354.22, 351.12, 354.31, 351.21, 354.22, 351.12
1988, 06, 32309, 1988.4563, 353.80, 351.48, 353.70, 351.40, 353.80, 351.48
1988, 07, 32339, 1988.5383, 352.38, 351.67, 352.25, 351.57, 352.38, 351.67
1988, 08, 32370, 1988.6230, 350.43, 351.85, 350.28, 351.74, 350.43, 351.85
1988, 09, 32401, 1988.7077, 348.73, 351.92, 348.68, 351.89, 348.73, 351.92
1988, 10, 32431, 1988.7896, 348.88, 352.18, 348.75, 352.03, 348.88, 352.18
1988, 11, 32462, 1988.8743, 350.07, 352.13, 350.12, 352.16, 350.07, 352.13
1988, 12, 32492, 1988.9563, 351.34, 352.18, 351.45, 352.27, 351.34, 352.18
1989, 01, 32523, 1989.0411, 352.76, 352.71, 352.45, 352.39, 352.76, 352.71
1989, 02, 32554, 1989.1260, 353.07, 352.38, 353.20, 352.50, 353.07, 352.38
1989, 03, 32582, 1989.2027, 353.68, 352.27, 354.01, 352.59, 353.68, 352.27
1989, 04, 32613, 1989.2877, 355.42, 352.87, 355.26, 352.69, 355.42, 352.87
1989, 05, 32643, 1989.3699, 355.67, 352.56, 355.90, 352.79, 355.67, 352.56
1989, 06, 32674, 1989.4548, 355.12, 352.77, 355.22, 352.89, 355.12, 352.77
1989, 07, 32704, 1989.5370, 353.90, 353.16, 353.69, 352.98, 353.90, 353.16
1989, 08, 32735, 1989.6219, 351.67, 353.07, 351.64, 353.08, 351.67, 353.07
1989, 09, 32766, 1989.7068, 349.81, 353.00, 349.97, 353.18, 349.81, 353.00
1989, 10, 32796, 1989.7890, 349.99, 353.30, 349.98, 353.28, 349.99, 353.30
1989, 11, 32827, 1989.8740, 351.30, 353.37, 351.33, 353.38, 351.30, 353.37
1989, 12, 32857, 1989.9562, 352.52, 353.37, 352.65, 353.47, 352.52, 353.37
1990, 01, 32888, 1990.0411, 353.66, 353.62, 353.64, 353.58, 353.66, 353.62
1990, 02, 32919, 1990.1260, 354.70, 354.00, 354.38, 353.68, 354.70, 354.00
1990, 03, 32947, 1990.2027, 355.38, 353.97, 355.20, 353.77, 355.38, 353.97
1990, 04, 32978, 1990.2877, 356.20, 353.64, 356.45, 353.88, 356.20, 353.64
1990, 05, 33008, 1990.3699, 357.16, 354.04, 357.10, 353.98, 357.16, 354.04
1990, 06, 33039, 1990.4548, 356.23, 353.87, 356.43, 354.09, 356.23, 353.87
1990, 07, 33069, 1990.5370, 354.81, 354.07, 354.92, 354.21, 354.81, 354.07
1990, 08, 33100, 1990.6219, 352.91, 354.32, 352.90, 354.34, 352.91, 354.32
1990, 09, 33131, 1990.7068, 350.96, 354.17, 351.26, 354.48, 350.96, 354.17
1990, 10, 33161, 1990.7890, 351.18, 354.50, 351.32, 354.63, 351.18, 354.50
1990, 11, 33192, 1990.8740, 352.83, 354.91, 352.72, 354.78, 352.83, 354.91
1990, 12, 33222, 1990.9562, 354.21, 355.06, 354.09, 354.92, 354.21, 355.06
1991, 01, 33253, 1991.0411, 354.72, 354.68, 355.13, 355.07, 354.72, 354.68
1991, 02, 33284, 1991.1260, 355.75, 355.05, 355.92, 355.21, 355.75, 355.05
1991, 03, 33312, 1991.2027, 357.16, 355.74, 356.76, 355.33, 357.16, 355.74
1991, 04, 33343, 1991.2877, 358.60, 356.03, 358.03, 355.45, 358.60, 356.03
1991, 05, 33373, 1991.3699, 359.34, 356.21, 358.67, 355.54, 359.34, 356.21
1991, 06, 33404, 1991.4548, 358.24, 355.88, 357.96, 355.62, 358.24, 355.88
1991, 07, 33434, 1991.5370, 356.17, 355.43, 356.40, 355.68, 356.17, 355.43
1991, 08, 33465, 1991.6219, 354.01, 355.43, 354.29, 355.74, 354.01, 355.43
1991, 09, 33496, 1991.7068, 352.15, 355.36, 352.57, 355.80, 352.15, 355.36
1991, 10, 33526, 1991.7890, 352.21, 355.54, 352.54, 355.86, 352.21, 355.54
1991, 11, 33557, 1991.8740, 353.75, 355.83, 353.86, 355.92, 353.75, 355.83
1991, 12, 33587, 1991.9562, 354.99, 355.84, 355.16, 355.99, 354.99, 355.84
1992, 01, 33618, 1992.0410, 355.99, 355.94, 356.12, 356.06, 355.99, 355.94
1992, 02, 33649, 1992.1257, 356.72, 356.02, 356.84, 356.13, 356.72, 356.02
1992, 03, 33678, 1992.2049, 357.81, 356.36, 357.66, 356.20, 357.81, 356.36
1992, 04, 33709, 1992.2896, 359.15, 356.55, 358.87, 356.26, 359.15, 356.55
1992, 05, 33739, 1992.3716, 359.66, 356.53, 359.45, 356.31, 359.66, 356.53
1992, 06, 33770, 1992.4563, 359.25, 356.91, 358.68, 356.36, 359.25, 356.91
1992, 07, 33800, 1992.5383, 357.02, 356.30, 357.08, 356.39, 357.02, 356.30
1992, 08, 33831, 1992.6230, 355.00, 356.44, 354.95, 356.43, 355.00, 356.44
1992, 09, 33862, 1992.7077, 353.01, 356.24, 353.21, 356.46, 353.01, 356.24
1992, 10, 33892, 1992.7896, 353.31, 356.64, 353.17, 356.49, 353.31, 356.64
1992, 11, 33923, 1992.8743, 354.16, 356.25, 354.46, 356.53, 354.16, 356.25
1992, 12, 33953, 1992.9563, 355.40, 356.25, 355.73, 356.57, 355.40, 356.25
1993, 01, 33984, 1993.0411, 356.70, 356.66, 356.68, 356.62, 356.70, 356.66
1993, 02, 34015, 1993.1260, 357.17, 356.46, 357.39, 356.68, 357.17, 356.46
1993, 03, 34043, 1993.2027, 358.38, 356.95, 358.18, 356.74, 358.38, 356.95
1993, 04, 34074, 1993.2877, 359.46, 356.88, 359.42, 356.82, 359.46, 356.88
1993, 05, 34104, 1993.3699, 360.28, 357.13, 360.05, 356.90, 360.28, 357.13
1993, 06, 34135, 1993.4548, 359.60, 357.22, 359.35, 356.99, 359.60, 357.22
1993, 07, 34165, 1993.5370, 357.57, 356.82, 357.81, 357.09, 357.57, 356.82
1993, 08, 34196, 1993.6219, 355.52, 356.94, 355.74, 357.20, 355.52, 356.94
1993, 09, 34227, 1993.7068, 353.69, 356.93, 354.07, 357.33, 353.69, 356.93
1993, 10, 34257, 1993.7890, 353.99, 357.34, 354.12, 357.46, 353.99, 357.34
1993, 11, 34288, 1993.8740, 355.34, 357.43, 355.54, 357.62, 355.34, 357.43
1993, 12, 34318, 1993.9562, 356.80, 357.65, 356.93, 357.77, 356.80, 357.65
1994, 01, 34349, 1994.0411, 358.37, 358.32, 358.00, 357.94, 358.37, 358.32
1994, 02, 34380, 1994.1260, 358.91, 358.21, 358.82, 358.11, 358.91, 358.21
1994, 03, 34408, 1994.2027, 359.97, 358.54, 359.71, 358.26, 359.97, 358.54
1994, 04, 34439, 1994.2877, 361.26, 358.67, 361.03, 358.43, 361.26, 358.67
1994, 05, 34469, 1994.3699, 361.69, 358.53, 361.74, 358.59, 361.69, 358.53
1994, 06, 34500, 1994.4548, 360.94, 358.56, 361.12, 358.75, 360.94, 358.56
1994, 07, 34530, 1994.5370, 359.55, 358.79, 359.64, 358.92, 359.55, 358.79
1994, 08, 34561, 1994.6219, 357.48, 358.90, 357.63, 359.09, 357.48, 358.90
1994, 09, 34592, 1994.7068, 355.84, 359.09, 356.01, 359.27, 355.84, 359.09
1994, 10, 34622, 1994.7890, 356.00, 359.36, 356.09, 359.44, 356.00, 359.36
1994, 11, 34653, 1994.8740, 357.58, 359.69, 357.55, 359.63, 357.58, 359.69
1994, 12, 34683, 1994.9562, 359.04, 359.89, 358.96, 359.81, 359.04, 359.89
1995, 01, 34714, 1995.0411, 359.97, 359.92, 360.05, 359.99, 359.97, 359.92
1995, 02, 34745, 1995.1260, 361.00, 360.30, 360.89, 360.17, 361.00, 360.30
1995, 03, 34773, 1995.2027, 361.63, 360.20, 361.78, 360.33, 361.63, 360.20
1995, 04, 34804, 1995.2877, 363.45, 360.85, 363.12, 360.50, 363.45, 360.85
1995, 05, 34834, 1995.3699, 363.80, 360.63, 363.83, 360.66, 363.80, 360.63
1995, 06, 34865, 1995.4548, 363.26, 360.87, 363.20, 360.83, 363.26, 360.87
1995, 07, 34895, 1995.5370, 361.89, 361.14, 361.71, 360.99, 361.89, 361.14
1995, 08, 34926, 1995.6219, 359.45, 360.88, 359.68, 361.15, 359.45, 360.88
1995, 09, 34957, 1995.7068, 358.05, 361.31, 358.04, 361.31, 358.05, 361.31
1995, 10, 34987, 1995.7890, 357.76, 361.13, 358.11, 361.47, 357.76, 361.13
1995, 11, 35018, 1995.8740, 359.56, 361.68, 359.54, 361.63, 359.56, 361.68
1995, 12, 35048, 1995.9562, 360.70, 361.56, 360.94, 361.78, 360.70, 361.56
1996, 01, 35079, 1996.0410, 362.05, 362.00, 361.99, 361.93, 362.05, 362.00
1996, 02, 35110, 1996.1257, 363.24, 362.54, 362.80, 362.08, 363.24, 362.54
1996, 03, 35139, 1996.2049, 364.02, 362.56, 363.69, 362.21, 364.02, 362.56
1996, 04, 35170, 1996.2896, 364.71, 362.08, 364.98, 362.33, 364.71, 362.08
1996, 05, 35200, 1996.3716, 365.42, 362.24, 365.62, 362.45, 365.42, 362.24
1996, 06, 35231, 1996.4563, 364.97, 362.60, 364.91, 362.56, 364.97, 362.60
1996, 07, 35261, 1996.5383, 363.65, 362.92, 363.35, 362.65, 363.65, 362.92
1996, 08, 35292, 1996.6230, 361.48, 362.94, 361.25, 362.75, 361.48, 362.94
1996, 09, 35323, 1996.7077, 359.45, 362.72, 359.54, 362.83, 359.45, 362.72
1996, 10, 35353, 1996.7896, 359.61, 362.98, 359.54, 362.91, 359.61, 362.98
1996, 11, 35384, 1996.8743, 360.76, 362.87, 360.90, 362.99, 360.76, 362.87
1996, 12, 35414, 1996.9563, 362.33, 363.19, 362.22, 363.06, 362.33, 363.19
1997, 01, 35445, 1997.0411, 363.19, 363.14, 363.21, 363.15, 363.19, 363.14
1997, 02, 35476, 1997.1260, 363.99, 363.28, 363.95, 363.23, 363.99, 363.28
1997, 03, 35504, 1997.2027, 364.56, 363.12, 364.78, 363.32, 364.56, 363.12
1997, 04, 35535, 1997.2877, 366.35, 363.74, 366.06, 363.42, 366.35, 363.74
1997, 05, 35565, 1997.3699, 366.80, 363.61, 366.72, 363.54, 366.80, 363.61
1997, 06, 35596, 1997.4548, 365.63, 363.22, 366.06, 363.67, 365.63, 363.22
1997, 07, 35626, 1997.5370, 364.47, 363.71, 364.55, 363.82, 364.47, 363.71
1997, 08, 35657, 1997.6219, 362.50, 363.94, 362.52, 364.00, 362.50, 363.94
1997, 09, 35688, 1997.7068, 360.19, 363.46, 360.91, 364.20, 360.19, 363.46
1997, 10, 35718, 1997.7890, 360.77, 364.17, 361.03, 364.42, 360.77, 364.17
1997, 11, 35749, 1997.8740, 362.43, 364.56, 362.56, 364.66, 362.43, 364.56
1997, 12, 35779, 1997.9562, 364.28, 365.14, 364.06, 364.91, 364.28, 365.14
1998, 01, 35810, 1998.0411, 365.33, 365.28, 365.24, 365.18, 365.33, 365.28
1998, 02, 35841, 1998.1260, 366.15, 365.44, 366.18, 365.45, 366.15, 365.44
1998, 03, 35869, 1998.2027, 367.31, 365.87, 367.17, 365.70, 367.31, 365.87
1998, 04, 35900, 1998.2877, 368.61, 365.99, 368.62, 365.98, 368.61, 365.99
1998, 05, 35930, 1998.3699, 369.30, 366.11, 369.44, 366.24, 369.30, 366.11
1998, 06, 35961, 1998.4548, 368.88, 366.46, 368.90, 366.50, 368.88, 366.46
1998, 07, 35991, 1998.5370, 367.64, 366.87, 367.48, 366.75, 367.64, 366.87
1998, 08, 36022, 1998.6219, 365.78, 367.22, 365.50, 366.98, 365.78, 367.22
1998, 09, 36053, 1998.7068, 363.90, 367.19, 363.90, 367.20, 363.90, 367.19
1998, 10, 36083, 1998.7890, 364.23, 367.64, 364.00, 367.39, 364.23, 367.64
1998, 11, 36114, 1998.8740, 365.46, 367.59, 365.46, 367.57, 365.46, 367.59
1998, 12, 36144, 1998.9562, 366.97, 367.84, 366.86, 367.71, 366.97, 367.84
1999, 01, 36175, 1999.0411, 368.15, 368.10, 367.91, 367.85, 368.15, 368.10
1999, 02, 36206, 1999.1260, 368.87, 368.16, 368.69, 367.96, 368.87, 368.16
1999, 03, 36234, 1999.2027, 369.59, 368.13, 369.51, 368.05, 369.59, 368.13
1999, 04, 36265, 1999.2877, 371.14, 368.51, 370.78, 368.13, 371.14, 368.51
1999, 05, 36295, 1999.3699, 371.00, 367.80, 371.40, 368.20, 371.00, 367.80
1999, 06, 36326, 1999.4548, 370.35, 367.93, 370.67, 368.27, 370.35, 367.93
1999, 07, 36356, 1999.5370, 369.27, 368.50, 369.06, 368.33, 369.27, 368.50
1999, 08, 36387, 1999.6219, 366.93, 368.37, 366.92, 368.40, 366.93, 368.37
1999, 09, 36418, 1999.7068, 364.64, 367.93, 365.16, 368.48, 364.64, 367.93
1999, 10, 36448, 1999.7890, 365.13, 368.54, 365.15, 368.56, 365.13, 368.54
1999, 11, 36479, 1999.8740, 366.68, 368.81, 366.53, 368.64, 366.68, 368.81
1999, 12, 36509, 1999.9562, 368.00, 368.88, 367.87, 368.73, 368.00, 368.88
2000, 01, 36540, 2000.0410, 369.14, 369.09, 368.88, 368.82, 369.14, 369.09
2000, 02, 36571, 2000.1257, 369.46, 368.75, 369.64, 368.91, 369.46, 368.75
2000, 03, 36600, 2000.2049, 370.51, 369.03, 370.51, 369.01, 370.51, 369.03
2000, 04, 36631, 2000.2896, 371.66, 369.00, 371.80, 369.12, 371.66, 369.00
2000, 05, 36661, 2000.3716, 371.83, 368.61, 372.45, 369.23, 371.83, 368.61
2000, 06, 36692, 2000.4563, 371.69, 369.29, 371.75, 369.36, 371.69, 369.29
2000, 07, 36722, 2000.5383, 370.11, 369.38, 370.20, 369.50, 370.11, 369.38
2000, 08, 36753, 2000.6230, 368.12, 369.60, 368.13, 369.64, 368.12, 369.60
2000, 09, 36784, 2000.7077, 366.62, 369.94, 366.46, 369.79, 366.62, 369.94
2000, 10, 36814, 2000.7896, 366.73, 370.15, 366.52, 369.93, 366.73, 370.15
2000, 11, 36845, 2000.8743, 368.29, 370.43, 367.96, 370.07, 368.29, 370.43
