Module 3 partie 2
parent eca42a5d
...@@ -576,81 +576,128 @@ ...@@ -576,81 +576,128 @@
"execution_count": 123, "execution_count": 142,
"outputs": [], "outputs": [],
"source": [ "source": [
"c=0\n", "c=0\n",
"m=0\n", "m=0\n",
"o=0\n",
"p=0\n",
"a=0\n",
"b=0\n",
"v=0\n",
"w=0\n",
"for j in range(0,1314):\n", "for j in range(0,1314):\n",
" if int(data.values[j,2])>=18 & int(data.values[j,2])<=34:\n",
" if 'Yes' in data.values[j,0]:\n", " if 'Yes' in data.values[j,0]:\n",
" m=m+1\n", " m=m+1\n",
" if 'Dead' in data.values[j,1]:\n", " if 'Dead' in data.values[j,1]:\n",
" c=c+1" " c=c+1\n",
" if int(data.values[j,2])>=35 & int(data.values[j,2])<=54:\n",
" o=o+1\n",
" p=p+1\n",
" if int(data.values[j,2])>=55 & int(data.values[j,2])<=64:\n",
" a=a+1\n",
" b=b+1\n",
" if int(data.values[j,2])>=65:\n",
" w=w+1\n",
" v=v+1"
"execution_count": 124, "execution_count": 146,
"outputs": [ "outputs": [
"data": { "data": {
"text/plain": [ "text/plain": [
"23.883161512027492" "(23.883161512027492, 23.883161512027492, 23.883161512027492, 85.71428571428571)"
"output_type": "execute_result" "output_type": "execute_result"
"(c/m)*100" "(c/m)*100,(p/o)*100,(b/a)*100,(v/w)*100\n",
"\n"
"execution_count": 125, "execution_count": 149,
"f=0\n", "c=0\n",
"n=0\n", "m=0\n",
"o=0\n",
"p=0\n",
"a=0\n",
"b=0\n",
"v=0\n",
"w=0\n",
" if 'No' in data.values[j,0]:\n",
" m=m+1\n",
" c=c+1\n",
" o=o+1\n",
" p=p+1\n",
" a=a+1\n",
" b=b+1\n",
" if 'No' in data.values[j,0]:\n", " if 'No' in data.values[j,0]:\n",
" f=f+1\n", " w=w+1\n",
" n=n+1" " v=v+1"
"execution_count": 126, "execution_count": 150,
"data": { "data": {
"31.420765027322407" "(31.420765027322407, 31.420765027322407, 31.420765027322407, 85.49222797927462)"
"(n/f)*100" "(c/m)*100,(p/o)*100,(b/a)*100,(v/w)*100"
"cell_type": "markdown", "cell_type": "markdown",
"Le taux de mortalité dans les fummeures est 23.88%\n", "Le taux de mortalité dans les fummeures et les non fummeures pour les trois premiers catogerie de l'age est la meme mais plus que 65 ans ce taux augmente beaucoup\n",
"Le taux de mortalité dans les non fummeures est 31.42%\n", "Pour plus 65 ans le taux de mortalite des fumeurs est plu que les non fumeurs contrairement au trois premier categories"
"Le resultat est surprenant car le pourentage des non fummeures est superieurs a celle des fummeurs ce qui n'est pas prevu ( fummer = mourire)"
