df8c66c8
df8c66c8
Update link which recently moved from github to gitlab.
c099a890
2
2 changed files
4 additions
4 deletions
+4
-4
emacs_orgmode.html
module2/ressources/emacs_orgmode.html
+2
-2
emacs_orgmode.org
module2/ressources/emacs_orgmode.org
+2
-2
df8c66c8
@@ -143,7 +143,7 @@ which is now deprecated.
<ul
class=
"org-ul"
<li
style=
"margin-bottom:0;"
><p>
<b>
Option 1
</b>
: Install the
<code>
.dmg
</code>
file from
<a
href=
"http://vgoulet.act.ulaval.ca/"
Vincent Goulet
</a>
<a
href=
"https://vigou3.git
hub.io/emacs-modified-macos/"
https://vigou3.githu
</a>
. It ships with recent
<a
href=
"https://vigou3.git
lab.io/emacs-modified-macos/"
https://vigou3.gitla
</a>
versions:
</p>
<ul
class=
"org-ul"
@@ -195,7 +195,7 @@ in order to make Emacs accessible directly from <code>/Applications</code>.
<div
class=
"outline-text-3"
id=
"text-org9f08150"
<p>
Install the
<code>
.exe
</code>
file from
<a
href=
Vincent Goulet
</a>
<a
href=
"https://vigou3.git
hub.io/emacs-modified-windows/"
</a>
<a
href=
"https://vigou3.git
lab.io/emacs-modified-windows/"
</a>
versions:
</p>
<ul
class=
"org-ul"
df8c66c8
@@ -59,7 +59,7 @@ which is now deprecated.
*Note:* macOS comes with a prehistoric command-line-only version of Emacs located at =/usr/bin/emacs=. It's best to forget about it.
- *Option 1*: Install the =.dmg= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]:
https://vigou3.git
hu
b.io/emacs-modified-macos/. It ships with recent
https://vigou3.git
la
versions:
- Emacs 26.1
- Org-mode 9.1.13
@@ -92,7 +92,7 @@ which is now deprecated.
in order to make Emacs accessible directly from =/Applications=.
** Windows
Install the =.exe= file from [[http://vgoulet.act.ulaval.ca/][Vincent Goulet]]:
https://vigou3.git
hu
b.io/emacs-modified-windows/. It ships with recent
https://vigou3.git
la
versions:
- Emacs 26.1
- Org-mode 9.1.13