2000, 12, 36875, 2000.9563, 369.53, 370.40, 369.34, 370.20, 369.53, 370.40
2001, 01, 36906, 2001.0411, 370.28, 370.23, 370.39, 370.33, 370.28, 370.23
2001, 02, 36937, 2001.1260, 371.50, 370.78, 371.18, 370.45, 371.50, 370.78
2001, 03, 36965, 2001.2027, 372.12, 370.66, 372.03, 370.55, 372.12, 370.66
2001, 04, 36996, 2001.2877, 372.86, 370.21, 373.34, 370.67, 372.86, 370.21
2001, 05, 37026, 2001.3699, 374.02, 370.79, 374.02, 370.79, 374.02, 370.79
2001, 06, 37057, 2001.4548, 373.31, 370.87, 373.34, 370.92, 373.31, 370.87
2001, 07, 37087, 2001.5370, 371.62, 370.85, 371.79, 371.05, 371.62, 370.85
2001, 08, 37118, 2001.6219, 369.55, 371.01, 369.71, 371.20, 369.55, 371.01
2001, 09, 37149, 2001.7068, 367.96, 371.28, 368.02, 371.35, 367.96, 371.28
2001, 10, 37179, 2001.7890, 368.09, 371.53, 368.08, 371.51, 368.09, 371.53
2001, 11, 37210, 2001.8740, 369.68, 371.83, 369.54, 371.67, 369.68, 371.83
2001, 12, 37240, 2001.9562, 371.24, 372.11, 370.97, 371.83, 371.24, 372.11
2002, 01, 37271, 2002.0411, 372.44, 372.39, 372.06, 372.00, 372.44, 372.39
2002, 02, 37302, 2002.1260, 373.08, 372.36, 372.91, 372.17, 373.08, 372.36
2002, 03, 37330, 2002.2027, 373.52, 372.05, 373.82, 372.33, 373.52, 372.05
2002, 04, 37361, 2002.2877, 374.85, 372.20, 375.19, 372.52, 374.85, 372.20
2002, 05, 37391, 2002.3699, 375.55, 372.31, 375.95, 372.71, 375.55, 372.31
2002, 06, 37422, 2002.4548, 375.40, 372.96, 375.35, 372.92, 375.40, 372.96
2002, 07, 37452, 2002.5370, 374.02, 373.25, 373.87, 373.14, 374.02, 373.25
2002, 08, 37483, 2002.6219, 371.48, 372.94, 371.86, 373.36, 371.48, 372.94
2002, 09, 37514, 2002.7068, 370.70, 374.03, 370.25, 373.60, 370.70, 374.03
2002, 10, 37544, 2002.7890, 370.25, 373.69, 370.39, 373.82, 370.25, 373.69
2002, 11, 37575, 2002.8740, 372.08, 374.24, 371.92, 374.06, 372.08, 374.24
2002, 12, 37605, 2002.9562, 373.78, 374.66, 373.42, 374.28, 373.78, 374.66
2003, 01, 37636, 2003.0411, 374.68, 374.63, 374.57, 374.50, 374.68, 374.63
2003, 02, 37667, 2003.1260, 375.62, 374.90, 375.46, 374.72, 375.62, 374.90
2003, 03, 37695, 2003.2027, 376.11, 374.64, 376.40, 374.92, 376.11, 374.64
2003, 04, 37726, 2003.2877, 377.65, 374.99, 377.81, 375.13, 377.65, 374.99
2003, 05, 37756, 2003.3699, 378.35, 375.11, 378.57, 375.33, 378.35, 375.11
2003, 06, 37787, 2003.4548, 378.13, 375.68, 377.96, 375.53, 378.13, 375.68
2003, 07, 37817, 2003.5370, 376.60, 375.83, 376.47, 375.72, 376.60, 375.83
2003, 08, 37848, 2003.6219, 374.48, 375.95, 374.41, 375.92, 374.48, 375.95
2003, 09, 37879, 2003.7068, 372.98, 376.31, 372.74, 376.10, 372.98, 376.31
2003, 10, 37909, 2003.7890, 373.00, 376.45, 372.82, 376.26, 373.00, 376.45
2003, 11, 37940, 2003.8740, 374.35, 376.51, 374.28, 376.42, 374.35, 376.51
2003, 12, 37970, 2003.9562, 375.69, 376.57, 375.70, 376.57, 375.69, 376.57
2004, 01, 38001, 2004.0410, 376.79, 376.74, 376.77, 376.71, 376.79, 376.74
2004, 02, 38032, 2004.1257, 377.37, 376.64, 377.57, 376.84, 377.37, 376.64
2004, 03, 38061, 2004.2049, 378.39, 376.89, 378.47, 376.96, 378.39, 376.89
2004, 04, 38092, 2004.2896, 380.50, 377.80, 379.79, 377.08, 380.50, 377.80
2004, 05, 38122, 2004.3716, 380.62, 377.36, 380.44, 377.19, 380.62, 377.36
2004, 06, 38153, 2004.4563, 379.55, 377.12, 379.72, 377.31, 379.55, 377.12
2004, 07, 38183, 2004.5383, 377.76, 377.02, 378.14, 377.43, 377.76, 377.02
2004, 08, 38214, 2004.6230, 375.83, 377.33, 376.03, 377.56, 375.83, 377.33
2004, 09, 38245, 2004.7077, 374.05, 377.40, 374.34, 377.71, 374.05, 377.40
2004, 10, 38275, 2004.7896, 374.22, 377.68, 374.43, 377.87, 374.22, 377.68
2004, 11, 38306, 2004.8743, 375.84, 378.01, 375.92, 378.06, 375.84, 378.01
2004, 12, 38336, 2004.9563, 377.44, 378.33, 377.38, 378.24, 377.44, 378.33
2005, 01, 38367, 2005.0411, 378.34, 378.29, 378.51, 378.45, 378.34, 378.29
2005, 02, 38398, 2005.1260, 379.61, 378.88, 379.40, 378.66, 379.61, 378.88
2005, 03, 38426, 2005.2027, 380.09, 378.61, 380.35, 378.85, 380.09, 378.61
2005, 04, 38457, 2005.2877, 382.05, 379.37, 381.77, 379.07, 382.05, 379.37
2005, 05, 38487, 2005.3699, 382.24, 378.97, 382.55, 379.29, 382.24, 378.97
2005, 06, 38518, 2005.4548, 382.08, 379.61, 381.95, 379.51, 382.08, 379.61
2005, 07, 38548, 2005.5370, 380.66, 379.88, 380.46, 379.72, 380.66, 379.88
2005, 08, 38579, 2005.6219, 378.67, 380.14, 378.42, 379.93, 378.67, 380.14
2005, 09, 38610, 2005.7068, 376.42, 379.78, 376.77, 380.14, 376.42, 379.78
2005, 10, 38640, 2005.7890, 376.80, 380.28, 376.88, 380.34, 376.80, 380.28
2005, 11, 38671, 2005.8740, 378.31, 380.48, 378.39, 380.54, 378.31, 380.48
2005, 12, 38701, 2005.9562, 379.96, 380.85, 379.86, 380.73, 379.96, 380.85
2006, 01, 38732, 2006.0411, 381.37, 381.32, 380.97, 380.91, 381.37, 381.32
2006, 02, 38763, 2006.1260, 382.02, 381.29, 381.82, 381.08, 382.02, 381.29
2006, 03, 38791, 2006.2027, 382.56, 381.08, 382.73, 381.23, 382.56, 381.08
2006, 04, 38822, 2006.2877, 384.36, 381.68, 384.09, 381.39, 384.36, 381.68
2006, 05, 38852, 2006.3699, 384.92, 381.65, 384.81, 381.53, 384.92, 381.65
2006, 06, 38883, 2006.4548, 384.03, 381.55, 384.13, 381.68, 384.03, 381.55
2006, 07, 38913, 2006.5370, 382.28, 381.50, 382.57, 381.82, 382.28, 381.50
2006, 08, 38944, 2006.6219, 380.48, 381.95, 380.45, 381.97, 380.48, 381.95
2006, 09, 38975, 2006.7068, 378.81, 382.17, 378.73, 382.12, 378.81, 382.17
2006, 10, 39005, 2006.7890, 379.06, 382.55, 378.79, 382.26, 379.06, 382.55
2006, 11, 39036, 2006.8740, 380.14, 382.32, 380.25, 382.41, 380.14, 382.32
2006, 12, 39066, 2006.9562, 381.66, 382.55, 381.69, 382.56, 381.66, 382.55
2007, 01, 39097, 2007.0411, 382.58, 382.53, 382.77, 382.71, 382.58, 382.53
2007, 02, 39128, 2007.1260, 383.71, 382.98, 383.61, 382.87, 383.71, 382.98
2007, 03, 39156, 2007.2027, 384.34, 382.85, 384.51, 383.01, 384.34, 382.85
2007, 04, 39187, 2007.2877, 386.23, 383.53, 385.88, 383.17, 386.23, 383.53
2007, 05, 39217, 2007.3699, 386.41, 383.13, 386.61, 383.32, 386.41, 383.13
2007, 06, 39248, 2007.4548, 385.87, 383.39, 385.95, 383.49, 385.87, 383.39
2007, 07, 39278, 2007.5370, 384.44, 383.66, 384.39, 383.64, 384.44, 383.66
2007, 08, 39309, 2007.6219, 381.84, 383.33, 382.29, 383.81, 381.84, 383.33
2007, 09, 39340, 2007.7068, 380.86, 384.24, 380.58, 383.97, 380.86, 384.24
2007, 10, 39370, 2007.7890, 380.86, 384.36, 380.64, 384.13, 380.86, 384.36
2007, 11, 39401, 2007.8740, 382.36, 384.54, 382.12, 384.29, 382.36, 384.54
2007, 12, 39431, 2007.9562, 383.61, 384.50, 383.56, 384.43, 383.61, 384.50
2008, 01, 39462, 2008.0410, 385.07, 385.02, 384.64, 384.58, 385.07, 385.02
2008, 02, 39493, 2008.1257, 385.84, 385.11, 385.47, 384.73, 385.84, 385.11
2008, 03, 39522, 2008.2049, 385.83, 384.31, 386.40, 384.86, 385.83, 384.31
2008, 04, 39553, 2008.2896, 386.77, 384.04, 387.76, 385.02, 386.77, 384.04
2008, 05, 39583, 2008.3716, 388.51, 385.22, 388.47, 385.17, 388.51, 385.22
2008, 06, 39614, 2008.4563, 388.05, 385.59, 387.78, 385.34, 388.05, 385.59
2008, 07, 39644, 2008.5383, 386.25, 385.50, 386.23, 385.51, 386.25, 385.50
2008, 08, 39675, 2008.6230, 384.08, 385.60, 384.12, 385.68, 384.08, 385.60
2008, 09, 39706, 2008.7077, 383.09, 386.48, 382.43, 385.84, 383.09, 386.48
2008, 10, 39736, 2008.7896, 382.78, 386.28, 382.51, 386.00, 382.78, 386.28
2008, 11, 39767, 2008.8743, 384.01, 386.20, 383.99, 386.16, 384.01, 386.20
2008, 12, 39797, 2008.9563, 385.11, 386.00, 385.43, 386.31, 385.11, 386.00
2009, 01, 39828, 2009.0411, 386.65, 386.61, 386.53, 386.46, 386.65, 386.61
2009, 02, 39859, 2009.1260, 387.12, 386.39, 387.37, 386.62, 387.12, 386.39
2009, 03, 39887, 2009.2027, 388.52, 387.02, 388.28, 386.77, 388.52, 387.02
2009, 04, 39918, 2009.2877, 389.57, 386.86, 389.66, 386.93, 389.57, 386.86
2009, 05, 39948, 2009.3699, 390.17, 386.86, 390.40, 387.10, 390.17, 386.86
2009, 06, 39979, 2009.4548, 389.62, 387.12, 389.75, 387.28, 389.62, 387.12
2009, 07, 40009, 2009.5370, 388.07, 387.28, 388.22, 387.46, 388.07, 387.28
2009, 08, 40040, 2009.6219, 386.08, 387.57, 386.14, 387.67, 386.08, 387.57
2009, 09, 40071, 2009.7068, 384.65, 388.05, 384.46, 387.88, 384.65, 388.05
2009, 10, 40101, 2009.7890, 384.33, 387.85, 384.58, 388.09, 384.33, 387.85
2009, 11, 40132, 2009.8740, 386.05, 388.25, 386.13, 388.31, 386.05, 388.25
2009, 12, 40162, 2009.9562, 387.49, 388.38, 387.65, 388.53, 387.49, 388.38
2010, 01, 40193, 2010.0411, 388.55, 388.50, 388.82, 388.76, 388.55, 388.50
2010, 02, 40224, 2010.1260, 390.08, 389.34, 389.73, 388.98, 390.08, 389.34
2010, 03, 40252, 2010.2027, 391.01, 389.51, 390.70, 389.18, 391.01, 389.51
2010, 04, 40283, 2010.2877, 392.38, 389.66, 392.12, 389.39, 392.38, 389.66
2010, 05, 40313, 2010.3699, 393.22, 389.90, 392.89, 389.58, 393.22, 389.90
2010, 06, 40344, 2010.4548, 392.24, 389.73, 392.24, 389.76, 392.24, 389.73
2010, 07, 40374, 2010.5370, 390.33, 389.54, 390.69, 389.93, 390.33, 389.54
2010, 08, 40405, 2010.6219, 388.52, 390.02, 388.57, 390.10, 388.52, 390.02
2010, 09, 40436, 2010.7068, 386.84, 390.25, 386.84, 390.27, 386.84, 390.25
2010, 10, 40466, 2010.7890, 387.16, 390.69, 386.91, 390.42, 387.16, 390.69
2010, 11, 40497, 2010.8740, 388.67, 390.88, 388.39, 390.57, 388.67, 390.88
2010, 12, 40527, 2010.9562, 389.81, 390.71, 389.83, 390.71, 389.81, 390.71
2011, 01, 40558, 2011.0411, 391.30, 391.25, 390.90, 390.84, 391.30, 391.25
2011, 02, 40589, 2011.1260, 391.92, 391.18, 391.72, 390.97, 391.92, 391.18
2011, 03, 40617, 2011.2027, 392.45, 390.95, 392.61, 391.09, 392.45, 390.95
2011, 04, 40648, 2011.2877, 393.37, 390.64, 393.97, 391.22, 393.37, 390.64
2011, 05, 40678, 2011.3699, 394.28, 390.96, 394.69, 391.36, 394.28, 390.96
2011, 06, 40709, 2011.4548, 393.69, 391.18, 394.01, 391.52, 393.69, 391.18
2011, 07, 40739, 2011.5370, 392.59, 391.80, 392.45, 391.69, 392.59, 391.80
2011, 08, 40770, 2011.6219, 390.21, 391.71, 390.32, 391.86, 390.21, 391.71
2011, 09, 40801, 2011.7068, 389.00, 392.42, 388.61, 392.04, 389.00, 392.42
2011, 10, 40831, 2011.7890, 388.93, 392.47, 388.69, 392.22, 388.93, 392.47
2011, 11, 40862, 2011.8740, 390.24, 392.46, 390.21, 392.40, 390.24, 392.46
2011, 12, 40892, 2011.9562, 391.80, 392.71, 391.70, 392.58, 391.80, 392.71
2012, 01, 40923, 2012.0410, 393.07, 393.02, 392.83, 392.77, 393.07, 393.02
2012, 02, 40954, 2012.1257, 393.35, 392.61, 393.70, 392.95, 393.35, 392.61
2012, 03, 40983, 2012.2049, 394.36, 392.82, 394.69, 393.13, 394.36, 392.82
2012, 04, 41014, 2012.2896, 396.43, 393.67, 396.12, 393.34, 396.43, 393.67
2012, 05, 41044, 2012.3716, 396.87, 393.53, 396.87, 393.54, 396.87, 393.53
2012, 06, 41075, 2012.4563, 395.88, 393.38, 396.23, 393.75, 395.88, 393.38
2012, 07, 41105, 2012.5383, 394.52, 393.76, 394.70, 393.97, 394.52, 393.76
2012, 08, 41136, 2012.6230, 392.54, 394.07, 392.64, 394.21, 392.54, 394.07
2012, 09, 41167, 2012.7077, 391.13, 394.57, 390.99, 394.45, 391.13, 394.57
2012, 10, 41197, 2012.7896, 391.01, 394.56, 391.16, 394.69, 391.01, 394.56
2012, 11, 41228, 2012.8743, 392.95, 395.17, 392.74, 394.93, 392.95, 395.17
2012, 12, 41258, 2012.9563, 394.33, 395.24, 394.27, 395.16, 394.33, 395.24
2013, 01, 41289, 2013.0411, 395.61, 395.55, 395.46, 395.39, 395.61, 395.55
2013, 02, 41320, 2013.1260, 396.85, 396.10, 396.38, 395.62, 396.85, 396.10
2013, 03, 41348, 2013.2027, 397.26, 395.74, 397.35, 395.82, 397.26, 395.74
2013, 04, 41379, 2013.2877, 398.35, 395.61, 398.79, 396.03, 398.35, 395.61
2013, 05, 41409, 2013.3699, 399.98, 396.63, 399.58, 396.23, 399.98, 396.63
2013, 06, 41440, 2013.4548, 398.87, 396.34, 398.94, 396.44, 398.87, 396.34
