Completed toy_document_fr.Rmd
parent ab841822
title: "Votre titre"
author: "Votre nom"
date: "La date du jour"
title: "Exercise 2 R-studio"
author: "Husnain Arshad"
date: "8/14/2022"
output: html_document
```{r setup, include=FALSE}
## Quelques explications
# À propos de pi
pi
## Buffon’s needle
Applying the method of Buffon’s needle:[Buffon's needle](https://fr.wikipedia.org/wiki/Aiguille_de_Buffon)
set.seed(42)
N = 100000
x = runif(N)
theta = pi/2*runif(N)
2/(mean(x+sin(theta)>1))
## Using Fraction arguement
A method that is easier to understand and does not make use of the sin function is based on the fact that if X∼U(0,1) and Y∼U(0,1), then P[X2+Y2≤1]=π/4 [Mont carlo method](https://en.wikipedia.org/wiki/Monte_Carlo_method). The following code uses this approach:
```{r pressure, echo=FALSE}
plot(pressure)
set.seed(42)
N = 1000
library(ggplot2)
It is therefore straightforward to obtain a (not really good) approximation to π by counting how many times, on average, X2+Y2 is smaller than 1 :
4*mean(df$Accept)
