a58a0dd3
a58a0dd3
Minor rephrasing
cfc34e67
6 additions
8 deletions
+6
-8
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+6
-8
a58a0dd3
@@ -146,22 +146,20 @@ this up but if you have any trouble, feel free to ask on the FUN
forums.
** A stub of replicable article
Remember, you need a working LaTeX and R environment. If you can't
open a terminal and run the commands =R=
and =pdflatex
=, you will not be
able to generate this document.
T
he article downloads the
, =pdflatex=, and =python
=, you will not be
When being compiled, t
corresponding LaTeX packages so you also need to have a working =wget=
command (alternatively,
you can use =curl=). Y
ou may still read the
it uses =curl=). Once downloaded, y
source ([[file:replicable_article/article.org][article.org]]) and understand how it works though.
#+begin_src shell :results output :exports none
make -C replicable_article/ replicable_article.tgz
all
: make : on entre dans le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article »
: tar --xform "s|^|replicable_article/|" -zcf replicable_article.tgz article.org biblio.bib Makefile
: make : on quitte le répertoire « /home/alegrand/Work/Documents/Enseignements/RR_MOOC/references/module2/replicable_article »
Download the following [[file:replicable_article/replicable_article.tgz][archive]] and untar it.
Download the [[file:replicable_article/replicable_article.tgz][archive]], untar it and simply make
to generate the
and simply =make=
to generate the
article. You should then be able to open the [[file:replicable_article/article.pdf][resulting article]]. This
is summarized in the following command:
#+begin_src sh :results output :exports both