2013, 07, 41470, 2013.5370, 397.37, 396.57, 397.39, 396.63, 397.37, 396.57
2013, 08, 41501, 2013.6219, 395.41, 396.92, 395.27, 396.82, 395.41, 396.92
2013, 09, 41532, 2013.7068, 393.39, 396.83, 393.55, 397.01, 393.39, 396.83
2013, 10, 41562, 2013.7890, 393.70, 397.26, 393.64, 397.19, 393.70, 397.26
2013, 11, 41593, 2013.8740, 395.19, 397.42, 395.17, 397.37, 395.19, 397.42
2013, 12, 41623, 2013.9562, 396.82, 397.73, 396.65, 397.54, 396.82, 397.73
2014, 01, 41654, 2014.0411, 397.93, 397.87, 397.77, 397.71, 397.93, 397.87
2014, 02, 41685, 2014.1260, 398.10, 397.35, 398.64, 397.88, 398.10, 397.35
2014, 03, 41713, 2014.2027, 399.47, 397.95, 399.57, 398.03, 399.47, 397.95
2014, 04, 41744, 2014.2877, 401.33, 398.57, 400.97, 398.20, 401.33, 398.57
2014, 05, 41774, 2014.3699, 401.88, 398.53, 401.71, 398.35, 401.88, 398.53
2014, 06, 41805, 2014.4548, 401.31, 398.77, 401.03, 398.51, 401.31, 398.77
2014, 07, 41835, 2014.5370, 399.07, 398.27, 399.44, 398.67, 399.07, 398.27
2014, 08, 41866, 2014.6219, 397.21, 398.72, 397.28, 398.83, 397.21, 398.72
2014, 09, 41897, 2014.7068, 395.40, 398.85, 395.53, 399.00, 395.40, 398.85
2014, 10, 41927, 2014.7890, 395.65, 399.22, 395.61, 399.17, 395.65, 399.22
2014, 11, 41958, 2014.8740, 397.23, 399.46, 397.13, 399.34, 397.23, 399.46
2014, 12, 41988, 2014.9562, 398.79, 399.70, 398.62, 399.51, 398.79, 399.70
2015, 01, 42019, 2015.0411, 399.85, 399.80, 399.76, 399.70, 399.85, 399.80
2015, 02, 42050, 2015.1260, 400.31, 399.56, 400.65, 399.89, 400.31, 399.56
2015, 03, 42078, 2015.2027, 401.51, 399.99, 401.61, 400.07, 401.51, 399.99
2015, 04, 42109, 2015.2877, 403.45, 400.69, 403.06, 400.28, 403.45, 400.69
2015, 05, 42139, 2015.3699, 404.10, 400.74, 403.85, 400.49, 404.10, 400.74
2015, 06, 42170, 2015.4548, 402.88, 400.33, 403.25, 400.73, 402.88, 400.33
2015, 07, 42200, 2015.5370, 401.61, 400.81, 401.74, 400.97, 401.61, 400.81
2015, 08, 42231, 2015.6219, 399.00, 400.52, 399.69, 401.25, 399.00, 400.52
2015, 09, 42262, 2015.7068, 397.50, 400.95, 398.07, 401.54, 397.50, 400.95
2015, 10, 42292, 2015.7890, 398.28, 401.87, 398.28, 401.85, 398.28, 401.87
2015, 11, 42323, 2015.8740, 400.24, 402.48, 399.95, 402.17, 400.24, 402.48
2015, 12, 42353, 2015.9562, 401.89, 402.81, 401.59, 402.48, 401.89, 402.81
2016, 01, 42384, 2016.0410, 402.65, 402.60, 402.86, 402.80, 402.65, 402.60
2016, 02, 42415, 2016.1257, 404.16, 403.41, 403.87, 403.11, 404.16, 403.41
2016, 03, 42444, 2016.2049, 404.85, 403.30, 404.96, 403.39, 404.85, 403.30
2016, 04, 42475, 2016.2896, 407.57, 404.77, 406.48, 403.67, 407.57, 404.77
2016, 05, 42505, 2016.3716, 407.66, 404.28, 407.29, 403.92, 407.66, 404.28
2016, 06, 42536, 2016.4563, 407.00, 404.48, 406.66, 404.16, 407.00, 404.48
2016, 07, 42566, 2016.5383, 404.50, 403.73, 405.12, 404.38, 404.50, 403.73
2016, 08, 42597, 2016.6230, 402.24, 403.79, 403.01, 404.60, 402.24, 403.79
2016, 09, 42628, 2016.7077, 401.01, 404.49, 401.32, 404.82, 401.01, 404.49
2016, 10, 42658, 2016.7896, 401.50, 405.09, 401.46, 405.03, 401.50, 405.09
2016, 11, 42689, 2016.8743, 403.64, 405.88, 403.02, 405.24, 403.64, 405.88
2016, 12, 42719, 2016.9563, 404.55, 405.47, 404.54, 405.44, 404.55, 405.47
2017, 01, 42750, 2017.0411, 406.07, 406.02, 405.69, 405.63, 406.07, 406.02
2017, 02, 42781, 2017.1260, 406.64, 405.89, 406.57, 405.81, 406.64, 405.89
2017, 03, 42809, 2017.2027, 407.06, 405.52, 407.51, 405.96, 407.06, 405.52
2017, 04, 42840, 2017.2877, 408.95, 406.17, 408.93, 406.13, 408.95, 406.17
2017, 05, 42870, 2017.3699, 409.91, 406.52, 409.67, 406.29, 409.91, 406.52
2017, 06, 42901, 2017.4548, 409.12, 406.56, 408.98, 406.45, 409.12, 406.56
2017, 07, 42931, 2017.5370, 407.20, 406.39, 407.38, 406.60, 407.20, 406.39
2017, 08, 42962, 2017.6219, 405.24, 406.77, 405.19, 406.76, 405.24, 406.77
2017, 09, 42993, 2017.7068, 403.27, 406.75, 403.42, 406.91, 403.27, 406.75
2017, 10, 43023, 2017.7890, 403.64, 407.24, 403.47, 407.06, 403.64, 407.24
2017, 11, 43054, 2017.8740, 405.17, 407.43, 404.99, 407.22, 405.17, 407.43
2017, 12, 43084, 2017.9562, 406.75, 407.67, 406.46, 407.36, 406.75, 407.67
2018, 01, 43115, 2018.0411, 408.05, 408.00, 407.58, 407.52, 408.05, 408.00
2018, 02, 43146, 2018.1260, 408.34, 407.59, 408.44, 407.67, 408.34, 407.59
2018, 03, 43174, 2018.2027, 409.25, 407.72, 409.38, 407.82, 409.25, 407.72
2018, 04, 43205, 2018.2877, 410.30, 407.52, 410.81, 408.00, 410.30, 407.52
2018, 05, 43235, 2018.3699, 411.30, 407.91, 411.59, 408.20, 411.30, 407.91
2018, 06, 43266, 2018.4548, 410.88, 408.31, 410.96, 408.42, 410.88, 408.31
2018, 07, 43296, 2018.5370, 408.90, 408.09, 409.42, 408.65, 408.90, 408.09
2018, 08, 43327, 2018.6219, 407.10, 408.63, 407.34, 408.91, 407.10, 408.63
2018, 09, 43358, 2018.7068, 405.59, 409.08, 405.67, 409.18, 405.59, 409.08
2018, 10, 43388, 2018.7890, 405.99, 409.61, 405.85, 409.45, 405.99, 409.61
2018, 11, 43419, 2018.8740, 408.12, 410.38, 407.49, 409.72, 408.12, 410.38
2018, 12, 43449, 2018.9562, 409.23, 410.15, 409.08, 409.98, 409.23, 410.15
2019, 01, 43480, 2019.0411, 410.92, 410.87, 410.31, 410.24, 410.92, 410.87
2019, 02, 43511, 2019.1260, 411.66, 410.90, 411.26, 410.48, 411.66, 410.90
2019, 03, 43539, 2019.2027, 412.00, 410.46, 412.25, 410.70, 412.00, 410.46
2019, 04, 43570, 2019.2877, 413.52, 410.73, 413.73, 410.92, 413.52, 410.73
2019, 05, 43600, 2019.3699, 414.83, 411.43, 414.54, 411.14, 414.83, 411.43
2019, 06, 43631, 2019.4548, 413.96, 411.39, 413.91, 411.36, 413.96, 411.39
2019, 07, 43661, 2019.5370, 411.85, 411.04, 412.34, 411.57, 411.85, 411.04
2019, 08, 43692, 2019.6219, 410.08, 411.62, 410.21, 411.79, 410.08, 411.62
2019, 09, 43723, 2019.7068, 408.55, 412.05, 408.49, 412.01, 408.55, 412.05
2019, 10, 43753, 2019.7890, 408.43, 412.06, 408.61, 412.22, 408.43, 412.06
2019, 11, 43784, 2019.8740, 410.29, 412.55, 410.20, 412.44, 410.29, 412.55
2019, 12, 43814, 2019.9562, 411.85, 412.78, 411.74, 412.65, 411.85, 412.78
2020, 01, 43845, 2020.0410, 413.37, 413.32, 412.92, 412.86, 413.37, 413.32
2020, 02, 43876, 2020.1257, 414.09, 413.33, 413.84, 413.07, 414.09, 413.33
2020, 03, 43905, 2020.2049, 414.51, 412.94, 414.85, 413.26, 414.51, 412.94
2020, 04, 43936, 2020.2896, 416.18, 413.35, 416.31, 413.47, 416.18, 413.35
2020, 05, 43966, 2020.3716, 417.16, 413.75, 417.08, 413.67, 417.16, 413.75
2020, 06, 43997, 2020.4563, 416.30, 413.75, 416.42, 413.89, 416.30, 413.75
2020, 07, 44027, 2020.5383, 414.49, 413.71, 414.85, 414.10, 414.49, 413.71
2020, 08, 44058, 2020.6230, 412.59, 414.16, 412.72, 414.33, 412.59, 414.16
2020, 09, 44089, 2020.7077, 411.25, 414.77, 411.03, 414.57, 411.25, 414.77
2020, 10, 44119, 2020.7896, 411.22, 414.85, 411.18, 414.80, 411.22, 414.85
2020, 11, 44150, 2020.8743, 412.95, 415.21, -99.99, -99.99, 412.95, 415.21
2020, 12, 44180, 2020.9563, -99.99, -99.99, -99.99, -99.99, -99.99, -99.99
" Please cite as: "
" New York, 2005. "
" The data file below contains 2 columns indicaing the date and CO2 "
" concentrations in micro-mol CO2 per mole (ppm), reported on the 2008A "
" SIO manometric mole fraction scale. These weekly values have been "
" adjusted to 12:00 hours at middle day of each weekly period as "
" indicated by the date in the first column. "
1958-03-29, 316.19
1958-04-05, 317.31
1958-04-12, 317.69
1958-04-19, 317.58
1958-04-26, 316.48
1958-05-03, 316.95
1958-05-17, 317.56
1958-05-24, 317.99
1958-07-05, 315.85
1958-07-12, 315.85
1958-07-19, 315.46
1958-07-26, 315.59
1958-08-02, 315.64
1958-08-09, 315.10
1958-08-16, 315.09
1958-08-30, 314.14
1958-09-06, 313.54
1958-11-08, 313.05
1958-11-15, 313.26
1958-11-22, 313.57
1958-11-29, 314.01
1958-12-06, 314.56
1958-12-13, 314.41
1958-12-20, 314.77
1958-12-27, 315.21
1959-01-03, 315.24
1959-01-10, 315.50
1959-01-17, 315.69
1959-01-24, 315.86
1959-01-31, 315.42
1959-02-14, 316.94
1959-02-21, 316.61
1959-02-28, 316.62
1959-03-07, 316.81
1959-03-21, 316.73
1959-03-28, 316.71
1959-04-04, 317.72
1959-04-11, 317.12
1959-04-18, 317.64
1959-04-25, 318.32
1959-05-02, 318.27
1959-05-09, 318.78
1959-05-16, 318.05
1959-05-23, 318.43
1959-06-06, 318.53
1959-06-13, 318.14
1959-06-20, 317.88
1959-06-27, 317.76
1959-07-04, 316.86
1959-07-11, 316.83
1959-07-18, 316.45
1959-07-25, 316.16
1959-08-01, 315.62
1959-08-08, 314.91
1959-08-22, 315.00
1959-08-29, 314.15
1959-09-05, 314.45
1959-09-12, 313.93
1959-09-19, 313.57
1959-09-26, 313.54
1959-10-03, 313.04
1959-10-10, 313.15
1959-10-17, 313.43
1959-10-24, 313.46
1959-10-31, 314.12
1959-11-07, 314.42
1959-11-14, 314.88
1959-11-21, 315.20
1959-11-28, 315.11
1959-12-05, 315.06
1959-12-12, 315.64
1959-12-19, 315.86
1959-12-26, 315.77
1960-01-02, 315.72
1960-01-09, 316.40
1960-01-16, 316.73
1960-01-23, 316.57
1960-01-30, 316.68
1960-02-06, 316.61
1960-02-13, 316.98
1960-02-20, 317.42
1960-02-27, 317.00
1960-03-05, 316.96
1960-03-12, 317.76
1960-03-19, 318.07
1960-03-26, 317.77
1960-04-02, 318.61
1960-04-09, 319.34
1960-04-16, 319.01
1960-04-23, 319.03
1960-04-30, 319.77
1960-05-07, 319.96
1960-05-14, 319.82
1960-05-21, 320.04
1960-05-28, 320.06
1960-06-04, 319.46
1960-06-11, 320.08
1960-06-18, 319.42
1960-06-25, 319.09
1960-07-02, 318.18
1960-07-09, 318.64
1960-07-16, 318.41
1960-07-23, 317.91
1960-07-30, 317.33
1960-08-06, 316.62
1960-08-13, 316.70
1960-08-20, 315.10
1960-08-27, 314.78
1960-09-03, 314.72
1960-09-10, 314.58
1960-09-17, 314.28
1960-09-24, 313.33
1960-10-01, 313.66
1960-10-08, 313.32
1960-10-15, 313.92
1960-10-22, 314.21
1960-10-29, 314.29
1960-11-05, 314.50
1960-11-12, 315.10
1960-11-19, 315.10
1960-11-26, 315.41
1960-12-03, 315.84
1960-12-10, 316.07
1960-12-17, 316.21
1960-12-24, 316.40
1960-12-31, 316.67
1961-01-07, 316.73
1961-01-14, 317.02
1961-01-21, 317.03
1961-01-28, 317.01
1961-02-04, 317.06
1961-02-11, 317.75
1961-02-18, 317.94
1961-02-25, 318.00
1961-03-04, 318.04
1961-03-11, 318.51
1961-03-18, 318.92
1961-03-25, 318.71
1961-04-01, 319.41
1961-04-08, 319.55
1961-04-15, 318.90
1961-04-22, 319.74
1961-04-29, 319.67
1961-05-06, 320.67
1961-05-13, 320.46
1961-05-20, 320.61
1961-05-27, 320.36
1961-06-03, 320.09
1961-06-10, 320.02
1961-06-17, 319.62
1961-06-24, 319.49
1961-07-01, 319.26
1961-07-08, 319.07
1961-07-15, 318.49
1961-07-22, 317.16
1961-07-29, 317.97
1961-08-05, 317.91
1961-08-12, 317.33
1961-08-19, 316.76
1961-08-26, 315.26
1961-09-02, 315.28
1961-09-09, 314.97
1961-09-16, 314.53
1961-09-23, 315.06
1961-09-30, 315.61
1961-10-07, 314.97
1961-10-14, 315.43
1961-10-21, 315.48
1961-10-28, 315.72
1961-11-04, 315.82
1961-11-11, 315.70
1961-11-18, 316.21
1961-11-25, 316.55
1961-12-02, 316.52
1961-12-09, 317.02
1961-12-16, 316.94
1961-12-23, 317.18
1961-12-30, 317.46
1962-01-06, 317.99
1962-01-13, 318.12
1962-01-20, 318.07
1962-01-27, 317.78
1962-02-03, 318.08
1962-02-10, 318.35
1962-02-17, 318.92
1962-02-24, 319.38
1962-03-03, 319.28
1962-03-10, 319.46
1962-03-17, 319.95
1962-03-24, 319.78
1962-03-31, 320.27
1962-04-07, 320.26
1962-04-14, 321.03
1962-04-21, 320.78
1962-04-28, 320.36
1962-05-05, 320.89
1962-05-12, 320.78
1962-05-19, 321.05
1962-05-26, 321.16
1962-06-02, 320.91
1962-06-09, 320.87
1962-06-16, 320.52
1962-06-23, 320.15
1962-06-30, 320.23
1962-07-07, 320.10
1962-07-14, 319.95
1962-07-21, 319.01
1962-07-28, 318.75
1962-08-04, 318.68
1962-08-11, 317.24
1962-08-18, 317.48
1962-09-15, 316.65
1962-09-22, 315.72
1962-09-29, 315.92
1962-10-06, 315.10
1962-10-13, 315.40
1962-10-20, 315.72
1962-10-27, 315.78
1962-11-03, 315.94
1962-11-10, 316.49
1962-11-17, 316.92
