# Calcul de la moyenne
d_mean <- mean(d$d)
# Calcul des valeurs extrêmes
d_min <- min(d$d)
d_max <- max(d$d)
# Calcul de la médiane
d_med <- median(d$d)
# Calcul de l'écart type
d_sd <- sd(d$d)
```{r pressure, echo=FALSE}
plot(pressure)
g <- ggplot(data = d,
mapping = aes(x = d)) +
geom_histogram(color = "black",
fill = "purple") +
theme_minimal()
g
# Caractéristiques de la distribution
- Moyenne = `r d_mean`
- Médiane = `r d_med`
- Ecart-type = `r d_sd`
- Valeur minimale = `r d_min`
- Valeur maximale = `r d_max`
