Commit 18776da4 authored by Julie Plantade's avatar Julie Plantade
Analyse d'une distribution de 100 valeurs
parent 9a85b7b7
title: "Votre titre"
author: "Votre nom"
date: "La date du jour"
title: "Analyse d'une distribution de 100 valeurs"
author: "Julie Plantade"
date: "Lundi 27 février 2023"
output: html_document
```{r setup, include=FALSE}
library(ggplot2)
## Quelques explications
```{r plot, echo=FALSE, message=FALSE}
# Import des données
d <- c(14.0, 7.6, 11.2, 12.8, 12.5, 9.9, 14.9, 9.4, 16.9, 10.2, 14.9, 18.1, 7.3, 9.8, 10.9,12.2, 9.9, 2.9, 2.8, 15.4, 15.7, 9.7, 13.1, 13.2, 12.3, 11.7, 16.0, 12.4, 17.9, 12.2, 16.2, 18.7, 8.9, 11.9, 12.1, 14.6, 12.1, 4.7, 3.9, 16.9, 16.8, 11.3, 14.4, 15.7, 14.0, 13.6, 18.0, 13.6, 19.9, 13.7, 17.0, 20.5, 9.9, 12.5, 13.2, 16.1, 13.5, 6.3, 6.4, 17.6, 19.1, 12.8, 15.5, 16.3, 15.2, 14.6, 19.1, 14.4, 21.4, 15.1, 19.6, 21.7, 11.3, 15.0, 14.3, 16.8, 14.0, 6.8, 8.2, 19.9, 20.4, 14.6, 16.4, 18.7, 16.8, 15.8, 20.4, 15.8, 22.4, 16.2, 20.3, 23.4, 12.1, 15.5, 15.4, 18.4, 15.7, 10.2, 8.9, 21.0)
d <- as.data.frame(d)
# Calcul de la moyenne
d_mean <- mean(d$d)
# Calcul des valeurs extrêmes
d_min <- min(d$d)
d_max <- max(d$d)
# Calcul de la médiane
d_med <- median(d$d)
# Calcul de l'écart type
d_sd <- sd(d$d)
```{r pressure, echo=FALSE}
plot(pressure)
g <- ggplot(data = d,
mapping = aes(x = d)) +
geom_histogram(color = "black",
fill = "purple") +
theme_minimal()
g
# Caractéristiques de la distribution
- Moyenne = `r d_mean`
- Médiane = `r d_med`
- Ecart-type = `r d_sd`
- Valeur minimale = `r d_min`
- Valeur maximale = `r d_max`