1962-11-24, 317.08
1962-12-01, 317.19
1962-12-08, 317.31
1962-12-15, 317.66
1962-12-22, 318.18
1963-01-05, 318.54
1963-01-12, 318.73
1963-01-19, 318.90
1963-01-26, 318.82
1963-02-02, 318.77
1963-02-09, 318.95
1963-02-23, 319.37
1963-03-02, 319.35
1963-03-09, 319.70
1963-03-16, 319.80
1963-03-23, 320.34
1963-03-30, 320.29
1963-04-06, 320.38
1963-04-13, 320.96
1963-04-20, 322.05
1963-04-27, 321.92
1963-05-11, 321.97
1963-05-18, 322.28
1963-05-25, 322.27
1963-06-01, 322.32
1963-06-08, 322.09
1963-06-15, 321.83
1963-06-22, 320.88
1963-06-29, 320.49
1963-07-06, 320.12
1963-07-13, 319.82
1963-07-20, 319.56
1963-07-27, 319.06
1963-08-03, 318.60
1963-08-10, 318.27
1963-08-17, 317.73
1963-08-24, 317.12
1963-08-31, 316.44
1963-09-07, 316.81
1963-09-14, 315.99
1963-09-21, 316.03
1963-09-28, 315.93
1963-10-05, 316.28
1963-10-12, 315.65
1963-10-19, 316.14
1963-10-26, 316.36
1963-11-02, 316.63
1963-11-09, 316.83
1963-11-16, 317.13
1963-11-30, 317.56
1963-12-07, 318.07
1963-12-14, 318.27
1963-12-21, 318.59
1963-12-28, 318.74
1964-01-04, 319.04
1964-01-11, 319.49
1964-01-18, 319.88
1964-05-30, 322.07
1964-06-06, 322.06
1964-06-27, 321.57
1964-07-04, 321.14
1964-07-11, 319.95
1964-07-18, 320.28
1964-07-25, 320.02
1964-08-01, 319.14
1964-08-15, 318.61
1964-08-22, 318.23
1964-08-29, 318.11
1964-09-05, 317.48
1964-09-12, 316.57
1964-09-19, 315.59
1964-09-26, 317.01
1964-10-03, 316.93
1964-10-10, 316.51
1964-10-17, 316.86
1964-10-24, 317.05
1964-10-31, 317.65
1964-11-07, 317.77
1964-11-14, 317.65
1964-11-21, 317.52
1964-11-28, 318.11
1964-12-05, 318.42
1964-12-12, 318.58
1964-12-19, 318.93
1964-12-26, 318.91
1965-01-02, 319.08
1965-01-09, 319.17
1965-01-16, 319.16
1965-01-23, 319.79
1965-01-30, 320.12
1965-02-06, 320.20
1965-02-13, 320.16
1965-02-20, 320.70
1965-02-27, 320.89
1965-03-06, 321.07
1965-03-13, 320.98
1965-03-20, 320.49
1965-03-27, 321.40
1965-04-03, 321.95
1965-04-10, 322.27
1965-04-17, 322.17
1965-04-24, 321.86
1965-05-01, 322.46
1965-05-08, 322.22
1965-05-15, 321.94
1965-05-22, 321.69
1965-05-29, 322.26
1965-06-05, 321.87
1965-06-12, 321.77
1965-06-19, 321.77
1965-06-26, 321.99
1965-07-03, 321.97
1965-07-10, 321.85
1965-07-17, 321.76
1965-07-24, 320.47
1965-07-31, 319.49
1965-08-07, 319.47
1965-08-14, 318.02
1965-08-21, 318.82
1965-08-28, 318.73
1965-09-04, 318.39
1965-09-11, 318.05
1965-09-18, 318.26
1965-09-25, 316.85
1965-10-02, 316.60
1965-10-09, 317.26
1965-10-16, 317.86
1965-10-23, 317.56
1965-10-30, 317.63
1965-11-06, 318.30
1965-11-13, 319.26
1965-11-20, 318.99
1965-11-27, 319.17
1965-12-04, 319.09
1965-12-11, 319.37
1965-12-18, 319.39
1965-12-25, 319.70
1966-01-01, 319.69
1966-01-08, 320.49
1966-01-15, 320.63
1966-01-22, 321.09
1966-01-29, 321.16
1966-02-05, 321.26
1966-02-12, 321.75
1966-02-19, 321.67
1966-02-26, 321.80
1966-03-05, 322.10
1966-03-12, 322.14
1966-03-19, 322.57
1966-03-26, 322.86
1966-04-02, 323.55
1966-04-09, 323.62
1966-04-16, 323.88
1966-04-23, 323.91
1966-04-30, 323.53
1966-05-07, 324.00
1966-05-14, 324.10
1966-05-21, 323.72
1966-05-28, 324.31
1966-06-04, 324.02
1966-06-11, 323.88
1966-06-18, 323.75
1966-06-25, 323.32
1966-07-02, 322.82
1966-07-09, 322.90
1966-08-06, 321.31
1966-08-13, 320.85
1966-08-20, 319.16
1966-08-27, 319.64
1966-09-03, 319.94
1966-09-10, 318.22
1966-09-17, 318.46
1966-09-24, 318.31
1966-10-01, 317.90
1966-10-08, 317.90
1966-10-15, 318.21
1966-10-22, 318.61
1966-10-29, 318.39
1966-11-12, 319.59
1966-11-19, 320.03
1966-11-26, 320.24
1966-12-03, 320.80
1966-12-10, 320.87
1966-12-17, 321.16
1966-12-24, 321.31
1966-12-31, 321.37
1967-01-07, 321.92
1967-01-14, 322.93
1967-02-04, 322.19
1967-02-11, 322.23
1967-02-18, 322.86
1967-02-25, 322.60
1967-03-04, 322.94
1967-03-11, 322.60
1967-03-18, 323.33
1967-03-25, 323.24
1967-04-01, 323.15
1967-04-08, 324.21
1967-04-15, 324.41
1967-04-22, 324.60
1967-04-29, 325.16
1967-05-06, 325.26
1967-05-13, 324.78
1967-05-20, 325.09
1967-05-27, 324.94
1967-06-03, 324.95
1967-06-10, 324.65
1967-06-17, 323.31
1967-06-24, 323.50
1967-07-01, 322.89
1967-07-08, 322.85
1967-07-15, 322.45
1967-07-22, 322.40
1967-07-29, 322.04
1967-08-05, 321.65
1967-08-12, 321.40
1967-08-19, 320.48
1967-08-26, 320.01
1967-09-02, 320.07
1967-09-09, 319.43
1967-09-16, 319.35
1967-09-23, 319.03
1967-09-30, 318.81
1967-10-07, 318.88
1967-10-14, 319.86
1967-10-21, 319.47
1967-10-28, 319.86
1967-11-04, 320.01
1967-11-11, 320.34
1967-11-18, 320.91
1967-11-25, 321.54
1967-12-02, 321.40
1967-12-09, 321.89
1967-12-16, 322.29
1967-12-23, 321.98
1967-12-30, 322.30
1968-01-06, 322.46
1968-01-13, 322.50
1968-01-20, 322.59
1968-01-27, 322.83
1968-02-03, 322.66
1968-02-10, 323.17
1968-02-17, 323.46
1968-02-24, 323.18
1968-03-02, 323.15
1968-03-09, 323.85
1968-03-16, 323.85
1968-03-23, 324.21
1968-03-30, 324.77
1968-04-06, 324.79
1968-04-13, 325.04
1968-04-20, 324.84
1968-04-27, 325.45
1968-05-04, 325.63
1968-05-11, 325.09
1968-05-18, 325.52
1968-05-25, 325.86
1968-06-01, 325.67
1968-06-08, 325.71
1968-06-15, 325.56
1968-06-22, 324.99
1968-06-29, 324.63
1968-07-06, 324.70
1968-07-13, 324.13
1968-07-20, 323.94
1968-07-27, 323.40
1968-08-03, 322.49
1968-08-10, 322.27
1968-08-17, 322.02
1968-08-24, 321.74
1968-08-31, 321.42
1968-09-07, 320.44
1968-09-14, 321.18
1968-09-21, 319.78
1968-09-28, 319.89
1968-10-05, 320.57
1968-10-12, 320.52
1968-10-19, 320.26
1968-10-26, 319.92
1968-11-02, 320.70
1968-11-09, 320.89
1968-11-16, 321.40
1968-11-23, 321.78
1968-11-30, 322.06
1968-12-07, 322.44
1968-12-14, 322.91
1968-12-21, 323.33
1968-12-28, 323.19
1969-01-04, 323.39
1969-01-11, 324.06
1969-01-18, 324.36
1969-01-25, 324.14
1969-02-01, 324.16
1969-02-08, 323.92
1969-02-15, 324.37
1969-02-22, 324.86
1969-03-01, 325.14
1969-03-08, 325.58
1969-03-15, 325.72
1969-03-22, 325.96
1969-03-29, 325.89
1969-04-05, 326.27
1969-04-12, 327.13
1969-04-19, 326.58
1969-04-26, 326.57
1969-05-03, 327.52
1969-05-10, 327.82
1969-05-17, 326.86
1969-05-24, 326.92
1969-05-31, 327.43
1969-06-07, 326.51
1969-06-14, 326.78
1969-06-21, 326.73
1969-06-28, 326.37
1969-07-05, 326.16
1969-07-12, 326.07
1969-07-19, 325.72
1969-07-26, 325.47
1969-08-02, 324.50
1969-08-09, 324.56
1969-08-16, 323.14
1969-08-23, 322.56
1969-08-30, 323.14
1969-09-06, 322.21
1969-09-13, 322.79
1969-09-20, 322.84
1969-09-27, 321.96
1969-10-04, 321.50
1969-10-11, 321.82
1969-10-18, 322.00
1969-10-25, 321.93
1969-11-01, 322.21
1969-11-08, 322.64
1969-11-15, 322.78
1969-11-22, 323.10
1969-11-29, 323.52
1969-12-06, 323.91
1969-12-13, 323.99
1969-12-20, 324.22
1969-12-27, 324.50
1970-01-03, 324.70
1970-01-10, 325.40
1970-01-17, 325.05
1970-01-24, 324.80
1970-01-31, 325.55
1970-02-07, 325.70
1970-02-14, 326.02
1970-02-21, 326.32
1970-02-28, 326.17
1970-03-07, 326.85
1970-03-14, 326.80
1970-03-21, 327.51
1970-03-28, 326.95
1970-04-04, 328.20
1970-04-11, 327.84
1970-04-18, 327.81
1970-04-25, 328.55
1970-05-02, 327.99
1970-05-09, 327.56
1970-05-16, 328.03
1970-05-23, 328.33
1970-05-30, 327.98
1970-06-06, 327.55
1970-06-13, 327.86
1970-06-20, 327.71
1970-06-27, 327.23
1970-07-04, 327.29
1970-07-11, 326.24
1970-07-18, 326.28
1970-07-25, 325.63
1970-08-01, 325.24
1970-08-08, 325.21
1970-08-15, 324.86
1970-08-22, 324.84
1970-08-29, 323.33
1970-09-05, 322.97
1970-09-12, 323.58
1970-09-19, 323.18
1970-09-26, 323.15
1970-10-03, 323.21
1970-10-10, 323.56
1970-10-17, 322.92
1970-10-24, 323.02
1970-10-31, 323.18
1970-11-07, 323.69
1970-11-14, 323.76
1970-11-21, 324.23
1970-11-28, 324.71
1970-12-05, 324.73
1970-12-12, 325.00
1970-12-19, 325.29
1970-12-26, 325.58
1971-01-02, 325.77
1971-01-09, 325.89
1971-01-16, 325.90
1971-01-23, 326.72
1971-01-30, 326.68
1971-02-06, 326.55
1971-02-13, 326.49
1971-02-20, 326.79
1971-02-27, 327.05
1971-03-06, 327.15
1971-03-13, 327.34
1971-03-20, 327.08
1971-03-27, 327.45
1971-04-03, 327.44
1971-04-10, 327.10
1971-04-17, 327.71
1971-04-24, 328.56
1971-05-01, 328.20
1971-05-08, 329.07
1971-05-15, 329.28
1971-05-22, 328.92
1971-05-29, 328.81
1971-06-05, 328.56
1971-06-12, 328.80
1971-06-19, 328.18
1971-06-26, 328.52
1971-07-03, 327.92
1971-07-10, 327.88
1971-07-17, 327.55
1971-07-24, 326.21
1971-07-31, 326.74
1971-08-07, 326.12
1971-08-14, 325.61
1971-08-21, 325.39
1971-08-28, 324.04
1971-09-04, 323.65
1971-09-11, 323.51
1971-09-18, 323.26
1971-09-25, 323.30
1971-10-02, 323.32
1971-10-09, 322.95
1971-10-16, 323.52
1971-10-23, 323.69
1971-10-30, 324.40
1971-11-06, 324.36
1971-11-13, 324.53
1971-11-20, 325.04
1971-11-27, 325.51
1971-12-04, 325.38
1971-12-11, 325.93
1971-12-18, 326.28
1971-12-25, 326.35
1972-01-01, 326.61
1972-01-08, 326.67
1972-01-15, 326.62
1972-01-22, 326.68
1972-01-29, 327.24
1972-02-05, 327.40
1972-02-12, 327.95
1972-02-19, 327.83
1972-02-26, 327.42
1972-03-04, 327.58
1972-03-11, 327.16
1972-03-18, 327.78
1972-03-25, 328.62
1972-04-01, 328.97
1972-04-08, 329.47
1972-04-15, 329.83
1972-04-22, 330.13
1972-04-29, 330.02
1972-05-06, 330.04
1972-05-13, 329.75
1972-05-20, 330.11
1972-05-27, 330.21
1972-06-03, 329.71
1972-06-10, 329.15
1972-06-17, 329.04
1972-06-24, 328.52
1972-07-01, 328.63
1972-07-08, 328.30
1972-07-15, 327.72
1972-07-22, 328.14
1972-07-29, 327.51
1972-08-05, 326.92
1972-08-12, 326.66
1972-08-19, 326.57
1972-08-26, 325.05
1972-09-02, 325.40
1972-09-09, 325.77
1972-09-16, 324.81
1972-09-23, 324.26
1972-09-30, 324.23
1972-10-07, 324.88
1972-10-14, 325.52
1972-10-21, 325.11
1972-10-28, 325.86
1972-11-04, 326.32
1972-11-11, 326.13
1972-11-18, 326.44
1972-11-25, 326.98
1972-12-02, 326.94
1972-12-09, 327.16
1972-12-16, 327.60
1972-12-23, 327.91
1972-12-30, 328.26
1973-01-06, 328.40
1973-01-13, 328.44
1973-01-20, 328.66
1973-01-27, 328.86
1973-02-03, 329.19
1973-02-10, 329.53
1973-02-17, 329.67
1973-02-24, 329.70
1973-03-03, 329.95
1973-03-10, 330.11
1973-03-17, 330.55
1973-03-24, 330.83
1973-03-31, 330.68
1973-04-07, 331.22
1973-04-14, 331.10
1973-04-21, 331.94
1973-04-28, 332.16
1973-05-05, 332.21
1973-05-12, 332.35
1973-05-19, 332.63
1973-05-26, 332.58
1973-06-02, 332.27
1973-06-09, 332.58
1973-06-16, 332.02
1973-06-23, 331.63
1973-06-30, 331.43
1973-07-07, 331.53
1973-07-14, 331.07
1973-07-21, 330.08
1973-07-28, 330.13
1973-08-04, 330.05
1973-08-11, 329.54
1973-08-18, 329.36
1973-08-25, 328.53
1973-09-01, 328.45
1973-09-08, 327.65
1973-09-15, 327.81
1973-09-22, 327.10
1973-09-29, 326.60
1973-10-06, 327.05
1973-10-13, 327.40
1973-10-20, 327.48
1973-10-27, 327.18
1973-11-03, 327.59
1973-11-10, 328.02
1973-11-17, 328.20
1973-11-24, 328.57
1973-12-01, 329.05
1973-12-08, 328.70
1973-12-15, 328.65
1973-12-22, 328.24
1973-12-29, 328.71
1974-01-05, 328.91
1974-01-12, 329.29
1974-01-19, 329.41
1974-01-26, 329.85
1974-02-02, 330.54
1974-02-09, 330.81
1974-02-16, 330.61
1974-02-23, 330.68
1974-03-02, 330.79
1974-03-09, 331.20
1974-03-16, 332.11
1974-03-23, 332.00
1974-03-30, 331.56
1974-04-06, 332.47
1974-04-13, 332.14
1974-04-20, 332.93
1974-04-27, 333.17
1974-05-04, 332.95
1974-05-11, 333.09
1974-05-18, 333.27
1974-05-25, 332.87
1974-06-01, 332.93
1974-06-08, 332.03
1974-06-15, 332.03
1974-06-22, 332.26
1974-06-29, 331.73
1974-07-06, 331.73
1974-07-13, 331.29
1974-07-20, 330.47
1974-07-27, 331.02
1974-08-03, 330.09
1974-08-10, 329.92
1974-08-17, 329.29
1974-08-24, 328.97
1974-08-31, 328.19
1974-09-07, 328.03
1974-09-14, 327.35
1974-09-21, 326.91
1974-09-28, 327.38
1974-10-05, 327.39
1974-10-12, 327.06
1974-10-19, 327.56
1974-10-26, 327.70
1974-11-02, 327.99
1974-11-09, 328.09
1974-11-16, 328.83
1974-11-23, 328.65
