8388c1425d3a684d1ec014af187ba020
2b07cb57
2b07cb57
Update toy_document_orgmode_python_en.org
2f558eee
21 additions
29 deletions
+21
-29
module2/exo1/toy_document_orgmode_python_en.org
+21
-29
2b07cb57
#+TITLE: Mr.
#+TITLE: On the computation of pi
#+AUTHOR: Bikash Adhikari
#+DATE: 23/03/2020
#+DATE: 23/03/2020
#+LANGUAGE: en
#+LANGUAGE: en
#+PROPERTY: header-args :session :export both
* Table of Contents
* [[1. Asking the math library]]
* [[2. *Buffon's needle]]
* [[3. Using a surface fraction argument]]
* Asking the math library
* 1. Asking the math library
My computer tells me that $\pi$ is /approximately/
My computer tells me that \pi is /approximately/
#+begin_src python :results value :session *python* :export both
from math import *
from math import *
pi
pi
* 2. *Buffon's needle
Applying the method of [[https://en.wikipedia.org/wiki/Buffon%27s_needle_problem][_Buffon's needle_]], we get the *approximation*
* * Buffon's needle
np.random.seed(seed=42)
N
10000
N
10000
x
=np.random.uniform(size=N, low =0, high=pi/2
x
= np.random.uniform(size=N, low=0, high=1
theta
=np.random.uniform(size=N, low=0, high =
pi/2)
theta
pi/2)
2/(sum((x+np.sin(theta))>1)/N)
* Using a surface fraction argument
* 3. Using a surface fraction argument
A method that is easier to understand and does not make use of the sin
function is based on the fact that if $X \sim U(0,1)$ and $Y \sim
U(0,1)$, then $P[X^2 + Y^2 \leq 1] = \pi/4$ (see [[https://en.wikipedia.org/wiki/Monte_Carlo_method][_"Monte Carlo method on
Wikipedia"_]]). THe following code use this approach:
[[https://en.wikipedia.org/wiki/Monte_Carlo_method][ _"Monte Carlo method" on
Wikipedia_]]). The following code use this approach:
@@ -68,7 +61,6 @@ print(matplot_lib_filename)
It is then straightforward to obtain a (not really good) approximation
of \pi by counting how many time, on average, $X^2$ + $^{}Y^2$ is smaller
than 1:
than 1:
4*np.mean(accept)
4*np.mean(accept)