1974-11-30, 328.75
1974-12-07, 329.50
1974-12-14, 329.73
1974-12-21, 329.82
1974-12-28, 329.78
1975-01-04, 329.93
1975-01-11, 329.82
1975-01-18, 330.27
1975-01-25, 331.13
1975-02-01, 331.18
1975-02-08, 331.47
1975-02-15, 331.00
1975-02-22, 331.72
1975-03-01, 331.88
1975-03-08, 331.61
1975-03-15, 331.96
1975-03-22, 332.27
1975-03-29, 332.58
1975-04-05, 333.03
1975-04-12, 333.58
1975-04-19, 333.54
1975-04-26, 333.13
1975-05-03, 333.94
1975-05-10, 333.93
1975-05-17, 333.76
1975-05-24, 333.73
1975-05-31, 334.13
1975-06-07, 333.87
1975-06-14, 333.38
1975-06-21, 333.45
1975-06-28, 333.19
1975-07-05, 332.71
1975-07-12, 332.05
1975-07-19, 331.05
1975-07-26, 331.57
1975-08-02, 330.83
1975-08-09, 330.70
1975-08-16, 330.35
1975-08-23, 329.30
1975-08-30, 328.88
1975-09-06, 329.45
1975-09-13, 328.52
1975-09-20, 328.09
1975-09-27, 328.28
1975-10-04, 328.03
1975-10-11, 328.05
1975-10-18, 328.57
1975-10-25, 328.81
1975-11-01, 329.35
1975-11-08, 329.20
1975-11-15, 329.17
1975-11-22, 329.54
1975-11-29, 330.14
1975-12-06, 330.35
1975-12-13, 330.54
1975-12-20, 331.13
1975-12-27, 331.29
1976-01-03, 331.57
1976-01-10, 331.51
1976-01-17, 331.74
1976-01-24, 331.87
1976-01-31, 332.28
1976-02-07, 332.19
1976-02-14, 332.52
1976-02-21, 333.26
1976-02-28, 332.48
1976-03-06, 332.81
1976-03-13, 333.60
1976-03-20, 333.14
1976-03-27, 334.39
1976-04-03, 334.73
1976-04-10, 334.26
1976-04-17, 334.42
1976-04-24, 334.54
1976-05-01, 334.74
1976-05-08, 334.33
1976-05-15, 334.60
1976-05-22, 335.43
1976-05-29, 334.87
1976-06-05, 334.36
1976-06-12, 334.63
1976-06-19, 334.32
1976-07-03, 333.66
1976-07-10, 333.42
1976-07-17, 332.85
1976-07-24, 332.47
1976-07-31, 332.13
1976-08-07, 331.72
1976-08-14, 330.65
1976-08-21, 330.69
1976-08-28, 330.09
1976-09-04, 329.75
1976-09-11, 330.09
1976-09-18, 329.33
1976-09-25, 328.42
1976-10-02, 328.85
1976-10-09, 329.06
1976-10-16, 329.60
1976-10-23, 329.17
1976-10-30, 329.03
1976-11-06, 329.84
1976-11-13, 330.43
1976-11-20, 330.59
1976-11-27, 330.70
1976-12-04, 331.15
1976-12-11, 331.33
1976-12-18, 331.92
1976-12-25, 332.20
1977-01-01, 332.58
1977-01-08, 332.43
1977-01-15, 333.14
1977-01-22, 333.24
1977-01-29, 333.22
1977-02-05, 333.41
1977-02-12, 333.33
1977-02-19, 333.45
1977-02-26, 333.63
1977-03-05, 334.10
1977-03-12, 334.67
1977-03-19, 335.11
1977-03-26, 335.02
1977-04-02, 335.53
1977-04-09, 335.94
1977-04-16, 336.01
1977-04-23, 336.12
1977-04-30, 336.78
1977-05-07, 336.80
1977-05-14, 336.47
1977-05-21, 336.84
1977-05-28, 336.72
1977-06-04, 336.49
1977-06-11, 336.31
1977-06-18, 336.19
1977-06-25, 336.03
1977-07-02, 335.59
1977-07-09, 335.10
1977-07-16, 335.11
1977-07-23, 334.60
1977-07-30, 333.76
1977-08-06, 333.01
1977-08-13, 332.98
1977-08-20, 332.84
1977-08-27, 332.85
1977-09-03, 332.17
1977-09-10, 331.21
1977-09-17, 332.10
1977-09-24, 330.96
1977-10-01, 330.45
1977-10-08, 330.95
1977-10-15, 331.52
1977-10-22, 331.52
1977-10-29, 331.74
1977-11-05, 332.13
1977-11-12, 332.03
1977-11-19, 332.59
1977-11-26, 332.85
1977-12-03, 333.20
1977-12-10, 333.51
1977-12-17, 333.85
1977-12-24, 334.25
1977-12-31, 334.67
1978-01-07, 334.27
1978-01-14, 334.63
1978-01-21, 335.46
1978-01-28, 335.94
1978-02-04, 335.00
1978-02-11, 335.13
1978-02-18, 335.66
1978-02-25, 335.70
1978-03-04, 336.27
1978-03-11, 336.10
1978-03-18, 336.80
1978-03-25, 337.39
1978-04-01, 337.08
1978-04-08, 337.99
1978-04-15, 337.94
1978-04-22, 337.47
1978-04-29, 338.05
1978-05-06, 338.07
1978-05-13, 338.10
1978-05-20, 337.82
1978-05-27, 337.90
1978-06-03, 338.48
1978-06-10, 338.23
1978-06-17, 337.86
1978-06-24, 337.39
1978-07-01, 337.69
1978-07-08, 336.79
1978-07-15, 336.72
1978-07-22, 335.95
1978-07-29, 335.69
1978-08-05, 335.17
1978-08-12, 334.84
1978-08-19, 334.41
1978-08-26, 334.37
1978-09-02, 333.88
1978-09-09, 332.88
1978-09-16, 332.19
1978-09-23, 332.38
1978-09-30, 332.76
1978-10-07, 332.10
1978-10-14, 332.45
1978-10-21, 333.02
1978-10-28, 333.18
1978-11-04, 333.58
1978-11-11, 333.85
1978-11-18, 333.88
1978-11-25, 334.20
1978-12-02, 334.52
1978-12-09, 334.80
1978-12-16, 335.15
1978-12-23, 335.12
1978-12-30, 335.32
1979-01-06, 335.36
1979-01-13, 335.97
1979-01-20, 336.85
1979-01-27, 336.95
1979-02-03, 336.90
1979-02-10, 336.54
1979-02-17, 336.71
1979-02-24, 336.79
1979-03-03, 337.12
1979-03-10, 337.79
1979-03-17, 337.43
1979-03-24, 339.02
1979-03-31, 338.80
1979-04-07, 338.17
1979-04-14, 338.66
1979-04-21, 339.25
1979-04-28, 339.60
1979-05-05, 339.30
1979-05-12, 338.88
1979-05-19, 339.86
1979-05-26, 339.62
1979-06-02, 339.93
1979-06-09, 339.52
1979-06-16, 338.90
1979-06-23, 338.95
1979-06-30, 339.00
1979-07-07, 338.28
1979-07-14, 337.82
1979-07-21, 337.37
1979-07-28, 336.84
1979-08-04, 337.03
1979-08-11, 336.59
1979-08-18, 336.17
1979-08-25, 334.56
1979-09-01, 334.45
1979-09-08, 334.00
1979-09-15, 334.21
1979-09-22, 333.28
1979-09-29, 334.11
1979-10-06, 334.10
1979-10-13, 333.97
1979-10-20, 333.74
1979-10-27, 334.16
1979-11-03, 334.73
1979-11-10, 334.86
1979-11-17, 335.59
1979-11-24, 335.68
1979-12-01, 335.99
1979-12-08, 336.50
1979-12-15, 336.77
1979-12-22, 336.88
1979-12-29, 337.40
1980-01-05, 337.67
1980-01-12, 337.48
1980-01-19, 338.38
1980-01-26, 338.49
1980-02-02, 338.05
1980-02-09, 338.14
1980-02-16, 338.68
1980-02-23, 338.26
1980-03-01, 339.31
1980-03-08, 339.54
1980-03-15, 340.02
1980-03-22, 340.54
1980-03-29, 341.01
1980-04-05, 340.41
1980-04-12, 340.95
1980-04-19, 340.75
1980-04-26, 341.06
1980-05-03, 341.52
1980-05-10, 341.30
1980-05-17, 341.38
1980-05-24, 340.92
1980-05-31, 341.72
1980-06-07, 341.38
1980-06-14, 341.39
1980-06-21, 340.87
1980-06-28, 340.40
1980-07-05, 340.44
1980-07-12, 339.78
1980-07-19, 338.51
1980-07-26, 338.92
1980-08-02, 337.98
1980-08-09, 337.77
1980-08-16, 337.75
1980-08-23, 337.79
1980-08-30, 337.01
1980-09-06, 336.65
1980-09-13, 335.75
1980-09-20, 335.28
1980-09-27, 336.03
1980-10-04, 335.83
1980-10-11, 335.87
1980-10-18, 336.10
1980-10-25, 336.42
1980-11-01, 336.65
1980-11-08, 336.98
1980-11-15, 337.14
1980-11-22, 337.31
1980-11-29, 337.41
1980-12-06, 337.77
1980-12-13, 338.10
1980-12-20, 338.39
1980-12-27, 338.72
1981-01-03, 338.94
1981-01-10, 339.13
1981-01-17, 339.39
1981-01-24, 339.36
1981-01-31, 339.55
1981-02-07, 340.57
1981-02-14, 340.04
1981-02-21, 340.20
1981-02-28, 341.11
1981-03-07, 340.73
1981-03-14, 341.04
1981-03-21, 341.89
1981-03-28, 342.19
1981-04-04, 342.42
1981-04-11, 342.49
1981-04-18, 342.78
1981-04-25, 342.30
1981-05-02, 342.95
1981-05-09, 343.00
1981-05-16, 342.80
1981-05-23, 342.70
1981-05-30, 342.75
1981-06-06, 342.64
1981-06-13, 342.54
1981-06-20, 341.81
1981-06-27, 341.64
1981-07-04, 341.05
1981-07-11, 340.87
1981-07-18, 339.76
1981-07-25, 340.21
1981-08-01, 339.56
1981-08-08, 338.92
1981-08-15, 338.48
1981-08-22, 337.57
1981-08-29, 337.73
1981-09-05, 337.20
1981-09-12, 337.03
1981-09-19, 336.75
1981-09-26, 335.95
1981-10-03, 336.30
1981-10-10, 336.65
1981-10-17, 337.13
1981-10-24, 337.22
1981-10-31, 337.56
1981-11-07, 337.87
1981-11-14, 338.14
1981-11-21, 338.57
1981-11-28, 339.30
1981-12-05, 339.29
1981-12-12, 339.41
1981-12-19, 339.65
1981-12-26, 340.23
1982-01-02, 340.28
1982-01-09, 340.39
1982-01-16, 340.72
1982-01-23, 341.13
1982-01-30, 341.29
1982-02-06, 341.94
1982-02-13, 341.11
1982-02-20, 341.14
1982-02-27, 342.19
1982-03-06, 342.66
1982-03-13, 342.61
1982-03-20, 342.78
1982-03-27, 342.81
1982-04-03, 342.96
1982-04-10, 343.30
1982-04-17, 343.50
1982-04-24, 344.29
1982-05-01, 343.83
1982-05-08, 343.68
1982-05-15, 344.29
1982-05-22, 344.10
1982-05-29, 344.10
1982-06-05, 343.48
1982-06-12, 343.50
1982-06-19, 343.46
1982-06-26, 342.91
1982-07-03, 342.53
1982-07-10, 342.03
1982-07-17, 342.02
1982-07-24, 341.81
1982-07-31, 341.31
1982-08-07, 340.57
1982-08-14, 340.06
1982-08-21, 339.71
1982-08-28, 338.32
1982-09-04, 338.88
1982-09-11, 338.61
1982-09-18, 337.84
1982-09-25, 336.92
1982-10-02, 337.32
1982-10-09, 338.09
1982-10-16, 337.60
1982-10-23, 337.94
1982-10-30, 338.70
1982-11-06, 338.49
1982-11-13, 339.20
1982-11-20, 339.72
1982-11-27, 339.88
1982-12-04, 339.86
1982-12-11, 340.43
1982-12-18, 340.71
1982-12-25, 340.82
1983-01-01, 340.94
1983-01-08, 341.44
1983-01-15, 341.57
1983-01-22, 341.25
1983-01-29, 341.72
1983-02-05, 342.00
1983-02-12, 342.77
1983-02-19, 342.50
1983-02-26, 342.84
1983-03-05, 342.38
1983-03-12, 342.58
1983-03-19, 344.06
1983-03-26, 343.81
1983-04-02, 344.02
1983-04-09, 344.89
1983-04-16, 345.07
1983-04-23, 345.32
1983-04-30, 345.46
1983-05-07, 345.43
1983-05-14, 345.77
1983-05-21, 345.85
1983-05-28, 345.76
1983-06-04, 345.68
1983-06-11, 345.60
1983-06-18, 345.04
1983-06-25, 344.97
1983-07-02, 344.74
1983-07-09, 344.59
1983-07-16, 343.73
1983-07-23, 343.66
1983-07-30, 342.60
1983-08-06, 343.05
1983-08-13, 341.70
1983-08-20, 342.14
1983-08-27, 341.80
1983-09-03, 339.94
1983-09-10, 339.99
1983-09-17, 339.86
1983-09-24, 339.98
1983-10-01, 339.87
1983-10-08, 339.76
1983-10-15, 340.12
1983-10-22, 340.25
1983-10-29, 340.37
1983-11-05, 340.80
1983-11-12, 341.00
1983-11-19, 341.18
1983-11-26, 341.70
1983-12-03, 341.87
1983-12-10, 342.85
1983-12-17, 343.39
1983-12-24, 343.61
1983-12-31, 343.47
1984-01-07, 343.78
1984-01-14, 343.47
1984-01-21, 343.50
1984-01-28, 344.16
1984-02-04, 344.35
1984-02-11, 344.57
1984-02-18, 344.33
1984-02-25, 344.69
1984-03-03, 344.88
1984-03-10, 344.95
1984-03-17, 345.45
1984-03-24, 345.69
1984-04-28, 347.47
1984-05-05, 347.49
1984-05-12, 347.78
1984-05-19, 347.36
1984-05-26, 347.03
1984-06-02, 347.09
1984-06-09, 347.02
1984-06-16, 346.89
1984-06-23, 346.37
1984-06-30, 346.24
1984-07-07, 345.82
1984-07-14, 345.48
1984-07-21, 345.25
1984-07-28, 344.48
1984-08-04, 344.05
1984-08-11, 344.12
1984-08-18, 343.19
1984-08-25, 342.05
1984-09-01, 341.65
1984-09-08, 340.65
1984-09-15, 341.37
1984-09-22, 341.31
1984-09-29, 340.85
1984-10-06, 341.19
1984-10-13, 341.30
1984-10-20, 341.91
1984-10-27, 341.67
1984-11-03, 342.01
1984-11-10, 342.65
1984-11-17, 343.14
1984-11-24, 343.75
1984-12-01, 343.60
1984-12-08, 343.95
1984-12-15, 344.23
1984-12-22, 344.58
1984-12-29, 344.57
1985-01-05, 344.77
1985-01-12, 345.01
1985-01-19, 345.01
1985-01-26, 345.08
1985-02-02, 345.95
1985-02-09, 345.54
1985-02-16, 345.82
1985-02-23, 346.37
1985-03-02, 346.77
1985-03-09, 347.11
1985-03-16, 347.58
1985-03-23, 347.70
1985-03-30, 348.27
1985-04-06, 348.04
1985-04-13, 348.08
1985-04-20, 348.52
1985-04-27, 348.84
1985-05-04, 348.89
1985-05-11, 349.31
1985-05-18, 349.18
1985-05-25, 348.18
1985-06-01, 349.05
1985-06-08, 348.49
1985-06-15, 348.24
1985-06-22, 347.90
1985-06-29, 347.47
1985-07-06, 346.90
1985-07-13, 346.80
1985-07-20, 346.43
1985-07-27, 345.79
1985-08-10, 344.70
1985-08-17, 344.50
1985-08-24, 344.38
1985-08-31, 343.76
1985-09-07, 344.29
1985-09-14, 343.37
1985-09-21, 342.46
1985-09-28, 342.13
1985-10-05, 342.40
1985-10-12, 342.50
1985-10-19, 343.14
1985-10-26, 343.22
1985-11-02, 343.38
1985-11-09, 343.77
1985-11-16, 344.25
1985-11-23, 344.64
1985-11-30, 345.30
1985-12-07, 345.37
1985-12-14, 345.67
1985-12-21, 345.17
1985-12-28, 346.30
1986-01-04, 346.44
1986-01-11, 346.09
1986-01-18, 346.25
1986-01-25, 346.46
1986-02-01, 346.22
1986-02-08, 346.84
1986-02-15, 347.18
1986-02-22, 347.20
1986-03-01, 347.07
1986-03-08, 346.65
1986-03-15, 347.22
1986-03-22, 349.15
1986-03-29, 348.87
1986-04-05, 349.21
1986-04-12, 349.45
1986-04-19, 349.34
1986-04-26, 350.20
1986-05-03, 349.99
1986-05-10, 350.14
1986-05-17, 350.23
1986-05-24, 350.13
1986-05-31, 350.18
1986-06-07, 349.73
1986-06-14, 349.54
1986-06-21, 349.48
1986-06-28, 348.92
1986-07-05, 348.69
1986-07-12, 347.77
1986-07-19, 347.61
1986-07-26, 347.41
1986-08-02, 346.65
1986-08-09, 346.23
1986-08-16, 345.59
1986-08-23, 345.62
1986-08-30, 345.27
1986-09-06, 345.05
1986-09-13, 345.32
1986-09-20, 344.43
1986-09-27, 344.51
1986-10-04, 343.99
1986-10-11, 344.11
1986-10-18, 343.99
1986-10-25, 344.57
1986-11-01, 345.17
1986-11-08, 345.35
1986-11-15, 345.63
1986-11-22, 345.72
1986-11-29, 346.41
1986-12-06, 346.92
1986-12-13, 346.77
1986-12-20, 346.97
1986-12-27, 347.08
1987-01-03, 347.62
1987-01-10, 348.37
1987-01-17, 348.27
1987-01-24, 347.96
1987-01-31, 348.03
1987-02-07, 347.91
1987-02-14, 348.25
1987-02-21, 348.54
1987-02-28, 349.47
1987-03-07, 348.85
1987-03-14, 349.27
1987-03-21, 349.79
1987-03-28, 350.20
1987-04-04, 350.82
1987-04-11, 350.27
1987-04-18, 351.19
1987-04-25, 351.39
1987-05-02, 351.43
1987-05-09, 352.00
1987-05-16, 351.73
1987-05-23, 351.91
1987-05-30, 351.78
1987-06-06, 351.65
1987-06-13, 351.17
1987-06-20, 351.00
1987-06-27, 350.94
1987-07-04, 349.76
1987-07-11, 349.84
1987-07-18, 348.87
1987-07-25, 349.51
1987-08-01, 349.04
1987-08-08, 348.15
1987-08-15, 348.62
1987-08-22, 348.01
1987-08-29, 346.71
1987-09-05, 347.05
1987-09-12, 346.65
1987-09-19, 346.29
1987-09-26, 345.85
1987-10-03, 345.77
1987-10-10, 346.34
1987-10-17, 346.59
1987-10-24, 346.80
1987-10-31, 346.91
1987-11-07, 347.34
1987-11-14, 347.65
1987-11-21, 348.16
1987-11-28, 348.75
1987-12-05, 348.66
1987-12-12, 348.82
1987-12-19, 349.12
1987-12-26, 349.29
1988-01-02, 349.78
1988-01-09, 350.28
1988-01-16, 350.21
1988-01-23, 350.79
1988-01-30, 351.22
1988-02-06, 351.81
1988-02-13, 351.31
1988-02-20, 351.53
1988-02-27, 352.55
1988-03-05, 352.88
1988-03-12, 351.88
1988-03-19, 351.78
1988-03-26, 352.23
1988-04-02, 353.13
1988-04-09, 353.57
1988-04-16, 353.15
1988-04-23, 354.00
1988-04-30, 354.23
1988-05-07, 353.76
1988-05-14, 354.30
1988-05-21, 354.52
1988-05-28, 354.20
1988-06-04, 354.18
1988-06-11, 354.20
1988-06-18, 353.61
1988-06-25, 353.19
1988-07-02, 353.08
1988-07-09, 352.56
1988-07-16, 352.65
1988-07-23, 351.96
1988-07-30, 351.13
1988-08-06, 350.95
1988-08-13, 350.30
1988-08-20, 350.49
1988-08-27, 349.61
1988-09-03, 349.38
1988-09-10, 348.73
1988-09-17, 348.95
1988-09-24, 348.19
1988-10-01, 348.82
1988-10-08, 348.88
1988-10-15, 348.68
1988-10-22, 349.42
1988-10-29, 349.29
1988-11-05, 349.78
1988-11-12, 349.89
1988-11-19, 350.18
1988-11-26, 350.48
1988-12-03, 350.50
1988-12-10, 351.02
1988-12-17, 351.60
1988-12-24, 351.36
1988-12-31, 352.40
1989-01-07, 352.77
1989-01-14, 352.97
1989-01-21, 352.51
1989-01-28, 353.06
1989-02-04, 352.83
1989-02-11, 352.64
1989-02-18, 353.22
1989-02-25, 353.48
1989-03-04, 353.17
1989-03-11, 353.46
1989-03-18, 353.55
1989-03-25, 354.48
1989-04-01, 354.56
1989-04-08, 355.05
1989-04-15, 355.41
1989-04-22, 356.01
1989-04-29, 355.90
1989-05-06, 355.36
1989-05-13, 355.82
1989-05-20, 355.64
1989-05-27, 355.76
1989-06-03, 355.80
1989-06-10, 355.09
1989-06-17, 354.87
1989-06-24, 354.90
1989-07-01, 354.50
1989-07-08, 354.76
1989-07-15, 353.85
1989-07-22, 353.19
1989-07-29, 353.21
1989-08-05, 352.62
1989-08-12, 352.24
1989-08-19, 351.16
1989-08-26, 350.43
1989-09-02, 350.79
1989-09-09, 350.28
1989-09-16, 349.41
1989-09-23, 349.31
1989-09-30, 349.71
1989-10-07, 349.97
1989-10-14, 349.74
1989-10-21, 350.24
1989-10-28, 350.47
1989-11-04, 350.66
1989-11-11, 351.29
1989-11-18, 351.60
1989-11-25, 351.46
1989-12-02, 352.09
1989-12-09, 352.16
1989-12-16, 352.48
1989-12-23, 352.59
1989-12-30, 353.44
1990-01-06, 353.47
1990-01-13, 353.55
1990-01-20, 353.80
1990-01-27, 353.96
1990-02-03, 354.13
1990-02-10, 355.02
1990-02-17, 354.87
1990-02-24, 354.78
1990-03-03, 355.72
1990-03-10, 354.99
1990-03-17, 355.84
1990-03-24, 355.17
1990-03-31, 355.95
1990-04-07, 356.17
1990-04-14, 355.90
1990-04-21, 356.68
1990-04-28, 356.18
1990-05-05, 357.30
1990-05-12, 357.09
1990-05-19, 356.99
1990-05-26, 357.13
1990-06-02, 357.01
1990-06-09, 356.63
1990-06-16, 355.68
1990-06-23, 355.53
1990-06-30, 355.79
1990-07-07, 355.51
1990-07-14, 354.00
1990-07-21, 354.59
1990-07-28, 354.72
1990-08-04, 353.56
1990-08-11, 353.23
1990-08-18, 352.92
1990-08-25, 352.01
1990-09-01, 350.99
1990-09-08, 350.75
1990-09-15, 351.33
1990-09-22, 350.97
1990-09-29, 350.92
1990-10-06, 351.10
1990-10-13, 351.08
1990-10-20, 351.48
1990-10-27, 351.47
1990-11-03, 352.12
1990-11-10, 352.62
1990-11-17, 353.05
1990-11-24, 353.18
1990-12-01, 353.61
1990-12-08, 354.07
1990-12-15, 353.87
1990-12-22, 354.51
1990-12-29, 354.89
1991-01-05, 354.28
1991-01-12, 354.73
1991-01-19, 354.86
1991-01-26, 355.05
1991-02-02, 355.22
1991-02-09, 355.23
1991-02-16, 356.40
1991-02-23, 355.83
1991-03-02, 356.41
1991-03-09, 357.21
1991-03-16, 357.69
1991-03-23, 356.96
1991-03-30, 357.94
1991-04-06, 358.32
1991-04-13, 357.83
1991-04-20, 359.19
1991-04-27, 359.24
1991-05-04, 359.11
1991-05-11, 358.94
1991-05-18, 360.03
1991-05-25, 359.08
1991-06-01, 358.52
1991-06-08, 358.46
1991-06-15, 358.22
1991-06-22, 358.12
1991-06-29, 357.74
1991-07-06, 357.27
1991-07-13, 356.54
1991-07-20, 355.26
1991-07-27, 355.30
1991-08-03, 354.89
1991-08-10, 354.60
1991-08-17, 353.78
1991-08-24, 353.07
1991-08-31, 353.22
1991-09-07, 353.06
1991-09-14, 352.12
1991-09-21, 351.84
1991-09-28, 351.69
1991-10-05, 351.70
1991-10-12, 352.18
1991-10-19, 352.53
1991-10-26, 352.72
1991-11-02, 353.47
1991-11-09, 353.76
1991-11-16, 353.56
1991-11-23, 353.86
1991-11-30, 354.35
1991-12-07, 354.54
1991-12-14, 354.97
1991-12-21, 355.22
1991-12-28, 355.50
1992-01-04, 355.69
1992-01-11, 356.07
1992-01-18, 356.19
1992-01-25, 355.96
1992-02-01, 356.05
1992-02-08, 356.73
1992-02-15, 357.33
1992-02-22, 356.99
1992-02-29, 356.58
1992-03-07, 357.30
1992-03-14, 357.80
1992-03-21, 358.18
1992-03-28, 358.42
1992-04-04, 358.57
1992-04-11, 358.99
1992-04-18, 359.75
1992-04-25, 359.25
1992-05-02, 359.69
1992-05-09, 359.73
1992-05-16, 358.60
1992-05-23, 359.65
1992-05-30, 360.25
1992-06-06, 360.03
1992-06-13, 359.48
1992-06-20, 358.75
1992-06-27, 358.45
1992-07-04, 358.47
1992-07-11, 357.20
1992-07-18, 356.37
1992-07-25, 356.10
1992-08-01, 354.99
1992-08-08, 355.33
1992-08-15, 355.32
1992-08-22, 354.59
1992-08-29, 354.34
1992-09-05, 353.53
1992-09-12, 353.66
1992-09-19, 352.37
1992-09-26, 352.75
1992-10-03, 353.60
1992-10-10, 353.38
1992-10-17, 353.24
1992-10-24, 353.51
1992-10-31, 353.56
1992-11-07, 353.99
1992-11-14, 353.86
1992-11-21, 354.57
1992-11-28, 354.64
1992-12-05, 354.85
1992-12-12, 355.37
1992-12-19, 355.46
1992-12-26, 355.97
1993-01-02, 356.29
1993-01-09, 356.96
1993-01-16, 356.72
1993-01-23, 356.66
1993-01-30, 357.03
1993-02-06, 356.62
1993-02-13, 357.23
1993-02-20, 357.36
1993-02-27, 357.68
1993-03-06, 358.39
1993-03-13, 358.52
1993-03-20, 358.13
1993-03-27, 358.85
1993-04-03, 359.17
1993-04-10, 358.87
1993-04-17, 359.42
1993-04-24, 360.03
1993-05-01, 359.62
1993-05-08, 359.78
1993-05-15, 360.70
1993-05-22, 360.62
1993-05-29, 360.35
1993-06-05, 359.79
1993-06-12, 359.92
1993-06-19, 359.34
1993-06-26, 359.15
1993-07-03, 357.91
1993-07-10, 358.02
1993-07-17, 358.10
1993-07-24, 356.69
1993-07-31, 356.52
1993-08-07, 355.88
1993-08-14, 355.95
1993-08-21, 354.90
1993-08-28, 354.72
1993-09-04, 354.30
1993-09-11, 353.23
1993-09-18, 353.81
1993-09-25, 353.86
1993-10-02, 353.80
1993-10-09, 353.87
1993-10-16, 354.00
1993-10-23, 354.45
1993-10-30, 354.38
1993-11-06, 354.78
1993-11-13, 355.16
1993-11-20, 355.65
1993-11-27, 356.03
1993-12-04, 356.27
1993-12-11, 356.52
1993-12-18, 356.99
1993-12-25, 357.50
1994-01-01, 358.14
1994-01-08, 358.12
1994-01-15, 358.43
1994-01-22, 358.33
1994-01-29, 358.78
1994-02-05, 358.49
1994-02-12, 358.61
1994-02-19, 359.02
1994-02-26, 359.64
1994-03-05, 358.77
1994-03-12, 359.86
1994-03-19, 360.49
1994-03-26, 360.83
1994-04-02, 360.68
1994-04-09, 361.01
1994-04-16, 361.07
1994-04-23, 361.34
1994-04-30, 362.25
1994-05-07, 361.63
1994-05-14, 361.42
1994-05-21, 361.78
1994-05-28, 361.91
1994-06-04, 361.04
1994-06-11, 361.07
1994-06-18, 360.93
1994-06-25, 360.70
1994-07-02, 360.22
1994-07-09, 359.90
1994-07-16, 359.43
1994-07-23, 359.00
1994-07-30, 358.81
1994-08-06, 358.10
1994-08-13, 357.52
1994-08-20, 357.63
1994-08-27, 356.39
1994-09-03, 356.44
1994-09-10, 356.46
1994-09-17, 355.46
1994-09-24, 355.50
1994-10-01, 355.46
1994-10-08, 355.81
1994-10-15, 356.09
1994-10-22, 356.39
1994-10-29, 356.61
1994-11-05, 356.97
1994-11-12, 357.40
1994-11-19, 357.93
1994-11-26, 358.11
1994-12-03, 358.43
1994-12-10, 359.13
1994-12-17, 359.25
1994-12-24, 359.15
1994-12-31, 359.52
1995-01-07, 359.68
1995-01-14, 360.28
1995-01-21, 360.12
1995-01-28, 360.04
1995-02-04, 360.67
1995-02-11, 361.09
1995-02-18, 360.88
1995-02-25, 361.36
1995-03-04, 362.20
1995-03-11, 361.24
1995-03-18, 360.99
1995-03-25, 362.00
1995-04-01, 363.80
1995-04-08, 363.44
1995-04-15, 363.34
1995-04-22, 362.89
1995-04-29, 363.58
1995-05-06, 363.24
1995-05-13, 364.11
1995-05-20, 364.18
1995-05-27, 363.47
1995-06-03, 363.92
1995-06-10, 363.47
1995-06-17, 362.96
1995-06-24, 362.81
1995-07-01, 362.53
1995-07-08, 362.27
1995-07-15, 361.97
1995-07-22, 361.58
1995-07-29, 360.98
1995-08-05, 360.45
1995-08-12, 359.21
1995-08-19, 358.72
1995-08-26, 359.29
1995-09-02, 357.37
1995-09-09, 358.50
1995-09-16, 358.58
1995-09-23, 358.20
1995-09-30, 357.56
1995-10-07, 357.65
1995-10-14, 357.60
1995-10-21, 358.04
1995-10-28, 358.23
1995-11-04, 359.19
1995-11-11, 359.43
1995-11-18, 359.69
1995-11-25, 359.87
1995-12-02, 360.13
1995-12-09, 360.43
1995-12-16, 360.53
1995-12-23, 360.89
1995-12-30, 361.73
1996-01-06, 361.81
1996-01-13, 362.06
1996-01-20, 362.17
1996-01-27, 362.23
1996-02-03, 362.68
1996-02-10, 363.12
1996-02-17, 363.01
1996-02-24, 364.03
1996-03-02, 363.84
1996-03-09, 363.66
1996-03-16, 364.10
1996-03-23, 364.53
1996-03-30, 364.35
1996-04-06, 364.57
1996-04-13, 364.89
1996-04-20, 364.40
1996-04-27, 365.13
1996-05-04, 364.92
1996-05-11, 365.37
1996-05-18, 365.74
1996-05-25, 365.43
1996-06-01, 364.86
1996-06-08, 365.19
1996-06-15, 365.27
1996-06-22, 365.00
1996-06-29, 364.30
1996-07-06, 364.19
1996-07-13, 363.75
1996-07-20, 363.38
1996-07-27, 362.84
1996-08-03, 361.78
1996-08-10, 362.10
1996-08-17, 361.29
1996-08-24, 360.85
1996-08-31, 360.82
1996-09-07, 359.86
1996-09-14, 359.82
1996-09-21, 359.09
1996-09-28, 359.04
1996-10-05, 359.45
1996-10-12, 359.52
1996-10-19, 359.86
1996-10-26, 359.87
1996-11-02, 359.94
1996-11-09, 360.52
1996-11-16, 360.79
1996-11-23, 361.24
1996-11-30, 361.40
1996-12-07, 361.97
1996-12-14, 362.68
1996-12-21, 362.47
1996-12-28, 362.62
1997-01-04, 362.95
1997-01-11, 363.00
1997-01-18, 363.16
1997-01-25, 363.51
1997-02-01, 363.28
1997-02-08, 364.19
1997-02-15, 364.02
1997-02-22, 364.24
1997-03-01, 364.50
1997-03-08, 364.16
1997-03-15, 364.19
1997-03-22, 364.75
1997-03-29, 365.43
1997-04-05, 365.80
1997-04-12, 366.25
1997-04-19, 366.69
1997-04-26, 366.79
1997-05-03, 366.76
1997-05-10, 366.80
1997-05-17, 367.03
1997-05-24, 366.61
1997-05-31, 366.36
1997-06-07, 365.71
1997-06-14, 365.61
1997-06-21, 365.53
1997-06-28, 365.16
1997-07-05, 365.09
1997-07-12, 364.67
1997-07-19, 364.11
1997-07-26, 363.80
1997-08-02, 363.39
1997-08-09, 363.36
1997-08-16, 362.63
1997-08-23, 361.51
1997-08-30, 361.66
1997-09-06, 360.69
1997-09-13, 360.26
1997-09-20, 360.08
1997-09-27, 359.81
1997-10-04, 360.54
1997-10-11, 360.49
1997-10-18, 361.07
1997-10-25, 361.13
1997-11-01, 361.71
1997-11-08, 362.19
1997-11-15, 362.06
1997-11-22, 362.65
1997-11-29, 363.51
1997-12-06, 363.97
1997-12-13, 363.95
1997-12-20, 364.27
1997-12-27, 365.09
1998-01-03, 365.24
1998-01-10, 365.30
1998-01-17, 365.35
1998-01-24, 365.38
1998-01-31, 365.69
1998-02-07, 366.06
1998-02-14, 365.52
1998-02-21, 366.08
1998-02-28, 367.36
1998-03-07, 367.02
1998-03-14, 366.66
1998-03-21, 367.49
1998-03-28, 368.57
1998-04-04, 368.69
1998-04-11, 368.68
1998-04-18, 368.05
1998-04-25, 368.90
1998-05-02, 369.17
1998-05-09, 368.83
1998-05-16, 368.51
1998-05-23, 369.66
1998-05-30, 369.70
1998-06-06, 369.41
1998-06-13, 368.88
1998-06-20, 368.54
1998-06-27, 368.36
1998-07-04, 368.05
1998-07-11, 367.54
1998-07-18, 367.67
1998-07-25, 367.36
1998-08-01, 366.88
1998-08-08, 366.46
1998-08-15, 365.64
1998-08-22, 365.63
1998-08-29, 364.25
1998-09-05, 364.74
1998-09-12, 363.96
1998-09-19, 363.50
1998-09-26, 363.60
1998-10-03, 364.01
1998-10-10, 364.17
1998-10-17, 364.46
1998-10-24, 364.49
1998-10-31, 364.70
1998-11-07, 365.05
1998-11-14, 365.48
1998-11-21, 365.80
1998-11-28, 366.00
1998-12-05, 366.46
1998-12-12, 366.74
1998-12-19, 367.30
1998-12-26, 367.38
1999-01-02, 367.58
1999-01-09, 367.87
1999-01-16, 367.80
1999-01-23, 368.33
1999-01-30, 369.25
1999-02-06, 369.19
1999-02-13, 368.90
1999-02-20, 369.05
1999-02-27, 368.52
1999-03-06, 368.13
1999-03-13, 369.58
1999-03-20, 370.27
1999-03-27, 370.65
1999-04-03, 371.11
1999-04-10, 371.59
1999-04-17, 371.07
1999-04-24, 370.32
1999-05-01, 370.82
1999-05-08, 371.33
1999-05-15, 371.09
1999-05-22, 370.89
1999-05-29, 370.41
1999-06-05, 370.98
1999-06-12, 370.33
1999-06-19, 369.97
1999-06-26, 369.97
1999-07-03, 369.49
1999-07-10, 370.15
1999-07-17, 369.54
1999-07-24, 368.66
1999-07-31, 367.48
1999-08-07, 367.65
1999-08-14, 366.77
1999-08-21, 366.44
1999-08-28, 366.16
1999-09-04, 364.22
1999-09-11, 364.75
1999-09-18, 365.25
1999-09-25, 364.74
1999-10-02, 364.62
1999-10-09, 365.11
1999-10-16, 364.94
1999-10-23, 365.70
1999-10-30, 365.81
1999-11-06, 366.24
1999-11-13, 366.75
1999-11-20, 366.74
1999-11-27, 367.20
1999-12-04, 367.47
1999-12-11, 368.10
1999-12-18, 368.05
1999-12-25, 368.27
2000-01-01, 368.74
2000-01-08, 368.63
2000-01-15, 369.12
2000-01-22, 369.93
2000-01-29, 369.35
2000-02-05, 369.18
2000-02-12, 369.66
2000-02-19, 369.45
2000-02-26, 369.61
2000-03-04, 370.11
2000-03-11, 370.09
2000-03-18, 370.98
2000-03-25, 370.86
2000-04-01, 371.04
2000-04-08, 371.81
2000-04-15, 371.91
2000-04-22, 372.10
2000-04-29, 371.37
2000-05-06, 371.36
2000-05-13, 371.83
2000-05-20, 372.01
2000-05-27, 371.91
2000-06-03, 371.98
2000-06-10, 371.71
2000-06-17, 371.82
2000-06-24, 371.41
2000-07-01, 370.96
2000-07-08, 370.17
2000-07-15, 370.29
2000-07-22, 369.85
2000-07-29, 369.10
2000-08-05, 368.86
2000-08-12, 368.46
2000-08-19, 367.78
2000-08-26, 367.25
2000-09-02, 367.28
2000-09-09, 366.84
2000-09-16, 366.35
2000-09-23, 366.34
2000-09-30, 366.54
2000-10-07, 366.42
2000-10-14, 366.75
2000-10-21, 366.79
2000-10-28, 367.46
2000-11-04, 367.78
2000-11-11, 368.10
2000-11-18, 368.76
2000-11-25, 368.42
2000-12-02, 369.10
2000-12-09, 369.74
2000-12-16, 369.41
2000-12-23, 369.64
2000-12-30, 369.91
2001-01-06, 369.95
2001-01-13, 370.35
2001-01-20, 370.10
2001-01-27, 370.91
2001-02-03, 371.45
2001-02-10, 371.29
2001-02-17, 371.82
2001-02-24, 371.33
2001-03-03, 372.34
2001-03-10, 372.32
2001-03-17, 372.23
2001-03-24, 371.97
2001-03-31, 372.18
2001-04-07, 372.82
2001-04-14, 372.84
2001-04-21, 373.17
2001-04-28, 372.91
2001-05-05, 373.83
2001-05-12, 374.08
2001-05-19, 373.85
2001-05-26, 374.05
2001-06-02, 374.00
2001-06-09, 373.27
2001-06-16, 372.98
2001-06-23, 373.04
2001-06-30, 372.90
2001-07-07, 372.29
2001-07-14, 371.51
2001-07-21, 371.36
2001-07-28, 370.76
2001-08-04, 370.07
2001-08-11, 369.70
2001-08-18, 369.43
2001-08-25, 369.15
2001-09-01, 368.61
2001-09-08, 368.34
2001-09-15, 368.18
2001-09-22, 367.61
2001-09-29, 367.56
2001-10-06, 367.93
2001-10-13, 367.73
2001-10-20, 368.23
2001-10-27, 368.92
2001-11-03, 368.87
2001-11-10, 369.03
2001-11-17, 369.84
2001-11-24, 370.44
2001-12-01, 370.51
2001-12-08, 371.03
2001-12-15, 371.34
2001-12-22, 371.51
2001-12-29, 371.67
2002-01-05, 371.94
2002-01-12, 372.26
2002-01-19, 373.04
2002-01-26, 372.46
2002-02-02, 372.85
2002-02-09, 372.93
2002-02-16, 372.84
2002-02-23, 373.40
2002-03-02, 373.29
2002-03-09, 373.47
2002-03-16, 373.37
2002-03-23, 373.51
2002-03-30, 374.29
2002-04-06, 374.50
2002-04-13, 374.55
2002-04-20, 375.06
2002-04-27, 375.47
2002-05-04, 375.78
2002-05-11, 374.95
2002-05-18, 375.24
2002-05-25, 375.92
2002-06-01, 375.78
2002-06-08, 375.66
2002-06-15, 375.12
2002-06-22, 375.50
2002-06-29, 374.47
2002-07-06, 374.62
2002-07-13, 374.13
2002-07-20, 373.68
2002-07-27, 373.16
2002-08-03, 372.93
2002-08-10, 371.73
2002-08-17, 371.03
2002-08-24, 370.87
2002-08-31, 370.12
2002-09-07, 371.39
2002-09-14, 371.16
2002-09-21, 370.45
2002-09-28, 369.97
2002-10-05, 369.68
2002-10-12, 370.04
2002-10-19, 371.06
2002-10-26, 370.44
2002-11-02, 371.67
2002-11-09, 371.55
2002-11-16, 372.08
2002-11-23, 372.69
2002-11-30, 372.65
2002-12-07, 373.32
2002-12-14, 373.44
2002-12-21, 374.16
2002-12-28, 374.60
2003-01-04, 374.49
2003-01-11, 374.46
2003-01-18, 374.82
2003-01-25, 374.89
2003-02-01, 375.23
2003-02-08, 374.81
2003-02-15, 375.70
2003-02-22, 376.36
2003-03-01, 375.82
2003-03-08, 375.89
2003-03-15, 375.76
2003-03-22, 376.44
2003-03-29, 376.82
2003-04-05, 376.81
2003-04-12, 377.30
2003-04-19, 378.11
2003-04-26, 378.46
2003-05-03, 378.11
2003-05-10, 377.49
2003-05-17, 378.79
2003-05-24, 378.71
2003-05-31, 378.29
2003-06-07, 378.39
2003-06-21, 377.34
2003-06-28, 377.85
2003-07-05, 376.43
2003-07-12, 377.05
2003-07-19, 376.70
2003-07-26, 375.98
2003-08-02, 375.48
2003-08-09, 374.67
2003-08-16, 374.06
2003-08-23, 374.47
2003-08-30, 373.48
2003-09-06, 373.09
2003-09-13, 372.76
2003-09-20, 373.08
2003-09-27, 373.03
2003-10-04, 372.87
2003-10-25, 373.33
2003-11-01, 373.50
2003-11-08, 373.76
2003-11-15, 374.45
2003-11-22, 375.21
2003-11-29, 374.72
2003-12-06, 374.47
2003-12-13, 376.15
2003-12-20, 376.05
2003-12-27, 376.43
2004-01-03, 376.17
2004-01-10, 376.17
2004-01-17, 377.01
2004-01-24, 377.29
2004-01-31, 377.49
2004-02-07, 377.47
2004-02-14, 377.00
2004-02-21, 377.35
2004-02-28, 377.67
2004-03-06, 378.05
2004-03-13, 379.40
2004-03-20, 378.47
2004-03-27, 378.50
2004-04-03, 380.09
2004-04-10, 380.41
2004-04-17, 380.56
2004-04-24, 380.71
2004-05-01, 380.28
2004-05-08, 381.04
2004-05-15, 380.51
2004-05-22, 380.33
2004-05-29, 380.66
2004-06-05, 379.62
2004-06-12, 380.00
2004-06-19, 379.30
2004-06-26, 379.07
2004-07-03, 378.44
2004-07-10, 378.04
2004-07-17, 377.33
2004-07-24, 376.99
2004-07-31, 377.35
2004-08-07, 376.56
2004-08-14, 375.84
2004-08-21, 375.70
2004-08-28, 374.62
2004-09-04, 373.82
2004-09-11, 374.57
2004-09-18, 374.14
2004-09-25, 373.80
2004-10-02, 374.01
2004-10-09, 373.95
2004-10-16, 374.05
2004-10-23, 374.58
2004-10-30, 375.02
2004-11-06, 375.06
2004-11-13, 376.13
2004-11-20, 376.46
2004-11-27, 376.13
2004-12-04, 377.09
2004-12-11, 377.37
2004-12-18, 377.50
2004-12-25, 377.68
2005-01-01, 378.06
2005-01-08, 378.21
2005-01-15, 378.36
2005-01-22, 378.34
2005-01-29, 378.66
2005-02-05, 379.02
2005-02-12, 379.31
2005-02-19, 380.25
2005-03-26, 380.57
2005-04-02, 382.07
2005-04-09, 382.25
2005-04-16, 381.35
2005-04-23, 382.08
2005-04-30, 382.38
2005-05-07, 381.51
2005-05-14, 382.53
2005-05-21, 382.14
2005-05-28, 382.58
2005-06-04, 382.36
2005-06-11, 382.31
2005-06-18, 382.12
2005-06-25, 381.48
2005-07-02, 381.15
2005-07-09, 380.90
2005-07-16, 380.63
2005-07-23, 380.36
2005-07-30, 379.86
2005-08-06, 379.21
2005-08-13, 378.97
2005-08-20, 378.40
2005-08-27, 377.69
2005-09-03, 377.82
2005-09-10, 376.33
2005-09-17, 376.14
2005-09-24, 375.95
2005-10-01, 376.33
2005-10-08, 376.44
2005-10-15, 377.12
2005-10-22, 377.31
2005-10-29, 377.24
2005-11-05, 377.76
2005-11-12, 378.07
2005-11-19, 378.75
2005-11-26, 378.77
2005-12-03, 379.41
2005-12-10, 380.09
2005-12-17, 380.09
2005-12-24, 380.14
2005-12-31, 380.43
2006-01-07, 381.28
2006-01-14, 381.41
2006-01-21, 381.57
2006-01-28, 381.47
2006-02-04, 382.04
2006-02-25, 381.86
2006-03-04, 382.39
2006-03-11, 382.55
2006-03-18, 382.74
2006-03-25, 382.55
2006-04-01, 382.97
2006-04-08, 384.65
2006-04-15, 384.67
2006-04-22, 384.71
2006-04-29, 384.62
2006-05-06, 384.91
2006-05-13, 384.87
2006-05-20, 385.34
2006-05-27, 384.30
2006-06-03, 384.29
2006-06-10, 384.31
2006-06-17, 384.07
2006-06-24, 383.55
2006-07-01, 383.00
2006-07-08, 382.78
2006-07-15, 381.28
2006-07-22, 381.81
2006-07-29, 381.55
2006-08-05, 381.22
2006-08-12, 380.63
2006-08-19, 380.20
2006-08-26, 379.77
2006-09-02, 379.52
2006-09-09, 378.66
2006-09-16, 378.80
2006-09-23, 378.49
2006-09-30, 379.00
2006-10-07, 378.78
2006-10-14, 379.14
2006-10-21, 379.22
2006-10-28, 379.57
2006-11-04, 379.67
2006-11-11, 379.81
2006-11-18, 379.98
2006-11-25, 381.42
2006-12-02, 381.31
2006-12-09, 381.60
2006-12-16, 381.81
2006-12-23, 381.96
2006-12-30, 381.76
2007-01-06, 382.64
2007-01-13, 382.36
2007-01-20, 381.84
2007-02-03, 383.09
2007-02-10, 383.60
2007-02-17, 384.22
2007-02-24, 383.76
2007-03-03, 383.71
2007-03-10, 383.64
2007-03-17, 384.28
2007-03-24, 384.96
2007-03-31, 385.93
2007-04-07, 385.46
2007-04-14, 386.30
2007-04-21, 387.00
2007-04-28, 386.42
2007-05-05, 385.85
2007-05-12, 386.54
2007-05-19, 386.03
2007-05-26, 386.93
2007-06-02, 386.60
2007-06-09, 386.23
2007-06-16, 386.29
2007-06-23, 384.95
2007-06-30, 384.85
2007-07-07, 384.92
2007-07-14, 384.75
2007-07-21, 383.97
2007-07-28, 383.41
2007-08-04, 382.51
2007-08-11, 381.72
2007-08-18, 381.60
2007-08-25, 381.67
2007-09-01, 381.69
2007-09-08, 380.74
2007-09-15, 380.75
2007-09-22, 380.94
2007-09-29, 380.80
2007-10-06, 380.68
2007-10-13, 380.68
2007-10-20, 381.10
2007-10-27, 381.36
2007-11-03, 381.76
2007-11-10, 381.92
2007-11-17, 382.43
2007-11-24, 382.91
2007-12-01, 382.90
2007-12-08, 383.31
2007-12-15, 383.79
2007-12-22, 383.90
2007-12-29, 384.04
2008-01-05, 384.36
2008-01-12, 384.41
2008-01-19, 385.47
2008-01-26, 386.06
2008-02-02, 386.19
2008-02-09, 385.72
2008-02-16, 385.58
2008-02-23, 385.24
2008-03-01, 384.88
2008-03-08, 385.88
2008-03-15, 385.64
2008-03-22, 386.17
2008-03-29, 386.70
2008-04-05, 388.00
2008-04-12, 385.90
2008-04-19, 386.38
2008-04-26, 387.19
2008-05-03, 386.94
2008-05-10, 388.90
2008-05-17, 388.84
2008-05-24, 388.53
2008-05-31, 388.48
2008-06-07, 388.16
2008-06-14, 387.79
2008-06-21, 387.54
2008-06-28, 388.11
2008-07-05, 387.08
2008-07-12, 386.11
2008-07-19, 385.73
2008-07-26, 385.96
2008-08-02, 384.91
2008-08-09, 384.68
2008-08-16, 383.89
2008-08-23, 383.55
2008-08-30, 383.16
2008-09-06, 383.18
2008-09-13, 383.37
2008-09-20, 382.98
2008-09-27, 382.92
2008-10-04, 382.66
2008-10-11, 382.72
2008-10-18, 382.96
2008-10-25, 382.94
2008-11-01, 383.61
2008-11-08, 383.60
2008-11-15, 384.03
2008-11-22, 384.32
2008-11-29, 384.46
2008-12-06, 384.77
2008-12-13, 384.89
2008-12-20, 385.15
2008-12-27, 385.80
2009-01-03, 386.01
2009-01-10, 386.53
2009-01-17, 386.64
2009-01-24, 387.05
2009-01-31, 387.26
2009-02-07, 386.51
2009-02-14, 387.44
2009-02-21, 387.40
2009-02-28, 387.48
2009-03-07, 388.54
2009-03-14, 388.64
2009-03-21, 388.44
2009-03-28, 389.17
2009-04-04, 389.39
2009-04-11, 389.74
2009-04-18, 388.67
2009-04-25, 390.37
2009-05-02, 390.16
2009-05-09, 389.87
2009-05-16, 390.30
2009-05-23, 390.76
2009-05-30, 389.35
2009-06-06, 390.46
2009-06-13, 390.01
2009-06-20, 388.88
2009-06-27, 388.72
2009-07-04, 388.30
2009-07-11, 388.68
2009-07-18, 388.03
2009-07-25, 387.48
2009-08-01, 387.16
2009-08-08, 386.67
2009-08-15, 385.27
2009-08-22, 386.05
2009-08-29, 385.65
2009-09-05, 385.30
2009-09-12, 384.48
2009-09-19, 384.61
2009-09-26, 384.51
2009-10-03, 383.43
2009-10-10, 384.28
2009-10-17, 384.55
2009-10-24, 384.79
2009-10-31, 385.18
2009-11-07, 385.60
2009-11-14, 386.09
2009-11-21, 386.31
2009-11-28, 386.73
2009-12-05, 386.91
2009-12-12, 386.81
2009-12-19, 388.04
2009-12-26, 388.19
2010-01-02, 388.41
2010-01-09, 388.17
2010-01-16, 388.69
2010-01-23, 388.59
2010-01-30, 389.04
2010-02-06, 390.91
2010-02-13, 389.78
2010-02-20, 390.84
2010-02-27, 389.38
2010-03-06, 391.07
2010-03-13, 391.37
2010-03-20, 391.55
2010-03-27, 390.08
2010-04-03, 391.15
2010-04-10, 391.60
2010-04-17, 393.27
2010-04-24, 393.27
2010-05-01, 392.99
2010-05-08, 392.97
2010-05-15, 393.13
2010-05-22, 393.55
2010-05-29, 393.02
2010-06-05, 393.08
2010-06-12, 392.35
2010-06-19, 391.73
2010-06-26, 391.46
2010-07-03, 391.01
2010-07-10, 390.20
2010-07-17, 389.91
2010-07-24, 390.12
2010-07-31, 389.49
2010-08-07, 389.06
2010-08-14, 388.76
2010-08-21, 388.12
2010-08-28, 387.42
2010-09-04, 386.91
2010-09-11, 386.85
2010-09-18, 386.97
2010-09-25, 386.87
2010-10-02, 386.75
2010-10-09, 386.98
2010-10-16, 387.03
2010-10-23, 387.80
2010-10-30, 387.78
2010-11-06, 387.95
2010-11-13, 388.27
2010-11-20, 389.11
2010-11-27, 389.59
2010-12-04, 389.88
2010-12-11, 389.75
2010-12-18, 389.58
2010-12-25, 389.96
2011-01-01, 390.50
2011-01-08, 391.61
2011-01-15, 391.06
2011-01-22, 391.25
2011-01-29, 392.00
2011-02-05, 391.89
2011-02-12, 391.52
2011-02-19, 391.82
2011-02-26, 392.50
2011-03-05, 391.59
2011-03-12, 391.94
2011-03-19, 392.43
2011-03-26, 394.11
2011-04-02, 393.40
2011-04-09, 392.71
2011-04-16, 393.73
2011-04-23, 393.22
2011-04-30, 393.59
2011-05-07, 393.36
2011-05-14, 393.84
2011-05-21, 395.12
2011-05-28, 394.49
2011-06-04, 394.08
2011-06-11, 393.42
2011-06-18, 393.92
2011-06-25, 393.37
2011-07-02, 393.31
2011-07-09, 393.61
2011-07-16, 392.64
2011-07-23, 391.13
2011-07-30, 391.77
2011-08-06, 390.76
2011-08-13, 390.53
2011-08-20, 389.82
2011-08-27, 389.41
2011-09-03, 389.23
2011-09-10, 389.17
2011-09-17, 389.15
2011-09-24, 388.86
2011-10-01, 388.91
2011-10-08, 388.74
2011-10-15, 388.91
2011-10-22, 389.09
2011-10-29, 389.45
2011-11-05, 389.64
2011-11-12, 390.24
2011-11-19, 390.44
2011-11-26, 390.77
2011-12-03, 391.08
2011-12-10, 391.70
2011-12-17, 392.24
2011-12-24, 392.09
2011-12-31, 392.26
2012-01-07, 392.92
2012-01-14, 393.61
2012-01-21, 393.04
2012-01-28, 393.03
2012-02-04, 392.43
2012-02-11, 393.45
2012-02-18, 393.97
2012-02-25, 393.62
2012-03-03, 394.17
2012-03-10, 393.38
2012-03-17, 394.79
2012-03-24, 395.15
2012-03-31, 394.91
2012-04-07, 396.45
2012-04-14, 396.38
2012-04-21, 396.56
2012-04-28, 396.70
2012-05-05, 397.08
2012-05-12, 397.28
2012-05-19, 396.56
2012-05-26, 396.28
2012-06-02, 396.03
2012-06-09, 396.02
2012-06-16, 395.86
2012-06-23, 395.73
2012-06-30, 395.41
2012-07-07, 394.86
2012-07-14, 394.59
2012-07-21, 394.35
2012-07-28, 393.60
2012-08-04, 393.39
2012-08-11, 392.93
2012-08-18, 392.31
2012-08-25, 391.70
2012-09-01, 391.98
2012-09-08, 391.00
2012-09-15, 391.03
2012-09-22, 391.02
2012-09-29, 390.99
2012-10-20, 391.29
2012-10-27, 391.46
2012-11-03, 391.76
2012-11-10, 392.77
2012-11-17, 393.42
2012-11-24, 393.36
2012-12-01, 393.61
2012-12-08, 394.05
2012-12-15, 394.46
2012-12-22, 394.83
2012-12-29, 394.62
2013-01-05, 394.99
2013-01-12, 395.57
2013-01-19, 396.21
2013-01-26, 395.64
2013-02-02, 396.39
2013-02-09, 396.46
2013-02-16, 397.31
2013-02-23, 396.88
2013-03-02, 397.13
2013-03-09, 396.64
2013-03-16, 397.25
2013-03-23, 397.21
2013-03-30, 398.39
2013-04-06, 398.05
2013-04-13, 397.43
2013-04-20, 398.76
2013-04-27, 399.33
2013-05-04, 399.64
2013-05-11, 399.78
2013-05-18, 400.04
2013-05-25, 400.22
2013-06-01, 399.43
2013-06-08, 398.91
2013-06-15, 398.58
2013-06-22, 398.50
2013-06-29, 398.65
2013-07-06, 397.56
2013-07-13, 397.48
2013-07-20, 396.83
2013-07-27, 396.98
2013-08-03, 396.61
2013-08-10, 395.55
2013-08-17, 395.24
2013-08-24, 394.73
2013-08-31, 394.33
2013-09-07, 393.52
2013-09-14, 393.25
2013-09-21, 393.53
2013-09-28, 393.22
2013-10-05, 393.47
2013-10-12, 393.52
2013-10-19, 393.93
2013-10-26, 394.13
2013-11-02, 394.39
2013-11-09, 395.25
2013-11-16, 394.85
2013-11-23, 395.66
2013-11-30, 396.06
2013-12-07, 396.27
2013-12-14, 396.52
2013-12-21, 397.30
2013-12-28, 397.59
2014-01-04, 397.90
2014-01-11, 397.82
2014-01-18, 398.13
2014-01-25, 397.75
2014-02-01, 398.02
2014-02-08, 397.98
2014-02-15, 397.79
2014-02-22, 398.24
2014-03-01, 397.92
2014-03-08, 398.88
2014-03-15, 400.68
2014-03-22, 399.62
2014-03-29, 400.34
2014-04-05, 401.32
2014-04-12, 401.22
2014-04-19, 401.29
2014-04-26, 401.42
2014-05-03, 401.74
2014-05-10, 401.51
2014-05-17, 402.18
2014-05-24, 401.44
2014-05-31, 402.12
2014-06-07, 401.55
2014-06-14, 401.31
2014-06-21, 401.21
2014-06-28, 400.57
2014-07-05, 400.06
2014-07-12, 399.58
2014-07-19, 398.54
2014-07-26, 397.86
2014-08-02, 397.86
2014-08-09, 397.45
2014-08-16, 397.23
2014-08-23, 396.75
2014-08-30, 396.37
2014-09-06, 396.35
2014-09-13, 394.80
2014-09-20, 395.32
2014-09-27, 395.55
2014-10-04, 395.57
2014-10-11, 395.49
2014-10-18, 395.72
2014-10-25, 395.91
2014-11-01, 396.52
2014-11-08, 396.90
2014-11-15, 397.34
2014-11-22, 397.24
2014-11-29, 398.10
2014-12-06, 398.26
2014-12-13, 398.92
2014-12-20, 399.09
2014-12-27, 399.01
2015-01-03, 399.92
2015-01-10, 399.86
2015-01-17, 399.72
2015-01-24, 399.98
2015-01-31, 400.20
2015-02-07, 400.02
2015-02-14, 400.15
2015-02-21, 400.36
2015-02-28, 401.03
2015-03-07, 401.63
2015-03-14, 401.80
2015-03-21, 400.79
2015-03-28, 402.50
2015-04-04, 402.74
2015-04-11, 403.88
2015-04-18, 403.80
2015-04-25, 403.22
2015-05-02, 404.07
2015-05-09, 404.09
2015-05-16, 404.31
2015-05-23, 403.85
2015-05-30, 403.81
2015-06-06, 403.45
2015-06-13, 402.72
2015-06-20, 402.63
2015-06-27, 402.36
2015-07-04, 402.25
2015-07-11, 401.71
2015-07-18, 401.02
2015-07-25, 401.30
2015-08-01, 398.74
2015-08-08, 399.21
2015-08-15, 399.12
2015-08-22, 399.03
2015-08-29, 398.80
2015-09-05, 398.16
2015-09-12, 397.10
2015-09-19, 397.57
2015-09-26, 397.42
2015-10-03, 397.74
2015-10-10, 398.51
2015-10-17, 398.61
2015-10-24, 398.43
2015-10-31, 398.87
2015-11-07, 399.53
2015-11-14, 400.75
2015-11-21, 400.42
2015-11-28, 400.83
2015-12-05, 400.91
2015-12-12, 402.40
2015-12-19, 402.32
2015-12-26, 402.01
2016-01-02, 402.25
2016-01-09, 402.23
2016-01-16, 402.68
2016-01-23, 403.26
2016-01-30, 402.79
2016-02-06, 404.98
2016-02-13, 403.22
2016-02-20, 404.59
2016-02-27, 403.98
2016-03-05, 403.99
2016-03-12, 404.51
2016-03-19, 405.01
2016-03-26, 406.16
2016-04-02, 405.70
2016-04-09, 408.56
2016-04-16, 408.16
2016-04-23, 407.70
2016-04-30, 407.84
2016-05-07, 407.51
2016-05-14, 407.54
2016-05-21, 407.41
2016-05-28, 407.92
2016-06-04, 407.52
2016-06-11, 406.99
2016-06-18, 407.02
2016-06-25, 406.40
2016-07-02, 405.96
2016-07-09, 404.93
2016-07-16, 403.64
2016-07-23, 403.71
2016-07-30, 403.76
2016-08-06, 403.22
2016-08-13, 402.11
2016-08-20, 401.78
2016-08-27, 401.43
2016-09-03, 401.27
2016-09-10, 401.13
2016-09-17, 401.25
2016-09-24, 400.85
2016-10-01, 400.82
2016-10-08, 401.20
2016-10-15, 401.70
2016-10-22, 401.82
2016-10-29, 402.38
2016-11-05, 403.15
2016-11-12, 403.12
2016-11-19, 403.95
2016-11-26, 404.44
2016-12-03, 404.16
2016-12-10, 404.28
2016-12-17, 404.63
2016-12-24, 404.66
2016-12-31, 405.38
2017-01-07, 405.94
2017-01-14, 405.91
2017-01-21, 406.37
2017-01-28, 406.35
2017-02-04, 406.20
2017-02-11, 406.02
2017-02-18, 406.17
2017-02-25, 408.07
2017-03-04, 407.06
2017-03-11, 406.53
2017-03-18, 406.73
2017-03-25, 407.89
2017-04-01, 408.66
2017-04-08, 407.19
2017-04-15, 409.12
2017-04-22, 409.89
2017-04-29, 409.04
2017-05-06, 409.54
2017-05-13, 409.83
2017-05-20, 410.18
2017-05-27, 409.88
2017-06-03, 409.67
2017-06-10, 409.62
2017-06-17, 408.82
2017-06-24, 408.43
2017-07-01, 407.77
2017-07-08, 407.68
2017-07-15, 407.11
2017-07-22, 406.76
2017-07-29, 406.50
2017-08-05, 405.93
2017-08-12, 405.55
2017-08-19, 404.81
2017-08-26, 404.54
2017-09-02, 404.10
2017-09-09, 403.39
2017-09-16, 403.44
2017-09-23, 402.95
2017-09-30, 402.73
2017-10-07, 403.19
2017-10-14, 403.60
2017-10-21, 404.05
2017-10-28, 404.25
2017-11-04, 404.28
2017-11-11, 404.51
2017-11-18, 405.53
2017-11-25, 406.36
2017-12-02, 406.85
2017-12-09, 406.16
2017-12-16, 406.50
2017-12-23, 407.07
2017-12-30, 407.24
2018-01-06, 407.96
2018-01-13, 408.08
2018-01-20, 408.26
2018-01-27, 408.05
2018-02-03, 407.63
2018-02-10, 408.41
2018-02-17, 408.46
2018-02-24, 408.69
2018-03-03, 408.77
2018-03-10, 409.64
2018-03-17, 408.69
2018-03-24, 409.77
2018-03-31, 409.63
2018-04-07, 409.41
2018-04-14, 410.10
2018-04-21, 411.36
2018-04-28, 410.58
2018-05-05, 409.75
2018-05-12, 411.62
2018-05-19, 411.43
2018-05-26, 411.81
2018-06-02, 411.15
2018-06-09, 411.24
2018-06-16, 410.56
2018-06-23, 410.81
2018-06-30, 410.19
2018-07-07, 409.29
2018-07-14, 409.07
2018-07-21, 408.49
2018-07-28, 408.08
2018-08-04, 407.36
2018-08-11, 407.28
2018-08-18, 407.07
2018-08-25, 406.63
2018-09-01, 405.98
2018-09-08, 405.61
2018-09-15, 405.60
2018-09-22, 405.69
2018-09-29, 405.56
2018-10-06, 405.56
2018-10-13, 405.91
2018-10-20, 406.42
2018-10-27, 406.51
2018-11-03, 406.83
2018-11-10, 407.69
2018-11-17, 409.11
2018-11-24, 408.46
2018-12-01, 408.56
2018-12-08, 408.92
2018-12-15, 409.56
2018-12-22, 409.73
2018-12-29, 409.26
2019-01-05, 410.32
2019-01-12, 409.73
2019-01-19, 412.31
2019-01-26, 410.91
2019-02-02, 410.97
2019-02-09, 412.12
2019-02-16, 411.79
2019-02-23, 411.46
2019-03-02, 412.08
2019-03-09, 412.26
2019-03-16, 412.87
2019-03-23, 410.73
2019-03-30, 412.37
2019-04-06, 412.62
2019-04-13, 413.36
2019-04-20, 413.94
2019-04-27, 414.27
2019-05-04, 414.41
2019-05-11, 414.95
2019-05-18, 415.08
2019-05-25, 414.66
2019-06-01, 414.21
2019-06-08, 414.45
2019-06-15, 413.85
2019-06-22, 413.68
2019-06-29, 413.38
2019-07-06, 412.69
2019-07-13, 412.30
2019-07-20, 411.76
2019-07-27, 410.32
2019-08-03, 410.50
2019-08-10, 410.48
2019-08-17, 410.05
2019-08-24, 409.52
2019-08-31, 409.32
2019-09-07, 408.80
2019-09-14, 408.61
2019-09-21, 408.50
2019-09-28, 408.28
2019-10-05, 407.99
2019-10-12, 408.61
2019-10-19, 408.77
2019-10-26, 408.68
2019-11-02, 409.86
2019-11-09, 410.15
2019-11-16, 410.22
2019-11-23, 410.48
2019-11-30, 410.92
2019-12-07, 411.27
2019-12-14, 411.67
2019-12-21, 412.30
2019-12-28, 412.59
2020-01-04, 413.19
2020-01-11, 413.39
2020-01-25, 413.36
2020-02-01, 413.99
2020-02-08, 414.83
2020-02-15, 413.81
2020-02-22, 414.17
2020-02-29, 413.89
2020-03-07, 414.00
2020-03-14, 414.30
2020-03-21, 414.62
2020-03-28, 415.57
2020-04-04, 415.61
2020-04-11, 416.47
2020-04-18, 416.60
2020-04-25, 415.86
2020-05-02, 417.20
2020-05-09, 416.99
2020-05-16, 416.54
2020-05-23, 417.49
2020-05-30, 417.19
2020-06-06, 416.49
2020-06-13, 416.50
2020-06-20, 416.11
2020-06-27, 415.75
2020-07-04, 415.20
2020-07-11, 414.91
2020-07-18, 414.29
2020-07-25, 413.63
2020-08-01, 413.42
2020-08-08, 412.85
2020-08-15, 412.75
2020-08-22, 412.25
2020-08-29, 411.79
2020-09-05, 411.55
2020-09-12, 411.45
2020-09-19, 411.17
2020-09-26, 411.06
2020-10-03, 411.08
2020-10-10, 411.14
2020-10-17, 411.16
2020-10-24, 411.54
2020-10-31, 411.92
2020-11-07, 412.37
2020-11-14, 412.67
2020-11-21, 412.98
2020-11-28, 414.32
